S12Z example code for CAN driver @Radek #CanDriver
hajerbalti
Is there from NXP actual code example for CAN driver for S12Z?
danielmartynek
There is a very simple application note for MSCAN on the MagniV (AN4975) with software.
But because the MSCAN module used on MagniV is the same as the module on S12XE, you can refer to MSCANDriver For S12 + S12X.
