How use LDF/NPF to config 2ch LIN
3,412件の閲覧回数
simonliu
I use LDF/NPF to config 2ch LIN by SCI0/SCI1. I need config 2ch LIN with slave mode. But after generate the lin.h/lin.c,I found the mode in lin.h is master(#define LIN_MODE   _MASTER_MODE_ )。 And the mode is slave(#define LIN_MODE   _SLAVE_MODE_) when I config 1ch LIN.
See the attachment for details of the configuration picture.
The LIN.c have same variable and prompt error during  compile.
タグ(4)
0 返答(返信)
