Peripheral is already used ... USER - how do I remove ?
checkers
I was learning the Processor Expert and defined MSCAN as used externally.
Then I discovered that was not the right way to do it.
Now, I want to add the MSCAN component, but it does not allow me to assign it to MSCAN because
Peripheral is already used by special signal USER (MSCAN controller)
I have looked for over an hour through help files, etc and cannot find how to remove the incorrect definition.
Do you know where I can find this to un-assign it from USER?
checkers
It took three hours to find the doc for this. And I cannot consistently remember how I got there. Please add this to the help index.
In Processor Expert, under CPUs I find my cpu defined as Cpu:MC9S12P32CFT
Double cllicking on that link opens the Component Inspector.
Clicking to the 'Used' tab shows several categories of items.
Under the  last item, A/D and communication channels I found MSCAN
Clicking on the purple arrow released MSCAN from USER.
Thanks for the help.
