About MC9S12XEP100 programming
1,308件の閲覧回数
gary_yang
Hi Sir:
We are a third-party programmer manufacturer and our customers have programming problems
MC9S12XEP100CAG needs to be programmed with address 0x12000~0x13FFF
Is this block an EEPROM? Can it be programmed?
Is there a programming process for this block that I can refer to? Is it the same as the DFlash block? The only difference is the address? Do I need to set another register?
1,291件の閲覧回数
danielmartynek
Hi @gary_yang,
There is just an emulated EEPROM, the NVM must be partitioned for the Emulated EEPROM first.
Please refer to AN3490 Overview of the MC9S12XE Emulated EEPROM
https://www.nxp.com/docs/en/application-note/AN3490.pdf
Here you can find some examples and the S12XE memory map:
https://community.nxp.com/t5/S12-MagniV-Microcontrollers/S12XE-and-S12G128-EEPROM/m-p/803764
