RDDRONE-BMS772
RDDRONE-BMS772
136,350 次查看
iaingalloway
Please ask questions about the RDDRONE-BMS772 board and software here
115 回复数
6,124 次查看
Shane93
I am using the BMS-772 for a university project and do not have access to the battery cell emulator. I was wondering how design a resistor setup on breadboard to mimic the battery cells for purely testing purposes temporarily.
Thank you for any help,
Shane.
6,117 次查看
cisvmierlo
Hello @SH ,
This depends on what you would like to test.
If you would like to have voltages on cell measurement tabs. Without charging or (passively) balancing the cells. You can easily add some resistors over your voltage supply to mimic the cell voltages and measure them with the BMS772.
For example you have a lab power supply and you would like to test a 3S battery (3 cells in series) setup.
You can set the lab power supply to 12V attach them to the power in + and power in - of the BMS. Parallel to that you add a voltage divider with 3 resistors of for example 1kΩ in series from power + to power -.
You can add the 4 balance wires to these resistor (+, - and the 2 in between resistors) to connect to the balance lead connector JP1.
Make sure to solder the BMS for 3S configuration according to the release notes on github: RDDRONE-BMS772/BMS772_releaseNotes_6.0.pdf at main · NXP-Robotics/RDDRONE-BMS772 · GitHub
I would suggest to download this release note PDF as the viewer is clipping the document.
There should be ~4V per "cell" in this setup.
You should be able to start up the BMS772 in normal mode when you power on the lab power supply (current limit could be set to 100mA without a load).
As long as the BMS and power supply is able to handle it and configured for it, you can add a load to the output of the BMS772 as well.
I hope this helps!
Kind regards,
Cis
4,970 次查看
Shane93
Hello again,
Thank you for your help. I have a second BMS-772 board and have soldered the 3 cell connector to the board and I am using a three cell configuration with resistors mimicking cells. However, the CLI always gives me 0v for the 3rd cell and therefore an undervoltage error. There is voltage across the 3rd resistor. I got some solder across the cell setup pads on the bottom of the board but removed most of it. What could be the issue here?
Thank you again for any help,
Shane
4,816 次查看
cisvmierlo
Hi @Shane93 ,
Thank you for reaching out for a question on the RDDRONE-BMS772.
And thank for sharing the helpful images!
Would it be possible to verify the solder connections to make sure the BMS is configured for 3S?
From the image it looks like SJ2 is connected, while SJ12 and SJ10 might not be connected?
If you have a multimeter with resistance measurement, you are able to check with (with resistors removed and the board not powered).
Here you can find more information on the solder jumpers for the cell configuration (3S): https://nxp.gitbook.io/rddrone-bms772/board-user-guide/getting-started-with-the-rddrone-bms772/confi...
Another thing that I notice is that you are using a bread board and Dupont jumper wires. Keep in mind that these are known to have bad connections. I do understand that for debugging this might be easy to do. But a bad connection because of the breadboard and / or the wires could also be a problem.
From what I can see in the image, the way you connect it is OK.
I'm also curious about your settings.
If you type in the CLI / UART command window the following command:
bms get all
What do you see?
I would like to see the n-cells you have configured for example as default this is 6 cells.
You can find which commands to look at in the Chapter 6 Getting started / quick start guide of the release notes (page 9 of 59): RDDRONE-BMS772/BMS772_releaseNotes_6.0.pdf at main · NXP-Robotics/RDDRONE-BMS772 · GitHub
Chapter 6.4.1: The most important BMS variables lets you know what to configure when you start with a BMS. Like n-cells.
You can change n-cells to 3 (in your case) with the command:
bms set n-cells 3
That should make sure the BMS doesn't check the other 3 cells that are not present in your setup.
I hope this helps!
Kind regards,
Cis van Mierlo
4,773 次查看
Shane93
Hi @cisvmierlo
Thank you for all your help. The solder pads seem to be connected, when I run a "bms get all" I get this return. However, measuring across the 3 resistors gives me the natural step down of 12v, 8v, 4v, 0v.
Thank you,
Shane
4,732 次查看
cisvmierlo
@Shane93 ,
Thank you for sharing this information.
I can see that you have configured the BMS for 3 cells (n-cells == 3), a stack voltage (v-batt), but indeed v-cell3 is missing.
This is probably because there is a bad connection with cell 3.
The other 2 cells could have a bad connection as well.
If you look at the schematic in the design files of https://www.nxp.com/design/design-center/development-boards-and-designs/smart-battery-management-for...
You can see that with 3S configuration (SJ6, SJ10, SJ11 and SJ12), cell3 is connected to BP-C6P and CT6.
Cell1 and cell2 are connected to the normal BP-C1M (cell1-), BP-C1P (cell1+) and BP-C2P (cell2+).
Is there a way you could verify the connection of cell 3?
Not just to the balance connector, but the full chain more close to the IC?
Between BP-C2P and CT_2 (cell3-) and BP-C6P and CT_6 (cell3+).
And the other 2 cell's connections.
Could you share more of you your log output?
I would assume you will have an error like: "bcc_monitoring ERROR: stackvoltage too different from sum of cells!"
Can you verify you also did not alter the code? And have the latest release programmed on the BMS772 (version 6.1)?
Do you recall any misconnections to the BMS772 board? For example swapping the voltages on the balance connector? Or connecting to the balance connector wrongly?
As mentioned before, I strongly advise to not use a bread board.
If you really want to use the breadboard, maybe you can make the connections just on the conductive legs of the resistors instead. Using crocodile clamps or clips for example.
I hope this helps!
Kind regards,
Cis van Mierlo
3,957 次查看
Shane93
@cisvmierlo
Thank you very much for you help. Two of the surface mount resistors had lifted on the back of the board causing an error in the cell reading circuit. The issue is resolved now thank you again. I have one final question you might be able to assist with. I am building my own custom CAN interface using NI-XNET with Cyphal CAN. Can you tell me how the CAN frames are structured and the addresses? Also is it possible to turn off the output voltage by controlling the MOSFET's over CAN?
Thank you,
Shane
3,887 次查看
cisvmierlo
Hi @Shane93,
Good that you have found this issue with 2 SMD resistors and thank you for sharing this information.
I believe both CyphalCAN and DroneCAN information can be found in the release notes.
It will mention which messages are implemented.
There is no direct message in either protocol that can turn off the power switch.
With DroneCAN, you can easily change settings and might be able to create an error in which the BMS will turn off the power. For example, changing the overtemperature setting.
You should be able to change the setting back to a "good" value and reset the fault.
This has been tested with DroneCAN.
But if you are creating your own custom CAN interface, you can add this feature yourself.
I hope this helps.
Cis
7,330 次查看
xete
I am trying to flash firmware on to the BMS.
However, I am facing this error when attempting to connect via SWD.
7,326 次查看
cisvmierlo
Hi @xete ,
Could you explain more about your setup in which you face an issue?
How did you power the RDDRONE-BMS772?
What is the status of the RGB LED on the RDDRONE-BMS772?
A picture of your setup would be helpful to be able to assist you in your problem with programming.
Kind regards,
Cis
7,260 次查看
xete
Hi @cisvmierlo ,
Thank you for the quick reply.
I was powering the BMS with a 4S battery. I was also using 3.3V TTL to USB to look at the serial output. The BMS was in the NORMAL state based on the LCD Screen and Serial.
It was connected to a J Link Compact Plus according to the pinout below.
Do let me know if you require any other info/suggestions for troubleshooting
7,254 次查看
cisvmierlo
Hi @xete ,
It seems that the IC is powered and working.
A 4S battery (both LiPo or LiFePO4)  is indeed in the correct supply range. That cannot be the issue.
Maybe a full disconnect (battery, programmer, serial interface) could help?
It could be a connection issue.
Can you try a slower programming speed?
Long wires and pin converters could impact the maximum programing speed.
You now use 1000kHz, "1000", can you try "100"? 100kHz programming speed?
If you would be able to upload a picture of the setup, that might show an issue.
Or provide the voltages on these programmer pins.
It would be interesting to know if the MCU is kept in reset or what VTref is.
Kind regards,
Cis
6,096 次查看
xete
HI @cisvmierlo ,
Thank you for your help. Lowering the clock speed solved the issue.
22,130 次查看
highcatjan
We would like to use the RDDRONE-BMS772 in our drone batteries.
My question is, if there already is a PX4 integration based on UAVCAN?
Is there any work which we can pick up?
Thanks in advance
Jan
22,118 次查看
GeraldP
Yes, we are currently testing the next release candidate of the open source BMS772 reference SW that includes DroneCAN support.
24,741 次查看
lmiles-sosub
Hi All,
I am wondering is there anyway to read the type of fault code from the CLI? I can read the state (bms get state => FAULT) but is there a way to receive the type of fault e.g. over voltage?
If not do you have some guidance on the best way to implement that in the firmware?
Thanks for your help,
Lewis
24,943 次查看
lmiles-sosub
Hi All,
We are facing an issue with the integration of the NXP BMS into our ROV system and hoping for some guidance on the changes I should make to the firmware to resolve the issue.
The problem is we occasionally will deplete a battery during an ROV flight underwater, and the vehicle becomes unrecoverable as the BMS will go into deep sleep. Following an under voltage fault the BMS will enter deep sleep to reduce any further draw on the battery, part of this means turning off the UART communications. If we apply voltage to the BMS it will remain in deep sleep until the physical reset button is pushed. The issue is that the robot is deployed under the water, so physically pushing the button won't work and we aren't able to communicate via UART as it has gone into deep sleep.
So I am seeking any advice on how I might be able to overcome this problem. The goal would be to still have the BMS enter deep sleep mode to prevent further discharge of the battery however to be able to wake the battery via a UART command or if charge voltage is detected.
I was thinking I could attach an interrupt to the UART RX pin before entering deep sleep, which will reset the fault during wake up. Is this a feasible solution and if so is it possible for you to point me in the direction of the firmware I could do this?
Thank you for your help,
Lewis
24,932 次查看
cisvmierlo
Hi Lewis,
Indeed, the BMS goes to deep sleep to preserve any charge left in the battery. Meaning that this will be the lowest power mode (±100uA).
The only way that this is feasible, is to turn off the VCC_3V3_SBC, which is used to power the MCU.
Meaning that the MCU will be off. So, setting an interrupt won't help with waking up from this mode.
The only to wake up from this is mode is to either re-apply a voltage to the BMS or to pull down the SBC's (U3) wake pin (pin 12).
Maybe use J22 to pull down the wake pin (keep in mind that the voltage on this connector is between the battery voltage and 0V). For example, you could use an external switch or signal controlled from your other system to pull this low.
Another solution would be to send the "bms reset" command over de CLI (UART) when you receive the undervoltage fault and the BMS is counting down before going into the deep sleep mode. This will reset the timer.
You could also reconfigure the timeout time for the BMS to go to deep sleep and even disable it.
To do this, see t-fault-timeout in chapter 8.2.2 (page 18) in https://github.com/NXPHoverGames/RDDRONE-BMS772/blob/main/BMS772_releaseNotes_5.0.pdf
Hopefully this will help, kind regards,
Cis van Mierlo
24,887 次查看
lmiles-sosub
Thank you for your reply Cis van Mierlo, that was very helpful.
I was able to get the functionality I needed by using an N-Channel, P-Channel Mosfet with and RC timer to momentarily pull the wake pin low if a charger voltage is connected.
Another thing I am looking into is the time it takes for the BMS to wake from sleep state due to over current detection (i-sleep-oc). The issue I am facing that after a full charge the BMS output will be disabled to stop overcharging, if our robot then draws more current then the charger can supply the BMS will detect this and enable the output. However attaching the scope I have measured a switch time of the BMS of about 300-800ms. This delay is a problem as it causes a brown out for the raspberry pi.
I am wondering if there is a way to reduce this time? Maybe by updating the frequency it checks the output current to wake? If I can reduce the time I can the look into smoothing the voltage drop.
Thanks again for your help.
Lewis.
24,867 次查看
cisvmierlo
Hi Lewis,
From reading your story I'm assuming the BMS is in the charge-complete state. With the power disabled to stop the battery from overcharging.
When your system draws more current than the still attached battery charger can provide, the voltage will drop.
In the charge-complete state, there will not be a current flowing from the battery, as the power switch is open. The BMS will check the output voltage too see if the charger is disconnected.
When the charger has this voltage drop and this drop is low enough for the BMS to think the charger is disconnected, it will go the SLEEP state, but it will first set the MCU in very low power run (VLPR) mode and other peripherals in lower power modes as well before closing the power switch.
After this voltage drop of the charger, will the charger stay off?
Or will it have a lower volage than your battery and the charger is protected against sinking the current?
Kind regards,
Cis van Mierlo
%3CLINGO-SUB%20id%3D%22lingo-sub-1093111%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1093111%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%AF%B7%E5%9C%A8%E6%AD%A4%E5%A4%84%E8%AF%A2%E9%97%AE%E6%9C%89%E5%85%B3%20RDDRONE-BMS772%20%E6%9D%BF%E5%92%8C%E8%BD%AF%E4%BB%B6%E7%9A%84%E9%97%AE%E9%A2%98%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2295106%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2295106%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F258869%22%20target%3D%22_blank%22%3E%40xete%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E9%9B%86%E6%88%90%E7%94%B5%E8%B7%AF%E4%BC%BC%E4%B9%8E%E5%B7%B2%E9%80%9A%E7%94%B5%E5%B9%B6%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E3%80%82%3CBR%20%2F%3E4S%20%E7%94%B5%E6%B1%A0%EF%BC%88%E9%94%82%E8%81%9A%E5%90%88%E7%89%A9%E7%94%B5%E6%B1%A0%E6%88%96%E7%A3%B7%E9%85%B8%E9%93%81%E9%94%82%E7%94%B5%E6%B1%A0%EF%BC%89%E7%A1%AE%E5%AE%9E%E5%9C%A8%E6%AD%A3%E7%A1%AE%E7%9A%84%E4%BE%9B%E7%94%B5%E8%8C%83%E5%9B%B4%E5%86%85%E3%80%82%E8%BF%99%E4%B8%8D%E5%8F%AF%E8%83%BD%E6%98%AF%E9%97%AE%E9%A2%98%E6%89%80%E5%9C%A8%E3%80%82%3CBR%20%2F%3E%E4%B9%9F%E8%AE%B8%E5%AE%8C%E5%85%A8%E6%96%AD%E5%BC%80%E8%BF%9E%E6%8E%A5%EF%BC%88%E7%94%B5%E6%B1%A0%E3%80%81%E7%BC%96%E7%A8%8B%E5%99%A8%E3%80%81%E4%B8%B2%E8%A1%8C%E6%8E%A5%E5%8F%A3%EF%BC%89%E4%BC%9A%E6%9C%89%E5%B8%AE%E5%8A%A9%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E5%8F%AF%E8%83%BD%E6%98%AF%E8%BF%9E%E6%8E%A5%E9%97%AE%E9%A2%98%E3%80%82%20%3CBR%20%2F%3E%E6%82%A8%E8%83%BD%E8%AF%95%E8%AF%95%E8%BE%83%E6%85%A2%E7%9A%84%E7%BC%96%E7%A8%8B%E9%80%9F%E5%BA%A6%E5%90%97%EF%BC%9F%20%3CBR%20%2F%3E%E9%95%BF%E7%BA%BF%E5%92%8C%E5%BC%95%E8%84%9A%E5%8F%98%E6%B5%81%E5%99%A8%E5%8F%AF%E8%83%BD%E4%BC%9A%E5%BD%B1%E5%93%8D%E6%9C%80%E5%A4%A7%E7%BC%96%E7%A8%8B%E9%80%9F%E5%BA%A6%E3%80%82%3CBR%20%2F%3E%E6%82%A8%E7%8E%B0%E5%9C%A8%E4%BD%BF%E7%94%A8%201000kHz%EF%BC%8C%221000%22%20%EF%BC%8C%E6%82%A8%E8%83%BD%E8%AF%95%E8%AF%95%22100%22%20%E5%90%97%EF%BC%9F100%20kHz%20%E7%9A%84%E7%BC%96%E7%A8%8B%E9%80%9F%E5%BA%A6%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E8%83%BD%E4%B8%8A%E4%BC%A0%E8%AE%BE%E7%BD%AE%E7%9A%84%E5%9B%BE%E7%89%87%EF%BC%8C%E5%8F%AF%E8%83%BD%E4%BC%9A%E6%98%BE%E7%A4%BA%E5%87%BA%E9%97%AE%E9%A2%98%E3%80%82%3CBR%20%2F%3E%3CSPAN%3E%E6%88%96%E8%80%85%E6%8F%90%E4%BE%9B%E8%BF%99%E4%BA%9B%E7%BC%96%E7%A8%8B%E5%99%A8%E5%BC%95%E8%84%9A%E4%B8%8A%E7%9A%84%E7%94%B5%E5%8E%8B%E3%80%82%3CBR%20%2F%3E%E6%83%B3%E7%9F%A5%E9%81%93%E5%BE%AE%E6%8E%A7%E5%88%B6%E5%99%A8%E6%98%AF%E5%90%A6%E5%A4%84%E4%BA%8ERESET%E7%8A%B6%E6%80%81%E6%88%96%E8%80%85VTref%E6%98%AF%E4%BB%80%E4%B9%88%E4%BC%9A%E5%BE%88%E6%9C%89%E8%B6%A3%3C%2FSPAN%3E%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%0A%3CP%3ECis%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2295098%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2295098%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%BF%AB%E9%80%9F%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E7%94%A8%204S%20%E7%94%B5%E6%B1%A0%E4%B8%BA%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%E4%BE%9B%E7%94%B5%E3%80%82%E6%88%91%E8%BF%98%E4%BD%BF%E7%94%A8%203.3V%20TTL%20%E8%BD%AC%20USB%20%E6%9D%A5%E6%9F%A5%E7%9C%8B%E4%B8%B2%E8%A1%8C%E8%BE%93%E5%87%BA%E3%80%82%E6%A0%B9%E6%8D%AE%E6%B6%B2%E6%99%B6%E5%B1%8F%E5%92%8C%E4%B8%B2%E8%A1%8C%E4%BF%A1%E6%81%AF%EF%BC%8C%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%20%E5%A4%84%E4%BA%8E%E6%AD%A3%E5%B8%B8%E7%8A%B6%E6%80%81%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%A0%B9%E6%8D%AE%E4%B8%8B%E9%9D%A2%E7%9A%84%E5%BC%95%E8%84%9A%E5%9B%BE%EF%BC%8C%E5%AE%83%E8%A2%AB%E8%BF%9E%E6%8E%A5%E5%88%B0%20J%20Link%20Compact%20Plus%20%E4%B8%8A%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E9%9C%80%E8%A6%81%E4%BB%BB%E4%BD%95%E5%85%B6%E4%BB%96%E4%BF%A1%E6%81%AF%2F%E6%95%85%E9%9A%9C%E6%8E%92%E9%99%A4%E5%BB%BA%E8%AE%AE%EF%BC%8C%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22xete_0-1768570899050.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xete_0-1768570899050.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xete_0-1768570899050.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xete_0-1768570899050.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xete_0-1768570899050.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xete_0-1768570899050.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xete_0-1768570899050.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xete_0-1768570899050.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xete_0-1768570899050.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xete_0-1768570899050.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F373199i227E45D69D530B2D%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22xete_0-1768570899050.png%22%20alt%3D%22xete_0-1768570899050.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2295081%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2295081%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F258869%22%20target%3D%22_blank%22%3E%40xete%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E8%83%BD%E5%90%A6%E8%AF%A6%E7%BB%86%E8%A7%A3%E9%87%8A%E4%B8%80%E4%B8%8B%E6%82%A8%E9%81%87%E5%88%B0%E9%97%AE%E9%A2%98%E6%97%B6%E7%9A%84%E8%AE%BE%E7%BD%AE%E6%83%85%E5%86%B5%EF%BC%9F%3CBR%20%2F%3E%E6%82%A8%E6%98%AF%E5%A6%82%E4%BD%95%E4%B8%BA%20RDDRONE-BMS772%20%E4%BE%9B%E7%94%B5%E7%9A%84%EF%BC%9F%3CBR%20%2F%3ERDDRONE-BMS772%20%E4%B8%8A%20RGB%20LED%20%E7%9A%84%E7%8A%B6%E6%80%81%E5%A6%82%E4%BD%95%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E8%83%BD%E6%8F%90%E4%BE%9B%E6%82%A8%E7%9A%84%E8%AE%BE%E7%BD%AE%E5%9B%BE%E7%89%87%EF%BC%8C%E5%B0%86%E6%9C%89%E5%8A%A9%E4%BA%8E%E5%B8%AE%E5%8A%A9%E6%82%A8%E8%A7%A3%E5%86%B3%E7%BC%96%E7%A8%8B%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%E6%95%AC%E7%A4%BC%EF%BC%8C%3C%2FP%3E%0A%3CP%3ECis%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2295079%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2295079%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E5%B0%86%E5%9B%BA%E4%BB%B6%E5%88%B7%E6%96%B0%E5%88%B0%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%E4%B8%8A%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E5%9C%A8%E5%B0%9D%E8%AF%95%E9%80%9A%E8%BF%87%20SWD%20%E8%BF%9E%E6%8E%A5%E6%97%B6%EF%BC%8C%E6%88%91%E9%81%87%E5%88%B0%E4%BA%86%E8%BF%99%E4%B8%AA%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22xete_0-1768568009515.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xete_0-1768568009515.png%22%20style%3D%22width%3A%20376px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xete_0-1768568009515.png%22%20style%3D%22width%3A%20376px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xete_0-1768568009515.png%22%20style%3D%22width%3A%20376px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xete_0-1768568009515.png%22%20style%3D%22width%3A%20376px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xete_0-1768568009515.png%22%20style%3D%22width%3A%20376px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xete_0-1768568009515.png%22%20style%3D%22width%3A%20376px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xete_0-1768568009515.png%22%20style%3D%22width%3A%20376px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xete_0-1768568009515.png%22%20style%3D%22width%3A%20376px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xete_0-1768568009515.png%22%20style%3D%22width%3A%20376px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F373194i33943E5395F278C4%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22xete_0-1768568009515.png%22%20alt%3D%22xete_0-1768568009515.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1833766%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1833766%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E6%88%91%E4%BB%AC%E7%9B%AE%E5%89%8D%E6%AD%A3%E5%9C%A8%E6%B5%8B%E8%AF%95%E6%94%AF%E6%8C%81%20DroneCan%20%E7%9A%84%E5%BC%80%E6%BA%90%20BMS772%20%E5%8F%82%E8%80%83%E8%BD%AF%E4%BB%B6%E7%9A%84%E4%B8%8B%E4%B8%80%E4%B8%AA%E5%80%99%E9%80%89%E7%89%88%E6%9C%AC%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1833144%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1833144%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E6%88%91%E4%BB%AC%E5%B8%8C%E6%9C%9B%E5%9C%A8%E6%97%A0%E4%BA%BA%E6%9C%BA%E7%94%B5%E6%B1%A0%E4%B8%AD%E4%BD%BF%E7%94%A8%20RDDRONE-BMS772%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E6%88%91%E7%9A%84%E9%97%AE%E9%A2%98%E6%98%AF%EF%BC%8C%E6%98%AF%E5%90%A6%E5%B7%B2%E7%BB%8F%E6%9C%89%E5%9F%BA%E4%BA%8E%20UAVCAN%20%E7%9A%84%20PX4%20%E9%9B%86%E6%88%90%EF%BC%9F%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%9C%89%E4%BB%80%E4%B9%88%E5%B7%A5%E4%BD%9C%E6%98%AF%E6%88%91%E4%BB%AC%E5%8F%AF%E4%BB%A5%E6%8E%A5%E6%89%8B%E7%9A%84%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E9%A2%84%E5%85%88%E6%84%9F%E8%B0%A2%3CBR%20%2F%3EJan%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1734010%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1734010%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E5%9C%A8%E5%85%85%E7%94%B5%E5%99%A8%E7%9A%84%E7%94%B5%E5%8E%8B%E4%B8%8B%E9%99%8D%E4%B9%8B%E5%90%8E%EF%BC%8C%E5%85%85%E7%94%B5%E5%99%A8%E4%BC%9A%E4%BF%9D%E6%8C%81%E5%85%B3%E9%97%AD%E7%8A%B6%E6%80%81%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%AD%A4%E6%97%B6%E5%85%85%E7%94%B5%E5%99%A8%E4%B8%8D%E4%BC%9A%E5%90%AF%E5%8A%A8%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E5%A6%82%E6%9E%9C%E7%94%B5%E6%B5%81%E5%81%9C%E6%AD%A2%EF%BC%8C%E5%AE%83%E5%B0%B1%E4%BC%9A%E9%87%8D%E6%96%B0%E5%90%AF%E5%8A%A8%E5%85%85%E7%94%B5%E8%BF%87%E7%A8%8B%E3%80%82%E4%BB%8A%E5%90%8E%EF%BC%8C%E6%88%91%E4%BB%AC%E5%B0%86%E9%87%87%E7%94%A8%E5%8F%AF%E6%8E%A7%E5%85%85%E7%94%B5%E5%99%A8%EF%BC%8C%E5%9C%A8%E5%85%85%E6%BB%A1%E7%94%B5%E5%90%8E%E7%A6%81%E7%94%A8%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%88%96%E8%80%85%EF%BC%8C%E5%AE%83%E7%9A%84%E7%94%B5%E5%8E%8B%E6%AF%94%E7%94%B5%E6%B1%A0%E4%BD%8E%EF%BC%8C%E8%80%8C%E5%85%85%E7%94%B5%E5%99%A8%E6%9C%89%E4%BF%9D%E6%8A%A4%E5%8A%9F%E8%83%BD%EF%BC%8C%E5%8F%AF%E4%BB%A5%E9%98%B2%E6%AD%A2%E7%94%B5%E6%B5%81%E4%B8%8B%E9%99%8D%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E4%B8%8D%EF%BC%8C%E5%85%85%E7%94%B5%E5%99%A8%E7%9A%84%E7%94%B5%E5%8E%8B%E7%A8%8D%E9%AB%98%E4%B8%80%E4%BA%9B%E6%89%8D%E8%83%BD%E5%AE%9E%E7%8E%B0%E5%AE%8C%E5%85%A8%E5%85%85%E7%94%B5%EF%BC%8C%E4%BD%86%E5%AE%83%E4%B9%9F%E6%9C%89%E9%98%B2%E6%AD%A2%E5%8F%8D%E5%90%91%E7%94%B5%E6%B5%81%E7%9A%84%E4%BF%9D%E6%8A%A4%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%8F%90%E9%AB%98%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%E7%A1%AE%E5%AE%9A%E5%85%85%E7%94%B5%E5%99%A8%E5%B7%B2%E6%96%AD%E5%BC%80%E7%9A%84%E7%94%B5%E5%8E%8B%E7%AD%89%E7%BA%A7%E6%98%AF%E5%90%A6%E5%8F%AF%E8%A1%8C%EF%BC%9F%E8%BF%99%E6%A0%B7%E5%B0%B1%E5%8F%AF%E4%BB%A5%E9%98%B2%E6%AD%A2%E7%94%B5%E8%84%91%E8%A4%90%E5%8F%98%E3%80%82%E7%84%B6%E5%90%8E%EF%BC%8C%E5%AE%83%E5%B0%B1%E4%BC%9A%E9%87%8D%E6%96%B0%E8%BF%9B%E5%85%A5%E5%85%85%E7%94%B5%E7%8A%B6%E6%80%81%EF%BC%8C%E4%BF%9D%E6%8A%A4%E8%87%AA%E5%B7%B1%E4%B8%8D%E4%BC%9A%E8%BF%87%E5%BA%A6%E5%85%85%E7%94%B5%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E8%BF%98%E5%B0%86%E5%AF%B9%20UPS%20%E8%BF%9B%E8%A1%8C%E5%8D%87%E7%BA%A7%EF%BC%8C%E4%BD%9C%E4%B8%BA%E8%A7%A3%E5%86%B3%E9%97%AE%E9%A2%98%E7%9A%84%E6%9B%BF%E4%BB%A3%E6%96%B9%E6%A1%88%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%B8%AE%E5%8A%A9%20%3CLI-EMOJI%20id%3D%22lia_slightly-smiling-face%22%20title%3D%22%3Aslightly_smiling_face%3A%22%3E%3C%2FLI-EMOJI%3E%26nbsp%3B%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1733969%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1733969%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E6%83%B3%E7%9F%A5%E9%81%93%E6%98%AF%E5%90%A6%E8%83%BD%E9%80%9A%E8%BF%87%20CLI%20%E8%AF%BB%E5%8F%96%E6%95%85%E9%9A%9C%E4%BB%A3%E7%A0%81%E7%9A%84%E7%B1%BB%E5%9E%8B%EF%BC%9F%E6%88%91%E8%83%BD%E8%AF%BB%E5%8F%96%E7%8A%B6%E6%80%81%EF%BC%88%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%20%E8%8E%B7%E5%8F%96%E7%8A%B6%E6%80%81%20%3D%20%26gt%3B%20FAULT%EF%BC%89%E4%BD%86%E6%98%AF%E6%9C%89%E6%B2%A1%E6%9C%89%E5%8A%9E%E6%B3%95%E6%8E%A5%E6%94%B6%E6%95%85%E9%9A%9C%E7%B1%BB%E5%9E%8B%EF%BC%8C%E4%BE%8B%E5%A6%82%E8%BF%87%E5%8E%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%B2%A1%E6%9C%89%EF%BC%8C%E6%82%A8%E6%98%AF%E5%90%A6%E6%9C%89%E5%9C%A8%E5%9B%BA%E4%BB%B6%E4%B8%AD%E5%AE%9E%E7%8E%B0%E8%AF%A5%E5%8A%9F%E8%83%BD%E7%9A%84%E6%9C%80%E4%BD%B3%E6%96%B9%E6%B3%95%EF%BC%9F%20%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%B8%AE%E5%8A%A9%EF%BC%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%88%98%E6%98%93%E6%96%AF%20%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1732104%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1732104%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E5%88%98%E6%98%93%E6%96%AF%E3%80%81%3C%2FP%3E%0A%3CP%3E%E9%80%9A%E8%BF%87%E9%98%85%E8%AF%BB%E4%BD%A0%E7%9A%84%E6%95%85%E4%BA%8B%EF%BC%8C%E6%88%91%E5%81%87%E8%AE%BE%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%E5%A4%84%E4%BA%8E%E5%85%85%E7%94%B5%E5%AE%8C%E6%88%90%E7%8A%B6%E6%80%81%E3%80%82%E5%85%B3%E9%97%AD%E7%94%B5%E6%BA%90%EF%BC%8C%E9%98%B2%E6%AD%A2%E7%94%B5%E6%B1%A0%E8%BF%87%E5%BA%A6%E5%85%85%E7%94%B5%E3%80%82%20%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%BD%93%E7%B3%BB%E7%BB%9F%E6%B6%88%E8%80%97%E7%9A%84%E7%94%B5%E6%B5%81%E8%B6%85%E8%BF%87%E4%BB%8D%E8%BF%9E%E6%8E%A5%E7%9A%84%E7%94%B5%E6%B1%A0%E5%85%85%E7%94%B5%E5%99%A8%E6%89%80%E8%83%BD%E6%8F%90%E4%BE%9B%E7%9A%84%E7%94%B5%E6%B5%81%E6%97%B6%EF%BC%8C%E7%94%B5%E5%8E%8B%E5%B0%B1%E4%BC%9A%E4%B8%8B%E9%99%8D%E3%80%82%20%3C%2FP%3E%0A%3CP%3E%E5%9C%A8%E5%85%85%E7%94%B5%E5%AE%8C%E6%88%90%E7%8A%B6%E6%80%81%E4%B8%8B%EF%BC%8C%E7%94%B1%E4%BA%8E%E7%94%B5%E6%BA%90%E5%BC%80%E5%85%B3%E5%A4%84%E4%BA%8E%E6%89%93%E5%BC%80%E7%8A%B6%E6%80%81%EF%BC%8C%E5%9B%A0%E6%AD%A4%E4%B8%8D%E4%BC%9A%E6%9C%89%E7%94%B5%E6%B5%81%E9%87%8F%E4%BB%8E%E7%94%B5%E6%B1%A0%E6%B5%81%E5%87%BA%E3%80%82%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%E5%B0%86%E6%A3%80%E6%9F%A5%E8%BE%93%E5%87%BA%E7%94%B5%E5%8E%8B%EF%BC%8C%E4%BB%A5%E6%9F%A5%E7%9C%8B%E5%85%85%E7%94%B5%E5%99%A8%E6%98%AF%E5%90%A6%E6%96%AD%E5%BC%80%E8%BF%9E%E6%8E%A5%E3%80%82%3CBR%20%2F%3E%E5%BD%93%E5%85%85%E7%94%B5%E5%99%A8%E6%9C%89%E8%BF%99%E6%A0%B7%E7%9A%84%E7%94%B5%E5%8E%8B%E4%B8%8B%E9%99%8D%E5%B9%B6%E4%B8%94%E7%94%B5%E5%8E%8B%E4%B8%8B%E9%99%8D%E8%B6%B3%E5%A4%9F%E4%BD%8E%E4%BB%A5%E8%87%B4%E4%BA%8E%20BMS%20%E8%AE%A4%E4%B8%BA%E5%85%85%E7%94%B5%E5%99%A8%E5%B7%B2%E6%96%AD%E5%BC%80%E8%BF%9E%E6%8E%A5%E6%97%B6%EF%BC%8C%E5%AE%83%E5%B0%86%E8%BF%9B%E5%85%A5%E7%9D%A1%E7%9C%A0%E7%8A%B6%E6%80%81%EF%BC%8C%E4%BD%86%E5%9C%A8%E5%85%B3%E9%97%AD%E7%94%B5%E6%BA%90%E5%BC%80%E5%85%B3%E4%B9%8B%E5%89%8D%EF%BC%8C%E5%AE%83%E4%BC%9A%E9%A6%96%E5%85%88%E5%B0%86%20MCU%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%E6%9E%81%E4%BD%8E%E5%8A%9F%E8%80%97%E8%BF%90%E8%A1%8C%20(VLPR)%20%E6%A8%A1%E5%BC%8F%EF%BC%8C%E5%B9%B6%E5%B0%86%E5%85%B6%E4%BB%96%E5%A4%96%E5%9B%B4%E8%AE%BE%E5%A4%87%E8%AE%BE%E7%BD%AE%E4%B8%BA%E4%BD%8E%E7%94%B5%E6%BA%90%E6%A8%A1%E5%BC%8F%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%9C%A8%E5%85%85%E7%94%B5%E5%99%A8%E7%9A%84%E7%94%B5%E5%8E%8B%E4%B8%8B%E9%99%8D%E4%B9%8B%E5%90%8E%EF%BC%8C%E5%85%85%E7%94%B5%E5%99%A8%E4%BC%9A%E4%BF%9D%E6%8C%81%E5%85%B3%E9%97%AD%E7%8A%B6%E6%80%81%E5%90%97%EF%BC%9F%3CBR%20%2F%3E%E6%88%96%E8%80%85%E5%AE%83%E7%9A%84%E7%94%B5%E5%8E%8B%E6%AF%94%E7%94%B5%E6%B1%A0%E4%BD%8E%EF%BC%8C%E8%80%8C%E5%85%85%E7%94%B5%E5%99%A8%E6%9C%89%E9%98%B2%E6%AD%A2%E7%94%B5%E6%B5%81%E4%B8%8B%E9%99%8D%E7%9A%84%E4%BF%9D%E6%8A%A4%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%B0%A8%E8%87%B4%E9%97%AE%E5%80%99%E3%80%81%3C%2FP%3E%0A%3CP%3E%E8%A5%BF%E6%96%AF-%E8%8C%83%E7%B1%B3%E8%80%B6%E7%BD%97%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1731794%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1731794%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%3CSPAN%3E%EF%BC%8CCis%20van%20Mierlo%3C%2FSPAN%3E%E7%9A%84%E5%9B%9E%E7%AD%94%E9%9D%9E%E5%B8%B8%E6%9C%89%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%E4%B8%80%E4%B8%AA%20N%20%E6%B2%9F%E9%81%93%E3%80%81P%20%E6%B2%9F%E9%81%93%E8%8E%AB%E6%96%AF%E8%8F%B2%E7%AE%A1%E5%92%8C%E4%B8%80%E4%B8%AA%20RC%20%E5%AE%9A%E6%97%B6%E5%99%A8%EF%BC%8C%E5%9C%A8%E8%BF%9E%E6%8E%A5%E5%85%85%E7%94%B5%E5%99%A8%E7%94%B5%E5%8E%8B%E6%97%B6%E5%B0%86%E5%94%A4%E9%86%92%E5%BC%95%E8%84%9A%E7%9E%AC%E9%97%B4%E6%8B%89%E4%BD%8E%EF%BC%8C%E4%BB%8E%E8%80%8C%E5%AE%9E%E7%8E%B0%E4%BA%86%E6%89%80%E9%9C%80%E7%9A%84%E5%8A%9F%E8%83%BD%E3%80%82%20%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E7%A0%94%E7%A9%B6%E7%9A%84%E5%8F%A6%E4%B8%80%E4%BB%B6%E4%BA%8B%E6%98%AF%EF%BC%8C%E7%94%B1%E4%BA%8E%E8%BF%87%E6%B5%81%E6%A3%80%E6%B5%8B%EF%BC%88i-sleep-oc%EF%BC%89%EF%BC%8C%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%E4%BB%8E%E7%9D%A1%E7%9C%A0%E7%8A%B6%E6%80%81%E4%B8%AD%E9%86%92%E6%9D%A5%E6%89%80%E9%9C%80%E7%9A%84%E6%97%B6%E9%97%B4%E3%80%82%E6%88%91%E9%9D%A2%E4%B8%B4%E7%9A%84%E9%97%AE%E9%A2%98%E6%98%AF%EF%BC%8C%E5%85%85%E6%BB%A1%E7%94%B5%E5%90%8E%EF%BC%8C%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%E7%9A%84%E8%BE%93%E5%87%BA%E5%B0%86%E8%A2%AB%E7%A6%81%E7%94%A8%E4%BB%A5%E5%81%9C%E6%AD%A2%E8%BF%87%E5%BA%A6%E5%85%85%E7%94%B5%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%88%91%E4%BB%AC%E7%9A%84%E6%9C%BA%E5%99%A8%E4%BA%BA%E9%9A%8F%E5%90%8E%E6%B6%88%E8%80%97%E6%9B%B4%E5%A4%9A%E7%9A%84%E7%94%B5%E6%B5%81%EF%BC%8C%E5%88%99%E5%85%85%E7%94%B5%E5%99%A8%E5%8F%AF%E4%BB%A5%E6%8F%90%E4%BE%9B%E7%94%B5%E6%B5%81%EF%BC%8C%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%E5%B0%86%E6%A3%80%E6%B5%8B%E5%88%B0%E8%BF%99%E4%B8%80%E7%82%B9%E5%B9%B6%E5%90%AF%E7%94%A8%E8%BE%93%E5%87%BA%E3%80%82%E4%BD%86%E6%98%AF%EF%BC%8C%E8%BF%9E%E6%8E%A5%E7%A4%BA%E6%B3%A2%E5%99%A8%E5%90%8E%EF%BC%8C%E6%88%91%E6%B5%8B%E5%BE%97%E7%9A%84%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%E7%9A%84%E5%88%87%E6%8D%A2%E6%97%B6%E9%97%B4%E7%BA%A6%E4%B8%BA300-800%E6%AF%AB%E7%A7%92%E3%80%82%E8%BF%99%E7%A7%8D%E5%BB%B6%E8%BF%9F%E6%98%AF%E4%B8%80%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%8C%E5%9B%A0%E4%B8%BA%E5%AE%83%E4%BC%9A%E5%AF%BC%E8%87%B4%20raspberry%20pi%20%E6%96%AD%E7%94%B5%E3%80%82%20%3C%2FP%3E%3CP%3E%E6%88%91%E6%83%B3%E7%9F%A5%E9%81%93%E6%98%AF%E5%90%A6%E6%9C%89%E5%8A%9E%E6%B3%95%E7%BC%A9%E7%9F%AD%E8%BF%99%E6%AE%B5%E6%97%B6%E9%97%B4%EF%BC%9F%E4%B9%9F%E8%AE%B8%E9%80%9A%E8%BF%87%E6%9B%B4%E6%96%B0%E9%A2%91%E7%8E%87%E5%8F%AF%E4%BB%A5%E6%A3%80%E6%9F%A5%E8%BE%93%E5%87%BA%E7%94%B5%E6%B5%81%E4%BB%A5%E5%94%A4%E9%86%92%EF%BC%9F%E5%A6%82%E6%9E%9C%E6%88%91%E8%83%BD%E7%BC%A9%E7%9F%AD%E6%97%B6%E9%97%B4%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E8%80%83%E8%99%91%E5%B9%B3%E6%BB%91%E7%94%B5%E5%8E%8B%E4%B8%8B%E9%99%8D%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%86%8D%E6%AC%A1%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%3CP%3E%E5%88%98%E6%98%93%E6%96%AF%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1730178%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1730178%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E5%88%98%E6%98%93%E6%96%AF%E3%80%81%3C%2FP%3E%0A%3CP%3E%E5%AE%9E%E9%99%85%E4%B8%8A%EF%BC%8C%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%E8%BF%9B%E5%85%A5%E6%B7%B1%E5%BA%A6%E7%9D%A1%E7%9C%A0%E7%8A%B6%E6%80%81%E4%BB%A5%E4%BF%9D%E7%95%99%E7%94%B5%E6%B1%A0%E4%B8%AD%E5%89%A9%E4%BD%99%E7%9A%84%E6%89%80%E6%9C%89%E7%94%B5%E9%87%8F%E3%80%82%E8%BF%99%E6%84%8F%E5%91%B3%E7%9D%80%E8%BF%99%E5%B0%86%E6%98%AF%E6%9C%80%E4%BD%8E%E7%94%B5%E6%BA%90%E6%A8%A1%E5%BC%8F%EF%BC%88%C2%B1100uA%EF%BC%89%E3%80%82%3CBR%20%2F%3E%E5%94%AF%E4%B8%80%E5%8F%AF%E8%A1%8C%E7%9A%84%E5%8A%9E%E6%B3%95%E6%98%AF%E5%85%B3%E9%97%AD%E7%94%A8%E4%BA%8E%E4%B8%BA%20MCU%20%E4%BE%9B%E7%94%B5%E7%9A%84%20VCC_3V3_SBC%E3%80%82%3CBR%20%2F%3E%E8%BF%99%E6%84%8F%E5%91%B3%E7%9D%80%20MCU%20%E5%B0%86%E5%85%B3%E9%97%AD%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E8%AE%BE%E7%BD%AE%E4%B8%AD%E6%96%AD%E6%97%A0%E5%8A%A9%E4%BA%8E%E4%BB%8E%E8%AF%A5%E6%A8%A1%E5%BC%8F%E5%94%A4%E9%86%92%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%94%AF%E4%B8%80%E8%83%BD%E4%BB%8E%E4%B8%AD%E5%94%A4%E9%86%92%E7%9A%84%E6%98%AF%E6%A8%A1%E5%BC%8F%EF%BC%8C%E8%A6%81%E4%B9%88%E5%90%91%20%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%20%E9%87%8D%E6%96%B0%E6%96%BD%E5%8A%A0%E7%94%B5%E5%8E%8B%EF%BC%8C%E8%A6%81%E4%B9%88%E6%8B%89%E4%B8%8B%20SBC%EF%BC%88U3%EF%BC%89%E7%9A%84%E5%94%A4%E9%86%92%E5%BC%95%E8%84%9A%EF%BC%88%E5%BC%95%E8%84%9A%2012%EF%BC%89%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%B9%9F%E8%AE%B8%E4%BD%BF%E7%94%A8%20J22%20%E6%8B%89%E4%B8%8B%E5%94%A4%E9%86%92%E5%BC%95%E8%84%9A%EF%BC%88%E8%AF%B7%E8%AE%B0%E4%BD%8F%EF%BC%8C%E6%AD%A4%E8%BF%9E%E6%8E%A5%E5%99%A8%E4%B8%8A%E7%9A%84%E7%94%B5%E5%8E%8B%E4%BB%8B%E4%BA%8E%E7%94%B5%E6%B1%A0%E7%94%B5%E5%8E%8B%E5%92%8C%200V%20%E4%B9%8B%E9%97%B4%EF%BC%89%E3%80%82%E4%BE%8B%E5%A6%82%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E5%A4%96%E9%83%A8%E5%BC%80%E5%85%B3%E6%88%96%E5%85%B6%E4%BB%96%E7%B3%BB%E7%BB%9F%E6%8E%A7%E5%88%B6%E7%9A%84%E4%BF%A1%E5%8F%B7%E5%B0%86%E5%85%B6%E6%8B%89%E4%BD%8E%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%8F%A6%E4%B8%80%E7%A7%8D%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E6%98%AF%EF%BC%8C%E5%BD%93%E4%BD%A0%E6%94%B6%E5%88%B0%E6%AC%A0%E5%8E%8B%E6%95%85%E9%9A%9C%E5%B9%B6%E4%B8%94%20%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%20%E5%9C%A8%E8%BF%9B%E5%85%A5%E6%B7%B1%E5%BA%A6%E7%9D%A1%E7%9C%A0%E6%A8%A1%E5%BC%8F%E4%B9%8B%E5%89%8D%E6%AD%A3%E5%9C%A8%E5%80%92%E8%AE%A1%E6%97%B6%E6%97%B6%EF%BC%8C%E9%80%9A%E8%BF%87%20de%20CLI%20(UART)%20%E5%8F%91%E9%80%81%20%22%20%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%20RESET%20%22%20%E5%91%BD%E4%BB%A4%E3%80%82%E8%BF%99%E5%B0%86%E9%87%8D%E7%BD%AE%E8%AE%A1%E6%97%B6%E5%99%A8%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%BD%A0%E4%B9%9F%E5%8F%AF%E4%BB%A5%E9%87%8D%E6%96%B0%E9%85%8D%E7%BD%AE%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%E8%BF%9B%E5%85%A5%E6%B7%B1%E5%BA%A6%E7%9D%A1%E7%9C%A0%E7%9A%84%E8%B6%85%E6%97%B6%E6%97%B6%E9%97%B4%EF%BC%8C%E7%94%9A%E8%87%B3%E5%B0%86%E5%85%B6%E7%A6%81%E7%94%A8%E3%80%82%3CBR%20%2F%3E%E8%A6%81%E5%81%9A%E5%88%B0%E8%BF%99%E4%B8%80%E7%82%B9%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2Fblob%2Fmain%2FBMS772_releaseNotes_5.0.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2Fblob%2Fmain%2FBMS772_releaseNotes_5.0.pdf%3C%2FA%3E%E7%AC%AC%208.2.2%20%E7%AB%A0%EF%BC%88%E7%AC%AC%2018%20%E9%A1%B5%EF%BC%89%E4%B8%AD%E7%9A%84%20t-fault-timeout%3CBR%20%2F%3E%3CBR%20%2F%3E%EF%BC%8C%E5%B8%8C%E6%9C%9B%E5%AF%B9%E6%82%A8%E6%9C%89%E6%89%80%E5%B8%AE%E5%8A%A9%EF%BC%8C%E8%B0%A8%E8%87%B4%E9%97%AE%E5%80%99%EF%BC%8C%3CBR%20%2F%3E%3CBR%20%2F%3ECis%20van%20Mierlo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1730153%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1730153%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E5%9C%A8%E5%B0%86%E6%81%A9%E6%99%BA%E6%B5%A6%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%E9%9B%86%E6%88%90%E5%88%B0%E6%88%91%E4%BB%AC%E7%9A%84ROV%E7%B3%BB%E7%BB%9F%E6%97%B6%E9%81%87%E5%88%B0%E4%BA%86%E9%97%AE%E9%A2%98%EF%BC%8C%E5%B8%8C%E6%9C%9B%E8%83%BD%E5%B0%B1%E6%88%91%E5%BA%94%E8%AF%A5%E5%AF%B9%E5%9B%BA%E4%BB%B6%E8%BF%9B%E8%A1%8C%E5%93%AA%E4%BA%9B%E6%9B%B4%E6%94%B9%E4%BB%A5%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E8%8E%B7%E5%BE%97%E4%B8%80%E4%BA%9B%E6%8C%87%E5%AF%BC%E3%80%82%3C%2FP%3E%3CP%3E%E9%97%AE%E9%A2%98%E5%9C%A8%E4%BA%8E%EF%BC%8C%E5%9C%A8%E6%B0%B4%E4%B8%8B%E6%BD%9C%E6%B0%B4%E4%B8%8B%E9%A3%9E%E8%A1%8C%E6%9C%9F%E9%97%B4%EF%BC%8C%E6%88%91%E4%BB%AC%E5%81%B6%E5%B0%94%E4%BC%9A%E8%80%97%E5%B0%BD%E7%94%B5%E6%B1%A0%E7%94%B5%E9%87%8F%EF%BC%8C%E9%9A%8F%E7%9D%80%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%E8%BF%9B%E5%85%A5%E6%B7%B1%E5%BA%A6%E7%9D%A1%E7%9C%A0%EF%BC%8C%E9%A3%9E%E8%A1%8C%E5%99%A8%E5%8F%98%E5%BE%97%E6%97%A0%E6%B3%95%E6%81%A2%E5%A4%8D%E3%80%82%E5%87%BA%E7%8E%B0%E6%AC%A0%E5%8E%8B%E6%95%85%E9%9A%9C%E5%90%8E%EF%BC%8C%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%E5%B0%86%E8%BF%9B%E5%85%A5%E6%B7%B1%E5%BA%A6%E7%9D%A1%E7%9C%A0%E4%BB%A5%E5%87%8F%E5%B0%91%E5%AF%B9%E7%94%B5%E6%B1%A0%E7%9A%84%E8%BF%9B%E4%B8%80%E6%AD%A5%E6%B6%88%E8%80%97%EF%BC%8C%E5%85%B6%E4%B8%AD%E4%B8%80%E9%83%A8%E5%88%86%E6%84%8F%E5%91%B3%E7%9D%80%E5%85%B3%E9%97%ADUART%E9%80%9A%E4%BF%A1%E3%80%82%E5%A6%82%E6%9E%9C%E6%88%91%E4%BB%AC%E5%90%91%20%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%20%E6%96%BD%E5%8A%A0%E7%94%B5%E5%8E%8B%EF%BC%8C%E5%AE%83%E5%B0%86%E4%BF%9D%E6%8C%81%E6%B7%B1%E5%BA%A6%E7%9D%A1%E7%9C%A0%E7%8A%B6%E6%80%81%EF%BC%8C%E7%9B%B4%E5%88%B0%E6%8C%89%E4%B8%8B%E7%89%A9%E7%90%86%20RESET%20%E6%8C%89%E9%92%AE%E3%80%82%E9%97%AE%E9%A2%98%E6%98%AF%EF%BC%8C%E6%9C%BA%E5%99%A8%E4%BA%BA%E9%83%A8%E7%BD%B2%E5%9C%A8%E6%B0%B4%E4%B8%8B%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%8C%89%E4%B8%8B%E6%8C%89%E9%92%AE%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%EF%BC%8C%E6%88%91%E4%BB%AC%E4%B9%9F%E6%97%A0%E6%B3%95%E9%80%9A%E8%BF%87%20UART%20%E8%BF%9B%E8%A1%8C%E9%80%9A%E4%BF%A1%EF%BC%8C%E5%9B%A0%E4%B8%BA%E5%AE%83%E5%B7%B2%E8%BF%9B%E5%85%A5%E6%B7%B1%E5%BA%A6%E4%BC%91%E7%9C%A0%E7%8A%B6%E6%80%81%E3%80%82%3C%2FP%3E%3CP%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%88%91%E6%83%B3%E5%B0%B1%E5%A6%82%E4%BD%95%E5%85%8B%E6%9C%8D%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E5%AF%BB%E6%B1%82%E5%BB%BA%E8%AE%AE%E3%80%82%E7%9B%AE%E6%A0%87%E6%98%AF%E4%BB%8D%E7%84%B6%E8%AE%A9%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%E8%BF%9B%E5%85%A5%E6%B7%B1%E5%BA%A6%E7%9D%A1%E7%9C%A0%E6%A8%A1%E5%BC%8F%E4%BB%A5%E9%98%B2%E6%AD%A2%E7%94%B5%E6%B1%A0%E8%BF%9B%E4%B8%80%E6%AD%A5%E6%94%BE%E7%94%B5%EF%BC%8C%E4%BD%86%E6%98%AF%E8%83%BD%E5%A4%9F%E9%80%9A%E8%BF%87UART%E5%91%BD%E4%BB%A4%E6%88%96%E6%A3%80%E6%B5%8B%E5%88%B0%E5%85%85%E7%94%B5%E7%94%B5%E5%8E%8B%E6%97%B6%E5%94%A4%E9%86%92%E7%94%B5%E6%B1%A0%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%9C%A8%E6%83%B3%E6%88%91%E5%8F%AF%E4%BB%A5%E5%9C%A8%E8%BF%9B%E5%85%A5%E6%B7%B1%E5%BA%A6%E7%9D%A1%E7%9C%A0%E4%B9%8B%E5%89%8D%E5%9C%A8%20UART%20RX%20%E5%BC%95%E8%84%9A%E4%B8%8A%E8%BF%9E%E6%8E%A5%E4%B8%80%E4%B8%AA%E4%B8%AD%E6%96%AD%EF%BC%8C%E8%BF%99%E5%B0%86%E5%9C%A8%E9%86%92%E6%9D%A5%E6%97%B6%20RESET%20%E6%95%85%E9%9A%9C%E3%80%82%E8%BF%99%E6%98%AF%E5%90%A6%E6%98%AF%E4%B8%80%E4%B8%AA%E5%8F%AF%E8%A1%8C%E7%9A%84%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%EF%BC%9F%E5%A6%82%E6%9E%9C%E6%98%AF%EF%BC%8C%E6%82%A8%E8%83%BD%E5%90%A6%E4%B8%BA%E6%88%91%E6%8C%87%E5%87%BA%E5%9B%BA%E4%BB%B6%E7%9A%84%E6%96%B9%E5%90%91%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%B8%AE%E5%8A%A9%E3%80%81%3C%2FP%3E%3CP%3E%E5%88%98%E6%98%93%E6%96%AF%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1730004%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1730004%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E4%BD%A0%EF%BC%8C%E8%BF%99%E4%B8%AA%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E5%AF%B9%E6%88%91%E4%BB%AC%E5%BE%88%E6%9C%89%E6%95%88%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1702673%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1702673%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F212097%22%20target%3D%22_blank%22%3E%40lmiles-sosub%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E9%97%B8%E9%97%A8%E6%A3%80%E6%9F%A5%E7%9A%84%E7%9B%AE%E7%9A%84%E6%98%AF%E7%A1%AE%E4%BF%9D%E9%97%B8%E9%97%A8%E9%A9%B1%E5%8A%A8%E5%99%A8%E8%83%BD%E5%A4%9F%E5%85%B3%E9%97%AD%E7%94%B5%E6%BA%90%E3%80%82%E5%A6%82%E6%9E%9C%E8%BF%99%E4%B8%AA%E5%85%83%E5%99%A8%E4%BB%B6%E6%88%96%E5%85%B6%E4%BB%96%E5%85%83%E5%99%A8%E4%BB%B6%E5%87%BA%E7%8E%B0%E9%97%AE%E9%A2%98%E5%B9%B6%E4%B8%94%E6%97%A0%E6%B3%95%E5%85%B3%E9%97%AD%E7%94%B5%E6%BA%90%EF%BC%8C%E8%BF%99%E5%8F%AF%E8%83%BD%E4%BC%9A%E5%AF%BC%E8%87%B4%E5%8A%9F%E8%83%BD%E5%AE%89%E5%85%A8%E9%97%AE%E9%A2%98%EF%BC%8C%E5%9B%A0%E6%AD%A4%E9%9C%80%E8%A6%81%E8%BF%9B%E8%A1%8C%E8%87%AA%E6%A3%80%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%98%8E%E7%99%BD%EF%BC%8C%E5%B0%B1%E4%BD%A0%E7%9A%84%E7%9B%AE%E7%9A%84%E8%80%8C%E8%A8%80%EF%BC%8C%E8%BF%99%E5%B9%B6%E4%B8%8D%E7%90%86%E6%83%B3%E3%80%82%E5%A6%82%E6%9E%9C%E6%82%A8%E8%AE%A4%E4%B8%BA%E8%BF%99%E6%A0%B7%E5%81%9A%E6%98%AF%E5%AE%89%E5%85%A8%E7%9A%84%EF%BC%8C%E5%8F%AF%E4%BB%A5%E5%9C%A8%E6%82%A8%E7%9A%84%E8%BD%AF%E4%BB%B6%E4%B8%AD%E7%A6%81%E7%94%A8%E8%BF%99%E4%B8%80%E6%A3%80%E6%9F%A5%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%B7%E8%AE%B0%E4%BD%8F%EF%BC%8C%E5%AE%83%E4%B8%8D%E4%BC%9A%E6%A3%80%E6%9F%A5%E6%98%AF%E5%90%A6%E5%8F%AF%E4%BB%A5%E5%85%B3%E9%97%AD%E7%94%B5%E6%BA%90%E3%80%82%3C%2FP%3E%3CP%3E%E5%8F%A6%E5%A4%96%EF%BC%8C%E6%88%91%E5%BB%BA%E8%AE%AE%E4%BD%A0%E4%BB%8D%E7%84%B6%E5%85%B3%E9%97%AD%E8%BF%99%E9%83%A8%E5%88%86%E4%BB%A3%E7%A0%81%E4%B8%AD%E7%9A%84%E7%94%B5%E6%BA%90%EF%BC%8C%E4%BD%A0%E5%8F%AF%E4%BB%A5%E7%94%A8%E4%B8%8B%E9%9D%A2%E7%9A%84%E4%BB%A3%E7%A0%81%E6%9B%BF%E6%8D%A2%E8%BF%99%E9%83%A8%E5%88%86%E4%BB%A3%E7%A0%81%EF%BC%8C%E6%88%96%E8%80%85%E6%B7%BB%E5%8A%A0%E7%BC%96%E8%AF%91%E5%BC%80%E5%85%B3%EF%BC%88%23ifdef%20%23else%20%23endif%EF%BC%89%EF%BC%8C%E8%BF%99%E6%A0%B7%E4%BD%A0%E5%B0%B1%E5%8F%AF%E4%BB%A5%E5%BE%88%E5%AE%B9%E6%98%93%E5%9C%B0%E5%9B%9E%E5%88%B0%E5%8E%9F%E6%9D%A5%E7%9A%84%E7%8A%B6%E6%80%81%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%A5%E9%83%A8%E5%88%86%E9%9C%80%E8%A6%81%E6%9B%BF%E6%8D%A2%E6%88%96%E6%94%BE%E5%85%A5%E7%BC%96%E8%AF%91%E5%BC%80%E5%85%B3%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2Fblob%2Fmain%2Fsrc%2FbatManagement.c%23L608-L672%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%EF%BC%9A%3C%2FA%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2Fblob%2Fmain%2Fsrc%2FbatManagement.c%23L608-L672%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2Fblob%2Fmain%2Fsrc%2FbatManagement.c%23L608-L672%3C%2FA%3E%20%3C%2FP%3E%3CP%3E%E6%88%91%E5%BB%BA%E8%AE%AE%E6%82%A8%E8%BF%98%E6%98%AF%E6%B7%BB%E5%8A%A0%E8%BF%99%E6%AE%B5%E4%BB%A3%E7%A0%81%EF%BC%9A%3C%2FP%3E%3CP%3E%2F%2F%20%E4%BB%8D%E7%84%B6%E5%85%B3%E9%97%AD%E9%97%B8%E9%97%A8%3CBR%20%2F%3EbatManagement_setGatePower(GATE_OPEN)%EF%BC%9B%3C%2FP%3E%3CP%3Ecli_printfWarning(%22SELF-TEST%20GATE%3A%20TURNED%20OFF!%5Cn%22)%EF%BC%9B%3C%2FP%3E%3CP%3E%E5%B8%8C%E6%9C%9B%E8%BF%99%E8%83%BD%E5%9B%9E%E7%AD%94%E4%BD%A0%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%B0%A8%E8%87%B4%E9%97%AE%E5%80%99%E3%80%81%3C%2FP%3E%3CP%3E%E8%A5%BF%E6%96%AF-%E8%8C%83%E7%B1%B3%E8%80%B6%E7%BD%97%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1702511%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1702511%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E6%AD%A3%E5%9C%A8%E6%B5%8B%E8%AF%95%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%E5%9C%A8ROV%E7%B3%BB%E7%BB%9F%E4%B8%AD%E7%9A%84%E4%BD%BF%E7%94%A8%EF%BC%8C%E8%AF%A5%E5%85%85%E7%94%B5%E5%99%A8%E5%8F%AF%E6%8C%81%E7%BB%AD%E4%B8%BAROV%E6%8F%90%E4%BE%9B%E7%94%B5%E5%8A%9B%EF%BC%8C%E7%94%B5%E6%B1%A0%E5%B0%86%E4%B8%BA%E8%B6%85%E8%BF%87%E5%85%85%E7%94%B5%E5%99%A8%E5%8A%9F%E7%8E%87%E5%AE%B9%E9%87%8F%E7%9A%84%E5%B3%B0%E5%80%BC%E8%B4%9F%E8%BD%BD%E6%8F%90%E4%BE%9B%E7%94%B5%E5%8A%9B%E3%80%82%3C%2FP%3E%3CP%3E%E5%BD%93%E7%94%B5%E6%B1%A0%E8%BE%BE%E5%88%B0%E6%AC%A0%E5%8E%8B%E4%BF%9D%E6%8A%A4%EF%BC%88%E8%BF%9B%E5%85%A5%E6%95%85%E9%9A%9C%E6%A8%A1%E5%BC%8F%EF%BC%89%E6%97%B6%EF%BC%8C%E6%88%91%E4%BB%AC%E9%81%87%E5%88%B0%E4%BA%86%E4%B8%80%E4%BA%9B%E9%97%AE%E9%A2%98%EF%BC%8C%E6%88%91%E4%BB%AC%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E5%B0%86%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%E4%BB%8E%E6%95%85%E9%9A%9C%E7%8A%B6%E6%80%81%E4%B8%AD%E6%81%A2%E5%A4%8D%EF%BC%8C%E4%BB%A5%E4%BE%BF%E8%83%BD%E5%A4%9F%E4%B8%BA%E7%94%B5%E6%B1%A0%E5%85%85%E7%94%B5%E3%80%82%3C%2FP%3E%3CP%3E%E7%90%86%E6%83%B3%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8C%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%20%E4%BC%9A%E5%85%B3%E9%97%AD%E8%BE%93%E5%87%BA%EF%BC%8C%E4%BD%86%E4%BB%8D%E5%85%81%E8%AE%B8%E5%85%85%E7%94%B5%E7%94%B5%E6%B5%81%E8%BF%9B%E5%85%A5%E7%94%B5%E6%B1%A0%EF%BC%8C%E6%97%A0%E9%9C%80%20RESET%E3%80%82%E7%9B%AE%E5%89%8D%EF%BC%8C%E6%88%91%E4%BB%AC%E6%AD%A3%E5%9C%A8%E9%80%9A%E8%BF%87CLI%E8%BF%9C%E7%A8%8BRESET%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%E4%BB%A5%E6%B6%88%E9%99%A4%E6%95%85%E9%9A%9C%EF%BC%8C%E4%BD%86%E6%98%AF%E8%A6%81%E4%B8%BA%E7%B3%BB%E7%BB%9F%E4%BE%9B%E7%94%B5%EF%BC%8C%E6%88%91%E4%BB%AC%E5%BF%85%E9%A1%BB%E6%89%93%E5%BC%80%E5%85%85%E7%94%B5%E5%99%A8%EF%BC%8C%E8%BF%99%E4%BC%9A%E5%AF%BC%E8%87%B4%E8%87%AA%E6%A3%80%E5%A4%B1%E8%B4%A5%E5%B9%B6%E5%BB%BA%E8%AE%AE%E6%8B%86%E4%B8%8B%E5%85%85%E7%94%B5%E5%99%A8%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84%E9%97%AE%E9%A2%98%E6%98%AF%E5%85%85%E7%94%B5%E5%99%A8%E5%BF%85%E9%A1%BB%E6%96%AD%E5%BC%80%E8%BF%9E%E6%8E%A5%E6%89%8D%E8%83%BD%E8%BF%9B%E8%A1%8C%E6%A0%85%E6%9E%81%E8%87%AA%E6%A3%80%E7%9A%84%E5%8A%9F%E8%83%BD%E3%80%82%E5%A6%82%E6%9E%9C%E6%88%91%E5%9C%A8%E5%9B%BA%E4%BB%B6%E4%B8%AD%E7%A6%81%E7%94%A8%E5%AE%83%EF%BC%8C%E4%BC%9A%E4%B8%8D%E4%BC%9A%E5%87%BA%E7%8E%B0%E4%B8%A5%E9%87%8D%E9%97%AE%E9%A2%98%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%3CP%3E%E5%88%98%E6%98%93%E6%96%AF%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1686646%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1686646%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F214383%22%20target%3D%22_blank%22%3E%40suvasis%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3ERDDRONE-BMS772%20%E7%9A%84%20.brd%20%E5%B8%83%E5%B1%80%E6%96%87%E4%BB%B6%E5%B7%B2%E6%B7%BB%E5%8A%A0%E5%88%B0%E8%AE%BE%E8%AE%A1%E6%96%87%E4%BB%B6%E4%B8%AD%EF%BC%8C%E5%8F%AF%E4%BE%9B%E4%B8%8B%E8%BD%BD%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%B7%E5%8F%82%E8%A7%81%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesigns%2Fsmart-battery-management-for-mobile-robotics%3ARDDRONE-BMS772%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesigns%2Fsmart-battery-management-for-mobile-robotics%3ARDDRONE-BMS772%3C%2FA%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%E6%95%AC%E7%A4%BC%EF%BC%8C%3C%2FP%3E%3CP%3E%E8%A5%BF%E6%96%AF-%E8%8C%83%E7%B1%B3%E8%80%B6%E7%BD%97%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1679245%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1679245%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E6%88%91%E5%B0%9D%E8%AF%95%E9%87%8D%E5%90%AF%E5%B9%B6%E9%87%8D%E6%96%B0%E5%90%AF%E5%8A%A8%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%E4%BD%86%E6%97%A0%E6%B5%8E%E4%BA%8E%E4%BA%8B%E3%80%82%E6%88%91%E4%BC%9A%E5%B0%9D%E8%AF%95%E8%BF%9B%E5%85%A5%20DEEP_SLEEP%E3%80%82%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3EPRINCE%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1673640%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1673640%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F195015%22%20target%3D%22_blank%22%3E%40Prince1%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E6%98%AF%E5%90%A6%E5%B0%9D%E8%AF%95%E8%BF%87%E4%BD%BF%E7%94%A8%22reboot%22%20%E5%91%BD%E4%BB%A4%E9%87%8D%E5%90%AF%20MCU%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E4%BD%A0%E5%8F%AF%E4%BB%A5%E5%B0%9D%E8%AF%95%E9%87%8D%E7%BD%AE%E9%80%9A%E4%BF%A1%E9%94%99%E8%AF%AF%EF%BC%88%E6%AD%A3%E5%A6%82%E4%BA%BA%E4%BB%AC%E6%89%80%E8%AE%B0%E4%BD%8F%E7%9A%84%E9%82%A3%E6%A0%B7%EF%BC%89%E7%9A%84%E5%8F%A6%E4%B8%80%E4%BB%B6%E4%BA%8B%E6%98%AF%20DEEP_SLEEP%20%E7%84%B6%E5%90%8E%E6%81%A2%E5%A4%8D%E5%88%B0%E6%AD%A3%E5%B8%B8%E7%8A%B6%E6%80%81%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%90%A6%E5%88%99%EF%BC%8C%E4%BD%A0%E5%8F%AF%E4%BB%A5%E5%B0%9D%E8%AF%95%E9%87%8D%E6%96%B0%E5%90%AF%E5%8A%A8%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%E7%9A%84%E7%94%B5%E6%BA%90%E6%9D%A5%E8%A7%A3%E5%86%B3%E9%97%AE%E9%A2%98%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%B0%A8%E8%87%B4%E9%97%AE%E5%80%99%E3%80%81%3C%2FP%3E%0A%3CP%3E%E8%A5%BF%E6%96%AF-%E8%8C%83%E7%B1%B3%E8%80%B6%E7%BD%97%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1673634%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1673634%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F214383%22%20target%3D%22_blank%22%3E%40suvasis%3C%2FA%3E%EF%BC%8C%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E9%97%AE%E8%BF%87%E5%9B%A2%E9%98%9F%E8%83%BD%E5%90%A6%E5%B0%86%E6%9D%BF%E6%96%87%E4%BB%B6%20(.brd)%20%E4%B8%8A%E4%BC%A0%E5%88%B0%20nxp.com%E3%80%82%3CBR%20%2F%3E%E8%AF%B7%E6%B3%A8%E6%84%8F%EF%BC%8C%E8%BF%99%E5%8F%AF%E8%83%BD%E9%9C%80%E8%A6%81%E5%87%A0%E5%A4%A9%E6%97%B6%E9%97%B4%E3%80%82%3C%2FP%3E%3CP%3E%E7%A4%BA%E6%84%8F%E5%9B%BE%E6%96%87%E4%BB%B6%20(.DSN)%20%E5%B7%B2%E5%8C%85%E5%90%AB%E5%9C%A8%E5%86%85%E3%80%82%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%E6%95%AC%E7%A4%BC%EF%BC%8C%3C%2FP%3E%3CP%3E%E8%A5%BF%E6%96%AF-%E8%8C%83%E7%B1%B3%E8%80%B6%E7%BD%97%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1673616%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1673616%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3ETera%20term%20%E4%B8%8E%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%E8%BF%9E%E6%8E%A5%E6%97%B6%E5%87%A0%E4%B9%8E%E6%B2%A1%E6%9C%89%E5%87%BA%E7%8E%B0%E9%94%99%E8%AF%AF%EF%BC%8C%E5%A6%82%E9%9A%8F%E9%99%84%E7%9A%84%E5%9B%BE%E5%83%8F%E6%89%80%E7%A4%BA%E3%80%82%3C%2FP%3E%3CP%3E%22%E6%97%A0%E6%B3%95%E8%BF%9B%E8%A1%8C%E6%B5%8B%E9%87%8F%EF%BC%8C%E4%B9%9F%E6%97%A0%E6%B3%95%E6%9B%B4%E6%96%B0%E6%B5%8B%E9%87%8F%E7%BB%93%E6%9E%9C%22%3C%2FP%3E%3CP%3E%E8%AF%B7%E5%B8%AE%E5%8A%A9%E8%A7%A3%E5%86%B3%E8%BF%99%E4%BA%9B%E9%97%AE%E9%A2%98%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3EPRINCE%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1672228%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1672228%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E8%AF%95%E5%9B%BE%E4%B8%BA%E6%88%91%E7%9A%84%E6%97%A0%E4%BA%BA%E6%9C%BA%E9%87%8D%E6%96%B0%E8%AE%BE%E8%AE%A1%E5%A4%96%E5%BD%A2%E6%9B%B4%E5%B0%8F%E7%9A%84%E5%8D%B0%E5%88%B7%E7%94%B5%E8%B7%AF%E6%9D%BF%E3%80%82%E4%BB%A5%E4%B8%8B%E6%96%87%E4%BB%B6%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesigns%2Fsmart-battery-management-for-mobile-robotics%3ARDDRONE-BMS772%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesigns%2Fsmart-battery-management-for-mobile-robotics%3ARDDRONE-BMS772%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%B0%81%E8%83%BD%3C%2FSPAN%3E%E6%8F%90%E4%BE%9B%E5%8D%B0%E5%88%B7%E7%94%B5%E8%B7%AF%E6%9D%BF%E7%9A%84%E6%BA%90%E6%96%87%E4%BB%B6%EF%BC%9F%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3E%E8%B0%81%E8%83%BD%E5%B8%AE%E5%B8%AE%E6%88%91%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FP%3E%3CP%3Esuvasis%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1631017%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1631017%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F213615%22%20target%3D%22_blank%22%3E%40dmorvay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id%3D%22lingo-sub-1630511%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1630511%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F213615%22%20target%3D%22_blank%22%3E%40dmorvay%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%85%B3%E4%BA%8E%E7%AC%AC%E4%BA%8C%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20S32K14x%20%E7%9A%84%20MBD%20%E5%B7%A5%E5%85%B7%E7%AE%B1%E5%BB%BA%E7%AB%8B%E5%9C%A8%E9%80%82%E7%94%A8%E4%BA%8E%20S32K14x%20%E7%9A%84%E8%BD%AF%E4%BB%B6%E5%BC%80%E5%8F%91%E5%B7%A5%E5%85%B7%E5%8C%85%E4%B9%8B%E4%B8%8A%E3%80%82%E9%81%97%E6%86%BE%E7%9A%84%E6%98%AF%EF%BC%8CSDK%20%E4%BC%BC%E4%B9%8E%E4%B8%8D%E6%94%AF%E6%8C%81%20LPI2C%20%E7%9A%84%204%20%E7%BA%BF%E6%A8%A1%E5%BC%8F%EF%BC%8C%E5%9B%A0%E6%AD%A4%20MBD%20%E5%B7%A5%E5%85%B7%E7%AE%B1%E4%B9%9F%E4%B8%8D%E6%94%AF%E6%8C%81%E8%BF%99%E7%A7%8D%E6%A8%A1%E5%BC%8F%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3E%E7%8F%AD%E8%A5%BF%E6%8B%89-%E7%B4%A2%E6%9E%97%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1629818%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1629818%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E6%8F%90%E4%BE%9B%E8%BF%99%E4%BA%9B%E4%BF%A1%E6%81%AF%E3%80%82%E6%88%91%E4%BB%8D%E7%84%B6%E4%B8%8D%E7%A1%AE%E5%AE%9A%E7%AC%AC%E4%B8%80%E4%B8%AA%E9%97%AE%E9%A2%98%E7%9A%84%E7%AD%94%E6%A1%88--PTA2%2FPTA3%20(J23)%20%E8%83%BD%E5%90%A6%E9%85%8D%E7%BD%AE%E4%B8%BA%20I2C%20%E4%BB%8E%E5%B1%9E%E8%AE%BE%E5%A4%87%EF%BC%9F%E8%BF%99%E7%A7%8D%20I%2FO%20%E6%98%AF%E5%90%A6%E6%9C%89%E4%BB%BB%E4%BD%95%E9%99%90%E5%88%B6%EF%BC%8C%E5%BF%85%E9%A1%BB%E5%A7%8B%E7%BB%88%E9%85%8D%E7%BD%AE%E4%B8%BA%E4%B8%BB%E8%AE%BE%E5%A4%87%EF%BC%9F%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1629793%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1629793%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F213615%22%20target%3D%22_blank%22%3E%40dmorvay%3C%2FA%3E%E3%80%81%20%3C%2FP%3E%0A%3CP%3E%E6%88%91%E4%B8%8D%E7%86%9F%E6%82%89%20MBDT%20%E7%A4%BA%E4%BE%8B%E4%BB%A5%E5%8F%8A%E8%AF%A5%E5%B7%A5%E5%85%B7%E7%AE%B1%E6%94%AF%E6%8C%81%E7%9A%84%E5%8A%9F%E8%83%BD%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E5%85%B3%E4%BA%8E%20C%20%2F%20C%2B%2B%20%E7%A4%BA%E4%BE%8B%EF%BC%8C%E6%88%91%E5%BB%BA%E8%AE%AE%E6%82%A8%E5%8F%82%E8%80%83%20NuttX%20RTOS%20SW%20%E7%A4%BA%E4%BE%8B%E3%80%82%3CBR%20%2F%3E%E5%9C%A8%E6%9C%AC%E7%A4%BA%E4%BE%8B%E4%B8%AD%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%E8%AF%BB%E5%8F%96%E8%A1%A8%206%20%E4%B8%AD%E6%89%80%E8%BF%B0%E7%9A%84%E6%AD%A3%E7%A1%AE%E7%9A%84%20I2C%20%E5%9C%B0%E5%9D%80%EF%BC%8C%E9%80%9A%E8%BF%87%20I2C%20%E8%8E%B7%E5%8F%96%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%E6%95%B0%E6%8D%AE%E3%80%82SMBus%20%E5%8F%98%E9%87%8F%E5%88%97%E8%A1%A8%EF%BC%88%E5%8F%82%E8%A7%81%E7%AC%AC%207.5%20%E7%AB%A0%20%E5%A6%82%E4%BD%95%E4%BD%BF%E7%94%A8%20SMBus%EF%BC%89%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E8%AF%A5%E7%A4%BA%E4%BE%8B%E4%BD%8D%E4%BA%8E%E6%AD%A4%E5%A4%84%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%EF%BC%9A%3C%2FA%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%3C%2FA%3E%20%3CBR%20%2F%3E%E5%AE%83%E8%BF%98%E9%9C%80%E8%A6%81%20NuttX%20RTOS%20%E6%BA%90%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fapache%2Fnuttx%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%EF%BC%9A%3C%2FA%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fapache%2Fnuttx%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fapache%2Fnuttx%3C%2FA%3E%20%3CBR%20%2F%3E%E6%9F%A5%E7%9C%8B%20NuttX%20%E5%AD%98%E5%82%A8%E5%BA%93%E4%B8%AD%E7%9A%84%20RDDRONE-BMS772%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fapache%2Fnuttx%2Ftree%2Fmaster%2Fboards%2Farm%2Fs32k1xx%2Frddrone-bms772%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%20%E6%9D%BF%EF%BC%9Ahttps%3A%2F%2Fgithub.com%2Fapache%2Fnuttx%2Ftree%2Fmaster%2Fboards%2Farm%2Fs32k1xx%2Frddrone-bms772%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E4%BB%A5%E5%8F%8A%20S32K1xx%20%E6%9E%B6%E6%9E%84%E7%89%B9%E5%AE%9A%E9%80%BB%E8%BE%91%20%EF%BC%9A%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fapache%2Fnuttx%2Ftree%2Fmaster%2Farch%2Farm%2Fsrc%2Fs32k1xx%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%20https%3A%2F%2Fgithub.com%2Fapache%2Fnuttx%2Ftree%2Fmaster%2Farch%2Farm%2Fsrc%2Fs32k1xx%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%B8%8C%E6%9C%9B%E5%AF%B9%E6%82%A8%E6%9C%89%E6%89%80%E5%B8%AE%E5%8A%A9%EF%BC%81%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%87%B4%E4%BB%A5%E4%BA%B2%E5%88%87%E7%9A%84%E9%97%AE%E5%80%99%E3%80%81%3C%2FP%3E%0A%3CP%3E%E8%A5%BF%E6%96%AF-%E8%8C%83%E7%B1%B3%E8%80%B6%E7%BD%97%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1629762%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1629762%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%3C%2FA%3E%3C%2FP%3E%3CP%3E%E6%A0%B9%E6%8D%AE%E4%BD%A0%E7%9A%84%E5%9B%9E%E7%AD%94%EF%BC%8C%E5%86%8D%E9%97%AE%E4%B8%A4%E4%B8%AA%E9%97%AE%E9%A2%98......%3C%2FP%3E%3CP%3E1.PTA2%20%E5%92%8C%20PTA3%EF%BC%88%E8%BF%9E%E6%8E%A5%E5%99%A8%20J23%EF%BC%89%E8%83%BD%E5%90%A6%E9%85%8D%E7%BD%AE%E4%B8%BA%20I2C%20%E4%BB%8E%E5%B1%9E%E8%AE%BE%E5%A4%87%EF%BC%9F%E5%9C%A8%E8%BD%AF%E4%BB%B6%E6%96%B9%E9%9D%A2%EF%BC%8C%E8%BF%99%E4%BC%BC%E4%B9%8E%E6%98%AF%E5%8F%AF%E8%83%BD%E7%9A%84%EF%BC%8C%E4%BD%86%E8%A6%81%E7%A1%AE%E4%BF%9D%E7%A1%AC%E4%BB%B6%E5%92%8C%E8%BD%AF%E4%BB%B6%E6%96%B9%E9%9D%A2%E7%9A%84%E4%B8%80%E5%88%87%E9%83%BD%E6%A3%80%E6%9F%A5%E6%97%A0%E8%AF%AF%E3%80%82%3C%2FP%3E%3CP%3E2.%E5%A6%82%E4%BD%95%E9%85%8D%E7%BD%AE%3CSPAN%3E%20LPI2C0_SCLS%3C%2FSPAN%3E%3CSTRONG%3E%20%3C%2FSTRONG%3E%3CSPAN%3E%E5%92%8C%20LPI2C0%20_%20SDAS%3C%2FSPAN%3E%3CSTRONG%3E%20%EF%BC%9F%3C%2FSTRONG%3E%E4%BD%A0%E6%9C%89%E5%85%B3%E4%BA%8E%E5%A6%82%E4%BD%95%E5%9C%A8%20C%20%E4%BB%A3%E7%A0%81%E5%92%8C%2F%E6%88%96%E9%80%9A%E8%BF%87%E5%9F%BA%E4%BA%8E%E6%A8%A1%E5%9E%8B%E7%9A%84%E5%BC%80%E5%8F%91%E8%BF%9B%E8%A1%8C%E9%85%8D%E7%BD%AE%E7%9A%84%E5%8F%82%E8%80%83%E8%B5%84%E6%96%99%E5%90%97%EF%BC%9F%E6%88%91%E7%9B%AE%E5%89%8D%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E5%9F%BA%E4%BA%8E%E6%A8%A1%E5%9E%8B%E7%9A%84%E5%BC%80%E5%8F%91%EF%BC%8C%E4%BD%86%E6%B2%A1%E6%9C%89%E7%9C%8B%E5%88%B0%E4%BB%BB%E4%BD%95%E5%B8%A6%E6%9C%89%3CSPAN%3E%20LPI2C0_SCLS%3C%2FSPAN%3E%3CSTRONG%3E%20%3C%2FSTRONG%3E%3CSPAN%3E%E5%92%8C%20LPI2C0_SDAS%20%E7%9A%84%E5%A4%96%E8%AE%BE%3C%2FSPAN%3E%3CSTRONG%3E%20%E3%80%82%3C%2FSTRONG%3E%E6%AD%A4%E5%A4%96%EF%BC%8CI2C%20%E9%85%8D%E7%BD%AE%E5%9D%97%E5%8F%AA%E6%9C%89%20PTA2%2FPTA3%20%E6%88%96%20PTB6%2FPTB7%20%E9%80%89%E9%A1%B9%E3%80%82%E6%88%91%E4%B8%8D%E5%A4%AA%E6%B8%85%E6%A5%9A%E5%A6%82%E4%BD%95%E6%BF%80%E6%B4%BB%E8%AF%A5%E8%BE%93%E5%87%BA%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1629540%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1629540%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F213615%22%20target%3D%22_blank%22%3E%40dmorvay%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E8%BF%9E%E6%8E%A5%E5%99%A8%20J18%20%E5%8F%AF%E7%94%A8%E4%BA%8E%20SMBUS%20%2F%3CSTRONG%3EI2CS%3C%2FSTRONG%3E%E3%80%82%20%3CBR%20%2F%3ESMBUS_SCL%20%E5%92%8C%20SMBUS_SDA%20%E7%BA%BF%E8%B7%AF%E8%BF%9E%E6%8E%A5%E8%87%B3%E8%AF%A5%E8%BF%9E%E6%8E%A5%E5%99%A8%E3%80%82%3C%2FP%3E%3CP%3E%E8%BF%99%E4%BA%9B%E7%BA%BF%E8%B7%AF%E6%98%AF%20PTA0%20%E5%92%8C%20PTA1%20%E7%9A%84%E8%BF%9E%E6%8E%A5%E5%99%A8%EF%BC%8C%E7%94%A8%E4%BA%8E%E6%94%AF%E6%8C%81%20LPI2C0_SCLS%3CSTRONG%3E%E5%92%8C%20%3C%2FSTRONG%3E%2FLPI2C0_SDAS%3CSTRONG%3E%E5%A4%96%E8%AE%BE%20%3C%2FSTRONG%3E%E3%80%82%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%E6%95%AC%E7%A4%BC%EF%BC%8C%3C%2FP%3E%3CP%3E%E8%A5%BF%E6%96%AF-%E8%8C%83%E7%B1%B3%E8%80%B6%E7%BD%97%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1629440%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1629440%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%3C%2FA%3E%3C%2FP%3E%3CP%3E%E5%85%B3%E4%BA%8E%20I2C%20%E9%80%9A%E4%BF%A1%E7%9A%84%E5%8F%A6%E4%B8%80%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%9A%E5%B0%86%20BMS772%20%E9%85%8D%E7%BD%AE%E4%B8%BA%E4%BB%8E%E5%B1%9E%E8%AE%BE%E5%A4%87%E6%97%B6%EF%BC%8CSDA%2FSCL%20%E5%BC%95%E8%84%9A%E5%BA%94%E5%88%86%E5%88%AB%E4%B8%BA%20PTB6%20%E5%92%8C%20PTB7%EF%BC%8C%E8%BF%98%E6%98%AF%20PTA2%20%E5%92%8C%20PTA3%EF%BC%9F%E4%BB%8E%E5%8E%9F%E7%90%86%E5%9B%BE%E4%B8%8A%E7%9C%8B%EF%BC%8C%E4%BC%BC%E4%B9%8E%E5%AE%9E%E9%99%85%E4%B8%8A%E4%B8%8D%E6%98%AF%E8%BF%99%E4%B8%A4%E4%B8%AA%E9%80%89%E9%A1%B9%EF%BC%8C%E8%80%8C%E6%98%AF%20PTA0%20%E5%92%8C%20PTA1%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%88%91%E5%AF%B9%E5%A6%82%E4%BD%95%E5%B0%86%E6%9D%BF%E8%AE%BE%E7%BD%AE%E4%B8%BAI2C%E9%80%9A%E4%BF%A1%E7%9A%84%E4%BB%8E%E6%9C%BA%E6%9C%89%E7%82%B9%E5%9B%B0%E6%83%91%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1624966%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1624966%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%3CP%3E%E9%81%97%E6%86%BE%E7%9A%84%E6%98%AF%EF%BC%8C%E6%81%A9%E6%99%BA%E6%B5%A6%E6%96%87%E6%A1%A3%E4%B8%AD%E6%8E%A8%E8%8D%90%E7%9A%84%20PSMNR70-30YLH%20MOSFET%20%E5%9C%A8%E6%88%91%E5%B0%9D%E8%AF%95%E7%9A%84%E7%BD%91%E7%AB%99%E4%B8%8A%E4%B9%B0%E4%B8%8D%E5%88%B0%E3%80%82%E8%BF%99%E6%98%AF%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%8C%E5%9B%A0%E4%B8%BA%E6%88%91%E6%97%A0%E6%B3%95%E5%8A%9F%E8%83%BD%E5%AE%89%E5%85%A8%E5%9C%B0%E6%B5%8B%E8%AF%95%E6%9D%BF%E3%80%82%E6%88%91%E5%9C%A8%E8%BF%99%E4%B8%AA%E7%A4%BE%E5%8C%BA%E9%87%8C%E7%9C%8B%E5%88%B0%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E5%9C%A8%20Nexperia%20%E6%89%BE%E5%88%B0%E5%AE%83%EF%BC%8C%E4%BD%86%E6%9C%80%E5%B0%8F%E8%AE%A2%E8%B4%AD%E9%87%8F%E6%98%AF%201500%E3%80%82%E6%88%91%E8%AF%95%E5%9B%BE%E5%AF%BB%E6%89%BE%E5%8F%A6%E4%B8%80%E7%A7%8D%E5%90%8C%E7%AD%89%E7%9A%84%E4%BA%A7%E5%93%81%EF%BC%8C%E4%BD%86%E6%B2%A1%E6%9C%89%E6%89%BE%E5%88%B0%E5%85%B7%E6%9C%89%E7%9B%B8%E5%90%8C%E7%89%B9%E6%80%A7%E7%9A%84%E4%BA%A7%E5%93%81%E3%80%82%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%E5%85%AC%E5%B7%AE%E6%88%96%20MOSFET%20%E7%9A%84%E5%B7%AE%E5%BC%82%E6%9C%89%E5%A4%9A%E5%A4%A7%E3%80%82%3C%2FP%3E%3CP%3E%E6%81%A9%E6%99%BA%E6%B5%A6%E6%8E%A8%E8%8D%90%E7%9A%84%20MOSFET%20%E7%89%B9%E6%80%A7%E5%A6%82%E4%B8%8B%E3%80%82%E8%AF%B7%E9%97%AE%E8%BF%98%E8%83%BD%E6%8E%A5%E5%8F%97%E5%93%AA%E4%BA%9B%E7%89%B9%E6%80%A7%EF%BC%8C%E6%88%96%E8%80%85%E6%82%A8%E8%BF%98%E8%83%BD%E6%8E%A8%E8%8D%90%E5%93%AA%E4%BA%9B%E5%90%88%E9%80%82%E7%9A%84%E7%89%B9%E6%80%A7%EF%BC%9F%20%3C%2FP%3E%3CP%3E%3CSPAN%3EN%20%E6%B2%9F%E9%81%93%2030%20V%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E0.82%20m%CE%A9%E3%80%81%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E300%20A%20%E9%80%BB%E8%BE%91%E7%94%B5%E5%B9%B3%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E9%87%87%E7%94%A8%20NextPowerS3%20%E6%8A%80%E6%9C%AF%E7%9A%84%20LFPAK56%20%E4%B8%AD%E7%9A%84%20MOSFET%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1624947%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1624947%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%3C%2FA%3E%E3%80%82%E6%88%91%E8%AE%A4%E4%B8%BARESET%E4%BF%A1%E5%8F%B7%E6%9C%89%E9%97%AE%E9%A2%98%E3%80%82%E7%8E%B0%E5%9C%A8%E5%A5%BD%E4%BA%86%EF%BC%8C%E8%B0%A2%E8%B0%A2%E4%BD%A0%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1623162%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1623162%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F212364%22%20target%3D%22_blank%22%3E%40DaveNXP%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E6%9C%89%E7%A4%BA%E6%B3%A2%E5%99%A8%E5%90%97%EF%BC%9F%E4%BD%A0%E8%83%BD%E6%B5%8B%E9%87%8F%E4%B8%80%E4%B8%8B%20MCU%20RESET%20%E7%BA%BF%E4%B8%8A%E6%98%AF%E5%90%A6%E6%9C%89%E8%84%89%E5%86%B2%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%E6%95%AC%E7%A4%BC%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E8%A5%BF%E6%96%AF-%E8%8C%83%E7%B1%B3%E8%80%B6%E7%BD%97%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1623057%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1623057%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E7%AD%94%E3%80%81%3C%2FP%3E%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E5%B0%9D%E8%AF%95%E8%BF%87%E4%BD%BF%E7%94%A8%20J2%20%E8%BF%9E%E6%8E%A5%E5%99%A8%EF%BC%88%E6%94%BE%E7%BD%AE%E5%A5%BD%E4%BA%86%EF%BC%89%E6%83%B3%E6%83%B3%20JTAG%20%E7%BA%BF%E8%B7%AF%EF%BC%8C%E6%9C%89%20RESET%20%E8%B7%B3%E7%BA%BF%E5%92%8C%E6%B2%A1%E6%9C%89%20RESET%20%E8%B7%B3%E7%BA%BF%E3%80%82%E4%BD%86%E6%88%91%E4%BB%8D%E7%84%B6%E6%97%A0%E6%B3%95%E8%BF%9E%E6%8E%A5%E5%88%B0%E7%9B%AE%E6%A0%87%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E8%83%BD%E5%81%9A%E4%BB%80%E4%B9%88%E5%91%A2%EF%BC%9F%E6%88%91%E6%80%8E%E6%A0%B7%E6%89%8D%E8%83%BD%E6%A3%80%E6%9F%A5RESET%E7%BA%BF%E8%B7%AF%E6%98%AF%E5%90%A6%E6%AD%A3%E7%A1%AE%E8%BF%9E%E6%8E%A5%E4%BB%A5%E5%8F%8A%E4%BF%A1%E5%8F%B7%E6%AD%A3%E5%B8%B8%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1623027%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1623027%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F212364%22%20target%3D%22_blank%22%3E%40DaveNXP%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E4%BD%A0%E8%83%BD%E6%A3%80%E6%9F%A5%E4%B8%80%E4%B8%8B%E8%B0%83%E8%AF%95%E5%99%A8%E7%9A%84RESET%E8%A1%8C%E5%90%97%EF%BC%9F%E4%B8%8E%20MCU%20%E7%9A%84%E8%BF%9E%E6%8E%A5%E6%98%AF%E5%90%A6%E6%AD%A3%E7%A1%AE%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%88%96%E8%80%85%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%94%BE%E7%BD%AE%E4%BA%86%20J2%EF%BC%8C%E4%B9%9F%E8%AE%B8%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E8%BF%99%E4%B8%AA%202x5%20%E8%BF%9E%E6%8E%A5%E5%99%A8%E9%80%9A%E8%BF%87%E8%AF%A5%E7%BC%96%E7%A8%8B%E5%A4%B4%E5%AF%B9%E6%9D%BF%E8%BF%9B%E8%A1%8C%E7%BC%96%E7%A8%8B%EF%BC%9F%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%B2%A1%E6%9C%89%E6%94%BE%E7%BD%AE%20J2%EF%BC%8C%E4%B9%9F%E8%AE%B8%E4%BD%A0%E5%8F%AF%E4%BB%A5%E7%84%8A%E6%8E%A5%E4%B8%80%E4%B8%AA%202x5%20%E5%BC%95%E8%84%9A%E6%8E%A5%E5%A4%B4%EF%BC%8C%E9%80%9A%E8%BF%87%E8%AF%A5%E8%B7%AF%E7%94%B1%E5%AF%B9%E6%9D%BF%E8%BF%9B%E8%A1%8C%E7%BC%96%E7%A8%8B%E3%80%82%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%E6%95%AC%E7%A4%BC%EF%BC%8C%3C%2FP%3E%3CP%3E%E8%A5%BF%E6%96%AF-%E8%8C%83%E7%B1%B3%E8%80%B6%E7%BD%97%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1622556%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1622556%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%9C%89%E4%BA%BA%E7%9F%A5%E9%81%93%E5%A6%82%E4%BD%95%E5%B0%86%20RDDRONE%20%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%20%E6%9D%BF%E6%81%A2%E5%A4%8D%E5%87%BA%E5%8E%82%E8%AE%BE%E7%BD%AE%EF%BC%88%E6%88%96%E5%B0%86%E5%85%B6%E5%94%A4%E9%86%92%EF%BC%89%E5%90%97%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%9D%BF%E5%8F%AF%E8%83%BD%E5%A4%84%E4%BA%8E%E6%B7%B1%E5%BA%A6%E7%9D%A1%E7%9C%A0%E7%8A%B6%E6%80%81%E6%88%96%E8%80%85%E5%A4%84%E4%BA%8E%E6%88%91%E6%97%A0%E6%B3%95%E6%91%86%E8%84%B1%E7%9A%84%E7%8A%B6%E6%80%81%E3%80%82%3C%2FP%3E%3CP%3E%E8%B5%B7%E5%88%9D%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E8%BF%9E%E6%8E%A5%E5%88%B0%E5%86%85%E6%A0%B8%EF%BC%88%E5%B7%B2%E8%AF%86%E5%88%AB%E7%9A%84%20Cortex-M4%EF%BC%89%EF%BC%8C%E4%BD%86%E5%9C%A8%E6%AD%A4%E4%B9%8B%E5%90%8E%EF%BC%8C%E5%BD%93%E6%88%91%E5%B0%9D%E8%AF%95%E9%97%AA%E5%AD%98%E5%9B%BA%E4%BB%B6%E6%97%B6%EF%BC%8C%E5%B0%B1%E5%86%8D%E4%B9%9F%E6%97%A0%E6%B3%95%E8%BF%9E%E6%8E%A5%E5%88%B0%E7%9B%AE%E6%A0%87%E4%BA%86%EF%BC%88%E6%97%A5%E5%BF%97%E5%B7%B2%E5%9C%A8%E4%B8%8A%E4%B8%80%E7%AF%87%E6%96%87%E7%AB%A0%E4%B8%AD%E5%A4%8D%E5%88%B6%EF%BC%89%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%88%91%E6%97%A0%E6%B3%95%E4%BD%BF%E7%94%A8%20J-Link%20Commander%20%E5%8F%91%E9%80%81%E4%BB%BB%E4%BD%95%E5%91%BD%E4%BB%A4%E3%80%82J-Link%20%E8%B0%83%E8%AF%95%E5%99%A8%E7%9A%84%E7%94%B5%E5%8E%8B%E4%B8%BA%203.3V%E3%80%82%E6%88%91%E5%9C%A8%E6%9D%BF%E9%80%9A%E7%94%B5%E6%97%B6%E6%8C%89%E4%B8%8B%E4%BA%86%E7%89%A9%E7%90%86%E6%8C%89%E9%92%AE%EF%BC%8C%E4%BD%86%E6%B2%A1%E6%9C%89%E4%BB%BB%E4%BD%95%E5%8F%98%E5%8C%96%EF%BC%8C%E5%AE%83%E4%B9%9F%E6%97%A0%E6%B3%95%E5%94%A4%E9%86%92%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%BF%99%E5%8F%91%E7%94%9F%E5%9C%A8%E6%88%91%E4%B9%B0%E7%9A%84%E4%B8%A4%E4%B8%AA%20RDDRONE%20%E6%9D%BF%E4%B8%8A%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%AF%B7%E6%8F%90%E4%BE%9B%E4%BB%BB%E4%BD%95%E5%B8%AE%E5%8A%A9%EF%BC%8C%E6%88%91%E4%BB%AC%E5%B0%86%E4%B8%8D%E8%83%9C%E6%84%9F%E6%BF%80%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%3C%2FA%3E%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F15914%22%20target%3D%22_blank%22%3E%40iaingalloway%3C%2FA%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1620687%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1620687%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E8%B0%A2%E8%B0%A2%E4%BD%A0%E7%9A%84%E5%9B%9E%E7%AD%94%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E8%AF%95%E7%9D%80%E6%8C%89%E4%B8%8B%20SW1%20%E6%8C%89%E9%92%AE%E3%80%82%E6%88%91%E8%AF%95%E8%BF%87%E7%94%A8RESET%E8%B7%B3%E7%BA%BF%E4%BD%86%E6%B2%A1%E6%9C%89%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%B0%9D%E8%AF%95%E6%8C%89%E7%85%A7s32k1xx%E6%95%B0%E6%8D%AE%E8%A1%A8%E4%B8%AD%E7%9A%84%E7%94%B5%E6%B0%94%E8%A7%84%E6%A0%BC%E4%BD%BF%E7%94%A8%E4%BF%A1%E5%8F%B7%E5%8F%91%E7%94%9F%E5%99%A8%E7%94%9F%E6%88%90RESET%20%E8%84%89%E5%86%B2%E3%80%82%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fdata-sheet%2FS32K-DS.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fdata-sheet%2FS32K-DS.pdf%3C%2FA%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%A3%80%E6%9F%A5%E4%BA%86%E6%89%80%E6%9C%89%E7%94%B5%E5%8E%8B%E3%80%82%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E8%BF%9E%E6%8E%A5%20FTDI%20%E7%94%B5%E7%BC%86%EF%BC%8C%E5%9C%A8%E5%BC%80%E5%85%B3%E7%94%B5%E6%BA%90%E6%97%B6%EF%BC%8CTera%20Term%20%E6%8E%A7%E5%88%B6%E5%8F%B0%E4%B8%AD%E4%BC%9A%E5%87%BA%E7%8E%B0%E4%B8%80%E4%BA%9B%E4%B9%B1%E4%B8%83%E5%85%AB%E7%B3%9F%E7%9A%84%E6%96%9C%E7%BA%BF%E5%99%AA%E9%9F%B3%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1620180%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1620180%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%BD%93%E4%BD%A0%E4%BD%BF%E7%94%A8%20JLINK%20%E8%BD%AF%E4%BB%B6%E5%92%8C%E8%B0%83%E8%AF%95%E5%99%A8%E8%BF%9E%E6%8E%A5%E5%88%B0%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%E6%97%B6%EF%BC%8CJLINK.exe%20%E9%A6%96%E5%85%88%E6%89%93%E5%8D%B0%E5%87%BA%E6%9D%A5%E7%9A%84%E5%86%85%E5%AE%B9%E4%B9%8B%E4%B8%80%E6%98%AF%20MCU%2F%E8%B0%83%E8%AF%95%E7%AB%AF%E5%8F%A3%E4%B8%8A%E7%9A%84%E7%94%B5%E5%8E%8B%E3%80%82%3C%2FP%3E%3CP%3E%E5%8D%B3%E4%BD%BF%20%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%E6%9D%BF%20%E6%8E%A5%E5%85%A5%2022V%20%E6%88%96%E4%BB%BB%E4%BD%95%E5%A4%96%E9%83%A8%E7%94%B5%E6%BA%90%EF%BC%8C%E4%B9%9F%E6%9C%89%E5%8F%AF%E8%83%BD%E6%97%A0%E6%B3%95%E5%BC%80%E5%90%AF%E4%B8%BA%20MCU%20%E4%BE%9B%E7%94%B5%E7%9A%84%E5%AE%9E%E9%99%85%E7%94%B5%E6%BA%90%E3%80%82%3C%2FP%3E%3CP%3E%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%E4%B8%8A%E6%9C%89%E4%B8%80%E4%B8%AA%E5%BE%AE%E5%B0%8F%E7%9A%84%E7%89%A9%E7%90%86%E6%8C%89%E9%92%AE%EF%BC%8C%E5%8F%AF%E4%BB%A5%E5%94%A4%E9%86%92%20MCU%20%E7%94%B5%E6%BA%90%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fnxp.gitbook.io%2Frddrone-bms772%2Fuser-guide%2Fgetting-to-know-the-hardware%2Fboard-organization%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fnxp.gitbook.io%2Frddrone-bms772%2Fuser-guide%2Fgetting-to-know-the-hardware%2Fboard-organization%3C%2FA%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1619705%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1619705%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E8%A5%BF%E6%96%AF-%E8%8C%83%E7%B1%B3%E8%80%B6%E7%BD%97%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%B0%83%E8%AF%95%E5%99%A8%E6%8F%90%E4%BE%9B%203.3V%20%E7%94%B5%E5%8E%8B%E3%80%82%E8%80%8C%E4%B8%94%E8%BF%9E%E6%8E%A5%E5%88%B0%20RDDRONE%20%E6%9D%BF%E8%BE%93%E5%85%A5%E7%9A%84%E7%94%B5%E6%BA%90%E7%9A%84%E8%BE%93%E5%87%BA%E4%B8%BA%2022%2C2V%E3%80%82%E6%88%91%E4%B8%8D%E5%A4%AA%E6%B8%85%E6%A5%9A%E9%97%AE%E9%A2%98%E5%8F%AF%E8%83%BD%E5%87%BA%E5%9C%A8%E5%93%AA%E9%87%8C%EF%BC%8C%E6%88%91%E5%BA%94%E8%AF%A5%E5%81%9A%E5%93%AA%E4%BA%9B%E6%9B%B4%E6%94%B9%E5%92%8C%E6%B5%8B%E8%AF%95%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%E6%9C%89%E4%BB%80%E4%B9%88%E6%8C%89%E9%92%AE%E5%8F%AF%E4%BB%A5%E6%8C%89%EF%BC%8C%E4%B9%9F%E4%B8%8D%E7%9F%A5%E9%81%93%E6%9C%89%E4%BB%80%E4%B9%88%E5%8A%9E%E6%B3%95%E5%8F%AF%E4%BB%A5%E9%87%8D%E6%96%B0%E5%90%AF%E5%8A%A8%E3%80%82%E5%A6%82%E6%9E%9C%E8%83%BD%E5%BE%97%E5%88%B0%E4%BB%BB%E4%BD%95%E5%B8%AE%E5%8A%A9%EF%BC%8C%E6%88%91%E5%B0%86%E4%B8%8D%E8%83%9C%E6%84%9F%E6%BF%80%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E3%80%82%E8%B0%A8%E8%87%B4%E9%97%AE%E5%80%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1619239%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1619239%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F212364%22%20target%3D%22_blank%22%3E%40DaveNXP%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E8%83%BD%E5%90%A6%E6%A0%B9%E6%8D%AE%E8%B0%83%E8%AF%95%E5%99%A8%E6%A3%80%E6%9F%A5%E4%B8%80%E4%B8%8B%E7%94%B5%E5%8E%8B%E6%98%AF%E5%90%A6%E6%AD%A3%E5%B8%B8%EF%BC%9F%3CBR%20%2F%3E%E4%B9%9F%E8%AE%B8%20SW%20%E4%BD%BF%E7%B3%BB%E7%BB%9F%E5%A4%84%E4%BA%8E%E6%B7%B1%E5%BA%A6%E4%BC%91%E7%9C%A0%E7%8A%B6%E6%80%81%EF%BC%8C%E9%9C%80%E8%A6%81%E6%8C%89%E4%B8%8B%E6%8C%89%E9%92%AE%E6%89%8D%E8%83%BD%E5%86%8D%E6%AC%A1%E5%90%AF%E5%8A%A8%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%E6%95%AC%E7%A4%BC%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E8%A5%BF%E6%96%AF-%E8%8C%83%E7%B1%B3%E8%80%B6%E7%BD%97%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1619209%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1619209%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%84%9F%E8%B0%A2%20cisvmierlo%20%E7%9A%84%E5%9B%9E%E7%AD%94%E3%80%81%3C%2FP%3E%3CP%3E%E9%97%AE%E9%A2%98%E6%98%AF%EF%BC%8C%E8%B5%B7%E5%88%9D%E6%88%91%E5%8F%AF%E4%BB%A5%E6%AD%A3%E7%A1%AE%E8%BF%9E%E6%8E%A5%E5%88%B0%20RDDRONE-BMS772%20%E6%9D%BF%E4%B8%8A%E7%9A%84%E5%86%85%E6%A0%B8%EF%BC%8C%E4%BD%86%E6%98%AF%E5%9C%A8%E7%AC%AC%E4%B8%80%E6%AC%A1%E9%97%AA%E5%AD%98%E4%B9%8B%E5%90%8E%E6%88%91%E5%B0%B1%E6%97%A0%E6%B3%95%E5%86%8D%E8%BF%9E%E6%8E%A5%E5%88%B0%E6%9D%BF%E4%B8%8A%E7%9A%84%E5%86%85%E6%A0%B8%E4%BA%86%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%88%91%E6%97%A0%E6%B3%95%E5%8F%91%E9%80%81%E6%82%A8%E6%8E%A8%E8%8D%90%E7%9A%84%20%22h%20%22%E5%91%BD%E4%BB%A4%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%A0%E8%BF%98%E6%9C%89%E5%85%B6%E4%BB%96%E6%83%B3%E6%B3%95%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1619170%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1619170%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F212364%22%20target%3D%22_blank%22%3E%40DaveNXP%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E7%9C%8B%E6%9D%A5%E4%BD%A0%E5%8F%AF%E4%BB%A5%E8%BF%9E%E6%8E%A5%E5%88%B0%E5%86%85%E6%A0%B8%EF%BC%8C%E4%BD%86%E4%B8%8D%E8%83%BD%E6%93%A6%E9%99%A4%E6%88%96%E9%9D%9E%E5%88%B7%E6%96%B0%E5%86%85%E6%A0%B8%E3%80%82%3C%2FP%3E%3CP%3E%E6%82%A8%E8%83%BD%E5%90%A6%E5%B0%9D%E8%AF%95%E9%87%8D%E5%90%AF%20J-Link%20%E6%8C%87%E6%8C%A5%E5%AE%98%EF%BC%8C%E5%B9%B6%E4%BD%BF%E7%94%A8%20%22h%20%22%E5%91%BD%E4%BB%A4%E5%81%9C%E6%AD%A2%E6%A0%B8%E5%BF%83%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%E6%95%AC%E7%A4%BC%EF%BC%8C%3C%2FP%3E%3CP%3E%E8%A5%BF%E6%96%AF-%E8%8C%83%E7%B1%B3%E8%80%B6%E7%BD%97%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1619116%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1619116%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E5%9C%A8%20RDDRONE-BMS772%20%E6%9D%BF%E4%B8%8A%E9%81%87%E5%88%B0%E4%BA%86%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%8C%89%E7%85%A7%20RDDRONE-BMS772%20%E6%89%8B%E5%86%8C%E4%B8%AD%E9%92%88%E5%AF%B9%206s%20%E7%94%B5%E6%B1%A0%E7%9A%84%E5%BB%BA%E8%AE%AE%EF%BC%8C%E7%84%8A%E6%8E%A5%E4%BA%86%E7%A1%AC%E4%BB%B6%22%E9%85%8D%E7%BD%AE%E7%84%8A%E7%9B%98%22%20%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fnxp.gitbook.io%2Frddrone-bms772%2Fuser-guide%2Fgetting-started-with-the-rddrone-bms772%2Fconfiguring-the-hardware%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fnxp.gitbook.io%2Frddrone-bms772%2Fuser-guide%2Fgetting-started-with-the-rddrone-bms772%2Fconfiguring-the-hardware%3C%2FA%3E%3C%2FP%3E%3CP%3E%E7%84%B6%E5%90%8E%EF%BC%8C%E6%88%91%E7%AC%AC%E4%B8%80%E6%AC%A1%E5%B0%86%20RDDRONE-BMS772%20%E6%9D%BF%E8%BF%9E%E6%8E%A5%E5%88%B0%2022.2V%20%E7%94%B5%E6%BA%90%EF%BC%8C%E6%9D%BF%E8%BD%BD%20LED%20%E4%BA%AE%E8%B5%B7%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%8C%89%E7%85%A7%22NXP%20Gitbook%22%20%E4%B8%AD%E7%9A%84%E6%8C%87%E5%8D%97%E6%AD%A5%E9%AA%A4%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%93%8D%E4%BD%9C%EF%BC%9A%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fnxp.gitbook.io%2Fnxpmobilerobotics%2Fflashing-guide%2Fflashing-hovergames-boards%2Fwindows%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fnxp.gitbook.io%2Fnxpmobilerobotics%2Fflashing-guide%2Fflashing-hovergames-boards%2Fwindows%3C%2FA%3E%3C%2FP%3E%3CP%3E%E4%BD%86%E5%9C%A8%E5%B0%9D%E8%AF%95%E9%97%AA%E5%AD%98%E4%BB%8E%E5%AE%98%E6%96%B9%20Github%20%E4%B8%8A%E4%B8%8B%E8%BD%BD%E7%9A%84%E5%9B%BA%E4%BB%B6%20bin%20%E6%96%87%E4%BB%B6%E5%90%8E%EF%BC%8C%E5%8F%91%E7%8E%B0%E8%AF%A5%E6%96%87%E4%BB%B6%E5%B9%B6%E4%B8%8D%E5%85%BC%E5%AE%B9%EF%BC%9A%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%3C%2FA%3E%3C%2FP%3E%3CP%3E%E6%88%91%E7%94%A8%E6%8E%A8%E8%8D%90%E7%9A%84%3CSPAN%3EJ-LINK%20%3C%2FSPAN%3E%E8%B0%83%E8%AF%95%E5%99%A8%E8%BF%9E%E6%8E%A5%E4%BA%86%E7%94%B5%E7%BC%86%EF%BC%8C%E5%A6%82%E5%9B%BE%E6%89%80%E7%A4%BA%EF%BC%9A%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fnxp.gitbook.io%2Fhovergames%2Frddrone-fmuk66%2Fconnectors%2Fdebug-interface-dcd-lz%2Fdcd-lz-breakout-board%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fnxp.gitbook.io%2Fhovergames%2Frddrone-fmuk66%2Fconnectors%2Fdebug-interface-dcd-lz%2Fdcd-lz-breakout-board%3C%2FA%3E%3C%2FP%3E%3CP%3E%E9%97%AA%E5%AD%98%E5%87%BA%E7%8E%B0%E6%95%85%E9%9A%9C%EF%BC%88%E5%A6%82%E4%B8%8B%E6%89%80%E7%A4%BA%EF%BC%89%EF%BC%8C%E6%88%91%E6%97%A0%E6%B3%95%E5%86%8D%E8%BF%9E%E6%8E%A5%E5%88%B0%20RDDRONE-BMS772%20%E6%9D%BF%E4%BA%86%E3%80%82%E6%AD%A4%E5%A4%96%EF%BC%8CLED%20%E6%8C%87%E7%A4%BA%E7%81%AF%E4%B9%9F%E4%B8%8D%E4%BA%AE%E3%80%82%E6%88%91%E6%AD%A3%E8%AF%95%E5%9B%BE%E9%87%8D%E6%96%B0%E5%88%B7%E6%96%B0%EF%BC%8C%E4%BD%86%E6%97%A0%E6%B3%95%E5%86%8D%E8%AE%A9%20J-Link%20commander%20%E8%BF%9E%E6%8E%A5%E5%88%B0%20RDDRONE-BMS772%E3%80%82%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%88%91%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20FTDI%20%E7%94%B5%E7%BC%86%E8%AE%BF%E9%97%AE%E6%9D%BF%EF%BC%8C%E6%88%91%E4%B9%9F%E6%97%A0%E6%B3%95%E4%BD%BF%E7%94%A8%20Putty%20%E8%BF%9B%E8%A1%8C%E4%BB%BB%E4%BD%95%E4%B8%B2%E8%A1%8C%E8%BF%9E%E6%8E%A5%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%9C%89%E7%82%B9%E5%9B%B0%E6%83%91%EF%BC%8C%E5%9B%A0%E4%B8%BA%E6%88%91%E4%B8%8D%E6%98%8E%E7%99%BD%E9%97%AE%E9%A2%98%E6%98%AF%E5%87%BA%E4%BA%8E%20CPU%20%E5%81%9C%E6%9C%BA%E4%BA%86%EF%BC%8C%E8%BF%98%E6%98%AF%20CPU%20%E5%A4%84%E4%BA%8E%20RESET%20%E5%BE%AA%E7%8E%AF%E4%B8%AD%EF%BC%8CCPU%20%E5%9C%A8%E7%AD%89%E5%BE%85%20RESET%20%E4%BF%A1%E5%8F%B7%EF%BC%8CCPU%20%E8%A2%AB%20%22%20%E9%94%81%E5%AE%9A%20%22%20%E6%88%91%E5%BF%85%E9%A1%BB%E8%A7%A3%E9%94%81%EF%BC%8C%E8%BF%98%E6%98%AF%E5%85%B6%E4%BB%96%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%E5%A6%82%E8%83%BD%E5%BE%97%E5%88%B0%E4%BB%BB%E4%BD%95%E5%B8%AE%E5%8A%A9%EF%BC%8C%E5%B0%86%E4%B8%8D%E8%83%9C%E6%84%9F%E6%BF%80%E3%80%82%3C%2FP%3E%3CP%3E%E8%BF%99%E6%98%AF%E6%88%91%E4%BB%8E%20J-Link%20Commander%20%E6%8E%A7%E5%88%B6%E5%8F%B0%E8%8E%B7%E5%BE%97%E7%9A%84%E6%97%A5%E5%BF%97%EF%BC%8C%E5%B8%8C%E6%9C%9B%E5%AF%B9%E4%BD%A0%E6%9C%89%E6%89%80%E5%B8%AE%E5%8A%A9%EF%BC%9A%3C%2FP%3E%3CP%3E%E9%94%AE%E5%85%A5%20%22%20connect%20%22%20%E5%BB%BA%E7%AB%8B%E7%9B%AE%E6%A0%87%E8%BF%9E%E6%8E%A5%EF%BC%8C'%EF%BC%9F'%E5%A6%82%E9%9C%80%E5%B8%AE%E5%8A%A9%20%3CBR%20%2F%3E%20J-Link%20%26gt%3B%20connect%20%3CBR%20%2F%3E%20%E8%AF%B7%E6%8C%87%E5%AE%9A%E8%AE%BE%E5%A4%87%2F%E5%86%85%E6%A0%B8%E3%80%82%3CDEFAULT%3E%3A%20S32K144%3CBR%20%2F%3E%20%E7%B1%BB%E5%9E%8B%20'%EF%BC%9F'%E5%AF%B9%E4%BA%8E%E9%80%89%E6%8B%A9%E5%AF%B9%E8%AF%9D%E6%A1%86%3CBR%20%2F%3E%20%E8%AE%BE%E5%A4%87%20%26gt%3B%3CBR%20%2F%3E%20%E8%AF%B7%E6%8C%87%E5%AE%9A%E7%9B%AE%E6%A0%87%E6%8E%A5%E5%8F%A3%EF%BC%9A%3CBR%20%2F%3E%20J)%20JTAG%EF%BC%88%E9%BB%98%E8%AE%A4%EF%BC%89%3CBR%20%2F%3E%20S)%20SWD%3CBR%20%2F%3E%20T)%20cjTag%3CBR%20%2F%3E%20TIF%20%26gt%3B%20s%3CBR%20%2F%3E%20%E6%8C%87%E5%AE%9A%E7%9B%AE%E6%A0%87%E6%8E%A5%E5%8F%A3%E9%80%9F%E5%BA%A6%20%5BkHz%5D%E3%80%82%3CDEFAULT%3E%3A%204000%20kHz%3CBR%20%2F%3E%20%E9%80%9F%E5%BA%A6%20%26gt%3B%201000%3CBR%20%2F%3E%20%E8%AE%BE%E5%A4%87%20%22%20S32K144%20%22%20%E5%B7%B2%E9%80%89%E4%B8%AD%E3%80%82%3C%2FDEFAULT%3E%3C%2FDEFAULT%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E9%80%9A%E8%BF%87%20SWD%20%E8%BF%9E%E6%8E%A5%E7%9B%AE%E6%A0%87%3CBR%20%2F%3EInitTarget()%20%E5%90%AF%E5%8A%A8%3CBR%20%2F%3E%E9%80%89%E6%8B%A9%20SWD%E3%80%82%E6%89%A7%E8%A1%8C%20JTAG%20-%26gt%3B%20SWD%20%E5%88%87%E6%8D%A2%E5%BA%8F%E5%88%97%E3%80%82%3CBR%20%2F%3EInitTarget()%20end%20-%20Took%2055ms%3CBR%20%2F%3E%E6%89%BE%E5%88%B0%20ID%20%E4%B8%BA%200x2BA01477%20%E7%9A%84%20SW-DP%3CBR%20%2F%3EDPIDR%3A%200x2BA01477%3CBR%20%2F%3ECoreSight%20SoC-400%20%E6%88%96%E6%9B%B4%E6%97%A9%E7%89%88%E6%9C%AC%3CBR%20%2F%3E%E6%89%AB%E6%8F%8F%20AP%20%E5%9C%B0%E5%9B%BE%E4%BB%A5%E6%9F%A5%E6%89%BE%E6%89%80%E6%9C%89%E5%8F%AF%E7%94%A8%20AP%3CBR%20%2F%3EAP%5B2%5D%EF%BC%9A%E7%94%B1%E4%BA%8E%E5%B7%B2%E5%88%B0%E8%BE%BE%20AP%20%E5%9C%B0%E5%9B%BE%E7%9A%84%E5%B0%BD%E5%A4%B4%EF%BC%8C%E5%9B%A0%E6%AD%A4%E5%81%9C%E6%AD%A2%20AP%20%E6%89%AB%E6%8F%8F%3CBR%20%2F%3EAP%5B0%5D%EF%BC%9AAHB-AP%20(IDR%3A%200x24770011)%3CBR%20%2F%3EAP%5B1%5D%EF%BC%9AJTAG-AP%20(IDR%3A%200x001C0000)%3CBR%20%2F%3E%E6%AD%A3%E5%9C%A8%E9%81%8D%E5%8E%86%20AP%20%E6%98%A0%E5%B0%84%E4%BB%A5%E6%9F%A5%E6%89%BE%E8%A6%81%E4%BD%BF%E7%94%A8%E7%9A%84%20AHB-AP%EF%BC%9A%3CBR%20%2F%3EAP%5B0%5D%EF%BC%9A%E6%89%BE%E5%88%B0%E5%86%85%E6%A0%B8%3CBR%20%2F%3EAP%5B0%5D%EF%BC%9AAHB-AP%20ROM%20base%EF%BC%9A0xE00FF000%3CBR%20%2F%3ECPUID%20%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%9A0x410FC241.%E5%AE%9E%E7%8E%B0%E8%80%85%E4%BB%A3%E7%A0%81%EF%BC%9A0x41%20(ARM)%20%3CBR%20%2F%3E%20%E6%89%BE%E5%88%B0%E4%BA%86%20Cortex-M4%20r0p1%EF%BC%8C%E5%B0%8F%E7%AB%AF%E8%8A%82%E5%BA%8F%E3%80%82%3CBR%20%2F%3EFPUnit%EF%BC%9A6%20%E4%B8%AA%E4%BB%A3%E7%A0%81%20(BP)%20%E6%8F%92%E6%A7%BD%E5%92%8C%202%20%E4%B8%AA%E6%96%87%E5%AD%97%E6%8F%92%E6%A7%BD%20%3CBR%20%2F%3E%20CoreSIGHT%20%E5%85%83%E5%99%A8%E4%BB%B6%EF%BC%9A%3CBR%20%2F%3EromTBL%20%5B0%5D%20%40%20E00FF000%20%3CBR%20%2F%3E%20%5B0%5D%20%5B0%5D%EF%BC%9AE000E000%20CID%20B105E00D%20PID%20000BB00C%20SCS-M7%20%3CBR%20%2F%3E%20%5B0%5D%20%5B1%5D%EF%BC%9AE0001000%20CID%20B105E00D%20003BB002%20PID%20DWT%20%5B0%5D%20%3CBR%20%2F%3E%20%5B2%5D%EF%BC%9AE0002000%20CID%20PID%20B105E00D%20002BB003%20FPB%20%3CBR%20%2F%3E%20%5B0%5D%20%5B3%5D%EF%BC%9AD%20PID%20TPIU%20%3CBR%20%2F%3E%20%E6%AD%A3%E5%9C%A8%E5%88%9D%E5%A7%8B%E5%8C%96%2061440%20%E5%AD%97%E8%8A%82%E7%9A%84%E5%B7%A5%E4%BD%9C%E5%86%85%E5%AD%98%20%40%200x1FFF8000%20RESET%EF%BC%9A%E9%80%9A%E8%BF%87%20DEM%20%3CBR%20%2F%3E%20CR.VC_CORERESET%20RESET%E5%90%8E%E6%9A%82%E5%81%9C%E5%86%85%E6%A0%B8%E3%80%82%3CBR%20%2F%3E%20E0000000%20B105E00D%20003BB001%20E0040000%20B105900D%20000BB9A1%3CBR%20%2F%3ERESET%EF%BC%9A%E9%80%9A%E8%BF%87%20AIRCR.SYSRESETREQ%20%E9%87%8D%E7%BD%AE%E8%AE%BE%E5%A4%87%E3%80%82%3CBR%20%2F%3E%E8%AE%B0%E5%BF%86%E5%8C%BA%E5%9F%9F%EF%BC%9A%3CBR%20%2F%3E%E5%8C%BA%E5%9F%9F%EF%BC%9A%22%E9%BB%98%E8%AE%A4%22%20%E8%AF%B4%E6%98%8E%EF%BC%9A%E9%BB%98%E8%AE%A4%E8%AE%BF%E9%97%AE%E6%A8%A1%E5%BC%8F%3CBR%20%2F%3ECortex-M4%20%E6%A0%87%E8%AF%86%E3%80%82%3CBR%20%2F%3EJ-Link%20%26gt%3B%20erase%20%3CBR%20%2F%3E%20%E6%9C%AA%E6%8C%87%E5%AE%9A%E5%9C%B0%E5%9D%80%E8%8C%83%E5%9B%B4%EF%BC%8C%E2%80%9C%E6%93%A6%E9%99%A4%E8%8A%AF%E7%89%87%E2%80%9D%20%E5%B0%86%E6%89%A7%E8%A1%8C%20%E2%80%9C%E6%93%A6%E9%99%A4%3CBR%20%2F%3E%E2%80%9D%EF%BC%9A%E6%89%A7%E8%A1%8C%E9%9A%90%E5%BC%8F%20RESET%20%26amp%3B%20%E6%9A%82%E5%81%9C%20MCU%E3%80%82%3CBR%20%2F%3ERESET%EF%BC%9A%E9%80%9A%E8%BF%87%20DEMCR.VC_CORERESET%20RESET%20%E5%90%8E%E6%9A%82%E5%81%9C%E5%86%85%E6%A0%B8%E3%80%82%3CBR%20%2F%3ERESET%EF%BC%9A%E9%80%9A%E8%BF%87%20AIRCR.SYSRESETREQ%20%E9%87%8D%E7%BD%AE%E8%AE%BE%E5%A4%87%E3%80%82%3CBR%20%2F%3E%E6%AD%A3%E5%9C%A8%E6%93%A6%E9%99%A4%E8%AE%BE%E5%A4%87...%3C%2FP%3E%3CP%3E******%20%E9%94%99%E8%AF%AF%EF%BC%9A%E6%93%A6%E9%99%A4%E6%89%87%E5%8C%BA%E5%A4%B1%E8%B4%A5%E3%80%82%3C%2FP%3E%3CP%3EJ-Link%EF%BC%9AFlash%20%E4%B8%8B%E8%BD%BD%EF%BC%9A%E6%80%BB%E8%80%97%E6%97%B61.490s%20%EF%BC%88%E5%87%86%E5%A4%870.603s%EF%BC%8C%E6%AF%94%E8%BE%830.000s%EF%BC%8C%E6%93%A6%E9%99%A4%EF%BC%9A0.885s%EF%BC%8C%E7%BC%96%E7%A8%8B%EF%BC%9A0.000s%EF%BC%8C%E6%A0%A1%E9%AA%8C%EF%BC%9A0.000s%EF%BC%8C%E8%BF%98%E5%8E%9F%EF%BC%9A0.885s%EF%BC%89%EF%BC%9A0.000s%EF%BC%8C%E9%AA%8C%E8%AF%81%EF%BC%9A0.000s%EF%BC%8C%E8%BF%98%E5%8E%9F%EF%BC%9A0.002s0.002s)%3C%2FP%3E%3CP%3E******%20%E9%94%99%E8%AF%AF%EF%BC%9A%E6%81%A2%E5%A4%8D%E7%9B%AE%E6%A0%87%E5%A4%B1%E8%B4%A5%E3%80%82RAMCode%20%E6%B0%B8%E4%B8%8D%E5%81%9C%E6%AD%A2%3CBR%20%2F%3E%E9%94%99%E8%AF%AF%EF%BC%9AErase%20%E8%BF%94%E5%9B%9E%E9%94%99%E8%AF%AF%E4%BB%A3%E7%A0%81%20-5%E3%80%82%3CBR%20%2F%3EJ-Link%20%26gt%3B%20loadbin%20%22%20C%3A%5CDocuments%5CRDDRONE-bms772-main%5C%20%E4%BA%8C%E8%BF%9B%E5%88%B6%5Cn%20uttx.bin%20%22%200x0%20%3CBR%20%2F%3E%20%E2%80%9Cloadbin%E2%80%9D%EF%BC%9A%E6%89%A7%E8%A1%8C%E9%9A%90%E5%BC%8F%20RESET%20%26amp%3B%20%E6%9A%82%E5%81%9C%20MCU%E3%80%82%3CBR%20%2F%3ERESET%EF%BC%9A%E9%80%9A%E8%BF%87%20DEMCR.VC_CORERESET%20RESET%20%E5%90%8E%E6%9A%82%E5%81%9C%E5%86%85%E6%A0%B8%E3%80%82%3CBR%20%2F%3ERESET%EF%BC%9A%E9%80%9A%E8%BF%87%20AIRCR.SYSRESETREQ%20%E9%87%8D%E7%BD%AE%E8%AE%BE%E5%A4%87%E3%80%82%3CBR%20%2F%3ERESET%EF%BC%9ASYSRESETREQ%20%E6%B7%B7%E4%B9%B1%E4%BA%86%E5%86%85%E6%A0%B8%E3%80%82%3CBR%20%2F%3E%E6%89%BE%E5%88%B0%20ID%20%E4%B8%BA%200x2BA01477%20%E7%9A%84%20SW-DP%3CBR%20%2F%3EDPIDR%3A%200x2BA01477%3CBR%20%2F%3ECoreSight%20SoC-400%20%E6%88%96%E6%9B%B4%E6%97%A9%E7%89%88%E6%9C%AC%3CBR%20%2F%3E%E8%B7%B3%E8%BF%87%20AP%20%E6%98%A0%E5%B0%84%E6%A3%80%E6%B5%8B%E3%80%82%E6%89%BE%E5%88%B0%E6%89%8B%E5%8A%A8%E9%85%8D%E7%BD%AE%E7%9A%84%20AP%20%E6%98%A0%E5%B0%84%E3%80%82%3CBR%20%2F%3EAP%5B0%5D%EF%BC%9AAHB-AP%20(IDR%3A%20%E6%9C%AA%E8%AE%BE%E7%BD%AE)%3CBR%20%2F%3EAP%5B0%5D%EF%BC%9A%E8%B7%B3%E8%BF%87%E3%80%82%E6%97%A0%E6%B3%95%E8%AF%BB%E5%8F%96%20CPUID%20%E5%AF%84%E5%AD%98%E5%99%A8%3CBR%20%2F%3E%E8%BF%9E%E6%8E%A5%20CPU%20%E5%A4%B1%E8%B4%A5%E3%80%82%E5%9C%A8RESET%E4%B8%8B%E6%89%A7%E8%A1%8C%E8%BF%9E%E6%8E%A5%E3%80%82%3CBR%20%2F%3EDPIDR%3A%200x2BA01477%3CBR%20%2F%3ECoreSight%20SoC-400%20%E6%88%96%E6%9B%B4%E6%97%A9%E7%89%88%E6%9C%AC%3CBR%20%2F%3E%E8%B7%B3%E8%BF%87%20AP%20%E6%98%A0%E5%B0%84%E6%A3%80%E6%B5%8B%E3%80%82%E6%89%BE%E5%88%B0%E6%89%8B%E5%8A%A8%E9%85%8D%E7%BD%AE%E7%9A%84%20AP%20%E6%98%A0%E5%B0%84%E3%80%82%3CBR%20%2F%3EAP%5B0%5D%EF%BC%9AAHB-AP%20(IDR%3A%20%E6%9C%AA%E8%AE%BE%E7%BD%AE)%3CBR%20%2F%3EAP%5B0%5D%EF%BC%9A%E8%B7%B3%E8%BF%87%E3%80%82%E6%97%A0%E6%B3%95%E8%AF%BB%E5%8F%96%20CPUID%20%E5%AF%84%E5%AD%98%E5%99%A8%3CBR%20%2F%3E%E5%9C%A8%20Coresight%20%E8%AE%BE%E7%BD%AE%E4%B8%AD%E6%89%BE%E4%B8%8D%E5%88%B0%E5%86%85%E6%A0%B8%3CBR%20%2F%3ERESET%EF%BC%9A%E4%BD%BF%E7%94%A8%E5%A4%87%E7%94%A8%EF%BC%9AVECTRESET%E3%80%82%3CBR%20%2F%3ERESET%EF%BC%9A%E9%80%9A%E8%BF%87%20DEMCR.VC_CORERESET%20RESET%20%E5%90%8E%E6%9A%82%E5%81%9C%E5%86%85%E6%A0%B8%E3%80%82%3CBR%20%2F%3ERESET%EF%BC%9A%E9%80%9A%E8%BF%87%20AIRCR.VECTRESET%20%E9%87%8D%E7%BD%AE%E8%AE%BE%E5%A4%87%E3%80%82%3CBR%20%2F%3ERESET%EF%BC%9AVECTRESET%20%E6%B7%B7%E4%B9%B1%E4%BA%86%E5%86%85%E6%A0%B8%E3%80%82%3CBR%20%2F%3ERESET%EF%BC%9A%E4%BD%BF%E7%94%A8%E5%A4%87%E7%94%A8%EF%BC%9A%E9%87%8D%E7%BD%AE%E5%AF%86%E7%A0%81%E3%80%82%3CBR%20%2F%3ERESET%EF%BC%9A%E9%80%9A%E8%BF%87%20DEMCR.VC_CORERESET%20RESET%20%E5%90%8E%E6%9A%82%E5%81%9C%E5%86%85%E6%A0%B8%E3%80%82%3CBR%20%2F%3ERESET%EF%BC%9A%E9%80%9A%E8%BF%87%20RESET%20%E5%BC%95%E8%84%9A%E9%87%8D%E7%BD%AE%E8%AE%BE%E5%A4%87%3CBR%20%2F%3ERESET%EF%BC%9AVC_CORERESET%20%E6%9C%AA%E5%81%9C%E6%AD%A2%20CPU%E3%80%82%EF%BC%88%E8%B0%83%E8%AF%95%E9%80%BB%E8%BE%91%E4%B9%9F%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%20RESET%20%E5%BC%95%E8%84%9A%E9%87%8D%E7%BD%AE%EF%BC%9F%EF%BC%89%E3%80%82%3CBR%20%2F%3ERESET%EF%BC%9A%E9%87%8D%E6%96%B0%E8%BF%9E%E6%8E%A5%E5%B9%B6%E6%89%8B%E5%8A%A8%E5%85%B3%E9%97%AD%20CPU%E3%80%82%3CBR%20%2F%3E%E5%8F%91%E7%8E%B0%20ID%20%E4%B8%BA%200x2ba01477%20DPID%20%3CBR%20%2F%3E%20R%20%E7%9A%84%20SW-DP%EF%BC%9A0x2ba01477%20CoreSIGHT%20SoC-400%20%E6%88%96%E6%9B%B4%E6%97%A9%E7%89%88%E6%9C%AC%E7%9A%84%20AP%20%E5%9C%B0%E5%9B%BE%E6%A3%80%E6%B5%8B%E5%B7%B2%E8%B7%B3%E8%BF%87%E3%80%82%3CBR%20%2F%3E%20%3CBR%20%2F%3E%E6%89%BE%E5%88%B0%E6%89%8B%E5%8A%A8%E9%85%8D%E7%BD%AE%E7%9A%84%20AP%20%E6%98%A0%E5%B0%84%E3%80%82%3CBR%20%2F%3EAP%5B0%5D%EF%BC%9AAHB-AP%20(IDR%3A%20%E6%9C%AA%E8%AE%BE%E7%BD%AE)%3CBR%20%2F%3EAP%5B0%5D%EF%BC%9A%E8%B7%B3%E8%BF%87%E3%80%82%E6%97%A0%E6%B3%95%E8%AF%BB%E5%8F%96%20CPUID%20%E5%AF%84%E5%AD%98%E5%99%A8%3CBR%20%2F%3E%E8%BF%9E%E6%8E%A5%20CPU%20%E5%A4%B1%E8%B4%A5%E3%80%82%E5%9C%A8RESET%E4%B8%8B%E6%89%A7%E8%A1%8C%E8%BF%9E%E6%8E%A5%E3%80%82%3CBR%20%2F%3EDPIDR%3A%200x2BA01477%3CBR%20%2F%3ECoreSight%20SoC-400%20%E6%88%96%E6%9B%B4%E6%97%A9%E7%89%88%E6%9C%AC%3CBR%20%2F%3E%E8%B7%B3%E8%BF%87%20AP%20%E6%98%A0%E5%B0%84%E6%A3%80%E6%B5%8B%E3%80%82%E6%89%BE%E5%88%B0%E6%89%8B%E5%8A%A8%E9%85%8D%E7%BD%AE%E7%9A%84%20AP%20%E6%98%A0%E5%B0%84%E3%80%82%3CBR%20%2F%3EAP%5B0%5D%EF%BC%9AAHB-AP%20(IDR%3A%20%E6%9C%AA%E8%AE%BE%E7%BD%AE)%3CBR%20%2F%3EAP%5B0%5D%EF%BC%9A%E8%B7%B3%E8%BF%87%E3%80%82%E6%97%A0%E6%B3%95%E8%AF%BB%E5%8F%96%20CPUID%20%E5%AF%84%E5%AD%98%E5%99%A8%3CBR%20%2F%3E%E5%9C%A8%20Coresight%20%E8%AE%BE%E7%BD%AE%E4%B8%AD%E6%89%BE%E4%B8%8D%E5%88%B0%E5%86%85%E6%A0%B8%20%3CBR%20%2F%3E%20CPU%20%E6%97%A0%E6%B3%95%E6%9A%82%E5%81%9C%3CBR%20%2F%3ERESET%EF%BC%9ARESET%20%E5%90%8E%E6%A0%B8%E5%BF%83%E6%9C%AA%E5%81%9C%E6%9C%BA%EF%BC%8C%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E7%A6%81%E7%94%A8%20WDT%E3%80%82%3CBR%20%2F%3ERESET%EF%BC%9A%E9%80%9A%E8%BF%87%20DEMCR.VC_CORERESET%20RESET%20%E5%90%8E%E6%9A%82%E5%81%9C%E5%86%85%E6%A0%B8%E3%80%82%3CBR%20%2F%3ERESET%EF%BC%9A%E9%80%9A%E8%BF%87%20RESET%20%E5%BC%95%E8%84%9A%E9%87%8D%E7%BD%AE%E8%AE%BE%E5%A4%87%3CBR%20%2F%3ERESET%EF%BC%9AVC_CORERESET%20%E6%9C%AA%E5%81%9C%E6%AD%A2%20CPU%E3%80%82%EF%BC%88%E8%B0%83%E8%AF%95%E9%80%BB%E8%BE%91%E4%B9%9F%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%20RESET%20%E5%BC%95%E8%84%9A%E9%87%8D%E7%BD%AE%EF%BC%9F%EF%BC%89%E3%80%82%3CBR%20%2F%3ERESET%EF%BC%9A%E9%87%8D%E6%96%B0%E8%BF%9E%E6%8E%A5%E5%B9%B6%E6%89%8B%E5%8A%A8%E5%85%B3%E9%97%AD%20CPU%E3%80%82%3CBR%20%2F%3E%E5%8F%91%E7%8E%B0%20ID%20%E4%B8%BA%200x2ba01477%20DPID%20%3CBR%20%2F%3E%20R%20%E7%9A%84%20SW-DP%EF%BC%9A0x2ba01477%20CoreSIGHT%20SoC-400%20%E6%88%96%E6%9B%B4%E6%97%A9%E7%89%88%E6%9C%AC%E7%9A%84%20AP%20%E5%9C%B0%E5%9B%BE%E6%A3%80%E6%B5%8B%E5%B7%B2%E8%B7%B3%E8%BF%87%E3%80%82%3CBR%20%2F%3E%20%3CBR%20%2F%3E%E6%89%BE%E5%88%B0%E6%89%8B%E5%8A%A8%E9%85%8D%E7%BD%AE%E7%9A%84%20AP%20%E6%98%A0%E5%B0%84%E3%80%82%3CBR%20%2F%3EAP%5B0%5D%EF%BC%9AAHB-AP%20(IDR%3A%20%E6%9C%AA%E8%AE%BE%E7%BD%AE)%3CBR%20%2F%3EAP%5B0%5D%EF%BC%9A%E8%B7%B3%E8%BF%87%E3%80%82%E6%97%A0%E6%B3%95%E8%AF%BB%E5%8F%96%20CPUID%20%E5%AF%84%E5%AD%98%E5%99%A8%3CBR%20%2F%3E%E8%BF%9E%E6%8E%A5%20CPU%20%E5%A4%B1%E8%B4%A5%E3%80%82%E5%9C%A8RESET%E4%B8%8B%E6%89%A7%E8%A1%8C%E8%BF%9E%E6%8E%A5%E3%80%82%3CBR%20%2F%3EDPIDR%3A%200x2BA01477%3CBR%20%2F%3ECoreSight%20SoC-400%20%E6%88%96%E6%9B%B4%E6%97%A9%E7%89%88%E6%9C%AC%3CBR%20%2F%3E%E8%B7%B3%E8%BF%87%20AP%20%E6%98%A0%E5%B0%84%E6%A3%80%E6%B5%8B%E3%80%82%E6%89%BE%E5%88%B0%E6%89%8B%E5%8A%A8%E9%85%8D%E7%BD%AE%E7%9A%84%20AP%20%E6%98%A0%E5%B0%84%E3%80%82%3CBR%20%2F%3EAP%5B0%5D%EF%BC%9AAHB-AP%EF%BC%88IDR%EF%BC%9A%E6%9C%AA%E8%AE%BE%E7%BD%AE%EF%BC%89%3CBR%20%2F%3EAP%5B0%5D%EF%BC%9A%E8%B7%B3%E8%BF%87%E3%80%82%E6%97%A0%E6%B3%95%E8%AF%BB%E5%8F%96%20CPUID%20%E5%AF%84%E5%AD%98%E5%99%A8%3CBR%20%2F%3E%E5%9C%A8%20Coresight%20%E8%AE%BE%E7%BD%AE%E4%B8%AD%E6%89%BE%E4%B8%8D%E5%88%B0%E5%86%85%E6%A0%B8%20%3CBR%20%2F%3E%20CPU%20%E6%97%A0%E6%B3%95%E6%9A%82%E5%81%9C%3CBR%20%2F%3ERESET%EF%BC%9A%E5%A4%B1%E8%B4%A5%E3%80%82%E5%88%87%E6%8D%A2%E9%87%8D%E7%BD%AE%E5%AF%86%E7%A0%81%E5%B9%B6%E5%86%8D%E6%AC%A1%E5%B0%9D%E8%AF%95%E9%87%8D%E7%BD%AE%E7%AD%96%E7%95%A5%E3%80%82%3CBR%20%2F%3E%E6%89%BE%E5%88%B0%20ID%20%E4%B8%BA%200x2BA01477%20%E7%9A%84%20SW-DP%3CBR%20%2F%3EDPIDR%3A%200x2BA01477%3CBR%20%2F%3ECoreSight%20SoC-400%20%E6%88%96%E6%9B%B4%E6%97%A9%E7%89%88%E6%9C%AC%3CBR%20%2F%3E%E8%B7%B3%E8%BF%87%20AP%20%E6%98%A0%E5%B0%84%E6%A3%80%E6%B5%8B%E3%80%82%E6%89%BE%E5%88%B0%E6%89%8B%E5%8A%A8%E9%85%8D%E7%BD%AE%E7%9A%84%20AP%20%E6%98%A0%E5%B0%84%E3%80%82%3CBR%20%2F%3EAP%5B0%5D%EF%BC%9AAHB-AP%20(IDR%3A%20%E6%9C%AA%E8%AE%BE%E7%BD%AE)%3CBR%20%2F%3EAP%5B0%5D%EF%BC%9A%E8%B7%B3%E8%BF%87%E3%80%82%E6%97%A0%E6%B3%95%E8%AF%BB%E5%8F%96%20CPUID%20%E5%AF%84%E5%AD%98%E5%99%A8%3CBR%20%2F%3E%E8%BF%9E%E6%8E%A5%20CPU%20%E5%A4%B1%E8%B4%A5%E3%80%82%E5%9C%A8RESET%E4%B8%8B%E6%89%A7%E8%A1%8C%E8%BF%9E%E6%8E%A5%E3%80%82%3CBR%20%2F%3EDPIDR%3A%200x2BA01477%3CBR%20%2F%3ECoreSight%20SoC-400%20%E6%88%96%E6%9B%B4%E6%97%A9%E7%89%88%E6%9C%AC%3CBR%20%2F%3E%E8%B7%B3%E8%BF%87%20AP%20%E6%98%A0%E5%B0%84%E6%A3%80%E6%B5%8B%E3%80%82%E6%89%BE%E5%88%B0%E6%89%8B%E5%8A%A8%E9%85%8D%E7%BD%AE%E7%9A%84%20AP%20%E6%98%A0%E5%B0%84%E3%80%82%3CBR%20%2F%3EAP%5B0%5D%EF%BC%9AAHB-AP%20(IDR%3A%20%E6%9C%AA%E8%AE%BE%E7%BD%AE)%3CBR%20%2F%3EAP%5B0%5D%EF%BC%9A%E8%B7%B3%E8%BF%87%E3%80%82%E6%97%A0%E6%B3%95%E8%AF%BB%E5%8F%96%20CPUID%20%E5%AF%84%E5%AD%98%E5%99%A8%E5%9C%A8%20Coresight%20%E8%AE%BE%E7%BD%AE%E4%B8%AD%3CBR%20%2F%3E%E6%89%BE%E4%B8%8D%E5%88%B0%E5%86%85%E6%A0%B8%3CBR%20%2F%3ERESET%EF%BC%9A%E9%80%9A%E8%BF%87%20DEMCR.VC_CORERESET%20%E9%87%8D%E7%BD%AE%E5%90%8E%E6%9A%82%E5%81%9C%E5%86%85%E6%A0%B8%E3%80%82%3CBR%20%2F%3ERESET%EF%BC%9A%E9%80%9A%E8%BF%87%20AIRCR.SYSRESETREQ%20%E9%87%8D%E7%BD%AE%E8%AE%BE%E5%A4%87%E3%80%82%3CBR%20%2F%3ERESET%EF%BC%9ASYSRESETREQ%20%E6%B7%B7%E4%B9%B1%E4%BA%86%E5%86%85%E6%A0%B8%E3%80%82%3CBR%20%2F%3E%E6%89%BE%E5%88%B0%20ID%20%E4%B8%BA%200x2BA01477%20%E7%9A%84%20SW-DP%3CBR%20%2F%3EDPIDR%3A%200x2BA01477%3CBR%20%2F%3ECoreSight%20SoC-400%20%E6%88%96%E6%9B%B4%E6%97%A9%E7%89%88%E6%9C%AC%3CBR%20%2F%3E%E8%B7%B3%E8%BF%87%20AP%20%E6%98%A0%E5%B0%84%E6%A3%80%E6%B5%8B%E3%80%82%E6%89%BE%E5%88%B0%E6%89%8B%E5%8A%A8%E9%85%8D%E7%BD%AE%E7%9A%84%20AP%20%E6%98%A0%E5%B0%84%E3%80%82%3CBR%20%2F%3EAP%5B0%5D%EF%BC%9AAHB-AP%20(IDR%3A%20%E6%9C%AA%E8%AE%BE%E7%BD%AE)%3CBR%20%2F%3EAP%5B0%5D%EF%BC%9A%E8%B7%B3%E8%BF%87%E3%80%82%E6%97%A0%E6%B3%95%E8%AF%BB%E5%8F%96%20CPUID%20%E5%AF%84%E5%AD%98%E5%99%A8%3CBR%20%2F%3E%E8%BF%9E%E6%8E%A5%20CPU%20%E5%A4%B1%E8%B4%A5%E3%80%82%E5%9C%A8RESET%E4%B8%8B%E6%89%A7%E8%A1%8C%E8%BF%9E%E6%8E%A5%E3%80%82%3CBR%20%2F%3EDPIDR%3A%200x2BA01477%3CBR%20%2F%3ECoreSight%20SoC-400%20%E6%88%96%E6%9B%B4%E6%97%A9%E7%89%88%E6%9C%AC%3CBR%20%2F%3E%E8%B7%B3%E8%BF%87%20AP%20%E6%98%A0%E5%B0%84%E6%A3%80%E6%B5%8B%E3%80%82%E6%89%BE%E5%88%B0%E6%89%8B%E5%8A%A8%E9%85%8D%E7%BD%AE%E7%9A%84%20AP%20%E6%98%A0%E5%B0%84%E3%80%82%3CBR%20%2F%3EAP%5B0%5D%EF%BC%9AAHB-AP%20(IDR%3A%20%E6%9C%AA%E8%AE%BE%E7%BD%AE)%3CBR%20%2F%3EAP%5B0%5D%EF%BC%9A%E8%B7%B3%E8%BF%87%E3%80%82%E6%97%A0%E6%B3%95%E8%AF%BB%E5%8F%96%20CPUID%20%E5%AF%84%E5%AD%98%E5%99%A8%3CBR%20%2F%3E%E5%9C%A8%20Coresight%20%E8%AE%BE%E7%BD%AE%E4%B8%AD%E6%89%BE%E4%B8%8D%E5%88%B0%E5%86%85%E6%A0%B8%3CBR%20%2F%3ERESET%EF%BC%9A%E4%BD%BF%E7%94%A8%E5%A4%87%E7%94%A8%EF%BC%9AVECTRESET%E3%80%82%3CBR%20%2F%3ERESET%EF%BC%9A%E9%80%9A%E8%BF%87%20DEMCR.VC_CORERESET%20RESET%20%E5%90%8E%E6%9A%82%E5%81%9C%E5%86%85%E6%A0%B8%E3%80%82%3CBR%20%2F%3ERESET%EF%BC%9A%E9%80%9A%E8%BF%87%20AIRCR.VECTRESET%20%E9%87%8D%E7%BD%AE%E8%AE%BE%E5%A4%87%E3%80%82%3CBR%20%2F%3ERESET%EF%BC%9AVECTRESET%20%E6%B7%B7%E4%B9%B1%E4%BA%86%E5%86%85%E6%A0%B8%E3%80%82%3CBR%20%2F%3ERESET%EF%BC%9A%E4%BD%BF%E7%94%A8%E5%A4%87%E7%94%A8%EF%BC%9A%E9%87%8D%E7%BD%AE%E5%AF%86%E7%A0%81%E3%80%82%3CBR%20%2F%3ERESET%EF%BC%9A%E9%80%9A%E8%BF%87%20DEMCR.VC_CORERESET%20RESET%20%E5%90%8E%E6%9A%82%E5%81%9C%E5%86%85%E6%A0%B8%E3%80%82%3CBR%20%2F%3ERESET%EF%BC%9A%E9%80%9A%E8%BF%87%20RESET%20%E5%BC%95%E8%84%9A%E9%87%8D%E7%BD%AE%E8%AE%BE%E5%A4%87%3CBR%20%2F%3ERESET%EF%BC%9AVC_CORERESET%20%E6%9C%AA%E5%81%9C%E6%AD%A2%20CPU%E3%80%82%EF%BC%88%E8%B0%83%E8%AF%95%E9%80%BB%E8%BE%91%E4%B9%9F%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%20RESET%20%E5%BC%95%E8%84%9A%E9%87%8D%E7%BD%AE%EF%BC%9F%EF%BC%89%E3%80%82%3CBR%20%2F%3ERESET%EF%BC%9A%E9%87%8D%E6%96%B0%E8%BF%9E%E6%8E%A5%E5%B9%B6%E6%89%8B%E5%8A%A8%E5%85%B3%E9%97%AD%20CPU%E3%80%82%3CBR%20%2F%3E%E5%8F%91%E7%8E%B0%20ID%20%E4%B8%BA%200x2ba01477%20DPID%20%3CBR%20%2F%3E%20R%20%E7%9A%84%20SW-DP%EF%BC%9A0x2ba01477%20CoreSIGHT%20SoC-400%20%E6%88%96%E6%9B%B4%E6%97%A9%E7%89%88%E6%9C%AC%E7%9A%84%20AP%20%E5%9C%B0%E5%9B%BE%E6%A3%80%E6%B5%8B%E5%B7%B2%E8%B7%B3%E8%BF%87%E3%80%82%3CBR%20%2F%3E%20%3CBR%20%2F%3E%E6%89%BE%E5%88%B0%E6%89%8B%E5%8A%A8%E9%85%8D%E7%BD%AE%E7%9A%84%20AP%20%E6%98%A0%E5%B0%84%E3%80%82%3CBR%20%2F%3EAP%5B0%5D%EF%BC%9AAHB-AP%20(IDR%3A%20%E6%9C%AA%E8%AE%BE%E7%BD%AE)%3CBR%20%2F%3EAP%5B0%5D%EF%BC%9A%E8%B7%B3%E8%BF%87%E3%80%82%E6%97%A0%E6%B3%95%E8%AF%BB%E5%8F%96%20CPUID%20%E5%AF%84%E5%AD%98%E5%99%A8%3CBR%20%2F%3E%E8%BF%9E%E6%8E%A5%20CPU%20%E5%A4%B1%E8%B4%A5%E3%80%82%E5%9C%A8RESET%E4%B8%8B%E6%89%A7%E8%A1%8C%E8%BF%9E%E6%8E%A5%E3%80%82%3CBR%20%2F%3EDPIDR%3A%200x2BA01477%3CBR%20%2F%3ECoreSight%20SoC-400%20%E6%88%96%E6%9B%B4%E6%97%A9%E7%89%88%E6%9C%AC%3CBR%20%2F%3E%E8%B7%B3%E8%BF%87%20AP%20%E6%98%A0%E5%B0%84%E6%A3%80%E6%B5%8B%E3%80%82%E6%89%BE%E5%88%B0%E6%89%8B%E5%8A%A8%E9%85%8D%E7%BD%AE%E7%9A%84%20AP%20%E6%98%A0%E5%B0%84%E3%80%82%3CBR%20%2F%3EAP%5B0%5D%EF%BC%9AAHB-AP%20(IDR%3A%20%E6%9C%AA%E8%AE%BE%E7%BD%AE)%3CBR%20%2F%3EAP%5B0%5D%EF%BC%9A%E8%B7%B3%E8%BF%87%E3%80%82%E6%97%A0%E6%B3%95%E8%AF%BB%E5%8F%96%20CPUID%20%E5%AF%84%E5%AD%98%E5%99%A8%3CBR%20%2F%3E%E5%9C%A8%20Coresight%20%E8%AE%BE%E7%BD%AE%E4%B8%AD%E6%89%BE%E4%B8%8D%E5%88%B0%E5%86%85%E6%A0%B8%20%3CBR%20%2F%3E%20CPU%20%E6%97%A0%E6%B3%95%E6%9A%82%E5%81%9C%3CBR%20%2F%3ERESET%EF%BC%9ARESET%20%E5%90%8E%E6%A0%B8%E5%BF%83%E6%9C%AA%E5%81%9C%E6%9C%BA%EF%BC%8C%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E7%A6%81%E7%94%A8%20WDT%E3%80%82%3CBR%20%2F%3ERESET%EF%BC%9A%E9%80%9A%E8%BF%87%20DEMCR.VC_CORERESET%20RESET%20%E5%90%8E%E6%9A%82%E5%81%9C%E5%86%85%E6%A0%B8%E3%80%82%3CBR%20%2F%3ERESET%EF%BC%9A%E9%80%9A%E8%BF%87%20RESET%20%E5%BC%95%E8%84%9A%E9%87%8D%E7%BD%AE%E8%AE%BE%E5%A4%87%3CBR%20%2F%3ERESET%EF%BC%9AVC_CORERESET%20%E6%9C%AA%E5%81%9C%E6%AD%A2%20CPU%E3%80%82%EF%BC%88%E8%B0%83%E8%AF%95%E9%80%BB%E8%BE%91%E4%B9%9F%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%20RESET%20%E5%BC%95%E8%84%9A%E9%87%8D%E7%BD%AE%EF%BC%9F%EF%BC%89%E3%80%82%3CBR%20%2F%3ERESET%EF%BC%9A%E9%87%8D%E6%96%B0%E8%BF%9E%E6%8E%A5%E5%B9%B6%E6%89%8B%E5%8A%A8%E5%85%B3%E9%97%AD%20CPU%E3%80%82%3CBR%20%2F%3E%E5%8F%91%E7%8E%B0%20ID%20%E4%B8%BA%200x2ba01477%20DPID%20%3CBR%20%2F%3E%20R%20%E7%9A%84%20SW-DP%EF%BC%9A0x2ba01477%20CoreSIGHT%20SoC-400%20%E6%88%96%E6%9B%B4%E6%97%A9%E7%89%88%E6%9C%AC%E7%9A%84%20AP%20%E5%9C%B0%E5%9B%BE%E6%A3%80%E6%B5%8B%E5%B7%B2%E8%B7%B3%E8%BF%87%E3%80%82%3CBR%20%2F%3E%20%3CBR%20%2F%3E%E6%89%BE%E5%88%B0%E6%89%8B%E5%8A%A8%E9%85%8D%E7%BD%AE%E7%9A%84%20AP%20%E6%98%A0%E5%B0%84%E3%80%82%3CBR%20%2F%3EAP%5B0%5D%EF%BC%9AAHB-AP%20(IDR%3A%20%E6%9C%AA%E8%AE%BE%E7%BD%AE)%3CBR%20%2F%3EAP%5B0%5D%EF%BC%9A%E8%B7%B3%E8%BF%87%E3%80%82%E6%97%A0%E6%B3%95%E8%AF%BB%E5%8F%96%20CPUID%20%E5%AF%84%E5%AD%98%E5%99%A8%3CBR%20%2F%3E%E8%BF%9E%E6%8E%A5%20CPU%20%E5%A4%B1%E8%B4%A5%E3%80%82%E5%9C%A8RESET%E4%B8%8B%E6%89%A7%E8%A1%8C%E8%BF%9E%E6%8E%A5%E3%80%82%3CBR%20%2F%3EDPIDR%3A%200x2BA01477%3CBR%20%2F%3ECoreSight%20SoC-400%20%E6%88%96%E6%9B%B4%E6%97%A9%E7%89%88%E6%9C%AC%3CBR%20%2F%3E%E8%B7%B3%E8%BF%87%20AP%20%E6%98%A0%E5%B0%84%E6%A3%80%E6%B5%8B%E3%80%82%E6%89%BE%E5%88%B0%E6%89%8B%E5%8A%A8%E9%85%8D%E7%BD%AE%E7%9A%84%20AP%20%E6%98%A0%E5%B0%84%E3%80%82%3CBR%20%2F%3EAP%5B0%5D%EF%BC%9AAHB-AP%20(IDR%3A%20%E6%9C%AA%E8%AE%BE%E7%BD%AE)%3CBR%20%2F%3EAP%5B0%5D%EF%BC%9A%E8%B7%B3%E8%BF%87%E3%80%82%E6%97%A0%E6%B3%95%E8%AF%BB%E5%8F%96%20CPUID%20%E5%AF%84%E5%AD%98%E5%99%A8%3CBR%20%2F%3E%E6%97%A0%E6%B3%95%E5%9C%A8%20Coresight%20%E8%AE%BE%E7%BD%AE%E4%B8%AD%E6%89%BE%E5%88%B0%E5%86%85%E6%A0%B8%3CBR%20%2F%3ECPU%20%E6%97%A0%E6%B3%95%E5%81%9C%E6%AD%A2%E8%BF%90%E8%A1%8C%3CBR%20%2F%3ECPU%20%E6%97%A0%E6%B3%95%E5%81%9C%E6%AD%A2%E8%BF%90%E8%A1%8C%3C%2FP%3E%3CP%3E******%20%E9%94%99%E8%AF%AF%EF%BC%9A%E6%97%A0%E6%B3%95%E5%81%9C%E6%AD%A2%20CPU%E3%80%82%3CBR%20%2F%3ECPU%20%E6%97%A0%E6%B3%95%E6%9A%82%E5%81%9C%3CBR%20%2F%3E%E6%AD%A3%E5%9C%A8%E4%B8%8B%E8%BD%BD%E6%96%87%E4%BB%B6%20%5BC%3A%5CDocuments%5CRDDRONE-BMS772-main%5C%E4%BA%8C%E8%BF%9B%E5%88%B6%5Cnuttx.bin%5D...%3CBR%20%2F%3ECPU%20%E6%97%A0%E6%B3%95%E5%81%9C%E6%AD%A2%3C%2FP%3E%3CP%3E******%20%E9%94%99%E8%AF%AF%EF%BC%9A%E6%81%A2%E5%A4%8D%E7%9B%AE%E6%A0%87%E5%A4%B1%E8%B4%A5%E3%80%82RAMCode%20%E6%B0%B8%E4%B8%8D%E5%81%9C%E6%AD%A2%3CBR%20%2F%3E%E6%93%A6%E9%99%A4%E6%89%87%E5%8C%BA%E5%A4%B1%E8%B4%A5%E3%80%82%3C%2FP%3E%3CP%3E%E4%B8%8D%E6%98%8E%E9%94%99%E8%AF%AF%20-1%3CBR%20%2F%3EJ-Link%26gt%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1617779%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1617779%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F213615%22%20target%3D%22_blank%22%3E%40dmorvay%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3EI2C%20%E7%94%B5%E5%8E%8B%E7%AD%89%E7%BA%A7%E4%B8%BA%203.3V%E3%80%82%3CBR%20%2F%3E%E8%BF%99%E4%B9%9F%E6%98%AF%20MCU%20%E5%8A%9F%E8%83%BD%E5%9F%9F%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%BD%86%E6%98%AF%E6%9D%BF%E4%B8%8A%E6%9C%89%205V%20%E5%8F%AF%E4%BB%A5%E7%94%A8%E6%9D%A5%E4%B8%BA%E6%98%BE%E7%A4%BA%E5%99%A8%E6%8F%90%E4%BE%9B%205V%20%E7%94%B5%E5%8E%8B%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3ERDDRONE-BMS772%20%E7%9A%84%E5%8E%9F%E7%90%86%E5%9B%BE%E5%8F%AF%E4%BB%8E%E6%81%A9%E6%99%BA%E6%B5%A6%E7%BD%91%E9%A1%B5%E4%B8%8B%E8%BD%BD%EF%BC%88%E7%82%B9%E5%87%BB%E8%AE%BE%E8%AE%A1%E6%96%87%E4%BB%B6%E6%88%96%E5%90%91%E4%B8%8B%E6%BB%9A%E5%8A%A8%E5%88%B0%E8%AE%BE%E8%AE%A1%E8%B5%84%E6%BA%90%EF%BC%89%20%EF%BC%9A%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesigns%2Fsmart-battery-management-for-mobile-robotics%3ARDDRONE-BMS772%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%20https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesigns%2Fsmart-battery-management-for-mobile-robotics%3ARDDRONE-BMS772%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%E6%95%AC%E7%A4%BC%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E8%A5%BF%E6%96%AF-%E8%8C%83%E7%B1%B3%E8%80%B6%E7%BD%97%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1617771%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1617771%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%3C%2FA%3E%EF%BC%8C%E6%84%9F%E8%B0%A2%E4%BD%A0%E6%8F%90%E4%BE%9B%E7%9A%84%E4%BF%A1%E6%81%AF%EF%BC%81%E6%88%91%E4%BC%9A%E5%9C%A8%E6%98%BE%E7%A4%BA%E5%B1%8F%E4%B8%8A%E5%86%8D%E8%AF%95%E4%B8%80%E6%AC%A1%E3%80%82%E4%BD%9C%E4%B8%BA%E5%8F%82%E8%80%83%EF%BC%8CBMS772%20%E4%B8%8A%E7%9A%84%20I2C%20%E4%BC%A0%E8%BE%93%E7%94%B5%E5%8E%8B%E6%98%AF%E5%A4%9A%E5%B0%91%EF%BC%9F%E6%98%AF%205V%20%E8%BF%98%E6%98%AF%203.3V%20I2C%EF%BC%9F%E5%A6%82%E6%9E%9C%E6%98%AF%203.3V%EF%BC%8C%E6%88%91%E4%B8%8D%E6%83%B3%E8%BF%9E%E6%8E%A5%205V%20%E7%9A%84%20I2C%EF%BC%88%E6%AF%94%E5%A6%82%20Arduino%EF%BC%89%E7%84%B6%E5%90%8E%E6%8D%9F%E5%9D%8F%E6%9D%BF%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1617458%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1617458%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F213615%22%20target%3D%22_blank%22%3E%40dmorvay%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E5%BE%88%E5%A5%BD%EF%BC%8C%E7%84%8A%E6%8E%A5%E6%AD%A3%E7%A1%AE%E7%9A%84%E8%B7%B3%E7%BA%BF%E8%A7%A3%E5%86%B3%E4%BA%86%E7%94%B5%E6%B1%A0%E7%94%B5%E5%8E%8B%E9%97%AE%E9%A2%98%EF%BC%81%20%3C%2FP%3E%3CP%3E%E5%85%B3%E4%BA%8E%20OLED%20%E6%98%BE%E7%A4%BA%E5%B1%8F%EF%BC%8C%E6%AD%A3%E5%A6%82%E6%88%91%E6%89%80%E8%AF%B4%EF%BC%8C%E6%88%91%E4%B8%8D%E7%86%9F%E6%82%89%E5%9F%BA%E4%BA%8E%E6%A8%A1%E5%9E%8B%E7%9A%84%E8%AE%BE%E8%AE%A1%E5%B7%A5%E5%85%B7%E7%AE%B1%E7%A4%BA%E4%BE%8B%E3%80%82%20%3CBR%20%2F%3E%E4%B9%9F%E8%AE%B8%E4%BB%96%E4%BB%AC%E7%9A%84%E6%84%8F%E6%80%9D%E6%98%AF%20LED%20%E7%A4%BA%E4%BE%8B%E4%B8%AD%E6%9D%BF%E4%B8%8A%E7%9A%84%20RGB-LED%EF%BC%9F%3C%2FP%3E%3CP%3E%E9%9A%8F%E5%A5%97%E4%BB%B6%E6%8F%90%E4%BE%9B%E7%9A%84%E6%98%BE%E7%A4%BA%E5%99%A8%E5%BA%94%E6%94%AF%E6%8C%81%203.3V%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E5%A6%82%E6%9E%9C%E4%BD%A0%E5%AF%B9%E4%BD%BF%E7%94%A8%20NuttX%20RTOS%EF%BC%88%E5%8C%85%E6%8B%AC%E6%98%BE%E7%A4%BA%E7%94%B5%E6%B1%A0%E7%94%B5%E9%87%8F%E5%80%BC%E7%9A%84%E6%98%BE%E7%A4%BA%E5%B1%8F%EF%BC%89%E7%94%A8%20C%20%E8%AF%AD%E8%A8%80%E7%BC%96%E5%86%99%E7%9A%84%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%E7%A4%BA%E4%BE%8B%E9%A1%B9%E7%9B%AE%E6%84%9F%E5%85%B4%E8%B6%A3%EF%BC%8C%E8%AF%B7%E5%9C%A8%E6%AD%A4%E5%A4%84%E6%9F%A5%E7%9C%8B%E7%A4%BA%E4%BE%8B%EF%BC%9Ahttps%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%3C%2FA%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9A%E8%BF%99%E6%98%AF%E5%9B%BE%E5%BD%A2%E6%98%BE%E7%A4%BA%EF%BC%8C%E4%B8%8D%E6%98%AF%E6%96%87%E5%AD%97%E6%98%BE%E7%A4%BA%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%AF%8F%E4%B8%AA%E5%AD%97%E7%AC%A6%E9%83%BD%E9%9C%80%E8%A6%81%E6%A0%B9%E6%8D%AE%E6%89%80%E4%BD%BF%E7%94%A8%E7%9A%84%E7%89%B9%E5%AE%9A%E5%AD%97%E4%BD%93%E6%9D%A5%E7%BB%98%E5%88%B6%E3%80%82%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%E6%95%AC%E7%A4%BC%EF%BC%8C%3C%2FP%3E%3CP%3E%E8%A5%BF%E6%96%AF-%E8%8C%83%E7%B1%B3%E8%80%B6%E7%BD%97%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1617200%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1617200%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%3C%2FA%3E%E8%BF%99%E4%BC%BC%E4%B9%8E%E8%B5%B7%E5%88%B0%E4%BA%86%E4%BD%9C%E7%94%A8%EF%BC%81%E7%9C%8B%E6%9D%A5%E6%88%91%E6%B2%A1%E6%9C%89%E9%98%85%E8%AF%BB%E6%96%87%E6%A1%A3%E4%B8%AD%E5%85%B3%E4%BA%8E%E7%84%8A%E6%8E%A5%E8%BF%99%E4%BA%9B%E8%B7%B3%E7%BA%BF%E7%9A%84%E9%83%A8%E5%88%86%E3%80%82%20%3C%2FP%3E%3CP%3E%E5%85%B3%E4%BA%8E%20OLED%20%E5%B1%8F%E5%B9%95%E7%9A%84%E5%8F%A6%E4%B8%80%E4%B8%AA%E9%97%AE%E9%A2%98%E6%98%AF%EF%BC%8C%E6%88%91%E5%B0%9D%E8%AF%95%E6%9E%84%E5%BB%BA%20LED%20%E7%A4%BA%E4%BE%8B%E5%B9%B6%E5%B0%86%E5%85%B6%E9%97%AA%E7%83%81%E5%88%B0%E6%9D%BF%E4%B8%8A%EF%BC%8C%E4%BD%86%E5%B1%8F%E5%B9%95%E6%97%A0%E6%B3%95%E5%BC%80%E5%90%AF%E3%80%82%E6%88%91%E5%9C%A8%E9%82%A3%E9%87%8C%E9%9C%80%E8%A6%81%E5%81%9A%E4%BB%80%E4%B9%88%E7%89%B9%E5%88%AB%E7%9A%84%E4%BA%8B%E6%83%85%E5%90%97%EF%BC%9F%E6%88%91%E5%9C%A8%20VCC%20%E5%92%8C%20GND%20%E4%B9%8B%E9%97%B4%E7%9A%84%20J23%20%E4%B8%8A%E8%AF%BB%E5%8F%96%E5%88%B0%203.3V%20%E7%94%B5%E5%8E%8B%EF%BC%8C%E4%BD%86%E5%BD%93%E6%88%91%E6%8F%92%E5%85%A5%E5%B1%8F%E5%B9%95%E6%97%B6%EF%BC%8C%E5%B1%8F%E5%B9%95%E6%97%A0%E6%B3%95%E6%89%93%E5%BC%80%E3%80%82%E6%9C%89%E4%BB%80%E4%B9%88%E5%BB%BA%E8%AE%AE%E5%90%97%EF%BC%9F%E6%88%91%E4%BB%8A%E5%A4%A9%E6%B2%A1%E6%9C%89%E6%9C%BA%E4%BC%9A%E6%A3%80%E6%9F%A5%20D34%20%E5%92%8C%20D35%20%E4%BA%8C%E6%9E%81%E7%AE%A1%EF%BC%8C%E4%BD%86%E6%98%AF%E5%A6%82%E6%9E%9C%E6%88%91%E7%9A%84%E8%AF%BB%E6%95%B0%E6%98%AF%203.3V%EF%BC%8C%E8%BF%99%E4%BA%9B%E4%BA%8C%E6%9E%81%E7%AE%A1%E9%9C%80%E8%A6%81%E7%A7%BB%E5%8A%A8%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1616502%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1616502%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F213615%22%20target%3D%22_blank%22%3E%40dmorvay%3C%2FA%3E%EF%BC%8C%3CBR%20%2F%3E%3CBR%20%2F%3E%EF%BC%8C%E6%88%91%E8%BF%98%E6%B2%A1%E6%9C%89%E4%BD%BF%E7%94%A8%3CSPAN%3E%E5%9F%BA%E4%BA%8E%E6%A8%A1%E5%9E%8B%E7%9A%84%E5%BC%80%E5%8F%91%E5%B7%A5%E5%85%B7%E7%AE%B1%E7%9A%84%E7%BB%8F%E9%AA%8C%EF%BC%8C%E6%89%80%E4%BB%A5%E5%9C%A8%E8%BF%99%E6%96%B9%E9%9D%A2%E6%88%91%E6%97%A0%E6%B3%95%E6%A3%80%E6%9F%A5%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%85%B3%E4%BA%8E%E7%A1%AC%E4%BB%B6%EF%BC%9A%3C%2FSPAN%3E%3CBR%20%2F%3E%E6%82%A8%E8%83%BD%E5%90%A6%E7%A1%AE%E8%AE%A4%E7%84%8A%E6%8E%A5%E7%9A%84%E8%B7%B3%E7%BA%BF%E6%98%AF%203S%20%E7%9A%84%20SJ6%E3%80%81SJ10%E3%80%81SJ11%20%E5%92%8C%20SJ12%EF%BC%9F%3CBR%20%2F%3E%E7%94%B5%E6%B1%A0%E7%94%B5%E5%8E%8B%E6%BB%A4%E6%B3%A2%E5%99%A8%E6%AD%A3%E7%A1%AE%E5%B0%B1%E4%BD%8D%EF%BC%9A%20%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22cisvmierlo_0-1678950769358.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cisvmierlo_0-1678950769358.png%22%20style%3D%22width%3A%20261px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cisvmierlo_0-1678950769358.png%22%20style%3D%22width%3A%20261px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cisvmierlo_0-1678950769358.png%22%20style%3D%22width%3A%20261px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cisvmierlo_0-1678950769358.png%22%20style%3D%22width%3A%20261px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cisvmierlo_0-1678950769358.png%22%20style%3D%22width%3A%20261px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cisvmierlo_0-1678950769358.png%22%20style%3D%22width%3A%20261px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cisvmierlo_0-1678950769358.png%22%20style%3D%22width%3A%20261px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cisvmierlo_0-1678950769358.png%22%20style%3D%22width%3A%20261px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cisvmierlo_0-1678950769358.png%22%20style%3D%22width%3A%20261px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F214878i62C02D5A4FCD83F1%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22cisvmierlo_0-1678950769358.png%22%20alt%3D%22cisvmierlo_0-1678950769358.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%E4%BA%B2%E5%88%87%E7%9A%84%E9%97%AE%E5%80%99%EF%BC%8C%3CBR%20%2F%3E%3CBR%20%2F%3ECis%20van%20Mierlo%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1616239%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1616239%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E4%BB%8A%E5%A4%A9%E6%99%9A%E4%B8%8A%E6%88%91%E5%9C%A8%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20BMS772%EF%BC%8C%E5%B9%B6%E8%AF%95%E5%9B%BE%E6%98%BE%E7%A4%BA%E7%94%B5%E6%B1%A0%E7%94%B5%E5%8E%8B%E3%80%82%E6%88%91%E6%9C%89%E4%B8%80%E4%B8%AA%203s%20%E7%94%B5%E6%B1%A0%E7%BB%84%EF%BC%8C%E4%B8%8D%E7%9F%A5%E4%BB%80%E4%B9%88%E5%8E%9F%E5%9B%A0%EF%BC%8C%E5%85%B6%E4%B8%AD%E4%B8%80%E4%B8%AA%E7%94%B5%E6%B1%A0%E7%9A%84%E8%AF%BB%E6%95%B0%E4%B8%80%E7%9B%B4%E6%AF%94%E5%85%B6%E4%BB%96%E7%94%B5%E6%B1%A0%E9%AB%98%E3%80%82%E6%88%91%E9%80%9A%E8%BF%87%E4%B8%87%E7%94%A8%E8%A1%A8%E7%A1%AE%E8%AE%A4%EF%BC%8C%E6%89%80%E6%9C%89%E7%94%B5%E6%B1%A0%E7%9A%84%E6%95%B0%E5%80%BC%E5%A4%A7%E8%87%B4%E7%9B%B8%E5%90%8C%E3%80%82%E6%88%91%E8%BF%98%E7%94%A8%E4%B8%A4%E4%B8%AA%E4%B8%8D%E5%90%8C%E7%9A%84%E7%94%B5%E6%B1%A0%E7%BB%84%E8%AF%95%E8%BF%87%E3%80%82%E6%9B%B4%E5%A4%9A%E4%BF%A1%E6%81%AF%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85%E6%88%91%E9%99%84%E4%B8%8A%E7%9A%84%E6%88%AA%E5%9B%BE%E3%80%82%E8%AF%B7%E6%B3%A8%E6%84%8F%EF%BC%8C%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%E7%9A%84%E8%AF%BB%E6%95%B0%E4%B8%80%E7%9B%B4%E6%AF%94%E5%85%B6%E4%BB%96%E9%AB%98%E5%87%BA%E7%BA%A6%200.7%E3%80%82%E6%88%91%E5%9C%A8%20FreeMaster%20%E4%B8%AD%E4%BD%BF%E7%94%A8%E5%9F%BA%E4%BA%8E%E6%A8%A1%E5%9E%8B%E7%9A%84%E5%BC%80%E5%8F%91%E5%92%8C%20J-Link%20%E8%B0%83%E8%AF%95%E5%99%A8%E3%80%82%E5%A6%82%E6%9C%89%E4%BB%BB%E4%BD%95%E5%BB%BA%E8%AE%AE%EF%BC%8C%E5%B0%86%E4%B8%8D%E8%83%9C%E6%84%9F%E6%BF%80%EF%BC%81%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22dmorvay_0-1678921034731.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22dmorvay_0-1678921034731.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22dmorvay_0-1678921034731.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22dmorvay_0-1678921034731.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22dmorvay_0-1678921034731.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22dmorvay_0-1678921034731.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22dmorvay_0-1678921034731.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22dmorvay_0-1678921034731.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22dmorvay_0-1678921034731.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22dmorvay_0-1678921034731.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F214816i1AD583C84C4CDDF9%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22dmorvay_0-1678921034731.png%22%20alt%3D%22dmorvay_0-1678921034731.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1606759%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1606759%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3EBMS772%20%E4%B8%BB%E6%9D%BF%E6%94%AF%E6%8C%81%20Pixhawk%20Cube%20Orange%20%E8%87%AA%E5%8A%A8%E9%A9%BE%E9%A9%B6%E4%BB%AA%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E6%88%90%E5%8A%9F%E5%9C%B0%E4%B8%8E%E5%85%B6%E4%BB%96%20UAVCAN%20%E8%AE%BE%E5%A4%87%E8%BF%9B%E8%A1%8C%E4%BA%86%E9%80%9A%E4%BF%A1%EF%BC%8C%E4%BE%8B%E5%A6%82%20%3CSTRONG%3EZubax%20ESC%3C%2FSTRONG%3E%E3%80%81Packet%20digital%20MPPT%E3%80%82%E9%93%BE%E6%8E%A5%E3%80%82%E4%BD%86%E5%AE%83%E6%97%A0%E6%B3%95%E4%B8%8E%20BMS772%20%E9%85%8D%E5%90%88%E4%BD%BF%E7%94%A8%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fpacketdigital.com%2Fpower-products%2Fmaximum-power-point-tracker%2F%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fpacketdigital.com%2Fpower-products%2Fmaximum-power-point-tracker%2F%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Ffiles.zubax.com%2Fproducts%2Fcom.zubax.telega%2FZubax_Myxa_Datasheet.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Ffiles.zubax.com%2Fproducts%2Fcom.zubax.telega%2FZubax_Myxa_Datasheet.pdf%3C%2FA%3E%3C%2FP%3E%3CP%3E%E5%8F%A6%E5%A4%96%EF%BC%8CBMS772%20%E4%B8%BB%E6%9D%BF%E6%98%AF%E5%90%A6%E6%94%AF%E6%8C%81%E7%BB%8F%E5%85%B8%E7%9A%84%20CAN%20(CAN%202.0)%20%E5%8D%8F%E8%AE%AE%EF%BC%9F%E5%A6%82%E6%9E%9C%E6%98%AF%EF%BC%8C%E6%88%91%E6%83%B3%E7%94%A8%E5%BE%AE%E8%8A%AF%E7%9A%84CAN%E6%80%BB%E7%BA%BF%E5%88%86%E6%9E%90%E4%BB%AA%E5%AF%B9%E5%85%B6%E8%BF%9B%E8%A1%8C%E6%B5%8B%E8%AF%95%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%B7%E6%BE%84%E6%B8%85%E3%80%82%3C%2FP%3E%3CP%3E%E5%9C%A8%E6%AD%A4%E5%85%88%E8%A1%A8%E7%A4%BA%E6%84%9F%E8%B0%A2%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1604889%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1604889%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%A0%B9%E6%8D%AE%E4%BD%A0%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%BF%99%E6%97%A0%E6%B5%8E%E4%BA%8E%E4%BA%8B%EF%BC%8C%E4%BD%86%E8%AF%A5%E4%BB%A3%E7%A0%81%E6%98%AF%E4%BD%BF%E7%94%A8%20segger%20jlink%20%E7%B3%BB%E5%88%97%E8%AE%BE%E5%A4%87%E5%BC%80%E5%8F%91%E7%9A%84%E3%80%82%E5%A6%82%E6%9E%9C%E6%82%A8%E6%98%AF%E5%AD%A6%E7%94%9F%EF%BC%8C%E5%B9%B6%E4%B8%94%E8%BF%99%E6%98%AF%E9%9D%9E%E5%95%86%E4%B8%9A%E7%94%A8%E9%80%94%EF%BC%8C%E5%88%99%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8Adafruit%E7%AD%89%E4%BE%9B%E5%BA%94%E5%95%86%E6%8F%90%E4%BE%9B%E7%9A%84%E4%BD%8E%E6%88%90%E6%9C%ACjlink-edu%E4%B9%8B%E4%B8%80%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1604885%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Request%20for%20Register%20Map%20for%20NXP%20RDDrone-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1604885%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%89%80%E5%AE%9E%E7%8E%B0%E5%86%85%E5%AE%B9%E7%9A%84%E6%9C%80%E4%BD%B3%E5%8F%82%E8%80%83%E6%98%AF%E5%8F%82%E8%80%83%E5%AE%9E%E9%99%85%E4%BB%A3%E7%A0%81%E3%80%82%E5%AE%83%E5%B7%B2%E5%87%BA%E7%89%88%E5%B9%B6%E5%BC%80%E6%94%BE%E6%BA%90%E4%BB%A3%E7%A0%81%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1604876%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Request%20for%20Register%20Map%20for%20NXP%20RDDrone-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1604876%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%99%BA%E8%83%BD%E7%94%B5%E6%B1%A0%E7%B3%BB%E7%BB%9F%E8%A7%84%E8%8C%83%E3%80%8B%E6%9C%80%E7%BB%88%E8%BF%98%E6%98%AF%E5%BE%88%E6%9C%89%E5%B8%AE%E5%8A%A9%E7%9A%84%E3%80%82%3C%2FP%3E%3CP%3E%E8%A7%84%E6%A0%BC%E8%A1%A8%E5%8F%AF%E4%BB%A5%E5%9C%A8%E8%BF%99%E9%87%8C%E6%89%BE%E5%88%B0%EF%BC%9A%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fsbs-forum.org%2Fspecs%2Fsbdat110.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fsbs-forum.org%2Fspecs%2Fsbdat110.pdf%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1604268%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERequest%20for%20Register%20Map%20for%20NXP%20RDDrone-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1604268%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%B4%A2%E5%8F%96%E6%81%A9%E6%99%BA%E6%B5%A6%20RDDrone-BMS772%20%E5%AF%84%E5%AD%98%E5%99%A8%E6%98%A0%E5%B0%84%E8%A1%A8%3C%2FP%3E%3CP%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E6%9C%80%E8%BF%91%E4%B8%BA%E6%88%91%E7%9A%84%E9%A1%B9%E7%9B%AE%E8%B4%AD%E4%B9%B0%E4%BA%86%E6%81%A9%E6%99%BA%E6%B5%A6%E7%9A%84RDdrone-BMS772%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%EF%BC%8C%E4%BD%86%E6%98%AF%E6%88%91%E5%9C%A8%E9%80%9A%E8%BF%87I2C%E4%B8%8E%E8%AE%BE%E5%A4%87%E9%80%9A%E4%BF%A1%E6%97%B6%E9%81%87%E5%88%B0%E4%BA%86%E9%97%AE%E9%A2%98%E3%80%82%E6%88%91%E4%B8%80%E7%9B%B4%E5%9C%A8%E5%B0%9D%E8%AF%95%E8%AF%BB%E5%8F%96%E8%AE%BE%E5%A4%87%E7%9A%84%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%8C%E4%BD%86%E6%98%AF%E5%A6%82%E6%9E%9C%E6%B2%A1%E6%9C%89%E5%AF%84%E5%AD%98%E5%99%A8%E6%98%A0%E5%B0%84%EF%BC%8C%E5%B0%B1%E5%BE%88%E9%9A%BE%E7%9F%A5%E9%81%93%E8%A6%81%E8%AE%BF%E9%97%AE%E5%93%AA%E4%B8%AA%E5%AF%84%E5%AD%98%E5%99%A8%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%83%B3%E7%9F%A5%E9%81%93%E6%98%AF%E5%90%A6%E6%9C%89%E4%BA%BA%E8%83%BD%E6%8F%90%E4%BE%9B%20RDDrone-BMS772%20%E7%9A%84%E5%AF%84%E5%AD%98%E5%99%A8%E5%9C%B0%E5%9B%BE%EF%BC%8C%E6%88%96%E8%80%85%E5%91%8A%E8%AF%89%E6%88%91%E5%9C%A8%E5%93%AA%E9%87%8C%E5%8F%AF%E4%BB%A5%E6%89%BE%E5%88%B0%E3%80%82%E6%88%91%E7%9B%B8%E4%BF%A1%E6%8B%A5%E6%9C%89%E5%AF%84%E5%AD%98%E5%99%A8%E5%9C%B0%E5%9B%BE%E5%B0%86%E6%9E%81%E5%A4%A7%E5%9C%B0%E5%B8%AE%E5%8A%A9%E6%88%91%E4%B8%8E%E8%AE%BE%E5%A4%87%E9%80%9A%E4%BF%A1%E5%B9%B6%E6%8F%90%E5%8F%96%E6%88%91%E9%9C%80%E8%A6%81%E7%9A%84%E4%BF%A1%E6%81%AF%E3%80%82%3C%2FP%3E%3CP%3E%E6%8F%90%E5%89%8D%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1601937%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1601937%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E6%82%A8%E7%9A%84%E5%B8%AE%E5%8A%A9%E3%80%82%E6%88%91%E5%8F%AF%E4%BB%A5%E8%A7%A3%E5%86%B3%E7%94%B5%E5%8E%8B%E6%95%85%E9%9A%9C%E9%97%AE%E9%A2%98%E3%80%82%E7%8E%B0%E5%9C%A8%E6%88%91%E6%83%B3%E5%9C%A8%E4%B8%80%E4%BA%9B%E8%BD%AF%E4%BB%B6%E5%B7%A5%E5%85%B7%E4%B8%AD%E6%9F%A5%E7%9C%8B%20%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%20%E5%8F%91%E9%80%81%E7%9A%84%20DroneCAN%2FUAVCAN%20%E6%B6%88%E6%81%AF%2F%E5%8F%82%E6%95%B0%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%A0%E6%9C%89%E4%B8%80%E4%BA%9B%E8%BD%AF%E4%BB%B6%20GUI%20%E5%B7%A5%E5%85%B7%E5%8F%AF%E4%BB%A5%E6%9F%A5%E7%9C%8B%E6%9D%A5%E8%87%AA%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%E7%9A%84%20CAN%20%E6%B6%88%E6%81%AF%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%88%91%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20DroneCAN%20GUI%20%E5%B7%A5%E5%85%B7%E6%9F%A5%E7%9C%8B%20BMS772%20%E4%B8%8E%20Orange%20Cube%20%E8%87%AA%E5%8A%A8%E9%A9%BE%E9%A9%B6%E4%BB%AA%E8%BF%9E%E6%8E%A5%E5%90%8E%E7%9A%84%E4%BF%A1%E6%81%AF%E3%80%82%E4%BD%86%E6%88%91%E6%B2%A1%E6%9C%89%E6%88%90%E5%8A%9F%E3%80%82%E4%BB%BB%E5%8A%A1%E8%A7%84%E5%88%92%E8%BD%AF%E4%BB%B6%E6%97%A0%E6%B3%95%E5%9C%A8%20SLCAN%20%E6%A8%A1%E5%BC%8F%E4%B8%8B%E8%AF%86%E5%88%AB%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E5%85%B6%E4%B8%AD%20Cube%20orange%20%E5%8F%AF%E4%BB%A5%E6%A3%80%E6%B5%8B%E5%85%B6%E4%BB%96%20UAVCAN%20%E8%AE%BE%E5%A4%87%EF%BC%8C%E4%BE%8B%E5%A6%82%20Zubax%20ESC%E3%80%81Packet%20digital%20MPPT%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E5%8F%A6%E5%A4%96%EF%BC%8C%E6%88%91%E6%98%AF%E5%90%A6%E5%BA%94%E8%AF%A5%E5%B0%86%20DroneCAN%20%E9%9D%99%E6%80%81%E8%8A%82%E7%82%B9%20ID%20%E6%94%B9%E4%B8%BA%20255%20%E4%BB%A5%E5%A4%96%E7%9A%84%E5%80%BC%EF%BC%8C%E8%BF%99%E6%A0%B7%E6%89%8D%E8%83%BD%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%81%A9%E6%99%BA%E6%B5%A6%E5%9F%BA%E4%BA%8E%20UCAN%20%E7%9A%84%E8%8A%82%E7%82%B9%E6%97%A0%E6%B3%95%E5%9C%A8%E5%8D%B0%E5%BA%A6%E8%B4%AD%E4%B9%B0%E3%80%82%3C%2FP%3E%3CP%3E%E5%8F%A6%E5%A4%96%EF%BC%8C%E8%AF%B7%E8%AF%B4%E6%98%8E%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%E4%B8%8A%E6%98%AF%E5%90%A6%E6%8F%90%E4%BE%9B%E8%BF%87%E6%B5%81%E3%80%81%E8%BE%93%E5%87%BA%E7%9F%AD%E8%B7%AF%E4%BF%9D%E6%8A%A4%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%AF%B7%E6%BE%84%E6%B8%85%E4%B8%8A%E8%BF%B0%E9%97%AE%E9%A2%98%E3%80%82%E5%86%8D%E6%AC%A1%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%A4%A7%E5%8A%9B%E6%94%AF%E6%8C%81%E3%80%82%3C%2FP%3E%3CP%3E...%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1601120%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1601120%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F195015%22%20target%3D%22_blank%22%3E%40Prince1%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E5%BE%88%E9%AB%98%E5%85%B4%E6%B2%9F%E9%80%9A%E9%97%AE%E9%A2%98%E5%BE%97%E5%88%B0%E4%BA%86%E8%A7%A3%E5%86%B3%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E5%85%B3%E4%BA%8E%E5%85%B6%E4%BB%96%E9%97%AE%E9%A2%98%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%22%E6%98%AF%E7%9A%84%EF%BC%8CCLI%20%E6%98%BE%E7%A4%BA%22%E6%A3%80%E6%B5%8B%E5%88%B0%E7%94%B5%E6%B1%A0%E7%94%B5%E5%8E%8B%E4%B8%8D%E8%B6%B3%EF%BC%81%22%20%EF%BC%8C%E6%98%BE%E7%A4%BA%E5%B1%8F%E6%98%BE%E7%A4%BA%2011.26V%EF%BC%8C%E8%80%8C%20fluke%20%E4%BB%AA%E5%99%A8%E6%B5%8B%E9%87%8F%E7%9A%84%E7%94%B5%E5%8E%8B%E4%B8%BA%2011.7V%E3%80%82%22%20%E3%80%82%20%3C%2FP%3E%0A%3CP%3E%E6%98%BE%E7%A4%BA%E5%B1%8F%E6%98%BE%E7%A4%BA%20v-out%E3%80%82%E9%80%9A%E8%BF%87%E8%BE%93%E5%87%BA%E7%AB%AF%E7%9A%84%E7%94%B5%E9%98%BB%E5%88%86%E9%A2%91%E5%99%A8%E6%B5%8B%E9%87%8F%EF%BC%8C%E5%AE%B9%E5%B7%AE%E4%B8%BA%201%25%E3%80%82%E4%B9%9F%E5%B0%B1%E6%98%AF%E8%AF%B4%EF%BC%8C26V%20%E7%9A%84%E7%94%B5%E5%8E%8B%E5%8F%AF%E8%83%BD%E7%9B%B8%E5%B7%AE%200.946V%EF%BC%8C%E8%BF%99%E4%BB%85%E4%BB%85%E6%98%AF%E5%9B%A0%E4%B8%BA%E7%94%B5%E9%98%BB%E5%99%A8%E5%85%AC%E5%B7%AE%E7%9A%84%E5%8E%9F%E5%9B%A0%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E8%BF%99%E5%8F%AF%E8%83%BD%E4%B8%8E%E5%AE%9E%E9%99%85%E5%80%BC%E6%9C%89%E4%BA%9B%E5%81%8F%E5%B7%AE%E3%80%82%E5%9C%A8%E5%BD%93%E5%89%8D%E7%9A%84%20SW%20%E7%A4%BA%E4%BE%8B%E4%B8%AD%EF%BC%8C%E6%B2%A1%E6%9C%89%E5%AF%B9%E8%AF%A5%E6%B5%8B%E9%87%8F%E8%BF%9B%E8%A1%8C%E5%BE%AE%E8%B0%83%E7%9A%84%E9%80%89%E9%A1%B9%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E8%BF%99%E6%A0%B7%E5%81%9A%EF%BC%9A%E6%9F%A5%E7%9C%8B%20v-batt%20%E6%88%96%E5%B0%86%E6%89%80%E6%9C%89%E7%94%B5%E6%B1%A0%E7%94%B5%E5%8E%8B%E7%9B%B8%E5%8A%A0%EF%BC%88%E8%BF%99%E6%98%AF%E6%9C%80%E7%B2%BE%E7%A1%AE%E7%9A%84%E6%96%B9%E6%B3%95%EF%BC%89%E3%80%82Vtot%20%3D%20v-cell1%20%2B%20v-cell2%20%2B%20...%3CBR%20%2F%3E%3CBR%20%2F%3E%22%201.%E5%A6%82%E6%9E%9C%E7%94%B5%E6%B1%A0%E7%94%B5%E5%8E%8B%E4%B8%BA%26lt%3B%203.8V%EF%BC%8C%E5%B0%B1%E4%BC%9A%E8%BF%9B%E5%85%A5%E6%B7%B1%E5%BA%A6%E4%BC%91%E7%9C%A0%E7%8A%B6%E6%80%81%E3%80%82%E5%8D%B3%E4%BD%BF%E5%9C%A8%20J5%20%E4%B8%8A%E8%BF%9E%E6%8E%A5%E4%BA%86%E8%B4%9F%E8%BD%BD%EF%BC%8C%E4%B9%9F%E4%BC%9A%E5%8F%91%E7%94%9F%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E5%90%97%EF%BC%9F%E6%88%91%E7%9A%84%E6%84%8F%E6%80%9D%E6%98%AF%EF%BC%8C%E5%A6%82%E6%9E%9C%E8%BF%9E%E6%8E%A5%E4%BA%86%E8%B4%9F%E8%BD%BD%EF%BC%8C%E5%9C%A8%203.8V%20%E6%97%B6%E6%96%AD%E5%BC%80%E7%94%B5%E6%B1%A0%E8%BF%9E%E6%8E%A5%E5%B0%B1%E5%A4%AA%E6%97%A9%E4%BA%86%EF%BC%8C%E5%9B%A0%E4%B8%BA%E7%94%B5%E6%B1%A0%E7%9A%84%E6%88%AA%E6%AD%A2%E7%94%B5%E5%8E%8B%E6%98%AF%203V%E3%80%82%22%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E9%BB%98%E8%AE%A4%E7%94%B5%E6%B1%A0%E6%AC%A0%E5%8E%8B%EF%BC%88%E9%94%82%E8%81%9A%E5%90%88%E7%89%A9%E7%94%B5%E6%B1%A0%EF%BC%89%E8%AE%BE%E7%BD%AE%E4%B8%BA%203V%E3%80%82%E4%BD%A0%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%20UART%20%E6%8E%A5%E5%8F%A3%E9%80%9A%E8%BF%87%E4%BB%A5%E4%B8%8B%E6%96%B9%E5%BC%8F%E6%9F%A5%E7%9C%8B%E8%BF%99%E4%B8%AA%E8%AE%BE%E7%BD%AE%EF%BC%9A%3CBR%20%2F%3Ebms%20get%20v-cell-uv%20%E4%BD%A0%E5%8F%AF%E4%BB%A5%E7%94%A8%3CBR%20%2F%3E%E4%BD%A0%E8%AE%A4%E4%B8%BA%E5%90%88%E9%80%82%E7%9A%84%E6%96%B9%E6%B3%95%E6%9D%A5%E8%AE%BE%E7%BD%AE%E7%94%B5%E6%B1%A0%E7%9A%84%E4%BD%8E%E7%94%B5%E5%8E%8B%EF%BC%9A%22%20bms%20set%20v-cell-uv%20x.xv%20%22%20%3CBR%20%2F%3E%E8%AE%BE%E7%BD%AE%E5%8F%82%E6%95%B0%E5%90%8E%EF%BC%8C%E5%88%AB%E5%BF%98%E4%BA%86%E4%BD%BF%E7%94%A8%20%22%20bms%20save%20%22%20%E5%B0%86%E5%85%B6%E4%BF%9D%E5%AD%98%E5%88%B0%E9%97%AA%E5%AD%98%E4%B8%AD%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%9C%89%E5%85%B3%E5%8F%82%E6%95%B0%E7%9A%84%E8%AF%A6%E7%BB%86%E4%BF%A1%E6%81%AF%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85%3CA%20class%3D%22js-navigation-open%20Link--primary%22%20title%3D%22BMS772_releaseNotes_5.0.pdf%22%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2Fblob%2Fmain%2FBMS772_releaseNotes_5.0.pdf%22%20data-turbo-frame%3D%22repo-content-turbo-frame%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EBMS772_releaseNotes_5.0.pdf%3C%2FA%3E%E7%AC%AC%208.2%20%E7%AB%A0%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%BD%86%E6%88%91%E4%BC%9A%E9%80%9A%E8%BF%87%20UART%20%E8%BF%9E%E6%8E%A5%E6%A3%80%E6%9F%A5%E7%94%B5%E6%B1%A0%E7%94%B5%E5%8E%8B%EF%BC%8C%E8%BF%99%E6%A0%B7%E4%BD%A0%E5%B0%B1%E8%83%BD%E7%9F%A5%E9%81%93%E5%93%AA%E4%B8%AA%E7%94%B5%E6%B1%A0%E5%87%BA%E4%BA%86%E9%97%AE%E9%A2%98%E3%80%82%20%3CBR%20%2F%3E%E4%BD%A0%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%EF%BC%9A%22%20%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%20%E8%8E%B7%E5%8F%96%E5%85%A8%E9%83%A8%20%22%EF%BC%88%E8%8E%B7%E5%8F%96%E6%89%80%E6%9C%89%E5%8F%82%E6%95%B0%EF%BC%89%EF%BC%8C%22%20%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%20%E6%98%BE%E7%A4%BA%E5%85%A8%E9%83%A8%201%20%22%EF%BC%88%E6%9B%B4%E6%96%B0%E7%94%B5%E6%B1%A0%E5%80%BC%EF%BC%89%EF%BC%8C%22%20%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%20%E6%98%BE%E7%A4%BA%E5%89%8D%201%20%E4%B8%AA%20%22%EF%BC%88%E4%B8%8D%E6%BB%9A%E5%8A%A8%E5%8D%B3%E5%8F%AF%E6%9B%B4%E6%96%B0%E7%94%B5%E6%B1%A0%E5%80%BC%EF%BC%89%E3%80%82%3C%2FP%3E%0A%3CP%3E%222.%E6%98%AF%E5%90%A6%E6%9C%89%E5%8F%AF%E8%83%BD%E5%87%8F%E5%B0%91%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%E4%B8%AD%E7%9A%84%E7%94%B5%E5%8E%8B%E6%B5%8B%E9%87%8F%E8%AF%AF%E5%B7%AE%EF%BC%9F%22%20%3CBR%20%2F%3E%E6%AD%A3%E5%A6%82%E5%BC%80%E5%A4%B4%E6%89%80%E8%AF%B4%EF%BC%8C%E6%B2%A1%E6%9C%89%E6%A0%A1%E6%AD%A3%E8%BE%93%E5%87%BA%E7%94%B5%E5%8E%8B%E7%9A%84%E5%8F%82%E6%95%B0%E3%80%82%20%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%BD%86%E6%82%A8%E4%B9%9F%E5%8F%AF%E4%BB%A5%E8%87%AA%E8%A1%8C%E8%B0%83%E6%95%B4%20SW%EF%BC%8C%E4%BE%8B%E5%A6%82%E5%9C%A8%E6%98%BE%E7%A4%BA%E5%B1%8F%E4%B8%8A%E6%98%BE%E7%A4%BA%20v-batt%20%E8%80%8C%E4%B8%8D%E6%98%AF%20v-out%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%B0%A8%E8%87%B4%E9%97%AE%E5%80%99%E3%80%81%20%3C%2FP%3E%0A%3CP%3E%E8%A5%BF%E6%96%AF-%E8%8C%83%E7%B1%B3%E8%80%B6%E7%BD%97%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1601097%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1601097%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%A0%E8%A7%A3%E5%86%B3%E4%BA%86%E6%88%91%E7%9A%84%E9%97%AE%E9%A2%98%3C%2FP%3E%3CP%3E%E4%BF%AE%E6%AD%A3%20J19%20%E8%BF%9E%E6%8E%A5%E5%90%8E%EF%BC%8CCLI%20%E5%92%8C%E6%98%BE%E7%A4%BA%E5%B1%8F%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E3%80%82%3C%2FP%3E%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8CCLI%20%E6%98%BE%E7%A4%BA%22%E6%A3%80%E6%B5%8B%E5%88%B0%E7%94%B5%E6%B1%A0%E6%AC%A0%E5%8E%8B%EF%BC%81%22%20%EF%BC%8C%E6%98%BE%E7%A4%BA%E5%B1%8F%E6%98%BE%E7%A4%BA%2011.26V%EF%BC%8C%E4%BD%86%20fluke%20%E4%BB%AA%E5%99%A8%E6%B5%8B%E9%87%8F%E7%9A%84%E7%94%B5%E5%8E%8B%E4%B8%BA%2011.7V%E3%80%82%3C%2FP%3E%3CP%3E1.%E5%A6%82%E6%9E%9C%E7%94%B5%E6%B1%A0%E7%94%B5%E5%8E%8B%E4%B8%BA%26lt%3B%203.8V%EF%BC%8C%E5%B0%B1%E4%BC%9A%E8%BF%9B%E5%85%A5%E6%B7%B1%E5%BA%A6%E4%BC%91%E7%9C%A0%E7%8A%B6%E6%80%81%E3%80%82%E5%8D%B3%E4%BD%BF%E5%9C%A8%20J5%20%E4%B8%8A%E8%BF%9E%E6%8E%A5%E4%BA%86%E8%B4%9F%E8%BD%BD%EF%BC%8C%E4%B9%9F%E4%BC%9A%E5%8F%91%E7%94%9F%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E5%90%97%EF%BC%9F%E6%88%91%E7%9A%84%E6%84%8F%E6%80%9D%E6%98%AF%EF%BC%8C%E5%A6%82%E6%9E%9C%E8%BF%9E%E6%8E%A5%E4%BA%86%E8%B4%9F%E8%BD%BD%EF%BC%8C%E5%9C%A8%203.8V%20%E6%97%B6%E6%96%AD%E5%BC%80%E7%94%B5%E6%B1%A0%E8%BF%9E%E6%8E%A5%E5%B0%B1%E5%A4%AA%E6%97%A9%E4%BA%86%EF%BC%8C%E5%9B%A0%E4%B8%BA%E7%94%B5%E6%B1%A0%E7%9A%84%E6%88%AA%E6%AD%A2%E7%94%B5%E5%8E%8B%E6%98%AF%203V%E3%80%82%3C%2FP%3E%3CP%3E2%E3%80%82%E6%98%AF%E5%90%A6%E6%9C%89%E5%8F%AF%E8%83%BD%E5%87%8F%E5%B0%91%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%E4%B8%AD%E7%9A%84%E7%94%B5%E5%8E%8B%E6%B5%8B%E9%87%8F%E8%AF%AF%E5%B7%AE%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%AF%B7%E5%9B%9E%E7%AD%94%E4%B8%8A%E8%BF%B0%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2......%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1601076%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1601076%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F195015%22%20target%3D%22_blank%22%3E%40Prince1%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E6%88%91%E6%83%B3%E6%88%91%E6%89%BE%E5%88%B0%E4%BA%86%20BMS1%20%E9%80%9A%E4%BF%A1%E7%9A%84%E9%97%AE%E9%A2%98%E6%89%80%E5%9C%A8%E3%80%82%20%3CBR%20%2F%3E%3CBR%20%2F%3E%E9%BB%91%E7%BA%BF%E8%BF%9E%E6%8E%A5%E5%88%B0%20J19%20%E9%92%88%E8%84%9A%201%EF%BC%8C%E8%AF%A5%E9%92%88%E8%84%9A%E7%94%B5%E5%8E%8B%E4%B8%BA%203.3V%EF%BC%8C%E6%9C%AA%E6%8E%A5%E5%9C%B0%E3%80%82%3CBR%20%2F%3E%E6%8E%A5%E5%9C%B0%E6%97%B6%EF%BC%8C%E9%9C%80%E8%A6%81%E5%B0%86%E9%BB%91%E7%BA%BF%E8%BF%9E%E6%8E%A5%E5%88%B0%20J19%20%E7%AC%AC%207%20%E9%92%88%EF%BC%88%E8%BF%9E%E6%8E%A5%E5%99%A8%E7%9A%84%E5%8F%A6%E4%B8%80%E4%BE%A7%EF%BC%89%E3%80%82%20%3C%2FP%3E%3CP%3E%E6%B7%A1%E8%93%9D%E8%89%B2%E7%8E%B0%E5%9C%A8%E8%BF%9E%E6%8E%A5%E5%88%B0%20J19%20%E5%BC%95%E8%84%9A%205%EF%BC%88SWD_CLK%EF%BC%89%EF%BC%8C%E9%BB%84%E8%89%B2%E7%8E%B0%E5%9C%A8%E8%BF%9E%E6%8E%A5%E5%88%B0%20J19%20%E5%BC%95%E8%84%9A%206%EF%BC%88RST_N%EF%BC%89%E3%80%82%3CBR%20%2F%3E%E6%88%91%E8%AE%A4%E4%B8%BA%E6%82%A8%E9%9C%80%E8%A6%81%E8%B0%83%E6%8D%A2%E8%BF%9E%E6%8E%A5%E5%99%A8%20J19%20%E4%B8%8A%E7%9A%84%E8%BF%9E%E6%8E%A5%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%88%91%E7%A8%8D%E5%90%8E%E5%86%8D%E8%B0%88%E5%85%B6%E4%BB%96%20PCB%E3%80%82%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%E6%95%AC%E7%A4%BC%EF%BC%8C%3C%2FP%3E%3CP%3E%E8%A5%BF%E6%96%AF-%E8%8C%83%E7%B1%B3%E8%80%B6%E7%BD%97%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1601062%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1601062%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%40CisvanMierlo%E3%80%81%3C%2FP%3E%3CP%3E%E6%88%91%E9%99%84%E4%B8%8A%E4%BA%86%E4%B8%A4%E4%B8%AA%20BMS%20%E7%9A%84%E5%9B%BE%E5%83%8F%E3%80%81%3C%2FP%3E%3CP%3E%E7%AC%AC%E4%B8%80%E4%B8%AA%EF%BC%9ALED%20%E7%BA%A2%E7%81%AF%E9%97%AA%E7%83%81%201%20%E5%88%86%E9%92%9F%EF%BC%8C%E7%84%B6%E5%90%8E%E8%BF%9B%E5%85%A5%E6%B7%B1%E5%BA%A6%E4%BC%91%E7%9C%A0%E7%8A%B6%E6%80%81%E3%80%82%3C%2FP%3E%3CP%3E%E7%AC%AC%E4%BA%8C%E4%B8%AA%EF%BC%9A%E6%9C%89%E8%BF%87%E7%83%AD%E9%97%AE%E9%A2%98%EF%BC%8CLED%20%E4%B8%8D%E4%BA%AE%E3%80%82%3C%2FP%3E%3CP%3E%E8%99%BD%E7%84%B6%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%205%20%E9%92%88%E7%94%B5%E6%B1%A0%E7%AB%AF%E5%AD%90%E8%BF%9E%E6%8E%A5%E5%99%A8%EF%BC%8C%E4%BD%86%E6%88%91%E6%B2%A1%E6%9C%89%E8%BF%9E%E6%8E%A5%204S%20%E9%92%88%EF%BC%88%E7%AC%AC%205%20%E9%92%88%E5%BC%80%E8%B7%AF%EF%BC%89%2F%E5%AF%BC%E7%BA%BF%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C3S%20%E7%94%B5%E6%B1%A0%E4%BD%BF%E7%94%A8%205%20%E9%92%88%E8%BF%9E%E6%8E%A5%E5%99%A8%E3%80%82JP1%20%E8%BF%9E%E6%8E%A5%E5%99%A8%E4%B8%8A%E7%9A%84%E7%94%B5%E5%8E%8B%E6%AD%A3%E7%A1%AE%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%8A%E5%A4%A9%EF%BC%8C%E6%88%91%E5%B0%86%E7%94%B5%E6%B1%A0%E5%85%85%E7%94%B5%E8%87%B3%2011.7V%EF%BC%8C%E6%B5%8B%E8%AF%95%E7%BB%93%E6%9E%9C%E4%BB%8D%E7%84%B6%E4%B8%80%E6%A0%B7%E3%80%82%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2......%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1600460%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1600460%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F195015%22%20target%3D%22_blank%22%3E%40Prince1%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E5%8F%AA%E6%9C%89%E5%9C%A8%E6%A3%80%E6%B5%8B%E5%88%B0%E7%94%B5%E6%B1%A0%E7%94%B5%E5%8E%8B%E4%B8%8D%E8%B6%B3%E6%97%B6%EF%BC%8C%E6%89%8D%E4%BC%9A%E5%9C%A8%201%20%E5%88%86%E9%92%9F%E5%90%8E%E8%BF%9B%E5%85%A5%E6%B7%B1%E5%BA%A6%E4%BC%91%E7%9C%A0%E7%8A%B6%E6%80%81%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%B9%9F%E8%AE%B8%E6%98%AF%E7%94%B5%E6%B1%A0%E8%BF%9E%E6%8E%A5%E5%87%BA%E4%BA%86%E9%97%AE%E9%A2%98%E3%80%82%3CBR%20%2F%3E%E4%BD%A0%E8%83%BD%E4%B8%8D%E8%83%BD%E4%B9%9F%E5%88%86%E4%BA%AB%E8%BF%99%E4%B8%AA%E6%9D%BF%E7%9A%84%E5%9B%BE%E7%89%87%EF%BC%88%E9%A1%B6%E9%83%A8%E5%92%8C%E5%BA%95%E9%83%A8%EF%BC%89%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%E6%95%AC%E7%A4%BC%EF%BC%8C%3C%2FP%3E%3CP%3E%E8%A5%BF%E6%96%AF-%E8%8C%83%E7%B1%B3%E8%80%B6%E7%BD%97%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1600427%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1600427%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E8%A5%BF%E6%96%AF-%E5%87%A1-%E7%B1%B3%E8%80%B6%E7%BD%97%E3%80%81%3C%2FP%3E%3CP%3E%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%20%E9%BB%98%E8%AE%A4%20%3CSTRONG%3EV-cell-U%3C%2FSTRONG%3E%20V%20%E5%8F%AF%E8%83%BD%E4%B8%BA%203V%EF%BC%8C%E4%BD%86%E6%88%91%E6%89%80%E6%9C%89%E7%9A%84%E7%94%B5%E6%B1%A0%E7%94%B5%E5%8E%8B%E9%83%BD%E8%B6%85%E8%BF%87%203.8V%EF%BC%8C3S%20%E7%94%B5%E6%B1%A0%E7%BB%84%E7%94%B5%E5%8E%8B%E4%B8%BA%2011.5V%E3%80%82%E6%88%91%E8%AE%A4%E4%B8%BA%E7%94%B5%E5%8E%8B%E4%B8%8D%E8%B6%B3%E4%B8%8D%E6%98%AF%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%E8%BF%9B%E5%85%A5%20Deep_Sleep%20%E7%9A%84%E5%8E%9F%E5%9B%A0%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%B7%E6%8F%90%E4%B8%80%E4%B8%8B%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%20LED%20%E4%BB%A5%E7%BA%A2%E8%89%B2%E9%97%AA%E7%83%81%201%20%E5%88%86%E9%92%9F%E7%84%B6%E5%90%8E%E8%BF%9B%E5%85%A5%20Deep_Sleep%20%E7%9A%84%E5%85%B6%E4%BB%96%E5%8E%9F%E5%9B%A0%E5%8F%AF%E8%83%BD%E6%98%AF%E4%BB%80%E4%B9%88%E3%80%82%3C%2FP%3E%3CP%3ED34%20%E5%B7%B2%E6%94%BE%E7%BD%AE%EF%BC%8CD35%20%E6%9C%AA%E6%94%BE%E7%BD%AE%E3%80%82%E6%98%BE%E7%A4%BA%E5%B1%8F%E4%BB%8D%E7%84%B6%E6%97%A0%E6%B3%95%E6%89%93%E5%BC%80%E3%80%82%E6%98%BE%E7%A4%BA%E9%92%88%E8%84%9A%E7%BC%96%E5%8F%B7%E6%8C%89%E5%BB%BA%E8%AE%AE%E8%BF%9E%E6%8E%A5%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%B0%86%E5%88%86%E4%BA%AB%E5%85%B6%E4%BB%96%E6%9C%89%E8%BF%87%E7%83%AD%E9%97%AE%E9%A2%98%E7%9A%84%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%E6%9D%BF%E7%9A%84%E5%9B%BE%E5%83%8F%E3%80%82%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2......%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1600323%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1600323%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F195015%22%20target%3D%22_blank%22%3E%40Prince1%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%22%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%20LED%20%E4%BB%A5%E7%BA%A2%E8%89%B2%E9%97%AA%E7%83%81%EF%BC%8C%E7%84%B6%E5%90%8E%E5%9C%A8%E5%A4%A7%E7%BA%A6%201%20%E5%88%86%E9%92%9F%E5%90%8E%E7%86%84%E7%81%AD%E3%80%82%E6%88%91%E8%A7%89%E5%BE%97%E6%98%AF%E7%9D%A1%E7%9C%A0%E3%80%82%22%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%BF%99%E8%A1%A8%E6%98%8E%E6%A3%80%E6%B5%8B%E5%88%B0%E7%94%B5%E6%B1%A0%E7%94%B5%E5%8E%8B%E4%B8%8D%E8%B6%B3%EF%BC%88%E5%9F%BA%E4%BA%8E%E9%BB%98%E8%AE%A4%E7%94%B5%E6%B1%A0%E6%8A%80%E6%9C%AF%EF%BC%9A%E9%94%82%E8%81%9A%E5%90%88%E7%89%A9%E7%94%B5%E6%B1%A0%EF%BC%89%E3%80%82%3CBR%20%2F%3E%E5%8F%91%E7%94%9F%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E6%97%B6%EF%BC%8C%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%20%E4%BC%9A%E5%9C%A8%20t%20%E6%95%85%E9%9A%9C%E8%B6%85%E6%97%B6%EF%BC%88%E9%BB%98%E8%AE%A4%2060%20%E7%A7%92%EF%BC%89%E4%B9%8B%E5%90%8E%E8%BF%9B%E5%85%A5DEEP_SLEEP%EF%BC%8C%E4%BB%A5%E4%BE%BF%E5%B0%86%E7%94%B5%E6%B1%A0%E4%BF%9D%E6%8C%81%E5%9C%A8%E6%9C%80%E4%BD%8E%E7%94%B5%E6%BA%90%E6%A8%A1%E5%BC%8F%E4%B8%8B%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%9C%A8%20DEEP_SLEEP%20%E7%8A%B6%E6%80%81%E4%B8%8B%EF%BC%8CMCU%EF%BC%88%E5%92%8C%20SBC%EF%BC%89%E5%A4%84%E4%BA%8E%E5%85%B3%E9%97%AD%E7%8A%B6%E6%80%81%EF%BC%8C%E5%9B%A0%E6%AD%A4%201%20%E5%88%86%E9%92%9F%E5%90%8E%E5%B0%86%E6%97%A0%E6%B3%95%E8%BF%9B%E8%A1%8C%E9%80%9A%E4%BF%A1%E3%80%82%E6%8C%89%E4%B8%8B%E6%8C%89%E9%92%AE%EF%BC%88%E6%88%96%E9%87%8D%E6%96%B0%E5%BC%80%E6%9C%BA%EF%BC%89%E6%98%AF%E5%94%AF%E4%B8%80%E8%83%BD%E5%B0%86%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%E4%BB%8E%20DEEP_SLEEP%20%E7%8A%B6%E6%80%81%E4%B8%AD%E5%94%A4%E9%86%92%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E5%8F%AF%E8%83%BD%E6%98%AF%E5%9B%A0%E4%B8%BA%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%E8%BF%9B%E5%85%A5%E4%BA%86DEEP_SLEEP%EF%BC%8C%E6%89%80%E4%BB%A5%E6%B2%A1%E6%9C%89%E9%80%9A%E4%BF%A1%E3%80%82%3CBR%20%2F%3E%E6%88%96%E8%80%85%E6%98%AF%E8%BF%9E%E6%8E%A5%E5%87%BA%E4%BA%86%E9%97%AE%E9%A2%98%E3%80%82%20%3C%2FP%3E%3CP%3E%E4%B8%BA%E4%BA%86%E5%9C%A8%E5%88%9D%E5%A7%8B%E5%8C%96%E8%BF%87%E7%A8%8B%E4%B8%AD%E6%89%93%E5%BC%80%E6%98%BE%E7%A4%BA%E5%B1%8F%EF%BC%8C%E6%82%A8%E6%98%AF%E5%90%A6%E5%8F%AF%E4%BB%A5%E6%A3%80%E6%9F%A5%E4%B8%80%E4%B8%8B%20D34%20%E7%9A%84%E4%BD%8D%E7%BD%AE%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%20D35%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%AF%B9%E4%BA%8E%E5%85%B6%E4%BB%96%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%E8%AE%BE%E7%BD%AE%EF%BC%8CSBC%20%E8%BF%87%E7%83%AD%E5%92%8C%20LED%20%E6%9C%AA%E4%BA%AE%E8%B5%B7%EF%BC%8C%E8%A1%A8%E7%A4%BA%203.3V%20%E5%8A%9F%E8%83%BD%E5%9F%9F%E5%8F%AF%E8%83%BD%E5%AD%98%E5%9C%A8%E7%9F%AD%E8%B7%AF%EF%BC%88%E4%B8%8E%20gnd%20%E7%9F%AD%E8%B7%AF%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%A0%E8%83%BD%E4%B8%8D%E8%83%BD%E5%B1%95%E7%A4%BA%E4%BD%A0%E7%9A%84%E4%B8%A4%E4%B8%AA%E6%9D%BF%EF%BC%88%E9%A1%B6%E9%83%A8%E5%92%8C%E5%BA%95%E9%83%A8%EF%BC%89%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%B0%A8%E8%87%B4%E9%97%AE%E5%80%99%E3%80%81%3C%2FP%3E%3CP%3E%E8%A5%BF%E6%96%AF-%E8%8C%83%E7%B1%B3%E8%80%B6%E7%BD%97%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1600171%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1600171%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%20%3CSPAN%20class%3D%22%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F90400%22%20target%3D%22_self%22%3E%3CSPAN%20class%3D%22%22%3E%E6%9D%B0%E6%8B%89%E5%B0%94%E5%BE%B7%3C%2FSPAN%3E%3C%2FA%3E%3C%2FSPAN%3E%2C%3C%2FP%3E%3CP%3E%E6%88%91%E5%9C%A8%E6%96%B0%E7%9A%84%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%E4%B8%8A%E5%81%9A%E4%BA%86%E4%BB%A5%E4%B8%8B%E6%93%8D%E4%BD%9C%EF%BC%8C%3C%2FP%3E%3CP%3ESJ6%E3%80%8110%E3%80%8111%E3%80%8112%20%E7%9F%AD%E8%B7%AF%EF%BC%8C%E7%94%A8%E4%BA%8E%203S%20%E9%85%8D%E7%BD%AE%E3%80%82%3C%2FP%3E%3CP%3E3S%20LiPo%20%E7%94%B5%E6%B1%A0%E8%BF%9E%E6%8E%A5%E8%87%B3%20J4%EF%BC%8C%E5%85%B6%E7%94%B5%E6%B1%A0%E5%B9%B3%E8%A1%A1%E7%BA%BF%E8%BF%9E%E6%8E%A5%E8%87%B3%20JP1%3C%2FP%3E%3CP%3EFTDI%20USB%20UART%20%E7%9A%84%E5%BC%95%E8%84%9A%205%E3%80%814%E3%80%811%20%E5%88%86%E5%88%AB%E4%B8%8E%20J19%20%E7%9A%84%E5%BC%95%E8%84%9A%202%E3%80%813%E3%80%817%20%E8%BF%9E%E6%8E%A5%EF%BC%8C%E7%84%B6%E5%90%8E%E4%B8%8E%20PC%20%E8%BF%9E%E6%8E%A5%3C%2FP%3E%3CP%3E115k2%208n1%EF%BC%8C%E5%A5%87%E5%81%B6%E6%A0%A1%E9%AA%8C%EF%BC%9A%E5%9C%A8%20COM%20%E7%AB%AF%E5%8F%A3%E5%B1%9E%E6%80%A7%E5%92%8C%20Tera%20Term%20%E4%B8%AD%E9%85%8D%E7%BD%AE%E7%9A%84%E6%B5%81%E9%87%8F%EF%BC%9A%E6%97%A0%3C%2FP%3E%3CP%3E%E7%BB%93%E6%9E%9C%E5%A6%82%E4%B8%8B%3C%2FP%3E%3CP%3E%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%20LED%20%E4%BB%A5%E7%BA%A2%E8%89%B2%E9%97%AA%E7%83%81%EF%BC%8C%E7%84%B6%E5%90%8E%E5%9C%A8%E5%A4%A7%E7%BA%A6%201%20%E5%88%86%E9%92%9F%E5%90%8E%E7%86%84%E7%81%AD%E3%80%82%E6%88%91%E8%A7%89%E5%BE%97%E6%98%AF%E7%9D%A1%E7%9C%A0%E3%80%82%3C%2FP%3E%3CP%3EJ5%20%E5%A4%84%E7%9A%84%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%E8%BE%93%E5%87%BA%E7%94%B5%E5%8E%8B%E4%B8%BA%E9%9B%B6%EF%BC%88%E6%9C%AA%E8%BF%9E%E6%8E%A5%E8%B4%9F%E8%BD%BD%EF%BC%89%3C%2FP%3E%3CP%3ETera%20Term%20%E7%AA%97%E5%8F%A3%E6%98%BE%E7%A4%BA%E7%A9%BA%E7%99%BD%E5%B1%8F%E5%B9%95%EF%BC%8C%E4%B8%8D%E6%8E%A5%E5%8F%97%E9%94%AE%E7%9B%98%E8%BE%93%E5%85%A5%3C%2FP%3E%3CP%3E%E8%BF%9E%E6%8E%A5%E8%87%B3%20J23%20%E7%9A%84%E6%98%BE%E7%A4%BA%E5%B1%8F%E6%9C%AA%E6%89%93%E5%BC%80%3C%2FP%3E%3CP%3E%E8%AF%B7%E5%B8%AE%E5%8A%A9%E6%88%91%E8%A7%A3%E5%86%B3%E4%B8%8A%E8%BF%B0%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%9C%A8%E5%8F%A6%E4%B8%80%E4%B8%AA%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%E4%B8%8A%E5%B0%9D%E8%AF%95%E4%BA%86%E5%90%8C%E6%A0%B7%E7%9A%84%E6%96%B9%E6%B3%95%EF%BC%8C%E5%85%B6%E4%B8%AD%20LED%20%E6%97%A0%E6%B3%95%E5%BC%80%E5%90%AF%EF%BC%8CSBC%20%E8%8A%AF%E7%89%87%E8%BF%87%E7%83%AD%E3%80%82%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2......%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1596441%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1596441%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%9C%89%E4%BA%BA%E7%9F%A5%E9%81%93%E9%99%A4%E4%BA%86%20J-Link%20%E6%88%96%20PeMicro%20%E4%B9%8B%E5%A4%96%EF%BC%8C%E6%88%91%E5%9C%A8%E5%93%AA%E9%87%8C%E5%8F%AF%E4%BB%A5%E4%B8%BA%E6%81%A9%E6%99%BA%E6%B5%A6%20RDDRONE-%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%20%E8%B4%AD%E4%B9%B0%E5%85%B6%E4%BB%96%E5%90%88%E9%80%82%E7%9A%84%E8%B0%83%E8%AF%95%E5%99%A8%E5%90%97%EF%BC%9F%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1594395%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1594395%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%20%3CSPAN%20class%3D%22%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F90400%22%20target%3D%22_self%22%3E%3CSPAN%20class%3D%22%22%3E%E6%9D%B0%E6%8B%89%E5%B0%94%E5%BE%B7%3C%2FSPAN%3E%3C%2FA%3E%3C%2FSPAN%3E%2C%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E6%82%A8%E7%9A%84%E5%B8%AE%E5%8A%A9%E3%80%82%E6%88%91%E4%BC%9A%E8%AF%95%E8%AF%95%E4%BD%A0%E5%BB%BA%E8%AE%AE%E7%9A%84%E6%96%B9%E6%B3%95%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1594197%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1594197%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F195015%22%20target%3D%22_blank%22%3E%40Prince1%3C%2FA%3E%EF%BC%8C%E5%A6%82%E6%9E%9C%E8%BF%9E%E6%8E%A5%E7%9A%84%E7%94%B5%E6%B1%A0%E5%8D%95%E5%85%83%E7%BC%96%E5%8F%B7%E4%B8%8E%E9%85%8D%E7%BD%AE%E7%9A%84%E4%B8%8D%E5%90%8C%EF%BC%8C%E5%88%99%20SW%20%E5%8F%AA%E4%BC%9A%E6%8A%A5%E9%94%99%EF%BC%8C%E5%B9%B6%E4%B8%94%E4%B8%8D%E4%BC%9A%E5%90%AF%E7%94%A8%E6%96%AD%E7%94%B5%E3%80%82%3CBR%20%2F%3E%E9%9C%80%E8%A6%81%E8%BF%9E%E6%8E%A5%E7%94%B5%E6%B1%A0%E6%89%8D%E8%83%BD%E9%85%8D%E7%BD%AE%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%E3%80%82%3CBR%20%2F%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E8%AE%BE%E7%BD%AE%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%E7%9A%84%E6%96%B9%E6%B3%95%E6%98%AF%EF%BC%9A%3CBR%20%2F%3E-%E8%BF%9E%E6%8E%A5%20UART%20%E9%80%82%E9%85%8D%E5%99%A8%E5%B9%B6%E4%BD%BF%E7%94%A8%20115k2%208n1%20%E4%B8%B2%E8%A1%8C%E7%AB%AF%E5%8F%A3%E8%AE%BE%E7%BD%AE%E6%89%93%E5%BC%80%E7%BB%88%E7%AB%AF%E8%BD%AF%E4%BB%B6%E3%80%82%3CBR%20%2F%3E-%E5%B0%86%E5%B9%B3%E8%A1%A1%E5%99%A8%E5%92%8C%E7%94%B5%E6%B1%A0%E7%9A%84%E4%B8%BB%E7%94%B5%E6%BA%90%E8%BF%9E%E6%8E%A5%E5%99%A8%E8%BF%9E%E6%8E%A5%E5%88%B0%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%3CBR%20%2F%3E-%E5%8F%82%E8%A7%81%E5%90%AF%E5%8A%A8%E9%A1%BA%E5%BA%8F%3CA%20href%3D%22https%3A%2F%2Fnxp.gitbook.io%2Frddrone-bms772%2Fsoftware-guide-nuttx%2Ffirst-start-up%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E9%A6%96%E6%AC%A1%E5%90%AF%E5%8A%A8-RDDRONE-BMS772%20(%3C%2FA%3Egitbook.io)%20%3CBR%20%2F%3E-%E9%80%9A%E8%BF%87%E5%91%BD%E4%BB%A4%E8%A1%8C%3CA%20href%3D%22https%3A%2F%2Fnxp.gitbook.io%2Frddrone-bms772%2Fsoftware-guide-nuttx%2Fcommand-line-interface-cli%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E5%91%BD%E4%BB%A4%E8%A1%8C%E7%95%8C%E9%9D%A2%20(CLI)%20%E9%85%8D%E7%BD%AE%20%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F-RDDRONE-BMS772%20(gitbook.io)%3C%2FA%3E%3CBR%20%2F%3E%3CPARAMETER%20name%3D%22%22%3E%3CVALUE%3E%3CA%20href%3D%22https%3A%2F%2Fnxp.gitbook.io%2Frddrone-bms772%2Fsoftware-guide-nuttx%2Funtitled-1%23bms-configuration-parameters-list%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%3C%2FA%3E%3CBR%20%2F%3E%20set%20%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%20%E7%9A%84%E5%8F%82%E6%95%B0-RDDRONE-BMS772%20(gitb%20ook.io)-%3CBR%20%2F%3E%20%E5%A6%82%E6%9E%9C%E9%94%AE%E5%85%A5%20reboot%EF%BC%8C%E5%88%99%E5%AE%8C%E6%88%90%20bms%20save%EF%BC%8CBMS%20%E5%B0%86%E4%BD%BF%E7%94%A8%E6%AD%A3%E7%A1%AE%E7%9A%84%E8%AE%BE%E7%BD%AE%E9%87%8D%E6%96%B0%E5%90%AF%E5%8A%A8%EF%BC%8C%E5%B9%B6%E5%9C%A8%E6%B2%A1%E6%9C%89%E9%94%99%E8%AF%AF%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E6%BF%80%E6%B4%BB%E8%BE%93%E5%87%BA%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FVALUE%3E%3C%2FPARAMETER%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1593928%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1593928%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E6%9C%89%20%3CSTRONG%3E%3CFONT%20size%3D%223%22%3EPL2303HX%20USB%20%E8%BD%AC%20TTL%EF%BC%88%E4%B8%B2%E8%A1%8C%EF%BC%89%E5%8F%98%E6%B5%81%E5%99%A8%3C%2FFONT%3E%3C%2FSTRONG%3E%EF%BC%8C%3CFONT%20size%3D%223%22%3E%E5%AE%83%E5%9C%A8%20Tx%E3%80%81Rx%20%E5%92%8C%20GND%20%E4%B8%8A%E6%8F%90%E4%BE%9B%203.3V%3C%2FFONT%3E%20%E7%9A%84%E7%94%B5%E5%8E%8B%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Frobu.in%2Fproduct%2Fpl2303-pl2303hx-usb-ttl-module-5-pin%2F%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Frobu.in%2Fproduct%2Fpl2303-pl2303hx-usb-ttl-module-5-pin%2F%3C%2FA%3E%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CP%3E%E6%9C%89%E4%BA%86%E5%AE%83%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E5%B0%9D%E8%AF%95%E8%BD%AF%E4%BB%B6%E9%87%8D%E6%96%B0%E9%85%8D%E7%BD%AE%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CFONT%20size%3D%223%22%3EPL2303HX%3C%2FFONT%3E%3C%2FSTRONG%3E%E5%B0%86%20PL2303HX%20%E6%8F%92%E5%85%A5%20USB%20%E7%AB%AF%E5%8F%A3%EF%BC%8C%E5%85%B6%20TX%E3%80%81RX%20%E5%92%8C%20GND%20%E5%BC%95%E8%84%9A%E5%88%86%E5%88%AB%E8%BF%9E%E6%8E%A5%E5%88%B0%20J19%20%E7%AB%AF%E5%8F%A3%E7%9A%84%E7%9B%B8%E5%BA%94%E5%BC%95%E8%84%9A%E4%B8%8A%E3%80%82%E6%88%91%E8%BF%98%E9%9C%80%E8%A6%81%E5%B0%86%E7%94%B5%E6%B1%A0%E8%BF%9E%E6%8E%A5%E5%88%B0%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%EF%BC%88%E8%BF%9E%E6%8E%A5%E5%88%B0%20J4%EF%BC%89%E6%89%8D%E8%83%BD%E4%B8%BA%E5%85%B6%E7%94%B5%E8%B7%AF%E4%BE%9B%E7%94%B5%E5%90%97%EF%BC%9F%E5%A6%82%E6%9E%9C%E6%98%AF%EF%BC%8C4S%20%E8%BF%98%E6%98%AF%203S%20%E7%94%B5%E6%B1%A0%EF%BC%9F%3C%2FP%3E%3CP%3E%E5%92%8C%E6%88%91%E7%9A%84%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%E4%B8%80%E6%A0%B7%EF%BC%8C4S%20%E7%94%B5%E6%B1%A0%E7%BB%88%E7%AB%AF%E8%BF%9E%E6%8E%A5%E5%99%A8%E6%98%AF%E7%84%8A%E6%8E%A5%E5%9C%A8%20JP1%20%E5%92%8C%20SJ3%E3%80%81SJ7%E3%80%81SJ11%20%E5%92%8C%20SJ12%20%E4%B8%AD%E8%BF%9E%E6%8E%A5%E7%9A%84%EF%BC%8C%E4%BD%86%E5%AE%83%E5%9C%A8%E8%BD%AF%E4%BB%B6%E4%B8%AD%E7%9A%84%E5%87%BA%E5%8E%82%E9%BB%98%E8%AE%A4%E9%85%8D%E7%BD%AE%E6%98%AF%203S%E3%80%82%E6%89%80%E4%BB%A5%EF%BC%8C%E6%88%91%E5%BE%88%E5%9B%B0%E6%83%91%E3%80%82%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2......%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1586545%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1586545%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F195015%22%20target%3D%22_blank%22%3E%40Prince1%3C%2FA%3E%E3%80%81%20%3C%2FP%3E%0A%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E6%82%A8%E5%8F%AA%E9%9C%80%E8%BF%9E%E6%8E%A5%20GND%E3%80%81TX%20%E5%92%8C%20RX%EF%BC%8C%E5%A6%82%E6%88%AA%E5%9B%BE%E6%89%80%E7%A4%BA%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22cisvmierlo_0-1674467103221.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cisvmierlo_0-1674467103221.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cisvmierlo_0-1674467103221.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cisvmierlo_0-1674467103221.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cisvmierlo_0-1674467103221.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cisvmierlo_0-1674467103221.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cisvmierlo_0-1674467103221.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cisvmierlo_0-1674467103221.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cisvmierlo_0-1674467103221.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cisvmierlo_0-1674467103221.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F208136i231AF9CF29015C16%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22cisvmierlo_0-1674467103221.png%22%20alt%3D%22cisvmierlo_0-1674467103221.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E%E8%AF%B7%E8%AE%B0%E4%BD%8F%EF%BC%8C%3CSPAN%20data-slate-fragment%3D%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%22%3E%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20USB-%3CSTRONG%3ETTL%20%3C%2FSTRONG%3E-3V3%EF%BC%8C%E8%BF%99%E5%8F%AF%E7%A1%AE%E4%BF%9D%20RX%20%E5%92%8C%20TX%20%E5%BC%95%E8%84%9A%E7%9A%84%E9%80%BB%E8%BE%91%E7%94%B5%E5%B9%B3%E4%B8%BA%203.3V%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%EF%BC%8C%E8%B0%A8%E8%87%B4%E9%97%AE%E5%80%99%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20data-slate-fragment%3D%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%22%3E%E8%A5%BF%E6%96%AF-%E8%8C%83%E7%B1%B3%E8%80%B6%E7%BD%97%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1586527%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1586527%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%20%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3Eiaingalloway%3C%2FSPAN%3E%3C%2FSPAN%3E%2C%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%83%B3%E5%B0%86%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%E9%85%8D%E7%BD%AE%E4%BB%8E%E9%BB%98%E8%AE%A4%203S%20%E6%9B%B4%E6%94%B9%E4%B8%BA%204S%EF%BC%8C%E8%BF%98%E6%83%B3%E9%80%9A%E8%BF%87%E4%B8%B2%E8%A1%8C%E6%8E%A7%E5%88%B6%E5%8F%B0%E6%9B%B4%E6%94%B9%E7%94%B5%E6%B1%A0%E5%8C%96%E5%AD%A6%E6%88%90%E5%88%86%E3%80%82%E8%BF%9E%E6%8E%A5%E5%88%B0%20JST%20GH%207%20%E9%92%88%E8%BF%9E%E6%8E%A5%E5%99%A8%EF%BC%88%E5%8F%AA%E6%9C%89%20Tx%E3%80%81Rx%20%E5%92%8C%20GND%20%E5%BC%95%E8%84%9A%EF%BC%89%E7%9A%84%20FTDI%20%E5%9E%8B%20USB-UART%20%E7%94%B5%E7%BC%86%E6%98%AF%E5%90%A6%E8%B6%B3%E5%A4%9F%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%88%91%E8%BF%98%E5%9C%A8%E5%B0%9D%E8%AF%95%E8%AE%A9%20J%20link%20EDU%20%E8%BF%B7%E4%BD%A0%E8%B0%83%E8%AF%95%E5%99%A8%E6%9B%B4%E6%96%B0%E5%9B%BA%E4%BB%B6%EF%BC%8C%E4%BD%86%E5%AE%83%E7%9A%84%E5%87%86%E5%A4%87%E6%97%B6%E9%97%B4%E6%98%AF%2040%20%E5%91%A8%E3%80%82%E6%89%80%E4%BB%A5%EF%BC%8C%E7%8E%B0%E5%9C%A8%E5%8F%AA%E6%98%AF%E5%B0%9D%E8%AF%95%E6%9B%B4%E6%96%B0%E9%85%8D%E7%BD%AE%E5%8F%82%E6%95%B0%E3%80%82%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2......%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1586201%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1586201%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E7%9F%A5%E9%81%93%E8%BF%99%E5%B7%B2%E7%BB%8F%E6%98%AF%E4%B8%80%E4%B8%AA%E8%80%81%E5%B8%96%E5%AD%90%E4%BA%86%EF%BC%8C%E4%BD%86%E6%88%91%E5%B7%B2%E7%BB%8F%E4%BA%A4%E5%8F%89%E5%8F%91%E5%B8%83%EF%BC%8C%E5%B9%B6%E8%AF%B7%E5%9F%BA%E4%BA%8E%E6%A8%A1%E5%9E%8B%E7%9A%84%E8%AE%BE%E8%AE%A1%E5%9B%A2%E9%98%9F%E5%9C%A8%E8%BF%99%E9%87%8C%E7%9C%8B%E4%B8%80%E7%9C%8B%E3%80%82%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FModel-Based-Design-Toolbox-MBDT%2FRDDRONE-BMS771-MBDT-question%2Fm-p%2F1586198%23M7996%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FModel-Based-Design-Toolbox-MBDT%2FRDDRONE-BMS771-MBDT-question%2Fm-p%2F1586198%23M7996%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1586193%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1586193%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%AF%B7%E6%B3%A8%E6%84%8F%EF%BC%8CNuttX%2FPX4%20%E5%9C%A8%20CAN%20%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E5%99%A8%E6%96%B9%E9%9D%A2%E4%B9%9F%E5%81%9A%E4%BA%86%E4%B8%80%E4%BA%9B%E5%B7%A5%E4%BD%9C%E3%80%82%E4%BD%86%E8%BF%99%E4%BA%9B%E7%9B%AE%E5%89%8D%E8%BF%98%E4%B8%8D%E5%AE%8C%E6%95%B4%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1586179%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1586179%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%83%B3%E6%8C%87%E5%87%BA%E7%9A%84%E6%98%AF%EF%BC%8C%E6%A0%B9%E6%8D%AE%E6%8B%9F%E8%AE%AE%E7%9A%84DroneCode%E6%A0%87%E5%87%86%EF%BC%8C%E7%94%B5%E8%B7%AF%E6%9D%BF%E4%B8%8A%E8%BF%98%E6%9C%89%E9%A2%9D%E5%A4%96%E7%9A%84GPIO%E5%88%86%E9%85%8D%E7%94%A8%E4%BA%8E%E5%B0%86%E6%9D%A5%E6%B7%BB%E5%8A%A0%E6%AD%A4%E7%B1%BB%E5%8A%9F%E8%83%BD%E3%80%82%E8%BF%99%E9%87%8C%E8%BF%98%E6%9C%89%E4%B8%80%E4%BA%9B%E5%85%B6%E4%BB%96%E6%BD%9C%E5%9C%A8%E7%9A%84%E9%99%84%E5%8A%A0%E5%8A%9F%E8%83%BD%EF%BC%8C%E5%8C%85%E6%8B%AC%E8%AF%86%E5%88%AB%E8%BD%A6%E8%BE%86%E7%94%B5%E6%B1%A0%E7%AD%89%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E9%99%A4%E4%BA%86%E9%9C%80%E8%A6%81%E7%BC%96%E5%86%99%E7%9A%84%E4%BB%A3%E7%A0%81%E5%A4%96%EF%BC%8C%3CBR%20%2F%3E%E5%AE%83%E4%BB%AC%E8%BF%98%E4%BD%8D%E4%BA%8E%E5%8D%95%E7%8B%AC%E7%9A%84%E6%A0%87%E5%A4%B4%E4%B8%8A%EF%BC%8C%E9%9C%80%E8%A6%81%E5%9C%A8%E5%B0%86%E7%94%B5%E6%B1%A0%E6%8F%92%E5%85%A5%E6%97%A0%E4%BA%BA%E6%9C%BA%E6%88%96%E8%BD%A6%E8%BE%86%E6%97%B6%E9%92%B3%E4%BD%8D%E3%80%82%3CBR%20%2F%3E%E6%9C%89%E5%85%B3%E8%AF%A6%E7%BB%86%E4%BF%A1%E6%81%AF%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85%20NXP.com%20%E4%B8%8A%E7%9A%84%E5%8E%9F%E7%90%86%E5%9B%BE%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%BF%99%E9%87%8C%E6%8C%87%E7%9A%84%E6%98%AF%E6%8E%A5%E5%A4%B4%20J21%EF%BC%9A%3C%2FP%3E%0A%3CDIV%20id%3D%22tinyMceEditoriaingalloway_0%22%20class%3D%22mceNonEditable%20lia-copypaste-placeholder%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22iaingalloway_2-1674236410319.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_2-1674236410319.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_2-1674236410319.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_2-1674236410319.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_2-1674236410319.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_2-1674236410319.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_2-1674236410319.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_2-1674236410319.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_2-1674236410319.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_2-1674236410319.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F208066i4CA12BCA40A012A6%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22iaingalloway_2-1674236410319.png%22%20alt%3D%22iaingalloway_2-1674236410319.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22iaingalloway_3-1674236426257.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_3-1674236426257.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_3-1674236426257.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_3-1674236426257.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_3-1674236426257.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_3-1674236426257.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_3-1674236426257.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_3-1674236426257.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_3-1674236426257.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_3-1674236426257.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F208067i7CB2E73936BFA44F%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22iaingalloway_3-1674236426257.png%22%20alt%3D%22iaingalloway_3-1674236426257.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CDIV%20id%3D%22tinyMceEditoriaingalloway_1%22%20class%3D%22mceNonEditable%20lia-copypaste-placeholder%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1586168%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1586168%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%AF%B7%E6%B3%A8%E6%84%8F%EF%BC%8C%E5%A6%82%E6%9E%9C%E4%BD%A0%E5%8F%AA%E6%83%B3%E4%BD%BF%E7%94%A8%E4%B8%B2%E8%A1%8C%E6%8E%A7%E5%88%B6%E5%8F%B0%E6%9D%A5%E6%9F%A5%E7%9C%8B%E5%86%85%E9%83%A8%E5%8F%91%E7%94%9F%E4%BA%86%E4%BB%80%E4%B9%88%EF%BC%88%E8%80%8C%E4%B8%8D%E6%98%AF%E9%87%8D%E6%96%B0%E7%BC%96%E7%A8%8B%E5%92%8C%E8%B0%83%E8%AF%95%E6%9D%BF%EF%BC%89%EF%BC%8C%E9%82%A3%E4%B9%88%E4%BD%A0%E5%8F%AF%E4%BB%A5%E8%B4%AD%E4%B9%B0%E4%BB%BB%E4%BD%95%20FTDI%20%E7%B1%BB%E5%9E%8B%E7%9A%84%20USB-UART%20%E7%94%B5%E7%BC%86%EF%BC%88%E6%88%96%E4%BD%BF%E7%94%A8%E5%B8%A6%E6%9C%89%20UART%20%E7%9A%84%20PC%EF%BC%89%E5%B0%86%E4%B8%B2%E8%A1%8C%E6%8E%A7%E5%88%B6%E5%8F%B0%E8%BF%9E%E6%8E%A5%E5%88%B0%20BMS772%E3%80%82%E9%80%9A%E5%B8%B8%EF%BC%8C%E8%BF%99%E6%98%AF%E5%9C%A8%20DCD-LZ%20%E6%9D%BF%E4%B8%8A%E5%87%BA%E7%8E%B0%E7%9A%84%EF%BC%8C%E5%9B%A0%E6%AD%A4%E5%8F%AF%E4%BB%A5%E8%BD%BB%E6%9D%BE%E6%8F%92%E5%85%A5%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%BB%A5%E4%B8%8B%E6%98%AF%E6%82%A8%E5%9C%A8%E4%BA%9A%E9%A9%AC%E9%80%8A%E3%80%81Digikey%20%E6%88%96%E5%85%B6%E4%BB%96%E5%9C%B0%E6%96%B9%E8%B4%AD%E4%B9%B0%E7%9A%84%E7%94%B5%E7%BC%86%E7%B1%BB%E5%9E%8B%EF%BC%9A%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fwww.digikey.com%2Fen%2Fproducts%2Fdetail%2Fftdi-future-technology-devices-international-ltd%2FTTL-234X-3V3%2F6823715%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.digikey.com%2Fen%2Fproducts%2Fdetail%2Fftdi-future-technology-devices-international-ltd%2FTTL-234X-3V3%2F6823715%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22iaingalloway_0-1674235896394.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_0-1674235896394.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_0-1674235896394.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_0-1674235896394.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_0-1674235896394.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_0-1674235896394.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_0-1674235896394.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_0-1674235896394.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_0-1674235896394.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_0-1674235896394.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F208063i084ED54D9FB16F5E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22iaingalloway_0-1674235896394.png%22%20alt%3D%22iaingalloway_0-1674235896394.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E%E7%84%B6%E5%90%8E%E4%BD%A0%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20JST-GH%20%E8%BF%9E%E6%8E%A5%E5%99%A8%E8%BF%9E%E6%8E%A5%E5%88%B0%3CSTRONG%3E%20%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%20%E4%B8%8A%20DCD-LZ%20%E6%8E%A5%E5%8F%A3%E7%9A%84%20RX%20TX%20%E5%92%8C%3C%2FSTRONG%3E%20GND%3CBR%20%2F%3E%20%E5%BC%95%E8%84%9A%E2%80%94%E2%80%94%20%E4%B8%8D%E8%A6%81%E5%B0%86%20FTDI%20%E7%94%B5%E7%BC%86%E7%9A%84%E7%94%B5%E6%BA%90%E8%BF%9E%E6%8E%A5%E5%88%B0%20DCD-LZ%EF%BC%9A%E5%BC%95%E8%84%9A%E6%8E%92%E5%88%97%E5%A6%82%E4%B8%8B%E6%89%80%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fnxp.gitbook.io%2Fhovergames%2Frddrone-fmuk66%2Fconnectors%2Fdebug-interface-dcd-lz%2Fdcd-lz-breakout-board%23pinout%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%20%E7%A4%BA%EF%BC%9Ahttps%3A%2F%2Fnxp.gitbook.io%2Fhovergames%2Frddrone-fmuk66%2Fconnectors%2Fdebug-interface-dcd-lz%2Fdcd-lz-breakout-board%23pinout%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1582513%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1582513%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%B0%A2%E8%B0%A2%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%3C%2FA%3E%E3%80%82%3C%2FP%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%9C%89%E7%94%A8%E7%9A%84%E4%BF%A1%E6%81%AF%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1581963%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1581963%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E8%AF%B7%E6%B3%A8%E6%84%8F%EF%BC%8C%E5%A6%82%E6%9E%9C%E8%A6%81%E4%BD%BF%E7%94%A8%E5%AE%83%EF%BC%8C%E6%82%A8%E9%9C%80%E8%A6%81%E5%B0%86%E4%B8%80%E4%B8%AA%200.50%22%20%E6%8E%A5%E5%A4%B4%E7%84%8A%E6%8E%A5%E5%88%B0%20J2%20%E4%B8%8A%E3%80%82%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1581962%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1581962%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22iaingalloway_0-1673558852262.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_0-1673558852262.png%22%20style%3D%22width%3A%20388px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_0-1673558852262.png%22%20style%3D%22width%3A%20388px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_0-1673558852262.png%22%20style%3D%22width%3A%20388px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_0-1673558852262.png%22%20style%3D%22width%3A%20388px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_0-1673558852262.png%22%20style%3D%22width%3A%20388px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_0-1673558852262.png%22%20style%3D%22width%3A%20388px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_0-1673558852262.png%22%20style%3D%22width%3A%20388px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_0-1673558852262.png%22%20style%3D%22width%3A%20388px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_0-1673558852262.png%22%20style%3D%22width%3A%20388px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F207150i2EFE104225F00316%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22iaingalloway_0-1673558852262.png%22%20alt%3D%22iaingalloway_0-1673558852262.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EJ2%20%E6%98%AF%E6%A0%87%E5%87%86%2010%2F9%20%E5%BC%95%E8%84%9A%E8%B0%83%E8%AF%95%E6%8E%A5%E5%A4%B4%E7%9A%84%E6%8F%92%E5%BA%A7%EF%BC%8C%E5%8F%AF%E4%B8%8E%E4%BB%BB%E4%BD%95%20Segger%20JLINK%20%E8%AE%BE%E5%A4%87%E4%B8%80%E8%B5%B7%E4%BD%BF%E7%94%A8%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%82%A8%E8%BF%98%E5%8F%AF%E4%BB%A5%E5%88%B6%E4%BD%9C%E4%B8%80%E6%9D%A1%E7%94%B5%E7%BC%86%EF%BC%8C%E6%8F%92%E5%85%A5%20DCDLZ%20%E7%AB%AF%E5%8F%A3%E5%B9%B6%E8%BF%9E%E6%8E%A5%E5%88%B0%20FTDI%203v3%20USB2UART%20%E7%94%B5%E7%BC%86%E3%80%82%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fwww.amazon.com%2FPre-Crimped-Connectors-Pixhawk2-Pixracer-Silicone%2Fdp%2FB07PBHN7TM%2Fref%3Dsr_1_3%3Fcrid%3DGL7B8ZZMTG79%26amp%3Bkeywords%3Djst-gh%26amp%3Bqid%3D1673558988%26amp%3Bsprefix%3Djst-gh%252Caps%252C147%26amp%3Bsr%3D8-3%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.amazon.com%2FPre-Crimped-Connectors-Pixhawk2-Pixracer-Silicone%2Fdp%2FB07PBHN7TM%2Fref%3Dsr_1_3%3Fcrid%3DGL7B8ZZMTG79%26amp%3Bkeywords%3Djst-gh%26amp%3Bqid%3D1673558988%26amp%3Bsprefix%3Djst-gh%252Caps%252C147%26amp%3Bsr%3D8-3%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%A6%82%E5%89%8D%E6%89%80%E8%BF%B0%EF%BC%8C%E8%BF%99%E4%BA%9B%E9%A1%B9%E7%9B%AE%E5%8C%85%E5%90%AB%E5%9C%A8%E5%85%B6%E4%BB%96%E4%B8%80%E4%BA%9B%E5%BC%80%E5%8F%91%E5%A5%97%E4%BB%B6%E4%B8%AD%EF%BC%8C%E5%8F%AF%E4%BB%A5%E5%9C%A8%E6%AD%A4%E9%87%8D%E5%A4%8D%E4%BD%BF%E7%94%A8%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1581811%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1581811%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F195015%22%20target%3D%22_blank%22%3E%40Prince1%3C%2FA%3E%E3%80%81%20%3C%2FP%3E%0A%3CP%3E%E8%AE%A9%E6%88%91%E5%9C%A8%E5%86%85%E9%83%A8%E6%A3%80%E6%9F%A5%E4%B8%80%E4%B8%8B%E8%BF%99%E4%B8%AA%E9%80%82%E9%85%8D%E5%99%A8%E6%9D%BF%E7%9A%84%E5%8F%AF%E7%94%A8%E6%80%A7%E3%80%82%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fnxp.gitbook.io%2Fhovergames%2Frddrone-fmuk66%2Fconnectors%2Fdebug-interface-dcd-lz%2Fdcd-lz-breakout-board%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E4%BB%A5%E4%B8%8B%E6%98%AF%E6%9C%89%E5%85%B3%20DCD-LZ%20%E9%80%82%E9%85%8D%E5%99%A8%E6%9D%BF%E7%9A%84%E6%9B%B4%E5%A4%9A%E4%BF%A1%E6%81%AF%EF%BC%8C%E5%8C%85%E6%8B%AC%E5%8E%9F%E7%90%86%E5%9B%BE%EF%BC%9Ahttps%3A%2F%2Fnxp.gitbook.io%2Fhovergames%2Frddrone-fmuk66%2Fconnectors%2Fdebug-interface-dcd-lz%2Fdcd-lz-breakout-board%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%88%91%E7%A1%AE%E5%AE%9E%E7%9F%A5%E9%81%93%E5%AE%83%E4%BB%AC%E9%80%9A%E5%B8%B8%E6%98%AF%E5%A5%97%E4%BB%B6%E7%9A%84%E4%B8%80%E9%83%A8%E5%88%86%EF%BC%8C%E6%88%91%E7%A1%AE%E5%AE%9E%E6%89%BE%E5%88%B0%E4%BA%86%E8%BF%99%E4%B8%AA%20UCAN%20%E6%9D%BF%EF%BC%8C%E4%BD%A0%E5%8F%AF%E4%BB%A5%E9%80%89%E6%8B%A9%E8%B4%AD%E4%B9%B0%20KIT-UCANS32K1SIC%E3%80%82%3CBR%20%2F%3E%E8%AF%A5%E5%A5%97%E4%BB%B6%E5%8C%85%E6%8B%AC%202%20%E4%B8%AA%20DCD-LZ%20%E9%80%82%E9%85%8D%E5%99%A8%E3%80%812%20%E6%A0%B9%20FTDI-USB%20%E7%94%B5%E7%BC%86%E5%92%8C%201%20%E4%B8%AA%20Segger%20Jlink%20mini%20EDU%20%E8%B0%83%E8%AF%95%E5%99%A8%EF%BC%88%E7%BC%96%E7%A8%8B%E5%92%8C%E8%B0%83%E8%AF%95%EF%BC%89%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E9%93%BE%E6%8E%A5%E5%88%B0%20KIT-UCANS32K1SIC%3A%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Finterfaces%2Fcan-transceivers%2Fcan-signal-improvement%2Fcan-sic-evaluation-board%3AUCANS32K1SIC%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%3C%2FA%3E%2F%2F%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fproducts%2Finterfaces%2Fcan-transceivers%2Fcan-signal-improvement%2Fcan-sic-evaluation-board%3AUCANS32K1SIC%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ewww.nxp.com%2Fproducts%2Finterfaces%2Fcan-transceivers%2Fcan-signal-improvement%2Fcan-sic-evaluation-board%3AUCANS32K1SIC%3C%2FA%3E%20%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%BA%B2%E5%88%87%E7%9A%84%E9%97%AE%E5%80%99%EF%BC%8C%3CBR%20%2F%3E%3CBR%20%2F%3ECis%20van%20Mierlo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1581747%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1581747%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F211084%22%20target%3D%22_blank%22%3E%40Airobot-Dynamics%3C%2FA%3E%E3%80%81%20%3C%2FP%3E%0A%3CP%3E%E5%9C%A8%E4%BB%A5%E4%B8%8B%E6%81%A9%E6%99%BA%E6%B5%A6%E7%A4%BE%E5%8C%BA%E9%A1%B5%E9%9D%A2%E4%B8%AD%EF%BC%8C%E8%AF%B4%E6%98%8E%3CSPAN%3E%E6%96%87%E6%A1%A3%E5%92%8C%E8%BD%AF%E4%BB%B6%E5%8F%AF%E5%9C%A8%20DocStore%20%E4%B8%8A%E8%8E%B7%E5%8F%96%E3%80%82%E5%AE%83%E8%BF%98%E8%A7%A3%E9%87%8A%E4%BA%86%E5%A6%82%E4%BD%95%E8%AE%BF%E9%97%AE%20DocStore%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%88%91%E8%AE%A4%E4%B8%BA%20A1007%20%E4%BB%85%E5%9C%A8%20NDA%20%E4%B8%8B%E5%8F%AF%E7%94%A8%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%E6%81%A9%E6%99%BA%E6%B5%A6%E7%A4%BE%E5%8C%BA%E7%BD%91%E9%A1%B5%E9%93%BE%E6%8E%A5%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FOther-NXP-Products%2FOM67201UL-driver-A1007%2Fm-p%2F1447573%22%20target%3D%22_blank%22%3E%EF%BC%9A%3C%2FA%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FOther-NXP-Products%2FOM67201UL-driver-A1007%2Fm-p%2F1447573%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FOther-NXP-Products%2FOM67201UL-driver-A1007%2Fm-p%2F1447573%3C%2FA%3E%20%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fiotsecurity%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E5%A6%82%E6%9E%9C%E4%BD%A0%E6%83%B3%E8%87%AA%E5%B7%B1%E5%BC%80%E5%8F%91%E4%B8%80%E4%BA%9B%E4%B8%9C%E8%A5%BF%EF%BC%8C%E6%88%91%E5%BB%BA%E8%AE%AE%E4%BD%A0%E7%9C%8B%E7%9C%8B%E5%B8%B8%E8%A7%81%E7%9A%84%E6%81%A9%E6%99%BA%E6%B5%A6%E7%89%A9%E8%81%94%E7%BD%91%E7%BD%91%E7%BB%9C%E5%AE%89%E5%85%A8%E5%92%8C%E8%BA%AB%E4%BB%BD%E9%AA%8C%E8%AF%81%E4%BA%A7%E5%93%81%E7%BB%84%E5%90%88%EF%BC%9Ahttps%3A%2F%2Fwww.nxp.com%2Fiotsecurity%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E4%BE%8B%E5%A6%82%EF%BC%8CSE050%20%E6%88%96%20SE051%20%E6%98%AF%E4%B8%80%E6%AC%BE%E5%A4%A7%E5%8A%9B%E6%94%AF%E6%8C%81%E7%9A%84%E8%AE%BE%E5%A4%87%EF%BC%8C%E5%B7%B2%E7%BB%8F%E5%AE%9E%E7%8E%B0%E4%BA%86%E8%AE%B8%E5%A4%9A%E7%94%A8%E4%BE%8B%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E4%BD%A0%E6%83%B3%E5%9C%A8%E9%85%8D%E5%A4%87%20SE050%20%E5%92%8C%E7%B1%BB%E4%BC%BC%E5%BE%AE%E6%8E%A7%E5%88%B6%E5%99%A8%EF%BC%88S32K146%20%E8%80%8C%E4%B8%8D%E6%98%AF%20S32K144%EF%BC%89%E7%9A%84%E6%9D%BF%E4%B8%8A%E8%BF%9B%E8%A1%8C%E5%BC%80%E5%8F%91%E3%80%82%3CSPAN%3EUCANS32K146%20%E5%8F%AF%E8%83%BD%E6%98%AF%E4%B8%80%E6%AC%BE%E6%9C%89%E8%B6%A3%E7%9A%84%E4%BA%A7%E5%93%81%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3ESE050%20%E7%9A%84%E9%93%BE%E6%8E%A5%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fsecurity-and-authentication%2Fauthentication%2Fedgelock-se050-plug-trust-secure-element-family-enhanced-iot-security-with-high-flexibility%3ASE050%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%EF%BC%9A%3C%2FA%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fsecurity-and-authentication%2Fauthentication%2Fedgelock-se050-plug-trust-secure-element-family-enhanced-iot-security-with-high-flexibility%3ASE050%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fproducts%2Fsecurity-and-authentication%2Fauthentication%2Fedgelock-se050-plug-trust-secure-element-family-enhanced-iot-security-with-high-flexibility%3ASE050%3C%2FA%3E%20%3CBR%20%2F%3E%E4%B8%8E%3CSPAN%3EUCANS32K146%3C%2FSPAN%3E%20%E7%9A%84%E9%93%BE%E6%8E%A5%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdevelopment-boards%2Fautomotive-development-platforms%2Fs32k-mcu-platforms%2Fs32k146-uavcan-v1-and-mavcan-development-system%3AUCANS32K146%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%EF%BC%9A%3C%2FA%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdevelopment-boards%2Fautomotive-development-platforms%2Fs32k-mcu-platforms%2Fs32k146-uavcan-v1-and-mavcan-development-system%3AUCANS32K146%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdevelopment-boards%2Fautomotive-development-platforms%2Fs32k-mcu-platforms%2Fs32k146-uavcan-v1-and-mavcan-development-system%3AUCANS32K146%3C%2FA%3E%20%3C%2FP%3E%0A%3CP%3E%E5%B8%8C%E6%9C%9B%E8%BF%99%E8%83%BD%E5%9B%9E%E7%AD%94%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%B0%A8%E8%87%B4%E9%97%AE%E5%80%99%E3%80%81%3C%2FP%3E%0A%3CP%3E%E8%A5%BF%E6%96%AF-%E8%8C%83%E7%B1%B3%E8%80%B6%E7%BD%97%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1580845%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1580845%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EA1007%20%E5%AE%89%E5%85%A8%E9%AA%8C%E8%AF%81%E8%8A%AF%E7%89%87%3C%2FP%3E%3CP%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%EF%BC%8C%E6%88%91%E5%88%9A%E5%88%9A%E5%BC%80%E5%A7%8B%E4%BD%BF%E7%94%A8%20BMS772%20%E8%BF%9B%E8%A1%8C%E5%BC%80%E5%8F%91%E3%80%82%E4%BD%86%E6%98%AF%EF%BC%8C%E6%88%91%E6%89%BE%E4%B8%8D%E5%88%B0%E6%9C%89%E5%85%B3%20A1007%20%E9%9B%86%E6%88%90%E7%94%B5%E8%B7%AF%E7%9A%84%E4%BB%BB%E4%BD%95%E4%BF%A1%E6%81%AF%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E7%94%9A%E8%87%B3%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6%E7%BD%91%E7%AB%99%E4%B8%8A%E6%89%BE%E4%B8%8D%E5%88%B0%E8%BF%99%E4%B8%AA%20IC%EF%BC%8C%E6%AF%94%E5%A6%82%E6%88%91%E4%BB%AC%E5%B8%B8%E7%94%A8%E7%9A%84%E4%BE%9B%E5%BA%94%E5%95%86%20Digi-Key%20%E7%AD%89%E3%80%82%3CBR%20%2F%3E%E8%BF%99%E4%B8%AA%E9%9B%86%E6%88%90%E7%94%B5%E8%B7%AF%E8%BF%87%E6%97%B6%E4%BA%86%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%98%AF%EF%BC%8C%E6%98%AF%E5%90%A6%E6%9C%89%E4%BB%BB%E4%BD%95%E6%9B%BF%E4%BB%A3%E5%BB%BA%E8%AE%AE%E3%80%82%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1580776%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1580776%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%BF%AB%E9%80%9F%E5%9B%9E%E5%A4%8D%E3%80%82%E4%B8%8D%E5%B9%B8%E7%9A%84%E6%98%AF%EF%BC%8C%E6%88%91%E6%89%BE%E4%B8%8D%E5%88%B0%E5%9C%A8%E5%8D%B0%E5%BA%A6%E8%B4%AD%E4%B9%B0%20DCD-LZ%20%E9%80%82%E9%85%8D%E5%99%A8%E7%9A%84%E4%BB%A3%E7%90%86%E5%95%86%E3%80%82%E6%88%91%E4%B9%9F%E6%B2%A1%E6%9C%89%E6%B0%94%E5%9E%AB%E6%B8%B8%E6%88%8F%E5%A5%97%E4%BB%B6%E3%80%82%3C%2FP%3E%3CP%3E%E6%82%A8%E8%83%BD%E6%8E%A8%E8%8D%90%E5%85%B6%E4%BB%96%E5%B9%BF%E6%B3%9B%E4%BD%BF%E7%94%A8%E7%9A%84%E9%80%82%E9%85%8D%E5%99%A8%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1579322%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1579322%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F195015%22%20target%3D%22_blank%22%3E%40Prince1%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E4%BA%8B%E5%AE%9E%E4%B8%8A%EF%BC%8C%E6%82%A8%E9%9C%80%E8%A6%81%E5%AF%B9%E8%BD%AF%E4%BB%B6%E8%BF%9B%E8%A1%8C%E7%9B%B8%E5%BA%94%E7%9A%84%E9%85%8D%E7%BD%AE%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%85%B7%E4%BD%93%E5%81%9A%E6%B3%95%E5%A6%82%E4%B8%8B%3C%2FP%3E%3CP%3E1%E3%80%82%E4%BD%BF%E7%94%A8%207%20%E9%92%88%20JST-GH%20%E7%94%B5%E7%BC%86%E5%B0%86%20DCD-LZ%20%E9%80%82%E9%85%8D%E5%99%A8%E8%BF%9E%E6%8E%A5%E5%88%B0%20BMS772%20%E6%9D%BF%E4%B8%8A%E3%80%82%3CBR%20%2F%3E2.%E7%94%A8%20FTDI%20USBUART-3V3%20%E7%94%B5%E7%BC%86%E5%B0%86%20DCD-LZ%20%E9%80%82%E9%85%8D%E5%99%A8%E8%BF%9E%E6%8E%A5%E5%88%B0%E7%AC%94%E8%AE%B0%E6%9C%AC%E7%94%B5%E8%84%91%E6%88%96%E4%B8%AA%E4%BA%BA%E7%94%B5%E8%84%91%E3%80%82%20%3CBR%20%2F%3E3.%E9%80%9A%E8%BF%87%20PuTTY%20%E6%88%96%20TeraTerm%EF%BC%88%3CSPAN%3E115%3C%2FSPAN%3E%20200%20%E6%B3%A2%E7%89%B9%EF%BC%89%E7%AD%89%E4%B8%B2%E8%A1%8C%E6%8E%A5%E5%8F%A3%E8%BF%9E%E6%8E%A5%E5%88%B0%20BMS772%E3%80%82%3CBR%20%2F%3E4%E3%80%82%E9%94%AE%E5%85%A5%20%22%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%20help%22%20%E4%BB%A5%E8%8E%B7%E5%8F%96%E5%91%BD%E4%BB%A4%E8%A1%8C%E7%95%8C%E9%9D%A2%20(CLI)%20%E7%9A%84%E5%B8%AE%E5%8A%A9%E3%80%82%3CBR%20%2F%3E5%E3%80%82%E9%94%AE%E5%85%A5%20%22%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%20get%20all%22%20%E4%BB%A5%E8%8E%B7%E5%8F%96%E6%89%80%E6%9C%89%E5%8F%82%E6%95%B0%E4%BB%A5%E5%8F%8A%E4%B8%8E%E8%BF%99%E4%BA%9B%E5%8F%82%E6%95%B0%E7%9B%B8%E5%85%B3%E7%9A%84%E5%80%BC%E3%80%82%3CBR%20%2F%3E6%E3%80%82%E6%9B%B4%E6%94%B9%E8%A6%81%E6%9B%B4%E6%94%B9%E7%9A%84%E5%8F%98%E9%87%8F%EF%BC%8C%E5%9C%A8%E6%9C%AC%E4%BE%8B%E4%B8%AD%E4%B8%BA%20n%20%E4%B8%AA%E5%8D%95%E5%85%83%E6%A0%BC%E6%9B%B4%E6%94%B9%E4%B8%BA%204%EF%BC%8C%E9%94%AE%E5%85%A5%EF%BC%9A%22%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%20set%20n%20cells%204%20%22%207%E3%80%82%3CBR%20%2F%3E%E8%A6%81%E7%A1%AE%E4%BF%9D%E5%B0%86%E5%8F%82%E6%95%B0%E4%BF%9D%E5%AD%98%E5%88%B0%E9%97%AA%E5%AD%98%E4%B8%AD%EF%BC%8C%E8%AF%B7%E9%94%AE%E5%85%A5%EF%BC%9A%22%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%20save%20%22%20%3CBR%20%2F%3E%208%E3%80%82%E8%AE%BE%E7%BD%AE%E6%96%B0%E5%8F%82%E6%95%B0%E5%90%8E%EF%BC%8C%E4%BD%A0%E5%8F%AF%E4%BB%A5%E6%8C%89%E4%B8%8B%E6%8C%89%E9%92%AE%E6%88%96%E9%94%AE%E5%85%A5%EF%BC%9A%22%20%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%20RESET%20%22%20%E6%9D%A5%20RESET%20%E6%95%85%E9%9A%9C%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3ECLI%20%E9%9D%9E%E5%B8%B8%E6%9C%89%E7%94%A8%EF%BC%8C%E5%9B%A0%E4%B8%BA%E5%AE%83%E4%BC%9A%E6%8C%87%E5%87%BA%E5%AF%BC%E8%87%B4%E9%94%99%E8%AF%AF%E7%9A%84%E5%8E%9F%E5%9B%A0%E3%80%82%20%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%BB%A5%E4%B8%8B%E6%98%AF%E4%B8%80%E4%BA%9B%E6%9C%89%E7%94%A8%E7%9A%84%E5%85%A5%E9%97%A8%E9%93%BE%E6%8E%A5%EF%BC%9A%3CBR%20%2F%3E%E6%9C%89%E5%85%B3%E8%AE%BE%E7%BD%AE%20CLI%20%E7%9A%84%E9%93%BE%E6%8E%A5%3CA%20href%3D%22https%3A%2F%2Fnxp.gitbook.io%2Frddrone-bms772%2Fuser-guide%2Fgetting-started-with-the-rddrone-bms772%2Fusing-the-command-line-interface-cli%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%EF%BC%9A%3C%2FA%3E%3CA%20href%3D%22https%3A%2F%2Fnxp.gitbook.io%2Frddrone-bms772%2Fuser-guide%2Fgetting-started-with-the-rddrone-bms772%2Fusing-the-command-line-interface-cli%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fnxp.gitbook.io%2Frddrone-bms772%2Fuser-guide%2Fgetting-started-with-the-rddrone-bms772%2Fusing-the-command-line-interface-cli%3C%2FA%3E%20%3CBR%20%2F%3E%E5%85%B3%E4%BA%8E%E4%BD%BF%E7%94%A8%20CLI%20%E7%9A%84%E9%93%BE%E6%8E%A5%3CA%20href%3D%22https%3A%2F%2Fnxp.gitbook.io%2Frddrone-bms772%2Fsoftware-guide-nuttx%2Fcommand-line-interface-cli%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%EF%BC%9A%3C%2FA%3E%3CA%20href%3D%22https%3A%2F%2Fnxp.gitbook.io%2Frddrone-bms772%2Fsoftware-guide-nuttx%2Fcommand-line-interface-cli%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fnxp.gitbook.io%2Frddrone-bms772%2Fsoftware-guide-nuttx%2Fcommand-line-interface-cli%3C%2FA%3E%20%3CBR%20%2F%3E%E5%B8%A6%E6%9C%89%E5%8F%82%E6%95%B0%E5%88%97%E8%A1%A8%E7%9A%84%E9%93%BE%E6%8E%A5%3CA%20href%3D%22https%3A%2F%2Fnxp.gitbook.io%2Frddrone-bms772%2Fsoftware-guide-nuttx%2Funtitled-1%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%EF%BC%9A%3C%2FA%3E%3CA%20href%3D%22https%3A%2F%2Fnxp.gitbook.io%2Frddrone-bms772%2Fsoftware-guide-nuttx%2Funtitled-1%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fnxp.gitbook.io%2Frddrone-bms772%2Fsoftware-guide-nuttx%2Funtitled-1%3C%2FA%3E%20%3CBR%20%2F%3E%3CBR%20%2F%3E%E7%89%88%E6%9C%AC%E8%AF%B4%E6%98%8E%E7%9A%84%E7%AC%AC%207%20%E7%AB%A0%EF%BC%88%E4%BF%AE%E8%AE%A2%E7%89%885%EF%BC%89%E4%B9%9F%E5%BE%88%E6%9C%89%E7%94%A8%EF%BC%8C%E5%9B%A0%E4%B8%BA%E5%AE%83%E5%8C%85%E5%90%AB%E4%B8%80%E5%BC%A0%20DCD-LZ%20%E9%80%82%E9%85%8D%E5%99%A8%E7%9A%84%E5%9B%BE%E7%89%87%EF%BC%8C%E4%B8%8A%E9%9D%A2%E8%BF%9E%E6%8E%A5%E7%9D%80%207%20%E9%92%88%20JST%20GH%20%E7%94%B5%E7%BC%86%E5%92%8C%20USB-TTL-3V3%20%E7%94%B5%E7%BC%86%E3%80%82%3CBR%20%2F%3E%E7%AC%AC%208%20%E7%AB%A0%E5%8C%85%E6%8B%AC%20BMS772%20%E7%9A%84%E5%8F%82%E6%95%B0%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%88%91%E4%BC%9A%E5%BB%BA%E8%AE%AE%E5%B0%86%E8%BD%AF%E4%BB%B6%E6%9B%B4%E6%96%B0%E5%88%B0%E6%9C%80%E6%96%B0%E7%9A%84%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E3%80%82%3CBR%20%2F%3E%E6%9C%80%E6%96%B0%E7%9A%84%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E5%8F%AF%E4%BB%A5%E5%9C%A8%E4%BB%A5%E4%B8%8B%E7%BD%91%E5%9D%80%E6%89%BE%E5%88%B0%EF%BC%9A%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2Ftree%2Fmain%2FBinary%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2Ftree%2Fmain%2FBinary%3C%2FA%3E%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fnxp.gitbook.io%2Frddrone-bms772%2Fuser-guide%2Fgetting-started-with-the-rddrone-bms772%2Fflashing-firmware-to-the-rddrone-bms772%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%E8%AF%B4%E6%98%8E%E5%8F%AF%E4%BB%A5%E5%9C%A8%E7%89%88%E6%9C%AC%E8%AF%B4%E6%98%8E%E7%9A%84%E7%AC%AC%207%20%E7%AB%A0%E3%80%81%E4%BB%A3%E7%A0%81%E5%AD%98%E5%82%A8%E5%BA%93%E6%88%96%20gitbook%20%E4%B8%8A%E6%89%BE%E5%88%B0%EF%BC%9Ahttps%3A%2F%2Fnxp.gitbook.io%2Frddrone-bms772%2Fuser-guide%2Fgetting-started-with-the-rddrone-bms772%2Fflashing-firmware-to-the-rddrone-bms772%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%AF%B7%E8%AE%B0%E4%BD%8F%EF%BC%8C%E7%BC%96%E7%A8%8B%E5%90%8E%EF%BC%8C%E6%82%A8%E9%9C%80%E8%A6%81%E9%87%8D%E6%96%B0%E9%85%8D%E7%BD%AE%E5%8F%82%E6%95%B0%EF%BC%8C%E5%9B%A0%E4%B8%BA%E8%BF%99%E4%BA%9B%E5%8F%82%E6%95%B0%E4%BC%9A%E8%A2%AB%E8%A6%86%E7%9B%96%E3%80%82%3C%2FP%3E%3CP%3E%E5%B8%8C%E6%9C%9B%E5%AF%B9%E6%82%A8%E6%9C%89%E6%89%80%E5%B8%AE%E5%8A%A9%EF%BC%8C%E8%B0%A8%E8%87%B4%E9%97%AE%E5%80%99%E3%80%81%3C%2FP%3E%3CP%3E%E8%A5%BF%E6%96%AF-%E8%8C%83%E7%B1%B3%E8%80%B6%E7%BD%97%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1579306%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1579306%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSTRONG%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E6%88%91%E4%B9%B0%E4%BA%86%E4%B8%80%E5%9D%97%E6%96%B0%E7%9A%84%20RDDRONE-BMS772%20%E6%9D%BF%E6%83%B3%E7%94%A8%E5%AE%83%E6%9D%A5%E5%81%9A%204S%20LiPO%20%E7%94%B5%E6%B1%A0%E7%BB%84%E3%80%82%E6%88%91%E4%B8%BA%204S%20%E7%84%8A%E6%8E%A5%E4%BA%86%E7%94%B5%E6%B1%A0%E7%AB%AF%E5%AD%90%E8%BF%9E%E6%8E%A5%E5%99%A8%E5%92%8C%E7%84%8A%E6%8E%A5%E8%B7%B3%E7%BA%BF%E5%BC%95%E8%84%9A%20(SJ)%E3%80%82%E8%BF%9E%E6%8E%A5%E5%88%B0%204S%20%E7%94%B5%E6%B1%A0%E7%BB%84%E5%90%8E%EF%BC%8C%E6%88%91%E6%B5%8B%E9%87%8F%E8%BE%93%E5%87%BA%E7%94%B5%E5%8E%8B%E6%97%B6%E5%8F%91%E7%8E%B0%E7%94%B5%E5%8E%8B%E4%B8%BA%200V%E3%80%82%E6%88%91%E4%B9%9F%E4%B8%8D%E7%9F%A5%E9%81%93%E4%B8%BA%E4%BB%80%E4%B9%88%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E8%BF%98%E9%9C%80%E8%A6%81%E5%9C%A8%E8%BD%AF%E4%BB%B6%E4%B8%AD%E6%9B%B4%E6%94%B9%E4%BB%BB%E4%BD%95%E9%85%8D%E7%BD%AE%EF%BC%88%E9%92%88%E5%AF%B9%204S%EF%BC%89%E5%90%97%EF%BC%9F%E5%A6%82%E6%9E%9C%E6%98%AF%EF%BC%8C%E6%80%8E%E4%B9%88%E5%81%9A%EF%BC%9F%E8%AF%B7%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%3CP%3E%E5%85%88%E8%A1%8C%E8%87%B4%E8%B0%A2%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1558683%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1558683%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F209164%22%20target%3D%22_blank%22%3E%40Ch_Han%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E5%BD%93%20%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%20%E5%A4%84%E4%BA%8E%20DEEP_SLEEP%20%E7%8A%B6%E6%80%81%E6%97%B6%EF%BC%8C%E5%AE%83%E9%9C%80%E8%A6%81%E9%99%90%E5%88%B6%20%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%20%E8%87%AA%E8%BA%AB%E6%B6%88%E8%80%97%E7%9A%84%E7%94%B5%E9%87%8F%EF%BC%8C%E4%BB%A5%E6%9C%80%E5%A4%A7%E9%99%90%E5%BA%A6%E5%9C%B0%E8%8A%82%E7%9C%81%E7%94%B5%E6%B1%A0%E7%94%B5%E9%87%8F%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%BF%99%E6%98%AF%E9%80%9A%E8%BF%87%E5%B0%86%E7%94%B5%E6%B1%A0%E4%BE%9B%E7%94%B5%E7%9A%84%E5%85%83%E5%99%A8%E4%BB%B6%E8%AE%BE%E7%BD%AE%E4%B8%BA%E6%B7%B1%E5%BA%A6%E7%9D%A1%E7%9C%A0%2F%E7%9D%A1%E7%9C%A0%E7%8A%B6%E6%80%81%E4%BB%A5%E5%8F%8A%E7%A6%81%E7%94%A8%E7%94%B5%E5%8E%8B%E5%8A%9F%E8%83%BD%E5%9F%9F%EF%BC%88%E5%85%B3%E9%97%AD3.3V%E5%92%8C5V%EF%BC%89%EF%BC%8C%E4%BB%A5%E5%8F%8A%E5%85%B3%E9%97%AD%E7%94%B1%E8%AF%A53.3V%E6%8F%90%E4%BE%9B%E7%9A%84%E5%BE%AE%E6%8E%A7%E5%88%B6%E5%99%A8%E7%9A%84%E7%94%B5%E6%BA%90%E6%9D%A5%E5%AE%8C%E6%88%90%E7%9A%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%B8%BA%E4%BA%86%E5%94%A4%E9%86%92%20SBC%EF%BC%88%E5%86%8D%E6%AC%A1%E6%89%93%E5%BC%80%203.3V%20%E7%94%B5%E6%BA%90%EF%BC%8C%E4%B8%BA%E5%BE%AE%E6%8E%A7%E5%88%B6%E5%99%A8%E4%BE%9B%E7%94%B5%EF%BC%89%EF%BC%8C%E6%88%91%E8%AE%A4%E4%B8%BA%20SW%20%E5%8F%AA%E9%85%8D%E7%BD%AE%E4%BA%86%20SBC%20%E7%9A%84%E5%94%A4%E9%86%92%E5%BC%95%E8%84%9A%EF%BC%8C%E4%BB%A5%E5%8F%91%E5%87%BA%20SBC%20%E5%94%A4%E9%86%92%E4%BF%A1%E5%8F%B7%E3%80%82%E4%B8%BA%E6%AD%A4%EF%BC%8C%E9%9C%80%E8%A6%81%E6%8C%89%E4%B8%8B%E6%8C%89%E9%92%AE%E6%88%96%E5%B0%86%20J22%20%E7%9F%AD%E8%B7%AF%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%BD%86%E6%88%91%E7%9B%B8%E4%BF%A1%EF%BC%8C%E9%80%9A%E8%BF%87%20CAN%20%E8%BF%9B%E8%A1%8C%E5%94%A4%E9%86%92%E5%8F%AF%E4%BB%A5%E5%9C%A8%20SW%20%E4%B8%AD%E5%90%AF%E7%94%A8%EF%BC%8C%E5%9B%A0%E4%B8%BA%20SBC%20%E5%A4%84%E4%BA%8E%E4%BC%91%E7%9C%A0%E7%8A%B6%E6%80%81%EF%BC%8C%E4%BB%8D%E7%94%B1%E7%94%B5%E6%B1%A0%E4%BE%9B%E7%94%B5%E3%80%82%E7%84%B6%E8%80%8C%EF%BC%8C%E7%9B%AE%E5%89%8D%E7%9A%84%E8%BD%AF%E4%BB%B6%E7%A4%BA%E4%BE%8B%E6%97%A0%E6%B3%95%E5%AE%9E%E7%8E%B0%E8%BF%99%E4%B8%80%E7%82%B9%EF%BC%8C%E6%88%91%E4%B9%9F%E4%B8%8D%E7%9F%A5%E9%81%93%E5%AF%B9%E7%A1%AC%E4%BB%B6%E7%9A%84%E8%A6%81%E6%B1%82%E6%98%AF%E4%BB%80%E4%B9%88%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E6%83%B3%E6%B7%BB%E5%8A%A0%E6%AD%A4%E5%8A%9F%E8%83%BD%EF%BC%8C%E5%8F%AF%E4%BB%A5%E6%9F%A5%E7%9C%8B%20SBC%20%E7%9A%84%E6%95%B0%E6%8D%AE%E8%A1%A8%E4%BB%A5%E5%8F%8A%E8%AF%A5%E6%9D%BF%E7%9A%84%E5%85%AC%E5%85%B1%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%E8%BD%AF%E4%BB%B6%E7%A4%BA%E4%BE%8B%E7%9A%84%20sbc.c%20%E5%92%8C%20sbc.h%20%E6%96%87%E4%BB%B6%E3%80%82%3CBR%20%2F%3ESBC%20%E7%9A%84%E6%95%B0%E6%8D%AE%E8%A1%A8%E5%8F%AF%E5%9C%A8%E8%BF%99%E9%87%8C%E6%89%BE%E5%88%B0%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fpower-management%2Fpmics-and-sbcs%2Fmini-sbcs%2Fmini-high-speed-can-system-basis-chip%3AUJA1169ATK%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%EF%BC%9A%3C%2FA%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fpower-management%2Fpmics-and-sbcs%2Fmini-sbcs%2Fmini-high-speed-can-system-basis-chip%3AUJA1169ATK%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fproducts%2Fpower-management%2Fpmics-and-sbcs%2Fmini-sbcs%2Fmini-high-speed-can-system-basis-chip%3AUJA1169ATK%3C%2FA%3E%20%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%E6%95%AC%E7%A4%BC%EF%BC%8C%3C%2FP%3E%0A%3CP%3Ecisvmierlo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1558599%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1558599%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E8%A7%A3%E7%AD%94%E3%80%82%3C%2FP%3E%3CP%3E%E9%82%A3%E4%B9%88%EF%BC%8C%E5%A6%82%E6%9E%9C%E7%94%B5%E6%B1%A0%E5%9C%A8%E5%AD%98%E5%82%A8%E4%B8%AD%EF%BC%8C%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%20%E5%A4%84%E4%BA%8E%20DEEPSLEEP%20%E7%8A%B6%E6%80%81%EF%BC%8C%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%20%E8%83%BD%E5%90%A6%E6%A3%80%E6%B5%8B%E5%88%B0%E8%BE%93%E5%87%BA%E4%BD%95%E6%97%B6%E8%BF%9E%E6%8E%A5%E4%BB%A5%E6%81%A2%E5%A4%8D%E6%AD%A3%E5%B8%B8%EF%BC%8C%E8%BF%98%E6%98%AF%E6%8C%89%E4%B8%8B%E6%8C%89%E9%92%AE%E6%98%AF%E9%80%80%E5%87%BA%20DEEPSLEEP%20%E7%9A%84%E5%94%AF%E4%B8%80%E5%87%BA%E8%B7%AF%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1558555%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1558555%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F196312%22%20target%3D%22_blank%22%3E%40OGUZ1%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E6%88%91%E6%83%B3%E5%91%8A%E8%AF%89%E4%BD%A0%EF%BC%8C%E9%80%82%E7%94%A8%E4%BA%8E%20S32K1xx%20%E7%9A%84%E6%81%A9%E6%99%BA%E6%B5%A6%E5%9F%BA%E4%BA%8E%E6%A8%A1%E5%9E%8B%E7%9A%84%E8%AE%BE%E8%AE%A1%E5%B7%A5%E5%85%B7%E7%AE%B1%20(MBDT)%20%E2%80%94%E2%80%94%E7%89%88%E6%9C%AC%204.3.0%20%E7%8E%B0%E5%9C%A8%E6%94%AF%E6%8C%81%20RDDRONE-BMS772%20%E6%9D%BF%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%BB%A5%E4%B8%8B%E6%98%AF%3CSPAN%3E%E4%BA%A7%E5%93%81%E7%89%88%E6%9C%AC%E5%85%AC%E5%91%8A%EF%BC%9A%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Model-Based-Design-Tools%2FNXP-Model-Based-Design-Toolbox-for-S32K1xx-MCUs-version-4-3-0%2Fta-p%2F1549163%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Model-Based-Design-Tools%2FNXP-Model-Based-Design-Toolbox-for-S32K1xx-MCUs-version-4-3-0%2Fta-p%2F1549163%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%81%A9%E6%99%BA%E6%B5%A6MBDT%E5%8C%85%E6%8B%AC%E4%B8%80%E4%B8%AA%E9%9B%86%E6%88%90%E7%9A%84Simulink%20%3CSUP%3E%C2%AE%3C%2FSUP%3E%20%E5%B5%8C%E5%85%A5%E5%BC%8F%E7%9B%AE%E6%A0%87%EF%BC%8C%E6%94%AF%E6%8C%81%E6%81%A9%E6%99%BA%E6%B5%A6%E5%BE%AE%E6%8E%A7%E5%88%B6%E5%99%A8%E8%BF%9B%E8%A1%8C%E7%9B%B4%E6%8E%A5%E5%BF%AB%E9%80%9F%E5%8E%9F%E5%9E%8B%E8%AE%BE%E8%AE%A1%EF%BC%8C%E5%B9%B6%E5%86%85%E7%BD%AE%E4%BA%86%E5%AF%B9%E8%BD%AF%E4%BB%B6%E5%92%8C%E5%A4%84%E7%90%86%E5%99%A8%E5%9C%A8%E7%8E%AF%EF%BC%88SIL%20%E5%92%8C%20PIL%EF%BC%89%E5%BC%80%E5%8F%91%E7%9A%84%E6%94%AF%E6%8C%81%E3%80%82%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fautomotive-software-and-tools%2Fmodel-based-design-toolbox-mbdt%3AMBDT%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdesign%2Fautomotive-software-and-tools%2Fmodel-based-design-toolbox-mbdt%3AMBDT%3C%2FA%3E%20%3C%2FP%3E%0A%3CP%3E%E8%B0%A8%E8%87%B4%E9%97%AE%E5%80%99%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1558534%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1558534%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F209164%22%20target%3D%22_blank%22%3E%40Ch_Han%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E6%9C%89%E5%85%B3%20%E7%89%88%E6%9C%AC%E8%AF%B4%E6%98%8E%EF%BC%8C%3C%2FSPAN%3E%3CSPAN%3E%20%E8%AF%B7%E5%8F%82%E9%98%85%3C%2FSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%3CA%20title%3D%22https%3A%2F%2Fgithub.com%2Fnxphovergames%2Frddrone-bms772%2F%22%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2F%22%20target%3D%22_blank%22%20rel%3D%22noopener%20noreferrer%20nofollow%22%3E%20https%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2F%20%E3%80%82%E8%BF%99%E6%8F%8F%E8%BF%B0%E4%BA%86%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%E7%A4%BA%E4%BE%8B%E8%BD%AF%E4%BB%B6%E7%9A%84%E7%8A%B6%E6%80%81%E6%9C%BA%20%E3%80%82%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E7%9D%A1%E7%9C%A0%E7%8A%B6%E6%80%81%E4%B8%8D%E7%94%A8%E4%BA%8E%E5%AD%98%E5%82%A8%EF%BC%8C%E5%9B%A0%E4%B8%BA%E5%9C%A8%E6%9C%AC%E7%A4%BA%E4%BE%8B%E4%B8%AD%EF%BC%8C%E5%9C%A8%E6%AD%A4%E7%9D%A1%E7%9C%A0%E7%8A%B6%E6%80%81%E4%B8%8B%EF%BC%8C%E8%BE%93%E5%87%BA%E5%8A%9F%E7%8E%87%E4%BB%8D%E5%A4%84%E4%BA%8E%E5%90%AF%E7%94%A8%E7%8A%B6%E6%80%81%E3%80%82%E5%9C%A8%E5%AD%98%E5%82%A8%E6%96%B9%E9%9D%A2%EF%BC%8C%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%E7%A1%AE%E5%AE%9E%E5%BA%94%E8%AF%A5%E8%BF%9B%E5%85%A5DEEPSLEEP%E7%8A%B6%E6%80%81%EF%BC%8C%E5%9C%A8%E8%AF%A5%E7%8A%B6%E6%80%81%E4%B8%8B%EF%BC%8C%E8%BE%93%E5%87%BA%E5%8A%9F%E7%8E%87%E8%A2%AB%E7%A6%81%E7%94%A8%EF%BC%88%E7%94%B5%E6%BA%90%E5%BC%80%E5%85%B3%E5%A4%84%E4%BA%8E%E6%89%93%E5%BC%80%E7%8A%B6%E6%80%81%EF%BC%89%EF%BC%8C%E7%94%B5%E6%B5%81%E5%B0%BD%E5%8F%AF%E8%83%BD%E5%B0%8F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E5%9C%A8%E7%89%88%E6%9C%AC%E8%AF%B4%E6%98%8E%E7%9A%84%E7%AC%AC%208%20%E7%AB%A0%E4%B8%AD%EF%BC%8C%E6%8F%8F%E8%BF%B0%E4%BA%86%E6%8E%A7%E5%88%B6%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%E7%9A%84%E5%8F%82%E6%95%B0%E3%80%82%E5%A6%82%E6%9E%9C%E5%B0%86%E5%8F%82%E6%95%B0%20%22%E8%87%AA%E6%94%BE%E7%94%B5%E4%BD%BF%E8%83%BD%20%22%E8%AE%BE%E7%BD%AE%E4%B8%BA%200%EF%BC%8C%E5%88%99%E5%8F%AF%E4%BB%A5%E5%9C%A8%E4%B8%8D%E5%B0%86%E7%94%B5%E6%B1%A0%E5%8D%95%E5%85%83%E6%94%BE%E7%94%B5%E8%87%B3%E5%AD%98%E5%82%A8%E7%94%B5%E5%8E%8B%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E8%BF%9B%E5%85%A5%20DEEPSLEEP%20%E7%8A%B6%E6%80%81%E3%80%82%E8%AF%B7%E6%B3%A8%E6%84%8F%EF%BC%8C%E5%A6%82%E6%9E%9C%E7%94%B5%E6%B1%A0%E9%95%BF%E6%97%B6%E9%97%B4%E5%A4%84%E4%BA%8E%E9%AB%98%E7%94%B5%E5%8E%8B%E4%B8%8B%EF%BC%8C%E8%BF%99%E5%8F%AF%E8%83%BD%E5%AF%B9%E7%94%B5%E6%B1%A0%E4%B8%8D%E5%88%A9%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%9C%A8%E8%87%AA%E6%94%BE%E7%94%B5%E7%8A%B6%E6%80%81%E4%B8%8B%EF%BC%8C%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%E5%B0%86%E4%BD%BF%E7%94%A8%E5%B9%B3%E8%A1%A1%E7%94%B5%E6%B5%81%E5%B0%86%E6%89%80%E6%9C%89%E7%94%B5%E6%B1%A0%E6%94%BE%E7%94%B5%EF%BC%8C%E4%BD%BF%E5%85%B6%E4%BD%8E%E4%BA%8E%E8%AE%BE%E5%AE%9A%E7%9A%84%E5%AD%98%E5%82%A8%E7%94%B5%E5%8E%8B%EF%BC%88%E6%9C%89%E4%BD%99%E9%87%8F%EF%BC%89%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%9C%A8%E6%9C%AC%E7%A4%BA%E4%BE%8B%E4%B8%AD%EF%BC%8C%E5%9C%A8%20SLEEP%20%E7%8A%B6%E6%80%81%E4%B8%8B%EF%BC%8C%E5%BC%80%E5%85%B3%E5%A7%8B%E7%BB%88%E5%A4%84%E4%BA%8E%E5%85%B3%E9%97%AD%E7%8A%B6%E6%80%81%EF%BC%8C%E4%BB%8E%E8%80%8C%E5%90%AF%E7%94%A8%E8%BE%93%E5%87%BA%E5%8A%9F%E7%8E%87%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E5%AE%83%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%E6%B5%8B%E9%87%8F%E7%94%B5%E6%B5%81%E6%9D%A5%E6%A3%80%E6%B5%8B%E8%B4%9F%E8%BD%BD%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%88%91%E9%80%9A%E5%B8%B8%E4%BD%BF%E7%94%A8%E5%AE%9E%E9%AA%8C%E5%AE%A4%E7%94%B5%E6%BA%90%E4%B8%BA%E7%94%B5%E6%B1%A0%E5%85%85%E7%94%B5%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%B3%A8%EF%BC%9A%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%BC%80%E5%8F%91%E8%87%AA%E5%B7%B1%E7%9A%84%E8%BD%AF%E4%BB%B6%EF%BC%8C%E6%88%96%E6%A0%B9%E6%8D%AE%E8%87%AA%E5%B7%B1%E7%9A%84%E9%9C%80%E8%A6%81%EF%BC%8C%E5%9C%A8%3CA%20title%3D%22https%3A%2F%2Fgithub.com%2Fnxphovergames%2Frddrone-bms772%2F%22%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2F%22%20target%3D%22_blank%22%20rel%3D%22noopener%20noreferrer%20nofollow%22%3E%20https%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2F%20%E4%B8%8A%E7%9A%84%E5%BC%80%E6%94%BE%E6%BA%90%E4%BB%A3%E7%A0%81%E7%A4%BA%E4%BE%8B%E7%9A%84%E5%9F%BA%E7%A1%80%E4%B8%8A%E5%AF%B9%3C%2FA%3E%20SW%20%E8%BF%9B%E8%A1%8C%E6%94%B9%E7%BC%96%20%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%B8%8C%E6%9C%9B%E8%BF%99%E8%83%BD%E5%9B%9E%E7%AD%94%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%B0%A8%E8%87%B4%E9%97%AE%E5%80%99%E3%80%81%3C%2FP%3E%0A%3CP%3Ecisvmierlo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1558484%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1558484%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F15914%22%20target%3D%22_blank%22%3E%40iaingalloway%3C%2FA%3E%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E6%88%91%E8%AE%A1%E5%88%92%E5%B0%86%20BMS772%20%E4%B8%8E%206s%20LiPo%20%E7%94%B5%E6%B1%A0%E4%B8%80%E8%B5%B7%E4%BD%BF%E7%94%A8%EF%BC%8C%E5%B9%B6%E6%9C%89%E5%85%B3%E4%BA%8E%E5%85%85%E6%94%BE%E7%94%B5%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E1-%20%E6%98%AF%E5%90%A6%E6%9C%89%E5%8A%9E%E6%B3%95%E5%9C%A8%E4%B8%8D%E6%94%BE%E7%94%B5%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E5%82%A8%E5%AD%98%E7%94%B5%E6%B1%A0%EF%BC%9F%E6%88%91%E6%98%8E%E7%99%BD%EF%BC%8C%E5%9C%A8%E8%BF%9B%E5%85%A5%E5%A4%A7%E9%97%A8%E6%89%93%E5%BC%80%E7%9A%84DEEPSLEEP%E7%8A%B6%E6%80%81%E4%B9%8B%E5%89%8D%EF%BC%8C%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%E5%BF%85%E9%A1%BB%E5%A4%84%E4%BA%8E%E8%87%AA%E6%94%BE%E7%94%B5%E7%8A%B6%E6%80%81%EF%BC%9B%E6%88%96%E8%80%85%E5%A6%82%E6%9E%9C%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%E5%A4%84%E4%BA%8ESLEEP%E7%8A%B6%E6%80%81%EF%BC%8C%E5%88%99%E5%A4%A7%E9%97%A8%E5%85%B3%E9%97%AD%EF%BC%8C%E8%BF%99%E4%B9%9F%E4%BC%9A%E5%AF%BC%E8%87%B4%E6%94%BE%E7%94%B5%E3%80%82%3C%2FP%3E%3CP%3E2-%20%E8%87%AA%E6%94%BE%E7%94%B5%E7%9A%84%E7%89%A9%E7%90%86%E8%BF%87%E7%A8%8B%E6%98%AF%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FP%3E%3CP%3E3-%20%E6%9C%89%E6%B2%A1%E6%9C%89%E6%83%B3%E8%BF%87%E9%80%9A%E8%BF%87%20CAN%20%E6%B5%8B%E9%87%8F%E9%98%BB%E6%8A%97%E6%9D%A5%E6%A3%80%E6%B5%8B%E6%98%AF%E5%90%A6%E8%BF%9E%E6%8E%A5%E4%BA%86%E8%BE%93%E5%87%BA%EF%BC%9F%E4%BE%8B%E5%A6%82%EF%BC%8C%E8%A6%81%E7%9F%A5%E9%81%93%E5%9C%A8%E7%9D%A1%E7%9C%A0%E7%8A%B6%E6%80%81%E4%B8%8B%E9%97%B8%E9%97%A8%E5%BA%94%E8%AF%A5%E6%89%93%E5%BC%80%E8%BF%98%E6%98%AF%E5%85%B3%E9%97%AD%E3%80%82%3C%2FP%3E%3CP%3E4-%20%E6%98%AF%E5%90%A6%E6%9C%89%E6%8E%A8%E8%8D%90%E7%9A%84%E5%85%85%E7%94%B5%E5%99%A8%E5%8F%AF%E4%BB%A5%E7%94%A8%E6%9C%89%E9%99%90%E7%9A%84%E7%94%B5%E6%B5%81%E4%B8%BA%E7%94%B5%E6%B1%A0%E5%85%85%E7%94%B5%EF%BC%9F%E6%88%96%E8%80%85%E8%87%B3%E5%B0%91%E6%82%A8%E9%80%9A%E5%B8%B8%E4%BD%BF%E7%94%A8%E5%93%AA%E4%B8%80%E7%A7%8D%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1434088%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1434088%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F198622%22%20target%3D%22_blank%22%3E%40vikrantj%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E6%97%A2%E7%84%B6%E6%82%A8%E6%98%AF%E4%B8%BA%E5%AD%A6%E6%A0%A1%E9%A1%B9%E7%9B%AE%E5%81%9A%E8%BF%99%E4%B8%AA%EF%BC%8C%E6%88%91%E6%83%B3%E6%82%A8%E5%8F%AF%E4%BB%A5%E8%B4%AD%E4%B9%B0%20J-Link%20EDU%EF%BC%88%E8%BF%B7%E4%BD%A0%E5%9E%8B%EF%BC%89%E3%80%82%3CBR%20%2F%3E%E8%BF%99%E6%98%AF%E6%99%AE%E9%80%9A%20J-Link%20%E7%9A%84%E5%BB%89%E4%BB%B7%E7%89%88%EF%BC%8C%E7%94%A8%E4%BA%8E%E6%95%99%E8%82%B2%E7%9B%AE%E7%9A%84%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%BB%A5%E4%B8%8B%E6%98%AF%E5%A6%82%E4%BD%95%E4%BD%BF%E7%94%A8%20J-Link%20EDU%20(mini)%20%E9%97%AA%E5%AD%98%20RDDRONE-BMS772%20%E7%9A%84%E6%8C%87%E5%8D%97%3CA%20href%3D%22https%3A%2F%2Fnxp.gitbook.io%2Fnxpmobilerobotics%2Fflashing-guide%2Fflashing-hovergames-boards%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%EF%BC%9A%20%3C%2FA%3E%3CA%20href%3D%22https%3A%2F%2Fnxp.gitbook.io%2Fnxpmobilerobotics%2Fflashing-guide%2Fflashing-hovergames-boards%E3%80%82%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fnxp.gitbook.io%2Fnxpmobilerobotics%2Fflashing-guide%2Fflashing-hovergames-boards%E3%80%82%3C%2FA%3E%20%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%BF%99%E5%AF%B9%E4%BD%A0%E6%9C%89%E5%B8%AE%E5%8A%A9%E5%90%97%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%B0%A8%E8%87%B4%E9%97%AE%E5%80%99%E3%80%81%3C%2FP%3E%3CP%3E%E8%A5%BF%E6%96%AF-%E8%8C%83%E7%B1%B3%E8%80%B6%E7%BD%97%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1433972%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1433972%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F198622%22%20target%3D%22_blank%22%3E%40vikrantj%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E6%88%91%E8%BF%98%E6%B2%A1%E6%9C%89%E6%9C%BA%E4%BC%9A%E4%BD%BF%E7%94%A8%E8%BF%99%E4%B8%AA%E6%9D%BF%E3%80%82%E4%BD%86%E6%98%AF%E7%9C%8B%E4%B8%80%E4%B8%8B%E5%8E%9F%E7%90%86%E5%9B%BE%EF%BC%8C%E5%9C%A8%E4%B8%8D%E4%B8%80%E7%9B%B4%E4%BD%BF%E7%94%A8%20JTAG%20%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E7%9B%B4%E6%8E%A5%E4%BB%8E%20Simulink%20%E5%88%B7%E6%96%B0%E8%BF%99%E5%9D%97%E6%9D%BF%E7%9A%84%E6%9C%80%E7%AE%80%E5%8D%95%E6%96%B9%E6%B3%95%E6%98%AF%E9%80%9A%E8%BF%87%20UART%20%E4%BD%BF%E7%94%A8%20RappID%20%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E3%80%82%E5%BD%93%E7%84%B6%EF%BC%8C%E6%82%A8%E5%BF%85%E9%A1%BB%E4%BD%BF%E7%94%A8%20JTAG%20%E9%97%AA%E5%AD%98%E4%B8%80%E6%AC%A1%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%EF%BC%8C%E4%BD%86%E4%B8%80%E6%97%A6%E5%B0%86%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E5%86%99%E5%85%A5%E9%97%AA%E5%AD%98%EF%BC%8C%E6%82%A8%E5%B0%B1%E5%8F%AF%E4%BB%A5%E7%9B%B4%E6%8E%A5%E4%BB%8E%20Simulink%20%E4%BD%BF%E7%94%A8%E4%B8%B2%E8%A1%8C%E6%8E%A5%E5%8F%A3%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%9C%A8%E5%B7%A5%E5%85%B7%E7%AE%B1%E4%B8%AD%E6%89%BE%E5%88%B0%E5%90%88%E9%80%82%E7%9A%84%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%EF%BC%8C%E5%9C%A8%20tools%5CBootLoader%5CRBF_Files%20%E4%B8%8B%E6%89%BE%E5%88%B0%20S32K144_S32DS_UART1_CAN0.rbf%EF%BC%8C%E5%AE%83%E9%80%9A%E8%BF%87%20DCD-LZ%20%E4%BD%BF%E7%94%A8%E5%BC%95%E8%84%9A%20PTC6%20%E5%92%8C%20PTC7%E3%80%82%E5%9C%A8%E8%BF%99%E9%87%8C%EF%BC%8C%E4%BD%A0%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E5%A4%96%E7%BD%AEUSB2%E4%B8%B2%E8%A1%8C%E5%8F%98%E6%B5%81%E5%99%A8%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E5%A4%96%EF%BC%8CCAN0%20%E5%8F%AF%E7%94%A8%E4%BA%8E%E5%9C%A8%E6%9D%BF%E4%B8%8A%E9%83%A8%E7%BD%B2%E4%BB%A3%E7%A0%81%EF%BC%8C%E4%BD%86%E6%82%A8%E9%9C%80%E8%A6%81%E4%BD%BF%E7%94%A8%20RappID%20%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E5%92%8C%E5%85%BC%E5%AE%B9%E7%9A%84%20CAN%20%E5%B7%A5%E5%85%B7%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%20%22%E5%BA%8F%E5%88%97%20%22%E5%AF%B9%E6%82%A8%E6%9D%A5%E8%AF%B4%E6%98%AF%E4%B8%AA%E4%B8%8D%E9%94%99%E7%9A%84%E9%80%89%E6%8B%A9%EF%BC%8C%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%0A%3CP%3EMarius%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1433750%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1433750%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%20%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20RDDRONE-BMS772%20%E6%9D%A5%E5%88%B6%E9%80%A0%E4%B8%80%E4%B8%AA%203s%20%E7%9A%84%E9%94%82%E7%A6%BB%E5%AD%90%E7%94%B5%E6%B1%A0%E5%BE%AA%E7%8E%AF%E5%99%A8%E3%80%82%E6%88%91%E5%B8%8C%E6%9C%9B%E8%83%BD%E5%A4%9F%E4%BD%BF%E7%94%A8%20CAN%20%E6%80%BB%E7%BA%BF%E5%B0%86%E7%A8%8B%E5%BA%8F%E9%97%AA%E5%AD%98%E5%88%B0%E6%9D%BF%E4%B8%8A%E7%9A%84%20S32K%E3%80%82%E6%88%91%E6%83%B3%E7%9F%A5%E9%81%93%E6%98%AF%E5%90%A6%E6%9C%89%E5%8A%9E%E6%B3%95%E5%81%9A%E5%88%B0%E8%BF%99%E4%B8%80%E7%82%B9%E3%80%82%E8%BF%98%E6%98%AF%E5%8F%AA%E6%9C%89%E4%BD%BF%E7%94%A8%E8%B0%83%E8%AF%95%E5%99%A8%E6%89%8D%E8%83%BD%E9%97%AA%E5%AD%98%E7%A8%8B%E5%BA%8F%EF%BC%9F%E5%A6%82%E6%9E%9C%E6%82%A8%E6%9C%89%E4%BB%BB%E4%BD%95%E5%85%B6%E4%BB%96%E5%BB%BA%E8%AE%AE%EF%BC%8C%E6%88%91%E5%B0%86%E4%B8%8D%E8%83%9C%E6%84%9F%E6%BF%80%E3%80%82%E8%BF%99%E6%98%AF%E4%B8%80%E4%B8%AA%E5%AD%A6%E6%A0%A1%E9%A1%B9%E7%9B%AE%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%88%91%E9%9C%80%E8%A6%81%E9%99%8D%E4%BD%8E%E6%88%90%E6%9C%AC%EF%BC%88%E5%92%8C%E5%A4%8D%E6%9D%82%E7%A8%8B%E5%BA%A6%EF%BC%89%E3%80%82%20%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F196312%22%20target%3D%22_blank%22%3E%40OGUZ1%3C%2FA%3E%2C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F15914%22%20target%3D%22_blank%22%3E%40iaingalloway%3C%2FA%3E%2C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F72088%22%20target%3D%22_blank%22%3E%40mariuslucianand%3C%2FA%3E%E6%88%91%E5%BE%88%E6%83%B3%E7%9F%A5%E9%81%93%E4%BD%A0%E4%BB%AC%E5%AF%B9%E6%AD%A4%E7%9A%84%E7%9C%8B%E6%B3%95%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1420015%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1420015%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%3C%2FA%3E%3C%2FP%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E4%BD%A0%E7%9A%84%E7%AD%94%E5%A4%8D%E3%80%82%3C%2FP%3E%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20SPI0%EF%BC%8C%E4%BD%86%E7%9C%8B%E4%B8%8D%E5%88%B0%E4%BB%BB%E4%BD%95%E6%95%88%E6%9E%9C%E3%80%82%E6%88%91%E6%80%BB%E6%98%AF%E4%BB%8E%20V2%20%E5%BC%95%E8%84%9A%E8%AF%BB%E5%87%BA%E7%B1%BB%E4%BC%BC%202.7%20%E4%BC%8F%E7%9A%84%E7%94%B5%E5%8E%8B%E3%80%82%E6%88%91%E4%B8%80%E7%9B%B4%E4%BB%8E%20V1%20%E5%BC%95%E8%84%9A%E8%AF%BB%E5%8F%96%203.3%20%E4%BC%8F%E7%94%B5%E5%8E%8B%E3%80%82%E5%BD%93%E6%88%91%E6%8C%89%E4%B8%8BRESET%E6%8C%89%E9%92%AE%E6%97%B6%EF%BC%8C%E6%88%91%E4%BB%8D%E7%84%B6%E8%AF%BB%E5%8F%96%E7%9B%B8%E5%90%8C%E7%9A%84%E5%80%BC%E3%80%82%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%E8%BF%99%E6%98%AF%E4%BB%80%E4%B9%88%E6%84%8F%E6%80%9D%E3%80%82%E6%88%91%E5%B0%9D%E8%AF%95%E4%BA%86%E6%89%80%E6%9C%89%E9%85%8D%E7%BD%AE%E3%80%82%E5%9C%A8%20SBC%20%E4%B8%AD%EF%BC%8CVbat%20%E5%92%8C%20Wake%20%E5%BC%95%E8%84%9A%E7%9A%84%E5%80%BC%E7%9B%B8%E5%90%8C%E3%80%82%3CBR%20%2F%3E%E5%BD%93%E6%88%91%E6%8C%89%E4%B8%8BRESET%E9%94%AE%E6%97%B6%EF%BC%8C%E5%94%A4%E9%86%92%E5%BC%95%E8%84%9A%E4%BC%9A%E9%99%8D%E8%87%B3%200%E3%80%823.3%20%E4%BC%8F%E7%89%B9%E6%80%BB%E6%98%AF%E6%B5%81%E5%90%91%E5%A4%84%E7%90%86%E5%99%A8%E7%9A%84%20SBCWake%20%E5%BC%95%E8%84%9A%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F72088%22%20target%3D%22_blank%22%3E%3CFONT%3E%40mariuslucianand%3C%2FFONT%3E%3C%2FA%3E%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F176411%22%20target%3D%22_blank%22%3E%3CFONT%3E%40constantinrazva%3C%2FFONT%3E%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1419888%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1419888%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F196312%22%20target%3D%22_blank%22%3E%40OGUZ1%3C%2FA%3E%E3%80%81%20%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E5%BE%88%E6%8A%B1%E6%AD%89%EF%BC%8C%E6%88%91%E6%B2%A1%E6%9C%89%E5%9C%A8%20Matlab%20%2F%20Simulink%20%E4%B8%AD%E4%BD%BF%E7%94%A8%20MBDT%20%E7%9A%84%E7%BB%8F%E9%AA%8C%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E5%9C%A8%E5%9F%BA%E4%BA%8E%E6%A8%A1%E5%9E%8B%E7%9A%84%E8%AE%BE%E8%AE%A1%E5%B7%A5%E5%85%B7%E7%AE%B1%E5%92%8C%20SBC%205V%20%E9%97%AE%E9%A2%98%E4%B8%8A%E6%8F%90%E4%BE%9B%E7%9A%84%E5%B8%AE%E5%8A%A9%E3%80%82%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F72088%22%20target%3D%22_blank%22%3E%40mariuslucianand%3C%2FA%3E%E4%BD%A0%E8%83%BD%E5%B8%AE%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F196312%22%20target%3D%22_blank%22%3E%40OGUZ1%3C%2FA%3E%E8%BF%9B%E4%B8%80%E6%AD%A5%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3EUJA1169%20%E9%85%8D%E7%BD%AE%E5%8F%AF%E8%83%BD%E4%BB%85%E9%80%82%E7%94%A8%E4%BA%8E%20S32K144%20%E5%BC%80%E5%8F%91%E6%9D%BF%EF%BC%8C%E8%BF%99%E5%8F%AF%E8%83%BD%E4%B8%8E%20RDDRONE-BMS772%20%E4%B8%8A%E5%BA%94%E4%BD%BF%E7%94%A8%E7%9A%84%E9%85%8D%E7%BD%AE%E4%B8%8D%E5%90%8C%E3%80%82%3CBR%20%2F%3E%E4%BE%8B%E5%A6%82%EF%BC%8C%E5%9C%A8%20S32k144%20evb%20%E4%B8%8A%EF%BC%8CLPSPI1%20%E7%94%A8%E4%BA%8E%E4%B8%8E%20SBC%20%E9%80%9A%E4%BF%A1%E3%80%82%3CBR%20%2F%3E%E5%9C%A8%20RDDRONE-BMS772%20%E4%B8%8A%E4%BD%BF%E7%94%A8%20LPSPI0%E3%80%82%3CBR%20%2F%3E%E6%82%A8%E8%83%BD%E5%90%A6%E9%AA%8C%E8%AF%81%E6%98%AF%E5%90%A6%E4%BD%BF%E7%94%A8%E4%BA%86%E6%AD%A3%E7%A1%AE%E7%9A%84%20SPI%20%E6%80%BB%E7%BA%BF%200%20%E4%B8%8E%20SBC%20%E9%80%9A%E4%BF%A1%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%A0%B9%E6%8D%AE%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F176411%22%20target%3D%22_blank%22%3E%40constantinrazva%3C%2FA%3E%20%E7%9A%84%E8%AF%B4%E6%B3%95%EF%BC%8CSBC%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E4%BD%8D%E4%BA%8E%E5%A4%96%E9%83%A8%E8%AE%BE%E5%A4%87%E4%B8%AD%E3%80%82%3CBR%20%2F%3E%E8%83%BD%E5%90%A6%E7%A1%AE%E8%AE%A4%E6%82%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E8%BF%99%E4%B8%AA%20SBC%20%E5%9D%97%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E6%9C%89%E5%85%B4%E8%B6%A3%E4%BA%86%E8%A7%A3%E5%A6%82%E4%BD%95%E4%BD%BF%E7%94%A8%20C%20%E4%BB%A3%E7%A0%81%E8%AE%BE%E7%BD%AE%20SBC%EF%BC%8C%E4%B8%8B%E9%9D%A2%E6%98%AF%E4%B8%80%E4%B8%AA%E7%A4%BA%E4%BE%8B%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2Fblob%2Fmain%2Fsrc%2Fsbc.c%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%EF%BC%9A%20https%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2Fblob%2Fmain%2Fsrc%2Fsbc.c%3C%2FA%3E%3CBR%20%2F%3E%E8%BF%99%E6%A0%B7%EF%BC%8C%E5%9C%A8%20SBC%20%E6%AD%A3%E5%B8%B8%E8%BF%90%E8%A1%8C%E6%97%B6%EF%BC%8C5V%20%E7%94%B5%E5%8E%8B%E5%B0%B1%E8%83%BD%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E3%80%82%20%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E5%85%B3%E4%BA%8E%E6%98%BE%E7%A4%BA%E5%99%A8%EF%BC%8C%E6%88%91%E4%BB%AC%E6%8F%90%E4%BE%9B%E4%BA%86%E5%A6%82%E4%BD%95%E5%9C%A8%20NuttX%20%E5%AE%9E%E6%97%B6%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E4%B8%AD%E4%BD%BF%E7%94%A8%E6%98%BE%E7%A4%BA%E5%99%A8%E7%9A%84%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%E3%80%82%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2Fblob%2Fmain%2Fsrc%2Fdisplay.c%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E8%A7%81%3C%2FA%3E%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2Fblob%2Fmain%2Fsrc%2Fdisplay.c%E3%80%82%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2Fblob%2Fmain%2Fsrc%2Fdisplay.c%E3%80%82%3C%2FA%3E%20%3CBR%20%2F%3E%E5%AE%83%E4%BD%BF%E7%94%A8%20NuttX%20%E5%AE%9E%E6%97%B6%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E4%B8%AD%E7%9A%84%E5%AD%97%E7%AC%A6%E5%92%8C%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%98%BE%E7%A4%BA%E5%99%A8%E6%9C%AC%E8%BA%AB%E6%98%AF%E4%B8%80%E4%B8%AA%20SSD1306%20I2C%20%E6%98%BE%E7%A4%BA%E5%99%A8%EF%BC%8C%E5%8F%AF%E5%9C%A8%205V%20%E5%92%8C%203.3V%20%E7%94%B5%E5%8E%8B%E4%B8%8B%E5%B7%A5%E4%BD%9C%E3%80%82%3CBR%20%2F%3E%E6%88%91%E7%9B%B8%E4%BF%A1%E6%9C%89%E5%BE%88%E5%A4%9A%20C%20%E4%BE%8B%E5%AD%90%E5%8F%AF%E4%BB%A5%E8%AF%B4%E6%98%8E%E5%A6%82%E4%BD%95%E4%BD%BF%E7%94%A8%E8%BF%99%E7%A7%8D%E6%98%BE%E7%A4%BA%E5%B1%8F%E3%80%82%20%3CBR%20%2F%3E%E4%BE%8B%E5%A6%82%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fadafruit%2FAdafruit_SSD1306%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%EF%BC%9A%3C%2FA%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fadafruit%2FAdafruit_SSD1306%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fadafruit%2FAdafruit_SSD1306%3C%2FA%3E%20%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%AF%B9%E4%BA%8E%20MATLAB%EF%BC%8C%E4%BB%A5%E4%B8%8B%E8%B5%84%E6%96%99%E6%88%96%E8%AE%B8%E4%B9%9F%E8%83%BD%E6%8F%90%E4%BE%9B%E5%B8%AE%E5%8A%A9%3CA%20href%3D%22https%3A%2F%2Fnl.mathworks.com%2Fmatlabcentral%2Ffileexchange%2F50766-ssd1306-hex-bitmap-creator%3Fs_tid%3Dsrchtitle%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%EF%BC%9A%3C%2FA%3E%3CA%20href%3D%22https%3A%2F%2Fnl.mathworks.com%2Fmatlabcentral%2Ffileexchange%2F50766-ssd1306-hex-bitmap-creator%3Fs_tid%3Dsrchtitle%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fnl.mathworks.com%2Fmatlabcentral%2Ffileexchange%2F50766-ssd1306-hex-bitmap-creator%3Fs_tid%3Dsrchtitle%3C%2FA%3E%3CA%20href%3D%22https%3A%2F%2Fnl.mathworks.com%2Fmatlabcentral%2Fanswers%2F512483-how-to-control-ssd1306-128x32-oled-display-in-matlab%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E6%88%96%3C%2FA%3E%3CA%20href%3D%22https%3A%2F%2Fnl.mathworks.com%2Fmatlabcentral%2Fanswers%2F512483-how-to-control-ssd1306-128x32-oled-display-in-matlab%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fnl.mathworks.com%2Fmatlabcentral%2Fanswers%2F512483-how-to-control-ssd1306-128x32-oled-display-in-matlab%3C%2FA%3E%20%3C%2FP%3E%0A%3CP%3E%E8%B0%A8%E8%87%B4%E9%97%AE%E5%80%99%EF%BC%8C%E5%91%A8%E6%9C%AB%E6%84%89%E5%BF%AB%EF%BC%8C%3CBR%20%2F%3E%3CBR%20%2F%3ECis%20van%20Mierlo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1419827%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1419827%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F15914%22%20target%3D%22_blank%22%3E%20%40iaingalloway%3C%2FA%3E%3CSPAN%3E%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%20%40cisvmierlo%3C%2FA%3E%3CSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%88%91%E6%83%B3%E9%80%9A%E8%BF%87%20Matlab%2FSimulink%20%E8%BF%90%E8%A1%8C%E5%B1%8F%E5%B9%95%E3%80%82%E6%82%A8%E8%83%BD%E4%B8%BE%E4%B8%AA%E4%BE%8B%E5%AD%90%E5%90%97%EF%BC%9F%E6%88%91%E5%8F%AF%E4%BB%A5%E7%94%A8%20Matlab%2FSimulink%20%E6%9F%A5%E7%9C%8B%E7%94%B5%E6%B1%A0%E5%80%BC%E3%80%82%E6%88%91%E6%83%B3%E4%BD%BF%E7%94%A8%20CAN%20%E9%80%9A%E4%BF%A1%EF%BC%8C%E4%BD%86%E4%BB%8D%E6%97%A0%E6%B3%95%E4%BB%8E%20SBC%20%E8%8E%B7%E5%BE%97%205V%20%E7%94%B5%E5%8E%8B%E3%80%82%E6%88%91%E4%BB%8D%E7%84%B6%E6%97%A0%E6%B3%95%E4%BB%8E%20SBC%20%E8%8E%B7%E5%BE%97%205V%20%E8%BE%93%E5%87%BA%E3%80%82%E4%BD%A0%E5%AF%B9%E6%88%91%E6%84%9F%E5%85%B4%E8%B6%A3%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1411597%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1411597%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F196312%22%20target%3D%22_blank%22%3E%40OGUZ1%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E6%9C%89%E5%85%B3%20NuttX%20RDDRONE-BMS772%20%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%20%E7%A4%BA%E4%BE%8B%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85%3CSPAN%3E%3C%2FSPAN%3E%20%3CA%20title%3D%22https%3A%2F%2Fgithub.com%2Fnxphovergames%2Frddrone-bms772%2F%22%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2F%22%20target%3D%22_blank%22%20rel%3D%22noopener%20noreferrer%20nofollow%22%3Ehttps%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2F%3C%2FA%3E%3CSPAN%3E%3C%2FSPAN%3E%E3%80%82%3CSPAN%3E%E6%96%87%E6%A1%A3%E3%80%81%E6%BA%90%E4%BB%A3%E7%A0%81%E3%80%81%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E5%92%8C%E6%89%8B%E5%86%8C%E9%83%BD%E5%8F%AF%E4%BB%A5%E5%9C%A8%E8%AF%A5%E7%BD%91%E7%AB%99%E4%B8%8A%E6%89%BE%E5%88%B0%E3%80%82%3C%2FSPAN%3E%3CSPAN%3E%20%E5%AE%83%E4%BD%BF%E7%94%A8%20%E7%AC%A6%E5%90%88%20POSIX%3C%2FSPAN%3E%3CSPAN%3E%20%E6%A0%87%E5%87%86%3C%2FSPAN%3E%3CSPAN%3E%20%E7%9A%84%20RTOS%20NuttX%E3%80%82%3C%2FSPAN%3E%3CSPAN%3E%20%E8%AF%A5%E7%A4%BA%E4%BE%8B%E5%8C%85%E5%90%AB%E8%AF%B8%E5%A6%82%20SSD1306%20%E6%98%BE%E7%A4%BA%E5%B1%8F%E6%94%AF%E6%8C%81%E5%92%8C%E5%B0%86%20SBC%20%E9%85%8D%E7%BD%AE%E4%B8%BA%205V%20%E4%B9%8B%E7%B1%BB%E7%9A%84%E5%86%85%E5%AE%B9%E3%80%82%3C%2FSPAN%3E%3CSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E4%BD%BF%E7%94%A8%20Matlab%2FSimulink%E3%80%81FREEMASTER%20%E6%88%96%E5%85%B6%E4%BB%96%E4%B8%9C%E8%A5%BF%E5%AF%B9%E6%9D%BF%E8%BF%9B%E8%A1%8C%E9%87%8D%E6%96%B0%E7%BC%96%E7%A8%8B%EF%BC%8C%E5%88%99%E5%BE%AE%E6%8E%A7%E5%88%B6%E5%99%A8%E4%B8%8A%E5%8F%AF%E8%83%BD%E4%BC%9A%E8%BF%90%E8%A1%8C%E4%B8%8D%E5%90%8C%E7%9A%84%E8%BD%AF%E4%BB%B6%EF%BC%8C%E5%9B%A0%E6%AD%A4%E5%85%B6%E8%A1%8C%E4%B8%BA%E5%92%8C%E5%8A%9F%E8%83%BD%E4%B8%8D%E6%AD%A3%E7%A1%AE%E3%80%82%3CSPAN%3E%E4%BD%A0%E5%8F%AF%E4%BB%A5%E8%87%AA%E7%94%B1%E5%9C%B0%E4%BD%BF%E7%94%A8%E4%BD%A0%E6%83%B3%E8%A6%81%E7%9A%84%EF%BC%88%E6%88%96%E5%88%B6%E4%BD%9C%E7%9A%84%EF%BC%81%EF%BC%89%E7%9A%84%E8%BD%AF%E4%BB%B6%E5%AF%B9%E8%BF%99%E4%B8%AA%E6%9D%BF%2F%E5%BE%AE%E6%8E%A7%E5%88%B6%E5%99%A8%E8%BF%9B%E8%A1%8C%E9%87%8D%E6%96%B0%E7%BC%96%E7%A8%8B%EF%BC%8C%E4%BD%86%E8%A6%81%E7%A1%AE%E4%BF%9D%E4%BD%A0%E7%9A%84%E7%BC%96%E7%A8%8B%E5%B0%B1%E6%98%AF%E4%BD%A0%E6%83%B3%E8%A6%81%E7%9A%84%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E6%83%B3%E5%88%9B%E5%BB%BA%E8%87%AA%E5%B7%B1%E7%9A%84%E8%BD%AF%E4%BB%B6%EF%BC%8C%E5%8F%AF%E4%BB%A5%E6%A0%B9%E6%8D%AE%3CSPAN%3E%20%3C%2FSPAN%3E%3CA%20title%3D%22https%3A%2F%2Fgithub.com%2Fnxphovergames%2Frddrone-bms772%2F%22%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2F%22%20target%3D%22_blank%22%20rel%3D%22noopener%20noreferrer%20nofollow%22%3Ehttps%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2F%20%E4%B8%AD%3C%2FA%3E%E7%9A%84%E8%B5%84%E6%BA%90%E5%88%9B%E5%BB%BA%E3%80%82%E8%BF%99%E5%8F%AF%E4%BB%A5%E5%B8%AE%E5%8A%A9%E4%BD%A0%E5%BC%80%E5%A7%8B%E4%BD%BF%E7%94%A8%E6%81%A9%E6%99%BA%E6%B5%A6%E5%85%83%E5%99%A8%E4%BB%B6%EF%BC%8C%E4%BE%8B%E5%A6%82SBC%EF%BC%88UJA1169%EF%BC%89%E3%80%81BCC%EF%BC%88MC33772B%EF%BC%89%E6%88%96NTAG5%20boost%20NFC%E8%8A%AF%E7%89%87%E3%80%82%E5%A6%82%E6%9E%9C%E4%BD%A0%E6%83%B3%E5%AF%B9NuttX%20%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%E7%A4%BA%E4%BE%8B%E8%BF%9B%E8%A1%8C%E7%BC%96%E7%A8%8B%EF%BC%8C%E9%82%A3%E4%B9%88%E8%AF%A5%E7%BD%91%E7%AB%99%2F%E5%AD%98%E5%82%A8%E5%BA%93%E4%B8%AD%E5%B7%B2%E7%BB%8F%E6%9C%89%E4%BA%86%E4%B8%80%E4%B8%AA%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%EF%BC%8C%E4%BD%A0%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8J-Link%E5%91%BD%E4%BB%A4%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%88%E9%80%82%E7%94%A8%E4%BA%8EWindows%EF%BC%88%E6%88%96Linux%E4%B8%8A%E7%9A%84jLinkExe%EF%BC%89%EF%BC%89%E5%92%8CJ-Link%E7%A8%8B%E5%BA%8F%E5%91%98%E8%BD%BB%E6%9D%BE%E5%9C%B0%E5%AF%B9%E5%AE%83%E8%BF%9B%E8%A1%8C%E7%BC%96%E7%A8%8B%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1410958%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1410958%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F15914%22%20target%3D%22_blank%22%3E%40iaingalloway%3C%2FA%3E%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%3C%2FA%3E%3C%2FP%3E%3CP%3E%E6%88%91%E7%94%A8%20Matlab%2FSimulink%20%E5%AF%B9%20RDDRONE-BMS772%20%E6%9D%BF%E8%BF%9B%E8%A1%8C%E4%BA%86%E7%BC%96%E7%A8%8B%E3%80%82%E6%88%91%E5%9C%A8%20FreeMaster%20%E4%B8%AD%E7%9C%8B%E5%88%B0%E4%BA%86%E6%89%80%E6%9C%89%E5%80%BC%E3%80%82%3CBR%20%2F%3E%E6%88%91%E6%9C%89%E5%87%A0%E4%B8%AA%E9%97%AE%E9%A2%98%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E1)%20%E6%88%91%E6%83%B3%E5%9C%A8%E6%98%BE%E5%8D%A1%E4%B8%8A%E8%BF%90%E8%A1%8C%20SSD1306%20%E5%B1%8F%E5%B9%95%E3%80%82%E6%88%91%E6%9B%B4%E6%8D%A2%E4%BA%86%20D34%20%E5%92%8C%20D35%20%E4%BA%8C%E6%9E%81%E7%AE%A1%E3%80%82%E5%B1%8F%E5%B9%95%E4%B8%8A%E6%98%BE%E7%A4%BA%203.3%20%E4%BC%8F%EF%BC%8C%E4%BD%86%E4%B8%8D%E5%B7%A5%E4%BD%9C%E3%80%82%E6%82%A8%E8%83%BD%E5%B8%AE%E5%BF%99%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E2)%20%E6%88%91%E4%BB%AC%E4%BB%8E%E8%BD%AF%E4%BB%B6%E4%B8%AD%E7%BB%99%E7%94%B5%E8%B7%AF%E5%8D%A1%E5%8A%9F%E7%8E%87%E6%99%B6%E4%BD%93%E7%AE%A1%E7%9A%84%E6%A0%85%E6%9E%81%E8%BE%93%E5%85%A5%201%EF%BC%8C%E5%B0%B1%E8%83%BD%E5%BE%97%E5%88%B0%E8%BE%93%E5%87%BA%E7%94%B5%E5%8E%8B%E3%80%82%E4%B8%BA%E4%BB%80%E4%B9%88%E5%BD%93%E8%BD%AF%E4%BB%B6%E7%BB%99%E5%87%BA%E9%80%BB%E8%BE%91%200%20%E6%97%B6%EF%BC%8C%E6%88%91%E4%BB%AC%E4%BB%8D%E8%83%BD%E5%BE%97%E5%88%B0%E8%BE%93%E5%87%BA%E7%94%B5%E5%8E%8B%EF%BC%9F(%E6%88%91%E4%BB%AC%E5%9C%A8%E8%BF%9E%E6%8E%A5%E8%B4%9F%E8%BD%BD%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%B5%8B%E8%AF%95%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E3)%20%E8%99%BD%E7%84%B6%E6%88%91%E4%BB%AC%E5%9C%A8%E6%AD%A3%E5%B8%B8%E6%A8%A1%E5%BC%8F%E4%B8%8B%E6%93%8D%E4%BD%9C%20SBC%EF%BC%8C%E4%BD%86%E6%97%A0%E6%B3%95%E8%8E%B7%E5%BE%97%205V%20%E8%BE%93%E5%87%BA%E3%80%82%E6%88%91%E4%BB%AC%E5%8F%AA%E5%BE%97%E5%88%B0%203V3%E3%80%82%E6%88%91%E4%BB%AC%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20sbc_uja1169_s32k_config%E3%80%82%E8%99%BD%E7%84%B6%E6%88%91%E4%BB%AC%E5%9C%A8%E8%B0%83%E8%8A%82%E5%99%A8%E9%83%A8%E5%88%86%E6%BF%80%E6%B4%BB%E4%BA%86%20V2%2FVEXT%20%E9%85%8D%E7%BD%AE%E9%83%A8%E5%88%86%EF%BC%8C%E4%BD%86%E6%97%A0%E6%B3%95%E4%BB%8E%20V2%20%E8%8E%B7%E5%BE%97%E8%BE%93%E5%87%BA%E3%80%82%E5%8E%9F%E5%9B%A0%E4%BD%95%E5%9C%A8%EF%BC%9F%E6%82%A8%E8%83%BD%E5%B8%AE%E5%8A%A9%E6%88%91%E4%BB%AC%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1395481%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1395481%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F195015%22%20target%3D%22_blank%22%3E%40Prince1%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E9%A6%96%E5%85%88%EF%BC%8C%E7%A5%9D%E5%A4%A7%E5%AE%B6%E6%96%B0%E5%B9%B4%E5%BF%AB%E4%B9%90%EF%BC%81%3CBR%20%2F%3E%E5%BE%88%E6%8A%B1%E6%AD%89%E8%BF%99%E4%B9%88%E6%99%9A%E6%89%8D%E5%9B%9E%E5%A4%8D%EF%BC%8C%E6%88%91%E4%BB%AC%E4%BC%91%E6%81%AF%E4%BA%86%E4%B8%80%E6%AE%B5%E6%97%B6%E9%97%B4%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%9B%9E%E7%AD%94%E4%BD%A0%E7%9A%84%E9%97%AE%E9%A2%98%3C%2FP%3E%0A%3COL%3E%0A%3CLI%3E%0A%3CP%3EBMS772%20%E9%A2%84%E8%A3%85%E4%BA%86%E7%A4%BA%E4%BE%8B%E8%BD%AF%E4%BB%B6%EF%BC%8C%E4%BD%86%E6%82%A8%E5%8F%AF%E8%83%BD%E9%9C%80%E8%A6%81%E5%B0%86%E5%85%B6%E6%9B%B4%E6%96%B0%E5%88%B0%E6%9C%80%E6%96%B0%E7%89%88%E6%9C%AC%E3%80%82%E4%BD%86%E8%AF%B7%E8%AE%B0%E4%BD%8F%EF%BC%8C%E5%AE%83%E6%98%AF%E4%B8%80%E4%B8%AA%E5%B8%A6%E6%9C%89%E5%BC%80%E6%BA%90%E7%A4%BA%E4%BE%8B%E8%BD%AF%E4%BB%B6%E7%9A%84%E5%BC%80%E5%8F%91%E5%B9%B3%E5%8F%B0%E3%80%82%20%E6%9C%AC%E8%BD%AF%E4%BB%B6%E4%B8%BA%E5%BC%80%E6%BA%90%E8%BD%AF%E4%BB%B6%EF%BC%8C%E7%94%A8%E4%BA%8E%E5%BC%80%E5%8F%91%E7%9B%AE%E7%9A%84%EF%BC%8C%E4%B8%8D%E4%BF%9D%E8%AF%81%E6%9C%80%E7%BB%88%E7%94%A8%E9%80%94%E3%80%82%E6%82%A8%E4%BB%8D%E7%84%B6%E9%9C%80%E8%A6%81%E7%A1%AE%E4%BF%9D%E7%A1%AC%E4%BB%B6%E5%92%8C%E8%BD%AF%E4%BB%B6%E6%BB%A1%E8%B6%B3%E6%82%A8%E7%9A%84%E9%9C%80%E6%B1%82%E3%80%82%3C%2FP%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3E%E7%9B%AE%E5%89%8D%EF%BC%8C%E6%88%91%E4%BB%AC%E8%BF%98%E6%B2%A1%E6%9C%89%E4%BD%BF%E7%94%A8%E5%A4%9A%E4%B8%AA%E5%8C%85%E5%B9%B6%E8%A1%8C%E6%B5%8B%E8%AF%95%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%E3%80%82%E7%A1%AC%E4%BB%B6%E5%8F%AF%E8%83%BD%E5%8F%AF%E4%BB%A5%E6%BB%A1%E8%B6%B3%E8%A6%81%E6%B1%82%EF%BC%8C%E4%BD%86%E9%9C%80%E8%A6%81%E5%AF%B9%E8%BD%AF%E4%BB%B6%E5%92%8C%E7%8A%B6%E6%80%81%E6%9C%BA%E8%BF%9B%E8%A1%8C%E5%AE%A1%E6%9F%A5%EF%BC%8C%E4%BB%A5%E7%A1%AE%E4%BF%9D%E5%B9%B6%E8%A1%8C%E9%85%8D%E7%BD%AE%E4%B8%8B%E7%9A%84%E6%AD%A3%E7%A1%AE%E8%BF%90%E8%A1%8C%E3%80%82%3C%2FP%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3E%E5%86%85%E7%BD%AE%E8%87%AA%E6%A3%80%E7%89%88%E6%9C%AC%EF%BC%8C%E7%94%A8%E4%BA%8E%E6%B5%8B%E8%AF%95%E5%9C%A8%E5%90%AF%E5%8A%A8%E6%9C%9F%E9%97%B4%E6%98%AF%E5%90%A6%E5%8F%AF%E4%BB%A5%E5%85%B3%E9%97%AD%20MOSFET%E3%80%82%E8%BF%99%E5%8F%AF%E7%A1%AE%E4%BF%9D%20MOSFET%20%E5%8F%8A%E5%85%B6%E6%8E%A7%E5%88%B6%E7%94%B5%E8%B7%AF%E5%8A%9F%E8%83%BD%E9%BD%90%E5%85%A8%EF%BC%8C%E5%8F%AF%E7%94%A8%E4%BA%8E%E7%A1%AC%E4%BB%B6%2F%E8%BD%AF%E4%BB%B6%E8%BF%87%E7%83%AD%2F%E8%BF%87%E5%8E%8B%2F%E6%B8%A9%E5%BA%A6%E4%BF%9D%E6%8A%A4%EF%BC%88%E5%8F%82%E8%A7%81%E8%BD%AF%E4%BB%B6%E7%89%88%E6%9C%AC%E6%96%87%E6%A1%A3%EF%BC%89%E3%80%82%E7%94%B5%E6%B1%A0%E4%BC%9A%E5%8F%91%E7%94%9F%E4%BB%80%E4%B9%88%E5%8F%96%E5%86%B3%E4%BA%8E%E5%85%B7%E4%BD%93%E6%83%85%E5%86%B5%EF%BC%8C%E6%98%AF%E5%85%85%E7%94%B5%E8%BF%98%E6%98%AF%E6%94%BE%E7%94%B5%EF%BC%8C%E6%98%AF%E5%90%A6%E9%9C%80%E8%A6%81%E4%BD%BF%E7%94%A8%20MOSFET%20%E8%BF%9E%E6%8E%A5%E6%88%96%E6%96%AD%E5%BC%80%E7%94%B5%E6%B1%A0%E3%80%82%E5%8F%A6%E5%A4%96%EF%BC%8C%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%20%E4%B8%8E%E7%94%B5%E6%B1%A0%E5%85%85%E7%94%B5%E5%99%A8%E4%B8%8D%E5%90%8C%E3%80%82%E7%94%B5%E6%B1%A0%E5%85%85%E7%94%B5%E4%BB%8D%E7%84%B6%E9%9C%80%E8%A6%81%E5%A4%96%E9%83%A8%E6%8E%A7%E5%88%B6%E7%9A%84%E6%81%92%E6%B5%81%20(CC)%20%E6%81%92%E5%8E%8B%20(CV)%20%E6%BA%90%E3%80%82%3C%2FP%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3E%E7%9B%AE%E5%89%8D%EF%BC%8C%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%20%E5%9C%A8%E5%AE%89%E8%A3%85%E7%9A%84%20BCC%20%E8%8A%AF%E7%89%87%E5%86%85%E6%9C%89%E6%9D%BF%E8%BD%BD%E5%B9%B3%E8%A1%A1%E7%94%B5%E9%98%BB%E5%92%8C%20FET%20%E6%9D%A5%E5%B9%B3%E8%A1%A1%E7%94%B5%E6%B1%A0%EF%BC%8C%E4%BB%8E%20MCU%20%E5%88%B0%20BCC%20%E7%9A%84%E5%91%BD%E4%BB%A4%E5%8F%AF%E4%BB%A5%E5%90%AF%E7%94%A8%E6%88%96%E7%A6%81%E7%94%A8%E6%AF%8F%E4%B8%AA%E5%8D%95%E5%85%83%E7%9A%84%E5%B9%B3%E8%A1%A1%E3%80%82%3C%2FP%3E%0A%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3E%3CSPAN%3E%E5%B8%8C%E6%9C%9B%E8%BF%99%E8%83%BD%E5%9B%9E%E7%AD%94%E4%BD%A0%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1390544%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1390544%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E5%B8%8C%E6%9C%9B%E5%9C%A8%E5%A4%AA%E9%98%B3%E8%83%BD%E6%97%A0%E4%BA%BA%E6%9C%BA%E4%B8%8A%E4%BD%BF%E7%94%A8%20RDDRONE-BMS772%EF%BC%8C%E5%B9%B6%E8%81%94%2020%20%E4%B8%AA%204S%20%E7%94%B5%E6%B1%A0%E7%BB%84%E3%80%82%E8%AF%B7%E6%BE%84%E6%B8%85%E4%BB%A5%E4%B8%8B%E9%97%AE%E9%A2%98%E3%80%81%3C%2FP%3E%3CP%3E1%E3%80%82RDDRONE-BMS772%20%E6%9D%BF%E5%8F%AF%E4%BB%A5%E9%9A%8F%E6%97%B6%E4%BD%BF%E7%94%A8%E5%90%97%EF%BC%9F%E4%BD%BF%E7%94%A8%E5%89%8D%E5%8F%AF%E4%BB%A5%E4%B8%8A%E4%BC%A0%E4%BB%BB%E4%BD%95%E8%BD%AF%E4%BB%B6%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E2.%E6%88%91%E4%BB%AC%E8%83%BD%E5%90%A6%E5%B0%86%2020%20%E4%B8%AA%20BMS772%20%E5%B9%B6%E8%81%94%E8%B5%B7%E6%9D%A5%EF%BC%8C%E4%B8%BA%2020%20%E4%B8%AA%20BMS772%20%E5%85%85%E7%94%B5%EF%BC%9F%E7%94%B5%E6%B1%A0%E7%BB%84%EF%BC%88%E6%AF%8F%E4%B8%AA%E7%94%B5%E6%B1%A0%E7%BB%84%E6%9C%89%204%20%E8%8A%82%E7%94%B5%E6%B1%A0%EF%BC%89%EF%BC%9F%E5%A6%82%E6%9E%9C%E5%9B%9E%E7%AD%94%E4%B8%BA%20%22%E6%98%AF%22%EF%BC%8C%E6%98%AF%E5%90%A6%E9%9C%80%E8%A6%81%E5%9C%A8%E5%A4%96%E9%83%A8%E6%8F%90%E4%BE%9B%E9%A2%9D%E5%A4%96%E4%BF%9D%E6%8A%A4%EF%BC%9F%3C%2FP%3E%3CP%3E3.BMS772%20%E6%98%AF%E5%90%A6%E6%9C%89%E9%98%B2%E6%AD%A2%20MOSFET%20%E6%95%85%E9%9A%9C%E7%9A%84%E5%86%85%E7%BD%AE%E4%BF%9D%E6%8A%A4%EF%BC%9F%E5%A6%82%E6%9E%9C%E4%B8%8D%E6%98%AF%EF%BC%8C%E5%BD%93%20MOSFET%20%E5%87%BA%E7%8E%B0%E6%95%85%E9%9A%9C%E6%97%B6%EF%BC%8C%E7%94%B5%E6%B1%A0%E4%BC%9A%E5%8F%91%E7%94%9F%E4%BB%80%E4%B9%88%E6%83%85%E5%86%B5%EF%BC%9F%3C%2FP%3E%3CP%3E4.%E6%9C%89%E6%BA%90%E7%94%B5%E6%B1%A0%E5%B9%B3%E8%A1%A1%E6%98%AF%E5%90%A6%E9%9C%80%E8%A6%81%E5%A4%96%E9%83%A8%20MOSFET%EF%BC%9FBMS772%20%E4%B8%AD%E7%9A%84%E6%B4%BB%E6%80%A7%E7%BB%86%E8%83%9E%E5%B9%B3%E8%A1%A1%E6%98%AF%E5%A6%82%E4%BD%95%E5%B7%A5%E4%BD%9C%E7%9A%84%EF%BC%9F%3C%2FP%3E%3CP%3E%E5%85%88%E8%A1%8C%E8%87%B4%E8%B0%A2%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1371403%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1371403%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F189198%22%20target%3D%22_blank%22%3E%40coryjfowler%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%88%91%E4%BB%AC%E6%AD%A3%E5%9C%A8%E7%A7%AF%E6%9E%81%E8%B0%83%E6%9F%A5%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%E6%88%91%E4%BB%AC%E9%9C%80%E8%A6%81%E4%BB%8E%E4%BB%93%E5%BA%93%E9%87%8C%E6%8B%BF%E5%87%BA%E4%B8%80%E4%BA%9B%E7%9B%AE%E5%89%8D%E7%89%88%E6%9C%AC%E7%9A%84%E6%9D%BF%EF%BC%8C%E4%BB%A5%E7%A1%AE%E5%AE%9A%E8%BF%99%E4%B8%AA%E6%9C%80%E6%96%B0%E7%9A%84%E6%9D%BF%E7%89%88%E6%9C%AC%E6%98%AF%E6%80%8E%E4%B9%88%E5%9B%9E%E4%BA%8B%E3%80%82%E5%9C%A8%E7%A1%AE%E5%AE%9A%E6%A0%B9%E6%9C%AC%E5%8E%9F%E5%9B%A0%E7%9A%84%E5%90%8C%E6%97%B6%EF%BC%8C%E6%88%91%E4%BB%AC%E5%B0%86%E5%B0%BD%E5%BF%AB%E6%8F%90%E4%BE%9B%E8%A7%A3%E5%86%B3%E6%96%B9%E6%B3%95%E3%80%82%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E8%80%90%E5%BF%83%E7%AD%89%E5%BE%85%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1371347%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1371347%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E8%83%BD%E5%90%A6%E5%B0%B1%E6%88%91%E7%9A%84%20V%204.0%20REV%20D%20%E6%9D%BF%E4%BB%A5%E5%8F%8A%E5%AF%BC%E8%87%B4%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E5%AE%8C%E5%85%A8%E5%81%9C%E6%AD%A2%E7%9A%84%20NFC%20%E8%8A%AF%E7%89%87%E9%97%AE%E9%A2%98%E5%AF%BB%E6%B1%82%E5%B8%AE%E5%8A%A9%EF%BC%9F%E5%AF%B9%20Github%20%E9%97%AE%E9%A2%98%E7%9A%84%E6%9C%80%E5%90%8E%E5%9B%9E%E5%A4%8D%E6%98%AF%203%20%E5%A4%A9%E5%89%8D%E3%80%82%20%E6%88%91%E6%9C%AC%E4%BB%A5%E4%B8%BA%E4%BB%8A%E5%A4%A9%E4%B8%8A%E5%8D%88%E4%BC%9A%E6%94%B6%E5%88%B0%E5%9B%9E%E5%A4%8D%EF%BC%8C%E4%BD%86%E6%B2%A1%E9%82%A3%E4%B9%88%E5%B9%B8%E8%BF%90%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2Fissues%2F6%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2Fissues%2F6%3C%2FA%3E%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1277972%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1277972%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E5%8D%A1%E4%BC%A6%3C%2FP%3E%0A%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E8%BF%99%E6%98%AF%E5%8F%AF%E8%83%BD%E7%9A%84%E3%80%82%3C%2FP%3E%0A%3CP%3EJ19%20%E7%BB%93%E5%90%88%E4%BA%86%20JTAG%20%E8%B0%83%E8%AF%95%E5%99%A8%E5%BC%95%E8%84%9A%E5%92%8C%20UART%20%E5%BC%95%E8%84%9A%EF%BC%8CCLI%20%E9%9C%80%E8%A6%81%20UART%20%E5%BC%95%E8%84%9A%E3%80%82%3CBR%20%2F%3E%E6%9C%89%E4%B8%80%E4%B8%AA%20DCD-LZ%20%E5%88%86%E7%BA%BF%E6%9D%BF%EF%BC%8C%E5%8F%AF%E4%BB%A5%E8%AE%A9%E4%BD%A0%E5%B0%86%20JTAG%20%E8%B0%83%E8%AF%95%E5%99%A8%E8%BF%9E%E6%8E%A5%E5%88%B0%E8%AF%A5%E5%88%86%E7%BA%BF%E6%9D%BF%E7%9A%84%20JTAG%20%E8%B0%83%E8%AF%95%E5%99%A8%E5%BC%95%E8%84%9A%EF%BC%88%E5%A6%82%20J2%EF%BC%89%EF%BC%8C%E5%B9%B6%E5%B0%86%20UART%20%E4%B8%8E%20FTDI%20%E5%BC%95%E8%84%9A%E5%88%86%E5%BC%80%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%BF%99%E5%8F%AF%E4%BB%A5%E8%BF%9E%E6%8E%A5%E5%88%B0%20%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%20%E7%9A%84%20J19%E3%80%82%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fnxp.gitbook.io%2Fhovergames%2Frddrone-fmuk66%2Fconnectors%2Fdebug-interface-dcd-lz%2Fdcd-lz-breakout-board%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E5%8F%82%E8%A7%81%20https%3A%2F%2Fnxp.gitbook.io%2Fhovergames%2Frddrone-fmuk66%2Fconnectors%2Fdebug-interface-dcd-lz%2Fdcd-lz-breakout-board%3C%2FA%3E%E6%9C%89%E5%85%B3%E5%88%86%E7%BB%84%E8%AE%A8%E8%AE%BA%E6%9D%BF%E7%9A%84%E6%9B%B4%E5%A4%9A%E7%BB%86%E8%8A%82%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%BF%9E%E6%8E%A5%E5%99%A8%20J2%20%E5%8F%AA%E6%9C%89%2010%20%E5%BC%95%E8%84%9A%20JTAG%20%E8%BF%9E%E6%8E%A5%E5%99%A8%EF%BC%8C%E6%B2%A1%E6%9C%89%20UART%20%E5%BC%95%E8%84%9A%E3%80%82%3CBR%20%2F%3E%E4%BD%A0%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20J2%20%E5%AF%B9%E6%9D%BF%E8%BF%9B%E8%A1%8C%E7%BC%96%E7%A8%8B%2F%E8%B0%83%E8%AF%95%EF%BC%8C%E5%B9%B6%E4%BD%BF%E7%94%A8%20J19%20%E6%9D%A5%E7%BC%96%E7%A8%8B%2F%E8%B0%83%E8%AF%95%20CLI%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E%E4%BD%9C%E4%B8%BA%E6%9B%BF%E4%BB%A3%E6%96%B9%E6%A1%88%EF%BC%8C%E8%BF%9E%E6%8E%A5%E5%99%A8%20J21%20%E4%B8%8A%E6%9C%89%E5%8F%A6%E4%B8%80%E6%9D%A1%20UART%20%E6%80%BB%E7%BA%BF%E3%80%82%3C%2FP%3E%0A%3CP%3E%E7%94%B1%E4%BA%8E%E8%AF%A5%E4%BB%A3%E7%A0%81%E6%98%AF%E5%85%AC%E5%BC%80%E5%8F%AF%E7%94%A8%E7%9A%84%EF%BC%8C%E5%B9%B6%E4%B8%94%E4%BD%BF%E7%94%A8NuttX%20RTOS%EF%BC%8C%E5%9B%A0%E6%AD%A4%E5%9C%A8%E4%BD%BF%E7%94%A8%E5%85%B6%E4%BB%96UART%E6%80%BB%E7%BA%BF%E8%BF%9B%E8%A1%8CCLI%E6%97%B6%E5%8F%AF%E4%BB%A5%E8%BD%BB%E6%9D%BE%E5%AF%B9%E5%85%B6%E8%BF%9B%E8%A1%8C%E6%9B%B4%E6%94%B9%E3%80%82%3CBR%20%2F%3E%E4%BD%A0%E5%8F%AF%E4%BB%A5%E5%9C%A8%20NuttX%20%E7%9A%84%E8%8F%9C%E5%8D%95%E9%85%8D%E7%BD%AE%E4%B8%AD%E9%80%89%E6%8B%A9%20LPUART0%20%E4%BD%9C%E4%B8%BA%E4%B8%B2%E8%A1%8C%E6%8E%A7%E5%88%B6%E5%8F%B0%EF%BC%88%E5%9C%A8%E8%AE%BE%E5%A4%87%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E4%B8%AD-%26gt%3B%20%E4%B8%B2%E8%A1%8C%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%94%AF%E6%8C%81-%26gt%3B%20%E4%B8%B2%E8%A1%8C%E6%8E%A7%E5%88%B6%E5%8F%B0%EF%BC%89%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20J2%20%E8%BF%9B%E8%A1%8C%E7%BC%96%E7%A8%8B%2F%E8%B0%83%E8%AF%95%EF%BC%8C%E5%A6%82%E6%9E%9C%E9%85%8D%E7%BD%AE%E4%BA%86%20CLI%EF%BC%8C%E5%88%99%E4%BD%BF%E7%94%A8%20J21%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1276596%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1276596%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%81%3C%2FP%3E%3CP%3E%E6%88%91%E6%9C%89%E4%B8%80%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%8C%E5%A6%82%E6%9E%9C%20J-link%20%E8%B0%83%E8%AF%95%E5%99%A8%E5%9C%A8%20J2%20%E7%AB%AF%E5%8F%A3%E4%B8%8A%EF%BC%8C%E6%98%AF%E5%90%A6%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20CLI%EF%BC%9F%E6%88%96%E8%80%85%E6%9C%89%E6%B2%A1%E6%9C%89%E5%85%B6%E4%BB%96%E6%96%B9%E6%B3%95%E5%8F%AF%E4%BB%A5%E5%9C%A8%E4%B8%8D%E4%BD%BF%E7%94%A8%20CLI%20%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E8%8E%B7%E5%8F%96%20J2%20%E7%9A%84%E4%BF%A1%E6%81%AF%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1269793%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1269793%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%98%AF%E7%9A%84--%E5%BE%88%E9%81%97%E6%86%BE%E5%90%AC%E5%88%B0%E8%BF%99%E4%B8%AA%E6%B6%88%E6%81%AF%E3%80%82%E6%88%91%E4%B9%9F%E7%9C%8B%E4%BA%86%E4%B8%80%E4%B8%8B%EF%BC%8C%E4%BD%A0%E8%AF%B4%E5%BE%97%E6%B2%A1%E9%94%99%EF%BC%8C%E4%BC%BC%E4%B9%8E%E6%B2%A1%E6%9C%89%E5%85%A8%E7%90%83%E9%80%9A%E7%94%A8%E7%9A%84%E3%80%82%E8%BF%99%E6%98%AF%E4%B8%80%E4%B8%AA%E6%B4%BB%E8%B7%83%E8%80%8C%E4%BC%98%E7%A7%80%E7%9A%84%E9%83%A8%E5%88%86%EF%BC%8C%E5%8F%AA%E6%98%AF%E9%99%B7%E5%85%A5%E4%BA%86%E5%85%A8%E7%90%83%E8%8A%AF%E7%89%87%E7%9F%AD%E7%BC%BA%E7%9A%84%E5%9B%B0%E5%A2%83%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%BB%A5%E4%B8%8B%E6%98%AF%E4%B8%80%E4%BA%9B%EF%BC%88%E4%B8%8D%E5%A4%AA%E5%A5%BD%E7%9A%84%EF%BC%89%E9%80%89%E6%8B%A9%EF%BC%9A%3CBR%20%2F%3E-%20%E7%9B%B4%E6%8E%A5%E8%81%94%E7%B3%BB%20Nexperia%E3%80%82%E4%BD%A0%E5%8F%AA%E9%9C%80%E8%A6%81%E4%B8%80%E4%BA%9B%EF%BC%8C%E5%AF%B9%E5%90%97%EF%BC%9F%E6%9C%89%E6%97%B6%EF%BC%8C%E4%BB%96%E4%BB%AC%E6%89%8B%E5%A4%B4%E4%B8%8A%E4%BC%9A%E6%9C%89%E4%B8%80%E4%BA%9B%E6%A0%B7%E5%93%81%E3%80%82%3C%2FP%3E%0A%3CP%3E-%20%E9%80%9A%E8%BF%87%20Nexperia.com%20%E6%9F%A5%E7%9C%8B%E8%BF%91%E4%BC%BC%E6%9B%BF%E4%BB%A3%E5%93%81%EF%BC%9F%3C%2FP%3E%0A%3CP%3E-%E5%86%8D%E4%B9%B0%E4%B8%80%E4%B8%AA%20%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F-772%20%E7%84%B6%E5%90%8E%E4%BB%8E%E5%85%B6%E4%B8%AD%E4%B8%80%E4%B8%AA%E4%B8%8A%E5%8F%96%E4%B8%8B%E9%9B%B6%E4%BB%B6%E5%86%8D%E6%B7%BB%E5%8A%A0%E5%88%B0%E5%8F%A6%E4%B8%80%E4%B8%AA%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1269709%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1269709%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%94%B1%E4%BA%8E%E8%8A%AF%E7%89%87%E7%9F%AD%E7%BC%BA%EF%BC%8CPSMNR70-30YLH%20mosfet%20%E5%B7%B2%E6%97%A0%E6%B3%95%E5%9C%A8%E5%B8%82%E5%9C%BA%E4%B8%8A%E4%B9%B0%E5%88%B0%E3%80%82%E6%88%91%E4%BB%AC%E8%AF%A5%E5%A6%82%E4%BD%95%E5%A4%84%E7%90%86%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%8C%E6%98%AF%E5%90%A6%E6%9C%89%E5%85%B6%E4%BB%96%E7%9A%84%20mosfet%20%E5%8F%AF%E4%BB%A5%E4%B8%8E%E8%AF%A5%E5%9E%8B%E5%8F%B7%E4%B8%80%E8%B5%B7%E4%BD%BF%E7%94%A8%E3%80%82%E8%AF%B7%E5%B0%BD%E5%BF%AB%E5%9B%9E%E5%A4%8D%E6%88%91%EF%BC%8C%E5%9B%A0%E4%B8%BA%E6%88%91%E4%BB%AC%E9%9C%80%E8%A6%81%E5%B0%BD%E5%BF%AB%E5%BE%97%E5%88%B0%E8%AF%A5%E4%BA%A7%E5%93%81%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1267858%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1267858%22%20slang%3D%22en-US%22%20mode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href%3D%22https%3A%2F%2Fnxp.gitbook.io%2Frddrone-bms772%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%EF%BC%9Ahttps%3A%2F%2Fnxp.gitbook.io%2Frddrone-bms772%2F%3C%2FA%3E%E3%80%82%3CBR%20%2F%3E%E8%BD%AF%E4%BB%B6%E7%A4%BA%E4%BE%8B%E8%A7%81%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%EF%BC%9A%20https%3A%2F%2Fgithub.com%2FNXPHoverGames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us%20%E5%86%85%E6%8F%90%E4%BE%9B%20545A%20%E7%9A%84%E5%B3%B0%E5%80%BC%E7%94%B5%E6%B5%81%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%9B%B4%E9%AB%98%E7%9A%84%E7%94%B5%E6%B5%81%E6%88%96%E6%9B%B4%E9%95%BF%E6%97%B6%E9%97%B4%E7%9A%84%E7%94%B5%E6%B5%81%E5%8F%AF%E8%83%BD%E6%98%AF%E5%8F%AF%E8%A1%8C%E7%9A%84%EF%BC%8C%E4%BD%86%E5%B0%9A%E6%9C%AA%E8%BF%9B%E8%A1%8C%E8%BF%87%E6%B5%8B%E8%AF%95%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%B6%85%E8%BF%87%E6%9C%80%E5%A4%A7%E9%A2%9D%E5%AE%9A%E7%94%B5%E6%B5%81%E6%88%96%E8%A7%84%E5%AE%9A%E6%97%B6%E9%97%B4%EF%BC%8C%E9%A3%8E%E9%99%A9%E8%87%AA%E8%B4%9F%E3%80%82%3CBR%20%2F%3E%E8%AF%B7%E8%AE%B0%E4%BD%8F%EF%BC%8C%E5%BA%94%E5%A7%8B%E7%BB%88%E5%B0%8F%E5%BF%83%E5%A4%84%E7%90%86%E7%94%B5%E6%B1%A0%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1265442%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1265442%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E4%BB%AC%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E5%A4%AA%E9%98%B3%E8%83%BD%E6%97%A0%E4%BA%BA%E6%9C%BA%EF%BC%8C%E5%AE%83%E9%9C%80%E8%A6%81%E5%A4%A7%E9%87%8F%E7%94%B5%E5%8A%9B%E3%80%82%20%3C%2FP%3E%3CP%3E%E8%BF%99%E4%B8%AA%E4%BA%A7%E5%93%81%E7%9C%8B%E8%B5%B7%E6%9D%A5%E5%BE%88%E4%B8%8D%E9%94%99%EF%BC%8C%E4%BD%86%E6%88%91%E5%AF%B9%E6%9C%80%E9%AB%98%E8%AF%84%E7%BA%A7%E6%84%9F%E5%88%B0%E5%9B%B0%E6%83%91%E3%80%82%E6%88%91%E4%BB%AC%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%206%20%E8%8A%82%E9%85%8D%E7%BD%AE%E7%9A%84%E9%94%82%E8%81%9A%E5%90%88%E7%89%A9%E7%94%B5%E6%B1%A0%EF%BC%8C%E7%94%B5%E5%8E%8B%E4%B8%BA%2022%20%E4%BC%8F%EF%BC%8C%E9%A9%AC%E8%BE%BE%E9%9C%80%E8%A6%81%E5%BE%88%E5%A4%A7%E7%9A%84%E7%88%86%E5%8F%91%E7%94%B5%E6%B5%81%E5%92%8C%E6%8C%81%E7%BB%AD%E7%94%B5%E6%B5%81%EF%BC%8890A%20%E5%88%86%E9%92%9F%EF%BC%89%E3%80%82%20%E6%88%91%E7%9C%8B%E5%88%B0%E5%AE%83%E7%9A%84%E6%9C%80%E5%A4%A7%E9%A2%9D%E5%AE%9A%E5%80%BC%E6%98%AF%2090A%20DC%EF%BC%8C%E8%BF%99%E4%B8%AA%E5%80%BC%E6%98%AF%E8%BF%9E%E7%BB%AD%E6%9C%80%E5%A4%A7%E9%A2%9D%E5%AE%9A%E5%80%BC%E8%BF%98%E6%98%AF%E7%AA%81%E5%8F%91%E6%9C%80%E5%A4%A7%E9%A2%9D%E5%AE%9A%E5%80%BC%E3%80%82%E4%BB%80%E4%B9%88%E6%98%AF%E7%AA%81%E5%8F%91%E7%94%B5%E6%B5%81%E5%92%8C%E7%AA%81%E5%8F%91%E7%94%B5%E6%B5%81%E7%9A%84%E6%97%B6%E9%97%B4%E9%99%90%E5%88%B6%E3%80%82%E4%BD%A0%E8%83%BD%E4%B8%8D%E8%83%BD%E7%BB%99%E6%88%91%E6%8E%A8%E8%8D%90%E8%BF%99%E4%B8%AA%E6%88%96%E5%8F%A6%E4%B8%80%E4%B8%AA%20%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%20FRDM33772BSPIEVB%20%E5%93%AA%E4%B8%AA%E5%AF%B9%E6%88%91%E6%9B%B4%E5%A5%BD%E3%80%82%3C%2FP%3E%3CP%3E%E5%B8%8C%E6%9C%9B%E8%83%BD%E5%B0%BD%E5%BF%AB%E7%BB%99%E6%88%91%E7%AD%94%E5%A4%8D%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1216911%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1216911%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EBMS772%20%E5%8F%AF%E5%AE%9E%E7%8E%B0%E8%87%AA%E6%88%91%E5%B9%B3%E8%A1%A1%E3%80%82%E6%82%A8%E9%9C%80%E8%A6%81%E6%8E%A7%E5%88%B6%E4%B8%BA%E7%94%B5%E6%B1%A0%E5%85%85%E7%94%B5%E7%9A%84%E6%80%BB%E7%94%B5%E6%B5%81%E3%80%82%E6%82%A8%E8%BF%98%E5%BA%94%E8%AF%A5%E6%8F%90%E4%BE%9B%E4%B8%80%E4%BA%9B%E7%94%B5%E6%BA%90%E8%BD%AC%E5%90%91%2F%E9%9A%94%E7%A6%BB%E8%A3%85%E7%BD%AE%EF%BC%8C%E5%90%A6%E5%88%99%E5%9C%A8%E4%B8%A4%E4%B8%AA%E7%94%B5%E6%B1%A0%E5%B9%B6%E8%81%94%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8C%E7%94%B5%E9%87%8F%E8%BE%83%E9%AB%98%E7%9A%84%E7%94%B5%E6%B1%A0%E4%BC%9A%E8%AF%95%E5%9B%BE%E4%B8%BA%E7%94%B5%E9%87%8F%E8%BE%83%E4%BD%8E%E7%9A%84%E7%94%B5%E6%B1%A0%E5%85%85%E7%94%B5%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%8F%A6%E5%A4%96%EF%BC%8C%E4%B8%8A%E9%9D%A2%E6%B2%A1%E6%9C%89%E8%AF%B4%E6%B8%85%E6%A5%9A%E7%9A%84%E6%98%AF%EF%BC%8C%E6%82%A8%E6%98%AF%E8%A6%81%E5%88%B6%E4%BD%9C%E4%B8%80%E4%B8%AA%E6%95%B0%E6%8D%AE%E5%8C%85%E8%BF%98%E6%98%AF%E4%B8%A4%E4%B8%AA%E7%8B%AC%E7%AB%8B%E7%9A%84%E5%8F%AF%E6%8F%92%E6%8B%94%E6%95%B0%E6%8D%AE%E5%8C%85%E3%80%82%E5%A6%82%E6%9E%9C%E4%BD%A0%E6%84%BF%E6%84%8F%EF%BC%8C%E4%BD%A0%E5%8F%AF%E4%BB%A5%E5%B0%86%E5%8D%95%E4%B8%AA%E7%BB%86%E8%83%9E%E5%B9%B6%E8%81%94%E6%88%90%E4%B8%80%E4%B8%AA%E5%A4%A7%E7%BB%86%E8%83%9E%EF%BC%88%E5%B9%B6%E4%BD%BF%E7%94%A8%E5%8D%95%E4%B8%AA%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%EF%BC%89%EF%BC%8C%E4%BD%86%E4%BD%A0%E4%BC%BC%E4%B9%8E%E4%B8%8D%E6%98%AF%E8%BF%99%E6%A0%B7%E6%8F%8F%E8%BF%B0%E7%9A%84%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%AF%8F%E5%8C%85%E9%9C%80%E8%A6%81%E4%B8%80%E4%B8%AA%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%20%E7%9A%84%E5%A4%A7%E5%B0%8F%E4%B8%8E%203S%204000mA%2FH%20%E7%88%B1%E5%A5%BD%20LiPO%20%E5%B7%AE%E4%B8%8D%E5%A4%9A-%E5%AF%B9%E4%B8%8D%E8%B5%B7%EF%BC%8C%E6%88%91%E6%B2%A1%E6%9C%89%E7%A1%AE%E5%88%87%E7%9A%84%E5%B0%BA%E5%AF%B8%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1203659%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1203659%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E6%9B%B4%E6%96%B0%E5%92%8C%E5%BF%AB%E9%80%9F%E5%9B%9E%E5%A4%8D%E3%80%82%E6%88%91%E4%B8%80%E5%AE%9A%E4%BC%9A%E5%85%B3%E6%B3%A8%E8%BF%99%E4%B8%AA%E4%B8%BB%E9%A2%98%E7%9A%84%E3%80%82%E5%AF%BB%E6%89%BE%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%E7%A2%B0%E5%88%B0%E4%BA%86%E4%BD%A0%E7%9A%84%E8%AF%9D%E9%A2%98%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Falaskasworld.run%2F%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ealaskasworld.com%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1153065%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1153065%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E4%BB%AC%E7%9A%84%E6%97%A0%E4%BA%BA%E6%9C%BA%E7%94%B5%E6%B1%A0%E7%94%B1%202%20x%207000mAh%206S%20%E9%94%82%E8%81%9A%E5%90%88%E7%89%A9%E7%94%B5%E6%B1%A0%E7%BB%84%E6%88%90%E3%80%82%E8%BF%99%E4%B8%A4%E4%B8%AA%E7%94%B5%E6%B1%A0%E7%BB%84%E5%B0%86%E5%B9%B6%E8%81%94%E4%BB%A5%E8%BE%BE%E5%88%B0%2014000mAh%206S%E3%80%82%20%3C%2FP%3E%3CP%3E%E6%88%91%E6%89%80%E5%81%9A%E7%9A%84%E6%98%AF%E5%88%B6%E4%BD%9C%E4%B8%80%E4%B8%AA%E5%A4%96%E5%A3%B3%E6%9D%A5%E5%AD%B5%E5%8C%96%E4%B8%A4%E4%B8%AA%E7%94%B5%E6%B1%A0%E5%8C%85%EF%BC%8C%E5%B9%B6%E5%B0%86%E5%AE%83%E4%BB%AC%E8%BF%9E%E6%8E%A5%E5%88%B0%E4%B8%80%E4%B8%AA%2010%20%E9%92%88%E7%A8%B3%E5%81%A5%E5%9E%8B%E5%85%AC%E8%BF%9E%E6%8E%A5%E5%99%A8%E4%B8%8A%EF%BC%8C%E5%9C%A8%E6%97%A0%E4%BA%BA%E6%9C%BA%E5%B0%BA%E5%AF%B8%E4%B8%AD%E8%BF%98%E6%9C%89%E4%B8%80%E4%B8%AA%E6%AF%8D%E8%BF%9E%E6%8E%A5%E5%99%A8%E3%80%82%E6%88%91%E4%BB%AC%E7%9A%84%E8%AE%A1%E5%88%92%E6%98%AF%E6%8A%8A%E6%97%A0%E4%BA%BA%E6%9C%BA%E7%94%B5%E6%B1%A0%E5%81%9A%E6%88%90%E7%94%B5%E6%B1%A0%E7%9B%92%E7%9A%84%E6%A0%B7%E5%AD%90%EF%BC%8C%E8%BF%99%E6%A0%B7%E6%88%91%E4%BB%AC%E5%B0%B1%E5%8F%AF%E4%BB%A5%E6%8A%8A%E5%AE%83%E6%BB%91%E5%88%B0%E6%97%A0%E4%BA%BA%E6%9C%BA%E4%B8%8A%EF%BC%8C%E7%82%B9%E5%87%BB%E8%BF%9B%E5%8E%BB%E5%B0%B1%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%EF%BC%8C%E5%BD%93%E7%94%B5%E6%B1%A0%E9%9C%80%E8%A6%81%E5%85%85%E7%94%B5%E6%97%B6%EF%BC%8C%E6%88%91%E4%BB%AC%E5%B0%B1%E6%8A%8A%E7%94%B5%E6%B1%A0%E7%9B%92%E6%8B%BF%E5%87%BA%E6%9D%A5%EF%BC%8C%E7%94%A8%E6%97%A0%E4%BA%BA%E6%9C%BA%E4%B8%8A%E4%BD%BF%E7%94%A8%E7%9A%84%E9%92%88%E5%9E%8B%E8%BF%9E%E6%8E%A5%E5%88%B0%E5%85%85%E7%94%B5%E5%99%A8%E4%B8%8A%E3%80%82%E9%97%AE%E9%A2%98%E6%98%AF%E5%85%85%E7%94%B5%E6%97%B6%E6%88%91%E4%BB%AC%E8%83%BD%E7%94%A8%E4%BD%A0%E7%9A%84%20%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%20772%20%E6%9D%A5%E5%AE%9E%E7%8E%B0%E8%87%AA%E5%B9%B3%E8%A1%A1%E5%A2%A8%E7%9B%92%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%98%AF%E8%BF%99%E6%A0%B7%EF%BC%8C%E6%88%91%E4%BB%AC%E8%AF%A5%E6%80%8E%E4%B9%88%E5%81%9A%EF%BC%9F%E6%88%91%E4%BB%AC%E9%9C%80%E8%A6%81%E4%B8%A4%E5%9D%97%E6%9D%BF%E8%BF%98%E6%98%AF%E5%8F%AA%E9%9C%80%E8%A6%81%E4%B8%80%E5%9D%97%E6%9D%BF%EF%BC%9F%E5%A6%82%E4%BD%95%E5%B0%86%E5%AE%83%E8%BF%9E%E6%8E%A5%E5%88%B0%E7%94%B5%E6%B1%A0%E4%B8%8A%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%AF%B7%E9%97%AE%E9%82%A3%E5%9D%97%E6%A3%8B%E7%9B%98%E7%9A%84%E5%B0%BA%E5%AF%B8%E6%98%AF%E5%A4%9A%E5%B0%91%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E9%97%AE%E5%80%99%20%3C%2FP%3E%3CP%3E%E7%8C%8E%E9%B9%B0%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2317845%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2317845%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%86%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F-772%20%E7%94%A8%E4%BA%8E%E5%A4%A7%E5%AD%A6%E9%A1%B9%E7%9B%AE%EF%BC%8C%E4%BD%86%E6%97%A0%E6%B3%95%E8%AE%BF%E9%97%AE%E7%94%B5%E6%B1%A0%E4%BB%BF%E7%9C%9F%E5%99%A8%E3%80%82%E6%88%91%E6%83%B3%E7%9F%A5%E9%81%93%E5%A6%82%E4%BD%95%E5%9C%A8%E9%9D%A2%E5%8C%85%E6%9D%BF%E4%B8%8A%E8%AE%BE%E8%AE%A1%E4%B8%80%E4%B8%AA%E7%94%B5%E9%98%BB%E5%99%A8%E8%A3%85%E7%BD%AE%EF%BC%8C%E4%BB%A5%E6%A8%A1%E4%BB%BF%E7%94%B5%E6%B1%A0%E5%8D%95%E5%85%83%EF%BC%8C%E6%9A%82%E6%97%B6%E7%94%A8%E4%BA%8E%E7%BA%AF%E7%B2%B9%E7%9A%84%E6%B5%8B%E8%AF%95%E7%9B%AE%E7%9A%84%E3%80%82%20%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%B8%AE%E5%8A%A9%E3%80%81%3C%2FP%3E%3CP%3E%E8%B0%A2%E6%81%A9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2317850%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2317850%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178538%22%20target%3D%22_blank%22%3E%40SH%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E8%BF%99%E5%8F%96%E5%86%B3%E4%BA%8E%E6%82%A8%E6%83%B3%E6%B5%8B%E8%AF%95%E4%BB%80%E4%B9%88%E3%80%82%20%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E6%83%B3%E5%9C%A8%E7%94%B5%E6%B1%A0%E6%B5%8B%E9%87%8F%E9%80%89%E9%A1%B9%E5%8D%A1%E4%B8%8A%E6%98%BE%E7%A4%BA%E7%94%B5%E5%8E%8B%E3%80%82%E4%B8%8D%E5%AF%B9%E7%94%B5%E6%B1%A0%E5%85%85%E7%94%B5%E6%88%96%EF%BC%88%E8%A2%AB%E5%8A%A8%EF%BC%89%E5%B9%B3%E8%A1%A1%E7%94%B5%E6%B1%A0%E3%80%82%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%BE%88%E5%AE%B9%E6%98%93%E5%9C%B0%E5%9C%A8%E7%94%B5%E5%8E%8B%E6%BA%90%E4%B8%8A%E6%B7%BB%E5%8A%A0%E4%B8%80%E4%BA%9B%E7%94%B5%E9%98%BB%E6%9D%A5%E6%A8%A1%E6%8B%9F%E7%94%B5%E6%B1%A0%E7%94%B5%E5%8E%8B%EF%BC%8C%E7%84%B6%E5%90%8E%E7%94%A8%20BMS772%20%E8%BF%9B%E8%A1%8C%E6%B5%8B%E9%87%8F%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%BE%8B%E5%A6%82%EF%BC%8C%E6%82%A8%E6%9C%89%E4%B8%80%E4%B8%AA%E5%AE%9E%E9%AA%8C%E5%AE%A4%E7%94%B5%E6%BA%90%EF%BC%8C%E6%83%B3%E6%B5%8B%E8%AF%95%203S%20%E7%94%B5%E6%B1%A0%EF%BC%883%20%E8%8A%82%E4%B8%B2%E8%81%94%EF%BC%89%E7%9A%84%E8%AE%BE%E7%BD%AE%E3%80%82%20%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%B0%86%E5%AE%9E%E9%AA%8C%E5%AE%A4%E7%94%B5%E6%BA%90%E8%AE%BE%E7%BD%AE%E4%B8%BA%2012V%EF%BC%8C%E5%B0%86%E5%AE%83%E4%BB%AC%E8%BF%9E%E6%8E%A5%E5%88%B0%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%E7%9A%84%2B%E5%92%8C%E7%94%B5%E6%BA%90%E8%BE%93%E5%85%A5-%E3%80%82%E4%B8%8E%E6%AD%A4%E5%90%8C%E6%97%B6%EF%BC%8C%E6%82%A8%E8%BF%98%E5%8F%AF%E4%BB%A5%E6%B7%BB%E5%8A%A0%E4%B8%80%E4%B8%AA%E5%88%86%E5%8E%8B%E5%99%A8%EF%BC%8C%E8%AF%A5%E5%88%86%E5%8E%8B%E5%99%A8%E5%85%B7%E6%9C%89%203%20%E4%B8%AA%E7%94%B5%E9%98%BB%EF%BC%8C%E4%BE%8B%E5%A6%82%EF%BC%8C%E4%BB%8E%E5%8A%9F%E7%8E%87%20%2B%20%E5%88%B0%E5%8A%9F%E7%8E%87-%E4%B8%B2%E8%81%94%E4%B8%BA%201k%CE%A9%E3%80%82%3CBR%20%2F%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%9C%A8%E8%BF%99%E4%BA%9B%E7%94%B5%E9%98%BB%E5%99%A8%E4%B8%8A%E6%B7%BB%E5%8A%A0%204%20%E6%A0%B9%E5%B9%B3%E8%A1%A1%E7%BA%BF%EF%BC%88%2B%E3%80%81-%20%E5%92%8C%E7%94%B5%E9%98%BB%E5%99%A8%E4%B9%8B%E9%97%B4%E7%9A%84%202%20%E6%A0%B9%EF%BC%89%EF%BC%8C%E4%BB%A5%E4%BE%BF%E8%BF%9E%E6%8E%A5%E5%88%B0%E5%B9%B3%E8%A1%A1%E5%AF%BC%E7%BA%BF%E8%BF%9E%E6%8E%A5%E5%99%A8%20JP1%E3%80%82%20%3CBR%20%2F%3E%E4%B8%80%E5%AE%9A%E8%A6%81%E6%8C%89%E7%85%A7%20github%20%E4%B8%8A%E7%9A%84%E7%89%88%E6%9C%AC%E8%AF%B4%E6%98%8E%E7%84%8A%E6%8E%A5%20BMS%20%E7%9A%84%203S%20%E9%85%8D%E7%BD%AE%EF%BC%9A%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXP-Robotics%2FRDDRONE-BMS772%2Fblob%2Fmain%2FBMS772_releaseNotes_6.0.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E4%B8%BB%E8%A6%81%E6%98%AF%20rddrone-bms772%2Fbms772_releasenotes_6.0.pdf%20%C2%B7%20nxp-robotics%2Frddrone-bms772%20%C2%B7%20GitHub%20%E6%88%91%E5%BB%BA%E8%AE%AE%E5%9C%A8%E6%9F%A5%E7%9C%8B%E8%80%85%E5%89%AA%E8%BE%91%E6%96%87%E6%A1%A3%E6%97%B6%E4%B8%8B%E8%BD%BD%E8%BF%99%E4%BB%BD%E7%89%88%E6%9C%AC%E8%AF%B4%E6%98%8E%20PDF%3C%2FA%3E%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%9C%A8%E6%AD%A4%E8%AE%BE%E7%BD%AE%E4%B8%AD%EF%BC%8C%E6%AF%8F%E4%B8%AA%22%E7%94%B5%E6%B1%A0%22%20%E5%BA%94%E8%AF%A5%E6%9C%89%20~4V%20%E7%94%B5%E5%8E%8B%E3%80%82%20%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%BD%93%E6%82%A8%E6%89%93%E5%BC%80%E5%AE%9E%E9%AA%8C%E5%AE%A4%E7%94%B5%E6%BA%90%E6%97%B6%EF%BC%8C%E6%82%A8%E5%BA%94%E8%AF%A5%E8%83%BD%E5%A4%9F%E5%9C%A8%E6%AD%A3%E5%B8%B8%E6%A8%A1%E5%BC%8F%E4%B8%8B%E5%90%AF%E5%8A%A8%20BMS772%EF%BC%88%E5%9C%A8%E6%B2%A1%E6%9C%89%E8%B4%9F%E8%BD%BD%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8C%E9%99%90%E6%B5%81%E5%8F%AF%E4%BB%A5%E8%AE%BE%E7%BD%AE%E4%B8%BA%20100mA%EF%BC%89%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%8F%AA%E8%A6%81%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%E5%92%8C%E7%94%B5%E6%BA%90%E8%83%BD%E5%A4%9F%E5%A4%84%E7%90%86%E5%B9%B6%E5%AF%B9%E5%85%B6%E8%BF%9B%E8%A1%8C%E9%85%8D%E7%BD%AE%EF%BC%8C%E6%82%A8%E4%B9%9F%E5%8F%AF%E4%BB%A5%E5%90%91%20BMS772%20%E7%9A%84%E8%BE%93%E5%87%BA%E6%B7%BB%E5%8A%A0%E8%B4%9F%E8%BD%BD%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%B8%8C%E6%9C%9B%E5%AF%B9%E6%82%A8%E6%9C%89%E6%89%80%E5%B8%AE%E5%8A%A9%EF%BC%81%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%B0%A8%E8%87%B4%E9%97%AE%E5%80%99%E3%80%81%3C%2FP%3E%0A%3CP%3E%E8%A5%BF%E6%96%AF%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2318145%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2318145%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%B8%AE%E5%8A%A9%E3%80%82%E9%99%8D%E4%BD%8E%E6%97%B6%E9%92%9F%E9%80%9F%E5%BA%A6%E5%90%8E%EF%BC%8C%E9%97%AE%E9%A2%98%E8%BF%8E%E5%88%83%E8%80%8C%E8%A7%A3%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2345508%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2345508%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%8F%88%E8%A7%81%E9%9D%A2%E4%BA%86%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%B8%AE%E5%8A%A9%E3%80%82%E6%88%91%E6%9C%89%E4%B8%80%E4%B8%AA%E7%AC%AC%E4%BA%8C%E4%B8%AA%20%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F-772%20%E6%9D%BF%EF%BC%8C%E5%B7%B2%E5%B0%86%203%20%E8%8A%82%E7%94%B5%E6%B1%A0%E8%BF%9E%E6%8E%A5%E5%99%A8%E7%84%8A%E6%8E%A5%E5%88%B0%20%E6%9D%BF%E4%B8%8A%EF%BC%8C%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E4%B8%89%E8%8A%82%E9%85%8D%E7%BD%AE%EF%BC%8C%E7%94%B5%E9%98%BB%E6%A8%A1%E4%BB%BF%E7%94%B5%E6%B1%A0%E3%80%82%E4%BD%86%E6%98%AF%EF%BC%8CCLI%20%E6%80%BB%E6%98%AF%E6%98%BE%E7%A4%BA%E7%AC%AC%203%20%E4%B8%AA%E7%94%B5%E6%B1%A0%E7%94%B5%E5%8E%8B%E4%B8%BA%200V%EF%BC%8C%E5%9B%A0%E6%AD%A4%E5%87%BA%E7%8E%B0%E7%94%B5%E5%8E%8B%E4%B8%8D%E8%B6%B3%E9%94%99%E8%AF%AF%E3%80%82%E7%AC%AC%203%20%E4%B8%AA%E7%94%B5%E9%98%BB%E4%B8%8A%E6%9C%89%E7%94%B5%E5%8E%8B%E3%80%82%E6%88%91%E5%9C%A8%E7%94%B5%E8%B7%AF%E6%9D%BF%E5%BA%95%E9%83%A8%E7%9A%84%E7%94%B5%E6%B1%A0%E5%AE%89%E8%A3%85%E5%9E%AB%E4%B8%8A%E6%9C%89%E4%B8%80%E4%BA%9B%E7%84%8A%E6%96%99%EF%BC%8C%E4%BD%86%E5%A4%A7%E9%83%A8%E5%88%86%E9%83%BD%E7%A7%BB%E9%99%A4%E4%BA%86%E4%BA%86%E3%80%82%E9%97%AE%E9%A2%98%E5%87%BA%E5%9C%A8%E5%93%AA%E9%87%8C%EF%BC%9F%3C%2FP%3E%3CP%3E%E5%86%8D%E6%AC%A1%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%B8%AE%E5%8A%A9%E3%80%81%3C%2FP%3E%3CP%3E%E5%A4%8F%E6%81%A9%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2220260404_171220.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260404_171220.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260404_171220.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260404_171220.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260404_171220.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260404_171220.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F381323i73E864FB58426931%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2220260404_171220.jpg%22%20alt%3D%2220260404_171220.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2220260404_171231.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260404_171231.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260404_171231.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260404_171231.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260404_171231.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260404_171231.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F381325i7006506CB8F06056%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2220260404_171231.jpg%22%20alt%3D%2220260404_171231.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2220260404_171422.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260404_171422.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260404_171422.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260404_171422.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260404_171422.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260404_171422.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F381324iF8917DE718BCF66E%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2220260404_171422.jpg%22%20alt%3D%2220260404_171422.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2346028%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2346028%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F259906%22%20target%3D%22_blank%22%3E%40Shane93%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E5%B0%B1%20RDDRONE-BMS772%20%E6%8F%90%E5%87%BA%E9%97%AE%E9%A2%98%E3%80%82%3CBR%20%2F%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E5%88%86%E4%BA%AB%E8%BF%99%E4%BA%9B%E6%9C%89%E7%94%A8%E7%9A%84%E5%9B%BE%E7%89%87%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E6%98%AF%E5%90%A6%E5%8F%AF%E4%BB%A5%E9%AA%8C%E8%AF%81%E7%84%8A%E6%8E%A5%E8%BF%9E%E6%8E%A5%E4%BB%A5%E7%A1%AE%E4%BF%9D%20%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%20%E9%85%8D%E7%BD%AE%E4%B8%BA%203S%EF%BC%9F%3CBR%20%2F%3E%E4%BB%8E%E5%9B%BE%E5%83%8F%E4%B8%AD%E7%9C%8B%E8%B5%B7%E6%9D%A5%20SJ2%20%E5%B7%B2%E8%BF%9E%E6%8E%A5%EF%BC%8C%E8%80%8C%20SJ12%20%E5%92%8C%20SJ10%20%E5%8F%AF%E8%83%BD%E6%B2%A1%E6%9C%89%E8%BF%9E%E6%8E%A5%EF%BC%9F%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E7%9A%84%E4%B8%87%E7%94%A8%E8%A1%A8%E5%85%B7%E6%9C%89%E7%94%B5%E9%98%BB%E6%B5%8B%E9%87%8F%E5%8A%9F%E8%83%BD%EF%BC%8C%E5%88%99%E5%8F%AF%E4%BB%A5%E8%BF%9B%E8%A1%8C%E6%A3%80%E6%9F%A5%EF%BC%88%E7%A7%BB%E9%99%A4%E7%94%B5%E9%98%BB%E4%B8%94%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%9C%AA%E9%80%9A%E7%94%B5%EF%BC%89%E3%80%82%3CBR%20%2F%3E%E6%9C%89%E5%85%B3%E7%94%B5%E6%B1%A0%E9%85%8D%E7%BD%AE%EF%BC%883S%EF%BC%89%E7%84%8A%E6%8E%A5%E8%B7%B3%E7%BA%BF%E7%9A%84%E6%9B%B4%E5%A4%9A%E4%BF%A1%E6%81%AF%EF%BC%8C%E8%AF%B7%E5%8F%82%E8%A7%81%3CA%20href%3D%22https%3A%2F%2Fnxp.gitbook.io%2Frddrone-bms772%2Fboard-user-guide%2Fgetting-started-with-the-rddrone-bms772%2Fconfiguring-the-hardware%23cell-terminal-connection%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%EF%BC%9A%3C%2FA%3E%3CA%20href%3D%22https%3A%2F%2Fnxp.gitbook.io%2Frddrone-bms772%2Fboard-user-guide%2Fgetting-started-with-the-rddrone-bms772%2Fconfiguring-the-hardware%23cell-terminal-connection%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fnxp.gitbook.io%2Frddrone-bms772%2Fboard-user-guide%2Fgetting-started-with-the-rddrone-bms772%2Fconfiguring-the-hardware%23cell-terminal-connection%3C%2FA%3E%20%3C%2FP%3E%0A%3CP%3E%E6%88%91%E6%B3%A8%E6%84%8F%E5%88%B0%E7%9A%84%E5%8F%A6%E4%B8%80%E4%BB%B6%E4%BA%8B%E6%98%AF%EF%BC%8C%E4%BD%A0%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E9%9D%A2%E5%8C%85%E6%9D%BF%E5%92%8C%E6%9D%9C%E9%82%A6%E8%B7%A8%E6%8E%A5%E7%BA%BF%E3%80%82%E8%AF%B7%E8%AE%B0%E4%BD%8F%EF%BC%8C%E4%BC%97%E6%89%80%E5%91%A8%E7%9F%A5%EF%BC%8C%E8%BF%99%E4%BA%9B%E8%BF%9E%E6%8E%A5%E9%83%BD%E5%BE%88%E7%B3%9F%E7%B3%95%E3%80%82%E6%88%91%E6%98%8E%E7%99%BD%EF%BC%8C%E4%B8%BA%E4%BA%86%E8%B0%83%E8%AF%95%EF%BC%8C%E8%BF%99%E5%8F%AF%E8%83%BD%E5%BE%88%E5%AE%B9%E6%98%93%E5%81%9A%E5%88%B0%E3%80%82%E4%BD%86%E9%9D%A2%E5%8C%85%E6%9D%BF%E5%92%8C%2F%E6%88%96%E5%AF%BC%E7%BA%BF%E8%BF%9E%E6%8E%A5%E4%B8%8D%E8%89%AF%E4%B9%9F%E5%8F%AF%E8%83%BD%E6%98%AF%E9%97%AE%E9%A2%98%E6%89%80%E5%9C%A8%E3%80%82%3CBR%20%2F%3E%E4%BB%8E%E5%9B%BE%E7%89%87%E4%B8%8A%E7%9C%8B%EF%BC%8C%E6%82%A8%E7%9A%84%E8%BF%9E%E6%8E%A5%E6%96%B9%E5%BC%8F%E6%B2%A1%E6%9C%89%E9%97%AE%E9%A2%98%E3%80%82%20%3C%2FP%3E%0A%3CP%3E%E6%88%91%E4%B9%9F%E5%BE%88%E5%A5%BD%E5%A5%87%E4%BD%A0%E7%9A%84%E8%AE%BE%E7%BD%AE%E3%80%82%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E4%BD%A0%E5%9C%A8%20CLI%2FUART%20%E5%91%BD%E4%BB%A4%E7%AA%97%E5%8F%A3%E4%B8%AD%E9%94%AE%E5%85%A5%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%EF%BC%9A%3CBR%20%2F%3E%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%20get%20all%20%3CBR%20%2F%3E%3CBR%20%2F%3E%E7%9C%8B%E5%88%B0%E4%BA%86%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E6%88%91%E6%83%B3%E6%9F%A5%E7%9C%8B%E6%82%A8%E9%85%8D%E7%BD%AE%E7%9A%84%20n%20%E4%B8%AA%E5%8D%95%E5%85%83%EF%BC%8C%E4%BE%8B%E5%A6%82%E9%BB%98%E8%AE%A4%E6%83%85%E5%86%B5%E4%B8%8B%E6%98%AF%206%20%E4%B8%AA%E5%8D%95%E5%85%83%E3%80%82%20%3CBR%20%2F%3E%E4%BD%A0%E5%8F%AF%E4%BB%A5%E5%9C%A8%E7%89%88%E6%9C%AC%E8%AF%B4%E6%98%8E%E7%9A%84%E7%AC%AC%206%20%E7%AB%A0%E5%85%A5%E9%97%A8%2F%E5%BF%AB%E9%80%9F%E5%85%A5%E9%97%A8%E6%8C%87%E5%8D%97%EF%BC%88%E7%AC%AC%209%20%E9%A1%B5%EF%BC%8C%E5%85%B1%2059%20%E9%A1%B5%EF%BC%89%E4%B8%AD%E6%89%BE%E5%88%B0%E9%9C%80%E8%A6%81%E6%9F%A5%E7%9C%8B%E7%9A%84%E5%91%BD%E4%BB%A4%EF%BC%9A%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXP-Robotics%2FRDDRONE-BMS772%2Fblob%2Fmain%2FBMS772_releaseNotes_6.0.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ERDDRONE-BMS772%2FBMS772_releaseNotes_6.0.pdf%20at%20main%20%C2%B7%20NXP-Robotics%2FRDDRONE-BMS772%20%C2%B7%20GitHub%3C%2FA%3E%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3EChapter%206.4.1%3A%20%E6%9C%80%E9%87%8D%E8%A6%81%E7%9A%84%20%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%20%E5%8F%98%E9%87%8F%E8%AE%A9%E6%82%A8%E7%9F%A5%E9%81%93%E5%9C%A8%E5%BC%80%E5%A7%8B%E4%BD%BF%E7%94%A8%20%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%20%E6%97%B6%E8%A6%81%E9%85%8D%E7%BD%AE%E4%BB%80%E4%B9%88%E3%80%82%E6%AF%94%E5%A6%82%20n%20%E4%B8%AA%E7%BB%86%E8%83%9E%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%BD%A0%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%E5%B0%86%20n%20%E4%B8%AA%E5%8D%95%E5%85%83%E6%9B%B4%E6%94%B9%E4%B8%BA%203%EF%BC%88%E5%9C%A8%E4%BD%A0%E7%9A%84%E4%BE%8B%E5%AD%90%E4%B8%AD%EF%BC%89%EF%BC%9A%3CBR%20%2F%3E%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%20set%20n-cells%203%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%E8%BF%99%E5%BA%94%E8%AF%A5%E7%A1%AE%E4%BF%9D%20%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%20%E4%B8%8D%E4%BC%9A%E6%A3%80%E6%9F%A5%E8%AE%BE%E7%BD%AE%E4%B8%AD%E4%B8%8D%E5%AD%98%E5%9C%A8%E7%9A%84%E5%85%B6%E4%BB%96%203%20%E4%B8%AA%E5%8D%95%E5%85%83%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%B8%8C%E6%9C%9B%E5%AF%B9%E6%82%A8%E6%9C%89%E6%89%80%E5%B8%AE%E5%8A%A9%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E8%A5%BF%E6%96%AF-%E8%8C%83%E7%B1%B3%E8%80%B6%E7%BD%97%3C%2FP%3E%0A%3CDIV%20id%3D%22tinyMceEditorcisvmierlo_1%22%20class%3D%22mceNonEditable%20lia-copypaste-placeholder%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2347106%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2347106%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%3C%2FA%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E4%BD%A0%E4%BB%AC%E7%9A%84%E5%B8%AE%E5%8A%A9%E3%80%82%E7%84%8A%E7%9B%98%E5%A5%BD%E5%83%8F%E6%98%AF%E8%BF%9E%E6%8E%A5%E5%9C%A8%E4%B8%80%E8%B5%B7%E7%9A%84%EF%BC%8C%E5%BD%93%E6%88%91%E8%BF%90%E8%A1%8C%20%22%20%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%20get%20all%20%22%20%E6%97%B6%E6%88%91%E4%BC%9A%E5%BE%97%E5%88%B0%E8%BF%99%E4%B8%AA%E9%80%80%E8%B4%A7%E3%80%82%E4%B8%8D%E8%BF%87%EF%BC%8C%E9%80%9A%E8%BF%87%E6%B5%8B%E9%87%8F%203%20%E4%B8%AA%E7%94%B5%E9%98%BB%E7%9A%84%E9%98%BB%E5%80%BC%EF%BC%8C%E5%8F%AF%E4%BB%A5%E5%BE%97%E5%87%BA%2012%20%E4%BC%8F%E3%80%818%20%E4%BC%8F%E3%80%814%20%E4%BC%8F%E5%92%8C%200%20%E4%BC%8F%E7%9A%84%E8%87%AA%E7%84%B6%E9%99%8D%E5%8E%8B%E5%80%BC%E3%80%82%20%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%E5%A4%8F%E6%81%A9%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22image_2026-04-08_115330382.png%22%20style%3D%22width%3A%20422px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image_2026-04-08_115330382.png%22%20style%3D%22width%3A%20422px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image_2026-04-08_115330382.png%22%20style%3D%22width%3A%20422px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image_2026-04-08_115330382.png%22%20style%3D%22width%3A%20422px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F381564i400DFD6906B5EBDB%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22image_2026-04-08_115330382.png%22%20alt%3D%22image_2026-04-08_115330382.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2357827%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2357827%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%3C%2FA%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E4%BD%A0%E4%BB%AC%E7%9A%84%E5%B8%AE%E5%8A%A9%E3%80%82%E7%94%B5%E8%B7%AF%E6%9D%BF%E8%83%8C%E9%9D%A2%E7%9A%84%E4%B8%A4%E4%B8%AA%E8%A1%A8%E9%9D%A2%E8%B4%B4%E8%A3%85%E7%94%B5%E9%98%BB%E5%99%A8%E5%8D%87%E8%B5%B7%EF%BC%8C%E5%AF%BC%E8%87%B4%E7%94%B5%E6%B1%A0%E8%AF%BB%E5%8F%96%E7%94%B5%E8%B7%AF%E5%87%BA%E7%8E%B0%E9%94%99%E8%AF%AF%E3%80%82%E7%8E%B0%E5%9C%A8%E9%97%AE%E9%A2%98%E5%B7%B2%E7%BB%8F%E8%A7%A3%E5%86%B3%EF%BC%8C%E5%86%8D%E6%AC%A1%E6%84%9F%E8%B0%A2%E6%82%A8%E3%80%82%E6%88%91%E8%BF%98%E6%9C%89%E6%9C%80%E5%90%8E%E4%B8%80%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%8C%E4%B9%9F%E8%AE%B8%E4%BD%A0%E8%83%BD%E5%B8%AE%E6%88%91%E8%A7%A3%E7%AD%94%E3%80%82%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20NI-XNET%20%E5%92%8C%20Cyphal%20CAN%20%E6%9E%84%E5%BB%BA%E8%87%AA%E5%B7%B1%E7%9A%84%E5%AE%9A%E5%88%B6%20CAN%20%E6%8E%A5%E5%8F%A3%E3%80%82%E6%82%A8%E8%83%BD%E5%91%8A%E8%AF%89%E6%88%91%20CAN%20%E5%B8%A7%E7%9A%84%E7%BB%93%E6%9E%84%E5%92%8C%E5%9C%B0%E5%9D%80%E5%90%97%EF%BC%9F%E5%8F%A6%E5%A4%96%EF%BC%8C%E6%98%AF%E5%90%A6%E6%9C%89%E5%8F%AF%E8%83%BD%E9%80%9A%E8%BF%87%20CAN%20%E6%8E%A7%E5%88%B6%20MOSFET%20%E6%9D%A5%E5%85%B3%E9%97%AD%E8%BE%93%E5%87%BA%E7%94%B5%E5%8E%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%E5%A4%8F%E6%81%A9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2358374%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2358374%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F259906%22%20target%3D%22_blank%22%3E%40Shane93%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E5%BE%88%E9%AB%98%E5%85%B4%E6%82%A8%E5%8F%91%E7%8E%B0%E4%BA%86%202%20%E4%B8%AA%20SMD%20%E7%94%B5%E9%98%BB%E5%99%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E6%84%9F%E8%B0%A2%E6%82%A8%E5%88%86%E4%BA%AB%E8%BF%99%E4%B8%80%E4%BF%A1%E6%81%AF%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E7%9B%B8%E4%BF%A1%20CyphalCAN%20%E5%92%8C%20DroneCAN%20%E7%9A%84%E4%BF%A1%E6%81%AF%E9%83%BD%E5%8F%AF%E4%BB%A5%E5%9C%A8%E7%89%88%E6%9C%AC%E8%AF%B4%E6%98%8E%E4%B8%AD%E6%89%BE%E5%88%B0%E3%80%82%3CBR%20%2F%3E%E5%AE%83%E5%B0%86%E6%8F%90%E5%88%B0%E5%93%AA%E4%BA%9B%E4%BF%A1%E6%81%AF%E5%B7%B2%E8%A2%AB%E6%89%A7%E8%A1%8C%E3%80%82%20%3C%2FP%3E%0A%3CP%3E%E4%B8%A4%E7%A7%8D%E5%8D%8F%E8%AE%AE%E4%B8%AD%E9%83%BD%E6%B2%A1%E6%9C%89%E5%8F%AF%E4%BB%A5%E5%85%B3%E9%97%AD%E7%94%B5%E6%BA%90%E5%BC%80%E5%85%B3%E7%9A%84%E7%9B%B4%E6%8E%A5%E4%BF%A1%E6%81%AF%E3%80%82%20%3CBR%20%2F%3E%E4%BD%BF%E7%94%A8DroneCan%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E8%BD%BB%E6%9D%BE%E6%9B%B4%E6%94%B9%E8%AE%BE%E7%BD%AE%EF%BC%8C%E5%B9%B6%E5%8F%AF%E8%83%BD%E9%80%A0%E6%88%90%E9%94%99%E8%AF%AF%EF%BC%8C%E5%AF%BC%E8%87%B4%E7%94%B5%E6%B1%A0%E7%AE%A1%E7%90%86%E7%B3%BB%E7%BB%9F%E5%85%B3%E9%97%AD%E7%94%B5%E6%BA%90%E3%80%82%E4%BE%8B%E5%A6%82%EF%BC%8C%E6%9B%B4%E6%94%B9%E8%B6%85%E6%B8%A9%E8%AE%BE%E7%BD%AE%E3%80%82%20%3CBR%20%2F%3E%E4%BD%A0%E5%BA%94%E8%AF%A5%E8%83%BD%E5%A4%9F%E5%B0%86%E8%AE%BE%E7%BD%AE%E6%94%B9%E5%9B%9E%20%22%20good%20%22%20%E5%80%BC%E5%B9%B6%20RESET%20%E6%95%85%E9%9A%9C%E3%80%82%3CBR%20%2F%3E%E8%BF%99%E5%B7%B2%E9%80%9A%E8%BF%87%20DroneCAN%20%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%B5%8B%E8%AF%95%E3%80%82%20%3C%2FP%3E%0A%3CP%3E%E4%BD%86%E5%A6%82%E6%9E%9C%E6%82%A8%E8%A6%81%E5%88%9B%E5%BB%BA%E8%87%AA%E5%B7%B1%E7%9A%84%E8%87%AA%E5%AE%9A%E4%B9%89%20CAN%20%E7%95%8C%E9%9D%A2%EF%BC%8C%E5%88%99%E5%8F%AF%E4%BB%A5%E8%87%AA%E5%B7%B1%E6%B7%BB%E5%8A%A0%E8%BF%99%E4%B8%80%E5%8A%9F%E8%83%BD%E3%80%82%20%3C%2FP%3E%0A%3CP%3E%E5%B8%8C%E6%9C%9B%E5%AF%B9%E6%82%A8%E6%9C%89%E6%89%80%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3ECis%3C%2FP%3E%3C%2FLINGO-BODY%3E
