HC12DG128 flashing by secondary bootloader
926件の閲覧回数
sierra
Can you  explain me how application is loaded by secondary bootloader using CAN connection. Now i know only  start address for  secondary bootloader is 2000hex, parts off application are loaded at strange address 2B080hex ( flash when i read have only end address 1FFFFhex). I would like know how bootloader are started (how it is set ) and how erased after flashing  and as it is with this higher address.
0 返答(返信)
