How to set compiler(Code Warrior)calculate and save CRC checksum at flash
1,317 次查看
Gildarai
Hello
I use Code Warrior Compiler 11.1 with S12Z.
I want to calculate checksum of my project and save it at the flash.
And then I want to check it when SW is start up for check whether the SW is correct or not.
For this I think the calculating should performed when compile my project.
So what can I do for this, how can I set the compiler option or pre-do.
标记 (3)
1,298 次查看
lama
Have you read.....
 or....
 or....
Ladislav
