External Clock Overdriving
2,050 次查看
Fabrico
Although the specsheet specifies that the External Clock input should be driven with no more than 2.5 volts, I did connect it with a Citizen clock driving 5 volts!
What are the implications guys?
Fabrico
1,182 次查看
Alban
Senior Contributor II
Hi Fabricio,
Putting double the maximum voltage could simply result in damaging the MCU.
Specifications means it is how functionalities are tested and/or guaranteed.
Being out of specification not invalidates any warranty but present a risk to your application.
Alban.
