Filter configuration and optimization
Boris_Bloxsberg
does anyone know an detailed description for the implemented low pass filter?
A link for a sufficient windows tool would also be nice...
thx...
danielmartynek
Hi Boris,
I don't know what low-pass filter you mean.
There are passive, active, higher-order filters.
You can find many tutorials on the internet, such as
https://www.electronics-tutorials.ws/filter/filter_2.html
Then, you can simulate the filter in PSpice etc.
danielmartynek
Hi Boris,
Boris_Bloxsberg
some weeks ago I added a question regarding the Filter of the MagniV.
Now, I´ve got an additional question....
At page 139 of the manual of the MM9Z1_638  I found the main structure of the implemented low pass filter. In table 192, I found the value conversation: "Data Format: MSB = Sign (“1” minus)"
Does it mean, you are using the twos complement? and is there an excel sheet aviable to calculate new values?
regards.
Boris_Bloxsberg
I will take a look on eletronic-tut....
ths´x
