MTRCKTSBNG128 Kit Application Software
已解决
跳至解决方案
3,505 次查看
pratibhasurabhi
Contributor V
Hello All,
I am trying to download the application software for MTRCKTSBNG128 kit. It seems that link for the same the same is not active.
Link for the same : https://www.nxp.com/webapp/Download?colCode=MTRCKTSBNG128_SW&appType=license
Can someone please check it and direct me to an active link for the same.
Thank you in advance,
Pratibha.
1 解答
3,441 次查看
Beckywang
Hello Pratibha
This file has been upload once more. It works now.
Thank you for the report and sorry for any inconvenience.
Becky
在原帖中查看解决方案
2 回复数
3,442 次查看
Beckywang
Hello Pratibha
Becky
3,485 次查看
RadekS
Hello Pratibha,
Thank you for the notification. We have to fix that issue.
In meantime, please download the attached installer file (additionally packed into zip file due to web limitations).
Please be aware that MTRCKTSBNG128 is quite obsolete design and the last update was done several years ago.
I hope it helps you.
RadekS
