API_EXTCLK  problem
API_EXTCLK  problem
xiaohui200808
Hello
       Iam now using S12VC64.I want to know which pin is  API_EXTCLK. the datasheet says there is a API_EXTCLK pin .but it doesnot say which pin is.
ningbozhh
Iam now using S12ZVM256.   I want to know which pin is  API_EXTCLK. the datasheet says there is a API_EXTCLK pin .but it doesnot say which pin is.
danielmartynek
You mean S12ZVC64, right? Unfortunately, this pin is not bonded on S12ZVC.
Please have a look at chapter 1.13.1 API External Clock Output in the datasheet.
