About IPLL
About IPLL
1,524件の閲覧回数
zy
Hello kef !
I am using XET256 ,I have some promblem about IPLL.
when  fOSC=16MHz, I have two plans for count fVCO ,first SYNDIV=4;REFDIV=1 then fVCO=80M; second YNDIV=24 ;REFDIV=7 ,then fVCO=100M,if the first one is better then the second one because there are explains in document "Use lowest possible fVCO/fREF ratio (SYNDIV value). Use highest possible REFCLK frequency fREF". The the second plan unsafe?
I also want to know how to use FM0 and FM1,and why to use them?
Thank you for your continued support.
2 返答(返信)
1,412件の閲覧回数
kef
Specialist I
Hello
You should address your questions not only for me, but for whole forums community.
Regarding your question, try using this SW to calculate IPLL settings http://cache.freescale.com/files/microcontrollers/doc/user_guide/S12XEIPLLCUGSW.zip
Enabling frequency modulation may help passing EMI tests. Google for spread spectrum modulation.
1,413件の閲覧回数
zy
Thank you very much
