56f8006 loading codes using simple rs232
2,092件の閲覧回数
pisayisi
i want learn is it possible to load our codes to 56f8006 using only windows xp hyperterminal (as sending s-record file from pc to 56f8006) and simle rs232 tx, rx pins. idont want use jtag or other type of bootloading.
Sincerely...
1,467件の閲覧回数
jag
You need to put a serial bootloader in the 56F8006 first.
Bye Jack
