S912ZVML128 Desaturation Error Issue
dannydeng
Dears,
    I am designing in a EOP system used S912ZVML128 . I tested the prototype, found the desaturation error trigged not steady. Here is my  testing result,
Ids / A         Vds / V                           Time delay after tBLANK / ns        Desaturation Error Flag Set?
10                  2.55                                             75                                                 Yes
20                  3.1                                               188                                                No
26                  2.2                                                98                                                 No
t BLANK is 2 us.
Can anybody give me any advice?
Thanks and Best Regards,
Ray Deng
alejandro_cervantes
Hello Ray,
I think tBLACK time is not set correctly
Could you tell me which is your core clock frequency and which is the values for register GDUCTR_GBKTIM2[3:0].
Also, how are you setting the test?
Could you share the part of the schematic where you are doing the test.
Thanks and best regards,
Alejandro
