Hello
CodeWarrior for HC12 does not allow to allocate an object across a page boundary.
If you are using global addresses in the .prm file you can have object up to 64K.
But you cannot have object with size bigger than this.
You will have to split your big data structure in portion which are not bigger than 64K.
If you decide to allocate an object across page boundary you will have to manage the page switch yourself.
The compiler will not do it for you.
CrasyCat
