How do I jump to the reset vector on an S12G?
DDuckDDuck
I did this on my old S08DZ... but the S12 compiler won´t like the assembler instructions.... How do I do the same on an S12G?
   __asm LDHX   $FFFE                // reset vector
    __asm JMP    ,X                            / /Jump and reset!
Many thanks,
Lars
Tags (2)
kef2
Senior Contributor V
From C you can simply
   ((void (*__near)(void))0xFFFE)();
, where __near is pointer type modifier, which you can remove. No matter what memory model, it still will work for S12 and S08.
There's no LDHX instruction in S12. Also ,X addressing mode is not supported. You need to modify your code like this
   __asm LDX   #$FFFE                // reset vector
    __asm JMP    0,X                            / /Jump and reset!
keli
The suggested C code violate MISRA C-1998: rule 45. Is there walk-around?
