Regarding S12ZVM Eval kit Ballast option
pratibhasurabhi
Contributor V
Hi I am using S12ZVMx12EVB evaluation board.
on this kit instead of using an external ballast for generating VDDX , i want to generate it through internal regulator.
Can someone please tell me what all changes (Jumper settings ) are required to be performed to do that.
danielmartynek
Just disconnect the ballast transistor (J40 open).
