EVB9S12NE64 hyperterminal settings
1,948 次查看
Ed22
I've got an Axiom EVB9S12NE64, and I wish to communicate with the serial monitor, using HyperTerminal. What are the correct settings for baud rate, parity, data bits, stop bits and flow control? I can't find the information anywhere on the included documentation. Thank you.
1,114 次查看
UK_CF_FAE
Hi Ed22,
It has been a real long time since I used the NE64, but going back to a project that I had:
ne64debug.c:
void InitDebug(void)
#define BAUD_RATE    115200
#define BAUD_DIV     ECLK/16/BAUD_RATE
  SCIBD= BAUD_DIV;
  SCICR1= 0;
  SCICR2= SCI1CR2_TE_MASK | SCI1CR2_RE_MASK | SCI1CR2_RWU_MASK ;
I'd go for 115200 8N1 No flow control. Sometimes, though, you just have to make a few guesses.
No doubt, you will let us all know how you get on.
Mark
