Memory operand constraint
1,298 次查看
Nagarjuna
 How to replace Memory operand constraint "m" in Codewarrior for HCS12 controller.
"m" (*((unsigned char *)&log_tooth+1)), \  // byte 3:**2**:1:0
 "m" (*((unsigned int *)&log_tooth+1)), \ // bytes 3:2:**1**:**0**
 "m" (synch),  \
 "m" (flagbyte1) ;
While compiling the above code in codewarrior i am getting the below compiler error.
Error : C12070 Identifier expected.
 As Memory operand constraint is not supported in codewarrior, can someone suggest the solution for the above problem.
Nagarjuna Reddy
0 回复数
