In Circuit Programming
vrtrasura
Greetings,
I have a couple of general questions.  Is BDM the easiest way to flash a HC12X in the field?  I'm using a PE usb BDM interface to work with right now, but what does one use while the uC is on a PCB? Any advice or links to app-notes woud be greatly appreciated-
Thanks!
J2MEJediMaster
Specialist I
There have been several discussions on Flash bootloaders in these forums, where sometimes the serial port, and sometimes the I2C interface, have been used. Search for "bootloader" and see what comes up.
---Tom
