S12G128 Overflow Interrupt Timer
ソリューションへジャンプ
2,671件の閲覧回数
rayhall
Contributor V
I have set up TIM with a overflow interrupt. The prescaler is set to precision. I want to set the overflow to exactly 10 msec. The prescaler does not give me a way to set to this time. It also seems that I cannot write to TCNT in the interrupt to control the next overflow time. How can I get the 10 msec I require.
Ray.
2,438件の閲覧回数
ZhangJennie
Hi Ray,
attached is processor expert demo code for 10ms overflow interrupt.
in the sample, system clock is 6.25M
interrupt frequency is 6.25M/65536=95.367Hz  that is around 10ms
can this help you?
Zhang Jun
3 返答(返信)
2,438件の閲覧回数
ZhangJennie
Hi Ray,
can this help you?
Zhang Jun
2,438件の閲覧回数
rayhall
Contributor V
Zhang Jun
Thank you.
Ray.
2,438件の閲覧回数
ZhangJennie
Hi Ray,
you are welcome!
Zhang Jun
