D-BUG12 BUG ?
D-BUG12 BUG ?
5,411件の閲覧回数
fmiku
I just found somthing weird disassembly while is in a debug session..
as you see on the attached pic on same address and same opcode gives different disassembly.
3 返答(返信)
5,234件の閲覧回数
RadekS
Hi Ferenc,
We found and fixed the issue with D-Bug12XZ disassembly.
The problem existed not only for MOVB/MOVW <Indexed>,<Extended>, but also for MOVB/MOVW <immediate>,<Indexed>.
Thank you very much for your bug report.
Attached is a zip file containing the latest version of D-Bug12XZ (600b19), Reference Manual, and release notes.
Could you please test it and let us know whether it works correctly on your side?
I hope it helps you.
Radek
5,234件の閲覧回数
fmiku
Hi Radek,
Thank you very much :smileyhappy:, I uploaded the new firmware and seems to be OK.
This week I will debugging alot of, so I will report if I found anything.
I have a feature request too, what makes the debug sessions more faster/easy.
It's possible ? can I place here or need to open a new thread for it ?
Ferenc
5,231件の閲覧回数
RadekS
Hi Ferenc,
Thank you very much for your bug report. I forwarded to the responsible team.
I will update this thread in the case of new information.
Radek
