Where to find S-Record format documentation
AndersJ
Where can I find an updated document that
in detail describes the S-Record format?
Anders J
Alban
Senior Contributor II
You can fins it by using the search engine at the bottom of the Forums.
Also, using the search engine at the top of every single page is a fine idea !
Search for "s-record"...
Cheers,
Alban.
AndersJ
I did try the search, but found nothing really useful.
I need a document, preferably a Motorola document,
that descibes the S-Records fully.
Most docs I've seen do not discuss ALL record types. Only S0, S1 and S9.
AJ
Alban
The second link of the first result of the search for "S-Record", which is kindly repeated by Mike in this thread, does cover "ALL record types".
Cheers,
Alban.
AndersJ
True!
I don't see why I missed it.
Thanks Mike, and Alban.
Anders
mke_et
