MC9S12ZVML128 Lin Sample Code
itsnewforme
Hii, I want to use S12ZVML128 as Lin Slave  and CANoe as Lin Master.
1)I'm successfully able to send a Lin frame from CANoe to S12ZVML128 and receive a Lin Frame from S12ZVML128 to CANoe. I've done this thing using NXP provided Lin Stack
2) But I want to do this without using Lin stack. Is there any sample code for it.
Thanks in advance :))
danielmartynek
Hi @itsnewforme,
Unfortunately, the Driver/Stack is the only solution available for the S12Z MCUs.
BR, Daniel
