CAN message transmission Successful
1,397 次查看
pratibhasurabhi
How can I decide or monitor if message transmission is successful. Which register to monitor?
1,392 次查看
StanoA
Hello Pratibha,
When the error occurs during the transmission message the CANTXERR register increases value and the TSTAT[1:0] in the CANRFLG register can change.
The detail description is in Reference Manual in Section 13.3.2.16 and 13.4.
I think it can help you to solve your task.
Stano.
