C2450: How do I fix this error?
checkers
The help files says "Check to see if you are using the right compiler lanquage option."
Where do I find that option? I've looked in preferences.
checkers
OK. After some brute force learning I found the answer. K&R.
checkers
bool PB_Talk_var;
Isn't bool a valid type?
checkers
