Machine Exception in S12z
1,275件の閲覧回数
kathi
Hi Team,
When a 2 bit RAM or ROM error occurs in S12z it enters machine exception, is LIN transmission(from mcu to GUI) possible after entering the Machine Exception to indicate on the GUI that 2 bit error has occurred.
1,253件の閲覧回数
lama
There is no problem in your consideration up to the moment you will read again RAM/ROM (also execution of the code is reading) the corrupted memory range which has ECC error.
Ladislav
