S12-Compiler -Error
S12-Compiler -Error
曾毅峰
How to resolve large-scale compilation errors? Below are some errors encountered during the build process. Engineers, please provide answers. Thank you.
如何解决大规模编译错误,以下是编译过程中遇到的一些错误。工程师们,请提供答案。谢谢。
错误导致工具中止。
mingw32-make: *** [来源/ADC_c.obj] 错误 1
mingw32-make: *** 正在等待未完成的工作......
mingw32-make: *** [来源/main_c.obj] 错误 1
stanish
Could you provide us with more details?
1) Which codewarrior version are you using?
2) Are you able yo build an empty project generated by project wizard for the MCU you are targetting?
3) The error message does not include any hint.  Can you send us entire build console listing? e.g. are you able to bulild at least some .c files?
4) can you delete your output folder (e.g. DEBUG_FLASH) and rebuld the project?
This will helpl us to find a rootcause much faster
Thanks.
Stan
