CW5.9 Projects Management Problem
1,429 次查看
fanziyu
Hi folks!
I experiencing a strange problem
First I created a new project,and then found a new idea on the basis of the existing project .So,I  create a new project.Finally I have many projects.
Today,I found out a terrible thing, one source file  that   have been removed from the project  appear again(I not deleted the  source file in the hard drive).
1 回复
1,358 次查看
stanish
Hello
CodeWarrior Classic project file (.mcp) contains list of the files associated with the project. The list doesn't reflect file structure on the hard drive in contrast to eclipse based CodeWarrior.
Could you please double-check you saved the project after removing file from the project?
Are all the project you "derived" from the original one affected?
Can you still reproduce the error?
Stan
