About the communication between two MSCAN
2,078 次查看
lwjtutu
The MSCAN0 and MSCAN1 are used in the  project and the CPU's type is MC9S12XDP512.
They can work normally in the LOOPBAKE mode respectively. But when the MSCAN0 sends a  message to the MSCAN1 or the MSCAN1 sends a  message to the MSCAN0, neither of  them can receive the message. I don;t know why?
   I am a fresh user of the chip, so I don't know  where the mistake may hides.
 Hope the experienced  users to tell me the mistake.
1,039 次查看
Nabla69
If you wish several msCAN modules to talk together, you should not use the LOOPBACK mode.
Cheers,
Alban.
