RDDRONE-BMS772
RDDRONE-BMS772
108,676件の閲覧回数
iaingalloway
Please ask questions about the RDDRONE-BMS772 board and software here
115 返答(返信)
14,743件の閲覧回数
Airobot-Dynamics
A1007 Secure Authenticator
Hi community, I have just started developing with the BMS772. However, I can not find any information on the A1007 IC.
I can not even find this IC on the NXP site of any of our usual suppliers, Digi-Key etc.
Is this IC obsolete?
If so, are there any suggested alternative.
14,717件の閲覧回数
cisvmierlo
Hi @Airobot-Dynamics
In the following NXP community page it is stated that the documentation and software is available on DocStore. It also explains how to get access to DocStore.
So I believe the A1007 is available under NDA only.
Link to the NXP community page: https://community.nxp.com/t5/Other-NXP-Products/OM67201UL-driver-A1007/m-p/1447573
If you are looking to build something yourself, I would recommend to look at the common available NXP IoT Security and Authentication Portfolio: https://www.nxp.com/iotsecurity
For example, the SE050 or SE051 is a greatly supported device, with lots of use cases already implemented.
If you would like to develop on a board with an SE050 and a similar MCU (S32K146 instead of S32K144). The UCANS32K146 might be an interesting product.
Link to the SE050: https://www.nxp.com/products/security-and-authentication/authentication/edgelock-se050-plug-trust-se...
Link to the UCANS32K146https://www.nxp.com/design/development-boards/automotive-development-platforms/s32k-mcu-platforms/s3...
I hope this answers your questions, kind regards,
Cis van Mierlo
15,427件の閲覧回数
Airobot-Dynamics
Thank you @cisvmierlo.
Very useful information.
15,605件の閲覧回数
Prince1
I bought a new RDDRONE-BMS772 board and want to use it for 4S LiPo battery pack. I have soldered Cell terminal connector and Solder jumper pins (SJ) for 4S. After connecting to 4S pack, When I measured the output voltage it is 0V. I don't know why.
Shall I do any configuration change(for 4S) in the software also? If so, how? Please reply.
Thanks in advance.
15,353件の閲覧回数
iaingalloway
Note that if you want to just use the serial console to see what is going on internally (and not reprogram and debug the board) Then you can buy any FTDI type USB-UART cable (or use a PC with a UART) to connect a serial console to the BMS772. Normally this is broken out on the DCD-LZ board so it can be plugged in easily.
Here is the type of cable you would buy at Amazon or Digikey or whereever:
https://www.digikey.com/en/products/detail/ftdi-future-technology-devices-international-ltd/TTL-234X...
You would then use a JST-GH connector to attach to the RX TX and GND pins of the DCD-LZ interface on the BMS - do NOT connect the power from the FTDI cable to the DCD-LZ:
The pinout is shown here:
https://nxp.gitbook.io/hovergames/rddrone-fmuk66/connectors/debug-interface-dcd-lz/dcd-lz-breakout-b...
15,660件の閲覧回数
Prince1
Hi iaingalloway,
Thanks for your reply.
I want to change the BMS configuration from default 3S to 4S and also change battery chemistry through serial console. Is FTDI type USB-UART cable connected to JST GH 7 pin connector (only Tx, Rx, GND pins) is sufficient for this?
I am also trying to get J link EDU mini debugger to update firmware, but it's lead time is 40 weeks. So, Just trying to update configuration parameters as of now.
Thanks..
16,719件の閲覧回数
cisvmierlo
Hi @Prince1
Yes you only need to connect GND, TX and RX as seen in this screenshot:
Keep in mind that a USB-TTL-3V3 is used, this ensures 3.3V logic level on the RX and TX pins.
Kind regards,
Cis van Mierlo
16,491件の閲覧回数
Prince1
I have PL2303HX USB To TTL(Serial) Converter which provides 3.3V on Tx, Rx and GND.
https://robu.in/product/pl2303-pl2303hx-usb-ttl-module-5-pin/
With this Can I attempt software reconfiguration?
PL2303HX will be inserted in USB port and its TX, RX, GND pins are connected to respective pins in J19 port. Do I need to connect battery also to BMS (to J4) to power it's circuit? If so, 4S or 3S battery?
As in my BMS, 4S cell terminal connector is soldered in JP1 and SJ3, SJ7, SJ11 and SJ12 are connected, but its factory default configuration in software is 3S. So, I am confused.
Thanks..
16,479件の閲覧回数
GeraldP
Hi @Prince1, the SW will just report an error and power out will be not enabled if you have a battery connected that has different cell numbering than configured.
Battery needs to be connected to be able to configure the BMS.
So the way to setup the BMS is:
- connect your UART adapter and open terminal SW with 115k2 8n1 serial port setting.
- Connect balancer and main power connector of battery to the BMS
- see bootup sequence First start-up - RDDRONE-BMS772 (gitbook.io)
- configure the bms via command line Command Line Interface (CLI) - RDDRONE-BMS772 (gitbook.io)
   bms set <parameter name> <value> Parameters of the BMS - RDDRONE-BMS772 (gitbook.io)
- finish with bms save
if you type reboot the BMS will reboot with correct settings and will activate output in case no errors.
16,684件の閲覧回数
Prince1
Hi GeraldP,
I have done the following on a new BMS,
SJ6, 10, 11, 12 are shorted for 3S configuration.
3S LiPo battery is connected to J4 and their cell balancing wires connected to JP1
pins 5, 4, 1 of FTDI USB UART are connected to pins 2, 3, 7 of J19 respectively and then connected to PC
115k2 8n1, Parity: None, Flow: None configured in COM port properties and Tera Term
The result is as follows,
BMS LED is blinking in red colour and then goes OFF after around 1min. I think it goes to SLEEP.
BMS output voltage at J5 is zero (load is not connected)
Tera Term window displays blank screen and doesn't take keyboard input
Display connected to J23 doesn't turn ON
Kindly help me in sorting out above issues.
I tried the same things on another BMS, in which LED doesn't turn ON and SBC chip is getting over heated.
Thanks..
16,662件の閲覧回数
cisvmierlo
Hi @Prince1,
"BMS LED is blinking in red colour and then goes OFF after around 1min. I think it goes to SLEEP."
This indicates that there is a cell under-voltage detected (based on default battery technology: LiPo).
When this happens, the BMS goes to DEEP_SLEEP after t-fault-timeout (60s default) in order to preserve the battery with its lowest power mode.
In that DEEP_SLEEP state the MCU (and SBC) is turned off, so no communication is possible after that 1 min. The button is press (or a re-power) is the only thing to wake the BMS from the DEEP_SLEEP state.
So it could be that there is no communication because the BMS entered the DEEP_SLEEP.
Or there would be something with the connection.
For the display to turn on during initialization, could you maybe check that D34 is placed instead of D35?
For the other BMS setup, the SBC overheating and LED not turning on, indicates that there might be a short on the 3.3V domain (shorted to gnd).
Could you maybe show both of your boards (top and bottom side)?
Kind regards,
Cis van Mierlo
16,655件の閲覧回数
Prince1
Hi Cis van Mierlo,
BMS default V-cell-UV may be 3V, but my all battery cell voltages are beyond 3.8V and 3S pack voltage is 11.5V. I think under voltage is not the reason for BMS going into Deep_Sleep.
Please mention what could be other reasons for BMS LED blinking in red for 1min and then going into Deep_Sleep.
D34 is placed, D35 not placed. Still Display doesn't turn on. Display pin numbers are connected as suggested.
I will share the images of other BMS board with over heating issue.
Thanks..
16,636件の閲覧回数
cisvmierlo
Hi @Prince1,
Only with a cell under voltage detection it will go to deep-sleep after 1 min.
Maybe there is something with the cell connections.
could you perhaps share images of this board as well (top and bottom)?
Kind regards,
Cis van Mierlo
31,784件の閲覧回数
Prince1
Hi @CisvanMierlo,
I have attached images of two BMSes,
1st one: LED blinks in red for 1 min before going to Deep_Sleep.
2nd one: has over heat issue and LED doesn't turn ON.
Though I have used 5 pin cell terminal connector, I have not connected 4S pin (5th pin open) / wire. So, 5 pin connector is used for 3S battery. Voltages are correct at JP1 connector.
Today I charged battery to 11.7V and tested still same result.
Thanks..
31,537件の閲覧回数
cisvmierlo
Hi @Prince1,
I think I found the issue with the communication on BMS1.
The black wire is connected to J19 pin 1, which is 3.3V and not connected to ground.
For ground, you need to connect the black wire to J19 pin 7 (other side of the connector).
Light blue is now connected to J19 pin 5 (SWD_CLK) and yellow is now connected to J19 pin 6 (RST_N).
I think you need to swap the connections on the connector J19.
I will come back on the other PCB later.
Kind regards,
Cis van Mierlo
31,086件の閲覧回数
Prince1
Hi @cisvmierlo ,
Thanks a lot.
You solved my problem.
After rectifying J19 connections, CLI and Display worked.
Yes, CLI shows "Cell undervoltage detected!" and display shows 11.26V although fluke instrument measures 11.7V.
1. It looks if cell voltages < 3.8V, it goes to Deep_Sleep. Will it happen even if load is connected on J5? I mean, if load is connected disconnecting the battery at 3.8V is too early when cell cutoff voltage is 3V.
2. Is it possible to reduce the voltage measurement error in BMS?
Kindly answer the above questions.
Thanks..
31,212件の閲覧回数
cisvmierlo
Hi @Prince1,
Great that the communication issue has been resolved!
For the other questions:
"Yes, CLI shows "Cell under voltage detected!" and display shows 11.26V although fluke instrument measures 11.7V."
The display shows v-out. Which is measured via a resistor divider on the output with 1% tolerance. Meaning that you could have a 0.946V difference on 26V, just because of the resistor tolerances.
So it could be that this is a little off with the actual value. In the current SW example there is no option to fine tune this measurement.
What you could do is: look at v-batt or add all the cell voltages together (which is the most precise). Vtot = v-cell1 + v-cell2 + ..
"1. It looks if cell voltages < 3.8V, it goes to Deep_Sleep. Will it happen even if load is connected on J5? I mean, if load is connected disconnecting the battery at 3.8V is too early when cell cutoff voltage is 3V."
So the default cell under voltage (for a LiPo battery) is set at 3V. You could check this setting via the UART interface via:
bms get v-cell-uv
You could set the cell under voltage you think is suitable with: "bms set v-cell-uv x.xV"
After setting parameters, do not forget to save it to flash with "bms save".
For more information on which parameters there are, please have a look at chapter 8.2 of BMS772_releaseNotes_5.0.pdf.
But I would check the cell voltages via the UART connection, so you can see which cell has a problem.
You can use: "bms get all" (gets all parameters),  "bms show all 1" (updates the battery values), "bms show top 1" (updates the battery values without scrolling).
"2. Is it possible to reduce the voltage measurement error in BMS?"
As stated in the beginning, there is no parameter for correcting the v-out voltage.
But feel free to adjust the SW yourself so for example v-batt is displayed on the display instead of v-out.
Kind regards,
Cis van Mierlo
31,170件の閲覧回数
Prince1
Hi @cisvmierlo,
Thanks for your help. I could solve Under voltage fault problem. Now I want to see DroneCAN / UAVCAN messages / parameters sent by BMS in some software tool.
Do you have some software GUI tool to see CAN messages from BMS?
I tried to see messages with DroneCAN GUI tool with BMS772 connected to Orange Cube Autopilot. But I am not successful. Mission planner software didn't recognize BMS in SLCAN mode.
Where as Cube orange detects other UAVCAN devices such as Zubax ESC, Packet digital MPPT.
Also, Should I change DroneCAN static node ID to other than 255 for it to work?
NXP's UCAN based nodes are not available for purchase in India.
Also, please clarify whether Over current, output short circuit protection is available on BMS?
Please clarify the above. Thanks again for your great support.
31,552件の閲覧回数
Prince1
Hi GeraldP,
Thanks for your help. I will try the way you suggested.
32,134件の閲覧回数
cisvmierlo
Hi @Prince1,
Indeed you would need to configure the software accordingly.
This can be done as followed:
1. Hook up the DCD-LZ adapter to the BMS772 board using the 7-pins JST-GH cable.
2. Hook up the DCD-LZ adapter to a laptop or PC with a FTDI USBUART-3V3 cable.
3. Connect to the BMS772 over a serial interface, like PuTTY or TeraTerm (115200 Baud).
4. Type "bms help" to get the help for the Command Line Interface (CLI).
5. Type "bms get all" to get all the parameters and the values associated with those parameters.
6. Change the variable you would like to change, in this case n-cells to 4, type: "bms set n-cells 4"
7. To make sure the parameters are saved to flash, type: "bms save"
8. After the new parameter settings, you could either press the button or type: "bms reset" to reset the fault.
The CLI is very useful as it will indicate what caused the error.
Here are some useful links to get started:
A link about setting up the CLI: https://nxp.gitbook.io/rddrone-bms772/user-guide/getting-started-with-the-rddrone-bms772/using-the-c...
A link about using the CLI: https://nxp.gitbook.io/rddrone-bms772/software-guide-nuttx/command-line-interface-cli
A link with a list of parameters: https://nxp.gitbook.io/rddrone-bms772/software-guide-nuttx/untitled-1
Chapter 7 of the release notes (rev. 5) is useful as well as this contains a picture of the DCD-LZ adapter with the 7-pins JST GH cable and the USB-TTL-3V3 cable connected to it.
Chapter 8 includes the parameters of the BMS772.
I would recommend the update the software to the latest binary.
The latest binary can be found at: https://github.com/NXPHoverGames/RDDRONE-BMS772/tree/main/Binary
Instructions can be found in chapter 7 of the release notes, on the code repository or on the gitbook: https://nxp.gitbook.io/rddrone-bms772/user-guide/getting-started-with-the-rddrone-bms772/flashing-fi...
Keep in mind that after programming, you need to re-configure the parameters again as these get overwritten.
I hope this helps, kind regards,
Cis van Mierlo
32,138件の閲覧回数
Prince1
Thanks for your quick reply. Unfortunately, I couldn't find distributor to purchase DCD-LZ adapter in India. I don't have a hover games kit as well.
Can you suggest any alternative adapter which is widely available?
Thanks.
%3CLINGO-SUB%20id%3D%22lingo-sub-1093111%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1093111%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3ERDDRONE-BMS772%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A8%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%81%94%E8%B3%AA%E5%95%8F%E3%81%AF%E3%80%81%E3%81%93%E3%81%A1%E3%82%89%E3%81%BE%E3%81%A7%E3%81%8A%E5%95%8F%E3%81%84%E5%90%88%E3%82%8F%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2295106%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2295106%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F258869%22%20target%3D%22_blank%22%3E%40xete%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%0A%3CP%3EIC%20%E3%81%AF%E9%9B%BB%E6%BA%90%E3%81%8C%E5%85%A5%E3%81%A3%E3%81%A6%E3%81%84%E3%81%A6%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E4S%20%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%20(LiPo%20%E3%81%BE%E3%81%9F%E3%81%AF%20LiFePO4%20%E3%81%AE%E4%B8%A1%E6%96%B9)%20%E3%81%AF%E7%A2%BA%E3%81%8B%E3%81%AB%E6%AD%A3%E3%81%97%E3%81%84%E4%BE%9B%E7%B5%A6%E7%AF%84%E5%9B%B2%E5%86%85%E3%81%A7%E3%81%99%E3%80%82%E3%81%9D%E3%82%8C%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%E5%AE%8C%E5%85%A8%E3%81%AA%E5%88%87%E6%96%AD%20(%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%80%81%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9E%E3%83%BC%E3%80%81%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9)%20%E3%81%8C%E5%BD%B9%E7%AB%8B%E3%81%A4%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3E%E6%8E%A5%E7%B6%9A%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%A7%E3%81%82%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%E9%80%9F%E5%BA%A6%E3%82%92%E9%81%85%E3%81%8F%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%AF%E3%81%84%E3%81%8B%E3%81%8C%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3CBR%20%2F%3E%E9%95%B7%E3%81%84%E3%83%AF%E3%82%A4%E3%83%A4%E3%81%A8%E3%83%94%E3%83%B3%E3%82%B3%E3%83%B3%E3%83%90%E3%83%BC%E3%82%BF%E3%81%AF%E6%9C%80%E5%A4%A7%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%E9%80%9F%E5%BA%A6%E3%81%AB%E5%BD%B1%E9%9F%BF%E3%82%92%E4%B8%8E%E3%81%88%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E7%8F%BE%E5%9C%A8%201000kHz%E3%80%81%E3%80%8C1000%E3%80%8D%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%80%8C100%E3%80%8D%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F100kHz%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%E9%80%9F%E5%BA%A6%3F%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%AE%E5%86%99%E7%9C%9F%E3%82%92%E3%82%A2%E3%83%83%E3%83%97%E3%83%AD%E3%83%BC%E3%83%89%E3%81%A7%E3%81%8D%E3%82%8C%E3%81%B0%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%8C%E6%98%8E%E3%82%89%E3%81%8B%E3%81%AB%E3%81%AA%E3%82%8B%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%3CSPAN%3E%E3%81%BE%E3%81%9F%E3%81%AF%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9E%E3%83%BC%20%E3%83%94%E3%83%B3%E3%81%AB%E9%9B%BB%E5%9C%A7%E3%82%92%E4%BE%9B%E7%B5%A6%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20MCU%20%E3%81%8C%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E7%8A%B6%E6%85%8B%E3%81%AB%E7%B6%AD%E6%8C%81%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%20VTref%20%E3%81%8C%E4%BD%95%E3%81%A7%E3%81%82%E3%82%8B%E3%81%8B%E3%82%92%E7%9F%A5%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E8%88%88%E5%91%B3%E6%B7%B1%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%B7%E3%82%B9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2295098%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2295098%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%97%A9%E9%80%9F%E3%81%AE%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E7%A7%81%E3%81%AF%204S%20%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%81%A7%20BMS%20%E3%81%AB%E9%9B%BB%E5%8A%9B%E3%82%92%E4%BE%9B%E7%B5%A6%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E5%87%BA%E5%8A%9B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%813.3V%20TTL%20%E3%81%8B%E3%82%89%20USB%20%E3%82%82%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82LCD%20%E7%94%BB%E9%9D%A2%E3%81%A8%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%80%81BMS%20%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AA%E7%8A%B6%E6%85%8B%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%B8%8B%E8%A8%98%E3%81%AE%E3%83%94%E3%83%B3%E9%85%8D%E5%88%97%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%20J%20Link%20Compact%20Plus%20%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%83%88%E3%83%A9%E3%83%96%E3%83%AB%E3%82%B7%E3%83%A5%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%E6%83%85%E5%A0%B1%E3%82%84%E6%8F%90%E6%A1%88%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AA%E5%A0%B4%E5%90%88%E3%81%AF%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22xete_0-1768570899050.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xete_0-1768570899050.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xete_0-1768570899050.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xete_0-1768570899050.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xete_0-1768570899050.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xete_0-1768570899050.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xete_0-1768570899050.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xete_0-1768570899050.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xete_0-1768570899050.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xete_0-1768570899050.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F373199i227E45D69D530B2D%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22xete_0-1768570899050.png%22%20alt%3D%22xete_0-1768570899050.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2295081%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2295081%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F258869%22%20target%3D%22_blank%22%3E%40xete%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%0A%3CP%3E%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E8%A8%AD%E5%AE%9A%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%A9%B3%E3%81%97%E3%81%8F%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3ERDDRONE-BMS772%20%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E9%9B%BB%E6%BA%90%E3%82%92%E4%BE%9B%E7%B5%A6%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%3CBR%20%2F%3ERDDRONE-BMS772%20%E3%81%AE%20RGB%20LED%20%E3%81%AE%E7%8A%B6%E6%85%8B%E3%81%AF%E3%81%A9%E3%81%86%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3E%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E5%95%8F%E9%A1%8C%E3%81%AE%E8%A7%A3%E6%B1%BA%E3%82%92%E6%94%AF%E6%8F%B4%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%AE%E5%86%99%E7%9C%9F%E3%81%8C%E5%BD%B9%E7%AB%8B%E3%81%A1%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%95%AC%E5%85%B7%3C%2FP%3E%0A%3CP%3E%E3%82%B7%E3%82%B9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2295079%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2295079%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%20BMS%20%E3%81%AB%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81SWD%20%E7%B5%8C%E7%94%B1%E3%81%A7%E6%8E%A5%E7%B6%9A%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%81%93%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22xete_0-1768568009515.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xete_0-1768568009515.png%22%20style%3D%22width%3A%20376px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xete_0-1768568009515.png%22%20style%3D%22width%3A%20376px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xete_0-1768568009515.png%22%20style%3D%22width%3A%20376px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xete_0-1768568009515.png%22%20style%3D%22width%3A%20376px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xete_0-1768568009515.png%22%20style%3D%22width%3A%20376px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xete_0-1768568009515.png%22%20style%3D%22width%3A%20376px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xete_0-1768568009515.png%22%20style%3D%22width%3A%20376px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xete_0-1768568009515.png%22%20style%3D%22width%3A%20376px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xete_0-1768568009515.png%22%20style%3D%22width%3A%20376px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F373194i33943E5395F278C4%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22xete_0-1768568009515.png%22%20alt%3D%22xete_0-1768568009515.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1833766%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1833766%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%AF%E3%81%84%E3%80%81%E7%8F%BE%E5%9C%A8%E3%80%81DroneCAN%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E5%90%AB%E3%82%80%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%20%E3%82%BD%E3%83%BC%E3%82%B9%20BMS772%20%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%20SW%20%E3%81%AE%E6%AC%A1%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E5%80%99%E8%A3%9C%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1833144%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1833144%22%20slang%3D%22en-US%22%20mode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id%3D%22lingo-sub-1734010%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1734010%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E5%85%85%E9%9B%BB%E5%99%A8%E3%81%AE%E9%9B%BB%E5%9C%A7%E3%81%8C%E4%BD%8E%E4%B8%8B%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%E5%85%85%E9%9B%BB%E5%99%A8%E3%81%AF%E3%82%AA%E3%83%95%E3%81%AE%E3%81%BE%E3%81%BE%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%81%84%E3%81%84%E3%81%88%E3%80%81%E3%81%93%E3%81%AE%E6%99%82%E7%82%B9%E3%81%A7%E3%81%AF%E5%85%85%E9%9B%BB%E5%99%A8%E3%81%AF%E3%82%AA%E3%83%B3%E3%81%AE%E3%81%BE%E3%81%BE%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81%E9%9B%BB%E6%B5%81%E3%81%AE%E6%B6%88%E8%B2%BB%E3%81%8C%E5%81%9C%E6%AD%A2%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E5%85%85%E9%9B%BB%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%81%8C%E5%86%8D%E9%96%8B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E5%B0%86%E6%9D%A5%E7%9A%84%E3%81%AB%E3%81%AF%E3%80%81%E3%83%95%E3%83%AB%E5%85%85%E9%9B%BB%E6%99%82%E3%81%AB%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E5%88%B6%E5%BE%A1%E5%8F%AF%E8%83%BD%E3%81%AA%E5%85%85%E9%9B%BB%E5%99%A8%E3%82%92%E5%AE%9F%E8%A3%85%E3%81%99%E3%82%8B%E4%BA%88%E5%AE%9A%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E3%80%81%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%82%88%E3%82%8A%E3%82%82%E9%9B%BB%E5%9C%A7%E3%81%8C%E4%BD%8E%E3%81%8F%E3%80%81%E5%85%85%E9%9B%BB%E5%99%A8%E3%81%8C%E9%9B%BB%E6%B5%81%E3%81%AE%E5%90%B8%E5%8F%8E%E3%81%8B%E3%82%89%E4%BF%9D%E8%AD%B7%E3%81%95%E3%82%8C%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%81%84%E3%81%84%E3%81%88%E3%80%81%E5%85%85%E9%9B%BB%E5%99%A8%E3%81%AF%E3%83%95%E3%83%AB%E5%85%85%E9%9B%BB%E3%82%92%E9%81%94%E6%88%90%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E9%9B%BB%E5%9C%A7%E3%81%8C%E3%82%8F%E3%81%9A%E3%81%8B%E3%81%AB%E9%AB%98%E3%81%8F%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E9%80%86%E9%9B%BB%E6%B5%81%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%E3%82%82%E4%BF%9D%E8%AD%B7%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EBMS%20%E3%81%8C%E5%85%85%E9%9B%BB%E5%99%A8%E3%81%8C%E5%88%87%E6%96%AD%E3%81%95%E3%82%8C%E3%81%9F%E3%81%A8%E5%88%A4%E6%96%AD%E3%81%99%E3%82%8B%E9%9B%BB%E5%9C%A7%E3%83%AC%E3%83%99%E3%83%AB%E3%82%92%E4%B8%8A%E3%81%92%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%E3%81%93%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E3%82%B3%E3%83%B3%E3%83%94%E3%83%A5%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%AE%E3%83%96%E3%83%A9%E3%82%A6%E3%83%B3%E3%82%A2%E3%82%A6%E3%83%88%E3%82%92%E9%98%B2%E3%81%90%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81%E5%85%85%E9%9B%BB%E7%8A%B6%E6%85%8B%E3%81%AB%E6%88%BB%E3%82%8A%E3%80%81%E9%81%8E%E5%85%85%E9%9B%BB%E3%81%8B%E3%82%89%E4%BF%9D%E8%AD%B7%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E5%95%8F%E9%A1%8C%E3%81%AE%E4%BB%A3%E6%9B%BF%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%81%A8%E3%81%97%E3%81%A6%E3%80%81UPS%20%E3%82%82%E7%B5%B1%E5%90%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%94%E5%8D%94%E5%8A%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%20%3CLI-EMOJI%20id%3D%22lia_slightly-smiling-face%22%20title%3D%22%3Aslightly_smiling_face%3A%22%3E%3C%2FLI-EMOJI%3E%26nbsp%3B%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1733969%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1733969%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E7%9A%86%E3%81%95%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3ECLI%20%E3%81%8B%E3%82%89%E9%9A%9C%E5%AE%B3%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E7%A8%AE%E9%A1%9E%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AF%E3%81%82%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%E7%8A%B6%E6%85%8B%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%20(bms%20get%20state%20%3D%26gt%3B%20FAULT)%20%E3%81%8C%E3%80%81%E9%81%8E%E9%9B%BB%E5%9C%A7%E3%81%AA%E3%81%A9%E3%81%AE%E9%9A%9C%E5%AE%B3%E3%81%AE%E7%A8%AE%E9%A1%9E%E3%82%92%E5%8F%96%E5%BE%97%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%86%E3%81%A7%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%A7%E3%81%9D%E3%82%8C%E3%82%92%E5%AE%9F%E8%A3%85%E3%81%99%E3%82%8B%E6%9C%80%E8%89%AF%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AE%E3%82%AC%E3%82%A4%E3%83%80%E3%83%B3%E3%82%B9%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%94%E5%9B%9E%E7%AD%94%E3%82%92%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%83%AB%E3%82%A4%E3%82%B9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1732104%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1732104%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%AB%E3%82%A4%E3%82%B9%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E8%A9%B1%E3%82%92%E8%AA%AD%E3%82%93%E3%81%A7%E3%80%81BMS%20%E3%81%AF%E5%85%85%E9%9B%BB%E5%AE%8C%E4%BA%86%E7%8A%B6%E6%85%8B%E3%81%AB%E3%81%82%E3%82%8B%E3%81%A8%E6%8E%A8%E6%B8%AC%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%81%AE%E9%81%8E%E5%85%85%E9%9B%BB%E3%82%92%E9%98%B2%E3%81%90%E3%81%9F%E3%82%81%E3%81%AB%E9%9B%BB%E6%BA%90%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%E3%80%81%E3%81%BE%E3%81%A0%E5%8F%96%E3%82%8A%E4%BB%98%E3%81%91%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%83%BB%E3%83%81%E3%83%A3%E3%83%BC%E3%82%B8%E3%83%A3%E3%81%8C%E4%BE%9B%E7%B5%A6%E3%81%A7%E3%81%8D%E3%82%8B%E4%BB%A5%E4%B8%8A%E3%81%AE%E9%9B%BB%E6%B5%81%E3%82%92%E5%BC%95%E3%81%8D%E5%87%BA%E3%81%99%E3%81%A8%E3%80%81%E9%9B%BB%E5%9C%A7%E3%81%8C%E4%BD%8E%E4%B8%8B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%85%85%E9%9B%BB%E5%AE%8C%E4%BA%86%E7%8A%B6%E6%85%8B%E3%81%A7%E3%81%AF%E3%80%81%E9%9B%BB%E6%BA%90%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%81%8C%E9%96%8B%E3%81%84%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%81%8B%E3%82%89%E9%9B%BB%E6%B5%81%E3%81%AF%E6%B5%81%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82BMS%20%E3%81%AF%E5%87%BA%E5%8A%9B%E9%9B%BB%E5%9C%A7%E3%82%92%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%80%81%E5%85%85%E9%9B%BB%E5%99%A8%E3%81%8C%E5%88%87%E6%96%AD%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E5%85%85%E9%9B%BB%E5%99%A8%E3%81%AB%E3%81%93%E3%81%AE%E9%9B%BB%E5%9C%A7%E9%99%8D%E4%B8%8B%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%80%81%E3%81%93%E3%81%AE%E9%99%8D%E4%B8%8B%E3%81%8C%20BMS%20%E3%81%8C%E5%85%85%E9%9B%BB%E5%99%A8%E3%81%8C%E5%88%87%E6%96%AD%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E5%88%A4%E6%96%AD%E3%81%99%E3%82%8B%E3%81%BB%E3%81%A9%E4%BD%8E%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81%E5%85%85%E9%9B%BB%E5%99%A8%E3%81%AF%E3%82%B9%E3%83%AA%E3%83%BC%E3%83%97%E7%8A%B6%E6%85%8B%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E9%9B%BB%E6%BA%90%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%82%92%E9%96%89%E3%81%98%E3%82%8B%E5%89%8D%E3%81%AB%E3%80%81%E3%81%BE%E3%81%9A%20MCU%20%E3%82%92%E8%B6%85%E4%BD%8E%E9%9B%BB%E5%8A%9B%E5%AE%9F%E8%A1%8C%20(VLPR)%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%80%81%E4%BB%96%E3%81%AE%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%82%82%E4%BD%8E%E9%9B%BB%E5%8A%9B%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%85%85%E9%9B%BB%E5%99%A8%E3%81%AE%E9%9B%BB%E5%9C%A7%E3%81%8C%E4%BD%8E%E4%B8%8B%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%E5%85%85%E9%9B%BB%E5%99%A8%E3%81%AF%E3%82%AA%E3%83%95%E3%81%AE%E3%81%BE%E3%81%BE%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E3%80%81%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%82%88%E3%82%8A%E3%82%82%E9%9B%BB%E5%9C%A7%E3%81%8C%E4%BD%8E%E3%81%8F%E3%80%81%E5%85%85%E9%9B%BB%E5%99%A8%E3%81%AF%E9%9B%BB%E6%B5%81%E3%81%AE%E5%90%B8%E5%8F%8E%E3%81%8B%E3%82%89%E4%BF%9D%E8%AD%B7%E3%81%95%E3%82%8C%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%95%AC%E5%85%B7%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%82%B7%E3%82%B9%E3%83%BB%E3%83%95%E3%82%A1%E3%83%B3%E3%83%BB%E3%83%9F%E3%82%A8%E3%83%AB%E3%83%AD%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1731794%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1731794%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3ECis%20van%20Mierlo%E3%81%95%E3%82%93%E3%80%81%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%A8%E3%81%A6%E3%82%82%E5%8A%A9%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%85%85%E9%9B%BB%E5%99%A8%E3%81%AE%E9%9B%BB%E5%9C%A7%E3%81%8C%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%83%83%E3%83%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81N%20%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%80%81P%20%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%20MOSFET%20%E3%81%A8%20RC%20%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%20%E3%83%94%E3%83%B3%E3%82%92%E4%B8%80%E6%99%82%E7%9A%84%E3%81%AB%E4%BD%8E%E3%81%8F%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%80%81%E5%BF%85%E8%A6%81%E3%81%AA%E6%A9%9F%E8%83%BD%E3%82%92%E5%AE%9F%E7%8F%BE%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%8C%E8%AA%BF%E3%81%B9%E3%81%A6%E3%81%84%E3%82%8B%E3%82%82%E3%81%86%201%20%E3%81%A4%E3%81%AE%E7%82%B9%E3%81%AF%E3%80%81%E9%81%8E%E9%9B%BB%E6%B5%81%E6%A4%9C%E5%87%BA%20(i-sleep-oc)%20%E3%81%AB%E3%82%88%E3%82%8A%20BMS%20%E3%81%8C%E3%82%B9%E3%83%AA%E3%83%BC%E3%83%97%E7%8A%B6%E6%85%8B%E3%81%8B%E3%82%89%E5%BE%A9%E5%B8%B0%E3%81%99%E3%82%8B%E3%81%BE%E3%81%A7%E3%81%AB%E3%81%8B%E3%81%8B%E3%82%8B%E6%99%82%E9%96%93%E3%81%A7%E3%81%99%E3%80%82%E7%A7%81%E3%81%8C%E7%9B%B4%E9%9D%A2%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%95%8F%E9%A1%8C%E3%81%AF%E3%80%81%E5%AE%8C%E5%85%A8%E3%81%AB%E5%85%85%E9%9B%BB%E3%81%95%E3%82%8C%E3%81%9F%E5%BE%8C%E3%80%81%E9%81%8E%E5%85%85%E9%9B%BB%E3%82%92%E6%AD%A2%E3%82%81%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%20BMS%20%E5%87%BA%E5%8A%9B%E3%81%8C%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%AA%E3%82%8A%E3%80%81%E3%81%9D%E3%81%AE%E5%BE%8C%E3%83%AD%E3%83%9C%E3%83%83%E3%83%88%E3%81%8C%E5%85%85%E9%9B%BB%E5%99%A8%E3%81%8C%E4%BE%9B%E7%B5%A6%E3%81%A7%E3%81%8D%E3%82%8B%E4%BB%A5%E4%B8%8A%E3%81%AE%E9%9B%BB%E6%B5%81%E3%82%92%E6%B6%88%E8%B2%BB%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81BMS%20%E3%81%8C%E3%81%93%E3%82%8C%E3%82%92%E6%A4%9C%E5%87%BA%E3%81%97%E3%81%A6%E5%87%BA%E5%8A%9B%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%97%E3%82%92%E5%8F%96%E3%82%8A%E4%BB%98%E3%81%91%E3%82%8B%E3%81%A8%E3%80%81BMS%20%E3%81%AE%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E6%99%82%E9%96%93%E3%81%AF%E7%B4%84%20300%20%EF%BD%9E%20800%20%E3%83%9F%E3%83%AA%E7%A7%92%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E6%B8%AC%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%81%AE%E9%81%85%E5%BB%B6%E3%81%AF%E3%80%81%E3%83%A9%E3%82%BA%E3%83%99%E3%83%AA%E3%83%BC%20%E3%83%91%E3%82%A4%E3%81%AE%E9%9B%BB%E6%BA%90%E5%88%87%E3%82%8C%E3%82%92%E5%BC%95%E3%81%8D%E8%B5%B7%E3%81%93%E3%81%99%E3%81%9F%E3%82%81%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%A8%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E6%99%82%E9%96%93%E3%82%92%E7%9F%AD%E7%B8%AE%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AF%E3%81%82%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%E3%81%8A%E3%81%9D%E3%82%89%E3%81%8F%E5%91%A8%E6%B3%A2%E6%95%B0%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E5%87%BA%E5%8A%9B%E9%9B%BB%E6%B5%81%E3%82%92%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%E6%99%82%E9%96%93%E3%82%92%E7%9F%AD%E7%B8%AE%E3%81%A7%E3%81%8D%E3%82%8C%E3%81%B0%E3%80%81%E9%9B%BB%E5%9C%A7%E9%99%8D%E4%B8%8B%E3%81%AE%E5%B9%B3%E6%BB%91%E5%8C%96%E3%82%92%E6%A4%9C%E8%A8%8E%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%94%E5%8D%94%E5%8A%9B%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%AB%E3%82%A4%E3%82%B9%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1730178%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1730178%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%AB%E3%82%A4%E3%82%B9%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%AE%9F%E9%9A%9B%E3%80%81BMS%20%E3%81%AF%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%81%AB%E6%AE%8B%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E9%9B%BB%E8%8D%B7%E3%82%92%E4%BF%9D%E5%AD%98%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%83%87%E3%82%A3%E3%83%BC%E3%83%97%E3%82%B9%E3%83%AA%E3%83%BC%E3%83%97%E7%8A%B6%E6%85%8B%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E6%9C%80%E4%BD%8E%E9%9B%BB%E5%8A%9B%E3%83%A2%E3%83%BC%E3%83%89%20(%C2%B1100uA)%20%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%93%E3%82%8C%E3%82%92%E5%AE%9F%E7%8F%BE%E3%81%A7%E3%81%8D%E3%82%8B%E5%94%AF%E4%B8%80%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%AF%E3%80%81MCU%20%E3%81%AB%E9%9B%BB%E5%8A%9B%E3%82%92%E4%BE%9B%E7%B5%A6%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%20VCC_3V3_SBC%20%E3%82%92%E3%82%AA%E3%83%95%E3%81%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81MCU%20%E3%81%AF%E3%82%AA%E3%83%95%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82SO%E3%80%81%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%82%82%E3%80%81%E3%81%93%E3%81%AE%E3%83%A2%E3%83%BC%E3%83%89%E3%81%8B%E3%82%89%E3%81%AE%E5%BE%A9%E5%B8%B0%E3%81%AB%E3%81%AF%E5%BD%B9%E7%AB%8B%E3%81%A1%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E3%83%A2%E3%83%BC%E3%83%89%E3%81%8B%E3%82%89%E5%BE%A9%E5%B8%B0%E3%81%99%E3%82%8B%E5%94%AF%E4%B8%80%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%AF%E3%80%81BMS%20%E3%81%AB%E9%9B%BB%E5%9C%A7%E3%82%92%E5%86%8D%E9%81%A9%E7%94%A8%E3%81%99%E3%82%8B%E3%81%8B%E3%80%81SBC%20(U3)%20%E3%81%AE%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%20%E3%83%94%E3%83%B3%20(%E3%83%94%E3%83%B3%2012)%20%E3%82%92%E3%83%97%E3%83%AB%E3%83%80%E3%82%A6%E3%83%B3%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%8A%E3%81%9D%E3%82%89%E3%81%8F%E3%80%81J22%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%20%E3%83%94%E3%83%B3%E3%82%92%E3%83%97%E3%83%AB%E3%83%80%E3%82%A6%E3%83%B3%E3%81%97%E3%81%BE%E3%81%99%20(%E3%81%93%E3%81%AE%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%E3%81%AE%E9%9B%BB%E5%9C%A7%E3%81%AF%E3%80%81%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E9%9B%BB%E5%9C%A7%E3%81%A8%200V%20%E3%81%AE%E9%96%93%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%B3%A8%E6%84%8F%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84)%E3%80%82%E3%81%9F%E3%81%A8%E3%81%88%E3%81%B0%E3%80%81%E5%A4%96%E9%83%A8%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%81%BE%E3%81%9F%E3%81%AF%E4%BB%96%E3%81%AE%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8B%E3%82%89%E5%88%B6%E5%BE%A1%E3%81%95%E3%82%8C%E3%82%8B%E4%BF%A1%E5%8F%B7%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E3%81%93%E3%82%8C%E3%82%92%E4%BD%8E%E3%81%8F%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%82%E3%81%86%201%20%E3%81%A4%E3%81%AE%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%81%AF%E3%80%81%E4%BD%8E%E9%9B%BB%E5%9C%A7%E9%9A%9C%E5%AE%B3%E3%82%92%E5%8F%97%E4%BF%A1%E3%81%97%E3%80%81BMS%20%E3%81%8C%E3%83%87%E3%82%A3%E3%83%BC%E3%83%97%20%E3%82%B9%E3%83%AA%E3%83%BC%E3%83%97%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E5%85%A5%E3%82%8B%E5%89%8D%E3%81%AB%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%20%E3%83%80%E3%82%A6%E3%83%B3%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AB%E3%80%81CLI%20(UART)%20%E7%B5%8C%E7%94%B1%E3%81%A7%E3%80%8Cbms%20reset%E3%80%8D%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E9%80%81%E4%BF%A1%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E3%81%8C%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%BE%E3%81%9F%E3%80%81BMS%20%E3%81%8C%E3%83%87%E3%82%A3%E3%83%BC%E3%83%97%20%E3%82%B9%E3%83%AA%E3%83%BC%E3%83%97%E7%8A%B6%E6%85%8B%E3%81%AB%E5%85%A5%E3%82%8B%E3%81%BE%E3%81%A7%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E6%99%82%E9%96%93%E3%82%92%E5%86%8D%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%9F%E3%82%8A%E3%80%81%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%9F%E3%82%8A%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%93%E3%82%8C%E3%82%92%E8%A1%8C%E3%81%86%E3%81%AB%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2Fblob%2Fmain%2FBMS772_releaseNotes_5.0.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2Fblob%2Fmain%2FBMS772_releaseNotes_5.0.pdf%3C%2FA%3E%E3%81%AE%208.2.2%20%E7%AB%A0%20(18%20%E3%83%9A%E3%83%BC%E3%82%B8)%20%E3%81%AE%20t-fault-timeout%20%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%93%E3%82%8C%E3%81%8C%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%B7%E3%82%B9%E3%83%BB%E3%83%95%E3%82%A1%E3%83%B3%E3%83%BB%E3%83%9F%E3%82%A8%E3%83%AB%E3%83%AD%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1730153%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1730153%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E7%9A%86%E3%81%95%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3ENXP%20BMS%20%E3%82%92%20ROV%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AB%E7%B5%B1%E5%90%88%E3%81%99%E3%82%8B%E9%9A%9B%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E5%8A%A0%E3%81%88%E3%82%8B%E3%81%B9%E3%81%8D%E5%A4%89%E6%9B%B4%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AE%E3%82%AC%E3%82%A4%E3%83%80%E3%83%B3%E3%82%B9%E3%82%92%E6%9C%9F%E5%BE%85%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E5%95%8F%E9%A1%8C%E3%81%AF%E3%80%81ROV%20%E3%81%AE%E6%B0%B4%E4%B8%AD%E9%A3%9B%E8%A1%8C%E4%B8%AD%E3%81%AB%E6%99%82%E3%80%85%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%81%8C%E6%B6%88%E8%80%97%E3%81%97%E3%80%81BMS%20%E3%81%8C%E6%B7%B1%E3%81%84%E3%82%B9%E3%83%AA%E3%83%BC%E3%83%97%E7%8A%B6%E6%85%8B%E3%81%AB%E3%81%AA%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E8%BB%8A%E4%B8%A1%E3%81%8C%E5%9B%9E%E5%BE%A9%E4%B8%8D%E8%83%BD%E3%81%AB%E3%81%AA%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E4%BD%8E%E9%9B%BB%E5%9C%A7%E9%9A%9C%E5%AE%B3%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81BMS%20%E3%81%AF%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%81%AE%E6%B6%88%E8%B2%BB%E3%82%92%E6%8A%91%E3%81%88%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%83%87%E3%82%A3%E3%83%BC%E3%83%97%20%E3%82%B9%E3%83%AA%E3%83%BC%E3%83%97%E7%8A%B6%E6%85%8B%E3%81%AB%E5%85%A5%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E5%8B%95%E4%BD%9C%E3%81%AE%E4%B8%80%E9%83%A8%E3%81%A8%E3%81%97%E3%81%A6%E3%80%81UART%20%E9%80%9A%E4%BF%A1%E3%81%8C%E3%82%AA%E3%83%95%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82BMS%20%E3%81%AB%E9%9B%BB%E5%9C%A7%E3%82%92%E5%8D%B0%E5%8A%A0%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E7%89%A9%E7%90%86%E7%9A%84%E3%81%AA%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%20%E3%83%9C%E3%82%BF%E3%83%B3%E3%81%8C%E6%8A%BC%E3%81%95%E3%82%8C%E3%82%8B%E3%81%BE%E3%81%A7%E3%80%81BMS%20%E3%81%AF%E3%83%87%E3%82%A3%E3%83%BC%E3%83%97%20%E3%82%B9%E3%83%AA%E3%83%BC%E3%83%97%E7%8A%B6%E6%85%8B%E3%81%AE%E3%81%BE%E3%81%BE%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E5%95%8F%E9%A1%8C%E3%81%AF%E3%80%81%E3%83%AD%E3%83%9C%E3%83%83%E3%83%88%E3%81%8C%E6%B0%B4%E4%B8%AD%E3%81%AB%E9%85%8D%E7%BD%AE%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E7%89%A9%E7%90%86%E7%9A%84%E3%81%AB%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E6%8A%BC%E3%81%97%E3%81%A6%E3%82%82%E6%A9%9F%E8%83%BD%E3%81%9B%E3%81%9A%E3%80%81%E3%83%AD%E3%83%9C%E3%83%83%E3%83%88%E3%81%8C%E3%83%87%E3%82%A3%E3%83%BC%E3%83%97%E3%82%B9%E3%83%AA%E3%83%BC%E3%83%97%E7%8A%B6%E6%85%8B%E3%81%AB%E3%81%82%E3%82%8B%E3%81%9F%E3%82%81%20UART%20%E7%B5%8C%E7%94%B1%E3%81%A7%E9%80%9A%E4%BF%A1%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ESO%E3%80%81%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E5%85%8B%E6%9C%8D%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%82%A2%E3%83%89%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E6%B1%82%E3%82%81%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%9B%AE%E6%A8%99%E3%81%AF%E3%80%81%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%81%AE%E3%81%95%E3%82%89%E3%81%AA%E3%82%8B%E6%94%BE%E9%9B%BB%E3%82%92%E9%98%B2%E3%81%90%E3%81%9F%E3%82%81%E3%81%AB%20BMS%20%E3%82%92%E3%83%87%E3%82%A3%E3%83%BC%E3%83%97%20%E3%82%B9%E3%83%AA%E3%83%BC%E3%83%97%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E3%81%97%E3%81%9F%E3%81%BE%E3%81%BE%E3%80%81UART%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E7%B5%8C%E7%94%B1%E3%81%BE%E3%81%9F%E3%81%AF%E5%85%85%E9%9B%BB%E9%9B%BB%E5%9C%A7%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AB%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%87%E3%82%A3%E3%83%BC%E3%83%97%20%E3%82%B9%E3%83%AA%E3%83%BC%E3%83%97%E3%81%AB%E5%85%A5%E3%82%8B%E5%89%8D%E3%81%AB%20UART%20RX%20%E3%83%94%E3%83%B3%E3%81%AB%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%92%E6%8E%A5%E7%B6%9A%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%A8%E8%80%83%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E4%B8%AD%E3%81%AB%E9%9A%9C%E5%AE%B3%E3%81%8C%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E5%AE%9F%E7%8F%BE%E5%8F%AF%E8%83%BD%E3%81%AA%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%20%E3%82%82%E3%81%97%E3%81%9D%E3%81%86%E3%81%AA%E3%82%89%E3%80%81%E3%81%93%E3%82%8C%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E6%96%B9%E5%90%91%E6%80%A7%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%8A%A9%E3%81%91%E3%81%A6%E3%81%8F%E3%82%8C%E3%81%A6%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%81%3C%2FP%3E%3CP%3E%E3%83%AB%E3%82%A4%E3%82%B9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1730004%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1730004%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%9D%E3%81%AE%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%81%8C%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AB%E3%81%A8%E3%81%A3%E3%81%A6%E3%81%86%E3%81%BE%E3%81%8F%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E6%84%9F%E8%AC%9D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1702673%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1702673%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F212097%22%20target%3D%22_blank%22%3E%40lmiles-sosub%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%3CP%3E%E3%82%B2%E3%83%BC%E3%83%88%20%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%81%AE%E7%9B%AE%E7%9A%84%E3%81%AF%E3%80%81%E3%82%B2%E3%83%BC%E3%83%88%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E9%9B%BB%E6%BA%90%E3%82%92%E3%82%AA%E3%83%95%E3%81%AB%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88%E3%81%BE%E3%81%9F%E3%81%AF%E4%BB%96%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E9%9B%BB%E6%BA%90%E3%82%92%E3%82%AA%E3%83%95%E3%81%AB%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%82%BB%E3%83%BC%E3%83%95%E3%83%86%E3%82%A3%E4%B8%8A%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%82%BB%E3%83%AB%E3%83%95%E3%83%86%E3%82%B9%E3%83%88%E3%81%8C%E8%A1%8C%E3%82%8F%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E7%9B%AE%E7%9A%84%E3%81%AB%E3%81%A8%E3%81%A3%E3%81%A6%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E7%90%86%E6%83%B3%E7%9A%84%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%AF%E7%90%86%E8%A7%A3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%8C%E5%AE%89%E5%85%A8%E3%81%A0%E3%81%A8%E6%80%9D%E3%82%8F%E3%82%8C%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E7%9B%AE%E7%9A%84%E3%81%AB%E5%BF%9C%E3%81%98%E3%81%A6%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%A7%E3%81%93%E3%81%AE%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E9%9B%BB%E6%BA%90%E3%82%92%E3%82%AA%E3%83%95%E3%81%ABCAN%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%81%AF%E7%A2%BA%E8%AA%8D%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%E3%81%AE%E3%81%A7%E6%B3%A8%E6%84%8F%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%95%E3%82%89%E3%81%AB%E3%80%81%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E3%81%9D%E3%81%AE%E9%83%A8%E5%88%86%E3%81%A7%E3%81%AF%E9%9B%BB%E6%BA%90%E3%82%92%E3%82%AA%E3%83%95%E3%81%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%AE%E9%83%A8%E5%88%86%E3%82%92%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AB%E7%BD%AE%E3%81%8D%E6%8F%9B%E3%81%88%E3%82%8B%E3%81%8B%E3%80%81%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%20%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%20(%23ifdef%20%23else%20%23endif)%20%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%E3%80%81%E7%B0%A1%E5%8D%98%E3%81%AB%E5%85%83%E3%81%AE%E7%8A%B6%E6%85%8B%E3%81%AB%E6%88%BB%E3%81%99%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E9%83%A8%E5%88%86%E3%81%AF%E7%BD%AE%E3%81%8D%E6%8F%9B%E3%81%88%E3%82%8B%E3%81%8B%E3%80%81%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%20%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3A%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2Fblob%2Fmain%2Fsrc%2FbatManagement.c%23L608-L672%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2Fblob%2Fmain%2Fsrc%2FbatManagement.c%23L608-L672%3C%2FA%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%99%E3%82%8B%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E4%B8%80%E9%83%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%2F%2F%20%E3%82%B2%E3%83%BC%E3%83%88%E3%82%92%E3%82%AA%E3%83%95%E3%81%AB%E3%81%99%E3%82%8B%3CBR%20%2F%3EbutManagement_setGatePower(GATE_OPEN)%3B%3C%2FP%3E%3CP%3Ecli_printfWarning(%22%E3%82%BB%E3%83%AB%E3%83%95%E3%83%86%E3%82%B9%E3%83%88%E3%82%B2%E3%83%BC%E3%83%88%3A%20%E3%82%AA%E3%83%95%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F!%5Cn%22)%3B%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%A7%E3%81%94%E8%B3%AA%E5%95%8F%E3%81%B8%E3%81%AE%E5%9B%9E%E7%AD%94%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%9F%E3%81%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%B7%E3%82%B9%E3%83%BB%E3%83%95%E3%82%A1%E3%83%B3%E3%83%BB%E3%83%9F%E3%82%A8%E3%83%AB%E3%83%AD%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1702511%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1702511%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E7%9A%86%E3%81%95%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AF%E3%80%81ROV%20%E3%81%AB%E5%B8%B8%E6%99%82%E9%9B%BB%E5%8A%9B%E3%82%92%E4%BE%9B%E7%B5%A6%E3%81%99%E3%82%8B%E5%85%85%E9%9B%BB%E5%99%A8%E3%82%92%E5%82%99%E3%81%88%E3%81%9F%20ROV%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%A7%E3%81%AE%20BMS%20%E3%81%AE%E4%BD%BF%E7%94%A8%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E5%85%85%E9%9B%BB%E5%99%A8%E3%81%AE%E9%9B%BB%E5%8A%9B%E5%AE%B9%E9%87%8F%E3%82%92%E8%B6%85%E3%81%88%E3%82%8B%E3%83%94%E3%83%BC%E3%82%AF%E8%B2%A0%E8%8D%B7%E3%81%AB%E3%81%AF%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%81%8C%E9%9B%BB%E5%8A%9B%E3%82%92%E4%BE%9B%E7%B5%A6%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%81%8C%E4%BD%8E%E9%9B%BB%E5%9C%A7%E4%BF%9D%E8%AD%B7%E3%81%AB%E9%81%94%E3%81%99%E3%82%8B%E3%81%A8%EF%BC%88%E9%9A%9C%E5%AE%B3%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E5%85%A5%E3%82%8B%E3%81%A8%EF%BC%89%E3%80%81%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%82%92%E5%85%85%E9%9B%BB%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%20BMS%20%E3%82%92%E9%9A%9C%E5%AE%B3%E7%8A%B6%E6%85%8B%E3%81%8B%E3%82%89%E5%9B%9E%E5%BE%A9%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%90%86%E6%83%B3%E7%9A%84%E3%81%AB%E3%81%AF%E3%80%81BMS%20%E3%81%AF%E5%87%BA%E5%8A%9B%E3%82%92%E9%81%AE%E6%96%AD%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%AA%E3%81%8F%E3%80%81%E5%85%85%E9%9B%BB%E9%9B%BB%E6%B5%81%E3%81%8C%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%81%AB%E6%B5%81%E5%85%A5%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E7%8F%BE%E5%9C%A8%E3%80%81%E9%9A%9C%E5%AE%B3%E3%82%92%E5%8F%96%E3%82%8A%E9%99%A4%E3%81%8F%E3%81%9F%E3%82%81%E3%81%AB%20CLI%20%E3%82%92%E4%BB%8B%E3%81%97%E3%81%A6%20BMS%20%E3%82%92%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%81%A7%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AB%E9%9B%BB%E6%BA%90%E3%82%92%E5%85%A5%E3%82%8C%E3%82%8B%E3%81%AB%E3%81%AF%E5%85%85%E9%9B%BB%E5%99%A8%E3%82%92%E3%82%AA%E3%83%B3%E3%81%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E3%81%9D%E3%81%AE%E7%B5%90%E6%9E%9C%E3%80%81%E3%82%BB%E3%83%AB%E3%83%95%E3%83%86%E3%82%B9%E3%83%88%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%80%81%E5%85%85%E9%9B%BB%E5%99%A8%E3%82%92%E5%8F%96%E3%82%8A%E5%A4%96%E3%81%99%E3%82%88%E3%81%86%E3%81%AB%E6%8F%90%E6%A1%88%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AF%E3%80%81%E3%82%B2%E3%83%BC%E3%83%88%E3%82%BB%E3%83%AB%E3%83%95%E3%83%86%E3%82%B9%E3%83%88%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E5%85%85%E9%9B%BB%E5%99%A8%E3%82%92%E5%88%87%E6%96%AD%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E6%A9%9F%E8%83%BD%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82%E3%81%9D%E3%81%AE%E7%9B%AE%E7%9A%84%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%3F%20%E3%81%BE%E3%81%9F%E3%80%81%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%A7%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81%E9%87%8D%E5%A4%A7%E3%81%AA%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%94%E5%8A%A9%E8%A8%80%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%AB%E3%82%A4%E3%82%B9%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1686646%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1686646%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F214383%22%20target%3D%22_blank%22%3E%40suvasis%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%3CP%3ERDDRONE-BMS772%20%E3%81%AE%20.brd%20%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%95%E3%82%8C%E3%80%81%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesigns%2Fsmart-battery-management-for-mobile-robotics%3ARDDRONE-BMS772%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesigns%2Fsmart-battery-management-for-mobile-robotics%3ARDDRONE-BMS772%3C%2FA%3E%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E6%95%AC%E5%85%B7%3C%2FP%3E%3CP%3E%E3%82%B7%E3%82%B9%E3%83%BB%E3%83%95%E3%82%A1%E3%83%B3%E3%83%BB%E3%83%9F%E3%82%A8%E3%83%AB%E3%83%AD%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1679245%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1679245%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%3CP%3EBMS%20%E3%82%92%E5%86%8D%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E9%9B%BB%E6%BA%90%E3%82%92%E5%85%A5%E3%82%8C%E7%9B%B4%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E5%8A%B9%E6%9E%9C%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82DEEP_SLEEP%E3%81%AB%E5%85%A5%E3%81%A3%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%94%E5%8A%A9%E8%A8%80%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%8E%8B%E5%AD%90%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1673640%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1673640%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F195015%22%20target%3D%22_blank%22%3E%40Prince1%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%80%8Creboot%E3%80%8D%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%A7%20MCU%20%E3%82%92%E5%86%8D%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3E%E9%80%9A%E4%BF%A1%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E8%A9%A6%E3%81%99%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%82%E3%81%86%201%20%E3%81%A4%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%AF%20(%E8%A8%98%E6%86%B6%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%81%8A%E3%82%8A)%E3%80%81DEEP_SLEEP%20%E3%81%AB%E7%A7%BB%E8%A1%8C%E3%81%97%E3%81%A6%20NORMAL%20%E7%8A%B6%E6%85%8B%E3%81%AB%E6%88%BB%E3%81%99%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%9D%E3%82%8C%E4%BB%A5%E5%A4%96%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81BMS%20%E9%9B%BB%E6%BA%90%E3%82%92%E5%86%8D%E6%8A%95%E5%85%A5%E3%81%97%E3%81%A6%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%95%AC%E5%85%B7%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%82%B7%E3%82%B9%E3%83%BB%E3%83%95%E3%82%A1%E3%83%B3%E3%83%BB%E3%83%9F%E3%82%A8%E3%83%AB%E3%83%AD%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1673634%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1673634%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F214383%22%20target%3D%22_blank%22%3E%40suvasis%3C%2FA%3E%20%E3%80%81%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%83%81%E3%83%BC%E3%83%A0%E3%81%AB%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20(.brd)%20%E3%82%82%20NXP.com%20%E3%81%AB%E3%82%A2%E3%83%83%E3%83%97%E3%83%AD%E3%83%BC%E3%83%89%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E5%B0%8B%E3%81%AD%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E3%81%93%E3%82%8C%E3%81%AB%E3%81%AF%E6%95%B0%E6%97%A5%E3%81%8B%E3%81%8B%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%8C%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%B3%A8%E6%84%8F%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E5%9B%9E%E8%B7%AF%E5%9B%B3%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20(.DSN)%20%E3%81%AF%E3%81%99%E3%81%A7%E3%81%AB%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%95%AC%E5%85%B7%3C%2FP%3E%3CP%3E%E3%82%B7%E3%82%B9%E3%83%BB%E3%83%95%E3%82%A1%E3%83%B3%E3%83%BB%E3%83%9F%E3%82%A8%E3%83%AB%E3%83%AD%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1673616%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1673616%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%E6%B7%BB%E4%BB%98%E3%81%AE%E7%94%BB%E5%83%8F%E3%81%AB%E7%A4%BA%E3%81%99%E3%82%88%E3%81%86%E3%81%AB%E3%80%81Tera%20term%20%E3%81%AF%20BMS%20%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E3%81%A8%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E3%82%B9%E3%83%AD%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%80%8C%E6%B8%AC%E5%AE%9A%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%9A%E3%80%81%E6%B8%AC%E5%AE%9A%E5%80%A4%E3%81%AE%E6%9B%B4%E6%96%B0%E3%81%AB%E3%82%82%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%8D%3C%2FP%3E%3CP%3E%E8%A7%A3%E6%B1%BA%E3%81%AB%E3%81%94%E5%8D%94%E5%8A%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E7%8E%8B%E5%AD%90%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1672228%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1672228%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%83%89%E3%83%AD%E3%83%BC%E3%83%B3%E7%94%A8%E3%81%AB%20PCB%20%E3%82%92%E3%82%88%E3%82%8A%E5%B0%8F%E3%81%95%E3%81%AA%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%20%E3%83%95%E3%82%A1%E3%82%AF%E3%82%BF%E3%83%BC%E3%81%AB%E5%86%8D%E8%A8%AD%E8%A8%88%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E4%BB%A5%E4%B8%8B%E3%81%AE%E6%96%87%E6%9B%B8%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesigns%2Fsmart-battery-management-for-mobile-robotics%3ARDDRONE-BMS772%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesigns%2Fsmart-battery-management-for-mobile-robotics%3ARDDRONE-BMS772%3C%2FA%3E%3C%2FP%3E%3CP%3E%E9%80%9A%E5%B8%B8%E3%80%81%E5%9B%9E%E8%B7%AF%E5%9B%B3%E3%81%A8%E8%A3%BD%E9%80%A0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%81%AE%3CSPAN%3E%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%AB%E3%81%AF%20PCB%20%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82PCB%20%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%90%AB%E3%82%81%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%E4%BA%BA%E3%81%AF%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3E%E8%AA%B0%E3%81%8B%E5%8A%A9%E3%81%91%E3%81%A6%E3%81%8F%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%B9%E3%83%B4%E3%82%A1%E3%82%B7%E3%82%B9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1631017%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1631017%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F213615%22%20target%3D%22_blank%22%3E%40dmorvay%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%3CP%3EI2CS%20%E3%82%92%3CSPAN%3EPTA2%2FPTA3%20%E3%83%94%E3%83%B3%E3%81%AB%E5%A4%9A%E9%87%8D%E5%8C%96%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A0%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%3E%E3%81%93%E3%82%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81S32K-RM%20%E3%81%AE%E7%AC%AC%2052%20%E7%AB%A0%E3%80%8CLow%20Power%20Inter-Integrated%20Circuit%20(LPI2C)%E3%80%8D%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AB%E6%AD%A3%E3%81%97%E3%81%84%E5%A4%89%E6%9B%B4%E3%82%92%E5%8A%A0%E3%81%88%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81SDK%20%E3%81%8C%E3%81%93%E3%82%8C%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%81%AF%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%95%AC%E5%85%B7%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%82%B7%E3%82%B9%E3%83%BB%E3%83%95%E3%82%A1%E3%83%B3%E3%83%BB%E3%83%9F%E3%82%A8%E3%83%AB%E3%83%AD%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1630511%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1630511%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F213615%22%20target%3D%22_blank%22%3E%40dmorvay%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E2%20%E7%95%AA%E7%9B%AE%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AB%E9%96%A2%E3%81%97%E3%81%A6%E8%A8%80%E3%81%88%E3%81%B0%E3%80%81S32K14x%20%E7%94%A8%E3%81%AE%20MBD%20%E3%83%84%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E3%81%AF%E3%80%81S32k14x%20%E7%94%A8%E3%81%AE%20SDK%20%E4%B8%8A%E3%81%AB%E6%A7%8B%E7%AF%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E6%AE%8B%E5%BF%B5%E3%81%AA%E3%81%8C%E3%82%89%E3%80%81SDK%20%E3%81%A7%E3%81%AF%20LPI2C%20%E3%81%AE%204%20%E7%B7%9A%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E3%81%9D%E3%81%AE%E3%81%9F%E3%82%81%E3%80%81MBD%20%E3%83%84%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E3%81%A7%E3%82%82%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%90%E3%83%B3%E3%83%81%E3%83%A9%E3%83%BB%E3%82%BD%E3%83%AA%E3%83%B3%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1629818%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1629818%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E6%83%85%E5%A0%B1%E3%82%92%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E6%9C%80%E5%88%9D%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AB%E5%AF%BE%E3%81%99%E3%82%8B%E7%AD%94%E3%81%88%E3%81%8C%E3%81%BE%E3%81%A0%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%20-%20PTA2%2FPTA3%20(J23)%20%E3%81%AF%20I2C%20%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%81%A8%E3%81%97%E3%81%A6%E6%A7%8B%E6%88%90%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%93%E3%81%AE%20I%2FO%20%E3%81%AB%E3%81%AF%E5%B8%B8%E3%81%AB%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%81%A8%E3%81%97%E3%81%A6%E6%A7%8B%E6%88%90%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A8%E3%81%84%E3%81%86%E5%88%B6%E9%99%90%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1629793%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1629793%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F213615%22%20target%3D%22_blank%22%3E%40dmorvay%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%0A%3CP%3EMBDT%20%E3%81%AE%E4%BE%8B%E3%82%84%E3%81%9D%E3%81%AE%E3%83%84%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E3%81%A7%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%86%85%E5%AE%B9%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%82%88%E3%81%8F%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EC%20%2F%20C%2B%2B%20%E3%81%AE%E4%BE%8B%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81NuttX%20RTOS%20SW%20%E3%81%AE%E4%BE%8B%E3%82%92%E5%8F%82%E7%85%A7%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%AF%E3%80%81%E8%A1%A8%206%20%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E6%AD%A3%E3%81%97%E3%81%84%20I2C%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%80%81I2C%20%E7%B5%8C%E7%94%B1%E3%81%A7%20BMS%20%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82SMBus%20%E5%A4%89%E6%95%B0%E3%83%AA%E3%82%B9%E3%83%88%20(%E7%AC%AC%207.5%20%E7%AB%A0%20SMBus%20%E3%81%AE%E4%BD%BF%E7%94%A8%E6%96%B9%E6%B3%95)%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%81%AE%E4%BE%8B%E3%81%AF%E3%81%93%E3%81%93%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3A%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%3C%2FA%3E%3CBR%20%2F%3ENuttX%20RTOS%20%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%82%E5%BF%85%E8%A6%81%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%3A%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fapache%2Fnuttx%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fapache%2Fnuttx%3C%2FA%3E%3CBR%20%2F%3ENuttX%20%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%81%AE%20RDDRONE-BMS772%20%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fapache%2Fnuttx%2Ftree%2Fmaster%2Fboards%2Farm%2Fs32k1xx%2Frddrone-bms772%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fapache%2Fnuttx%2Ftree%2Fmaster%2Fboards%2Farm%2Fs32k1xx%2Frddrone-bms772%3C%2FA%3E%3C%2FP%3E%0A%3CP%3ES32K1xx%20%E3%82%A2%E3%83%BC%E3%82%AD%E3%83%86%E3%82%AF%E3%83%81%E3%83%A3%E5%9B%BA%E6%9C%89%E3%81%AE%E3%83%AD%E3%82%B8%E3%83%83%E3%82%AF%3A%3CBR%20%2F%3E%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fapache%2Fnuttx%2Ftree%2Fmaster%2Farch%2Farm%2Fsrc%2Fs32k1xx%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fapache%2Fnuttx%2Ftree%2Fmaster%2Farch%2Farm%2Fsrc%2Fs32k1xx%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%93%E3%82%8C%E3%81%8C%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99!%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%95%AC%E5%85%B7%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%82%B7%E3%82%B9%E3%83%BB%E3%83%95%E3%82%A1%E3%83%B3%E3%83%BB%E3%83%9F%E3%82%A8%E3%83%AB%E3%83%AD%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1629762%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1629762%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%3C%2FA%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E5%9B%9E%E7%AD%94%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%81%95%E3%82%89%E3%81%AB%202%20%E3%81%A4%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99...%3C%2FP%3E%3CP%3E1.%20PTA2%20%E3%81%8A%E3%82%88%E3%81%B3%20PTA3%20(%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%20J23)%20%E3%82%92%20I2C%20%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%81%A8%E3%81%97%E3%81%A6%E6%A7%8B%E6%88%90%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E5%81%B4%E3%81%A7%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A8%E6%80%9D%E3%82%8F%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%A8%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%A7%E3%81%99%E3%81%B9%E3%81%A6%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E2.%20%3CSPAN%3ELPI2C0_SCL%3C%2FSPAN%3E%20%3CSTRONG%3ES%3C%2FSTRONG%3E%3CSPAN%3E%E3%81%A8LPI2C0_SDA%3C%2FSPAN%3E%20%3CSTRONG%3ES%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FSTRONG%3EC%20%E3%82%B3%E3%83%BC%E3%83%89%E3%82%84%E3%83%A2%E3%83%87%E3%83%AB%E3%83%99%E3%83%BC%E3%82%B9%E9%96%8B%E7%99%BA%E3%82%92%E9%80%9A%E3%81%98%E3%81%A6%E3%81%93%E3%82%8C%E3%82%92%E6%A7%8B%E6%88%90%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E5%8F%82%E8%80%83%E8%B3%87%E6%96%99%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%E7%8F%BE%E5%9C%A8%E3%80%81%E3%83%A2%E3%83%87%E3%83%AB%E3%83%99%E3%83%BC%E3%82%B9%E9%96%8B%E7%99%BA%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%20%3CSPAN%3ELPI2C0_SCL%3C%2FSPAN%3E%20%3CSTRONG%3ES%3C%2FSTRONG%3E%3CSPAN%3E%E3%81%8A%E3%82%88%E3%81%B3%20LPI2C0_SDA%3C%2FSPAN%3E%20%3CSTRONG%3ES%3C%2FSTRONG%3E%E3%82%92%E5%82%99%E3%81%88%E3%81%9F%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%95%E3%82%89%E3%81%AB%E3%80%81I2C%20%E6%A7%8B%E6%88%90%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AB%E3%81%AF%E3%80%81PTA2%2FPTA3%20%E3%81%BE%E3%81%9F%E3%81%AF%20PTB6%2FPTB7%20%E3%81%AE%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E3%81%BF%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E3%81%AB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%8C%E6%AD%A3%E7%A2%BA%E3%81%AB%E3%81%AF%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1629540%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1629540%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F213615%22%20target%3D%22_blank%22%3E%40dmorvay%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%20J18%20%E3%81%AF%20SMBUS%20%2F%20I2C%20%3CSTRONG%3ES%3C%2FSTRONG%3E%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3ESMBUS_SCL%20%E3%81%8A%E3%82%88%E3%81%B3%20SMBUS_SDA%20%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AF%E3%81%93%E3%81%AE%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AF%E3%80%81LPI2C0_SCL%20%3CSTRONG%3ES%3C%2FSTRONG%3E%E3%81%8A%E3%82%88%E3%81%B3%20%2FLPI2C0_SDA%20%3CSTRONG%3ES%3C%2FSTRONG%3E%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%20PTA0%20%E3%81%8A%E3%82%88%E3%81%B3%20PTA1%20%E3%81%B8%E3%81%AE%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%E3%81%A7%E3%81%99%E3%80%82%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E6%95%AC%E5%85%B7%3C%2FP%3E%3CP%3E%E3%82%B7%E3%82%B9%E3%83%BB%E3%83%95%E3%82%A1%E3%83%B3%E3%83%BB%E3%83%9F%E3%82%A8%E3%83%AB%E3%83%AD%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1629440%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1629440%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%3C%2FA%3E%3C%2FP%3E%3CP%3EI2C%20%E9%80%9A%E4%BF%A1%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%82%82%E3%81%86%201%20%E3%81%A4%E3%81%AE%E8%B3%AA%E5%95%8F%3A%20BMS772%20%E3%82%92%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%81%A8%E3%81%97%E3%81%A6%E6%A7%8B%E6%88%90%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81SDA%2FSCL%20%E3%81%AE%E3%83%94%E3%83%B3%E3%81%AF%E3%81%9D%E3%82%8C%E3%81%9E%E3%82%8C%20PTB6%20%E3%81%A8%20PTB7%20%E3%81%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E3%81%9D%E3%82%8C%E3%81%9E%E3%82%8C%20PTA2%20%E3%81%A8%20PTA3%20%E3%81%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%E5%9B%9E%E8%B7%AF%E5%9B%B3%E3%82%92%E8%A6%8B%E3%82%8B%E3%81%A8%E3%80%81%E5%AE%9F%E9%9A%9B%E3%81%AB%E3%81%AF%E3%81%93%E3%82%8C%E3%82%89%202%20%E3%81%A4%E3%81%AE%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E3%81%A9%E3%81%A1%E3%82%89%E3%81%A7%E3%82%82%E3%81%AA%E3%81%8F%E3%80%81%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%20PTA0%20%E3%81%A8%20PTA1%20%E3%81%8C%E3%81%82%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%20I2C%20%E9%80%9A%E4%BF%A1%E3%81%AE%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%81%A8%E3%81%97%E3%81%A6%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%8C%E5%B0%91%E3%81%97%E6%B7%B7%E4%B9%B1%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1624966%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1624966%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3ENXP%20%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%A7%E6%8E%A8%E5%A5%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%20PSMNR70-30YLH%20MOSFET%20%E3%81%AF%E3%80%81%E6%AE%8B%E5%BF%B5%E3%81%AA%E3%81%8C%E3%82%89%E7%A7%81%E3%81%8C%E8%A9%A6%E3%81%97%E3%81%9F%E3%82%B5%E3%82%A4%E3%83%88%E3%81%A7%E3%81%AF%E8%B3%BC%E5%85%A5%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E3%82%BB%E3%83%BC%E3%83%95%E3%83%86%E3%82%A3%E3%81%AB%E3%83%86%E3%82%B9%E3%83%88%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E3%81%93%E3%82%8C%E3%81%8C%E5%95%8F%E9%A1%8C%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E3%81%A7%E8%AA%AD%E3%82%93%E3%81%A0%E3%81%A8%E3%81%93%E3%82%8D%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%E3%80%81Nexperia%20%E3%81%A7%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%89%E3%82%8C%E3%82%8B%E3%81%A8%E3%81%AE%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E6%B3%A8%E6%96%87%E3%81%A7%E3%81%8D%E3%82%8B%E6%9C%80%E5%B0%8F%E6%95%B0%E9%87%8F%E3%81%AF%201500%20%E5%80%8B%E3%81%A0%E3%81%9D%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E5%90%8C%E7%AD%89%E3%81%AE%E8%A3%BD%E5%93%81%E3%82%92%E6%8E%A2%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E5%90%8C%E3%81%98%E7%89%B9%E6%80%A7%E3%82%92%E6%8C%81%E3%81%A4%E3%82%82%E3%81%AE%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E8%A8%B1%E5%AE%B9%E7%AF%84%E5%9B%B2%E3%82%84%20MOSFET%20%E3%81%8C%E3%81%A9%E3%81%AE%E7%A8%8B%E5%BA%A6%E7%95%B0%E3%81%AA%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8B%E3%81%8B%E3%81%AF%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3ENXP%20%E3%81%8C%E6%8E%A8%E5%A5%A8%E3%81%99%E3%82%8B%20MOSFET%20%E3%81%AE%E7%89%B9%E6%80%A7%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%E4%BB%96%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E7%89%B9%E6%80%A7%E3%81%8C%E8%A8%B1%E5%AE%B9%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8B%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E4%BB%96%E3%81%AB%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E9%81%A9%E5%88%87%E3%81%AA%E7%89%B9%E6%80%A7%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3CSPAN%3EN%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB30V%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E0.82%20m%CE%A9%E3%80%81%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E300%20A%E3%83%AD%E3%82%B8%E3%83%83%E3%82%AF%E3%83%AC%E3%83%99%E3%83%AB%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ENextPowerS3%E3%83%86%E3%82%AF%E3%83%8E%E3%83%AD%E3%82%B8%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9FLFPAK56%E3%81%AEMOSFET%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%A9%E3%81%86%E3%82%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1624947%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1624947%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%20%E3%81%95%E3%82%93%E3%80%81%3C%2FA%3E%E6%9C%AC%E5%BD%93%E3%81%AB%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E4%BF%A1%E5%8F%B7%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%81%A3%E3%81%9F%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%81%AE%E3%81%A7%E3%80%81%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1623162%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1623162%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F212364%22%20target%3D%22_blank%22%3E%40DaveNXP%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%82%AA%E3%82%B7%E3%83%AD%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%97%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3FMCU%20%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%20%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AB%E3%83%91%E3%83%AB%E3%82%B9%E3%81%8C%E3%81%82%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E6%B8%AC%E5%AE%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3E%E6%95%AC%E5%85%B7%3C%2FP%3E%0A%3CP%3E%E3%82%B7%E3%82%B9%E3%83%BB%E3%83%95%E3%82%A1%E3%83%B3%E3%83%BB%E3%83%9F%E3%82%A8%E3%83%AB%E3%83%AD%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1623057%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1623057%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%94%E5%9B%9E%E7%AD%94%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%81%99%E3%81%A7%E3%81%AB%E3%80%81J2%20%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%20(%E9%85%8D%E7%BD%AE%E6%B8%88%E3%81%BF)%20%E3%82%92%20JTAG%20%E3%83%A9%E3%82%A4%E3%83%B3%E7%B5%8C%E7%94%B1%E3%81%A7%E3%80%81%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%20%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%91%E3%83%BC%E3%81%82%E3%82%8A%E3%81%A8%E3%81%AA%E3%81%97%E3%81%AE%E7%8A%B6%E6%85%8B%E3%81%A7%E8%A9%A6%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E3%81%BE%E3%81%A0%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AB%E4%BD%95%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%20%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%83%83%E3%83%89%E3%81%95%E3%82%8C%E3%80%81%E4%BF%A1%E5%8F%B7%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%E3%81%95%E3%82%93%E3%80%81%3C%2FA%3E%E6%9C%AC%E5%BD%93%E3%81%AB%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1623027%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1623027%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F212364%22%20target%3D%22_blank%22%3E%40DaveNXP%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%83%BC%E3%81%AE%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E8%A1%8C%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3FMCU%E3%81%AB%E6%AD%A3%E3%81%97%E3%81%8F%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%83%83%E3%83%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%81%AF%E3%80%81J2%20%E3%81%8C%E9%85%8D%E7%BD%AE%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%202x5%20%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E3%81%9D%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%20%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E3%82%92%E4%BB%8B%E3%81%97%E3%81%A6%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%99%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3CBR%20%2F%3EJ2%20%E3%81%8C%E9%85%8D%E7%BD%AE%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%812x5%20%E3%83%94%E3%83%B3%20%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E3%82%92%E3%81%AF%E3%82%93%E3%81%A0%E4%BB%98%E3%81%91%E3%81%97%E3%81%A6%E3%80%81%E3%81%9D%E3%81%AE%E3%83%AB%E3%83%BC%E3%83%88%E7%B5%8C%E7%94%B1%E3%81%A7%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%A7%E3%81%8D%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%95%AC%E5%85%B7%3C%2FP%3E%3CP%3E%E3%82%B7%E3%82%B9%E3%83%BB%E3%83%95%E3%82%A1%E3%83%B3%E3%83%BB%E3%83%9F%E3%82%A8%E3%83%AB%E3%83%AD%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1622556%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1622556%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ERDDRONE%20BMS%20%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E5%B7%A5%E5%A0%B4%E5%87%BA%E8%8D%B7%E6%99%82%E3%81%AE%E7%8A%B6%E6%85%8B%E3%81%AB%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%20(%E3%81%BE%E3%81%9F%E3%81%AF%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95)%20%E3%82%92%E7%9F%A5%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E4%BA%BA%E3%81%AF%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8C%E3%83%87%E3%82%A3%E3%83%BC%E3%83%97%E3%82%B9%E3%83%AA%E3%83%BC%E3%83%97%E7%8A%B6%E6%85%8B%E3%81%AB%E3%81%82%E3%82%8B%E3%81%8B%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E3%81%9D%E3%81%93%E3%81%8B%E3%82%89%E6%8A%9C%E3%81%91%E5%87%BA%E3%81%9B%E3%81%AA%E3%81%84%E7%8A%B6%E6%85%8B%E3%81%AB%E3%81%82%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%9C%80%E5%88%9D%E3%81%AF%E3%82%B3%E3%82%A2%20(Cortex-M4%20%E3%82%92%E8%AD%98%E5%88%A5)%20%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%8F%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%20(%E3%83%AD%E3%82%B0%E3%81%AF%E5%89%8D%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99)%E3%80%82SO%E3%80%81J-Link%20Commander%20%E3%81%A7%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E9%80%81%E4%BF%A1%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82J-Link%20%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%83%BC%E3%81%AE%E9%9B%BB%E5%9C%A7%E3%81%AF%203.3V%20%E3%81%A7%E3%81%99%E3%80%82%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E9%9B%BB%E6%BA%90%E3%81%8C%E5%85%A5%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E9%96%93%E3%81%AB%E7%89%A9%E7%90%86%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E6%8A%BC%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E4%BD%95%E3%82%82%E5%A4%89%E5%8C%96%E3%81%8C%E3%81%AA%E3%81%8F%E3%80%81%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E7%A7%81%E3%81%8C%E8%B3%BC%E5%85%A5%E3%81%97%E3%81%9F%202%20%E3%81%A4%E3%81%AE%20RDDRONE%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%A9%E3%81%86%E3%81%8B%E3%80%81%E3%81%A9%E3%82%93%E3%81%AA%E5%8A%A9%E3%81%91%E3%81%A7%E3%82%82%E6%9C%AC%E5%BD%93%E3%81%AB%E3%81%82%E3%82%8A%E3%81%8C%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%EF%BC%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%3C%2FA%3E%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F15914%22%20target%3D%22_blank%22%3E%40iaingalloway%3C%2FA%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1620687%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1620687%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82%E3%81%94%E5%9B%9E%E7%AD%94%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ESW1%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E6%8A%BC%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%91%E3%83%BC%E3%82%92%E4%BB%98%E3%81%91%E3%81%9F%E7%8A%B6%E6%85%8B%E3%81%A8%E4%BB%98%E3%81%91%E3%81%AA%E3%81%84%E7%8A%B6%E6%85%8B%E3%81%A7%E8%A9%A6%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3Es32k1xx%20%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%AE%E9%9B%BB%E6%B0%97%E4%BB%95%E6%A7%98%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%80%81%E4%BF%A1%E5%8F%B7%E7%99%BA%E7%94%9F%E5%99%A8%E3%81%A7%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%20%E3%83%91%E3%83%AB%E3%82%B9%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fdata-sheet%2FS32K-DS.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2F%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%2FS32K-DS.pdf%3C%2FA%3E%3C%2FP%3E%3CP%3E%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E9%9B%BB%E5%9C%A7%E3%82%92%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3EFTDI%20%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%82%92%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%81%AE%E9%9B%BB%E6%BA%90%E3%82%92%E3%82%AA%E3%83%B3%2F%E3%82%AA%E3%83%95%E3%81%AB%E3%81%97%E3%81%9F%E3%81%A8%E3%81%8D%E3%81%AB%E3%80%81Tera%20Term%20%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%81%AB%E3%82%B4%E3%83%9F%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%B9%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%8E%E3%82%A4%E3%82%BA%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1620180%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1620180%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EJLINK%20%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%A8%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20BMS%20%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81JLINK.exe%20%E3%81%8C%E6%9C%80%E5%88%9D%E3%81%AB%E5%87%BA%E5%8A%9B%E3%81%99%E3%82%8B%E3%82%82%E3%81%AE%E3%81%AE%201%20%E3%81%A4%E3%81%AF%E3%80%81MCU%2F%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AE%E9%9B%BB%E5%9C%A7%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EBMS%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%2022V%20%E3%81%AA%E3%81%A9%E3%81%AE%E5%A4%96%E9%83%A8%E9%9B%BB%E6%BA%90%E3%81%8C%E4%BE%9B%E7%B5%A6%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%A6%E3%82%82%E3%80%81MCU%20%E3%81%AB%E9%9B%BB%E5%8A%9B%E3%82%92%E4%BE%9B%E7%B5%A6%E3%81%99%E3%82%8B%E5%AE%9F%E9%9A%9B%E3%81%AE%E9%9B%BB%E6%BA%90%E3%81%8C%E3%82%AA%E3%83%B3%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EBMS%20%E3%81%AB%E3%81%AF%E3%80%81MCU%20%E9%9B%BB%E6%BA%90%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%A7%E3%81%8D%E3%82%8B%E5%B0%8F%E3%81%95%E3%81%AA%E7%89%A9%E7%90%86%E3%83%9C%E3%82%BF%E3%83%B3%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fnxp.gitbook.io%2Frddrone-bms772%2Fuser-guide%2Fgetting-to-know-the-hardware%2Fboard-organization%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fnxp.gitbook.io%2Frddrone-bms772%2F%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%AC%E3%82%A4%E3%83%89%2F%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E7%90%86%E8%A7%A3%E3%82%92%E6%B7%B1%E3%82%81%E3%82%8B%2F%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E6%A7%8B%E6%88%90%3C%2FA%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1619705%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1619705%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81Cis%20van%20Mierlo%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%83%BC%E3%81%AF%203.3V%20%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81RDDRONE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E5%85%A5%E5%8A%9B%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%9F%E9%9B%BB%E6%BA%90%E3%81%AE%E5%87%BA%E5%8A%9B%E3%81%AF22.2V%E3%81%A7%E3%81%99%E3%80%82%E4%BD%95%E3%81%8C%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%AE%E3%81%8B%E3%80%81%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E5%A4%89%E6%9B%B4%E3%82%84%E3%83%86%E3%82%B9%E3%83%88%E3%82%92%E8%A1%8C%E3%81%86%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%AE%E3%81%8B%E3%80%81%E3%82%88%E3%81%8F%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%A9%E3%81%AE%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E6%8A%BC%E3%81%9B%E3%81%B0%E3%81%84%E3%81%84%E3%81%AE%E3%81%8B%E3%80%81%E5%86%8D%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%93%E3%82%8C%E3%81%AB%E9%96%A2%E3%81%97%E3%81%A6%E3%81%A9%E3%82%93%E3%81%AA%E3%81%94%E5%8A%A9%E5%8A%9B%E3%81%A7%E3%82%82%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%82%E6%95%AC%E5%85%B7%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1619239%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1619239%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F212364%22%20target%3D%22_blank%22%3E%40DaveNXP%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%83%BC%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E9%9B%BB%E5%9C%A7%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E%E3%81%8A%E3%81%9D%E3%82%89%E3%81%8F%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%E3%83%87%E3%82%A3%E3%83%BC%E3%83%97%E3%82%B9%E3%83%AA%E3%83%BC%E3%83%97%E7%8A%B6%E6%85%8B%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E5%86%8D%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E6%8A%BC%E3%81%99%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%95%AC%E5%85%B7%3C%2FP%3E%0A%3CP%3E%E3%82%B7%E3%82%B9%E3%83%BB%E3%83%95%E3%82%A1%E3%83%B3%E3%83%BB%E3%83%9F%E3%82%A8%E3%83%AB%E3%83%AD%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1619209%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1619209%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ecisvmierlo%E3%81%95%E3%82%93%E3%80%81%E5%9B%9E%E7%AD%94%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E5%95%8F%E9%A1%8C%E3%81%AF%E3%80%81%E6%9C%80%E5%88%9D%E3%81%AF%20RDDRONE-BMS772%20%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%AE%E3%82%B3%E3%82%A2%E3%81%AB%E6%AD%A3%E3%81%97%E3%81%8F%E6%8E%A5%E7%B6%9A%E3%81%A7%E3%81%8D%E3%81%9F%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%81%AE%E6%9C%80%E5%88%9D%E3%81%AE%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E4%BB%A5%E9%99%8D%E3%81%AF%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%AE%E3%82%B3%E3%82%A2%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%8F%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%97%E3%81%BE%E3%81%A3%E3%81%9F%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82SO%E3%80%81%E6%8E%A8%E5%A5%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%AE%E3%80%8Ch%E3%80%8D%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E9%80%81%E4%BF%A1%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%96%E3%81%AB%E4%BD%95%E3%81%8B%E3%82%A2%E3%82%A4%E3%83%87%E3%82%A2%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1619170%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1619170%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F212364%22%20target%3D%22_blank%22%3E%40DaveNXP%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%3CP%3E%E3%82%B3%E3%82%A2%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E6%B6%88%E5%8E%BB%E3%81%97%E3%81%9F%E3%82%8A%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%97%E3%81%9F%E3%82%8A%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EJ-Link%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%80%E3%83%BC%E3%82%92%E5%86%8D%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%80%81%E3%80%8Ch%E3%80%8D%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%A7%E3%82%B3%E3%82%A2%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%3F%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%E6%95%AC%E5%85%B7%3C%2FP%3E%3CP%3E%E3%82%B7%E3%82%B9%E3%83%BB%E3%83%95%E3%82%A1%E3%83%B3%E3%83%BB%E3%83%9F%E3%82%A8%E3%83%AB%E3%83%AD%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1619116%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1619116%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3ERDDRONE-BMS772%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E6s%20%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E7%94%A8%E3%81%AE%20RDDRONE-BMS772%20%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%81%A7%E6%8E%A8%E5%A5%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%80%8C%E6%A7%8B%E6%88%90%E3%83%91%E3%83%83%E3%83%89%E3%80%8D%E3%82%92%E3%81%AF%E3%82%93%E3%81%A0%E4%BB%98%E3%81%91%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fnxp.gitbook.io%2Frddrone-bms772%2Fuser-guide%2Fgetting-started-with-the-rddrone-bms772%2Fconfiguring-the-hardware%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fnxp.gitbook.io%2Frddrone-bms772%2F%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%AC%E3%82%A4%E3%83%89%2Frddrone-bms772%20%E3%82%92%E4%BD%BF%E3%81%84%E5%A7%8B%E3%82%81%E3%82%8B%2F%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E8%A8%AD%E5%AE%9A%3C%2FA%3E%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81RDDRONE-BMS772%20%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E5%88%9D%E3%82%81%E3%81%A6%2022.2V%20%E9%9B%BB%E6%BA%90%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%82%AA%E3%83%B3%E3%83%9C%E3%83%BC%E3%83%89%20LED%20%E3%81%8C%E7%82%B9%E7%81%AF%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%80%8CNXP%20Gitbook%E3%80%8D%E3%81%AE%E3%81%93%E3%81%AE%E3%82%AC%E3%82%A4%E3%83%89%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AB%E5%BE%93%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fnxp.gitbook.io%2Fnxpmobilerobotics%2Fflashing-guide%2Fflashing-hovergames-boards%2Fwindows%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fnxp.gitbook.io%2Fnxpmobilerobotics%2Fflashing-guide%2Fflashing-hovergames-boards%2Fwindows%3C%2FA%3E%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E5%85%AC%E5%BC%8Fgithub%E3%81%8B%E3%82%89%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%9F%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2bin%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%9F%E5%BE%8C%EF%BC%9A%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%3C%2FA%3E%3C%2FP%3E%3CP%3E%E6%8E%A8%E5%A5%A8%E3%81%95%E3%82%8C%E3%82%8B%3CSPAN%3EJ-LINK%3C%2FSPAN%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%82%92%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fnxp.gitbook.io%2Fhovergames%2Frddrone-fmuk66%2Fconnectors%2Fdebug-interface-dcd-lz%2Fdcd-lz-breakout-board%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fnxp.gitbook.io%2Fhovergames%2Frddrone-fmuk66%2Fconnectors%2Fdebug-interface-dcd-lz%2Fdcd-lz-breakout-board%3C%2FA%3E%3C%2FP%3E%3CP%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20(%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%83%AD%E3%82%B0%E3%82%92%E5%8F%82%E7%85%A7)%E3%80%82RDDRONE-BMS772%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%8F%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%95%E3%82%89%E3%81%ABLED%E3%82%82%E7%82%B9%E7%81%AF%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E5%86%8D%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E8%A9%A6%E3%81%BF%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81J-Link%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%80%E3%83%BC%E3%82%92%20RDDRONE-BMS772%20%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%8F%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3EFTDI%20%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81Putty%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%82%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E6%8E%A5%E7%B6%9A%E3%81%8C%E7%A2%BA%E7%AB%8B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E5%95%8F%E9%A1%8C%E3%81%8C%20CPU%20%E3%81%8C%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AA%E3%81%AE%E3%81%8B%E3%80%81CPU%20%E3%81%8C%20RESET%20%E3%83%AB%E3%83%BC%E3%83%97%E3%81%AB%E5%85%A5%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%8B%E3%80%81CPU%20%E3%81%8C%20RESET%20%E4%BF%A1%E5%8F%B7%E3%82%92%E5%BE%85%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%8B%E3%80%81CPU%20%E3%81%8C%E3%80%8C%E3%83%AD%E3%83%83%E3%82%AF%E3%80%8D%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%A6%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E8%A7%A3%E9%99%A4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%AE%E3%81%8B%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E4%BB%96%E3%81%AE%E4%BD%95%E3%81%8B%E3%81%AA%E3%81%AE%E3%81%8B%E3%80%81%E7%90%86%E8%A7%A3%E3%81%A7%E3%81%8D%E3%81%9A%E3%80%81%E5%B0%91%E3%81%97%E6%B7%B7%E4%B9%B1%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%81%94%E5%8A%A9%E5%8A%9B%E3%82%82%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E5%8F%82%E8%80%83%E3%81%AB%E3%81%AA%E3%82%8C%E3%81%B0%E3%81%A8%E6%80%9D%E3%81%84%E3%80%81J-Link%20Commander%20%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%81%8B%E3%82%89%E5%8F%96%E5%BE%97%E3%81%97%E3%81%9F%E3%83%AD%E3%82%B0%E3%82%92%E4%BB%A5%E4%B8%8B%E3%81%AB%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E6%8E%A5%E7%B6%9A%E3%82%92%E7%A2%BA%E7%AB%8B%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%8Cconnect%E3%80%8D%E3%81%A8%E5%85%A5%E5%8A%9B%E3%81%97%E3%80%81%E3%83%98%E3%83%AB%E3%83%97%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%8C%3F%E3%80%8D%E3%81%A8%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3EJ-Link%26gt%3B%E6%8E%A5%E7%B6%9A%3CBR%20%2F%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%2F%E3%82%B3%E3%82%A2%E3%82%92%E6%8C%87%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CDEFAULT%3E%3A%20S32K144%3CBR%20%2F%3E%20%E9%81%B8%E6%8A%9E%E3%83%80%E3%82%A4%E3%82%A2%E3%83%AD%E3%82%B0%E3%81%AB%E3%80%8C%3F%E3%80%8D%E3%81%A8%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3CBR%20%2F%3E%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%26gt%3B%3CBR%20%2F%3E%20%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%92%E6%8C%87%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3A%3CBR%20%2F%3E%20J)%20JTAG%20(%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88)%3CBR%20%2F%3E%20S)%20SWD%3CBR%20%2F%3E%20T)%20cJTAG%3CBR%20%2F%3E%20TIF%26gt%3Bs%3CBR%20%2F%3E%20%E5%AF%BE%E8%B1%A1%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E9%80%9F%E5%BA%A6%5BkHz%5D%E3%82%92%E6%8C%87%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CDEFAULT%3E%3A%204000%20kHz%3CBR%20%2F%3E%20%E9%80%9F%E5%BA%A6%26gt%3B1000%3CBR%20%2F%3E%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%80%8CS32K144%E3%80%8D%E3%81%8C%E9%81%B8%E6%8A%9E%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FDEFAULT%3E%3C%2FDEFAULT%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3ESWD%E7%B5%8C%E7%94%B1%E3%81%A7%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%3CBR%20%2F%3EInitTarget()%20%E9%96%8B%E5%A7%8B%3CBR%20%2F%3ESWD%E3%81%8C%E9%81%B8%E6%8A%9E%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82JTAG%20-%26gt%3B%20SWD%20%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%82%B7%E3%83%BC%E3%82%B1%E3%83%B3%E3%82%B9%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3EInitTarget()%20%E7%B5%82%E4%BA%86%20-%2055%20%E3%83%9F%E3%83%AA%E7%A7%92%E3%81%8B%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EID%200x2BA01477%20%E3%81%AE%20SW-DP%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EDPIDR%3A%200x2BA01477%3CBR%20%2F%3E%20CoreSight%20SoC-400%20%E4%BB%A5%E5%89%8D%3CBR%20%2F%3EAP%E3%83%9E%E3%83%83%E3%83%97%E3%82%92%E3%82%B9%E3%82%AD%E3%83%A3%E3%83%B3%E3%81%97%E3%81%A6%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AEAP%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%3CBR%20%2F%3EAP%5B2%5D%3A%20AP%E3%83%9E%E3%83%83%E3%83%97%E3%81%AE%E7%B5%82%E7%AB%AF%E3%81%AB%E9%81%94%E3%81%97%E3%81%9F%E3%81%9F%E3%82%81%E3%80%81AP%E3%82%B9%E3%82%AD%E3%83%A3%E3%83%B3%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EAP%5B0%5D%3A%20AHB-AP%20(IDR%3A%200x24770011)%3CBR%20%2F%3E%20AP%5B1%5D%3A%20JTAG-AP%20(IDR%3A%200x001C0000)%3CBR%20%2F%3E%20AP%E3%83%9E%E3%83%83%E3%83%97%E3%82%92%E5%8F%8D%E5%BE%A9%E5%87%A6%E7%90%86%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8BAHB-AP%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%3CBR%20%2F%3EAP%5B0%5D%3A%20%E3%82%B3%E3%82%A2%E3%82%92%E7%99%BA%E8%A6%8B%3CBR%20%2F%3EAP%5B0%5D%3A%20AHB-AP%20ROM%E3%83%99%E3%83%BC%E3%82%B9%3A%200xE00FF000%3CBR%20%2F%3E%20CPUID%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%3A%200x410FC241%E3%80%82%E5%AE%9F%E8%A3%85%E8%80%85%E3%82%B3%E3%83%BC%E3%83%89%3A%200x41%20(ARM)%3CBR%20%2F%3E%20Cortex-M4%20r0p1%E3%80%81%E3%83%AA%E3%83%88%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%87%E3%82%A3%E3%82%A2%E3%83%B3%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3EFPUnit%3A%206%20%E3%81%A4%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%20(BP)%20%E3%82%B9%E3%83%AD%E3%83%83%E3%83%88%E3%81%A8%202%20%E3%81%A4%E3%81%AE%E3%83%AA%E3%83%86%E3%83%A9%E3%83%AB%20%E3%82%B9%E3%83%AD%E3%83%83%E3%83%88%3CBR%20%2F%3ECoreSight%20%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88%3A%3CBR%20%2F%3E%20ROMTbl%5B0%5D%20%40%20E00FF000%3CBR%20%2F%3E%20%5B0%5D%5B0%5D%3A%20E000E000%20CID%20B105E00D%20PID%20000BB00C%20SCS-M7%3CBR%20%2F%3E%20%5B0%5D%5B1%5D%3A%20E0001000%20CID%20B105E00D%20PID%20003BB002%20DWT%3CBR%20%2F%3E%20%5B0%5D%5B2%5D%3A%20E0002000%20CID%20B105E00D%20PID%20002BB003%20FPB%3CBR%20%2F%3E%20%5B0%5D%5B3%5D%3A%20E0000000%20CID%20B105E00D%20PID%20003BB001%20ITM%3CBR%20%2F%3E%20%5B0%5D%5B4%5D%3A%20E0040000%20CID%20B105900D%20PID%20000BB9A1%20TPIU%3CBR%20%2F%3E%2061440%E3%83%90%E3%82%A4%E3%83%88%E3%81%AE%E4%BD%9C%E6%A5%AD%E7%94%A8RAM%EF%BC%880x1FFF8000%EF%BC%89%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3A%20DEMCR.VC_CORERESET%20%E3%81%AB%E3%82%88%E3%82%8B%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E5%BE%8C%E3%81%AB%E3%82%B3%E3%82%A2%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3A%20AIRCR.SYSRESETREQ%20%E7%B5%8C%E7%94%B1%E3%81%A7%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%BE%E3%83%BC%E3%83%B3%3A%3CBR%20%2F%3E%E3%82%BE%E3%83%BC%E3%83%B3%3A%20%E3%80%8C%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%80%8D%20%E8%AA%AC%E6%98%8E%3A%20%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%83%A2%E3%83%BC%E3%83%89%3CBR%20%2F%3ECortex-M4%20%E3%81%8C%E8%AD%98%E5%88%A5%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3EJ-Link%26gt%3B%E6%B6%88%E5%8E%BB%3CBR%20%2F%3E%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E7%AF%84%E5%9B%B2%E3%81%8C%E6%8C%87%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%80%8C%E3%83%81%E3%83%83%E3%83%97%E6%B6%88%E5%8E%BB%E3%80%8D%E3%81%8C%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%E3%80%8C%E6%B6%88%E5%8E%BB%E3%80%8D%3A%20MCU%20%E3%81%AE%E6%9A%97%E9%BB%99%E7%9A%84%E3%81%AA%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%A8%E5%81%9C%E6%AD%A2%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3A%20DEMCR.VC_CORERESET%20%E3%81%AB%E3%82%88%E3%82%8B%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E5%BE%8C%E3%81%AB%E3%82%B3%E3%82%A2%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3A%20AIRCR.SYSRESETREQ%20%E7%B5%8C%E7%94%B1%E3%81%A7%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E6%B6%88%E5%8E%BB%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3C%2FP%3E%3CP%3E******%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC%E3%81%AE%E6%B6%88%E5%8E%BB%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3EJ-Link%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%3A%20%E5%90%88%E8%A8%88%E6%89%80%E8%A6%81%E6%99%82%E9%96%93%3A%201.490%20%E7%A7%92%20(%E6%BA%96%E5%82%99%3A%200.603%20%E7%A7%92%E3%80%81%E6%AF%94%E8%BC%83%3A%200.000%20%E7%A7%92%E3%80%81%E6%B6%88%E5%8E%BB%3A%200.885%20%E7%A7%92%E3%80%81%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%3A%200.000%20%E7%A7%92%E3%80%81%E6%A4%9C%E8%A8%BC%3A%200.000%20%E7%A7%92%E3%80%81%E5%BE%A9%E5%85%83%3A%200.002%20%E7%A7%92)%3C%2FP%3E%3CP%3E******%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%AE%E5%BE%A9%E5%85%83%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82RAMCode%E3%81%AF%E6%B1%BA%E3%81%97%E3%81%A6%E6%AD%A2%E3%81%BE%E3%82%89%E3%81%AA%E3%81%84%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%82%A8%E3%83%A9%E3%83%BC%20%E3%82%B3%E3%83%BC%E3%83%89%20-5%20%E3%81%A7%E6%B6%88%E5%8E%BB%E3%81%8C%E8%BF%94%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%20J-Link%26gt%3Bloadbin%20%22C%3A%5CDocuments%5CRDDRONE-BMS772-main%5CBinary%5Cnuttx.bin%22%200x0%3CBR%20%2F%3E%20'loadbin'%3A%20MCU%20%E3%81%AE%E6%9A%97%E9%BB%99%E7%9A%84%E3%81%AA%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%A8%E5%81%9C%E6%AD%A2%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3A%20DEMCR.VC_CORERESET%20%E3%81%AB%E3%82%88%E3%82%8B%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E5%BE%8C%E3%81%AB%E3%82%B3%E3%82%A2%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3A%20AIRCR.SYSRESETREQ%20%E7%B5%8C%E7%94%B1%E3%81%A7%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3A%20SYSRESETREQ%20%E3%81%AB%E3%82%88%E3%82%8A%E3%82%B3%E3%82%A2%E3%81%8C%E6%B7%B7%E4%B9%B1%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3EID%200x2BA01477%20%E3%81%AE%20SW-DP%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EDPIDR%3A%200x2BA01477%3CBR%20%2F%3E%20CoreSight%20SoC-400%20%E4%BB%A5%E5%89%8D%3CBR%20%2F%3EAP%20%E3%83%9E%E3%83%83%E3%83%97%E3%81%AE%E6%A4%9C%E5%87%BA%E3%82%92%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%89%8B%E5%8B%95%E3%81%A7%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%20AP%20%E3%83%9E%E3%83%83%E3%83%97%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3EAP%5B0%5D%3A%20AHB-AP%20(IDR%3A%20%E6%9C%AA%E8%A8%AD%E5%AE%9A)%3CBR%20%2F%3E%20AP%5B0%5D%3A%20%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82CPUID%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3ECPU%E3%81%B8%E3%81%AE%E6%8E%A5%E7%B6%9A%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E7%8A%B6%E6%85%8B%E3%81%A7%E6%8E%A5%E7%B6%9A%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3EDPIDR%3A%200x2BA01477%3CBR%20%2F%3E%20CoreSight%20SoC-400%20%E4%BB%A5%E5%89%8D%3CBR%20%2F%3EAP%20%E3%83%9E%E3%83%83%E3%83%97%E3%81%AE%E6%A4%9C%E5%87%BA%E3%82%92%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%89%8B%E5%8B%95%E3%81%A7%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%20AP%20%E3%83%9E%E3%83%83%E3%83%97%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3EAP%5B0%5D%3A%20AHB-AP%20(IDR%3A%20%E6%9C%AA%E8%A8%AD%E5%AE%9A)%3CBR%20%2F%3E%20AP%5B0%5D%3A%20%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82CPUID%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3ECoresight%20%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%A7%E3%82%B3%E3%82%A2%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3A%20%E3%83%95%E3%82%A9%E3%83%BC%E3%83%AB%E3%83%90%E3%83%83%E3%82%AF%E3%82%92%E4%BD%BF%E7%94%A8%3A%20VECTRESET%E3%80%82%3CBR%20%2F%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3A%20DEMCR.VC_CORERESET%20%E3%81%AB%E3%82%88%E3%82%8B%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E5%BE%8C%E3%81%AB%E3%82%B3%E3%82%A2%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3A%20AIRCR.VECTRESET%20%E7%B5%8C%E7%94%B1%E3%81%A7%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3A%20VECTRESET%20%E3%81%AF%E3%82%B3%E3%82%A2%E3%82%92%E6%B7%B7%E4%B9%B1%E3%81%95%E3%81%9B%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3A%20%E3%83%95%E3%82%A9%E3%83%BC%E3%83%AB%E3%83%90%E3%83%83%E3%82%AF%E3%82%92%E4%BD%BF%E7%94%A8%3A%20%E3%83%94%E3%83%B3%E3%82%92%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3A%20DEMCR.VC_CORERESET%20%E3%81%AB%E3%82%88%E3%82%8B%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E5%BE%8C%E3%81%AB%E3%82%B3%E3%82%A2%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3A%20%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%83%94%E3%83%B3%E7%B5%8C%E7%94%B1%E3%81%A7%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3A%20VC_CORERESET%20%E3%81%AF%20CPU%20%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82(%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%83%AD%E3%82%B8%E3%83%83%E3%82%AF%E3%82%82%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%20%E3%83%94%E3%83%B3%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8B%3F)%E3%80%82%3CBR%20%2F%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3A%20%E5%86%8D%E6%8E%A5%E7%B6%9A%E3%81%97%E3%80%81CPU%20%E3%82%92%E6%89%8B%E5%8B%95%E3%81%A7%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20ID%200x2BA01477%20%E3%81%AE%20SW-DP%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EDPIDR%3A%200x2BA01477%3CBR%20%2F%3E%20CoreSight%20SoC-400%20%E4%BB%A5%E5%89%8D%3CBR%20%2F%3EAP%20%E3%83%9E%E3%83%83%E3%83%97%E3%81%AE%E6%A4%9C%E5%87%BA%E3%82%92%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%89%8B%E5%8B%95%E3%81%A7%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%20AP%20%E3%83%9E%E3%83%83%E3%83%97%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3EAP%5B0%5D%3A%20AHB-AP%20(IDR%3A%20%E6%9C%AA%E8%A8%AD%E5%AE%9A)%3CBR%20%2F%3E%20AP%5B0%5D%3A%20%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82CPUID%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3ECPU%E3%81%B8%E3%81%AE%E6%8E%A5%E7%B6%9A%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E7%8A%B6%E6%85%8B%E3%81%A7%E6%8E%A5%E7%B6%9A%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3EDPIDR%3A%200x2BA01477%3CBR%20%2F%3E%20CoreSight%20SoC-400%20%E4%BB%A5%E5%89%8D%3CBR%20%2F%3EAP%20%E3%83%9E%E3%83%83%E3%83%97%E3%81%AE%E6%A4%9C%E5%87%BA%E3%82%92%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%89%8B%E5%8B%95%E3%81%A7%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%20AP%20%E3%83%9E%E3%83%83%E3%83%97%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3EAP%5B0%5D%3A%20AHB-AP%20(IDR%3A%20%E6%9C%AA%E8%A8%AD%E5%AE%9A)%3CBR%20%2F%3E%20AP%5B0%5D%3A%20%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82CPUID%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3ECoresight%20%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%A7%E3%82%B3%E3%82%A2%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3ECPU%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3A%20%E3%82%B3%E3%82%A2%E3%81%AF%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E5%BE%8C%E3%81%AB%E5%81%9C%E6%AD%A2%E3%81%9B%E3%81%9A%E3%80%81WDT%20%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3A%20DEMCR.VC_CORERESET%20%E3%81%AB%E3%82%88%E3%82%8B%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E5%BE%8C%E3%81%AB%E3%82%B3%E3%82%A2%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3A%20%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%83%94%E3%83%B3%E7%B5%8C%E7%94%B1%E3%81%A7%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3A%20VC_CORERESET%20%E3%81%AF%20CPU%20%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82(%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%83%AD%E3%82%B8%E3%83%83%E3%82%AF%E3%82%82%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%20%E3%83%94%E3%83%B3%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8B%3F)%E3%80%82%3CBR%20%2F%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3A%20%E5%86%8D%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%20CPU%20%E3%82%92%E6%89%8B%E5%8B%95%E3%81%A7%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20ID%200x2BA01477%20%E3%81%AE%20SW-DP%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EDPIDR%3A%200x2BA01477%3CBR%20%2F%3E%20CoreSight%20SoC-400%20%E4%BB%A5%E5%89%8D%3CBR%20%2F%3EAP%20%E3%83%9E%E3%83%83%E3%83%97%E3%81%AE%E6%A4%9C%E5%87%BA%E3%82%92%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%89%8B%E5%8B%95%E3%81%A7%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%20AP%20%E3%83%9E%E3%83%83%E3%83%97%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3EAP%5B0%5D%3A%20AHB-AP%20(IDR%3A%20%E6%9C%AA%E8%A8%AD%E5%AE%9A)%3CBR%20%2F%3E%20AP%5B0%5D%3A%20%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82CPUID%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3ECPU%E3%81%B8%E3%81%AE%E6%8E%A5%E7%B6%9A%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E7%8A%B6%E6%85%8B%E3%81%A7%E6%8E%A5%E7%B6%9A%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3EDPIDR%3A%200x2BA01477%3CBR%20%2F%3E%20CoreSight%20SoC-400%20%E4%BB%A5%E5%89%8D%3CBR%20%2F%3EAP%20%E3%83%9E%E3%83%83%E3%83%97%E3%81%AE%E6%A4%9C%E5%87%BA%E3%82%92%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%89%8B%E5%8B%95%E3%81%A7%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%20AP%20%E3%83%9E%E3%83%83%E3%83%97%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3EAP%5B0%5D%3A%20AHB-AP%20(IDR%3A%20%E6%9C%AA%E8%A8%AD%E5%AE%9A)%3CBR%20%2F%3E%20AP%5B0%5D%3A%20%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82CPUID%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3ECoresight%20%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%A7%E3%82%B3%E3%82%A2%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3ECPU%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3A%20%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%20%E3%83%94%E3%83%B3%E3%82%92%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%81%A6%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E6%88%A6%E7%95%A5%E3%82%92%E5%86%8D%E5%BA%A6%E8%A9%A6%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3EID%200x2BA01477%20%E3%81%AE%20SW-DP%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EDPIDR%3A%200x2BA01477%3CBR%20%2F%3E%20CoreSight%20SoC-400%20%E4%BB%A5%E5%89%8D%3CBR%20%2F%3EAP%20%E3%83%9E%E3%83%83%E3%83%97%E3%81%AE%E6%A4%9C%E5%87%BA%E3%82%92%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%89%8B%E5%8B%95%E3%81%A7%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%20AP%20%E3%83%9E%E3%83%83%E3%83%97%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3EAP%5B0%5D%3A%20AHB-AP%20(IDR%3A%20%E6%9C%AA%E8%A8%AD%E5%AE%9A)%3CBR%20%2F%3E%20AP%5B0%5D%3A%20%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82CPUID%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3ECPU%E3%81%B8%E3%81%AE%E6%8E%A5%E7%B6%9A%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E7%8A%B6%E6%85%8B%E3%81%A7%E6%8E%A5%E7%B6%9A%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3EDPIDR%3A%200x2BA01477%3CBR%20%2F%3E%20CoreSight%20SoC-400%20%E4%BB%A5%E5%89%8D%3CBR%20%2F%3EAP%20%E3%83%9E%E3%83%83%E3%83%97%E3%81%AE%E6%A4%9C%E5%87%BA%E3%82%92%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%89%8B%E5%8B%95%E3%81%A7%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%20AP%20%E3%83%9E%E3%83%83%E3%83%97%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3EAP%5B0%5D%3A%20AHB-AP%20(IDR%3A%20%E6%9C%AA%E8%A8%AD%E5%AE%9A)%3CBR%20%2F%3E%20AP%5B0%5D%3A%20%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82CPUID%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3ECoresight%20%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%A7%E3%82%B3%E3%82%A2%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3A%20DEMCR.VC_CORERESET%20%E3%81%AB%E3%82%88%E3%82%8B%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E5%BE%8C%E3%81%AB%E3%82%B3%E3%82%A2%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3A%20AIRCR.SYSRESETREQ%20%E7%B5%8C%E7%94%B1%E3%81%A7%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3A%20SYSRESETREQ%20%E3%81%AB%E3%82%88%E3%82%8A%E3%82%B3%E3%82%A2%E3%81%8C%E6%B7%B7%E4%B9%B1%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3EID%200x2BA01477%20%E3%81%AE%20SW-DP%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EDPIDR%3A%200x2BA01477%3CBR%20%2F%3E%20CoreSight%20SoC-400%20%E4%BB%A5%E5%89%8D%3CBR%20%2F%3EAP%20%E3%83%9E%E3%83%83%E3%83%97%E3%81%AE%E6%A4%9C%E5%87%BA%E3%82%92%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%89%8B%E5%8B%95%E3%81%A7%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%20AP%20%E3%83%9E%E3%83%83%E3%83%97%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3EAP%5B0%5D%3A%20AHB-AP%20(IDR%3A%20%E6%9C%AA%E8%A8%AD%E5%AE%9A)%3CBR%20%2F%3E%20AP%5B0%5D%3A%20%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82CPUID%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3ECPU%E3%81%B8%E3%81%AE%E6%8E%A5%E7%B6%9A%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E7%8A%B6%E6%85%8B%E3%81%A7%E6%8E%A5%E7%B6%9A%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3EDPIDR%3A%200x2BA01477%3CBR%20%2F%3E%20CoreSight%20SoC-400%20%E4%BB%A5%E5%89%8D%3CBR%20%2F%3EAP%20%E3%83%9E%E3%83%83%E3%83%97%E3%81%AE%E6%A4%9C%E5%87%BA%E3%82%92%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%89%8B%E5%8B%95%E3%81%A7%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%20AP%20%E3%83%9E%E3%83%83%E3%83%97%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3EAP%5B0%5D%3A%20AHB-AP%20(IDR%3A%20%E6%9C%AA%E8%A8%AD%E5%AE%9A)%3CBR%20%2F%3E%20AP%5B0%5D%3A%20%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82CPUID%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3ECoresight%20%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%A7%E3%82%B3%E3%82%A2%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3A%20%E3%83%95%E3%82%A9%E3%83%BC%E3%83%AB%E3%83%90%E3%83%83%E3%82%AF%E3%82%92%E4%BD%BF%E7%94%A8%3A%20VECTRESET%E3%80%82%3CBR%20%2F%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3A%20DEMCR.VC_CORERESET%20%E3%81%AB%E3%82%88%E3%82%8B%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E5%BE%8C%E3%81%AB%E3%82%B3%E3%82%A2%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3A%20AIRCR.VECTRESET%20%E7%B5%8C%E7%94%B1%E3%81%A7%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3A%20VECTRESET%20%E3%81%AF%E3%82%B3%E3%82%A2%E3%82%92%E6%B7%B7%E4%B9%B1%E3%81%95%E3%81%9B%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3A%20%E3%83%95%E3%82%A9%E3%83%BC%E3%83%AB%E3%83%90%E3%83%83%E3%82%AF%E3%82%92%E4%BD%BF%E7%94%A8%3A%20%E3%83%94%E3%83%B3%E3%82%92%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3A%20DEMCR.VC_CORERESET%20%E3%81%AB%E3%82%88%E3%82%8B%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E5%BE%8C%E3%81%AB%E3%82%B3%E3%82%A2%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3A%20%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%83%94%E3%83%B3%E7%B5%8C%E7%94%B1%E3%81%A7%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3A%20VC_CORERESET%20%E3%81%AF%20CPU%20%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82(%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%83%AD%E3%82%B8%E3%83%83%E3%82%AF%E3%82%82%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%20%E3%83%94%E3%83%B3%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8B%3F)%E3%80%82%3CBR%20%2F%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3A%20%E5%86%8D%E6%8E%A5%E7%B6%9A%E3%81%97%E3%80%81CPU%20%E3%82%92%E6%89%8B%E5%8B%95%E3%81%A7%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20ID%200x2BA01477%20%E3%81%AE%20SW-DP%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EDPIDR%3A%200x2BA01477%3CBR%20%2F%3E%20CoreSight%20SoC-400%20%E4%BB%A5%E5%89%8D%3CBR%20%2F%3EAP%20%E3%83%9E%E3%83%83%E3%83%97%E3%81%AE%E6%A4%9C%E5%87%BA%E3%82%92%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%89%8B%E5%8B%95%E3%81%A7%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%20AP%20%E3%83%9E%E3%83%83%E3%83%97%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3EAP%5B0%5D%3A%20AHB-AP%20(IDR%3A%20%E6%9C%AA%E8%A8%AD%E5%AE%9A)%3CBR%20%2F%3E%20AP%5B0%5D%3A%20%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82CPUID%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3ECPU%E3%81%B8%E3%81%AE%E6%8E%A5%E7%B6%9A%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E7%8A%B6%E6%85%8B%E3%81%A7%E6%8E%A5%E7%B6%9A%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3EDPIDR%3A%200x2BA01477%3CBR%20%2F%3E%20CoreSight%20SoC-400%20%E4%BB%A5%E5%89%8D%3CBR%20%2F%3EAP%20%E3%83%9E%E3%83%83%E3%83%97%E3%81%AE%E6%A4%9C%E5%87%BA%E3%82%92%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%89%8B%E5%8B%95%E3%81%A7%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%20AP%20%E3%83%9E%E3%83%83%E3%83%97%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3EAP%5B0%5D%3A%20AHB-AP%20(IDR%3A%20%E6%9C%AA%E8%A8%AD%E5%AE%9A)%3CBR%20%2F%3E%20AP%5B0%5D%3A%20%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82CPUID%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3ECoresight%20%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%A7%E3%82%B3%E3%82%A2%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3ECPU%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3A%20%E3%82%B3%E3%82%A2%E3%81%AF%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E5%BE%8C%E3%81%AB%E5%81%9C%E6%AD%A2%E3%81%9B%E3%81%9A%E3%80%81WDT%20%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3A%20DEMCR.VC_CORERESET%20%E3%81%AB%E3%82%88%E3%82%8B%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E5%BE%8C%E3%81%AB%E3%82%B3%E3%82%A2%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3A%20%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%83%94%E3%83%B3%E7%B5%8C%E7%94%B1%E3%81%A7%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3A%20VC_CORERESET%20%E3%81%AF%20CPU%20%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82(%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%83%AD%E3%82%B8%E3%83%83%E3%82%AF%E3%82%82%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%20%E3%83%94%E3%83%B3%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8B%3F)%E3%80%82%3CBR%20%2F%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3A%20%E5%86%8D%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%20CPU%20%E3%82%92%E6%89%8B%E5%8B%95%E3%81%A7%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20ID%200x2BA01477%20%E3%81%AE%20SW-DP%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EDPIDR%3A%200x2BA01477%3CBR%20%2F%3E%20CoreSight%20SoC-400%20%E4%BB%A5%E5%89%8D%3CBR%20%2F%3EAP%20%E3%83%9E%E3%83%83%E3%83%97%E3%81%AE%E6%A4%9C%E5%87%BA%E3%82%92%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%89%8B%E5%8B%95%E3%81%A7%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%20AP%20%E3%83%9E%E3%83%83%E3%83%97%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3EAP%5B0%5D%3A%20AHB-AP%20(IDR%3A%20%E6%9C%AA%E8%A8%AD%E5%AE%9A)%3CBR%20%2F%3E%20AP%5B0%5D%3A%20%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82CPUID%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3ECPU%E3%81%B8%E3%81%AE%E6%8E%A5%E7%B6%9A%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E7%8A%B6%E6%85%8B%E3%81%A7%E6%8E%A5%E7%B6%9A%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3EDPIDR%3A%200x2BA01477%3CBR%20%2F%3E%20CoreSight%20SoC-400%20%E4%BB%A5%E5%89%8D%3CBR%20%2F%3EAP%20%E3%83%9E%E3%83%83%E3%83%97%E3%81%AE%E6%A4%9C%E5%87%BA%E3%82%92%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%89%8B%E5%8B%95%E3%81%A7%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%20AP%20%E3%83%9E%E3%83%83%E3%83%97%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3EAP%5B0%5D%3A%20AHB-AP%20(IDR%3A%20%E6%9C%AA%E8%A8%AD%E5%AE%9A)%3CBR%20%2F%3E%20AP%5B0%5D%3A%20%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82CPUID%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3ECoresight%20%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%A7%E3%82%B3%E3%82%A2%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3ECPU%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3ECPU%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E******%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%20CPU%20%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%20CPU%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%5BC%3A%5CDocuments%5CRDDRONE-BMS772-main%5CBinary%5Cnuttx.bin%5D%20%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3CBR%20%2F%3E%20CPU%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E******%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%AE%E5%BE%A9%E5%85%83%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82RAMCode%E3%81%AF%E6%B1%BA%E3%81%97%E3%81%A6%E6%AD%A2%E3%81%BE%E3%82%89%E3%81%AA%E3%81%84%3CBR%20%2F%3E%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC%E3%81%AE%E6%B6%88%E5%8E%BB%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E6%9C%AA%E6%8C%87%E5%AE%9A%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%20-1%3CBR%20%2F%3E%20J-Link%26gt%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1617779%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1617779%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F213615%22%20target%3D%22_blank%22%3E%40dmorvay%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%0A%3CP%3EI2C%20%E9%9B%BB%E5%9C%A7%E3%83%AC%E3%83%99%E3%83%AB%E3%81%AF%203.3V%20%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%93%E3%82%8C%E3%82%82%20MCU%20%E9%9B%BB%E5%9C%A7%E3%83%89%E3%83%A1%E3%82%A4%E3%83%B3%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%AB%E3%81%AF%205V%20%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E3%81%93%E3%82%8C%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AB%205V%20%E3%82%92%E4%BE%9B%E7%B5%A6%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3ERDDRONE-BMS772%20%E3%81%AE%E5%9B%9E%E8%B7%AF%E5%9B%B3%E3%81%AF%E3%80%81NXP%20%E3%81%AE%20Web%20%E3%83%9A%E3%83%BC%E3%82%B8%E3%81%8B%E3%82%89%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%20(%E8%A8%AD%E8%A8%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%99%E3%82%8B%E3%81%8B%E3%80%81%E8%A8%AD%E8%A8%88%E3%83%AA%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%BE%E3%81%A7%E4%B8%8B%E3%81%AB%E3%82%B9%E3%82%AF%E3%83%AD%E3%83%BC%E3%83%AB%E3%81%97%E3%81%BE%E3%81%99)%E3%80%82%3CBR%20%2F%3E%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesigns%2Fsmart-battery-management-for-mobile-robotics%3ARDDRONE-BMS772%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdesign%2F%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%2Fsmart-battery-management-for-mobile-robotics%3ARDDRONE-BMS772%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%95%AC%E5%85%B7%3C%2FP%3E%0A%3CP%3E%E3%82%B7%E3%82%B9%E3%83%BB%E3%83%95%E3%82%A1%E3%83%B3%E3%83%BB%E3%83%9F%E3%82%A8%E3%83%AB%E3%83%AD%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1617771%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1617771%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%3C%2FA%3E%20%E3%80%81%E6%83%85%E5%A0%B1%E3%82%92%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99!%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%A7%E3%82%82%E3%81%86%E4%B8%80%E5%BA%A6%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%E5%8F%82%E8%80%83%E3%81%BE%E3%81%A7%E3%81%AB%E3%80%81BMS772%20%E3%81%AE%20I2C%20%E9%80%81%E4%BF%A1%E9%9B%BB%E5%9C%A7%E3%81%AF%E3%81%84%E3%81%8F%E3%82%89%E3%81%A7%E3%81%99%E3%81%8B%3FI2C%E3%81%AF5V%E3%81%A7%E3%81%99%E3%81%8B%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%823.3V%E3%81%A7%E3%81%99%E3%81%8B%3F5V%20I2C%20(Arduino%20%E3%81%AA%E3%81%A9)%20%E3%82%92%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E3%80%813.3V%20%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E6%90%8D%E5%82%B7%E3%81%97%E3%81%9F%E3%81%8F%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1617458%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1617458%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F213615%22%20target%3D%22_blank%22%3E%40dmorvay%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%3CP%3E%E6%AD%A3%E3%81%97%E3%81%84%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%91%E3%83%BC%E3%82%92%E3%81%AF%E3%82%93%E3%81%A0%E4%BB%98%E3%81%91%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%82%BB%E3%83%AB%E9%9B%BB%E5%9C%A7%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AF%E7%B4%A0%E6%99%B4%E3%82%89%E3%81%97%E3%81%84%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EOLED%20%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E5%89%8D%E8%BF%B0%E3%81%97%E3%81%9F%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E3%83%A2%E3%83%87%E3%83%AB%20Based%20%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%20Toolbox%20%E3%81%AE%E4%BE%8B%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%82%88%E3%81%8F%E7%9F%A5%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%E3%81%8A%E3%81%9D%E3%82%89%E3%81%8F%E3%80%81LED%20%E3%81%AE%E4%BE%8B%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%AB%E3%81%82%E3%82%8B%20RGB-LED%20%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%82%AD%E3%83%83%E3%83%88%E3%81%AB%E4%BB%98%E5%B1%9E%E3%81%99%E3%82%8B%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AF%203.3V%20%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81NuttX%20RTOS%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20C%20%E3%81%A7%E8%A8%98%E8%BF%B0%E3%81%95%E3%82%8C%E3%81%9F%20BMS%20%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%20(%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E5%80%A4%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%82%92%E5%90%AB%E3%82%80)%20%E3%81%AB%E8%88%88%E5%91%B3%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E4%BE%8B%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3A%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3EPS%3A%20%E3%81%93%E3%82%8C%E3%81%AF%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88%E8%A1%A8%E7%A4%BA%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81%E3%82%B0%E3%83%A9%E3%83%95%E3%82%A3%E3%82%AB%E3%83%AB%E8%A1%A8%E7%A4%BA%E3%81%A7%E3%81%99%E3%80%82%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81%E5%90%84%E6%96%87%E5%AD%97%E3%81%AF%E3%80%81%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%E7%89%B9%E5%AE%9A%E3%81%AE%E3%83%95%E3%82%A9%E3%83%B3%E3%83%88%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E6%8F%8F%E7%94%BB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%95%AC%E5%85%B7%3C%2FP%3E%3CP%3E%E3%82%B7%E3%82%B9%E3%83%BB%E3%83%95%E3%82%A1%E3%83%B3%E3%83%BB%E3%83%9F%E3%82%A8%E3%83%AB%E3%83%AD%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1617200%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1617200%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%3C%2FA%3E%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%A3%E3%81%9F%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%81%AD%EF%BC%81%E3%81%A9%E3%81%86%E3%82%84%E3%82%89%E7%A7%81%E3%81%AF%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%91%E3%83%BC%E3%81%AE%E3%81%AF%E3%82%93%E3%81%A0%E4%BB%98%E3%81%91%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AE%E3%81%9D%E3%81%AE%E9%83%A8%E5%88%86%E3%82%92%E8%AA%AD%E3%82%93%E3%81%A7%E3%81%84%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EOLED%20%E7%94%BB%E9%9D%A2%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%82%82%E3%81%86%201%20%E3%81%A4%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%A7%E3%81%99%E3%80%82%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%AB%20LED%20%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%97%E3%81%A6%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E7%94%BB%E9%9D%A2%E3%81%8C%E3%82%AA%E3%83%B3%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E3%81%9D%E3%81%93%E3%81%A7%E4%BD%95%E3%81%8B%E7%89%B9%E5%88%A5%E3%81%AB%E3%82%84%E3%82%89%E3%81%AA%E3%81%91%E3%82%8C%E3%81%B0%E3%81%84%E3%81%91%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9FVCC%20%E3%81%A8%20GND%20%E9%96%93%E3%81%AE%20J23%20%E3%81%A7%203.3V%20%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E7%94%BB%E9%9D%A2%E3%82%92%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E3%82%82%E9%9B%BB%E6%BA%90%E3%81%8C%E5%85%A5%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E4%BD%95%E3%81%8B%E6%8F%90%E6%A1%88%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%E4%BB%8A%E6%97%A5%E3%81%AF%20D34%20%E3%81%A8%20D35%20%E3%81%AE%E3%83%80%E3%82%A4%E3%82%AA%E3%83%BC%E3%83%89%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E6%A9%9F%E4%BC%9A%E3%81%8C%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%813.3V%20%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%82%92%E7%A7%BB%E5%8B%95%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1616502%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1616502%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F213615%22%20target%3D%22_blank%22%3E%40dmorvay%3C%2FA%3E%20%E3%80%81%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%E3%83%A2%E3%83%87%E3%83%AB%E3%83%99%E3%83%BC%E3%82%B9%E9%96%8B%E7%99%BA%E3%83%84%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E3%81%AE%E4%BD%BF%E7%94%A8%E7%B5%8C%E9%A8%93%E3%81%8C%E3%81%BE%E3%81%A0%E3%81%AA%E3%81%84%E3%81%AE%E3%81%A7%E3%80%81%E3%81%93%E3%81%AE%E7%82%B9%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E5%A0%B4%E5%90%88%3A%3CBR%20%2F%3E%E3%81%AF%E3%82%93%E3%81%A0%E4%BB%98%E3%81%91%E3%81%95%E3%82%8C%E3%81%9F%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%91%E3%83%BC%E3%81%8C%203S%20%E3%81%AE%20SJ6%E3%80%81SJ10%E3%80%81SJ11%E3%80%81SJ12%20%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E%E3%82%BB%E3%83%AB%E9%9B%BB%E5%9C%A7%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%83%BC%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%8F%E9%85%8D%E7%BD%AE%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22cisvmierlo_0-1678950769358.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cisvmierlo_0-1678950769358.png%22%20style%3D%22width%3A%20261px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cisvmierlo_0-1678950769358.png%22%20style%3D%22width%3A%20261px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cisvmierlo_0-1678950769358.png%22%20style%3D%22width%3A%20261px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cisvmierlo_0-1678950769358.png%22%20style%3D%22width%3A%20261px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cisvmierlo_0-1678950769358.png%22%20style%3D%22width%3A%20261px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cisvmierlo_0-1678950769358.png%22%20style%3D%22width%3A%20261px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cisvmierlo_0-1678950769358.png%22%20style%3D%22width%3A%20261px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cisvmierlo_0-1678950769358.png%22%20style%3D%22width%3A%20261px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cisvmierlo_0-1678950769358.png%22%20style%3D%22width%3A%20261px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F214878i62C02D5A4FCD83F1%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22cisvmierlo_0-1678950769358.png%22%20alt%3D%22cisvmierlo_0-1678950769358.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%E6%95%AC%E5%85%B7%E3%80%81%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%B7%E3%82%B9%E3%83%BB%E3%83%95%E3%82%A1%E3%83%B3%E3%83%BB%E3%83%9F%E3%82%A8%E3%83%AB%E3%83%AD%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1616239%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1616239%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82%E4%BB%8A%E6%99%A9%E3%80%81BMS772%20%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%84%E3%81%A6%E3%80%81%E3%82%BB%E3%83%AB%E9%9B%BB%E5%9C%A7%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%823s%20%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E4%BD%95%E3%82%89%E3%81%8B%E3%81%AE%E7%90%86%E7%94%B1%E3%81%A7%E3%80%811%20%E3%81%A4%E3%81%AE%E3%82%BB%E3%83%AB%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E5%80%A4%E3%81%8C%E5%B8%B8%E3%81%AB%E4%BB%96%E3%81%AE%E3%82%BB%E3%83%AB%E3%82%88%E3%82%8A%E3%82%82%E9%AB%98%E3%81%8F%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%9E%E3%83%AB%E3%83%81%E3%83%A1%E3%83%BC%E3%82%BF%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E3%82%BB%E3%83%AB%E3%81%8C%E3%81%99%E3%81%B9%E3%81%A6%E3%81%BB%E3%81%BC%E5%90%8C%E3%81%98%E5%80%A4%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%822%E3%81%A4%E3%81%AE%E7%95%B0%E3%81%AA%E3%82%8B%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%83%91%E3%83%83%E3%82%AF%E3%81%A7%E3%82%82%E3%81%93%E3%82%8C%E3%82%92%E8%A9%A6%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E6%B7%BB%E4%BB%98%E3%81%AE%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%B7%E3%83%A7%E3%83%83%E3%83%88%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82BMS%20%E3%81%AF%E4%B8%80%E8%B2%AB%E3%81%97%E3%81%A6%E4%BB%96%E3%81%AE%E5%80%A4%E3%82%88%E3%82%8A%E3%82%82%E7%B4%84%200.7%20%E5%A4%A7%E3%81%8D%E3%81%84%E5%80%A4%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%B3%A8%E6%84%8F%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82FreeMaster%20%E3%81%A7%20J-Link%20%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%83%A2%E3%83%87%E3%83%AB%E3%83%99%E3%83%BC%E3%82%B9%E9%96%8B%E7%99%BA%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%A2%E3%83%89%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22dmorvay_0-1678921034731.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22dmorvay_0-1678921034731.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22dmorvay_0-1678921034731.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22dmorvay_0-1678921034731.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22dmorvay_0-1678921034731.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22dmorvay_0-1678921034731.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22dmorvay_0-1678921034731.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22dmorvay_0-1678921034731.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22dmorvay_0-1678921034731.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22dmorvay_0-1678921034731.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F214816i1AD583C84C4CDDF9%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22dmorvay_0-1678921034731.png%22%20alt%3D%22dmorvay_0-1678921034731.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1606759%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1606759%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3EBMS772%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AF%20Pixhawk%20Cube%20Orange%20Autopilot%20%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3CSTRONG%3EZubax%20ESC%E3%80%81Packet%20digital%20MPPT%20%E3%81%AA%E3%81%A9%E3%81%AE%E4%BB%96%E3%81%AE%20UAVCAN%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A8%E3%81%AE%E9%80%9A%E4%BF%A1%E3%81%AB%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSTRONG%3E%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%AF%E4%B8%8B%E8%A8%98%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81BMS772%E3%81%A7%E3%81%AF%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fpacketdigital.com%2Fpower-products%2Fmaximum-power-point-tracker%2F%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fpacketdigital.com%2Fpower-products%2Fmaximum-power-point-tracker%2F%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Ffiles.zubax.com%2Fproducts%2Fcom.zubax.telega%2FZubax_Myxa_Datasheet.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Ffiles.zubax.com%2Fproducts%2Fcom.zubax.telega%2FZubax_Myxa_Datasheet.pdf%3C%2FA%3E%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81BMS772%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AF%E5%BE%93%E6%9D%A5%E3%81%AE%20CAN%20(CAN%202.0)%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%82%82%E3%81%97%E3%81%9D%E3%81%86%E3%81%AA%E3%82%89%E3%80%81Microchip%20%E3%81%AE%20CAN%20%E3%83%90%E3%82%B9%20%E3%82%A2%E3%83%8A%E3%83%A9%E3%82%A4%E3%82%B6%E3%83%BC%E3%81%A7%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%98%8E%E7%A2%BA%E3%81%AB%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E5%89%8D%E3%82%82%E3%81%A3%E3%81%A6%E6%84%9F%E8%AC%9D%E3%81%97%E3%81%BE%E3%81%99..%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1604889%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1604889%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%B3%AA%E5%95%8F%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%E3%81%93%E3%82%8C%E3%81%AF%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A1%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%20segger%20jlink%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E9%96%8B%E7%99%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%AD%A6%E7%94%9F%E3%81%A7%E9%9D%9E%E5%95%86%E7%94%A8%E7%9B%AE%E7%9A%84%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81Adafruit%20%E3%81%AA%E3%81%A9%E3%81%AE%E3%82%B5%E3%83%97%E3%83%A9%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%8C%E6%8F%90%E4%BE%9B%E3%81%99%E3%82%8B%E4%BD%8E%E3%82%B3%E3%82%B9%E3%83%88%E3%81%AE%20jlink-edu%20%E3%81%AE%E3%81%84%E3%81%9A%E3%82%8C%E3%81%8B%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1604885%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Request%20for%20Register%20Map%20for%20NXP%20RDDrone-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1604885%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%95%E3%81%8C%E5%AE%9F%E8%A3%85%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%82%92%E7%9F%A5%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E5%AE%9F%E9%9A%9B%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%AE%E3%81%8C%E6%9C%80%E9%81%A9%E3%81%A7%E3%81%99%E3%80%82%E5%85%AC%E9%96%8B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1604876%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Request%20for%20Register%20Map%20for%20NXP%20RDDrone-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1604876%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%82%B9%E3%83%9E%E3%83%BC%E3%83%88%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E4%BB%95%E6%A7%98%E3%81%AF%E7%B5%90%E5%B1%80%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A1%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%95%E6%A7%98%E6%9B%B8%E3%81%AF%E3%81%93%E3%81%93%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3A%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fsbs-forum.org%2Fspecs%2Fsbdat110.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fsbs-forum.org%2Fspecs%2Fsbdat110.pdf%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1604268%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERequest%20for%20Register%20Map%20for%20NXP%20RDDrone-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1604268%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ENXP%20RDDRone-BMS772%20%E3%81%AE%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%83%9E%E3%83%83%E3%83%97%E8%A6%81%E6%B1%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E7%9A%86%E3%81%95%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E6%9C%80%E8%BF%91%E3%80%81%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E7%94%A8%E3%81%AB%20NXP%20RDDRone-BMS772%20%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%83%BB%E3%83%9E%E3%83%8D%E3%82%B8%E3%83%A1%E3%83%B3%E3%83%88%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E8%B3%BC%E5%85%A5%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81I2C%20%E7%B5%8C%E7%94%B1%E3%81%A7%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A8%E9%80%9A%E4%BF%A1%E3%81%99%E3%82%8B%E9%9A%9B%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8D%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20%E3%83%9E%E3%83%83%E3%83%97%E3%81%8C%E3%81%AA%E3%81%84%E3%81%A8%E3%80%81%E3%81%A9%E3%81%AE%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%8B%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%AA%E3%81%9F%E3%81%8B%E3%80%81RDDrone-BMS772%20%E3%81%AE%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20%E3%83%9E%E3%83%83%E3%83%97%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%AA%E3%81%84%E3%81%8B%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E3%81%A9%E3%81%93%E3%81%A7%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%89%E3%82%8C%E3%82%8B%E3%81%8B%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%E3%80%82%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20%E3%83%9E%E3%83%83%E3%83%97%E3%81%8C%E3%81%82%E3%82%8C%E3%81%B0%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A8%E9%80%9A%E4%BF%A1%E3%81%97%E3%81%A6%E5%BF%85%E8%A6%81%E3%81%AA%E6%83%85%E5%A0%B1%E3%82%92%E6%8A%BD%E5%87%BA%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AB%E9%9D%9E%E5%B8%B8%E3%81%AB%E5%BD%B9%E7%AB%8B%E3%81%A4%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%94%E5%8D%94%E5%8A%9B%E3%82%92%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1601937%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1601937%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%3CP%3E%E3%81%94%E5%8D%94%E5%8A%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E4%BD%8E%E9%9B%BB%E5%9C%A7%E9%9A%9C%E5%AE%B3%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%81%93%E3%81%A7%E3%80%81BMS%20%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%9F%20DroneCAN%20%2F%20UAVCAN%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%20%2F%20%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%95%E3%82%89%E3%81%8B%E3%81%AE%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%20%E3%83%84%E3%83%BC%E3%83%AB%E3%81%A7%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EBMS%20%E3%81%8B%E3%82%89%E3%81%AE%20CAN%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%20GUI%20%E3%83%84%E3%83%BC%E3%83%AB%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3EOrange%20Cube%20Autopilot%20%E3%81%AB%20BMS772%20%E3%82%92%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%83%83%E3%83%89%E3%81%97%E3%81%A6%E3%80%81DroneCAN%20GUI%20%E3%83%84%E3%83%BC%E3%83%AB%E3%81%A7%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E7%A7%81%E3%81%AF%E6%88%90%E5%8A%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%9F%E3%83%83%E3%82%B7%E3%83%A7%E3%83%B3%20%E3%83%97%E3%83%A9%E3%83%B3%E3%83%8A%E3%83%BC%20%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AF%20SLCAN%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%20BMS%20%E3%82%92%E8%AA%8D%E8%AD%98%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3ECube%20orange%20%E3%81%AF%E3%80%81Zubax%20ESC%E3%80%81Packet%20digital%20MPPT%20%E3%81%AA%E3%81%A9%E3%81%AE%E4%BB%96%E3%81%AE%20UAVCAN%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E6%A4%9C%E5%87%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81%E5%8B%95%E4%BD%9C%E3%81%95%E3%81%9B%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81DroneCAN%20%E3%81%AE%E9%9D%99%E7%9A%84%E3%83%8E%E3%83%BC%E3%83%89%20ID%20%E3%82%92%20255%20%E4%BB%A5%E5%A4%96%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3ENXP%20%E3%81%AE%20UCAN%20%E3%83%99%E3%83%BC%E3%82%B9%E3%83%8E%E3%83%BC%E3%83%89%E3%81%AF%E3%82%A4%E3%83%B3%E3%83%89%E3%81%A7%E3%81%AF%E8%B3%BC%E5%85%A5%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81BMS%20%E3%81%A7%E9%81%8E%E9%9B%BB%E6%B5%81%E3%80%81%E5%87%BA%E5%8A%9B%E7%9F%AD%E7%B5%A1%E4%BF%9D%E8%AD%B7%E3%81%8C%E5%88%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E6%98%8E%E7%A2%BA%E3%81%AB%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E4%B8%8A%E8%A8%98%E3%82%92%E6%98%8E%E7%A2%BA%E3%81%AB%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E5%A4%9A%E5%A4%A7%E3%81%AA%E3%82%8B%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%80%81%E6%94%B9%E3%82%81%E3%81%A6%E6%84%9F%E8%AC%9D%E7%94%B3%E3%81%97%E4%B8%8A%E3%81%92%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E...%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1601120%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1601120%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F195015%22%20target%3D%22_blank%22%3E%40Prince1%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E8%A7%A3%E6%B1%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%82%88%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%A7%E3%81%99!%3C%2FP%3E%0A%3CP%3E%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%3A%3C%2FP%3E%0A%3CP%3E%E3%80%8C%E3%81%AF%E3%81%84%E3%80%81CLI%20%E3%81%AB%E3%81%AF%E3%80%8C%E3%82%BB%E3%83%AB%E4%BD%8E%E9%9B%BB%E5%9C%A7%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F!%E3%80%8D%E3%81%A8%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%80%81Fluke%20%E3%81%AE%E8%A8%88%E6%B8%AC%E5%99%A8%E3%81%A7%E3%81%AF%2011.7V%20%E3%81%A8%E6%B8%AC%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AB%E3%82%82%E3%81%8B%E3%81%8B%E3%82%8F%E3%82%89%E3%81%9A%E3%80%81%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AB%E3%81%AF%2011.26V%20%E3%81%A8%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%80%8D%3C%2FP%3E%0A%3CP%3E%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%ABv-out%E3%81%A8%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%811%25%20%E3%81%AE%E8%A8%B1%E5%AE%B9%E8%AA%A4%E5%B7%AE%E3%82%92%E6%8C%81%E3%81%A4%E5%87%BA%E5%8A%9B%E3%81%AE%E6%8A%B5%E6%8A%97%E5%88%86%E5%89%B2%E5%99%A8%E3%82%92%E4%BB%8B%E3%81%97%E3%81%A6%E6%B8%AC%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81%E6%8A%B5%E6%8A%97%E5%99%A8%E3%81%AE%E8%A8%B1%E5%AE%B9%E8%AA%A4%E5%B7%AE%E3%81%AB%E3%82%88%E3%82%8A%E3%80%8126V%20%E3%81%A7%200.946V%20%E3%81%AE%E5%B7%AE%E3%81%8C%E7%94%9F%E3%81%98%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E5%AE%9F%E9%9A%9B%E3%81%AE%E5%80%A4%E3%81%A8%E3%81%AF%E5%B0%91%E3%81%97%E7%95%B0%E3%81%AA%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E7%8F%BE%E5%9C%A8%E3%81%AE%20SW%20%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E6%B8%AC%E5%AE%9A%E3%82%92%E5%BE%AE%E8%AA%BF%E6%95%B4%E3%81%99%E3%82%8B%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%80%81v-batt%20%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%8B%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%BB%E3%83%AB%E9%9B%BB%E5%9C%A7%E3%82%92%E5%90%88%E8%A8%88%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%20(%E3%81%93%E3%82%8C%E3%81%8C%E6%9C%80%E3%82%82%E6%AD%A3%E7%A2%BA%E3%81%A7%E3%81%99)%E3%80%82Vtot%20%3D%20v-cell1%20%2B%20v-cell2%20%2B%20..%3CBR%20%2F%3E%3CBR%20%2F%3E%20%E3%80%8C1.%E3%82%BB%E3%83%AB%E9%9B%BB%E5%9C%A7%E3%81%8C%203.8V%20%E6%9C%AA%E6%BA%80%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81Deep_Sleep%20%E3%81%AB%E3%81%AA%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82J5%20%E3%81%AB%E8%B2%A0%E8%8D%B7%E3%81%8C%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%A6%E3%82%82%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81%E8%B2%A0%E8%8D%B7%E3%81%8C%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%83%83%E3%83%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E3%82%BB%E3%83%AB%E3%81%AE%E3%82%AB%E3%83%83%E3%83%88%E3%82%AA%E3%83%95%E9%9B%BB%E5%9C%A7%E3%81%8C%203V%20%E3%81%AE%E3%81%A8%E3%81%8D%E3%81%AB%203.8V%20%E3%81%A7%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%82%92%E5%88%87%E6%96%AD%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AF%E6%97%A9%E3%81%99%E3%81%8E%E3%81%BE%E3%81%99%E3%80%82%E3%80%8D%3CBR%20%2F%3E%3CBR%20%2F%3ESO%E3%80%81%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E3%82%BB%E3%83%AB%E4%BD%8E%E9%9B%BB%E5%9C%A7%20(LiPo%20%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%81%AE%E5%A0%B4%E5%90%88)%20%E3%81%AF%203V%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%AF%E3%80%81UART%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E7%B5%8C%E7%94%B1%E3%81%A7%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20bms%E3%81%AFv-cell-uv%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%81%A6%E3%80%81%E9%81%A9%E5%88%87%E3%81%A8%E6%80%9D%E3%82%8F%E3%82%8C%E3%82%8B%E9%9B%BB%E5%9C%A7%E3%81%A7%E3%82%BB%E3%83%AB%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%3A%20%22bms%20set%20v-cell-uv%20x.xV%22%3CBR%20%2F%3E%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%9F%E3%82%89%E3%80%81%E3%80%8Cbms%20save%E3%80%8D%E3%81%A7%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AB%E4%BF%9D%E5%AD%98%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E5%BF%98%E3%82%8C%E3%81%AA%E3%81%84%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%8C%E3%81%82%E3%82%8B%E3%81%8B%E3%81%AE%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%20%3CA%20class%3D%22js-navigation-open%20Link--primary%22%20title%3D%22BMS772_%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%83%8E%E3%83%BC%E3%83%88_5.0.pdf%22%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2Fblob%2Fmain%2FBMS772_releaseNotes_5.0.pdf%22%20data-turbo-frame%3D%22repo-content-turbo-frame%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EBMS772_releaseNotes_5.0.pdf%20%E3%81%AE%E7%AC%AC%208.2%20%E7%AB%A0%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81UART%20%E6%8E%A5%E7%B6%9A%E3%82%92%E4%BB%8B%E3%81%97%E3%81%A6%E3%82%BB%E3%83%AB%E9%9B%BB%E5%9C%A7%E3%82%92%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%81%A9%E3%81%AE%E3%82%BB%E3%83%AB%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8B%E3%81%8B%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AF%E3%80%81%E3%80%8Cbms%20get%20all%E3%80%8D%EF%BC%88%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%82%92%E5%8F%96%E5%BE%97%EF%BC%89%E3%80%81%E3%80%8Cbms%20show%20all%201%E3%80%8D%EF%BC%88%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%81%AE%E5%80%A4%E3%82%92%E6%9B%B4%E6%96%B0%EF%BC%89%E3%80%81%E3%80%8Cbms%20show%20top%201%E3%80%8D%EF%BC%88%E3%82%B9%E3%82%AF%E3%83%AD%E3%83%BC%E3%83%AB%E3%81%9B%E3%81%9A%E3%81%AB%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%81%AE%E5%80%A4%E3%82%92%E6%9B%B4%E6%96%B0%EF%BC%89%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%80%8C2.BMS%20%E3%81%AE%E9%9B%BB%E5%9C%A7%E6%B8%AC%E5%AE%9A%E8%AA%A4%E5%B7%AE%E3%82%92%E4%BD%8E%E6%B8%9B%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E%E5%86%92%E9%A0%AD%E3%81%A7%E8%BF%B0%E3%81%B9%E3%81%9F%E3%82%88%E3%81%86%E3%81%AB%E3%80%81v-out%20%E9%9B%BB%E5%9C%A7%E3%82%92%E8%A3%9C%E6%AD%A3%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81SW%20%E3%82%92%E8%87%AA%E7%94%B1%E3%81%AB%E8%AA%BF%E6%95%B4%E3%81%97%E3%81%A6%E3%80%81%E3%81%9F%E3%81%A8%E3%81%88%E3%81%B0%E3%80%81%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AB%20v-out%20%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%20v-batt%20%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%95%AC%E5%85%B7%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%82%B7%E3%82%B9%E3%83%BB%E3%83%95%E3%82%A1%E3%83%B3%E3%83%BB%E3%83%9F%E3%82%A8%E3%83%AB%E3%83%AD%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1601097%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1601097%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AF%E7%A7%81%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%A6%E3%81%8F%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3EJ19%20%E6%8E%A5%E7%B6%9A%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81CLI%20%E3%81%A8%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%AF%E3%81%84%E3%80%81CLI%20%E3%81%AB%E3%81%AF%E3%80%8C%E3%82%BB%E3%83%AB%E4%BD%8E%E9%9B%BB%E5%9C%A7%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%8D%E3%81%A8%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%80%81Fluke%20%E6%A9%9F%E5%99%A8%E3%81%A7%E3%81%AF%2011.7V%20%E3%81%8C%E6%B8%AC%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AB%E3%82%82%E3%81%8B%E3%81%8B%E3%82%8F%E3%82%89%E3%81%9A%E3%80%81%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AB%E3%81%AF%2011.26V%20%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E1.%E3%82%BB%E3%83%AB%E9%9B%BB%E5%9C%A7%E3%81%8C%203.8V%20%E6%9C%AA%E6%BA%80%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81Deep_Sleep%20%E3%81%AB%E3%81%AA%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82J5%20%E3%81%AB%E8%B2%A0%E8%8D%B7%E3%81%8C%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%A6%E3%82%82%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81%E8%B2%A0%E8%8D%B7%E3%81%8C%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%83%83%E3%83%89%E3%81%A7%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E3%82%BB%E3%83%AB%E3%81%AE%E3%82%AB%E3%83%83%E3%83%88%E3%82%AA%E3%83%95%E9%9B%BB%E5%9C%A7%E3%81%8C%203V%20%E3%81%AE%E3%81%A8%E3%81%8D%E3%81%AB%203.8V%20%E3%81%A7%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%82%92%E5%88%87%E6%96%AD%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AF%E6%97%A9%E3%81%99%E3%81%8E%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E2.%20BMS%20%E3%81%AE%E9%9B%BB%E5%9C%A7%E6%B8%AC%E5%AE%9A%E8%AA%A4%E5%B7%AE%E3%82%92%E6%B8%9B%E3%82%89%E3%81%99%E3%81%93%E3%81%A8%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E4%B8%8A%E8%A8%98%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AB%E3%81%94%E5%9B%9E%E7%AD%94%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1601076%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1601076%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F195015%22%20target%3D%22_blank%22%3E%40Prince1%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%3CP%3EBMS1%20%E3%81%AE%E9%80%9A%E4%BF%A1%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%81%A3%E3%81%9F%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E9%BB%92%E3%81%84%E3%83%AF%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%AF%20J19%20%E3%83%94%E3%83%B3%201%20%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%203.3%20V%20%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E3%82%B0%E3%83%A9%E3%83%B3%E3%83%89%E3%81%AB%E3%81%AF%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%E3%82%A2%E3%83%BC%E3%82%B9%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E9%BB%92%E8%89%B2%E3%81%AE%E3%83%AF%E3%82%A4%E3%83%A4%E3%82%92%20J19%20%E3%83%94%E3%83%B3%207%20(%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%E3%81%AE%E5%8F%8D%E5%AF%BE%E5%81%B4)%20%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%B0%B4%E8%89%B2%E3%81%AF%20J19%20%E3%83%94%E3%83%B3%205%20(SWD_CLK)%20%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%80%81%E9%BB%84%E8%89%B2%E3%81%AF%20J19%20%E3%83%94%E3%83%B3%206%20(RST_N)%20%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%20J19%20%E3%81%AE%E6%8E%A5%E7%B6%9A%E3%82%92%E4%BA%A4%E6%8F%9B%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%BB%96%E3%81%AE%20PCB%20%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E5%BE%8C%E3%81%A7%E3%81%BE%E3%81%9F%E5%8F%96%E3%82%8A%E4%B8%8A%E3%81%92%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%95%AC%E5%85%B7%3C%2FP%3E%3CP%3E%E3%82%B7%E3%82%B9%E3%83%BB%E3%83%95%E3%82%A1%E3%83%B3%E3%83%BB%E3%83%9F%E3%82%A8%E3%83%AB%E3%83%AD%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1601062%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1601062%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%40CisvanMierlo%E3%81%95%E3%82%93%E3%80%81%3C%2FP%3E%3CP%3E2%E3%81%A4%E3%81%AEBMS%E3%81%AE%E7%94%BB%E5%83%8F%E3%82%92%E6%B7%BB%E4%BB%98%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E1%20%E7%95%AA%E7%9B%AE%3A%20Deep_Sleep%20%E3%81%AB%E5%85%A5%E3%82%8B%E5%89%8D%E3%81%AB%20LED%20%E3%81%8C%201%20%E5%88%86%E9%96%93%E8%B5%A4%E8%89%B2%E3%81%AB%E7%82%B9%E6%BB%85%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E2%E7%95%AA%E7%9B%AE%3A%20%E9%81%8E%E7%86%B1%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81LED%E3%81%8C%E7%82%B9%E7%81%AF%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E5%E3%83%94%E3%83%B3%E3%82%BB%E3%83%AB%E3%82%BF%E3%83%BC%E3%83%9F%E3%83%8A%E3%83%AB%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%814S%E3%83%94%E3%83%B3%EF%BC%885%E7%95%AA%E7%9B%AE%E3%81%AE%E3%83%94%E3%83%B3%E3%81%AF%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%EF%BC%89%2F%E3%83%AF%E3%82%A4%E3%83%A4%E3%82%92%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82SO%E3%80%813S%20%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%81%AB%E3%81%AF%205%20%E3%83%94%E3%83%B3%20%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82JP1%20%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%E3%81%AE%E9%9B%BB%E5%9C%A7%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%8A%E6%97%A5%E3%80%81%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%82%92%2011.7V%20%E3%81%BE%E3%81%A7%E5%85%85%E9%9B%BB%E3%81%97%E3%81%A6%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E7%B5%90%E6%9E%9C%E3%81%AF%E5%90%8C%E3%81%98%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1600460%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1600460%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F195015%22%20target%3D%22_blank%22%3E%40Prince1%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%3CP%3E%E3%82%BB%E3%83%AB%E3%81%AE%E4%BD%8E%E9%9B%BB%E5%9C%A7%E6%A4%9C%E5%87%BA%E3%81%AE%E3%81%BF%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%811%20%E5%88%86%E5%BE%8C%E3%81%AB%E3%83%87%E3%82%A3%E3%83%BC%E3%83%97%E3%82%B9%E3%83%AA%E3%83%BC%E3%83%97%E7%8A%B6%E6%85%8B%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%8A%E3%81%9D%E3%82%89%E3%81%8F%E3%80%81%E6%90%BA%E5%B8%AF%E9%9B%BB%E8%A9%B1%E3%81%AE%E6%8E%A5%E7%B6%9A%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%80%82%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E7%94%BB%E5%83%8F%EF%BC%88%E4%B8%8A%E9%83%A8%E3%81%A8%E4%B8%8B%E9%83%A8%EF%BC%89%E3%82%82%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%95%AC%E5%85%B7%3C%2FP%3E%3CP%3E%E3%82%B7%E3%82%B9%E3%83%BB%E3%83%95%E3%82%A1%E3%83%B3%E3%83%BB%E3%83%9F%E3%82%A8%E3%83%AB%E3%83%AD%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1600427%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1600427%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81Cis%20van%20Mierlo%E3%81%95%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3EBMS%20%E3%81%AE%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%3CSTRONG%3EV-cell-UV%3C%2FSTRONG%3E%E3%81%AF%203V%20%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%20%E3%82%BB%E3%83%AB%E3%81%AE%E9%9B%BB%E5%9C%A7%E3%81%AF%203.8V%20%E3%82%92%E8%B6%85%E3%81%88%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%813S%20%E3%83%91%E3%83%83%E3%82%AF%E3%81%AE%E9%9B%BB%E5%9C%A7%E3%81%AF%2011.5V%20%E3%81%A7%E3%81%99%E3%80%82BMS%20%E3%81%8C%20Deep_Sleep%20%E7%8A%B6%E6%85%8B%E3%81%AB%E3%81%AA%E3%82%8B%E5%8E%9F%E5%9B%A0%E3%81%AF%E9%9B%BB%E5%9C%A7%E4%B8%8D%E8%B6%B3%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EBMS%20LED%20%E3%81%8C%201%20%E5%88%86%E9%96%93%E8%B5%A4%E8%89%B2%E3%81%AB%E7%82%B9%E6%BB%85%E3%81%97%E3%81%A6%E3%81%8B%E3%82%89%20Deep_Sleep%20%E7%8A%B6%E6%85%8B%E3%81%AB%E3%81%AA%E3%82%8B%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%E7%90%86%E7%94%B1%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3ED34%20%E3%81%AF%E9%85%8D%E7%BD%AE%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81D35%20%E3%81%AF%E9%85%8D%E7%BD%AE%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%BE%E3%81%A0%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%8C%E3%82%AA%E3%83%B3%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AE%E3%83%94%E3%83%B3%E7%95%AA%E5%8F%B7%E3%81%AF%E6%8F%90%E6%A1%88%E3%81%A9%E3%81%8A%E3%82%8A%E3%81%AB%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%83%83%E3%83%89%E3%81%A8%E3%81%97%E3%81%A6%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E9%81%8E%E7%86%B1%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E4%BB%96%E3%81%AE%20BMS%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E7%94%BB%E5%83%8F%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1600323%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1600323%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F195015%22%20target%3D%22_blank%22%3E%40Prince1%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%3CP%3E%E3%80%8CBMS%20LED%20%E3%81%8C%E8%B5%A4%E8%89%B2%E3%81%AB%E7%82%B9%E6%BB%85%E3%81%97%E3%80%81%E7%B4%84%201%20%E5%88%86%E5%BE%8C%E3%81%AB%E6%B6%88%E7%81%AF%E3%81%97%E3%81%BE%E3%81%99%E3%80%82SLEEP%E3%81%99%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%80%8D%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E3%82%BB%E3%83%AB%E3%81%AE%E4%BD%8E%E9%9B%BB%E5%9C%A7%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%20(%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%83%86%E3%82%AF%E3%83%8E%E3%83%AD%E3%82%B8%3A%20LiPo%20%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%8F)%E3%80%82%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E7%8A%B6%E6%B3%81%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81BMS%20%E3%81%AF%20t-fault-timeout%20(%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AF%2060%20%E7%A7%92)%20%E5%BE%8C%E3%81%AB%20DEEP_SLEEP%20%E3%81%AB%E7%A7%BB%E8%A1%8C%E3%81%97%E3%80%81%E6%9C%80%E4%BD%8E%E9%9B%BB%E5%8A%9B%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%82%92%E4%BF%9D%E8%AD%B7%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3EDEEP_SLEEP%20%E7%8A%B6%E6%85%8B%E3%81%A7%E3%81%AF%20MCU%20(%E3%81%8A%E3%82%88%E3%81%B3%20SBC)%20%E3%81%8C%E3%82%AA%E3%83%95%E3%81%AB%E3%81%AA%E3%82%8B%E3%81%9F%E3%82%81%E3%80%811%20%E5%88%86%E5%BE%8C%E3%81%AB%E3%81%AF%E9%80%9A%E4%BF%A1%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%8F%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E6%8A%BC%E3%81%99%20(%E3%81%BE%E3%81%9F%E3%81%AF%E9%9B%BB%E6%BA%90%E3%82%92%E5%86%8D%E6%8A%95%E5%85%A5%E3%81%99%E3%82%8B)%20%E3%81%93%E3%81%A8%E3%81%8C%E3%80%81BMS%20%E3%82%92%20DEEP_SLEEP%20%E7%8A%B6%E6%85%8B%E3%81%8B%E3%82%89%E5%BE%A9%E5%B8%B0%E3%81%95%E3%81%9B%E3%82%8B%E5%94%AF%E4%B8%80%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3ESO%E3%80%81BMS%20%E3%81%8C%20DEEP_SLEEP%20%E7%8A%B6%E6%85%8B%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%9F%E3%81%9F%E3%82%81%E3%81%AB%E9%80%9A%E4%BF%A1%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%82%E3%82%8B%E3%81%84%E3%81%AF%E3%80%81%E6%8E%A5%E7%B6%9A%E3%81%AB%E9%96%A2%E3%81%97%E3%81%A6%E4%BD%95%E3%81%8B%E3%81%82%E3%82%8B%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E5%88%9D%E6%9C%9F%E5%8C%96%E4%B8%AD%E3%81%AB%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%82%92%E3%82%AA%E3%83%B3%E3%81%AB%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81D35%20%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%20D34%20%E3%81%8C%E9%85%8D%E7%BD%AE%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%BB%96%E3%81%AE%20BMS%20%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%A7%E3%81%AF%E3%80%81SBC%20%E3%81%8C%E9%81%8E%E7%86%B1%E3%81%97%E3%80%81LED%20%E3%81%8C%E7%82%B9%E7%81%AF%E3%81%97%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%813.3V%20%E3%83%89%E3%83%A1%E3%82%A4%E3%83%B3%E3%81%AB%E7%9F%AD%E7%B5%A1%20(GND%20%E3%81%AB%E7%9F%AD%E7%B5%A1)%20%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E4%B8%A1%E6%96%B9%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%EF%BC%88%E4%B8%8A%E9%9D%A2%E3%81%A8%E4%B8%8B%E9%9D%A2%EF%BC%89%E3%82%92%E8%A6%8B%E3%81%9B%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%95%AC%E5%85%B7%E3%80%81%3C%2FP%3E%3CP%3E%E3%82%B7%E3%82%B9%E3%83%BB%E3%83%95%E3%82%A1%E3%83%B3%E3%83%BB%E3%83%9F%E3%82%A8%E3%83%AB%E3%83%AD%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1600171%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1600171%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CSPAN%20class%3D%22%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F90400%22%20target%3D%22_self%22%3E%3CSPAN%20class%3D%22%22%3EGeraldP%E3%81%95%E3%82%93%3C%2FSPAN%3E%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%96%B0%E3%81%97%E3%81%84BMS%E3%81%A7%E6%AC%A1%E3%81%AE%E3%81%93%E3%81%A8%E3%82%92%E8%A1%8C%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E3S%20%E6%A7%8B%E6%88%90%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81SJ6%E3%80%8110%E3%80%8111%E3%80%8112%20%E3%81%AF%E7%9F%AD%E7%B5%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E3S%20LiPo%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%81%AFJ4%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%80%81%E3%82%BB%E3%83%AB%E3%83%90%E3%83%A9%E3%83%B3%E3%82%B9%E3%83%AF%E3%82%A4%E3%83%A4%E3%81%AFJP1%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EFTDI%20USB%20UART%E3%81%AE%E3%83%94%E3%83%B35%E3%80%814%E3%80%811%E3%81%AF%E3%81%9D%E3%82%8C%E3%81%9E%E3%82%8CJ19%E3%81%AE%E3%83%94%E3%83%B32%E3%80%813%E3%80%817%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%80%81PC%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E115k2%208n1%E3%80%81%E3%83%91%E3%83%AA%E3%83%86%E3%82%A3%3A%E3%81%AA%E3%81%97%E3%80%81%E3%83%95%E3%83%AD%E3%83%BC%3A%E3%81%AA%E3%81%97%EF%BC%88COM%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AE%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%E3%81%A8Tera%20Term%E3%81%A7%E8%A8%AD%E5%AE%9A%EF%BC%89%3C%2FP%3E%3CP%3E%E7%B5%90%E6%9E%9C%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EBMS%20LED%20%E3%81%8C%E8%B5%A4%E8%89%B2%E3%81%AB%E7%82%B9%E6%BB%85%E3%81%97%E3%80%81%E7%B4%84%201%20%E5%88%86%E5%BE%8C%E3%81%AB%E6%B6%88%E7%81%AF%E3%81%97%E3%81%BE%E3%81%99%E3%80%82SLEEP%E7%8A%B6%E6%85%8B%E3%81%AB%E3%81%AA%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EJ5%E3%81%AEBMS%E5%87%BA%E5%8A%9B%E9%9B%BB%E5%9C%A7%E3%81%AF%E3%82%BC%E3%83%AD%E3%81%A7%E3%81%99%EF%BC%88%E8%B2%A0%E8%8D%B7%E3%81%AF%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%83%83%E3%83%89%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%EF%BC%89%3C%2FP%3E%3CP%3ETera%20Term%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%E3%81%AB%E7%A9%BA%E7%99%BD%E3%81%AE%E7%94%BB%E9%9D%A2%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%80%81%E3%82%AD%E3%83%BC%E3%83%9C%E3%83%BC%E3%83%89%E5%85%A5%E5%8A%9B%E3%81%8C%E5%8F%97%E3%81%91%E4%BB%98%E3%81%91%E3%82%89%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3EJ23%E3%81%AB%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%83%83%E3%83%89%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%8C%E3%82%AA%E3%83%B3%E3%81%AB%E3%81%AA%E3%82%89%E3%81%AA%E3%81%84%3C%2FP%3E%3CP%3E%E4%B8%8A%E8%A8%98%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AE%E8%A7%A3%E6%B1%BA%E3%81%AB%E3%81%94%E5%8D%94%E5%8A%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E5%88%A5%E3%81%AE%20BMS%20%E3%81%A7%E3%82%82%E5%90%8C%E3%81%98%E3%81%93%E3%81%A8%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81LED%20%E3%81%AF%E7%82%B9%E7%81%AF%E3%81%9B%E3%81%9A%E3%80%81SBC%20%E3%83%81%E3%83%83%E3%83%97%E3%81%8C%E9%81%8E%E7%86%B1%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1596441%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1596441%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EJ-Link%20%E3%82%84%20PEMicro%20%E4%BB%A5%E5%A4%96%E3%81%A7%E3%80%81NXP%20RDDRONE-BMS%20%E3%81%AB%E9%81%A9%E3%81%97%E3%81%9F%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%83%BC%E3%82%92%E3%81%A9%E3%81%93%E3%81%A7%E8%B3%BC%E5%85%A5%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%8B%E7%9F%A5%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E4%BA%BA%E3%81%AF%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%3F%20%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1594395%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1594395%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CSPAN%20class%3D%22%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F90400%22%20target%3D%22_self%22%3E%3CSPAN%20class%3D%22%22%3EGeraldP%E3%81%95%E3%82%93%3C%2FSPAN%3E%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%81%94%E5%8D%94%E5%8A%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%94%E6%8F%90%E6%A1%88%E3%81%84%E3%81%9F%E3%81%A0%E3%81%84%E3%81%9F%E6%96%B9%E6%B3%95%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1594197%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1594197%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F195015%22%20target%3D%22_blank%22%3E%40Prince1%3C%2FA%3E%20%E3%80%81%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%BB%E3%83%AB%E7%95%AA%E5%8F%B7%E3%81%A8%E7%95%B0%E3%81%AA%E3%82%8B%E3%82%BB%E3%83%AB%E7%95%AA%E5%8F%B7%E3%82%92%E6%8C%81%E3%81%A4%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%81%8C%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%83%83%E3%83%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81SW%20%E3%81%AF%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E5%A0%B1%E5%91%8A%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%80%81%E9%9B%BB%E6%BA%90%E5%87%BA%E5%8A%9B%E3%81%AF%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3EBMS%20%E3%82%92%E6%A7%8B%E6%88%90%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%81%8C%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%83%83%E3%83%89%E3%81%A7%E3%81%82%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3EBMS%20%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%20-%20UART%20%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%E3%83%BC%E3%82%92%E6%8E%A5%E7%B6%9A%E3%81%97%E3%80%81115k2%208n1%20%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%20%E3%83%9D%E3%83%BC%E3%83%88%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%82%BF%E3%83%BC%E3%83%9F%E3%83%8A%E3%83%AB%20SW%20%E3%82%92%E9%96%8B%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20-%20%E3%83%90%E3%83%A9%E3%83%B3%E3%82%B5%E3%83%BC%E3%81%A8%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%81%AE%E4%B8%BB%E9%9B%BB%E6%BA%90%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%E3%82%92BMS%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E-%20%E8%B5%B7%E5%8B%95%E3%82%B7%E3%83%BC%E3%82%B1%E3%83%B3%E3%82%B9%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3CA%20href%3D%22https%3A%2F%2Fnxp.gitbook.io%2Frddrone-bms772%2Fsoftware-guide-nuttx%2Ffirst-start-up%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E6%9C%80%E5%88%9D%E3%81%AE%E8%B5%B7%E5%8B%95%20-%20RDDRONE-BMS772%20(gitbook.io)%3C%2FA%3E%3CBR%20%2F%3E-%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%3CA%20href%3D%22https%3A%2F%2Fnxp.gitbook.io%2Frddrone-bms772%2Fsoftware-guide-nuttx%2Fcommand-line-interface-cli%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%20(CLI)%20%E7%B5%8C%E7%94%B1%E3%81%A7%20BMS%20%E3%82%92%E6%A7%8B%E6%88%90%E3%81%99%E3%82%8B%20-%20RDDRONE-BMS772%20(gitbook.io)%3C%2FA%3E%3CBR%20%2F%3Ebms%20set%3CPARAMETER%20name%3D%22%22%3E%3CVALUE%3E%3CA%20href%3D%22https%3A%2F%2Fnxp.gitbook.io%2Frddrone-bms772%2Fsoftware-guide-nuttx%2Funtitled-1%23bms-configuration-parameters-list%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%20BMS%E3%81%AE%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%20-%20RDDRONE-BMS772%20(gitbook.io)%3C%2FA%3E%3CBR%20%2F%3E-%20BMS%E3%82%BB%E3%83%BC%E3%83%96%E3%81%A7%E7%B5%82%E4%BA%86%3CBR%20%2F%3E%E3%80%8Creboot%E3%80%8D%E3%81%A8%E5%85%A5%E5%8A%9B%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81BMS%20%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%84%E8%A8%AD%E5%AE%9A%E3%81%A7%E5%86%8D%E8%B5%B7%E5%8B%95%E3%81%97%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AB%E3%81%AF%E5%87%BA%E5%8A%9B%E3%82%92%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FVALUE%3E%3C%2FPARAMETER%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1593928%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1593928%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%80%81Tx%E3%80%81Rx%E3%80%81GND%20%E3%81%AB%20%3CFONT%20size%3D%223%22%3E3.3V%20%E3%82%92%E4%BE%9B%E7%B5%A6%E3%81%99%E3%82%8B%3C%2FFONT%3E%3CSTRONG%3E%3CFONT%20size%3D%223%22%3E%20PL2303HX%20USB%20%E3%81%8B%E3%82%89%20TTL%20(%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB)%20%E3%81%B8%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%90%E3%83%BC%E3%82%BF%E3%82%92%20%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FFONT%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Frobu.in%2Fproduct%2Fpl2303-pl2303hx-usb-ttl-module-5-pin%2F%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Frobu.in%2Fproduct%2Fpl2303-pl2303hx-usb-ttl-%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB-5%E3%83%94%E3%83%B3%2F%3C%2FA%3E%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%A7%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E5%86%8D%E6%A7%8B%E6%88%90%E3%82%92%E8%A9%A6%E3%81%BF%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CFONT%20size%3D%223%22%3EPL2303HX%20%E3%81%AF%3C%2FFONT%3E%3C%2FSTRONG%3EUSB%20%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AB%E6%8C%BF%E5%85%A5%E3%81%95%E3%82%8C%E3%80%81%E3%81%9D%E3%81%AE%20TX%E3%80%81RX%E3%80%81GND%20%E3%83%94%E3%83%B3%E3%81%AF%20J19%20%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AE%E3%81%9D%E3%82%8C%E3%81%9E%E3%82%8C%E3%81%AE%E3%83%94%E3%83%B3%E3%81%AB%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%83%83%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E5%9B%9E%E8%B7%AF%E3%81%AB%E9%9B%BB%E5%8A%9B%E3%82%92%E4%BE%9B%E7%B5%A6%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%82%92%20BMS%20(J4)%20%E3%81%AB%E3%82%82%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%82%82%E3%81%97%E3%81%9D%E3%81%86%E3%81%AA%E3%82%89%E3%80%814S%20%E3%81%BE%E3%81%9F%E3%81%AF%203S%20%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%20BMS%20%E3%81%A8%E5%90%8C%E6%A7%98%E3%81%AB%E3%80%814S%20%E3%82%BB%E3%83%AB%E7%AB%AF%E5%AD%90%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%E3%81%AF%20JP1%20%E3%81%AB%E3%81%AF%E3%82%93%E3%81%A0%E4%BB%98%E3%81%91%E3%81%95%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81SJ3%E3%80%81SJ7%E3%80%81SJ11%E3%80%81SJ12%20%E3%81%8C%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E5%B7%A5%E5%A0%B4%E5%87%BA%E8%8D%B7%E6%99%82%E3%81%AE%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E6%A7%8B%E6%88%90%E3%81%AF%203S%20%E3%81%A7%E3%81%99%E3%80%82SO%E3%80%81%E7%A7%81%E3%81%AF%E6%B7%B7%E4%B9%B1%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1586545%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1586545%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F195015%22%20target%3D%22_blank%22%3E%40Prince1%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%81%AF%E3%81%84%E3%80%81%E3%81%93%E3%81%AE%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%B7%E3%83%A7%E3%83%83%E3%83%88%E3%81%AB%E7%A4%BA%E3%81%99%E3%82%88%E3%81%86%E3%81%AB%E3%80%81GND%E3%80%81TX%E3%80%81RX%20%E3%82%92%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E6%B8%88%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22cisvmierlo_0-1674467103221.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cisvmierlo_0-1674467103221.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cisvmierlo_0-1674467103221.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cisvmierlo_0-1674467103221.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cisvmierlo_0-1674467103221.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cisvmierlo_0-1674467103221.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cisvmierlo_0-1674467103221.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cisvmierlo_0-1674467103221.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cisvmierlo_0-1674467103221.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cisvmierlo_0-1674467103221.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F208136i231AF9CF29015C16%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22cisvmierlo_0-1674467103221.png%22%20alt%3D%22cisvmierlo_0-1674467103221.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E%3CSPAN%20data-slate-fragment%3D%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%22%3EUSB-TTL-%20%3CSTRONG%3E3V3%3C%2FSTRONG%3E%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%B3%A8%E6%84%8F%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81RX%20%E3%83%94%E3%83%B3%E3%81%A8%20TX%20%E3%83%94%E3%83%B3%E3%81%A7%203.3V%20%E3%83%AD%E3%82%B8%E3%83%83%E3%82%AF%20%E3%83%AC%E3%83%99%E3%83%AB%E3%81%8C%E4%BF%9D%E8%A8%BC%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%95%AC%E5%85%B7%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20data-slate-fragment%3D%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%22%3E%E3%82%B7%E3%82%B9%E3%83%BB%E3%83%95%E3%82%A1%E3%83%B3%E3%83%BB%E3%83%9F%E3%82%A8%E3%83%AB%E3%83%AD%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1586527%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1586527%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3Eiaingalloway%E3%81%95%E3%82%93%3C%2FSPAN%3E%3C%2FSPAN%3E%E3%80%81%3C%2FP%3E%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EBMS%20%E6%A7%8B%E6%88%90%E3%82%92%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%203S%20%E3%81%8B%E3%82%89%204S%20%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%80%81%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%20%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%82%92%E9%80%9A%E3%81%98%E3%81%A6%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%81%AE%E5%8C%96%E5%AD%A6%E7%B5%84%E6%88%90%E3%82%82%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E8%80%83%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AB%E3%81%AF%E3%80%81JST%20GH%207%20%E3%83%94%E3%83%B3%20%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%20(Tx%E3%80%81Rx%E3%80%81GND%20%E3%83%94%E3%83%B3%E3%81%AE%E3%81%BF)%20%E3%81%AB%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%83%83%E3%83%89%20FTDI%20%E3%82%BF%E3%82%A4%E3%83%97%E3%81%AE%20USB-UART%20%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%81%A7%E5%8D%81%E5%88%86%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81J%20link%20EDU%20%E3%83%9F%E3%83%8B%20%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%83%AA%E3%83%BC%E3%83%89%20%E3%82%BF%E3%82%A4%E3%83%A0%E3%81%AF%2040%20%E9%80%B1%E9%96%93%E3%81%8B%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82SO%E3%80%81%E7%8F%BE%E6%99%82%E7%82%B9%E3%81%A7%E3%81%AF%E6%A7%8B%E6%88%90%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1586201%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1586201%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%82%82%E3%81%86%E5%8F%A4%E3%81%84%E6%8A%95%E7%A8%BF%E3%81%A0%E3%81%A8%E3%81%AF%E3%82%8F%E3%81%8B%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%82%AF%E3%83%AD%E3%82%B9%E3%83%9D%E3%82%B9%E3%83%88%E3%81%97%E3%81%A6%E3%80%81%E3%83%A2%E3%83%87%E3%83%AB%E3%83%99%E3%83%BC%E3%82%B9%E8%A8%AD%E8%A8%88%E3%83%81%E3%83%BC%E3%83%A0%E3%81%AB%E3%81%93%E3%81%93%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E4%BE%9D%E9%A0%BC%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FModel-Based-Design-Toolbox-MBDT%2FRDDRONE-BMS771-MBDT-question%2Fm-p%2F1586198%23M7996%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2F%E3%83%A2%E3%83%87%E3%83%AB%E3%83%99%E3%83%BC%E3%82%B9%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%83%84%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9MBDT%2FRDDRONE-BMS771-MBDT-question%2Fmp%2F1586198%23M7996%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1586193%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1586193%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81NuttX%2FPX4%20%E3%81%A7%E3%81%AF%20CAN%20%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E4%BD%9C%E6%A5%AD%E3%82%82%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E8%A1%8C%E3%82%8F%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%B3%A8%E6%84%8F%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E7%8F%BE%E6%99%82%E7%82%B9%E3%81%A7%E3%81%AF%E3%81%93%E3%82%8C%E3%82%89%E3%81%AF%E4%B8%8D%E5%AE%8C%E5%85%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1586179%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1586179%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%AB%E3%81%AF%E3%80%81%E6%8F%90%E6%A1%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%20DroneCode%20%E6%A8%99%E6%BA%96%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6FUTURE%E8%BF%BD%E5%8A%A0%E3%81%95%E3%82%8C%E3%82%8B%E3%81%93%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%97%E3%81%AE%E6%A9%9F%E8%83%BD%E7%94%A8%E3%81%AB%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%9F%E8%BF%BD%E5%8A%A0%E3%81%AE%20GPIO%20%E3%82%82%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%B3%A8%E6%84%8F%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%93%E3%81%93%E3%81%AB%E3%81%AF%E3%80%81%E8%BB%8A%E8%BC%89%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%81%AE%E8%AD%98%E5%88%A5%E3%81%AA%E3%81%A9%E3%80%81%E8%BF%BD%E5%8A%A0%E6%A9%9F%E8%83%BD%E3%81%AE%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8B%E3%82%82%E3%81%AE%E3%81%8C%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%82%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%9B%B8%E3%81%8F%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AB%E5%8A%A0%E3%81%88%E3%81%A6%E3%80%81%3CBR%20%2F%3E%E3%81%93%E3%82%8C%E3%82%89%E3%81%AF%E5%88%A5%E3%81%AE%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E3%81%AB%E9%85%8D%E7%BD%AE%E3%81%95%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%83%89%E3%83%AD%E3%83%BC%E3%83%B3%E3%81%BE%E3%81%9F%E3%81%AF%E8%BB%8A%E8%BC%89%E3%81%AB%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%82%92%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AB%E3%82%A2%E3%82%B5%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81NXP.com%20%E3%81%AE%E5%9B%9E%E8%B7%AF%E5%9B%B3%E3%82%92%E5%8F%82%E7%85%A7%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%81%93%E3%81%A7%E3%81%AF%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%20J21%20%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%A8%80%E5%8F%8A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CDIV%20id%3D%22tinyMceEditoriaingalloway_0%22%20class%3D%22mceNonEditable%20lia-copypaste-placeholder%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22iaingalloway_2-1674236410319.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_2-1674236410319.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_2-1674236410319.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_2-1674236410319.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_2-1674236410319.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_2-1674236410319.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_2-1674236410319.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_2-1674236410319.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_2-1674236410319.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_2-1674236410319.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F208066i4CA12BCA40A012A6%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22iaingalloway_2-1674236410319.png%22%20alt%3D%22iaingalloway_2-1674236410319.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22iaingalloway_3-1674236426257.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_3-1674236426257.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_3-1674236426257.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_3-1674236426257.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_3-1674236426257.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_3-1674236426257.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_3-1674236426257.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_3-1674236426257.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_3-1674236426257.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_3-1674236426257.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F208067i7CB2E73936BFA44F%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22iaingalloway_3-1674236426257.png%22%20alt%3D%22iaingalloway_3-1674236426257.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CDIV%20id%3D%22tinyMceEditoriaingalloway_1%22%20class%3D%22mceNonEditable%20lia-copypaste-placeholder%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1586168%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1586168%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%20%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E5%86%85%E9%83%A8%E3%81%A7%E4%BD%95%E3%81%8C%E8%B5%B7%E3%81%93%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%AE%E5%A0%B4%E5%90%88%20(%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E5%86%8D%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%82%84%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%AF%E8%A1%8C%E3%82%8F%E3%81%AA%E3%81%84)%E3%80%81FTDI%20%E3%82%BF%E3%82%A4%E3%83%97%E3%81%AE%20USB-UART%20%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%82%92%E8%B3%BC%E5%85%A5%E3%81%97%E3%81%A6%20(%E3%81%BE%E3%81%9F%E3%81%AF%20UART%20%E6%90%AD%E8%BC%89%E3%81%AE%20PC%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6)%E3%80%81%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%20%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%82%92%20BMS772%20%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E9%80%9A%E5%B8%B8%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%20DCD-LZ%20%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%A7%E5%88%86%E5%89%B2%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E7%B0%A1%E5%8D%98%E3%81%AB%E5%B7%AE%E3%81%97%E8%BE%BC%E3%82%80%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3EAmazon%20%E3%82%84%20Digikey%20%E3%81%AA%E3%81%A9%E3%81%A7%E8%B3%BC%E5%85%A5%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%81%AE%E7%A8%AE%E9%A1%9E%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%3CA%20href%3D%22https%3A%2F%2Fwww.digikey.com%2Fen%2Fproducts%2Fdetail%2Fftdi-future-technology-devices-international-ltd%2FTTL-234X-3V3%2F6823715%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.digikey.com%2Fen%2Fproducts%2Fdetail%2Fftdi-future-technology-devices-international-ltd%2FTTL-234X-3V3%2F6823715%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22iaingalloway_0-1674235896394.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_0-1674235896394.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_0-1674235896394.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_0-1674235896394.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_0-1674235896394.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_0-1674235896394.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_0-1674235896394.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_0-1674235896394.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_0-1674235896394.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_0-1674235896394.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F208063i084ED54D9FB16F5E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22iaingalloway_0-1674235896394.png%22%20alt%3D%22iaingalloway_0-1674235896394.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E%E6%AC%A1%E3%81%AB%E3%80%81JST-GH%20%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81BMS%20%E3%81%AE%20DCD-LZ%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%82%A4%E3%82%B9%E3%81%AE%20RX%20TX%20%E3%81%8A%E3%82%88%E3%81%B3%20GND%20%E3%83%94%E3%83%B3%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82FTDI%3CSTRONG%3E%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%81%8B%E3%82%89%E3%81%AE%E9%9B%BB%E6%BA%90%E3%82%92%20DCD-LZ%20%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%AA%E3%81%84%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FSTRONG%3E%E3%80%82%3CBR%20%2F%3E%E3%83%94%E3%83%B3%E9%85%8D%E7%BD%AE%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%3CA%20href%3D%22https%3A%2F%2Fnxp.gitbook.io%2Fhovergames%2Frddrone-fmuk66%2Fconnectors%2Fdebug-interface-dcd-lz%2Fdcd-lz-breakout-board%23pinout%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fnxp.gitbook.io%2Fhovergames%2Frddrone-fmuk66%2Fconnectors%2Fdebug-interface-dcd-lz%2Fdcd-lz-breakout-board%23%E3%83%94%E3%83%B3%E9%85%8D%E7%BD%AE%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1582513%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1582513%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%20%E3%81%95%E3%82%93%E3%80%81%3C%2FA%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E3%81%AB%E5%BD%B9%E7%AB%8B%E3%81%A4%E6%83%85%E5%A0%B1%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1581963%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1581963%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81J2%20%E3%81%AB%200.50%20%E3%82%A4%E3%83%B3%E3%83%81%E3%81%AE%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E3%82%92%E3%81%AF%E3%82%93%E3%81%A0%E4%BB%98%E3%81%91%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%B3%A8%E6%84%8F%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1581962%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1581962%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22iaingalloway_0-1673558852262.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_0-1673558852262.png%22%20style%3D%22width%3A%20388px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_0-1673558852262.png%22%20style%3D%22width%3A%20388px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_0-1673558852262.png%22%20style%3D%22width%3A%20388px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_0-1673558852262.png%22%20style%3D%22width%3A%20388px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_0-1673558852262.png%22%20style%3D%22width%3A%20388px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_0-1673558852262.png%22%20style%3D%22width%3A%20388px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_0-1673558852262.png%22%20style%3D%22width%3A%20388px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_0-1673558852262.png%22%20style%3D%22width%3A%20388px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_0-1673558852262.png%22%20style%3D%22width%3A%20388px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F207150i2EFE104225F00316%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22iaingalloway_0-1673558852262.png%22%20alt%3D%22iaingalloway_0-1673558852262.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EJ2%20%E3%81%AF%E3%80%81%E3%81%82%E3%82%89%E3%82%86%E3%82%8B%20Segger%20JLINK%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E6%A8%99%E6%BA%96%2010%2F9%20%E3%83%94%E3%83%B3%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E7%94%A8%E3%81%AE%E3%82%BD%E3%82%B1%E3%83%83%E3%83%88%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3EDCDLZ%20%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AB%E5%B7%AE%E3%81%97%E8%BE%BC%E3%82%93%E3%81%A7%20FTDI%203v3%20USB2UART%20%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fwww.amazon.com%2FPre-Crimped-Connectors-Pixhawk2-Pixracer-Silicone%2Fdp%2FB07PBHN7TM%2Fref%3Dsr_1_3%3Fcrid%3DGL7B8ZZMTG79%26amp%3Bkeywords%3Djst-gh%26amp%3Bqid%3D1673558988%26amp%3Bsprefix%3Djst-gh%252Caps%252C147%26amp%3Bsr%3D8-3%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.amazon.com%2FPre-Crimped-Connectors-Pixhawk2-Pixracer-Silicone%2Fdp%2FB07PBHN7TM%2Fref%3Dsr_1_3%3Fcrid%3DGL7B8ZZMTG79%26amp%3Bkeywords%3Djst-gh%26amp%3Bqid%3D1673558988%26amp%3Bsprefix%3Djst-gh%20%252Caps%25%202C147%26amp%3Bsr%3D8-3%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%89%8D%E8%BF%B0%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%82%A2%E3%82%A4%E3%83%86%E3%83%A0%E3%81%AF%E4%BB%96%E3%81%AE%E9%96%8B%E7%99%BA%E3%82%AD%E3%83%83%E3%83%88%E3%81%AE%E4%B8%80%E9%83%A8%E3%81%AB%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%81%93%E3%81%93%E3%81%A7%E5%86%8D%E5%88%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1581811%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1581811%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F195015%22%20target%3D%22_blank%22%3E%40Prince1%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%81%AE%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E5%8F%AF%E7%94%A8%E6%80%A7%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E7%A4%BE%E5%86%85%E3%81%A7%E7%A2%BA%E8%AA%8D%E3%81%95%E3%81%9B%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3EDCD-LZ%20%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%E3%83%BC%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E8%A9%B3%E7%B4%B0%E6%83%85%E5%A0%B1%20(%E5%9B%9E%E8%B7%AF%E5%9B%B3%E3%82%92%E5%90%AB%E3%82%80)%20%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%3A%20%3CA%20href%3D%22https%3A%2F%2Fnxp.gitbook.io%2Fhovergames%2Frddrone-fmuk66%2Fconnectors%2Fdebug-interface-dcd-lz%2Fdcd-lz-breakout-board%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fnxp.gitbook.io%2Fhovergames%2Frddrone-fmuk66%2Fconnectors%2Fdebug-interface-dcd-lz%2Fdcd-lz-breakout-board%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%82%8C%E3%82%89%E3%81%AF%E9%80%9A%E5%B8%B8%E3%82%AD%E3%83%83%E3%83%88%E3%81%AE%E4%B8%80%E9%83%A8%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E7%9F%A5%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81KIT-UCANS32K1SIC%20%E3%82%92%E8%B3%BC%E5%85%A5%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E3%81%82%E3%82%8B%E3%81%93%E3%81%AE%20UCAN%20%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E3%82%AD%E3%83%83%E3%83%88%E3%81%AB%E3%81%AF%E3%80%812%20%E5%80%8B%E3%81%AE%20DCD-LZ%20%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%E3%83%BC%E3%80%812%20%E5%80%8B%E3%81%AE%20FTDI-USB%20%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%201%20%E5%80%8B%E3%81%AE%20Segger%20Jlink%20mini%20EDU%20%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%83%BC%20(%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%8A%E3%82%88%E3%81%B3%E3%83%87%E3%83%90%E3%83%83%E3%82%B0)%20%E3%82%82%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3EKIT-UCANS32K1SIC%20%E3%81%B8%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%3A%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Finterfaces%2Fcan-transceivers%2Fcan-signal-improvement%2Fcan-sic-evaluation-board%3AUCANS32K1SIC%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fproducts%2Finterfaces%2Fcan-transceivers%2Fcan-signal-improvement%2Fcan-sic-evaluation-board%3AUCANS32K1SIC%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%95%AC%E5%85%B7%E3%80%81%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%B7%E3%82%B9%E3%83%BB%E3%83%95%E3%82%A1%E3%83%B3%E3%83%BB%E3%83%9F%E3%82%A8%E3%83%AB%E3%83%AD%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1581747%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1581747%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F211084%22%20target%3D%22_blank%22%3E%40Airobot-Dynamics%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%0A%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AENXP%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E3%83%9A%E3%83%BC%E3%82%B8%E3%81%AB%E3%81%AF%3CSPAN%3E%E3%80%81%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%A8%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%8CDocStore%E3%81%A7%E5%85%A5%E6%89%8B%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%82%E3%82%8B%E3%81%A8%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81DocStore%E3%81%B8%E3%81%AE%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E6%96%B9%E6%B3%95%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%82%82%E8%AA%AC%E6%98%8E%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%3E%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81A1007%20%E3%81%AF%20NDA%20%E3%81%AE%E4%B8%8B%E3%81%A7%E3%81%AE%E3%81%BF%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%82%E3%82%8B%E3%81%A8%E8%80%83%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSPAN%3ENXP%20%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%20%E3%83%9A%E3%83%BC%E3%82%B8%E3%81%B8%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%3A%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FOther-NXP-Products%2FOM67201UL-driver-A1007%2Fm-p%2F1447573%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FOther-NXP-Products%2FOM67201UL-driver-A1007%2Fmp%2F1447573%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E8%87%AA%E5%88%86%E3%81%A7%E4%BD%95%E3%81%8B%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E4%B8%80%E8%88%AC%E3%81%AB%E5%85%AC%E9%96%8B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%20NXP%20IoT%20%E3%82%BB%E3%82%AD%E3%83%A5%E3%83%AA%E3%83%86%E3%82%A3%EF%BC%86%E8%AA%8D%E8%A8%BC%E3%83%9D%E3%83%BC%E3%83%88%E3%83%95%E3%82%A9%E3%83%AA%E3%82%AA%E3%82%92%E5%8F%82%E7%85%A7%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%3A%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fiotsecurity%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fiotsecurity%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%81%9F%E3%81%A8%E3%81%88%E3%81%B0%E3%80%81SE050%20%E3%82%84%20SE051%20%E3%81%AF%E5%BA%83%E3%81%8F%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E3%81%99%E3%81%A7%E3%81%AB%E5%A4%9A%E3%81%8F%E3%81%AE%E3%83%A6%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%82%B9%E3%81%8C%E5%AE%9F%E8%A3%85%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3ESE050%20%E3%81%A8%E5%90%8C%E6%A7%98%E3%81%AE%20MCU%20(S32K144%20%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%20S32K146)%20%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9F%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E9%96%8B%E7%99%BA%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%82%3CSPAN%3EUCANS32K146%20%E3%81%AF%E8%88%88%E5%91%B3%E6%B7%B1%E3%81%84%E8%A3%BD%E5%93%81%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3ESE050%E3%81%B8%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%3A%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fsecurity-and-authentication%2Fauthentication%2Fedgelock-se050-plug-trust-secure-element-family-enhanced-iot-security-with-high-flexibility%3ASE050%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fproducts%2Fsecurity-and-authentication%2Fauthentication%2Fedgelock-se050-plug-trust-secure-element-family-enhanced-iot-security-with-high-flexibility%3ASE050%3C%2FA%3E%3CBR%20%2F%3E%3CSPAN%3EUCANS32K146%3C%2FSPAN%3E%E3%81%B8%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%3A%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdevelopment-boards%2Fautomotive-development-platforms%2Fs32k-mcu-platforms%2Fs32k146-uavcan-v1-and-mavcan-development-system%3AUCANS32K146%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdevelopment-boards%2Fautomotive-development-platforms%2Fs32k-mcu-platforms%2Fs32k146-uavcan-v1-and-mavcan-development-system%3AUCANS32K146%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%82%8C%E3%81%A7%E3%81%94%E8%B3%AA%E5%95%8F%E3%81%B8%E3%81%AE%E5%9B%9E%E7%AD%94%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%9F%E3%81%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%B7%E3%82%B9%E3%83%BB%E3%83%95%E3%82%A1%E3%83%B3%E3%83%BB%E3%83%9F%E3%82%A8%E3%83%AB%E3%83%AD%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1580845%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1580845%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EA1007%20%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%BB%E3%82%AA%E3%83%BC%E3%82%BB%E3%83%B3%E3%83%86%E3%82%A3%E3%82%B1%E3%83%BC%E3%82%BF%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E3%81%AE%E7%9A%86%E3%81%95%E3%82%93%E3%80%82%E7%A7%81%E3%81%AF%20BMS772%20%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%9F%E9%96%8B%E7%99%BA%E3%82%92%E5%A7%8B%E3%82%81%E3%81%9F%E3%81%B0%E3%81%8B%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81A1007%20IC%20%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E6%83%85%E5%A0%B1%E3%81%AF%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%20IC%20%E3%81%AF%E3%80%81%E5%BD%93%E7%A4%BE%E3%81%AE%E9%80%9A%E5%B8%B8%E3%81%AE%E3%82%B5%E3%83%97%E3%83%A9%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%A7%E3%81%82%E3%82%8B%20Digi-Key%20%E3%81%AA%E3%81%A9%E3%81%AE%20NXP%20%E3%82%B5%E3%82%A4%E3%83%88%E3%81%A7%E3%82%82%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%E3%81%93%E3%81%AEIC%E3%81%AF%E5%BB%83%E6%AD%A2%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%82%82%E3%81%97SO%E3%81%AA%E3%82%89%E3%80%81%E4%BB%A3%E6%9B%BF%E6%A1%88%E3%81%AF%E4%BD%95%E3%81%8B%E6%8F%90%E6%A1%88%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1580776%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1580776%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%E6%97%A9%E9%80%9F%E3%81%AE%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E6%AE%8B%E5%BF%B5%E3%81%AA%E3%81%8C%E3%82%89%E3%80%81%E3%82%A4%E3%83%B3%E3%83%89%E3%81%A7%20DCD-LZ%20%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%E3%83%BC%E3%82%92%E8%B3%BC%E5%85%A5%E3%81%A7%E3%81%8D%E3%82%8B%E4%BB%A3%E7%90%86%E5%BA%97%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E3%83%9B%E3%83%90%E3%83%BC%E3%82%B2%E3%83%BC%E3%83%A0%E3%82%AD%E3%83%83%E3%83%88%E3%82%82%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E5%BA%83%E3%81%8F%E5%85%A5%E6%89%8B%E5%8F%AF%E8%83%BD%E3%81%AA%E4%BB%A3%E6%9B%BF%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%E3%83%BC%E3%82%92%E6%8F%90%E6%A1%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1579322%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1579322%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F195015%22%20target%3D%22_blank%22%3E%40Prince1%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%3CP%3E%E5%AE%9F%E9%9A%9B%E3%81%AB%E3%81%AF%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AB%E5%BF%9C%E3%81%98%E3%81%A6%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E6%A7%8B%E6%88%90%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%93%E3%82%8C%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E1.%207%20%E3%83%94%E3%83%B3%20JST-GH%20%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81DCD-LZ%20%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%E3%83%BC%E3%82%92%20BMS772%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E2.%20FTDI%20USBUART-3V3%20%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81DCD-LZ%20%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%E3%83%BC%E3%82%92%E3%83%8E%E3%83%BC%E3%83%88PC%E3%81%BE%E3%81%9F%E3%81%AF%20PC%20%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E3.%20PuTTY%20%E3%82%84%20TeraTerm%20(%20%3CSPAN%3E115200%20%E3%83%9C%E3%83%BC%20)%3C%2FSPAN%3E%E3%81%AA%E3%81%A9%E3%81%AE%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%82%A4%E3%82%B9%E3%82%92%E4%BB%8B%E3%81%97%E3%81%A6%20BMS772%20%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%204.%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%20%E3%83%A9%E3%82%A4%E3%83%B3%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%82%A4%E3%82%B9%20(CLI)%20%E3%81%AE%E3%83%98%E3%83%AB%E3%83%97%E3%82%92%E5%8F%96%E5%BE%97%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%80%8Cbms%20help%E3%80%8D%E3%81%A8%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%205.%20%E3%80%8Cbms%20get%20all%E3%80%8D%E3%81%A8%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%A6%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%A8%E3%81%9D%E3%82%8C%E3%82%89%E3%81%AE%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%AB%E9%96%A2%E9%80%A3%E4%BB%98%E3%81%91%E3%82%89%E3%82%8C%E3%81%9F%E5%80%A4%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E6.%20%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%9F%E3%81%84%E5%A4%89%E6%95%B0%EF%BC%88%E3%81%93%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AFn-cells%E3%82%924%EF%BC%89%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%80%8Cbms%20set%20n-cells%204%E3%80%8D%E3%81%A8%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%207.%20%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%8C%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AB%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%80%8Cbms%20save%E3%80%8D%E3%81%A8%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%208.%E6%96%B0%E3%81%97%E3%81%84%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%9F%E3%82%89%E3%80%81%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E6%8A%BC%E3%81%99%E3%81%8B%E3%80%81%E3%80%8Cbms%20reset%E3%80%8D%E3%81%A8%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%A6%E9%9A%9C%E5%AE%B3%E3%82%92%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3ECLI%20%E3%81%AF%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AE%E5%8E%9F%E5%9B%A0%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%8F%E3%82%8C%E3%82%8B%E3%81%AE%E3%81%A7%E9%9D%9E%E5%B8%B8%E3%81%AB%E4%BE%BF%E5%88%A9%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%A7%8B%E3%82%81%E3%82%8B%E3%81%AB%E3%81%82%E3%81%9F%E3%81%A3%E3%81%A6%E5%BD%B9%E7%AB%8B%E3%81%A4%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%92%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E7%B4%B9%E4%BB%8B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20CLI%20%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%83%AA%E3%83%B3%E3%82%AF%3A%20%3CA%20href%3D%22https%3A%2F%2Fnxp.gitbook.io%2Frddrone-bms772%2Fuser-guide%2Fgetting-started-with-the-rddrone-bms772%2Fusing-the-command-line-interface-cli%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fnxp.gitbook.io%2Frddrone-bms772%2Fuser-guide%2Fgetting-started-with-the-rddrone-bms772%2Fusing-the-command-line-interface-cli%3C%2FA%3E%3CBR%20%2F%3ECLI%20%E3%81%AE%E4%BD%BF%E7%94%A8%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%83%AA%E3%83%B3%E3%82%AF%3A%20%3CA%20href%3D%22https%3A%2F%2Fnxp.gitbook.io%2Frddrone-bms772%2Fsoftware-guide-nuttx%2Fcommand-line-interface-cli%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fnxp.gitbook.io%2Frddrone-bms772%2Fsoftware-guide-nuttx%2Fcommand-line-interface-cli%3C%2FA%3E%3CBR%20%2F%3E%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%AE%E3%83%AA%E3%82%B9%E3%83%88%E3%82%92%E5%90%AB%E3%82%80%E3%83%AA%E3%83%B3%E3%82%AF%3A%20%3CA%20href%3D%22https%3A%2F%2Fnxp.gitbook.io%2Frddrone-bms772%2Fsoftware-guide-nuttx%2Funtitled-1%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fnxp.gitbook.io%2Frddrone-bms772%2Fsoftware-guide-nuttx%2Funtitled-1%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20%E3%83%8E%E3%83%BC%E3%83%88%E3%81%AE%E7%AC%AC%207%20%E7%AB%A0%20(rev.5)%20%E3%81%AF%E3%80%817%20%E3%83%94%E3%83%B3%20JST%20GH%20%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%81%A8%E3%81%9D%E3%82%8C%E3%81%AB%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%83%83%E3%83%89%20USB-TTL-3V3%20%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%82%92%E5%82%99%E3%81%88%E3%81%9F%20DCD-LZ%20%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%E3%83%BC%E3%81%AE%E5%86%99%E7%9C%9F%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E4%BE%BF%E5%88%A9%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%E7%AC%AC%208%20%E7%AB%A0%E3%81%AB%E3%81%AF%E3%80%81BMS772%20%E3%81%AE%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%8C%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E6%9C%80%E6%96%B0%E3%81%AE%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%81%AB%E6%9B%B4%E6%96%B0%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E6%9C%80%E6%96%B0%E3%81%AE%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%81%AF%E6%AC%A1%E3%81%AE%E5%A0%B4%E6%89%80%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3A%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2Ftree%2Fmain%2FBinary%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2Ftree%2Fmain%2FBinary%3C%2FA%3E%3CBR%20%2F%3E%E6%89%8B%E9%A0%86%E3%81%AF%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%83%8E%E3%83%BC%E3%83%88%E3%81%AE%E7%AC%AC%207%20%E7%AB%A0%E3%80%81%E3%82%B3%E3%83%BC%E3%83%89%20%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%20gitbook%20%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3A%20%3CA%20href%3D%22https%3A%2F%2Fnxp.gitbook.io%2Frddrone-bms772%2Fuser-guide%2Fgetting-started-with-the-rddrone-bms772%2Fflashing-firmware-to-the-rddrone-bms772%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fnxp.gitbook.io%2Frddrone-bms772%2Fuser-guide%2Fgetting-started-with-the-rddrone-bms772%2Fflashing-firmware-to-the-rddrone-bms772%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%E5%BE%8C%E3%81%AF%E3%80%81%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%8C%E4%B8%8A%E6%9B%B8%E3%81%8D%E3%81%95%E3%82%8C%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E5%86%8D%E5%BA%A6%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%B3%A8%E6%84%8F%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%8C%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%B7%E3%82%B9%E3%83%BB%E3%83%95%E3%82%A1%E3%83%B3%E3%83%BB%E3%83%9F%E3%82%A8%E3%83%AB%E3%83%AD%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1579306%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1579306%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSTRONG%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E6%96%B0%E3%81%97%E3%81%84%20RDDRONE-BMS772%20%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E8%B3%BC%E5%85%A5%E3%81%97%E3%80%814S%20LiPo%20%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%20%E3%83%91%E3%83%83%E3%82%AF%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E8%80%83%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%824S%20%E7%94%A8%E3%81%AE%E3%82%BB%E3%83%AB%E7%AB%AF%E5%AD%90%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%E3%81%A8%E5%8D%8A%E7%94%B0%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%91%E3%83%BC%E3%83%94%E3%83%B3%20(SJ)%20%E3%82%92%E5%8D%8A%E7%94%B0%E4%BB%98%E3%81%91%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%824S%20%E3%83%91%E3%83%83%E3%82%AF%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%E5%87%BA%E5%8A%9B%E9%9B%BB%E5%9C%A7%E3%82%92%E6%B8%AC%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%A8%200V%20%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E7%90%86%E7%94%B1%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%89%E3%81%AA%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%A7%E3%82%82%E6%A7%8B%E6%88%90%E3%81%AE%E5%A4%89%E6%9B%B4(4S%20%E7%94%A8)%E3%82%92%E8%A1%8C%E3%81%86%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%82%82%E3%81%97%E3%81%9D%E3%81%86%E3%81%AA%E3%82%89%E3%80%81%E3%81%A9%E3%81%86%E3%82%84%E3%81%A3%E3%81%A6%EF%BC%9F%E8%BF%94%E4%BF%A1%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1558683%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1558683%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F209164%22%20target%3D%22_blank%22%3E%40Ch_Han%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%0A%3CP%3EBMS%20%E3%81%8C%20DEEP_SLEEP%20%E7%8A%B6%E6%85%8B%E3%81%AB%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%82%92%E6%9C%80%E5%A4%A7%E9%99%90%E3%81%AB%E7%AF%80%E7%B4%84%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81BMS%20%E8%87%AA%E8%BA%AB%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E9%9B%BB%E5%8A%9B%E3%82%92%E5%88%B6%E9%99%90%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%81%A7%E9%9B%BB%E6%BA%90%E3%81%8C%E4%BE%9B%E7%B5%A6%E3%81%95%E3%82%8C%E3%82%8B%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88%E3%82%92%E3%83%87%E3%82%A3%E3%83%BC%E3%83%97%E3%82%B9%E3%83%AA%E3%83%BC%E3%83%97%2F%E3%82%B9%E3%83%AA%E3%83%BC%E3%83%97%E7%8A%B6%E6%85%8B%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%80%81%E9%9B%BB%E5%9C%A7%E3%83%89%E3%83%A1%E3%82%A4%E3%83%B3%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%A6%EF%BC%883.3V%20%E3%81%A8%205V%20%E3%82%92%E3%82%AA%E3%83%95%E3%81%AB%E3%81%99%E3%82%8B%EF%BC%89%E3%80%81%E3%81%93%E3%81%AE%203.3V%20%E3%81%A7%E4%BE%9B%E7%B5%A6%E3%81%95%E3%82%8C%E3%82%8B%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%81%AE%E9%9B%BB%E6%BA%90%E3%82%92%E3%82%AA%E3%83%95%E3%81%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E8%A1%8C%E3%82%8F%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3ESBC%20%E3%81%AE%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%20(%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%81%AB%E9%9B%BB%E5%8A%9B%E3%82%92%E4%BE%9B%E7%B5%A6%E3%81%99%E3%82%8B%203.3V%20%E3%82%92%E5%86%8D%E5%BA%A6%E3%82%AA%E3%83%B3%E3%81%AB%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF)%E3%80%81SW%20%E3%81%AF%20SBC%20%E3%81%AE%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%20%E3%83%94%E3%83%B3%E3%81%8C%20SBC%20%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%92%E7%99%BA%E8%A1%8C%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AE%E3%81%BF%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E3%81%AF%E3%80%81%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E6%8A%BC%E3%81%99%E3%81%8B%E3%80%81J22%20%E3%82%92%E7%9F%AD%E7%B5%A1%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81SBC%20%E3%81%AF%E3%82%B9%E3%83%AA%E3%83%BC%E3%83%97%E7%8A%B6%E6%85%8B%E3%81%AB%E3%81%82%E3%82%8A%E3%80%81%E3%81%BE%E3%81%A0%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%81%8B%E3%82%89%E9%9B%BB%E6%BA%90%E3%81%8C%E4%BE%9B%E7%B5%A6%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81CAN%20%E7%B5%8C%E7%94%B1%E3%81%AE%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%82%92%20SW%20%E3%81%A7%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%A8%E8%80%83%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E7%8F%BE%E5%9C%A8%E3%81%AE%20SW%20%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%AF%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E3%81%9D%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AE%20HW%20%E8%A6%81%E4%BB%B6%E3%81%AF%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%81%AE%E6%A9%9F%E8%83%BD%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%9F%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81SBC%20%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%A8%E3%80%81%E3%81%93%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E5%85%AC%E9%96%8B%20BMS%20SW%20%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%81%AE%20sbc.c%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A8%20sbc.h%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3ESBC%20%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%AF%E3%80%81%E3%81%93%E3%81%A1%E3%82%89%E3%81%A7%E3%81%94%E8%A6%A7%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%3A%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fpower-management%2Fpmics-and-sbcs%2Fmini-sbcs%2Fmini-high-speed-can-system-basis-chip%3AUJA1169ATK%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fproducts%2Fpower-management%2Fpmics-and-sbcs%2Fmini-sbcs%2Fmini-high-speed-can-system-basis-chip%3AUJA1169ATK%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%95%AC%E5%85%B7%3C%2FP%3E%0A%3CP%3Ecisvmierlo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1558599%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1558599%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%94%E5%9B%9E%E7%AD%94%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%81%A7%E3%81%AF%E3%80%81BMS%20%E3%81%8C%20DEEPSLEEP%20%E7%8A%B6%E6%85%8B%E3%81%AE%E3%81%A8%E3%81%8D%E3%81%AB%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%81%8C%E4%BF%9D%E7%AE%A1%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81BMS%20%E3%81%AF%E5%87%BA%E5%8A%9B%E3%81%8C%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E6%A4%9C%E5%87%BA%E3%81%97%E3%81%A6%20NORMAL%20%E3%81%AB%E6%88%BB%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E6%8A%BC%E3%81%99%E3%81%93%E3%81%A8%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%81%AE%E3%81%BF%20DEEPSLEEP%20%E3%81%8B%E3%82%89%E6%8A%9C%E3%81%91%E5%87%BA%E3%81%99%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1558555%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1558555%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F196312%22%20target%3D%22_blank%22%3E%40OGUZ1%20%E3%81%95%E3%82%93%3C%2FA%3E%3C%2FP%3E%0A%3CP%3ERDDRONE-BMS772%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8C%E3%80%81S32K1xx%20%E7%94%A8%E3%81%AE%20NXP%20%E3%83%A2%E3%83%87%E3%83%AB%E3%83%99%E3%83%BC%E3%82%B9%20%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%20%E3%83%84%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%20(MBDT)%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%204.3.0%20%E3%81%A7%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%81%AE%E3%81%A7%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E8%A3%BD%E5%93%81%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%AE%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%AF%E3%81%93%E3%81%A1%E3%82%89%E3%81%A7%E3%81%99%3A%3C%2FSPAN%3E%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Model-Based-Design-Tools%2FNXP-Model-Based-Design-Toolbox-for-S32K1xx-MCUs-version-4-3-0%2Fta-p%2F1549163%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Model-Based-Design-Tools%2FNXP-Model-Based-Design-Toolbox-for-S32K1xx-MCUs-version-4-3-0%2Fta-p%2F1549163%3C%2FA%3E%3C%2FP%3E%0A%3CP%3ENXP%20MBDT%20%E3%81%AB%E3%81%AF%E3%80%81%E7%9B%B4%E6%8E%A5%E3%83%A9%E3%83%94%E3%83%83%E3%83%89%E3%83%97%E3%83%AD%E3%83%88%E3%82%BF%E3%82%A4%E3%83%94%E3%83%B3%E3%82%B0%E7%94%A8%E3%81%AE%20NXP%20MCU%20%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E7%B5%B1%E5%90%88%20Simulink%20%3CSUP%3E%C2%AE%3C%2FSUP%3E%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BF%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%A8%E3%80%81%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%8A%E3%82%88%E3%81%B3%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%82%A4%E3%83%B3%E3%82%B6%E3%83%AB%E3%83%BC%E3%83%97%20(SIL%20%E3%81%8A%E3%82%88%E3%81%B3%20PIL)%20%E9%96%8B%E7%99%BA%E3%81%AE%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fautomotive-software-and-tools%2Fmodel-based-design-toolbox-mbdt%3AMBDT%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdesign%2Fautomotive-software-and-tools%2Fmodel-based-design-toolbox-mbdt%3AMBDT%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%95%AC%E5%85%B7%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1558534%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1558534%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F209164%22%20target%3D%22_blank%22%3E%40Ch_Han%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%83%8E%E3%83%BC%E3%83%88%E3%81%AF%3CA%20title%3D%22https%3A%2F%2Fgithub.com%2Fnxphovergames%2Frddrone-bms772%2F%22%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2F%22%20target%3D%22_blank%22%20rel%3D%22noopener%20noreferrer%20nofollow%22%3Ehttps%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2F%3C%2FA%3E%3CSPAN%3E%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82BMS%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E3%82%B9%E3%83%86%E3%83%BC%E3%83%88%E3%83%9E%E3%82%B7%E3%83%B3%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%81%93%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%AF%E3%80%81%E5%87%BA%E5%8A%9B%E9%9B%BB%E5%8A%9B%E3%81%AF%E3%82%B9%E3%83%AA%E3%83%BC%E3%83%97%E7%8A%B6%E6%85%8B%E3%81%A7%E3%82%82%E5%BC%95%E3%81%8D%E7%B6%9A%E3%81%8D%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%82%B9%E3%83%AA%E3%83%BC%E3%83%97%E7%8A%B6%E6%85%8B%E3%81%AF%E4%BF%9D%E5%AD%98%E7%94%A8%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E4%BF%9D%E7%AE%A1%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81BMS%20%E3%81%AF%20DEEPSLEEP%20%E7%8A%B6%E6%85%8B%E3%81%AB%E7%A7%BB%E8%A1%8C%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E7%8A%B6%E6%85%8B%E3%81%A7%E3%81%AF%E3%80%81%E5%87%BA%E5%8A%9B%E9%9B%BB%E5%8A%9B%E3%81%8C%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%AA%E3%82%8A%20(%E9%9B%BB%E6%BA%90%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%81%8C%E9%96%8B%E3%81%84%E3%81%A6%E3%81%84%E3%82%8B)%E3%80%81%E9%9B%BB%E6%B5%81%E3%81%8C%E6%9C%80%E5%B0%8F%E9%99%90%E3%81%AB%E6%8A%91%E3%81%88%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20%E3%83%8E%E3%83%BC%E3%83%88%E3%81%AE%E7%AC%AC%208%20%E7%AB%A0%E3%81%A7%E3%81%AF%E3%80%81BMS%20%E3%82%92%E5%88%B6%E5%BE%A1%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%20self-discharge-enable%20%E3%82%92%200%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%82%BB%E3%83%AB%E3%82%92%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B8%E9%9B%BB%E5%9C%A7%E3%81%BE%E3%81%A7%E6%94%BE%E9%9B%BB%E3%81%9B%E3%81%9A%E3%81%AB%20DEEPSLEEP%20%E7%8A%B6%E6%85%8B%E3%81%AB%E7%A7%BB%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E9%95%B7%E6%99%82%E9%96%93%E9%AB%98%E9%9B%BB%E5%9C%A7%E3%81%8C%E3%81%8B%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%BE%E3%81%BE%E3%81%A0%E3%81%A8%E3%80%81%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%82%BB%E3%83%AB%E3%81%AB%E6%82%AA%E5%BD%B1%E9%9F%BF%E3%82%92%E4%B8%8E%E3%81%88%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E7%95%99%E6%84%8F%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%87%AA%E5%B7%B1%E6%94%BE%E9%9B%BB%E7%8A%B6%E6%85%8B%E3%81%A7%E3%81%AF%E3%80%81BMS%20%E3%81%AF%E3%83%90%E3%83%A9%E3%83%B3%E3%82%B9%E9%9B%BB%E6%B5%81%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%BB%E3%83%AB%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%9F%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B8%E9%9B%BB%E5%9C%A7%20(%E3%83%9E%E3%83%BC%E3%82%B8%E3%83%B3%E4%BB%98%E3%81%8D)%20%E6%9C%AA%E6%BA%80%E3%81%BE%E3%81%A7%E6%94%BE%E9%9B%BB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%AF%E3%80%81%E3%82%B9%E3%83%AA%E3%83%BC%E3%83%97%E7%8A%B6%E6%85%8B%E3%81%A7%E3%81%AF%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%81%AF%E5%B8%B8%E3%81%AB%E9%96%89%E3%81%98%E3%82%89%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E5%87%BA%E5%8A%9B%E9%9B%BB%E5%8A%9B%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81%E9%9B%BB%E6%B5%81%E3%82%92%E6%B8%AC%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E8%B2%A0%E8%8D%B7%E3%82%92%E6%A4%9C%E5%87%BA%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E7%A7%81%E3%81%AF%E9%80%9A%E5%B8%B8%E3%80%81%E5%AE%9F%E9%A8%93%E5%AE%A4%E3%81%AE%E9%9B%BB%E6%BA%90%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%82%92%E5%85%85%E9%9B%BB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EPS%3A%20%3CA%20title%3D%22https%3A%2F%2Fgithub.com%2Fnxphovergames%2Frddrone-bms772%2F%22%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2F%22%20target%3D%22_blank%22%20rel%3D%22noopener%20noreferrer%20nofollow%22%3Ehttps%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2F%3C%2FA%3E%E3%81%AE%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%20%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%AE%E4%BE%8B%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%80%81%E7%8B%AC%E8%87%AA%E3%81%AE%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E9%96%8B%E7%99%BA%E3%81%97%E3%81%9F%E3%82%8A%E3%80%81%E3%83%8B%E3%83%BC%E3%82%BA%E3%81%AB%E5%90%88%E3%82%8F%E3%81%9B%E3%81%A6%20SW%20%E3%82%92%E8%AA%BF%E6%95%B4%E3%81%97%E3%81%9F%E3%82%8A%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%82%8C%E3%81%A7%E3%81%94%E8%B3%AA%E5%95%8F%E3%81%B8%E3%81%AE%E5%9B%9E%E7%AD%94%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%9F%E3%81%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3Ecisvmierlo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1558484%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1558484%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F15914%22%20target%3D%22_blank%22%3E%40iaingalloway%3C%2FA%3E%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%3CP%3EBMS772%20%E3%82%92%206s%20LiPo%20%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E4%BA%88%E5%AE%9A%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E5%85%85%E9%9B%BB%E3%81%A8%E6%94%BE%E9%9B%BB%E3%81%AB%E9%96%A2%E3%81%97%E3%81%A6%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E1-%20%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%82%92%E6%94%BE%E9%9B%BB%E3%81%9B%E3%81%9A%E3%81%AB%E4%BF%9D%E7%AE%A1%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%82%B2%E3%83%BC%E3%83%88%E3%81%8C%E9%96%8B%E3%81%84%E3%81%A6%E3%81%84%E3%82%8B%20DEEPSLEEP%20%E7%8A%B6%E6%85%8B%E3%81%AB%E5%85%A5%E3%82%8B%E5%89%8D%E3%81%AB%E3%80%81BMS%20%E3%81%AF%20SELF-DISCHARGE%20%E7%8A%B6%E6%85%8B%E3%82%92%E7%B5%8C%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81BMS%20%E3%81%8C%20SLEEP%20%E7%8A%B6%E6%85%8B%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%82%B2%E3%83%BC%E3%83%88%E3%81%8C%E9%96%89%E3%81%98%E3%82%89%E3%82%8C%E3%81%A6%E6%94%BE%E9%9B%BB%E3%82%82%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E2-%20%E8%87%AA%E5%B7%B1%E6%94%BE%E9%9B%BB%E3%81%AE%E7%89%A9%E7%90%86%E7%9A%84%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%81%A8%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E3-%20%E5%87%BA%E5%8A%9B%E3%81%8C%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%83%83%E3%83%89%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E6%A4%9C%E5%87%BA%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81CAN%20%E3%82%92%E4%BB%8B%E3%81%97%E3%81%A6%E3%82%A4%E3%83%B3%E3%83%94%E3%83%BC%E3%83%80%E3%83%B3%E3%82%B9%E3%82%92%E6%B8%AC%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E8%80%83%E3%81%88%E3%82%89%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%E3%81%9F%E3%81%A8%E3%81%88%E3%81%B0%E3%80%81SLEEP%20%E7%8A%B6%E6%85%8B%E3%81%A7%E3%82%B2%E3%83%BC%E3%83%88%E3%82%92%E9%96%8B%E3%81%8F%E3%81%8B%E9%96%89%E3%81%98%E3%82%8B%E3%81%8B%E3%82%92%E7%9F%A5%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AA%E3%81%A9%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E4-%20%E5%88%B6%E9%99%90%E3%81%95%E3%82%8C%E3%81%9F%E9%9B%BB%E6%B5%81%E3%81%A7%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%82%92%E5%85%85%E9%9B%BB%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E6%8E%A8%E5%A5%A8%E5%85%85%E9%9B%BB%E5%99%A8%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%82%E3%82%8B%E3%81%84%E3%81%AF%E3%80%81%E5%B0%91%E3%81%AA%E3%81%8F%E3%81%A8%E3%82%82%E6%99%AE%E6%AE%B5%E3%81%AF%E3%81%A9%E3%82%8C%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1434088%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1434088%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F198622%22%20target%3D%22_blank%22%3E%40vikrantj%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%3CP%3E%E5%AD%A6%E6%A0%A1%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A7%E3%81%93%E3%82%8C%E3%82%92%E8%A1%8C%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%80%81J-Link%20EDU%20(mini)%20%E3%82%92%E8%B3%BC%E5%85%A5%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E6%95%99%E8%82%B2%E7%9B%AE%E7%9A%84%E3%81%AE%E9%80%9A%E5%B8%B8%E3%81%AE%20J-Link%20%E3%81%AE%E5%AE%89%E4%BE%A1%E3%81%AA%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3EJ-Link%20EDU%20(mini)%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20RDDRONE-BMS772%20%E3%82%92%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%AC%E3%82%A4%E3%83%89%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3A%20%3CA%20href%3D%22https%3A%2F%2Fnxp.gitbook.io%2Fnxpmobilerobotics%2Fflashing-guide%2Fflashing-hovergames-boards%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fnxp.gitbook.io%2Fnxpmobilerobotics%2Fflashing-guide%2Fflashing-hovergames-boards%E3%80%82%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A1%E3%81%BE%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%95%AC%E5%85%B7%E3%80%81%3C%2FP%3E%3CP%3E%E3%82%B7%E3%82%B9%E3%83%BB%E3%83%95%E3%82%A1%E3%83%B3%E3%83%BB%E3%83%9F%E3%82%A8%E3%83%AB%E3%83%AD%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1433972%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1433972%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F198622%22%20target%3D%22_blank%22%3E%40vikrantj%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E3%81%BE%E3%81%A0%E4%BD%BF%E3%81%86%E6%A9%9F%E4%BC%9A%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E5%9B%9E%E8%B7%AF%E5%9B%B3%E3%82%92%E8%A6%8B%E3%82%8B%E3%81%A8%E3%80%81%E5%B8%B8%E3%81%AB%20JTAG%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%9B%E3%81%9A%E3%81%AB%20Simulink%20%E3%81%8B%E3%82%89%E3%81%93%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E7%9B%B4%E6%8E%A5%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%99%E3%82%8B%E6%9C%80%E3%82%82%E7%B0%A1%E5%8D%98%E3%81%AA%E6%96%B9%E6%B3%95%E3%81%AF%E3%80%81UART%20%E7%B5%8C%E7%94%B1%E3%81%A7%20RAppID%20%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E3%82%82%E3%81%A1%E3%82%8D%E3%82%93%E3%80%81JTAG%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%82%92%E4%B8%80%E5%BA%A6%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%82%92%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%80%E3%81%A8%E3%80%81Simulink%20%E3%81%8B%E3%82%89%E7%9B%B4%E6%8E%A5%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E9%81%A9%E5%88%87%E3%81%AA%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%81%AF%E3%80%81%E3%83%84%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E3%81%AE%20tools%5CBootLoader%5CRBF_Files%20%E3%81%AE%E4%B8%8B%E3%81%AB%E3%80%81DCD-LZ%20%E4%B8%8A%E3%81%AE%E3%83%94%E3%83%B3%20PTC6%20%E3%81%A8%20PTC7%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%20S32K144_S32DS_UART1_CAN0.rbf%20%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%93%E3%81%A7%E3%81%AF%E3%80%81%E5%A4%96%E9%83%A8%E3%81%AE%20USB2Serial%20%E3%82%B3%E3%83%B3%E3%83%90%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81CAN0%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E5%B1%95%E9%96%8B%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81RAppID%20%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%20%E3%82%A2%E3%83%97%E3%83%AA%E3%81%A8%E4%BA%92%E6%8F%9B%E6%80%A7%E3%81%AE%E3%81%82%E3%82%8B%20CAN%20%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3ESerial%20%E3%81%8C%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AB%E3%81%A8%E3%81%A3%E3%81%A6%E8%89%AF%E3%81%84%E9%81%B8%E6%8A%9E%E8%82%A2%E3%81%A7%E3%81%82%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%9E%E3%83%AA%E3%82%A6%E3%82%B9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1433750%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1433750%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%20RDDRONE-BMS772%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%203s%20%E3%83%AA%E3%83%81%E3%82%A6%E3%83%A0%E3%82%A4%E3%82%AA%E3%83%B3%20%E3%82%BB%E3%83%AB%20%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%A9%E3%83%BC%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82CAN%20%E3%83%90%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%AE%20S32K%20%E3%81%AB%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%82%92%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E8%80%83%E3%81%88%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%82%8C%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%8C%E3%81%82%E3%82%8B%E3%81%AE%E3%81%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E3%80%81%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%82%92%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%99%E3%82%8B%E5%94%AF%E4%B8%80%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%E4%BB%96%E3%81%AB%E4%BD%95%E3%81%8B%E4%BB%A3%E6%9B%BF%E6%A1%88%E3%81%8C%E3%81%82%E3%82%8C%E3%81%B0%E3%81%94%E6%8F%90%E6%A1%88%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8B%E3%81%A8%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E5%AD%A6%E6%A0%A1%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AA%E3%81%AE%E3%81%A7%E3%80%81%E3%82%B3%E3%82%B9%E3%83%88%EF%BC%88%E3%81%A8%E8%A4%87%E9%9B%91%E3%81%95%EF%BC%89%E3%82%92%E4%BD%8E%E3%81%8F%E6%8A%91%E3%81%88%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F196312%22%20target%3D%22_blank%22%3E%40OGUZ1%3C%2FA%3E%20%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F15914%22%20target%3D%22_blank%22%3E%40iaingalloway%3C%2FA%3E%20%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F72088%22%20target%3D%22_blank%22%3E%40mariuslucianand%3C%2FA%3E%E3%81%93%E3%82%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AE%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E8%80%83%E3%81%88%E3%82%92%E3%81%9C%E3%81%B2%E8%81%9E%E3%81%8B%E3%81%9B%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1420015%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1420015%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%3C%2FA%3E%3C%2FP%3E%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%AF%E3%81%84%E3%80%81SPI0%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E5%8A%B9%E6%9E%9C%E3%81%AF%E8%A6%8B%E3%82%89%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E7%A7%81%E3%81%AF%E5%B8%B8%E3%81%AB%E3%83%94%E3%83%B3%20V2%20%E3%81%8B%E3%82%89%202.7%20%E3%83%9C%E3%83%AB%E3%83%88%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E5%80%A4%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AF%E5%B8%B8%E3%81%AB%20V1%20%E3%83%94%E3%83%B3%E3%81%8B%E3%82%89%203.3%20%E3%83%9C%E3%83%AB%E3%83%88%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E6%8A%BC%E3%81%97%E3%81%A6%E3%82%82%E5%90%8C%E3%81%98%E5%80%A4%E3%81%8C%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%82%8C%E3%81%8C%E4%BD%95%E3%82%92%E6%84%8F%E5%91%B3%E3%81%99%E3%82%8B%E3%81%AE%E3%81%8B%E5%88%86%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E8%A9%A6%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82Vbat%20%E3%83%94%E3%83%B3%E3%81%A8%20Wake%20%E3%83%94%E3%83%B3%E3%81%AF%20SBC%20%E3%81%A7%E3%81%AF%E5%90%8C%E3%81%98%E5%80%A4%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%82%92%E6%8A%BC%E3%81%99%E3%81%A8%E3%80%81Wake%20%E3%83%94%E3%83%B3%E3%81%8C%200%20%E3%81%AB%E4%B8%8B%E3%81%8C%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%AE%20SBCWake%20%E3%83%94%E3%83%B3%E3%81%AB%E3%81%AF%E5%B8%B8%E3%81%AB%203.3%20%E3%83%9C%E3%83%AB%E3%83%88%E3%81%8C%E4%BE%9B%E7%B5%A6%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F72088%22%20target%3D%22_blank%22%3E%3CFONT%3E%40mariuslucian%20%E3%81%A8%3C%2FFONT%3E%3C%2FA%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F176411%22%20target%3D%22_blank%22%3E%3CFONT%3E%40constantinrazva%3C%2FFONT%3E%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1419888%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1419888%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F196312%22%20target%3D%22_blank%22%3E%40OGUZ1%20%E3%81%95%E3%82%93%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81Matlab%20%2F%20Simulink%20%E3%81%A7%20MBDT%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E7%B5%8C%E9%A8%93%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%83%A2%E3%83%87%E3%83%AB%E3%83%99%E3%83%BC%E3%82%B9%E8%A8%AD%E8%A8%88%E3%83%84%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E3%81%A8%20SBC%205V%20%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%83%98%E3%83%AB%E3%83%97%E3%80%82%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F72088%22%20target%3D%22_blank%22%3E%40mariuslucianand%3C%2FA%3E%E3%81%93%E3%82%8C%E3%81%AB%E9%96%A2%E3%81%97%E3%81%A6%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F196312%22%20target%3D%22_blank%22%3E%40OGUZ1%E3%82%92%3C%2FA%3E%E3%81%95%E3%82%89%E3%81%AB%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E%3CBR%20%2F%3EUJA1169%20%E3%81%AE%E6%A7%8B%E6%88%90%E3%81%AF%20S32K144%20evb%20%E3%83%9C%E3%83%BC%E3%83%89%E5%B0%82%E7%94%A8%E3%81%A7%E3%81%82%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81RDDRONE-BMS772%20%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A8%E3%81%AF%E7%95%B0%E3%81%AA%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%9F%E3%81%A8%E3%81%88%E3%81%B0%E3%80%81S32k144%20evb%20%E3%81%A7%E3%81%AF%E3%80%81SBC%20%E3%81%A8%E3%81%AE%E9%80%9A%E4%BF%A1%E3%81%AB%20LPSPI1%20%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3ERDDRONE-BMS772%20%E3%81%A7%E3%81%AF%20LPSPI0%20%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3ESBC%20%E3%81%A8%E3%81%AE%E9%80%9A%E4%BF%A1%E3%81%AB%E6%AD%A3%E3%81%97%E3%81%84%20SPI%20%E3%83%90%E3%82%B9%200%20%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F176411%22%20target%3D%22_blank%22%3E%40constantinrazva%3C%2FA%3E%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%E3%80%81SBC%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AF%E5%A4%96%E9%83%A8%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%93%E3%81%AE%20SBC%20%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E%3CBR%20%2F%3EC%20%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20SBC%20%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AB%E8%88%88%E5%91%B3%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E4%BE%8B%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3A%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2Fblob%2Fmain%2Fsrc%2Fsbc.c%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2Fblob%2Fmain%2Fsrc%2Fsbc.c%3C%2FA%3E%3CBR%20%2F%3E%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81SBC%20%E3%81%AE%E9%80%9A%E5%B8%B8%E5%8B%95%E4%BD%9C%E3%81%A7%205V%20%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81NuttX%20RTOS%20%E3%81%A7%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E7%A4%BA%E3%81%99%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%20%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2Fblob%2Fmain%2Fsrc%2Fdisplay.c%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2Fblob%2Fmain%2Fsrc%2Fdisplay.c%3C%2FA%3E%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%E3%81%93%E3%81%AE%20NuttX%20RTOS%20%E3%81%AE%E6%96%87%E5%AD%97%E3%81%A8%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E8%87%AA%E4%BD%93%E3%81%AF%E3%80%815V%20%E3%81%A8%203.3V%20%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%20SSD1306%20I2C%20%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E7%A8%AE%E3%81%AE%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%82%92%E6%93%8D%E4%BD%9C%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E7%A4%BA%E3%81%99%20C%20%E3%81%AE%E4%BE%8B%E3%81%AF%E3%81%9F%E3%81%8F%E3%81%95%E3%82%93%E3%81%82%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E4%BE%8B%3A%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fadafruit%2FAdafruit_SSD1306%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fadafruit%2FAdafruit_SSD1306%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3EMATLAB%20%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E6%83%85%E5%A0%B1%E3%82%82%E5%BD%B9%E7%AB%8B%E3%81%A4%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%3A%20%3CA%20href%3D%22https%3A%2F%2Fnl.mathworks.com%2Fmatlabcentral%2Ffileexchange%2F50766-ssd1306-hex-bitmap-creator%3Fs_tid%3Dsrchtitle%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fnl.mathworks.com%2Fmatlabcentral%2Ffileexchange%2F50766-ssd1306-hex-bitmap-creator%3Fs_tid%3Dsrchtitle%3C%2FA%3E%E3%81%BE%E3%81%9F%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fnl.mathworks.com%2Fmatlabcentral%2Fanswers%2F512483-how-to-control-ssd1306-128x32-oled-display-in-matlab%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fnl.mathworks.com%2Fmatlabcentral%2Fanswers%2F512483-how-to-control-ssd1306-128x32-oled-display-in-matlab%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E8%89%AF%E3%81%84%E9%80%B1%E6%9C%AB%E3%82%92%E3%81%8A%E9%81%8E%E3%81%94%E3%81%97%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%B7%E3%82%B9%E3%83%BB%E3%83%95%E3%82%A1%E3%83%B3%E3%83%BB%E3%83%9F%E3%82%A8%E3%83%AB%E3%83%AD%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1419827%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1419827%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F15914%22%20target%3D%22_blank%22%3E%40iaingalloway%3C%2FA%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%3C%2FA%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EMatlab%2FSimulink%20%E7%B5%8C%E7%94%B1%E3%81%A7%E7%94%BB%E9%9D%A2%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%E4%BD%95%E3%81%8B%E4%BE%8B%E3%82%92%E6%8C%99%E3%81%92%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3FMatlab%2FSimulink%20%E3%81%A7%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%81%AE%E5%80%A4%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82CAN%20%E9%80%9A%E4%BF%A1%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%81%84%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%81%BE%E3%81%A0%20SBC%20%E3%81%8B%E3%82%89%205V%20%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82SBC%E3%81%8B%E3%82%895V%E5%87%BA%E5%8A%9B%E3%81%8C%E3%81%BE%E3%81%A0%E5%BE%97%E3%82%89%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E8%88%88%E5%91%B3%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1411597%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1411597%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F196312%22%20target%3D%22_blank%22%3E%40OGUZ1%20%E3%81%95%E3%82%93%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CA%20title%3D%22https%3A%2F%2Fgithub.com%2Fnxphovergames%2Frddrone-bms772%2F%22%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2F%22%20target%3D%22_blank%22%20rel%3D%22noopener%20noreferrer%20nofollow%22%3Ehttps%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2F%3C%2FA%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3ENuttX%20RDDRONE-BMS772%20BMS%20%E3%81%AE%E4%BE%8B%E3%80%82%3CSPAN%3E%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%80%81%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%80%81%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%80%81%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%81%AF%E3%81%99%E3%81%B9%E3%81%A6%E3%81%93%E3%81%AE%E3%82%A6%E3%82%A7%E3%83%96%E3%82%B5%E3%82%A4%E3%83%88%E3%81%8B%E3%82%89%E5%85%A5%E6%89%8B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82POSIX%3C%2FSPAN%3E%3CSPAN%3E%E6%BA%96%E6%8B%A0%E3%81%AE%3C%2FSPAN%3ERTOS%20NuttX%3CSPAN%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3CSPAN%3E%E3%80%82%3C%2FSPAN%3E%3CSPAN%3E%E3%81%93%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%81%AB%E3%81%AF%E3%80%81SSD1306%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%82%845V%E7%94%A8%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%9FSBC%E3%81%AA%E3%81%A9%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EMatlab%2FSimulink%E3%80%81FREEMASTER%20%E3%81%AA%E3%81%A9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E5%86%8D%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E4%B8%8A%E3%81%A7%E7%95%B0%E3%81%AA%E3%82%8B%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%8C%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%80%81%E6%AD%A3%E3%81%97%E3%81%84%E5%8B%95%E4%BD%9C%E3%82%84%E6%A9%9F%E8%83%BD%E3%81%8C%E5%BE%97%E3%82%89%E3%82%8C%E3%81%AA%E3%81%84%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CSPAN%3E%E3%81%93%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%2F%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%81%AF%E3%80%81%E5%B8%8C%E6%9C%9B%E3%81%99%E3%82%8B%EF%BC%88%E3%81%BE%E3%81%9F%E3%81%AF%E4%BD%9C%E6%88%90%E3%81%97%E3%81%9F%EF%BC%89%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%A7%E8%87%AA%E7%94%B1%E3%81%AB%E5%86%8D%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%99%E3%82%8B%E3%82%82%E3%81%AE%E3%81%8C%E7%9B%AE%E7%9A%84%E3%81%AE%E3%82%82%E3%81%AE%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%9F%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E4%BD%9C%E6%88%90%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CA%20title%3D%22https%3A%2F%2Fgithub.com%2Fnxphovergames%2Frddrone-bms772%2F%22%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2F%22%20target%3D%22_blank%22%20rel%3D%22noopener%20noreferrer%20nofollow%22%3Ehttps%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2F%3C%2FA%3E%20%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81SBC%20(UJA1169)%E3%80%81BCC%20(MC33772B)%E3%80%81NTAG5%20%E3%83%96%E3%83%BC%E3%82%B9%E3%83%88%20NFC%20%E3%83%81%E3%83%83%E3%83%97%E3%81%AA%E3%81%A9%E3%81%AE%20NXP%20%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88%E3%81%AE%E4%BD%BF%E7%94%A8%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AB%E5%BD%B9%E7%AB%8B%E3%81%A1%E3%81%BE%E3%81%99%E3%80%82NuttX%20BMS%20%E3%81%AE%E4%BE%8B%E3%82%92%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%97%E3%81%9F%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%81%9D%E3%81%AE%20Web%20%E3%82%B5%E3%82%A4%E3%83%88%2F%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%81%AB%E3%81%99%E3%81%A7%E3%81%AB%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81J-Link%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%80%E3%83%BC%20%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20(Windows%20%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%20Linux%20%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%20JLinkExe)%20%E3%81%A8%20J-Link%20%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9E%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E7%B0%A1%E5%8D%98%E3%81%AB%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1410958%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1410958%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F15914%22%20target%3D%22_blank%22%3E%40iaingalloway%3C%2FA%3E%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%3C%2FA%3E%3C%2FP%3E%3CP%3ERDDRONE%20-%20BMS772%20%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%20Matlab%2FSimulink%20%E3%81%A7%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82FreeMaster%E3%81%A7%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E5%80%A4%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E2%80%A6%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E1)%20%E3%82%AB%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%A7%20SSD1306%20%E7%94%BB%E9%9D%A2%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%9F%E3%81%84%E3%80%82D34%20%E3%81%A8%20D35%20%E3%81%AE%E3%83%80%E3%82%A4%E3%82%AA%E3%83%BC%E3%83%89%E3%82%92%E4%BA%A4%E6%8F%9B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E7%94%BB%E9%9D%A2%E3%81%AB3.3%E3%83%9C%E3%83%AB%E3%83%88%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E5%8A%A9%E3%81%91%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E2)%20%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%8B%E3%82%89%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AE%E3%83%91%E3%83%AF%E3%83%BC%20MOSFET%20%E3%81%AE%E3%82%B2%E3%83%BC%E3%83%88%20%E3%83%AC%E3%83%83%E3%82%B0%E3%81%AB%201%20%E3%82%92%E4%B8%8E%E3%81%88%E3%80%81%E5%87%BA%E5%8A%9B%E9%9B%BB%E5%9C%A7%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%8B%E3%82%89%E3%83%AD%E3%82%B8%E3%83%83%E3%82%AF%200%20%E3%82%92%E6%8C%87%E5%AE%9A%E3%81%97%E3%81%A6%E3%82%82%E3%80%81%E3%81%AA%E3%81%9C%E5%87%BA%E5%8A%9B%E9%9B%BB%E5%9C%A7%E3%81%8C%E5%BE%97%E3%82%89%E3%82%8C%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F(%E8%B2%A0%E8%8D%B7%E3%82%92%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%83%83%E3%83%89%E7%8A%B6%E6%85%8B%E3%81%A7%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82)%3C%2FP%3E%3CP%3E3)SBC%E3%82%92%E9%80%9A%E5%B8%B8%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E6%93%8D%E4%BD%9C%E3%81%97%E3%81%A6%E3%82%82%E3%80%815V%E5%87%BA%E5%8A%9B%E3%81%8C%E5%BE%97%E3%82%89%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%823%E5%AF%BE3%E3%81%AE%E3%81%BF%E3%81%A7%E3%81%99%E3%80%82sbc_uja1169_s32k_config%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%20V2%2FVEXT%20%E6%A7%8B%E6%88%90%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E3%81%AB%E3%81%97%E3%81%A6%E3%82%82%E3%80%81V2%20%E3%81%8B%E3%82%89%E3%81%AE%E5%87%BA%E5%8A%9B%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%9D%E3%81%AE%E7%90%86%E7%94%B1%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%E5%8A%A9%E3%81%91%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1395481%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1395481%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F195015%22%20target%3D%22_blank%22%3E%40Prince1%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%81%BE%E3%81%9A%E3%81%AF%E6%96%B0%E5%B9%B4%E3%81%AE%E3%81%94%E5%A4%9A%E5%B9%B8%E3%82%92%E3%81%8A%E7%A5%88%E3%82%8A%E7%94%B3%E3%81%97%E4%B8%8A%E3%81%92%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E8%BF%94%E4%BA%8B%E3%81%8C%E9%81%85%E3%81%8F%E3%81%AA%E3%82%8A%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E5%B0%91%E3%81%97%E4%BC%91%E3%81%BF%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%94%E8%B3%AA%E5%95%8F%E3%81%AB%E3%81%8A%E7%AD%94%E3%81%88%E3%81%97%E3%81%BE%E3%81%99%3A%3C%2FP%3E%0A%3COL%3E%0A%3CLI%3E%0A%3CP%3EBMS772%20%E3%81%AB%E3%81%AF%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%20%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%8C%E3%83%97%E3%83%AA%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E6%9C%80%E6%96%B0%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AB%E6%9B%B4%E6%96%B0%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%20%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E5%82%99%E3%81%88%E3%81%9F%E9%96%8B%E7%99%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E7%95%99%E6%84%8F%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%93%E3%81%AE%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AF%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E9%96%8B%E7%99%BA%E7%9B%AE%E7%9A%84%E3%81%A7%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E6%9C%80%E7%B5%82%E4%BD%BF%E7%94%A8%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E4%BF%9D%E8%A8%BC%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%A8%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%8C%E3%83%8B%E3%83%BC%E3%82%BA%E3%82%92%E6%BA%80%E3%81%9F%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3E%E7%8F%BE%E6%99%82%E7%82%B9%E3%81%A7%E3%81%AF%E3%80%81%E8%A4%87%E6%95%B0%E3%81%AE%E3%83%91%E3%83%83%E3%82%AF%E3%82%92%E4%B8%A6%E8%A1%8C%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%20BMS%20%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%E3%81%AF%E5%AE%9F%E6%96%BD%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AF%E5%AF%BE%E5%BF%9C%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E4%B8%A6%E5%88%97%E6%A7%8B%E6%88%90%E3%81%A7%E6%AD%A3%E3%81%97%E3%81%8F%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%A8%E3%82%B9%E3%83%86%E3%83%BC%E3%83%88%20%E3%83%9E%E3%82%B7%E3%83%B3%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3E%E8%B5%B7%E5%8B%95%E6%99%82%E3%81%AB%20MOSFET%20%E3%82%92%E3%82%AA%E3%83%95%E3%81%AB%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%99%E3%82%8B%E3%82%BB%E3%83%AB%E3%83%95%E3%83%86%E3%82%B9%E3%83%88%E3%81%8C%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81MOSFET%20%E3%81%A8%E3%81%9D%E3%81%AE%E5%88%B6%E5%BE%A1%E5%9B%9E%E8%B7%AF%E3%81%8C%E5%AE%8C%E5%85%A8%E3%81%AB%E6%A9%9F%E8%83%BD%E3%81%97%E3%80%81HW%2FSW%20OC%2FOV%2F%E6%B8%A9%E5%BA%A6%E4%BF%9D%E8%AD%B7%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%A7%E3%81%99%20(SW%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E5%8F%82%E7%85%A7)%E3%80%82%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%81%AB%E4%BD%95%E3%81%8C%E8%B5%B7%E3%81%93%E3%82%8B%E3%81%8B%E3%81%AF%E3%82%B7%E3%83%8A%E3%83%AA%E3%82%AA%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E7%95%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E5%85%85%E9%9B%BB%E4%B8%AD%E3%81%8B%E6%94%BE%E9%9B%BB%E4%B8%AD%E3%81%8B%E3%80%81MOSFET%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%82%92%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%8B%E5%88%87%E6%96%AD%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%8B%E3%81%AA%E3%81%A9%E3%81%A7%E3%81%99%E3%80%82%E3%81%95%E3%82%89%E3%81%AB%E3%80%81BMS%20%E3%81%AF%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%20%E3%83%81%E3%83%A3%E3%83%BC%E3%82%B8%E3%83%A3%E3%83%BC%E3%81%A8%E5%90%8C%E3%81%98%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%82%92%E5%85%85%E9%9B%BB%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E5%A4%96%E9%83%A8%E3%81%A7%E5%88%B6%E5%BE%A1%E3%81%95%E3%82%8C%E3%82%8B%E5%AE%9A%E9%9B%BB%E6%B5%81%20(CC)%20%E5%AE%9A%E9%9B%BB%E5%9C%A7%20(CV)%20%E9%9B%BB%E6%BA%90%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3E%E7%8F%BE%E5%9C%A8%E3%80%81BMS%20%E3%81%AB%E3%81%AF%E3%80%81%E3%82%BB%E3%83%AB%E3%81%AE%E3%83%90%E3%83%A9%E3%83%B3%E3%82%B9%E3%82%92%E3%81%A8%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E6%90%AD%E8%BC%89%E3%83%90%E3%83%A9%E3%83%B3%E3%82%B9%E6%8A%B5%E6%8A%97%E5%99%A8%E3%81%A8%E3%80%81%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%9F%20BCC%20%E3%83%81%E3%83%83%E3%83%97%E5%86%85%E3%81%AE%20FET%20%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81MCU%20%E3%81%8B%E3%82%89%20BCC%20%E3%81%B8%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%80%81%E5%80%8B%E3%80%85%E3%81%AE%E3%82%BB%E3%83%AB%E3%81%AE%E3%83%90%E3%83%A9%E3%83%B3%E3%82%B9%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%BE%E3%81%9F%E3%81%AF%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3E%3CSPAN%3E%E3%81%93%E3%82%8C%E3%81%A7%E3%81%94%E8%B3%AA%E5%95%8F%E3%81%B8%E3%81%AE%E5%9B%9E%E7%AD%94%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%9F%E3%81%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1390544%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1390544%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%E3%82%BD%E3%83%BC%E3%83%A9%E3%83%BC%E3%83%89%E3%83%AD%E3%83%BC%E3%83%B3%E3%81%ABRDDRONE-BMS772%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%814S%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%83%91%E3%83%83%E3%82%AF%E3%82%9220%E5%80%8B%E4%B8%A6%E5%88%97%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E8%80%83%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E4%BB%A5%E4%B8%8B%E3%81%AE%E8%B3%AA%E5%95%8F%E3%82%92%E6%98%8E%E7%A2%BA%E3%81%AB%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E1.%20RDDRONE-BMS772%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AF%E3%81%9D%E3%81%AE%E3%81%BE%E3%81%BE%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E4%BD%BF%E7%94%A8%E5%89%8D%E3%81%AB%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E3%82%A2%E3%83%83%E3%83%97%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E2.%20BMS772%20%E3%82%92%2020%20%E5%80%8B%E4%B8%A6%E5%88%97%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%2020%20%E5%80%8B%E3%82%92%E5%85%85%E9%9B%BB%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%20%E3%83%91%E3%83%83%E3%82%AF%20(%E5%90%84%E3%83%91%E3%83%83%E3%82%AF%E3%81%AB%E3%81%AF%204S%20%E3%82%BB%E3%83%AB%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99)%3F%E3%81%AF%E3%81%84%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E5%A4%96%E9%83%A8%E3%81%AB%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%82%8B%E8%BF%BD%E5%8A%A0%E3%81%AE%E4%BF%9D%E8%AD%B7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E3.%20BMS772%20%E3%81%AB%E3%81%AF%20MOSFET%20%E3%81%AE%E6%95%85%E9%9A%9C%E3%82%92%E9%98%B2%E3%81%90%E3%81%9F%E3%82%81%E3%81%AE%E4%BF%9D%E8%AD%B7%E6%A9%9F%E8%83%BD%E3%81%8C%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%9D%E3%81%86%E3%81%A7%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81MOSFET%20%E3%81%8C%E6%95%85%E9%9A%9C%E3%81%99%E3%82%8B%E3%81%A8%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%81%AF%E3%81%A9%E3%81%86%E3%81%AA%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FP%3E%3CP%3E4.%20%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%20%E3%82%BB%E3%83%AB%20%E3%83%90%E3%83%A9%E3%83%B3%E3%82%B7%E3%83%B3%E3%82%B0%E3%81%AB%E3%81%AF%E5%A4%96%E4%BB%98%E3%81%91%20MOSFET%20%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%81%8B%3FBMS772%20%E3%81%A7%E3%81%AF%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%20%E3%82%BB%E3%83%AB%20%E3%83%90%E3%83%A9%E3%83%B3%E3%82%B9%E3%81%AF%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1371403%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1371403%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F189198%22%20target%3D%22_blank%22%3E%40coryjfowler%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E5%BD%93%E7%A4%BE%E3%81%AF%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E7%A9%8D%E6%A5%B5%E7%9A%84%E3%81%AB%E8%AA%BF%E6%9F%BB%E4%B8%AD%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E6%9C%80%E6%96%B0%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%20%E3%83%93%E3%83%AB%E3%83%89%E3%81%A7%E4%BD%95%E3%81%8C%E8%B5%B7%E3%81%93%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%82%92%E5%88%A4%E6%96%AD%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%20%E3%83%93%E3%83%AB%E3%83%89%E3%81%AE%E4%B8%80%E9%83%A8%E3%82%92%E5%80%89%E5%BA%AB%E3%81%8B%E3%82%89%E5%8F%96%E3%82%8A%E5%87%BA%E3%81%99%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%A0%B9%E6%9C%AC%E5%8E%9F%E5%9B%A0%E3%81%8C%E7%89%B9%E5%AE%9A%E3%81%95%E3%82%8C%E3%82%8B%E3%81%BE%E3%81%A7%E3%80%81%E5%9B%9E%E9%81%BF%E7%AD%96%E3%81%8C%E3%81%99%E3%81%90%E3%81%AB%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%94%E8%BE%9B%E6%8A%B1%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1371347%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1371347%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EV%204.0%20REV%20D%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A8%E3%80%81BMS%20%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E5%AE%8C%E5%85%A8%E3%81%AB%E5%81%9C%E6%AD%A2%E3%81%99%E3%82%8B%E5%8E%9F%E5%9B%A0%E3%81%A8%E3%81%AA%E3%82%8B%20NFC%20%E3%83%81%E3%83%83%E3%83%97%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E6%94%AF%E6%8F%B4%E3%81%97%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%3FGithub%20%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E5%AF%BE%E3%81%99%E3%82%8B%E6%9C%80%E5%BE%8C%E3%81%AE%E8%BF%94%E4%BF%A1%E3%81%AF%203%20%E6%97%A5%E5%89%8D%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E4%BB%8A%E6%9C%9D%E8%BF%94%E4%BA%8B%E3%82%92%E6%9C%9F%E5%BE%85%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E6%AE%8B%E5%BF%B5%E3%81%AA%E3%81%8C%E3%82%89%E3%81%9D%E3%81%86%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2Fissues%2F6%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2Fissues%2F6%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1277972%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1277972%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81KarenRdz%E3%81%95%E3%82%93%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E3%81%AF%E3%81%84%E3%80%81%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EJ19%20%E3%81%AF%20JTAG%20%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%83%BC%20%E3%83%94%E3%83%B3%E3%81%A8%20UART%20%E3%83%94%E3%83%B3%E3%82%92%E7%B5%84%E3%81%BF%E5%90%88%E3%82%8F%E3%81%9B%E3%81%BE%E3%81%99%E3%80%82UART%20%E3%83%94%E3%83%B3%E3%81%AF%20CLI%20%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3EDCD-LZ%20%E3%83%96%E3%83%AC%E3%83%BC%E3%82%AF%E3%82%A2%E3%82%A6%E3%83%88%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E3%81%93%E3%82%8C%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81JTAG%20%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%83%BC%E3%82%92%E3%81%9D%E3%81%AE%E3%83%96%E3%83%AC%E3%83%BC%E3%82%AF%E3%82%A2%E3%82%A6%E3%83%88%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%20JTAG%20%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%83%BC%20%E3%83%94%E3%83%B3%20(J2%20%E3%81%AA%E3%81%A9)%20%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%80%81UART%20%E3%82%92%20FTDI%20%E3%83%94%E3%83%B3%E9%85%8D%E7%BD%AE%E3%81%AB%E5%88%86%E9%9B%A2%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%20BMS%20%E3%81%AE%20J19%20%E3%81%AB%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%83%83%E3%83%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fnxp.gitbook.io%2Fhovergames%2Frddrone-fmuk66%2Fconnectors%2Fdebug-interface-dcd-lz%2Fdcd-lz-breakout-board%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fnxp.gitbook.io%2Fhovergames%2Frddrone-fmuk66%2Fconnectors%2Fdebug-interface-dcd-lz%2Fdcd-lz-breakout-board%3C%2FA%3E%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%83%96%E3%83%AC%E3%82%A4%E3%82%AF%E3%82%A2%E3%82%A6%E3%83%88%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E3%81%93%E3%81%A1%E3%82%89%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%20J2%20%E3%81%AF%E3%80%81UART%20%E3%83%94%E3%83%B3%E3%81%AE%E3%81%AA%E3%81%84%2010%20%E3%83%94%E3%83%B3%20JTAG%20%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%E3%81%AE%E3%81%BF%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3EJ2%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%2F%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%97%E3%80%81J19%20%E3%82%92%20CLI%20%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E%E3%81%9D%E3%81%AE%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%E3%80%81%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%20J21%20%E3%81%AB%E3%81%AF%E5%88%A5%E3%81%AE%20UART%20%E3%83%90%E3%82%B9%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E5%85%AC%E9%96%8B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81NuttX%20RTOS%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81CLI%20%E3%81%AB%E4%BB%96%E3%81%AE%20UART%20%E3%83%90%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E7%B0%A1%E5%8D%98%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3ENuttX%20%E3%81%AE%20menuconfig%20(%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20-%26gt%3B%20%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%20-%26gt%3B%20%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%20%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB)%20%E3%81%A7%E3%80%81LPUART0%20%E3%82%92%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%20%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%81%A8%E3%81%97%E3%81%A6%E9%81%B8%E6%8A%9E%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3ESO%E3%80%81%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8C%E3%81%B0%E3%80%81%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%2F%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%AB%E3%81%AF%20J2%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81CLI%20%E3%81%AB%E3%81%AF%20J21%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1276596%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1276596%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%EF%BC%81%3C%2FP%3E%3CP%3E%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82J-link%20%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%83%BC%E3%81%8C%20J2%20%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AB%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81CLI%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%BE%E3%81%9F%E3%81%AF%E3%80%81CLI%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%9B%E3%81%9A%E3%81%AB%20J2%20%E3%81%AE%E6%83%85%E5%A0%B1%E3%82%92%E5%8F%96%E5%BE%97%E3%81%99%E3%82%8B%E5%88%A5%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%94%E5%9B%9E%E7%AD%94%E3%82%92%E3%81%8A%E5%BE%85%E3%81%A1%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1269793%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1269793%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%AF%E3%81%84%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AF%E6%AE%8B%E5%BF%B5%E3%81%A7%E3%81%99%E3%81%AD%E3%80%82%E7%A7%81%E3%82%82%E8%AA%BF%E3%81%B9%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%8A%E3%81%A3%E3%81%97%E3%82%83%E3%82%8B%E9%80%9A%E3%82%8A%E3%80%81%E4%B8%96%E7%95%8C%E4%B8%AD%E3%81%A7%E5%88%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%8F%E3%81%91%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E6%B4%BB%E7%99%BA%E3%81%A7%E8%89%AF%E3%81%84%E9%83%A8%E5%88%86%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E4%B8%96%E7%95%8C%E7%9A%84%E3%81%AA%E3%83%81%E3%83%83%E3%83%97%E4%B8%8D%E8%B6%B3%E3%81%AB%E5%B7%BB%E3%81%8D%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%81%93%E3%81%AB%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%EF%BC%88%E3%81%82%E3%81%BE%E3%82%8A%E8%89%AF%E3%81%8F%E3%81%AA%E3%81%84%EF%BC%89%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3A%3CBR%20%2F%3E%20-%20Nexperia%20%E3%81%AB%E7%9B%B4%E6%8E%A5%E3%81%8A%E5%95%8F%E3%81%84%E5%90%88%E3%82%8F%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E5%BF%85%E8%A6%81%E3%81%AA%E3%81%AE%E3%81%AF%E3%81%BB%E3%82%93%E3%81%AE%E5%B0%91%E3%81%97%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%E6%99%82%E3%80%85%E3%80%81%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%81%8C%E6%89%8B%E5%85%83%E3%81%AB%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E-%20Nexperia.com%20%E3%81%A7%E9%A1%9E%E4%BC%BC%E3%81%AE%E4%BB%A3%E6%9B%BF%E5%93%81%E3%82%92%E6%8E%A2%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3E-%20%E8%BF%BD%E5%8A%A0%E3%81%AE%20BMS-772%20%E3%82%92%E8%B3%BC%E5%85%A5%E3%81%97%E3%80%81%E4%B8%80%E6%96%B9%E3%81%AE%E9%83%A8%E5%93%81%E3%82%92%E5%8F%96%E3%82%8A%E5%A4%96%E3%81%97%E3%81%A6%E3%82%82%E3%81%86%E4%B8%80%E6%96%B9%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1269709%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1269709%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%83%81%E3%83%83%E3%83%97%E4%B8%8D%E8%B6%B3%E3%81%AE%E3%81%9F%E3%82%81%E3%80%81PSMNR70-30YLH%20mosfet%20%E3%81%AF%E3%83%9E%E3%83%BC%E3%82%B1%E3%83%83%E3%83%88%E3%81%A7%E5%85%A5%E6%89%8B%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%8F%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%9D%E3%82%8C%E3%82%92%E3%81%A9%E3%81%86%E3%81%99%E3%82%8B%E3%81%8B%E3%80%81%E3%81%9D%E3%81%AE%E3%83%A2%E3%83%87%E3%83%AB%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%82%8B%E4%BB%96%E3%81%AE%20MOSFET%20%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%E3%81%93%E3%81%AE%E8%A3%BD%E5%93%81%E3%81%AF%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%A0%E3%81%91%E6%97%A9%E3%81%8F%E5%BF%85%E8%A6%81%E3%81%AA%E3%81%AE%E3%81%A7%E3%80%81%E3%81%99%E3%81%90%E3%81%AB%E8%BF%94%E4%BF%A1%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1267858%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1267858%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%82%A2%E3%83%8C%E3%82%B8%E3%81%95%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3EFRDM33772BSPIEVB%20%E3%81%AF%E3%80%81%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%20%E3%82%BB%E3%83%AB%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%81%AE%E8%A9%95%E4%BE%A1%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AB%E3%81%AF%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%80%81%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%80%81%E3%82%BB%E3%83%BC%E3%83%95%E3%83%86%E3%82%A3%E5%AF%BE%E7%AD%96%E3%81%AA%E3%81%A9%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3ERDDRONE-BMS772%20%E3%81%AF%E3%80%81%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%80%81%E9%9B%BB%E6%BA%90%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%80%81(%E5%8B%95%E4%BD%9C%E5%8F%AF%E8%83%BD%E3%81%A7%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA)%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%20%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%80%81%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E9%81%8E%E9%9B%BB%E6%B5%81%E5%9B%9E%E8%B7%AF%E3%81%AA%E3%81%A9%E3%82%92%E5%90%AB%E3%82%80%E3%83%A2%E3%83%90%E3%82%A4%E3%83%AB%20%E3%83%AD%E3%83%9C%E3%83%83%E3%83%88%E3%81%AE%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%20%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3ERDDRONE-BMS772%20%E3%81%AE%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fnxp.gitbook.io%2Frddrone-bms772%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fnxp.gitbook.io%2Frddrone-bms772%2F%3C%2FA%3E%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81https%3A%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%3C%2FA%3E%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3ERDDRONE-BMS772%20%E3%81%AF%E3%80%81%E5%AE%9F%E8%A3%85%E7%8A%B6%E6%85%8B%E3%81%A7%2060A%20%E3%81%AE%E9%80%A3%E7%B6%9A%20DC%20%E9%9B%BB%E6%B5%81%E5%AE%9A%E6%A0%BC%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E4%20%E7%B5%84%E3%81%AE%20MOSFET%20%E3%81%A8%204%20%E3%81%A4%E3%81%AE%E3%83%92%E3%83%BC%E3%83%88%E3%82%B7%E3%83%B3%E3%82%AF%E3%82%92%E5%82%99%E3%81%88%E3%80%81%E6%9C%80%E5%A4%A7%20DC%20%E9%9B%BB%E6%B5%81%E5%AE%9A%E6%A0%BC%E3%81%AF%2090A%20%E3%81%A7%E3%81%99%20(%E7%B6%9A%E3%81%8D)%E3%80%82%E3%81%93%E3%82%8C%E3%81%AB%E3%81%AF%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%E3%81%A8%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%E9%8A%85%E3%82%82%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3ERDDRONE-BMS772%20%E3%81%AB%E3%81%AF%E3%80%8120us%20%E4%BB%A5%E5%86%85%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%20545A%20%E3%81%AE%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E9%81%8E%E9%9B%BB%E6%B5%81%E5%9B%9E%E8%B7%AF%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E6%90%8D%E5%82%B7%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AA%E3%81%8F%E3%80%81545A%20%E3%81%AE%E3%83%94%E3%83%BC%E3%82%AF%E9%9B%BB%E6%B5%81%E3%81%8C%2020us%20%E9%96%93%E8%A8%B1%E5%AE%B9%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8A%E9%AB%98%E3%81%84%E9%9B%BB%E6%B5%81%E3%82%84%E3%82%88%E3%82%8A%E9%95%B7%E3%81%84%E6%99%82%E9%96%93%E3%81%AE%E9%9B%BB%E6%B5%81%E3%82%82%E5%8F%AF%E8%83%BD%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%83%86%E3%82%B9%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%9C%80%E5%A4%A7%E5%AE%9A%E6%A0%BC%E9%9B%BB%E6%B5%81%E3%81%BE%E3%81%9F%E3%81%AF%E6%8C%87%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%9F%E6%99%82%E9%96%93%E3%82%92%E8%B6%85%E3%81%88%E3%82%8B%E3%81%A8%E3%80%81%E8%87%AA%E5%B7%B1%E8%B2%AC%E4%BB%BB%E3%81%A8%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%81%AF%E5%B8%B8%E3%81%AB%E6%B3%A8%E6%84%8F%E3%81%97%E3%81%A6%E5%8F%96%E3%82%8A%E6%89%B1%E3%81%86%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%B3%A8%E6%84%8F%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1265442%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1265442%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AF%E5%A4%A7%E9%87%8F%E3%81%AE%E9%9B%BB%E5%8A%9B%E3%82%92%E5%BF%85%E8%A6%81%E3%81%A8%E3%81%99%E3%82%8B%E3%82%BD%E3%83%BC%E3%83%A9%E3%83%BC%E3%83%89%E3%83%AD%E3%83%BC%E3%83%B3%E3%81%AB%E5%8F%96%E3%82%8A%E7%B5%84%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E8%A3%BD%E5%93%81%E3%81%AF%E9%9D%9E%E5%B8%B8%E3%81%AB%E5%84%AA%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E6%9C%80%E9%AB%98%E8%A9%95%E4%BE%A1%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E5%BD%93%E7%A4%BE%E3%81%AF%2022%20%E3%83%9C%E3%83%AB%E3%83%88%E3%81%AE%206s%20%E6%A7%8B%E6%88%90%20Lipo%20%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%82%92%E4%BF%9D%E6%9C%89%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%83%A2%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%AB%E3%81%AF%E5%A4%A7%E9%87%8F%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B9%E3%83%88%E9%9B%BB%E6%B5%81%E3%81%A8%E9%80%A3%E7%B6%9A%E9%9B%BB%E6%B5%81%20(%E6%95%B0%E5%88%86%E9%96%93%2090A)%20%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AB%E3%81%AA%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AE%E6%9C%80%E5%A4%A7%E5%AE%9A%E6%A0%BC%E3%81%AF%2090A%20DC%20%E3%81%A8%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%81%AE%E5%80%A4%E3%81%AF%E9%80%A3%E7%B6%9A%E6%9C%80%E5%A4%A7%E5%AE%9A%E6%A0%BC%E3%81%A7%E3%81%99%E3%81%8B%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E3%83%90%E3%83%BC%E3%82%B9%E3%83%88%E6%9C%80%E5%A4%A7%E5%AE%9A%E6%A0%BC%E3%81%A7%E3%81%99%E3%81%8B%E3%80%82%E3%83%90%E3%83%BC%E3%82%B9%E3%83%88%E9%9B%BB%E6%B5%81%E3%81%A8%E3%83%90%E3%83%BC%E3%82%B9%E3%83%88%E9%9B%BB%E6%B5%81%E3%81%AE%E6%99%82%E9%96%93%E5%88%B6%E9%99%90%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%E3%80%82BMS%20FRDM33772BSPIEVB%20%E3%81%A8%E4%BB%96%E3%81%AE%20BMS%20%E3%81%AE%E3%81%A9%E3%81%A1%E3%82%89%E3%81%8C%E7%A7%81%E3%81%AB%E3%81%A8%E3%81%A3%E3%81%A6%E3%82%88%E3%82%8A%E9%81%A9%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E3%81%AB%E6%97%A9%E3%81%84%E8%BF%94%E4%BF%A1%E3%81%8C%E5%BE%97%E3%82%89%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E9%A1%98%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1216911%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1216911%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EBMS772%20%E3%81%AF%E8%87%AA%E5%8B%95%E3%83%90%E3%83%A9%E3%83%B3%E3%82%B9%E8%AA%BF%E6%95%B4%E3%82%92%E8%A1%8C%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%82%92%E5%85%85%E9%9B%BB%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E4%BE%9B%E7%B5%A6%E3%81%95%E3%82%8C%E3%82%8B%E9%9B%BB%E6%B5%81%E5%85%A8%E4%BD%93%E3%82%92%E5%88%B6%E5%BE%A1%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81%E3%83%91%E3%83%AF%E3%83%BC%E3%82%B9%E3%83%86%E3%82%A2%E3%83%AA%E3%83%B3%E3%82%B0%2F%E3%82%A2%E3%82%A4%E3%82%BD%E3%83%AC%E3%83%BC%E3%82%BF%E3%82%82%E6%8F%90%E4%BE%9B%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%86%E3%81%97%E3%81%AA%E3%81%84%E3%81%A8%E3%80%812%20%E3%81%A4%E3%81%AE%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%82%92%E4%B8%A6%E5%88%97%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81%E5%85%85%E9%9B%BB%E9%87%8F%E3%81%AE%E5%A4%9A%E3%81%84%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%81%8C%E5%85%85%E9%9B%BB%E9%87%8F%E3%81%AE%E5%B0%91%E3%81%AA%E3%81%84%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%82%92%E5%85%85%E9%9B%BB%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%BE%E3%81%9F%E3%80%81%E4%B8%8A%E8%A8%98%E3%81%A7%E3%81%AF%E6%98%8E%E7%A2%BA%E3%81%A7%E3%81%AA%E3%81%84%E3%81%AE%E3%81%AF%E3%80%811%20%E3%81%A4%E3%81%AE%E3%83%91%E3%83%83%E3%82%AF%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%81%AE%E3%81%8B%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%202%20%E3%81%A4%E3%81%AE%E5%80%8B%E5%88%A5%E3%81%AE%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E5%8F%AF%E8%83%BD%E3%81%AA%E3%83%91%E3%83%83%E3%82%AF%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%81%AE%E3%81%8B%E3%81%A8%E3%81%84%E3%81%86%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E5%BF%85%E8%A6%81%E3%81%AB%E5%BF%9C%E3%81%98%E3%81%A6%E3%80%81%E5%80%8B%E5%88%A5%E3%81%AE%E3%82%BB%E3%83%AB%E3%82%92%201%20%E3%81%A4%E3%81%AE%E5%A4%A7%E3%81%8D%E3%81%AA%E3%82%BB%E3%83%AB%E3%81%AB%E4%B8%A6%E5%88%97%E5%8C%96%E3%81%97%E3%81%A6%20(%E5%8D%98%E4%B8%80%E3%81%AE%20BMS%20%E3%82%92%E4%BD%BF%E7%94%A8)%20%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%AA%AC%E6%98%8E%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82SO%E3%80%81%E3%83%91%E3%83%83%E3%82%AF%E3%81%94%E3%81%A8%E3%81%AB%201%20%E3%81%A4%E3%81%AE%20BMS%20%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3EBMS%20%E3%81%AF%E3%81%8A%E3%82%88%E3%81%9D%203S%204000mA%2Fh%20%E3%81%AE%E8%B6%A3%E5%91%B3%E7%94%A8%20LiPo%20%E3%81%AE%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%A7%E3%81%99%E3%80%82%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E6%AD%A3%E7%A2%BA%E3%81%AA%E5%AF%B8%E6%B3%95%E3%81%AF%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1203659%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1203659%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%9B%B4%E6%96%B0%E6%83%85%E5%A0%B1%E3%81%A8%E8%BF%85%E9%80%9F%E3%81%AA%E8%BF%94%E4%BF%A1%E3%82%92%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AEThread%E3%82%92%E5%BF%85%E3%81%9A%E6%B3%A8%E7%9B%AE%E3%81%97%E3%81%A6%E3%81%8A%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%82%92%E6%8E%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AEThread%E3%81%AB%E5%81%B6%E7%84%B6%E5%87%BA%E4%BC%9A%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Falaskasworld.run%2F%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E3%82%A2%E3%83%A9%E3%82%B9%E3%82%AB%E3%83%AF%E3%83%BC%E3%83%AB%E3%83%89%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1153065%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1153065%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%BD%93%E7%A4%BE%E3%81%AF%202%20x%207000mAh%206S%20%E3%83%AA%E3%83%81%E3%82%A6%E3%83%A0%E3%83%9D%E3%83%AA%E3%83%9E%E3%83%BC%20%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%81%A7%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%E3%83%89%E3%83%AD%E3%83%BC%E3%83%B3%20%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%82%92%E8%A3%BD%E9%80%A0%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%82%89%202%20%E3%81%A4%E3%81%AE%E3%83%91%E3%83%83%E3%82%AF%E3%82%92%E4%B8%A6%E5%88%97%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E3%80%8114000mAh%206S%20%E3%82%92%E5%AE%9F%E7%8F%BE%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%8C%E3%82%84%E3%81%A3%E3%81%9F%E3%81%93%E3%81%A8%E3%81%AF%E3%80%812%20%E3%81%A4%E3%81%AE%E3%83%91%E3%83%83%E3%82%AF%E3%82%92%E3%82%A4%E3%83%B3%E3%82%AD%E3%83%A5%E3%83%99%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%83%8F%E3%82%A6%E3%82%B8%E3%83%B3%E3%82%B0%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81%E3%81%9D%E3%82%8C%E3%82%89%E3%82%92%201%20%E3%81%A4%E3%81%AE%2010%20%E3%83%94%E3%83%B3%E3%81%AE%E5%A0%85%E7%89%A2%E3%81%AA%E3%82%AA%E3%82%B9%20%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%80%81UAV%20%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AB%E3%81%AF%E3%83%A1%E3%82%B9%20%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%E3%81%8C%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E8%A8%88%E7%94%BB%E3%81%A7%E3%81%AF%E3%80%81%E3%83%89%E3%83%AD%E3%83%BC%E3%83%B3%E3%81%AE%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%82%92%E3%82%AB%E3%83%BC%E3%83%88%E3%83%AA%E3%83%83%E3%82%B8%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%81%A6%E3%80%81UAV%20%E3%81%AB%E5%B7%AE%E3%81%97%E8%BE%BC%E3%82%93%E3%81%A7%E3%82%AB%E3%83%81%E3%83%83%E3%81%A8%E3%81%AF%E3%82%81%E3%81%A6%E8%A3%85%E7%9D%80%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%80%81%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%81%AE%E5%85%85%E9%9B%BB%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AA%E3%81%A8%E3%81%8D%E3%81%AF%E3%82%AB%E3%83%BC%E3%83%88%E3%83%AA%E3%83%83%E3%82%B8%E3%82%92%E5%8F%96%E3%82%8A%E5%87%BA%E3%81%97%E3%81%A6%E3%80%81UAV%20%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A8%E5%90%8C%E3%81%98%E3%83%94%E3%83%B3%20%E3%82%BF%E3%82%A4%E3%83%97%E3%81%A7%E5%85%85%E9%9B%BB%E5%99%A8%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E8%B3%AA%E5%95%8F%E3%81%AF%E3%80%81%E5%85%85%E9%9B%BB%E6%99%82%E3%81%AB%E3%82%AB%E3%83%BC%E3%83%88%E3%83%AA%E3%83%83%E3%82%B8%E3%81%AE%E8%87%AA%E5%8B%95%E3%83%90%E3%83%A9%E3%83%B3%E3%82%B9%E3%82%92%E5%AE%9F%E7%8F%BE%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%20BMS%20772%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%82%E3%81%97SO%E3%81%AA%E3%82%89%E3%80%81%E3%81%A9%E3%81%86%E3%82%84%E3%81%A3%E3%81%A6%E3%81%9D%E3%82%8C%E3%82%92%E3%81%99%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AF%202%20%E3%81%A4%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%81%8B%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%201%20%E3%81%A4%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%E3%81%8B%3F%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%81%84%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E5%AF%B8%E6%B3%95%E3%81%AF%E3%81%A9%E3%82%8C%E3%81%8F%E3%82%89%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%83%95%E3%82%A1%E3%83%AB%E3%82%B3%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2317845%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2317845%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E5%A4%A7%E5%AD%A6%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A7%20BMS-772%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%20%E3%82%BB%E3%83%AB%20%E3%82%A8%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E4%B8%80%E6%99%82%E7%9A%84%E3%81%AB%E7%B4%94%E7%B2%8B%E3%81%AB%E3%83%86%E3%82%B9%E3%83%88%E7%9B%AE%E7%9A%84%E3%81%A7%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%82%BB%E3%83%AB%E3%82%92%E6%A8%A1%E5%80%A3%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E3%83%96%E3%83%AC%E3%83%83%E3%83%89%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%A7%E6%8A%B5%E6%8A%97%E5%99%A8%E3%81%AE%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%A8%AD%E8%A8%88%E3%81%99%E3%82%8B%E3%81%8B%E3%82%92%E7%9F%A5%E3%82%8A%E3%81%9F%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%94%E5%8D%94%E5%8A%9B%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%B7%E3%82%A7%E3%83%BC%E3%83%B3%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2317850%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2317850%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178538%22%20target%3D%22_blank%22%3E%40SH%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E4%BD%95%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%9F%E3%81%84%E3%81%8B%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E7%95%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%82%BB%E3%83%AB%E6%B8%AC%E5%AE%9A%E3%82%BF%E3%83%96%E3%81%AB%E9%9B%BB%E5%9C%A7%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%97%E3%81%9F%E3%81%84%E5%A0%B4%E5%90%88%E3%80%82%E3%82%BB%E3%83%AB%E3%82%92%E5%85%85%E9%9B%BB%E3%81%97%E3%81%9F%E3%82%8A%EF%BC%88%E5%8F%97%E5%8B%95%E7%9A%84%E3%81%AB%EF%BC%89%E3%83%90%E3%83%A9%E3%83%B3%E3%82%B9%E8%AA%BF%E6%95%B4%E3%81%97%E3%81%9F%E3%82%8A%E3%81%9B%E3%81%9A%E3%81%AB%E3%80%82%E9%9B%BB%E5%9C%A7%E4%BE%9B%E7%B5%A6%E3%81%AB%E6%8A%B5%E6%8A%97%E5%99%A8%E3%82%92%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%E3%82%BB%E3%83%AB%E9%9B%BB%E5%9C%A7%E3%82%92%E6%A8%A1%E5%80%A3%E3%81%97%E3%80%81BMS772%20%E3%81%A7%E6%B8%AC%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E7%B0%A1%E5%8D%98%E3%81%AB%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%9F%E3%81%A8%E3%81%88%E3%81%B0%E3%80%81%E3%83%A9%E3%83%9C%E3%81%AE%E9%9B%BB%E6%BA%90%E3%81%8C%E3%81%82%E3%82%8A%E3%80%813S%20%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%20(%E7%9B%B4%E5%88%97%203%20%E3%82%BB%E3%83%AB)%20%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%99%E3%82%8B%E3%81%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%83%A9%E3%83%9C%E3%81%AE%E9%9B%BB%E6%BA%90%E3%82%92%2012V%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81BMS%20%E3%81%AE%E9%9B%BB%E6%BA%90%20%2B%20%E3%81%A8%E9%9B%BB%E6%BA%90%20-%20%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%82%8C%E3%81%AB%E4%B8%A6%E5%88%97%E3%81%AB%E3%80%81%E9%9B%BB%E6%BA%90%20%2B%20%E3%81%8B%E3%82%89%E9%9B%BB%E6%BA%90%20-%20%E3%81%AB%E7%9B%B4%E5%88%97%E3%81%AB%E3%80%81%E3%81%9F%E3%81%A8%E3%81%88%E3%81%B0%201k%CE%A9%20%E3%81%AE%E6%8A%B5%E6%8A%97%203%20%E5%80%8B%E3%82%92%E6%8C%81%E3%81%A4%E5%88%86%E5%9C%A7%E5%99%A8%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E6%8A%B5%E6%8A%97%E5%99%A8%E3%81%AB%204%20%E6%9C%AC%E3%81%AE%E3%83%90%E3%83%A9%E3%83%B3%E3%82%B9%20%E3%83%AF%E3%82%A4%E3%83%A4%20(%2B%E3%80%81-%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E6%8A%B5%E6%8A%97%E5%99%A8%E9%96%93%E3%81%AE%202%20%E6%9C%AC)%20%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%E3%80%81%E3%83%90%E3%83%A9%E3%83%B3%E3%82%B9%20%E3%83%AA%E3%83%BC%E3%83%89%20%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%20JP1%20%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E3S%20%E6%A7%8B%E6%88%90%E3%81%AE%20BMS%20%E3%81%AF%E3%80%81github%20%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20%E3%83%8E%E3%83%BC%E3%83%88%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%81%AF%E3%82%93%E3%81%A0%E4%BB%98%E3%81%91%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3A%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXP-Robotics%2FRDDRONE-BMS772%2Fblob%2Fmain%2FBMS772_releaseNotes_6.0.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ERDDRONE-BMS772%2FBMS772_releaseNotes_6.0.pdf%20at%20main%20%C2%B7%20NXP-Robotics%2FRDDRONE-BMS772%20%C2%B7%20GitHub%3C%2FA%3E%3CBR%20%2F%3E%E9%96%B2%E8%A6%A7%E8%80%85%E3%81%8C%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%83%97%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%81%93%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20%E3%83%8E%E3%83%BC%E3%83%88%E3%81%AE%20PDF%20%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%A7%E3%81%AF%E3%80%81%E3%80%8C%E3%82%BB%E3%83%AB%E3%80%8D%E3%81%94%E3%81%A8%E3%81%AB%E7%B4%84%204V%20%E3%81%AB%E3%81%AA%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%83%A9%E3%83%9C%E3%81%AE%E9%9B%BB%E6%BA%90%E3%82%92%E3%82%AA%E3%83%B3%E3%81%AB%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81BMS772%20%E3%82%92%E9%80%9A%E5%B8%B8%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E8%B5%B7%E5%8B%95%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%20(%E8%B2%A0%E8%8D%B7%E3%81%AA%E3%81%97%E3%81%A7%E9%9B%BB%E6%B5%81%E5%88%B6%E9%99%90%E3%82%92%20100%20mA%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99)%E3%80%82%3C%2FP%3E%0A%3CP%3EBMS%20%E3%81%A8%E9%9B%BB%E6%BA%90%E3%81%8C%E5%AF%BE%E5%BF%9C%E5%8F%AF%E8%83%BD%E3%81%A7%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AB%E5%90%88%E3%82%8F%E3%81%9B%E3%81%A6%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E9%99%90%E3%82%8A%E3%80%81BMS772%20%E3%81%AE%E5%87%BA%E5%8A%9B%E3%81%AB%E8%B2%A0%E8%8D%B7%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%82%8C%E3%81%8C%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A4%E3%81%93%E3%81%A8%E3%82%92%E9%A1%98%E3%81%84%E3%81%BE%E3%81%99!%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%95%AC%E5%85%B7%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%82%B7%E3%82%B9%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2318145%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2318145%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%8A%A9%E3%81%91%E3%81%A6%E3%81%8F%E3%82%8C%E3%81%A6%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%82%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E9%80%9F%E5%BA%A6%E3%82%92%E4%B8%8B%E3%81%92%E3%82%8B%E3%81%A8%E5%95%8F%E9%A1%8C%E3%81%AF%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2345508%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2345508%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%8A%A9%E3%81%91%E3%81%A6%E3%81%8F%E3%82%8C%E3%81%A6%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%82%E7%A7%81%E3%81%AF2%E6%9E%9A%E7%9B%AE%E3%81%AEBMS-772%E5%9F%BA%E6%9D%BF%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%813%E3%82%BB%E3%83%AB%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%E3%82%92%E5%9F%BA%E6%9D%BF%E3%81%AB%E3%81%AF%E3%82%93%E3%81%A0%E4%BB%98%E3%81%91%E3%81%97%E3%81%A6%E3%80%81%E6%8A%B5%E6%8A%97%E5%99%A8%E3%81%A7%E3%82%BB%E3%83%AB%E3%82%92%E6%A8%A1%E5%80%A3%E3%81%97%E3%81%9F3%E3%82%BB%E3%83%AB%E6%A7%8B%E6%88%90%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81CLI%E3%81%A7%E3%81%AF%E5%B8%B8%E3%81%AB3%E7%95%AA%E7%9B%AE%E3%81%AE%E3%82%BB%E3%83%AB%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A60V%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%80%81%E3%81%9D%E3%81%AE%E3%81%9F%E3%82%81%E4%BD%8E%E9%9B%BB%E5%9C%A7%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%823%E7%95%AA%E7%9B%AE%E3%81%AE%E6%8A%B5%E6%8A%97%E5%99%A8%E3%81%AB%E3%81%AF%E9%9B%BB%E5%9C%A7%E3%81%8C%E3%81%8B%E3%81%8B%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E5%9F%BA%E6%9D%BF%E5%BA%95%E9%9D%A2%E3%81%AE%E3%82%BB%E3%83%AB%E8%A8%AD%E5%AE%9A%E3%83%91%E3%83%83%E3%83%89%E3%81%AB%E3%83%8F%E3%83%B3%E3%83%80%E3%81%8C%E4%BB%98%E7%9D%80%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%BB%E3%81%A8%E3%82%93%E3%81%A9%E9%99%A4%E5%8E%BB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E4%BD%95%E3%81%8C%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%E3%81%94%E5%8D%94%E5%8A%9B%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%B7%E3%82%A7%E3%83%BC%E3%83%B3%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2220260404_171220.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260404_171220.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260404_171220.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260404_171220.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260404_171220.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260404_171220.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F381323i73E864FB58426931%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2220260404_171220.jpg%22%20alt%3D%2220260404_171220.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2220260404_171231.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260404_171231.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260404_171231.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260404_171231.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260404_171231.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260404_171231.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F381325i7006506CB8F06056%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2220260404_171231.jpg%22%20alt%3D%2220260404_171231.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2220260404_171422.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260404_171422.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260404_171422.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260404_171422.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260404_171422.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260404_171422.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F381324iF8917DE718BCF66E%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2220260404_171422.jpg%22%20alt%3D%2220260404_171422.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2346028%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2346028%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F259906%22%20target%3D%22_blank%22%3E%40Shane93%20%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%82%3C%2FP%3E%0A%3CP%3ERDDRONE-BMS772%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%81%94%E8%B3%AA%E5%95%8F%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%80%81%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E5%BD%B9%E7%AB%8B%E3%81%A4%E7%94%BB%E5%83%8F%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%80%81%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%0A%3CP%3EBMS%E3%81%8C3S%E7%94%A8%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E3%81%AF%E3%82%93%E3%81%A0%E4%BB%98%E3%81%91%E6%8E%A5%E7%B6%9A%E3%82%92%E6%A4%9C%E8%A8%BC%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3CBR%20%2F%3E%E7%94%BB%E5%83%8F%E3%82%92%E8%A6%8B%E3%82%8B%E9%99%90%E3%82%8A%E3%80%81SJ2%E3%81%AF%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81SJ12%E3%81%A8SJ10%E3%81%AF%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E6%8A%B5%E6%8A%97%E6%B8%AC%E5%AE%9A%E6%A9%9F%E8%83%BD%E4%BB%98%E3%81%8D%E3%81%AE%E3%83%9E%E3%83%AB%E3%83%81%E3%83%A1%E3%83%BC%E3%82%BF%E3%83%BC%E3%82%92%E3%81%8A%E6%8C%81%E3%81%A1%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%EF%BC%88%E6%8A%B5%E6%8A%97%E5%99%A8%E3%82%92%E5%8F%96%E3%82%8A%E5%A4%96%E3%81%97%E3%80%81%E5%9F%BA%E6%9D%BF%E3%81%AB%E9%9B%BB%E6%BA%90%E3%82%92%E4%BE%9B%E7%B5%A6%E3%81%97%E3%81%AA%E3%81%84%E7%8A%B6%E6%85%8B%E3%81%A7%EF%BC%89%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%82%BB%E3%83%AB%E6%A7%8B%E6%88%90%EF%BC%883S%EF%BC%89%E7%94%A8%E3%81%AE%E3%81%AF%E3%82%93%E3%81%A0%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%91%E3%83%BC%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E8%A9%B3%E7%B4%B0%E6%83%85%E5%A0%B1%E3%81%AF%E3%80%81%E3%81%93%E3%81%A1%E3%82%89%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%EF%BC%9A%20%3CA%20href%3D%22https%3A%2F%2Fnxp.gitbook.io%2Frddrone-bms772%2Fboard-user-guide%2Fgetting-started-with-the-rddrone-bms772%2Fconfiguring-the-hardware%23cell-terminal-connection%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fnxp.gitbook.io%2Frddrone-bms772%2Fboard-user-guide%2Fgetting-started-with-the-rddrone-bms772%2Fconfiguring-the-hardware%23cell-terminal-connection%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%82%82%E3%81%86%E4%B8%80%E3%81%A4%E6%B0%97%E3%81%A5%E3%81%84%E3%81%9F%E3%81%AE%E3%81%AF%E3%80%81%E3%83%96%E3%83%AC%E3%83%83%E3%83%89%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A8%E3%83%87%E3%83%A5%E3%83%9D%E3%83%B3%E7%A4%BE%E3%81%AE%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%91%E3%83%BC%E7%B7%9A%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E7%82%B9%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E6%A9%9F%E5%99%A8%E3%81%AF%E6%8E%A5%E7%B6%9A%E7%8A%B6%E6%85%8B%E3%81%8C%E6%82%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%A7%E7%9F%A5%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%80%81%E3%81%9D%E3%81%AE%E7%82%B9%E3%81%AB%E3%81%94%E6%B3%A8%E6%84%8F%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%AE%E9%9A%9B%E3%81%AB%E3%81%AF%E3%80%81%E3%81%93%E3%82%8C%E3%81%8C%E7%B0%A1%E5%8D%98%E3%81%AB%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E7%90%86%E8%A7%A3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%83%96%E3%83%AC%E3%83%83%E3%83%89%E3%83%9C%E3%83%BC%E3%83%89%E3%82%84%E9%85%8D%E7%B7%9A%E3%81%AE%E4%B8%8D%E5%85%B7%E5%90%88%E3%81%AB%E3%82%88%E3%82%8B%E6%8E%A5%E7%B6%9A%E4%B8%8D%E8%89%AF%E3%82%82%E5%95%8F%E9%A1%8C%E3%81%A8%E3%81%AA%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E7%94%BB%E5%83%8F%E3%82%92%E8%A6%8B%E3%82%8B%E9%99%90%E3%82%8A%E3%80%81%E6%8E%A5%E7%B6%9A%E6%96%B9%E6%B3%95%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%82%82%E8%88%88%E5%91%B3%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3ECLI%20%2F%20UART%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%E3%81%AB%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%85%A5%E5%8A%9B%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20bms%20%E3%81%99%E3%81%B9%E3%81%A6%E3%82%92%E5%8F%96%E5%BE%97%E3%81%99%E3%82%8B%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%BD%95%E3%81%8C%E8%A6%8B%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E4%BE%8B%E3%81%88%E3%81%B0%E3%80%81%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%A7%E3%81%AF6%E3%82%BB%E3%83%AB%E3%81%A8%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%80%81%E3%81%9D%E3%81%AE%E3%82%BB%E3%83%AB%E6%95%B0%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%E5%8F%82%E7%85%A7%E3%81%99%E3%81%B9%E3%81%8D%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%83%8E%E3%83%BC%E3%83%88%E3%81%AE%E7%AC%AC6%E7%AB%A0%E3%80%8C%E3%81%AF%E3%81%98%E3%82%81%E3%81%AB%EF%BC%8F%E3%82%AF%E3%82%A4%E3%83%83%E3%82%AF%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88%E3%82%AC%E3%82%A4%E3%83%89%E3%80%8D%EF%BC%8859%E3%83%9A%E3%83%BC%E3%82%B8%E4%B8%AD9%E3%83%9A%E3%83%BC%E3%82%B8%E7%9B%AE%EF%BC%89%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82RDDRONE%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXP-Robotics%2FRDDRONE-BMS772%2Fblob%2Fmain%2FBMS772_releaseNotes_6.0.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E-BMS772%2FBMS772_releaseNotes_6.0.pdf%EF%BC%88main%20%C2%B7%20NXP-Robotics%2FRDDRONE-BMS772%20%C2%B7%20GitHub%EF%BC%89%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E7%AC%AC6%E7%AB%A04.1%E7%AF%80%EF%BC%9A%E6%9C%80%E3%82%82%E9%87%8D%E8%A6%81%E3%81%AABMS%E5%A4%89%E6%95%B0%E3%82%92%E7%9F%A5%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%80%81BMS%E3%82%92%E5%B0%8E%E5%85%A5%E3%81%99%E3%82%8B%E9%9A%9B%E3%81%AB%E4%BD%95%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%8B%E3%81%8C%E5%88%86%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82n%E5%80%8B%E3%81%AE%E7%B4%B0%E8%83%9E%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%82%E3%81%AE%E3%81%A0%E3%80%82%3C%2FP%3E%0A%3CP%3En-cells%E3%82%92%EF%BC%88%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E5%A0%B4%E5%90%88%EF%BC%893%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20bms%E3%81%AFn%E3%82%BB%E3%83%AB%E3%82%923%E3%81%A4%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81BMS%E3%81%8C%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AB%E5%AD%98%E5%9C%A8%E3%81%97%E3%81%AA%E3%81%84%E4%BB%96%E3%81%AE3%E3%81%A4%E3%81%AE%E3%82%BB%E3%83%AB%E3%82%92%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%81%97%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%82%8C%E3%81%8C%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%B7%E3%82%B9%E3%83%BB%E3%83%95%E3%82%A1%E3%83%B3%E3%83%BB%E3%83%9F%E3%82%A8%E3%83%AB%E3%83%AD%3C%2FP%3E%0A%3CDIV%20id%3D%22tinyMceEditorcisvmierlo_1%22%20class%3D%22mceNonEditable%20lia-copypaste-placeholder%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2347106%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2347106%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%3C%2FA%3E%3C%2FP%3E%3CP%3E%E3%81%94%E5%8D%94%E5%8A%9B%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%AF%E3%82%93%E3%81%A0%E3%83%91%E3%83%83%E3%83%89%E3%81%AF%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%83%83%E3%83%89%E3%81%AE%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E3%80%8Cbms%20get%20all%E3%80%8D%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%AC%A1%E3%81%AE%E7%B5%90%E6%9E%9C%E3%81%8C%E8%BF%94%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%813%E3%81%A4%E3%81%AE%E6%8A%B5%E6%8A%97%E5%99%A8%E3%81%AE%E4%B8%A1%E7%AB%AF%E3%82%92%E6%B8%AC%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%A8%E3%80%8112V%E3%80%818V%E3%80%814V%E3%80%810V%E3%81%A8%E3%81%84%E3%81%86%E8%87%AA%E7%84%B6%E3%81%AA%E9%99%8D%E5%9C%A7%E3%81%8C%E5%BE%97%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%B7%E3%82%A7%E3%83%BC%E3%83%B3%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22image_2026-04-08_115330382.png%22%20style%3D%22width%3A%20422px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image_2026-04-08_115330382.png%22%20style%3D%22width%3A%20422px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image_2026-04-08_115330382.png%22%20style%3D%22width%3A%20422px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image_2026-04-08_115330382.png%22%20style%3D%22width%3A%20422px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F381564i400DFD6906B5EBDB%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22image_2026-04-08_115330382.png%22%20alt%3D%22image_2026-04-08_115330382.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2357827%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2357827%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%3C%2FA%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%94%E5%8D%94%E5%8A%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%80%81%E6%9C%AC%E5%BD%93%E3%81%AB%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%9F%BA%E6%9D%BF%E8%A3%8F%E9%9D%A2%E3%81%AE%E8%A1%A8%E9%9D%A2%E5%AE%9F%E8%A3%85%E6%8A%B5%E6%8A%97%E5%99%A8%E3%81%AE%E3%81%86%E3%81%A12%E5%80%8B%E3%81%8C%E5%89%A5%E3%81%8C%E3%82%8C%E3%81%A6%E3%81%97%E3%81%BE%E3%81%84%E3%80%81%E3%82%BB%E3%83%AB%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E5%9B%9E%E8%B7%AF%E3%81%AB%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%9F%E3%80%82%E5%95%8F%E9%A1%8C%E3%81%AF%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%94%B9%E3%82%81%E3%81%A6%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%9C%80%E5%BE%8C%E3%81%AB%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AB%E3%81%94%E5%8D%94%E5%8A%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8B%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%AA%E3%81%84%E8%B3%AA%E5%95%8F%E3%81%8C%E4%B8%80%E3%81%A4%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AFNI-XNET%E3%81%A8Cyphal%20CAN%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E7%8B%AC%E8%87%AA%E3%81%AE%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0CAN%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82CAN%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%81%AE%E6%A7%8B%E9%80%A0%E3%81%A8%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E3%81%BE%E3%81%9F%E3%80%81CAN%E7%B5%8C%E7%94%B1%E3%81%A7MOSFET%E3%82%92%E5%88%B6%E5%BE%A1%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E5%87%BA%E5%8A%9B%E9%9B%BB%E5%9C%A7%E3%82%92%E3%82%AA%E3%83%95%E3%81%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%B7%E3%82%A7%E3%83%BC%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2358374%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2358374%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F259906%22%20target%3D%22_blank%22%3E%40Shane93%20%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%82%3C%2FP%3E%0A%3CP%3E2%E3%81%A4%E3%81%AESMD%E6%8A%B5%E6%8A%97%E5%99%A8%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E7%99%BA%E8%A6%8B%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%80%81%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E6%83%85%E5%A0%B1%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E6%84%9F%E8%AC%9D%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3ECyphalCAN%E3%81%A8DroneCAN%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E6%83%85%E5%A0%B1%E3%81%AF%E3%80%81%E3%81%A9%E3%81%A1%E3%82%89%E3%82%82%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%83%8E%E3%83%BC%E3%83%88%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%A9%E3%81%AE%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E5%AE%9F%E8%A3%85%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%8C%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%A9%E3%81%A1%E3%82%89%E3%81%AE%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%81%AB%E3%82%82%E3%80%81%E9%9B%BB%E6%BA%90%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%82%92%E3%82%AA%E3%83%95%E3%81%AB%E3%81%99%E3%82%8B%E7%9B%B4%E6%8E%A5%E7%9A%84%E3%81%AA%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AF%E5%AD%98%E5%9C%A8%E3%81%97%E3%81%AA%E3%81%84%E3%80%82%3CBR%20%2F%3EDroneCAN%E3%82%92%E4%BD%BF%E3%81%88%E3%81%B0%E3%80%81%E8%A8%AD%E5%AE%9A%E3%82%92%E7%B0%A1%E5%8D%98%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%A7%E3%81%8D%E3%80%81BMS%E3%81%8C%E9%9B%BB%E6%BA%90%E3%82%92%E9%81%AE%E6%96%AD%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E6%84%8F%E5%9B%B3%E7%9A%84%E3%81%AB%E7%99%BA%E7%94%9F%E3%81%95%E3%81%9B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E4%BE%8B%E3%81%88%E3%81%B0%E3%80%81%E9%81%8E%E7%86%B1%E8%A8%AD%E5%AE%9A%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E3%81%AA%E3%81%A9%E3%80%82%3CBR%20%2F%3E%E8%A8%AD%E5%AE%9A%E3%82%92%E3%80%8C%E6%AD%A3%E5%B8%B8%E3%80%8D%E3%81%AA%E5%80%A4%E3%81%AB%E6%88%BB%E3%81%97%E3%81%A6%E3%80%81%E4%B8%8D%E5%85%B7%E5%90%88%E3%82%92%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%99%E3%82%8C%E3%81%B0%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%93%E3%82%8C%E3%81%AFDroneCAN%E3%81%A7%E3%83%86%E3%82%B9%E3%83%88%E6%B8%88%E3%81%BF%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E7%8B%AC%E8%87%AA%E3%81%AE%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0CAN%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E6%A9%9F%E8%83%BD%E3%82%92%E8%87%AA%E5%88%86%E3%81%A7%E8%BF%BD%E5%8A%A0%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%82%8C%E3%81%8C%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%B7%E3%82%B9%3C%2FP%3E%3C%2FLINGO-BODY%3E
