as far as i know, it depends on the host i.e. a PC in this case.
Difference Between USB 2.0 Full Speed and USB 2.0 High Speed Devices:
- USB 2.0 full speed is transferring data at the same speed as USB 1.1 full speed (12Mbps), but uses protocols that allow for faster devices to be connected to the same hub or system on newer (now older) model computers in the market.
- USB 2.0 high speed is transferring data at (480Mbps).
iggi
