The message you are trying to access is permanently deleted.
Hi, where can I find the software Integrating BLDC sensorless using LIN that is mentioned in the AN5201 Application note https://www.nxp.com/docs/en/application-note/AN5201.pdf
Solved! Go to Solution.
Integrating the LIN driver with BLDC sensorless motor controller:
SW:
https://www.nxp.com/docs/en/application-note-software/AN5201SW.zip
Ladislav
