56F8037 and COP
56F8037 and COP
887 次查看
giacomopetrini
when I disable the interrupts (using Quickstart API macro "archDisableInt"), the COP is disabled as well or the COP is not influenced by the ICTRL register (so I need to disable it manually if I want)?
Thanks Bye Giacomo
764 次查看
kef
Specialist I
I'm not familiar with 56F devices, but by analogy with other devices, it should be not possible to disable COP, once it is enabled, and of course disabling interrupts should not have influence on COP operation.
