S12VR64 write flash
已解决
S12VR64 write flash
跳至解决方案
2,153 次查看
阳骏韩
Hello there. I use S12VR64 chip, I need to store a lot of data, eeprom is not enough to use. I want to store data in flash. I used the official NXP library to write to the flash address 0x30000, but in fact the corresponding address does not show the value I wrote.
1 解答
2,012 次查看
dianabatrlova
I recommend you look at the AN4448 SW. There is a flash demo example code for the S12VR64:
MC9S12VR Family Demonstration Lab Training:
http://cache.freescale.com/files/microcontrollers/doc/app_note/AN4448.pdf
Software:
http://cache.freescale.com/files/microcontrollers/doc/app_note/AN4448SW.zip
I hope it helps you.
Diana
在原帖中查看解决方案
2 回复数
2,012 次查看
dianabatrlova
Software:
Diana
2,012 次查看
阳骏韩
dear Diana,
The problem has been solved. Thank you for your help.
good luck,
yangjun Han
