Newbie
Newbie
admin
Specialist II
Hello
 Iam very much new to the microcontrollers and its programming. I am not aware of the follow up of datasheets..
please do let me know how to start the reading... how to understand the memory mapping, registers.. etc..
KH_SRNL
The S12 series of embedded controllers have their documentation divided into specific modules (ATD, SPI, SCI, ect).  This is a departure from the old HC11 "pink book" that had everything in one concise location.  I counted 17 different documents associated with the S12 controller (that I've located), this is in addition to the documentation provided by the chip integrator (Elmicro & Technological Arts are two companies that integrate the CPU with all supporting electronics on a single board).  If you haven't purchased a demo board, I would highly recommend it.  You usually get everything needed to get up and running so that you can get your feet wet a little at a time.
Two examples of Freescale documents are the: MC9S12CFAMPB document & S12SCIV2 document.  I think if you look under the specifc part, there should be a list of all documents.
Good luck & happy coding.
admin
Specialist II
yeah, hi
thankyou for the suggestion. I have a softech's SK-S12XDP512A demokit but Iam unable to understand it..
isionous
You might have better luck asking specific questions.
Lundin
Senior Contributor IV
Actually, only the fist releases of the S12 famility had this documentation fiasco. For newer S12, Freescale came to their senses and you will find all documentation in one single document. If you are using S12C, there is one such single bible available.
isionous
Datasheets usually are the best place for understanding registers, memory mapping, and so on.  If you are still confused, you might want to look at the example projects that come with Codewarrior.
admin
Specialist II
hi, thankyou for the suggestion.
 I have a demo kit from softech SK-S12XDP512A. I am unable to understand the working of it...
admin
Specialist II
thank you.
