Stack pointer
Stack pointer
Eric_t
Hi everybody,
I am using HCS12 controllers and Codewarrior v3.1.
Is it possible to read the current position of the SP and put it in a integer variable?
Nikos
MJW
Hello Nikos,
you can, for example, try this:
/*declaration*/
unsigned short oldsp;
     /* save current SP */
     asm {
          STS oldsp
Best Regards.
MJW
MJW
Hello Nikos,
/*declaration*/
     asm {
          STS oldsp
Best Regards.
MJW
Eric_t
Thanks Jens Winkler
It works
Nikos
