Clearing TCNT counter to 0
2,133 次查看
Pallavi
Hello Everyone. I need a support to clear TCNT register to 0.
While control comes from boot to App, I need clear TCNT register to 0.
I aware that , TNCT can't be cleared in normal mode. From google, i understand that below 2 are methods available.
Method 1: Using Timer Channel 7 (Hardware Reset) : As I want to clear TCNT only once, I didn’t try this method.
Method 2:  System/Module Reset (Force Clear)  : I have tried this way .
  1. Clear the TEN bit (Timer Enable) in the TSCR1 (Timer System Control Register 1) to turn off the timer. TSCR1_TEN =0;
  2. Set the TEN bit to re-enable it (TSCR1_TEN =1 ;). This should clear TCNT to 0000.
But this method is not working . Please help me out to solve this issue
1,956 次查看
Pallavi
Thank you Daniel for confirming.
6 回复数
2,058 次查看
Pallavi
Hello ,
I am using MC9S12ZVLA128
2,025 次查看
danielmartynek
Hello @Pallavi,
Unfortunately, there is no option to clear the counter on S12ZVLA.
However, why would you need to clear it? What would be the use case?
BR, Daniel
2,015 次查看
Pallavi
TCNT has incremented in bootloader before control comes to app. In app, i am calling 10ms, task depending onTCNTcount.
As of now I am reading the current count and calling 10ms task from that count value.
Instead of that I thought of clearing TCNT when control comes to app and then schedule 10ms task.
2,008 次查看
danielmartynek
You are doing it correctly, this is how output compare is updated.
BR, Daniel
1,957 次查看
Pallavi
2,096 次查看
danielmartynek
Hello @Pallavi,
Can you please specify the MCU?
%3CLINGO-SUB%20id%3D%22lingo-sub-2318409%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%B0%86%20TCNT%20%E8%AE%A1%E6%95%B0%E5%99%A8%E6%B8%85%E9%9B%B6%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2318409%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%E6%88%91%E9%9C%80%E8%A6%81%E5%B0%86%20TCNT%20%E5%AF%84%E5%AD%98%E5%99%A8%E6%B8%85%E9%9B%B6%E7%9A%84%E6%94%AF%E6%8C%81%E3%80%82%20%3C%2FP%3E%3CP%3E%E8%99%BD%E7%84%B6%E6%8E%A7%E5%88%B6%E6%9D%83%E4%BB%8E%E5%90%AF%E5%8A%A8%E5%88%B0%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%E4%BD%86%E6%88%91%E9%9C%80%E8%A6%81%E5%B0%86TCNT%E5%AF%84%E5%AD%98%E5%99%A8%E6%B8%85%E9%99%A4%E4%B8%BA0%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E7%9F%A5%E9%81%93%20TNCT%20%E6%97%A0%E6%B3%95%E5%9C%A8%E6%AD%A3%E5%B8%B8%E6%A8%A1%E5%BC%8F%E4%B8%8B%E6%B8%85%E9%99%A4%E3%80%82%E9%80%9A%E8%BF%87%E8%B0%B7%E6%AD%8C%EF%BC%8C%E6%88%91%E4%BA%86%E8%A7%A3%E5%88%B0%E4%BB%A5%E4%B8%8B%E4%B8%A4%E7%A7%8D%E6%96%B9%E6%B3%95%E5%8F%AF%E7%94%A8%E3%80%82%3C%2FP%3E%3CP%3E%E6%96%B9%E6%B3%95%201%EF%BC%9A%E4%BD%BF%E7%94%A8%E8%AE%A1%E6%97%B6%E5%99%A8%E9%80%9A%E9%81%93%207%EF%BC%88%E7%A1%AC%E4%BB%B6%20RESET%EF%BC%89%EF%BC%9A%E7%94%B1%E4%BA%8E%E6%88%91%E5%8F%AA%E6%83%B3%E6%B8%85%E9%99%A4%20TCNT%20%E4%B8%80%E6%AC%A1%EF%BC%8C%E6%89%80%E4%BB%A5%E6%88%91%E6%B2%A1%E6%9C%89%E5%B0%9D%E8%AF%95%E8%BF%87%E8%BF%99%E4%B8%AA%E6%96%B9%E6%B3%95%E3%80%82%3C%2FP%3E%3CP%3E%E6%96%B9%E6%B3%95%202%EF%BC%9A%E7%B3%BB%E7%BB%9F%2F%E6%A8%A1%E5%9D%97RESET%EF%BC%88%E5%BC%BA%E5%88%B6%E6%B8%85%E9%99%A4%EF%BC%89%EF%BC%9A%E6%88%91%E8%AF%95%E8%BF%87%E8%BF%99%E7%A7%8D%E6%96%B9%E6%B3%95%E3%80%82%3C%2FP%3E%3COL%3E%3CLI%3E%3CSPAN%3E%E6%B8%85%E9%99%A4%20TSCR1%EF%BC%88%E5%AE%9A%E6%97%B6%E5%99%A8%E7%B3%BB%E7%BB%9F%E6%8E%A7%E5%88%B6%E5%AF%84%E5%AD%98%E5%99%A8%201%EF%BC%89%E4%B8%AD%E7%9A%84%20TEN%20%E4%BD%8D%EF%BC%88%E5%AE%9A%E6%97%B6%E5%99%A8%E5%90%AF%E7%94%A8%EF%BC%89%EF%BC%8C%E5%85%B3%E9%97%AD%E5%AE%9A%E6%97%B6%E5%99%A8%E3%80%82TSCR1_TEN%20%3D0%EF%BC%9B%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3E%E8%AE%BE%E7%BD%AE%20TEN%20%E4%BD%8D%E5%8F%AF%E9%87%8D%E6%96%B0%E5%90%AF%E7%94%A8%E8%AF%A5%E5%8A%9F%E8%83%BD%EF%BC%88TSCR1_TEN%20%3D1%20%3B%EF%BC%89%E3%80%82%E8%BF%99%E5%B0%86%E6%8A%8A%20TCNT%20%E6%B8%85%E9%9B%B6%E4%B8%BA%200000%E3%80%82%20%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CBR%20%2F%3E%3CP%3E%E4%BD%86%E8%BF%99%E7%A7%8D%E6%96%B9%E6%B3%95%E8%A1%8C%E4%B8%8D%E9%80%9A%E3%80%82%E8%AF%B7%E5%B8%AE%E6%88%91%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2318991%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Clearing%20TCNT%20counter%20to%200%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2318991%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F259939%22%20target%3D%22_blank%22%3E%40Pallavi%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E8%83%BD%E5%90%A6%E8%AF%B7%E6%82%A8%E8%AF%B4%E6%98%8E%E4%B8%80%E4%B8%8B%20MCU%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2323810%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Clearing%20TCNT%20counter%20to%200%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2323810%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F259939%22%20target%3D%22_blank%22%3E%40Pallavi%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E9%81%97%E6%86%BE%E7%9A%84%E6%98%AF%EF%BC%8CS12ZVLA%20%E6%B2%A1%E6%9C%89%E6%B8%85%E9%99%A4%E8%AE%A1%E6%95%B0%E5%99%A8%E7%9A%84%E9%80%89%E9%A1%B9%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E4%B8%BA%E4%BB%80%E4%B9%88%E9%9C%80%E8%A6%81%E6%B8%85%E9%99%A4%E5%91%A2%EF%BC%9F%E7%94%A8%E4%BE%8B%E6%98%AF%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%EF%BC%8C%E4%B8%B9%E5%B0%BC%E5%B0%94%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2324199%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Clearing%20TCNT%20counter%20to%200%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2324199%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E7%9A%84%E6%93%8D%E4%BD%9C%E6%98%AF%E6%AD%A3%E7%A1%AE%E7%9A%84%EF%BC%8C%E8%BE%93%E5%87%BA%E6%AF%94%E8%BE%83%E5%B0%B1%E6%98%AF%E8%BF%99%E6%A0%B7%E6%9B%B4%E6%96%B0%E7%9A%84%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%EF%BC%8C%E4%B8%B9%E5%B0%BC%E5%B0%94%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2324145%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Clearing%20TCNT%20counter%20to%200%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2324145%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%9C%A8%E6%8E%A7%E5%88%B6%E6%9D%83%E8%BF%9B%E5%85%A5%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E4%B9%8B%E5%89%8D%EF%BC%8CTCNT%20%E5%B7%B2%E5%9C%A8%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E4%B8%AD%E9%80%92%E5%A2%9E%E3%80%82%E5%9C%A8%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E4%B8%AD%EF%BC%8C%E6%88%91%E6%A0%B9%E6%8D%AE%20TCNTcount%20%E8%B0%83%E7%94%A8%2010ms%20%E4%BB%BB%E5%8A%A1%E3%80%82%20%3C%2FP%3E%3CP%3E%E7%9B%AE%E5%89%8D%EF%BC%8C%E6%88%91%E6%AD%A3%E5%9C%A8%E8%AF%BB%E5%8F%96%E5%BD%93%E5%89%8D%E8%AE%A1%E6%95%B0%EF%BC%8C%E5%B9%B6%E6%A0%B9%E6%8D%AE%E8%AF%A5%E8%AE%A1%E6%95%B0%E5%80%BC%E8%B0%83%E7%94%A8%2010ms%20%E4%BB%BB%E5%8A%A1%E3%80%82%20%3C%2FP%3E%3CP%3E%E4%B8%8E%E5%85%B6%E8%BF%99%E6%A0%B7%EF%BC%8C%E6%88%91%E8%BF%98%E4%B8%8D%E5%A6%82%E5%9C%A8%E6%8E%A7%E5%88%B6%E8%BF%9B%E5%85%A5%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E6%97%B6%E6%B8%85%E9%99%A4%20TCNT%EF%BC%8C%E7%84%B6%E5%90%8E%E5%AE%89%E6%8E%92%2010ms%20%E4%BB%BB%E5%8A%A1%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2324804%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Clearing%20TCNT%20counter%20to%200%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2324804%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%84%9F%E8%B0%A2%E4%B8%B9%E5%B0%BC%E5%B0%94%E7%9A%84%E7%A1%AE%E8%AE%A4%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
