Problem using TC7 to also control TC3
2,816 次查看
JohnnyP
I'm using a 9s12C32 to control spark timing, using TC7 to also control TC3.
OC7D = 88 AND OC7M = 08.
After loading TC7, I ADDD $0032 into TC3, so TC3 should go low 100usec after TC7 ends, but TC3 instantly goes low when TC7 is loaded with the compare value.
BSET TIOS, $F8
LDAA #$88
STAA OC7M
LDAA #$08
STAA OC7D
LDD Delay
ADDD #$0002
ADDD TCNT
STD TC7
ADDD #$0032
STD TC3
3 回复数
2,746 次查看
JohnnyP
Oops, please edit my last post, as that doesn't really work.  It only works on every other spark event.
2,747 次查看
JohnnyP
Thanks for your reply but google Ai and I finally figured it out.  Here is the correct code:
; Assume PT3 has been properly set high via GPIO
; and the timer is already enabled via TSCR1:TEN
    ; Step 1: Disable OC3 to prepare for configuration
    BCLR TIOS, $08
    ; Step 2: Set TC3 to the immediate past
    LDD TCNT
    SUBD #$0001    STD TC3
    ; Step 3: Configure OC3 to "no action" (OM3:OL3 = 00)
    ; This ensures the pin is not affected when OC takes over.
    BCLR TCTL2, $C0
    ; Step 4: Re-enable OC3
    BSET TIOS, $08
    ; Step 5: Wait for the "past" compare event to occur and set its flag
zot:
    BRCLR TFLG1, $08, zot
    ; Step 6: Clear the timer flag for channel 3    LDAA #$08    STAA TFLG1
    ; Step 7: Set the TC3 for the future compare event
    LDD TCNT
    ADDD Delay
    ADDD #$0032    STD TC3
    ; Step 8: Configure OC3 for the **next** compare to "clear" the output (OM3:OL3 = 01)
    ; The timing is critical here. This must be done AFTER the flag is cleared.
    BSET TCTL2, $40      ; Set OL3 (bit 6)
    BCLR TCTL2, $80      ; Clear OM3 (bit 7)
2,752 次查看
lama
there is a lot of missing info. It is not possible to investigate issue without full setup and loop.
However, look at following code. It generates on pulse after delay.... inspired by your code.
I did it in C+ asm but believe you will understand....
unsigned int Delay;
void main(void)
  asm
    MOVW #$0022, Delay
    MOVB #$04, TSCR2 // ; prescaler =16, do not reset tim by OC of channel 7
                                     // ; ovf int disable
    MOVB #$AA, TCTL1  // ; channels 7,6,5,4 clear on compare
    MOVB #$AA, TCTL2 // ; channels 3,2,1,0 clear on compare
    BSET TIOS, $F8          // ; 7,6,5,4,3 :OC 2,1,0 :IC
    LDAA #$88
    STAA OC7M             // ; Xnnn ynnn
    LDAA #$08
    STAA OC7D              // ; 0000 1000 … FORCE TC3 TO 1 ON TC7 OC
    LDD Delay
    ADDD #$0002
    ADDD TCNT              // ; D = TCNT+DELAY+2
    STD TC7                    // ; TC7 = D
    ADDD #$0032
    STD TC3                    // ; TC3 = D+32
  TSCR1 = 0xE0;            // enable timer,stop in wait,stop in freeze, NO fast flag clear
  for(;;)
        asm nop;
Ladislav
%3CLINGO-SUB%20id%3D%22lingo-sub-2192873%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BD%BF%E7%94%A8%20TC7%20%E5%90%8C%E6%97%B6%E6%8E%A7%E5%88%B6%20TC3%20%E7%9A%84%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2192873%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%209s12C32%20%E6%8E%A7%E5%88%B6%E7%81%AB%E8%8A%B1%E5%AE%9A%E6%97%B6%EF%BC%8C%E5%90%8C%E6%97%B6%E4%BD%BF%E7%94%A8%20TC7%20%E6%8E%A7%E5%88%B6%20TC3%E3%80%82%3C%2FP%3E%3CP%3EOC7D%20%3D%2088%20%E5%92%8C%20OC7M%20%3D%2008%E3%80%82%3C%2FP%3E%3CP%3E%E5%8A%A0%E8%BD%BD%20TC7%20%E5%90%8E%EF%BC%8C%E6%88%91%E5%9C%A8%20TC3%20%E4%B8%AD%20ADDD%20%240032%EF%BC%8C%E5%9B%A0%E6%AD%A4%20TC3%20%E5%BA%94%E5%9C%A8%20TC7%20%E7%BB%93%E6%9D%9F%20100usec%20%E5%90%8E%E5%8F%98%E4%B8%BA%E4%BD%8E%E7%94%B5%E5%B9%B3%EF%BC%8C%E4%BD%86%20TC3%20%E5%9C%A8%20TC7%20%E5%8A%A0%E8%BD%BD%E6%AF%94%E8%BE%83%E5%80%BC%E5%90%8E%E7%AB%8B%E5%8D%B3%E5%8F%98%E4%B8%BA%E4%BD%8E%E7%94%B5%E5%B9%B3%E3%80%82%20%20%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EBSET%20TIOS%2C%20%24F8%3C%2FP%3E%3CP%3ELDAA%20%23%2488%3C%2FP%3E%3CP%3ESTAA%20OC7M%3C%2FP%3E%3CP%3ELDAA%20%23%2408%3C%2FP%3E%3CP%3ESTAA%20OC7D%3C%2FP%3E%3CP%3ELDD%20%E5%BB%B6%E8%BF%9F%3C%2FP%3E%3CP%3EADDD%20%23%240002%3C%2FP%3E%3CP%3EADDD%20TCNT%3C%2FP%3E%3CP%3ESTD%20TC7%3C%2FP%3E%3CP%3EADDD%20%23%240032%3C%2FP%3E%3CP%3ESTD%20TC3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2193624%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Problem%20using%20TC7%20to%20also%20control%20TC3%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2193624%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%93%8E%E5%91%80%EF%BC%8C%E8%AF%B7%E4%BF%AE%E6%94%B9%E6%88%91%E7%9A%84%E6%9C%80%E5%90%8E%E4%B8%80%E4%B8%AA%E5%B8%96%E5%AD%90%EF%BC%8C%E5%9B%A0%E4%B8%BA%E8%BF%99%E5%B9%B6%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%E3%80%82%20%E5%AE%83%E5%8F%AA%E5%9C%A8%E6%AF%8F%E9%9A%94%E4%B8%80%E6%AC%A1%E7%81%AB%E8%8A%B1%E4%BA%8B%E4%BB%B6%E4%B8%AD%E8%B5%B7%E4%BD%9C%E7%94%A8%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2193619%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Problem%20using%20TC7%20to%20also%20control%20TC3%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2193619%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%EF%BC%8C%E4%BD%86%E6%88%91%E5%92%8C%E8%B0%B7%E6%AD%8C%E5%B0%8F%E7%88%B1%E7%BB%88%E4%BA%8E%E5%BC%84%E6%98%8E%E7%99%BD%E4%BA%86%E3%80%82%20%E4%B8%8B%E9%9D%A2%E6%98%AF%E6%AD%A3%E7%A1%AE%E7%9A%84%E4%BB%A3%E7%A0%81%EF%BC%9A%3C%2FP%3E%3CBR%20%2F%3E%3CDIV%20class%3D%22%22%3E%3CPRE%20translate%3D%22no%22%3E%3CSPAN%20class%3D%22%22%3E%3B%20Assume%20PT3%20has%20been%20properly%20set%20high%20via%20GPIO%0A%3B%20and%20the%20timer%20is%20already%20enabled%20via%20TSCR1%3ATEN%0A%0A%20%20%20%20%3B%20Step%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E1%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3A%20Disable%20OC3%20to%20prepare%20for%20configuration%0A%20%20%20%20BCLR%20TIOS%2C%20%2408%0A%0A%20%20%20%20%3B%20Step%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E2%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3A%20Set%20TC3%20to%20the%20immediate%20past%0A%20%20%20%20LDD%20TCNT%0A%20%20%20%20SUBD%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%23%240001%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%20%20%20STD%20TC3%0A%0A%20%20%20%20%3B%20Step%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E3%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3A%20Configure%20OC3%20to%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%22no%20action%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20(OM3%3AOL3%20%3D%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E00%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E)%0A%20%20%20%20%3B%20This%20ensures%20the%20pin%20is%20not%20affected%20when%20OC%20takes%20over.%0A%20%20%20%20BCLR%20TCTL2%2C%20%24C0%0A%0A%20%20%20%20%3B%20Step%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E4%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3A%20Re-enable%20OC3%0A%20%20%20%20BSET%20TIOS%2C%20%2408%0A%0A%20%20%20%20%3B%20Step%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E5%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3A%20Wait%20for%20the%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%22past%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20compare%20event%20to%20occur%20and%20set%20its%20flag%0Azot%3A%0A%20%20%20%20BRCLR%20TFLG1%2C%20%2408%2C%20zot%0A%0A%20%20%20%20%3B%20Step%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E6%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3A%20Clear%20the%20timer%20flag%20for%20channel%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E3%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%20%20%20LDAA%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%23%2408%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%20%20%20STAA%20TFLG1%0A%0A%20%20%20%20%3B%20Step%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E7%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3A%20Set%20the%20TC3%20for%20the%20future%20compare%20event%0A%20%20%20%20LDD%20TCNT%0A%20%20%20%20ADDD%20Delay%0A%20%20%20%20ADDD%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%23%240032%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%20%20%20STD%20TC3%0A%0A%20%20%20%20%3B%20Step%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E8%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3A%20Configure%20OC3%20for%20the%20**next**%20compare%20to%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%22clear%22%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%20the%20output%20(OM3%3AOL3%20%3D%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E01%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E)%0A%20%20%20%20%3B%20The%20timing%20is%20critical%20here.%20This%20must%20be%20done%20AFTER%20the%20flag%20is%20cleared.%0A%20%20%20%20BSET%20TCTL2%2C%20%2440%20%20%20%20%20%20%3B%20Set%20OL3%20(bit%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E6%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E)%0A%20%20%20%20BCLR%20TCTL2%2C%20%2480%20%20%20%20%20%20%3B%20Clear%20OM3%20(bit%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E7%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E)%3C%2FSPAN%3E%3C%2FPRE%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2193517%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Problem%20using%20TC7%20to%20also%20control%20TC3%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2193517%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E6%9C%89%E5%BE%88%E5%A4%9A%E4%BF%A1%E6%81%AF%E7%BC%BA%E5%A4%B1%E3%80%82%E5%9C%A8%E6%B2%A1%E6%9C%89%E5%AE%8C%E6%95%B4%E8%AE%BE%E7%BD%AE%E5%92%8C%E5%BE%AA%E7%8E%AF%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8C%E6%97%A0%E6%B3%95%E5%AF%B9%E9%97%AE%E9%A2%98%E8%BF%9B%E8%A1%8C%E8%B0%83%E6%9F%A5%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E8%AF%B7%E7%9C%8B%E4%B8%8B%E9%9D%A2%E7%9A%84%E4%BB%A3%E7%A0%81%E3%80%82%E5%AE%83%E5%9C%A8%E5%BB%B6%E8%BF%9F%E4%B9%8B%E5%90%8E%E6%8C%89%E8%84%89%E5%86%B2%E7%94%9F%E6%88%90...%20%E5%8F%97%E4%BD%A0%E7%9A%84%E4%BB%A3%E7%A0%81%E5%90%AF%E5%8F%91%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E6%98%AF%E5%9C%A8%20C%2B%20asm%20%E4%B8%AD%E5%AE%8C%E6%88%90%E7%9A%84%EF%BC%8C%E4%BD%86%E7%9B%B8%E4%BF%A1%E6%82%A8%E8%83%BD%E7%90%86%E8%A7%A3....%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%0A%3CP%3E%2F%2F---------------------------------------%3CBR%20%2F%3E%20unsigned%20int%20Delay%3B%20%3CBR%20%2F%3E%20%2F%2F--------------------------------------------------------------%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20asm%20%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%7B%3CBR%20%2F%3EMOVW%20%23%240022%EF%BC%8C%E5%BB%B6%E8%BF%9F%20MOVB%20%23%2404%EF%BC%8CTSCR2%3CBR%20%2F%3E%2F%2F%EF%BC%9B%E9%A2%84%E5%88%86%E9%A2%91%E5%99%A8%20%3D16%EF%BC%8C%E4%B8%8D%E8%A6%81%E5%9C%A8%E9%A2%91%E9%81%93%207%20%E7%9A%84%20OC%20%E4%B9%8B%E5%89%8D%20RESET%20%E6%97%B6%E9%97%B4%2F%2F%EF%BC%9B%3CBR%20%2F%3E%3CBR%20%2F%3Eovf%20int%20%E7%A6%81%E7%94%A8%20MOVB%20%23%24AA%EF%BC%8CTCTL1%2F%2F%EF%BC%9B%E9%A2%91%E9%81%93%E5%9C%A8%E6%AF%94%E8%BE%83%20MOV%20%3CBR%20%2F%3E%20B%20%23%24AA%2C%20TCTL2%2F%2F%3B%20%E9%A2%91%E9%81%93%E6%97%B6%E6%B8%85%E9%99%A4%207%2C6%2C5%2C4%202%2C1%2C0%20%E6%AF%94%E8%BE%83%E6%97%B6%E6%B8%85%E9%99%A4%E6%9C%80%E4%BD%B3%20TIOS%EF%BC%8C%24F8%3CBR%20%2F%3E%2F%2F%3B%207%2C6%2C5%2C4%2C3%3A%20OC%202%2C1%2C0%3A%20IC%20LDAA%20%2388%20%E7%BE%8E%E5%85%83%20STAA%20OC7M%2F%2F%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3B%20xnnn%20ynnn%3C%2FP%3E%0A%3CP%3E%20%20%20%20ldaa%20%23%2408%3CBR%20%2F%3E%20staa%20oc7d%20%2F%2F%20%3B%200000%201000%20...%20%E5%9C%A8%20tc7%20%E4%B8%8A%E5%BC%BA%E5%88%B6%20tc3%20%E4%B8%BA%201%20oc%3C%2FP%3E%0A%3CP%3ELDD%20%E5%BB%B6%E8%BF%9F%20%3CBR%20%2F%3E%20ADDD%20%23%240002%20%3CBR%20%2F%3E%20ADDD%20TCNT%2F%2F%3B%20D%20%3D%20TCNT%2BDELAY%2B2%20STD%20TC7%2F%2F%3B%20TC7%20%3D%20D%20%3CBR%20%2F%3E%3C%2FP%3E%0A%3CP%3EADDD%20%23%240032%20%3CBR%20%2F%3E%20STD%20TC3%2F%2F%3B%20TC3%20%3D%20D%2B32%3CBR%20%2F%3E%7D%2F%3CBR%20%2F%3E%2F-------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20TSCR1%3C%2FP%3E%0A%3CP%3E%2F%2F***********************************************************************************%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%87%B4%E4%BB%A5%E6%9C%80%E8%AF%9A%E6%8C%9A%E7%9A%84%E9%97%AE%E5%80%99%EF%BC%8C%3CBR%20%2F%3ELadislav%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
