Connecting Jenkins and Codewarrior 5.9.0 Make Build
1,104件の閲覧回数
Luna_Maverick
Hi.
I'm a developer developing with the S912XET256 MCU.
I'm trying to connect Jenkins and the Codewarrior 5.9.0 IDE to create an automated build.
I know that pressing the "make" button in the Codewarrior 5.9.0 IDE starts the build.
And I know that the resulting *.s19 and *.map files are created in the bin folder.
I'm creating a Build.bat file to connect with Jenkins.
I need to know what the *.exe file is that executes the "make" button.
I look forward to your response.
Thank you.
タグ(4)
970件の閲覧回数
Luna_Maverick
I'm uploading a sample Jenkins connection bat file. Please refer to it.
As of Codewarrior 5.9.0, the build program is CmdIDE.exe.
S912XET256.bat
@echo off
setlocal enabledelayedexpansion
set "CW_PATH=C:\Program Files (x86)\Freescale\CWS12v5.1\bin\CmdIDE.exe"
set "PROJECT_ROOT=%~dp0.."
set "MCP_FILE=%PROJECT_ROOT%\Project.mcp"
echo [INFO] Build Start...
echo [INFO] Executing CmdIDE with Force Build...
"%CW_PATH%" "%MCP_FILE%" /F /C /M /E /S
set "BUILD_EXIT_CODE=%errorlevel%"
echo [DEBUG] Searching for generated .s19 files...
dir /s "%PROJECT_ROOT%\*.s19"
if %BUILD_EXIT_CODE% neq 0 (
echo [ERROR] Build Failed with code %BUILD_EXIT_CODE%
exit /b %BUILD_EXIT_CODE%
exit /b 0
Thanks.
%3CLINGO-SUB%20id%3D%22lingo-sub-2289951%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EJenkins%20%E3%81%A8%20Codewarrior%205.9.0%20%E3%81%AE%20Make%20Build%20%E3%82%92%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2289951%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%20S912XET256%20MCU%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E9%96%8B%E7%99%BA%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E9%96%8B%E7%99%BA%E8%80%85%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EJenkins%20%E3%81%A8%20Codewarrior%205.9.0%20IDE%20%E3%82%92%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E8%87%AA%E5%8B%95%E3%83%93%E3%83%AB%E3%83%89%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ECodewarrior%205.9.0%20IDE%20%E3%81%A7%E3%80%8Cmake%E3%80%8D%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E6%8A%BC%E3%81%99%E3%81%A8%E3%83%93%E3%83%AB%E3%83%89%E3%81%8C%E9%96%8B%E5%A7%8B%E3%81%95%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%82%8F%E3%81%8B%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E7%B5%90%E6%9E%9C%E3%81%A8%E3%81%97%E3%81%A6%E5%BE%97%E3%82%89%E3%82%8C%E3%81%9F%20*.s19%20%E3%81%8A%E3%82%88%E3%81%B3%20*.map%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%20bin%20%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%83%BC%E3%81%AB%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EJenkins%20%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%20Build.bat%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%80%8Cmake%E3%80%8D%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%20*.exe%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E4%BD%95%E3%81%A7%E3%81%82%E3%82%8B%E3%81%8B%E3%82%92%E7%9F%A5%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%82%92%E3%81%8A%E5%BE%85%E3%81%A1%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2292912%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Connecting%20Jenkins%20and%20Codewarrior%205.9.0%20Make%20Build%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2292912%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%81%AE%20Jenkins%20%E6%8E%A5%E7%B6%9A%20bat%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%82%A2%E3%83%83%E3%83%97%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%9C%E3%81%B2%E5%8F%82%E8%80%83%E3%81%AB%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3ECodewarrior%205.9.0%20%E4%BB%A5%E9%99%8D%E3%80%81%E3%83%93%E3%83%AB%E3%83%89%20%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%AF%20CmdIDE.exe%20%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3ES912XET256.bat%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F3933%22%20target%3D%22_blank%22%3E%40%3C%2FA%3E%E3%82%A8%E3%82%B3%E3%83%BC%E3%82%AA%E3%83%95%3CBR%20%2F%3Esetlocal%20%E6%9C%89%E5%8A%B9%E9%81%85%E5%BB%B6%E6%8B%A1%E5%BC%B5%3C%2FP%3E%3CP%3E%E3%80%8CCW_PATH%3DC%3A%5CProgram%20Files%20(x86)%5CFreescale%5CCWS12v5.1%5Cbin%5CCmdIDE.exe%E3%80%8D%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%80%8CPROJECT_ROOT%3D%25~dp0..%E3%80%8D%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%22MCP_FILE%3D%20%25PROJECT_ROOT%25%20%5CProject.mcp%22%20%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Eecho%20%5BINFO%5D%20%E3%83%93%E3%83%AB%E3%83%89%E9%96%8B%E5%A7%8B...%3CBR%20%2F%3E%20echo%20%5BINFO%5D%20%E5%BC%B7%E5%88%B6%E3%83%93%E3%83%AB%E3%83%89%E3%81%A7%20CmdIDE%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%20%E3%80%8C%20%25CW_PATH%25%20%E3%80%8D%E3%80%8C%20%25MCP_FILE%25%20%E3%80%8D%2FF%2FC%2FM%2FE%2FS%3C%2FP%3E%3CP%3E%E3%80%8CBUILD_EXIT_CODE%3D%20%25errorlevel%25%20%E3%80%8D%E3%82%92%E8%A8%AD%E5%AE%9A%3C%2FP%3E%3CP%3Eecho%20%5BDEBUG%5D%20%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F.s19%E3%82%92%E6%A4%9C%E7%B4%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB...%3CBR%20%2F%3E%20dir%20%2Fs%20%22%20%25PROJECT_ROOT%25%20%5C*.s19%22%3C%2FP%3E%3CP%3E%25BUILD_EXIT_CODE%25%E3%81%8C%200%20%E3%81%A7%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%20(%3CBR%20%2F%3E%20echo%20%5BERROR%5D%20%E3%82%B3%E3%83%BC%E3%83%89%25BUILD_EXIT_CODE%25%E3%81%A7%E3%83%93%E3%83%AB%E3%83%89%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%2Fb%20%25BUILD_EXIT_CODE%25%E3%82%92%E7%B5%82%E4%BA%86%3CBR%20%2F%3E%EF%BC%89%3CBR%20%2F%3E%20%2Fb%200%20%E3%82%92%E7%B5%82%E4%BA%86%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
