Finding MCAT Lib on Web of NXP
1,018 次查看
ahnjoseph
I received a MCAT FOC LIB(S12zvm) from this site
But I did not find a MCAT FOC Lib on Web NXP
I did tri with MCAT LIB source at EVB Kit (MTRCKTSBNZVM128 )
But that was N.G work
So I want to good work MCAT FOC Lib source on MTRCKTSBNZVM128kit
911 次查看
iggi
MCAT tool is not available for download on NXP web as it is not a standalone tool yet. It's rather a plugin for FreeMaster tool. We are working to make it standalone and hopefully this will be available this year.
The MCAT FOC lib you've got should be used with PMSM Motor Control Kit with  MagniV MC9S12ZVM - MTRCKTSPNZVM128.
The kit you are using is for BLDC motor control as indicated by letter B in the part number.
Now i'm not sure if we have the MCAT for the BLDC kit, probably yes. need to check.
iggi
