RDDRONE-BMS772
RDDRONE-BMS772
iaingalloway
Please ask questions about the RDDRONE-BMS772 board and software here
coryjfowler
Can I get some help with my V 4.0 REV D board and the issue with the NFC chip that causes a full stop of the BMS application?  Last reply to the Github issue was 3 days ago.  I was anticipating a reply this morning, but no such luck.
https://github.com/NXPHoverGames/RDDRONE-BMS772/issues/6
iaingalloway
Hi @coryjfowler
We're actively investigating the issue. We needed to get some of the current build of boards from the warehouse in order to determine what is going on with this latest board build. A workaround will be provided shortly while we determine the root cause. Thank you for your patience.
@cisvmierlo
KarenRdz
Hi!
I have a question, is it posible to use the CLI if the J-link debugger is on the J2 port? Or is there another way to obtain the information on the J2 whitout using the CLI?
Thank you!
cisvmierlo
Hi KarenRdz!
Yes that is possible.
J19 combines the JTAG debugger pins together with the UART pins, the UART pins are needed for the CLI.
There is a DCD-LZ breakout board which lets you connect your JTAG debugger to the JTAG debugger pins (like J2) of that breakout board and separates the UART to FTDI pinout.
This could be connected to J19 of the BMS.
See https://nxp.gitbook.io/hovergames/rddrone-fmuk66/connectors/debug-interface-dcd-lz/dcd-lz-breakout-b... for more detail on the breakout board.
Connector J2 is only a 10 pins JTAG connector, without UART pins.
You could use J2 to program/debug the board and use J19 for the CLI.
As an alternative to that, connector J21 has another UART bus on it.
Since the code is publicly available and it uses the NuttX RTOS, it could easily be changed in using the other UART bus for the CLI.
You could select LPUART0 as serial console in the menuconfig of NuttX (in Device Drivers -> Serial Driver Support -> Serial console).
So then you could use J2 for programming/debugging and J21 for the CLI if you configure it.
anuj
We are working with solar drone which requires a lot of power.
This product seems very nice but i am confused on the maximum rating. We have 6s configuration Lipo battery which is 22 volt, and the motor can require a huge burst current and continuous current(90A for minutes).  I see that the maximum rating for this is 90A DC, Is this value continuous maximum rating or burst maximum rating. What is the burst current and time limit for the burst current. Can you please suggest me which can be better for me this one or the other BMS FRDM33772BSPIEVB.
Hope i get a very fast reply.
cisvmierlo
Hi Anuj,
The FRDM33772BSPIEVB is an evaluation board for the battery cell controller. This is without microcontroller, switches, safety measures and etc.
The RDDRONE-BMS772 is a mobile robotics reference design including microcontroller, power switch, (working and available) example software, hardware overcurrent circuit and more.
For more information about the RDDRONE-BMS772 see: https://nxp.gitbook.io/rddrone-bms772/
For the example software see: https://github.com/NXPHoverGames/RDDRONE-BMS772
The RDDRONE-BMS772 as populated is rated for 60A continues DC current.
With 4 pairs of MOSFETs and 4 heatsinks it is rated at 90A maximum DC current (continues) and this includes the layout and copper used.
On the RDDRONE-BMS772 there is a hardware overcurrent circuit at 545A which will act within 20us.
Which means a peak current of 545A is allowed for 20us without damaging the board.
Higher currents or currents for a longer amount of time might be possible, but has not been tested.
Going over the maximum rated currents or the specified time will be of own risk.
Keep in mind batteries should always be handled with care.
anuj
Due to the chip shortage the PSMNR70-30YLH mosfet is no more available in the market. What to do with that, is there any other mosfet we can use with that model. Please reply me soon as we need this product as soon as possible.
iaingalloway
Yes - sorry to hear that. I also looked, and you are correct, there doesn't seem to be global availability. This is an active and good part, it is just caught up in the global chip shortage.
Here are some (not so great) options:
- Contact Nexperia directly. You only need a few correct? Sometimes there are samples they have on hand.
- Look through Nexperia.com for close alternatives?
- Buy an additional BMS-772 and take the parts off one to add to the other?
iaingalloway
The BMS772 does the self balancing. You will need to control the overall current provided to charge the battery. You should also provide some power steering/isolation otherwise with the two batteries in parallel, the higher charged one will attempt to charge the lower charged one.
Also - what is not clear above - are you making one pack or two separate pluggable packs. You CAN parallel individual cells in one large one (and use a single BMS) if you wish, but that does not seem to be how you have described it. So one BMS per pack is needed.
The BMS is approximately the size of a 3S 4000mA/h hobby LiPo - Sorry i do not have exact dimensions.
Lavern
Thanks for the update and quick reply. I'll be sure to keep an eye on this thread. Looking for the same issue. Bumped into your thread.
alaskasworld.com
Falcon15
Hi there,
we have a drone battery that consists of 2 x 7000mAh 6S lithium polymer batteries. These two packs are going to be connected in parallel to achieve 14000mAh 6S.
What I did is made a housing to incubate the two packs and connected them to a single 10 pin robust male connector and in the UAV size there is a female connector . The plan is to make the drone battery like cartridge so we can slide it in UAV to click in and go on and when battery need recharging we take out the cartridge and connect it to the charger with same pin type used on UAV. The question is are we able to use you BMS 772 to achieve a self balancing cartridge when recharging?
if so how would we do that? Do we need two boards or one only? And how to connect it to the batteries?
and what’s the dimensions of that board please?
best regards
Falcon
%3CLINGO-SUB%20id%3D%22lingo-sub-1093111%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1093111%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EPlease%20ask%20questions%20about%20the%26nbsp%3BRDDRONE-BMS772%20board%20and%20software%20here%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2295106%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2295106%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F258869%22%20target%3D%22_blank%22%3E%40xete%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CP%3EIt%20seems%20that%20the%20IC%20is%20powered%20and%20working.%20%3CBR%20%2F%3EA%204S%20battery%20(both%20LiPo%20or%20LiFePO4)%26nbsp%3B%20is%20indeed%20in%20the%20correct%20supply%20range.%20That%20cannot%20be%20the%20issue.%3CBR%20%2F%3EMaybe%20a%20full%20disconnect%20(battery%2C%20programmer%2C%20serial%20interface)%20could%20help%3F%3C%2FP%3E%0A%3CP%3EIt%20could%20be%20a%20connection%20issue.%26nbsp%3B%3CBR%20%2F%3ECan%20you%20try%20a%20slower%20programming%20speed%3F%26nbsp%3B%3CBR%20%2F%3ELong%20wires%20and%20pin%20converters%20could%20impact%20the%20maximum%20programing%20speed.%3CBR%20%2F%3EYou%20now%20use%201000kHz%2C%20%221000%22%2C%20can%20you%20try%20%22100%22%3F%20100kHz%20programming%20speed%3F%3CBR%20%2F%3E%3CBR%20%2F%3EIf%20you%20would%20be%20able%20to%20upload%20a%20picture%20of%20the%20setup%2C%20that%20might%20show%20an%20issue.%3CBR%20%2F%3E%3CSPAN%3EOr%20provide%20the%20voltages%20on%20these%20programmer%20pins.%3CBR%20%2F%3EIt%20would%20be%20interesting%20to%20know%20if%20the%20MCU%20is%20kept%20in%20reset%20or%20what%20VTref%20is.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EKind%20regards%2C%26nbsp%3B%3C%2FP%3E%0A%3CP%3ECis%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2295098%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2295098%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThank%20you%20for%20the%20quick%20reply.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EI%20was%20powering%20the%20BMS%20with%20a%204S%20battery.%20I%20was%20also%20using%203.3V%20TTL%20to%20USB%20to%20look%20at%20the%20serial%20output.%20The%20BMS%20was%20in%20the%20NORMAL%20state%20based%20on%20the%20LCD%20Screen%20and%20Serial.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EIt%20was%20connected%20to%20a%20J%20Link%20Compact%20Plus%20according%20to%20the%20pinout%20below.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EDo%20let%20me%20know%20if%20you%20require%20any%20other%20info%2Fsuggestions%20for%20troubleshooting%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22xete_0-1768570899050.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xete_0-1768570899050.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xete_0-1768570899050.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xete_0-1768570899050.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xete_0-1768570899050.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xete_0-1768570899050.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xete_0-1768570899050.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xete_0-1768570899050.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xete_0-1768570899050.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xete_0-1768570899050.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F373199i227E45D69D530B2D%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22xete_0-1768570899050.png%22%20alt%3D%22xete_0-1768570899050.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Exete_0-1768570899050.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2295081%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2295081%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F258869%22%20target%3D%22_blank%22%3E%40xete%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CP%3ECould%20you%20explain%20more%20about%20your%20setup%20in%20which%20you%20face%20an%20issue%3F%3CBR%20%2F%3EHow%20did%20you%20power%20the%20RDDRONE-BMS772%3F%3CBR%20%2F%3EWhat%20is%20the%20status%20of%20the%20RGB%20LED%20on%20the%26nbsp%3BRDDRONE-BMS772%3F%3C%2FP%3E%0A%3CP%3EA%20picture%20of%20your%20setup%20would%20be%20helpful%20to%20be%20able%20to%20assist%20you%20in%20your%20problem%20with%20programming.%3C%2FP%3E%0A%3CP%3EKind%20regards%2C%3C%2FP%3E%0A%3CP%3ECis%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2295079%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2295079%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20am%20trying%20to%20flash%20firmware%20on%20to%20the%20BMS.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EHowever%2C%20I%20am%20facing%20this%20error%20when%20attempting%20to%20connect%20via%20SWD.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22xete_0-1768568009515.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xete_0-1768568009515.png%22%20style%3D%22width%3A%20376px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xete_0-1768568009515.png%22%20style%3D%22width%3A%20376px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xete_0-1768568009515.png%22%20style%3D%22width%3A%20376px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xete_0-1768568009515.png%22%20style%3D%22width%3A%20376px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xete_0-1768568009515.png%22%20style%3D%22width%3A%20376px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xete_0-1768568009515.png%22%20style%3D%22width%3A%20376px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xete_0-1768568009515.png%22%20style%3D%22width%3A%20376px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xete_0-1768568009515.png%22%20style%3D%22width%3A%20376px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22xete_0-1768568009515.png%22%20style%3D%22width%3A%20376px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F373194i33943E5395F278C4%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22xete_0-1768568009515.png%22%20alt%3D%22xete_0-1768568009515.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Exete_0-1768568009515.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1833766%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1833766%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EYes%2C%20we%20are%20currently%20testing%20the%20next%20release%20candidate%20of%20the%20open%20source%20BMS772%20reference%20SW%20that%20includes%20DroneCAN%20support.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1833144%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1833144%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EWe%20would%20like%20to%20use%20the%26nbsp%3BRDDRONE-BMS772%20in%20our%20drone%20batteries.%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3EMy%20question%20is%2C%20if%20there%20already%20is%20a%20PX4%20integration%20based%20on%20UAVCAN%3F%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EIs%20there%20any%20work%20which%20we%20can%20pick%20up%3F%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3EThanks%20in%20advance%3CBR%20%2F%3EJan%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1734010%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1734010%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EAfter%20this%20voltage%20drop%20of%20the%20charger%2C%20will%20the%20charger%20stay%20off%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ENo%20at%20this%20point%20the%20charger%20will%20stay%20on.%20So%20it%20would%20restart%20the%20charge%20process%20if%20the%20current%20draw%20stopped.%20In%20the%20future%20we%20will%20implement%20a%20controllable%20charger%20to%20disable%20upon%20full%20charge.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EOr%20will%20it%20have%20a%20lower%20voltage%26nbsp%3Bthan%20your%20battery%20and%20the%20charger%20is%20protected%20against%20sinking%20the%20current%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ENo%20the%20charger%20is%20slightly%20higher%20in%20voltage%20to%20achieve%20full%20charge%20but%20it%20is%20also%20protected%20against%20reverse%20current.%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EWould%20it%20be%20feasible%20to%20increase%20the%20voltage%20level%20in%20which%20the%20BMS%20determines%20the%20charger%20has%20been%20disconnected%3F%20This%20way%20it%20may%20prevent%20the%20brown%20out%20of%20the%20computer.%20Then%20it%20would%20go%20back%20into%20charge%20state%20and%20protect%20itself%20from%20overcharging.%3C%2FP%3E%3CP%3EI%20will%20also%20intergrade%20a%20UPS%20as%20an%20alternative%20solution%20to%20the%20problem.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThanks%20for%20your%20help%20%3CLI-EMOJI%20id%3D%22lia_slightly-smiling-face%22%20title%3D%22%3Aslightly_smiling_face%3A%22%3E%3C%2FLI-EMOJI%3E%26nbsp%3B%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1733969%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1733969%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20All%2C%3C%2FP%3E%3CP%3EI%20am%20wondering%20is%20there%20anyway%20to%20read%20the%20type%20of%20fault%20code%20from%20the%20CLI%3F%20I%20can%20read%20the%20state%20(bms%20get%20state%20%3D%26gt%3B%20FAULT)%20but%20is%20there%20a%20way%20to%20receive%20the%20type%20of%20fault%20e.g.%20over%20voltage%3F%3C%2FP%3E%3CP%3EIf%20not%20do%20you%20have%20some%20guidance%20on%20the%20best%20way%20to%20implement%20that%20in%20the%20firmware%3F%26nbsp%3B%3C%2FP%3E%3CP%3EThanks%20for%20your%20help%2C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ELewis%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1732104%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1732104%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Lewis%2C%3C%2FP%3E%0A%3CP%3EFrom%20reading%20your%20story%20I'm%20assuming%20the%20BMS%20is%20in%20the%20charge-complete%20state.%20With%20the%20power%20disabled%20to%20stop%20the%20battery%20from%20overcharging.%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3EWhen%20your%20system%20draws%20more%20current%20than%20the%20still%20attached%20battery%20charger%20can%20provide%2C%20the%20voltage%20will%20drop.%26nbsp%3B%3C%2FP%3E%0A%3CP%3EIn%20the%20charge-complete%20state%2C%20there%20will%20not%20be%20a%20current%20flowing%20from%20the%20battery%2C%20as%20the%20power%20switch%20is%20open.%20The%20BMS%20will%20check%20the%20output%20voltage%20too%20see%20if%20the%20charger%20is%20disconnected.%26nbsp%3B%3CBR%20%2F%3EWhen%20the%20charger%20has%20this%20voltage%20drop%20and%20this%20drop%20is%20low%20enough%20for%20the%20BMS%20to%20think%20the%20charger%20is%20disconnected%2C%20it%20will%20go%20the%20SLEEP%20state%2C%20but%20it%20will%20first%20set%20the%20MCU%20in%20very%20low%20power%20run%20(VLPR)%20mode%20and%20other%20peripherals%20in%20lower%20power%20modes%20as%20well%20before%20closing%20the%20power%20switch.%3CBR%20%2F%3E%3CBR%20%2F%3EAfter%20this%20voltage%20drop%20of%20the%20charger%2C%20will%20the%20charger%20stay%20off%3F%20%3CBR%20%2F%3EOr%20will%20it%20have%20a%20lower%20volage%20than%20your%20battery%20and%20the%20charger%20is%20protected%20against%20sinking%20the%20current%3F%3CBR%20%2F%3E%3CBR%20%2F%3EKind%20regards%2C%3C%2FP%3E%0A%3CP%3ECis%20van%20Mierlo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1731794%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1731794%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThank%20you%20for%20your%20reply%26nbsp%3B%3CSPAN%3ECis%20van%20Mierlo%2C%20that%20was%20very%20helpful.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EI%20was%20able%20to%20get%20the%20functionality%20I%20needed%20by%20using%20an%20N-Channel%2C%20P-Channel%20Mosfet%20with%20and%20RC%20timer%20to%20momentarily%20pull%20the%20wake%20pin%20low%20if%20a%20charger%20voltage%20is%20connected.%26nbsp%3B%3C%2FP%3E%3CP%3EAnother%20thing%20I%20am%20looking%20into%20is%20the%20time%20it%20takes%20for%20the%20BMS%20to%20wake%20from%20sleep%20state%20due%20to%20over%20current%20detection%20(i-sleep-oc).%20The%20issue%20I%20am%20facing%20that%20after%20a%20full%20charge%20the%20BMS%20output%20will%20be%20disabled%20to%20stop%20overcharging%2C%20if%20our%20robot%20then%20draws%20more%20current%20then%20the%20charger%20can%20supply%20the%20BMS%20will%20detect%20this%20and%20enable%20the%20output.%20However%20attaching%20the%20scope%20I%20have%20measured%20a%20switch%20time%20of%20the%20BMS%20of%20about%20300-800ms.%20This%20delay%20is%20a%20problem%20as%20it%20causes%20a%20brown%20out%20for%20the%20raspberry%20pi.%26nbsp%3B%3C%2FP%3E%3CP%3EI%20am%20wondering%20if%20there%20is%20a%20way%20to%20reduce%20this%20time%3F%20Maybe%20by%20updating%20the%20frequency%20it%20checks%20the%20output%20current%20to%20wake%3F%20If%20I%20can%20reduce%20the%20time%20I%20can%20the%20look%20into%20smoothing%20the%20voltage%20drop.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThanks%20again%20for%20your%20help.%3C%2FP%3E%3CP%3ELewis.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1730178%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1730178%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Lewis%2C%3C%2FP%3E%0A%3CP%3EIndeed%2C%20the%20BMS%20goes%20to%20deep%20sleep%20to%20preserve%20any%20charge%20left%20in%20the%20battery.%20Meaning%20that%20this%20will%20be%20the%20lowest%20power%20mode%20(%C2%B1100uA).%26nbsp%3B%3CBR%20%2F%3EThe%20only%20way%20that%20this%20is%20feasible%2C%20is%20to%20turn%20off%20the%20VCC_3V3_SBC%2C%20which%20is%20used%20to%20power%20the%20MCU.%3CBR%20%2F%3EMeaning%20that%20the%20MCU%20will%20be%20off.%20So%2C%20setting%20an%20interrupt%20won't%20help%20with%20waking%20up%20from%20this%20mode.%3CBR%20%2F%3E%3CBR%20%2F%3EThe%20only%20to%20wake%20up%20from%20this%20is%20mode%20is%20to%20either%20re-apply%20a%20voltage%20to%20the%20BMS%20or%20to%20pull%20down%20the%20SBC's%20(U3)%20wake%20pin%20(pin%2012).%3CBR%20%2F%3E%3CBR%20%2F%3EMaybe%20use%20J22%20to%20pull%20down%20the%20wake%20pin%20(keep%20in%20mind%20that%20the%20voltage%20on%20this%20connector%20is%20between%20the%20battery%20voltage%20and%200V).%20For%20example%2C%20you%20could%20use%20an%20external%20switch%20or%20signal%20controlled%20from%20your%20other%20system%20to%20pull%20this%20low.%3CBR%20%2F%3E%3CBR%20%2F%3EAnother%20solution%20would%20be%20to%20send%20the%20%22bms%20reset%22%20command%20over%20de%20CLI%20(UART)%20when%20you%20receive%20the%20undervoltage%20fault%20and%20the%20BMS%20is%20counting%20down%20before%20going%20into%20the%20deep%20sleep%20mode.%20This%20will%20reset%20the%20timer.%3CBR%20%2F%3E%3CBR%20%2F%3EYou%20could%20also%20reconfigure%20the%20timeout%20time%20for%20the%20BMS%20to%20go%20to%20deep%20sleep%20and%20even%20disable%20it.%3CBR%20%2F%3ETo%20do%20this%2C%20see%20t-fault-timeout%20in%20chapter%208.2.2%20(page%2018)%20in%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2Fblob%2Fmain%2FBMS772_releaseNotes_5.0.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2Fblob%2Fmain%2FBMS772_releaseNotes_5.0.pdf%3C%2FA%3E%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3EHopefully%20this%20will%20help%2C%20kind%20regards%2C%3CBR%20%2F%3E%3CBR%20%2F%3ECis%20van%20Mierlo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1730153%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1730153%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20All%2C%3C%2FP%3E%3CP%3EWe%20are%20facing%20an%20issue%20with%20the%20integration%20of%20the%20NXP%20BMS%20into%20our%20ROV%20system%20and%20hoping%20for%20some%20guidance%20on%20the%20changes%20I%20should%20make%20to%20the%20firmware%20to%20resolve%20the%20issue.%3C%2FP%3E%3CP%3EThe%20problem%20is%20we%20occasionally%20will%20deplete%20a%20battery%20during%20an%20ROV%20flight%20underwater%2C%20and%20the%20vehicle%20becomes%20unrecoverable%20as%20the%20BMS%20will%20go%20into%20deep%20sleep.%20Following%20an%20under%20voltage%20fault%20the%20BMS%20will%20enter%20deep%20sleep%20to%20reduce%20any%20further%20draw%20on%20the%20battery%2C%20part%20of%20this%20means%20turning%20off%20the%20UART%20communications.%20If%20we%20apply%20voltage%20to%20the%20BMS%20it%20will%20remain%20in%20deep%20sleep%20until%20the%20physical%20reset%20button%20is%20pushed.%20The%20issue%20is%20that%20the%20robot%20is%20deployed%20under%20the%20water%2C%20so%20physically%20pushing%20the%20button%20won't%20work%20and%20we%20aren't%20able%20to%20communicate%20via%20UART%20as%20it%20has%20gone%20into%20deep%20sleep.%3C%2FP%3E%3CP%3ESo%20I%20am%20seeking%20any%20advice%20on%20how%20I%20might%20be%20able%20to%20overcome%20this%20problem.%20The%20goal%20would%20be%20to%20still%20have%20the%20BMS%20enter%20deep%20sleep%20mode%20to%20prevent%20further%20discharge%20of%20the%20battery%20however%20to%20be%20able%20to%20wake%20the%20battery%20via%20a%20UART%20command%20or%20if%20charge%20voltage%20is%20detected.%3C%2FP%3E%3CP%3EI%20was%20thinking%20I%20could%20attach%20an%20interrupt%20to%20the%20UART%20RX%20pin%20before%20entering%20deep%20sleep%2C%20which%20will%20reset%20the%20fault%20during%20wake%20up.%20Is%20this%20a%20feasible%20solution%20and%20if%20so%20is%20it%20possible%20for%20you%20to%20point%20me%20in%20the%20direction%20of%20the%20firmware%20I%20could%20do%20this%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThank%20you%20for%20your%20help%2C%3C%2FP%3E%3CP%3ELewis%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1730004%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1730004%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThank%20you%20that%20solution%20worked%20well%20for%20us.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1702673%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1702673%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F212097%22%20target%3D%22_blank%22%3E%40lmiles-sosub%3C%2FA%3E%2C%3C%2FP%3E%3CP%3EThe%20purpose%20of%20the%20gate%20check%20is%20to%20make%20sure%20the%20gate%20driver%20is%20able%20to%20turn%20off%20the%20power.%20It%20there%20would%20be%20something%20wrong%20with%20this%20or%20other%20components%20and%20it%20is%20not%20able%20to%20turn%20off%20the%20power%2C%20this%20could%20result%20in%20a%20safety%20issue%2C%20hence%20the%20self-test.%26nbsp%3B%3C%2FP%3E%3CP%3EI%20get%20that%20for%20your%20purpose%2C%20this%20is%20not%20ideal.%20Feel%20free%20to%20disable%20this%20check%20in%20your%20software%20for%20your%20purpose%20if%20you%20think%20this%20is%20safe.%3C%2FP%3E%3CP%3EKeep%20in%20mind%20that%20it%20will%20not%20check%20if%20the%20power%20can%20be%20switched%20off.%3C%2FP%3E%3CP%3EPlus%20I%20would%20advise%20you%20to%20still%20turn%20off%20the%20power%20in%20that%20part%20of%20the%20code%2C%20you%20could%20either%20replace%20the%20part%20with%20the%20below%20piece%20of%20code%20or%20add%20compile%20switches%20(%23ifdef%20%23else%20%23endif)%20so%20you%20could%20easily%20go%20back%20to%20the%20original%20state.%3C%2FP%3E%3CP%3EThis%20part%20needs%20to%20be%20replaced%20or%20put%20in%20an%20compile%20switch%3A%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2Fblob%2Fmain%2Fsrc%2FbatManagement.c%23L608-L672%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2Fblob%2Fmain%2Fsrc%2FbatManagement.c%23L608-L672%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3EThis%20is%20the%20piece%20of%20code%20I%20would%20advice%20you%20to%20still%20add%3A%3C%2FP%3E%3CP%3E%2F%2F%20still%20turn%20off%20the%20gate%3CBR%20%2F%3EbatManagement_setGatePower(GATE_OPEN)%3B%3C%2FP%3E%3CP%3Ecli_printfWarning(%22SELF-TEST%20GATE%3A%20TURNED%20OFF!%5Cn%22)%3B%3C%2FP%3E%3CP%3EI%20hope%20this%20answers%20your%20question%2C%20kind%20regards%2C%3C%2FP%3E%3CP%3ECis%20van%20Mierlo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1702511%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1702511%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20All%2C%3C%2FP%3E%3CP%3EWe%20are%20testing%20the%20use%20of%20the%20BMS%20in%20an%20ROV%20system%20with%20a%20charger%20that%20constantly%20supplies%20power%20to%20the%20ROV%20and%20the%20battery%20will%20provide%20power%20for%20peak%20loads%20above%20the%20chargers%20power%20capacity.%26nbsp%3B%3C%2FP%3E%3CP%3EWe%20are%20having%20some%20issues%20when%20the%20battery%20reaches%20its%20under%20voltage%20protection%20(enters%20fault%20mode)%20and%20are%20trying%20to%20recover%20the%20BMS%20from%20fault%20state%20to%20be%20able%20to%20charge%20the%20battery.%26nbsp%3B%3C%2FP%3E%3CP%3EIdeally%20the%20BMS%20would%20shut%20off%20output%20but%20would%20still%20allow%20a%20charge%20current%20to%20enter%20the%20battery%2C%20without%20needing%20to%20be%20reset.%20Currently%20we%20are%20resetting%20the%20BMS%20remotely%20through%20the%20CLI%20to%20remove%20the%20fault%20however%20to%20power%20the%20system%20we%20must%20have%20the%20charger%20on%2C%20which%20then%20results%20in%20the%20self%20test%20failing%20and%20suggesting%20to%20remove%20the%20charger.%3C%2FP%3E%3CP%3EMy%20question%20is%20around%20the%20functionality%20of%20the%20charger%20having%20to%20be%20disconnected%20for%20the%20gate%20self%20test.%20What%20is%20the%20purpose%20of%20it%20and%20would%20there%20be%20a%20critical%20issue%20if%20I%20were%20to%20disable%20it%20in%20the%20firmware%3F%3C%2FP%3E%3CP%3EThanks%20for%20your%20help.%3C%2FP%3E%3CP%3ELewis%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1686646%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1686646%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F214383%22%20target%3D%22_blank%22%3E%40suvasis%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%3CP%3EThe%20.brd%20layout%20file%20of%20the%20RDDRONE-BMS772%20has%20been%20added%20to%20the%20design%20files%20and%20could%20be%20downloaded.%3C%2FP%3E%3CP%3EPlease%20see%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesigns%2Fsmart-battery-management-for-mobile-robotics%3ARDDRONE-BMS772%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesigns%2Fsmart-battery-management-for-mobile-robotics%3ARDDRONE-BMS772%3C%2FA%3E%3C%2FP%3E%3CP%3EKind%20regards%2C%3C%2FP%3E%3CP%3ECis%20van%20Mierlo%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1679245%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1679245%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%3C%2FA%3E%2C%3C%2FP%3E%3CP%3EI%20tried%20rebooting%20and%20re%20powering%20the%20BMS%20it%20didn't%20help.%20I%20will%20try%20going%20into%20DEEP_SLEEP.%3C%2FP%3E%3CP%3EThanks%20for%20your%20help.%3C%2FP%3E%3CP%3ERegards%2C%3C%2FP%3E%3CP%3EPrince%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1673640%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1673640%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F195015%22%20target%3D%22_blank%22%3E%40Prince1%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EHave%20you%20tried%20rebooting%20the%20MCU%20with%20the%20%22reboot%22%20command%3F%3C%2FP%3E%0A%3CP%3EAnother%20thing%20you%20could%20try%20to%20reset%20the%20communication%20errors%20(as%20they%20are%20remembered)%20go%20to%20DEEP_SLEEP%20and%20back%20to%20NORMAL%20state%3F%3CBR%20%2F%3E%3CBR%20%2F%3EOtherwise%20you%20could%20try%20to%20re-power%20the%20BMS%20power%20to%20solve%20the%20problem.%3CBR%20%2F%3E%3CBR%20%2F%3EKind%20regards%2C%3C%2FP%3E%0A%3CP%3ECis%20van%20Mierlo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1673634%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1673634%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F214383%22%20target%3D%22_blank%22%3E%40suvasis%3C%2FA%3E%2C%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3EI've%20asked%20the%20team%20if%20they%20could%20upload%20the%20board%20file%20(.brd)%20as%20well%20to%20nxp.com.%3CBR%20%2F%3EBe%20aware%20that%20this%20could%20take%20a%20couple%20days.%3C%2FP%3E%3CP%3EThe%20schematic%20file%20(.DSN)%20is%20already%20included.%3C%2FP%3E%3CP%3EKind%20regards%2C%3C%2FP%3E%3CP%3ECis%20van%20Mierlo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1673616%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1673616%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3ETera%20term%20is%20throwing%20few%20errors%20when%20connected%20with%20BMS%20as%20shown%20in%20images%20attached%20herewith.%3C%2FP%3E%3CP%3E%22Couldn't%20do%20measurements%20and%20also%20Failed%20to%20update%20measurements%22%3C%2FP%3E%3CP%3EPlease%20help%20in%20resolving%20them%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThanks%2C%3C%2FP%3E%3CP%3EPrince%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1672228%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1672228%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ehi%2C%3C%2FP%3E%3CP%3EI%20am%20trying%20to%20redesign%20the%20PCB%20to%20a%20smaller%20form%20factor%20for%20my%20drone.%20The%20following%20document%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesigns%2Fsmart-battery-management-for-mobile-robotics%3ARDDRONE-BMS772%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesigns%2Fsmart-battery-management-for-mobile-robotics%3ARDDRONE-BMS772%3C%2FA%3E%3C%2FP%3E%3CP%3Egenerally%20provides%20schematic%20and%20fabrication%20files%20but%20t%3CSPAN%3Ehose%20link%20does%20not%20contain%20the%20source%20file%20of%20the%20PCB.%20can%20anyone%20include%20the%20source%20file%20for%20the%20PCB%3F%3C%2FSPAN%3E%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3ECan%20anyone%20help%20me%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3Ethanks.%3C%2FP%3E%3CP%3Esuvasis%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1631017%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1631017%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F213615%22%20target%3D%22_blank%22%3E%40dmorvay%3C%2FA%3E%2C%3C%2FP%3E%3CP%3EI%20think%20it%20would%20be%20possible%20to%20multiplex%20the%20I2CS%20to%20the%26nbsp%3B%3CSPAN%3EPTA2%2FPTA3%20pins.%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%3EI%20would%20check%20the%20S32K-RM%20chapter%2052%3A%26nbsp%3BLow%20Power%20Inter-Integrated%20Circuit%20(LPI2C)%20for%20this.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EBut%20then%20you%20need%20to%20make%20the%20correct%20changes%20in%20the%20code%2C%20I%20do%20not%20know%20if%20the%20SDK%20supports%20this.%3CBR%20%2F%3E%3CBR%20%2F%3EKind%20regards%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ECis%20van%20Mierlo%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1630511%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1630511%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F213615%22%20target%3D%22_blank%22%3E%40dmorvay%3C%2FA%3E%2C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ERegarding%20the%20second%20question%2C%20the%20MBD%20Toolbox%20for%20S32K14x%20is%20built%20on%20top%20of%20the%20SDK%20for%20S32k14x.%20Unfortunately%2C%20it%20seems%20that%20the%204-wire%20mode%20is%20not%20supported%20for%20LPI2C%20by%20the%20SDK%2C%20therefore%20MBD%20toolbox%20doesn't%20support%20it%20either.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EBest%20regards%2C%3C%2FP%3E%3CP%3EBancila%20Sorin%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1629818%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1629818%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%3CP%3EThank%20you%20for%20this%20information.%20I%20am%20still%20unsure%20about%20the%20answer%20to%20my%20first%20question%20-%20Can%20PTA2%2FPTA3%20(J23)%20be%20configured%20as%20an%20I2C%20slave%3F%20Are%20there%20any%20limitations%20on%20this%20I%2FO%20that%20it%20always%20has%20to%20be%20configured%20as%20a%20master%3F%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1629793%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1629793%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F213615%22%20target%3D%22_blank%22%3E%40dmorvay%3C%2FA%3E%2C%26nbsp%3B%3C%2FP%3E%0A%3CP%3EI'm%20not%20familiar%20with%20the%20MBDT%20example%20and%20what%20is%20supported%20in%20that%20toolbox.%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EFor%20a%20C%20%2F%20C%2B%2B%20example%20I%20would%20advise%20you%20to%20take%20a%20look%20into%20the%20NuttX%20RTOS%20SW%20example.%3CBR%20%2F%3EIn%20this%20example%20you%20can%20get%20the%20BMS%20data%20via%20I2C%20by%20reading%20the%20correct%20I2C%20addresses%20as%20stated%20in%20Table%206.%20SMBus%20variable%20list%20(Of%20chapter%207.5%20How%20to%20use%20SMBus).%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EThis%20example%20is%20located%20here%3A%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%3C%2FA%3E%26nbsp%3B%3CBR%20%2F%3EIt%20will%20need%20the%20NuttX%20RTOS%20sources%20as%20well%3A%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fapache%2Fnuttx%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fapache%2Fnuttx%3C%2FA%3E%26nbsp%3B%3CBR%20%2F%3ESee%20the%20RDDRONE-BMS772%20board%20in%20the%20NuttX%20repository%3A%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fapache%2Fnuttx%2Ftree%2Fmaster%2Fboards%2Farm%2Fs32k1xx%2Frddrone-bms772%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fapache%2Fnuttx%2Ftree%2Fmaster%2Fboards%2Farm%2Fs32k1xx%2Frddrone-bms772%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EAnd%20the%20S32K1xx%20architecture%20specific%20logic%3A%26nbsp%3B%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fapache%2Fnuttx%2Ftree%2Fmaster%2Farch%2Farm%2Fsrc%2Fs32k1xx%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fapache%2Fnuttx%2Ftree%2Fmaster%2Farch%2Farm%2Fsrc%2Fs32k1xx%3C%2FA%3E%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3EI%20hope%20this%20helps%20you!%3CBR%20%2F%3E%3CBR%20%2F%3EKind%20regards%2C%3C%2FP%3E%0A%3CP%3ECis%20van%20Mierlo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1629762%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1629762%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3ETwo%20more%20questions%20based%20on%20your%20answer...%3C%2FP%3E%3CP%3E1.%20Can%20PTA2%20and%20PTA3%20(connector%20J23)%20be%20configured%20as%20an%20I2C%20slave%3F%20On%20the%20software%20side%2C%20it%20seems%20to%20be%20possible%2C%20but%20want%20to%20make%20sure%20everything%20checks%20out%20in%20both%20hardware%20and%20software.%3C%2FP%3E%3CP%3E2.%20How%20do%20you%20configure%26nbsp%3B%3CSPAN%3ELPI2C0_SCL%3C%2FSPAN%3E%3CSTRONG%3ES%20%3C%2FSTRONG%3E%3CSPAN%3Eand%20LPI2C0_SDA%3C%2FSPAN%3E%3CSTRONG%3ES%3F%26nbsp%3B%3C%2FSTRONG%3EDo%20you%20have%20any%20references%20on%20how%20to%20configure%20this%20in%20C%20code%20and%2For%20through%20Model%20Based%20Development%3F%20I%20am%20currently%20using%20Model%20Based%20Development%2C%20but%20I%20do%20not%20see%20any%20peripherals%20with%26nbsp%3B%3CSPAN%3ELPI2C0_SCL%3C%2FSPAN%3E%3CSTRONG%3ES%20%3C%2FSTRONG%3E%3CSPAN%3Eand%20LPI2C0_SDA%3C%2FSPAN%3E%3CSTRONG%3ES.%26nbsp%3B%3C%2FSTRONG%3EAdditionally%2C%20the%20I2C%20configuration%20block%20only%20has%20the%20options%20for%20PTA2%2FPTA3%20or%20PTB6%2FPTB7.%20I%20am%20not%20exactly%20sure%20how%20to%20activate%20this%20output.%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1629540%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1629540%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F213615%22%20target%3D%22_blank%22%3E%40dmorvay%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%3CP%3EThe%20connector%20J18%20can%20be%20used%20for%20SMBUS%20%2F%20I2C%3CSTRONG%3ES%3C%2FSTRONG%3E.%26nbsp%3B%3CBR%20%2F%3EThe%26nbsp%3BSMBUS_SCL%20and%26nbsp%3BSMBUS_SDA%20lines%20are%20connected%20to%20this%20connector.%3C%2FP%3E%3CP%3EThese%20lines%20are%20connector%20to%20PTA0%20and%20PTA1%2C%20which%20support%20the%26nbsp%3BLPI2C0_SCL%3CSTRONG%3ES%20%3C%2FSTRONG%3Eand%26nbsp%3B%2FLPI2C0_SDA%3CSTRONG%3ES%20%3C%2FSTRONG%3Eperipheral.%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EKind%20regards%2C%3C%2FP%3E%3CP%3ECis%20van%20Mierlo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1629440%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1629440%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3EAnother%20question%20regarding%20I2C%20communication%3A%20when%20configuring%20the%20BMS772%20as%20a%20slave%2C%20should%20the%20pins%20for%20SDA%2FSCL%20be%20PTB6%20and%20PTB7%20respectively%20or%20PTA2%20and%20PTA3%20respectively%3F%20Looking%20at%20the%20schematics%2C%20it%20seems%20like%20it%20is%20actually%20neither%20of%20these%20two%20options%2C%20but%20instead%20PTA0%20and%20PTA1.%20Hence%2C%20I%20am%20slightly%20confused%20on%20how%20to%20setup%20the%20board%20as%20a%20slave%20for%20I2C%20communication.%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1624966%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1624966%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%3CP%3EThe%20PSMNR70-30YLH%20MOSFETS%20that%20are%20recommended%20by%20NXP%20documentation%20unfortunately%20are%20not%20available%20to%20buy%20in%20the%20sites%20I%20tried.%20This%20is%20an%20issue%20because%20I%20can%20not%20test%20with%20safety%20the%20board.%26nbsp%3B%20I%20read%20in%20this%20community%20I%20can%20find%20it%20in%20Nexperia%20but%20the%20minimun%20quantity%20to%20order%20is%201500.%20I%20tried%20to%20look%20for%20another%20equivalent%20one%20but%20I%20cannot%20find%20it%20with%20the%20same%20characteristics.%20I%20don't%20know%20the%20tolerance%20or%20how%20much%20the%20MOSFET%20can%20differ.%3C%2FP%3E%3CP%3EThe%20MOSFET%26nbsp%3Bcharacteristics%20recommended%20by%20NXP%20are%20below.%20What%20other%20characteristics%20are%20tolerated%20or%20what%20other%20suitable%20characteristics%20can%20you%20recommend%2C%20please%3F%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%3EN-channel%2030%20V%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E0.82%20m%CE%A9%2C%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E300%20A%20logic%20level%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EMOSFET%20in%20LFPAK56%20using%20NextPowerS3%20technology%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThank%20you%20very%20much%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1624947%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1624947%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThank%20you%20so%20much%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%3C%2FA%3E%26nbsp%3B.%20I%20think%20there%20was%20an%20issue%20with%20the%20reset%20signal.%20Now%20it's%20working%2C%20so%20thank%20you!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1623162%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1623162%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F212364%22%20target%3D%22_blank%22%3E%40DaveNXP%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CP%3EDo%20you%20have%20access%20to%20an%20oscilloscope%3F%20And%20could%20you%20measure%20the%20if%20there%20are%20pulses%20on%20the%20MCU%20reset%20line%3F%3C%2FP%3E%0A%3CP%3EKind%20regards%2C%3C%2FP%3E%0A%3CP%3ECis%20van%20Mierlo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1623057%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1623057%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThank%20you%20for%20your%20answer%2C%3C%2FP%3E%3CP%3EI%20already%20tried%20with%20the%20J2%20connector(it%20is%20placed)%20thought%20JTAG%20lines%2C%20with%20the%20reset%20jumper%20and%20without%20it.%20And%20I%20still%20cannot%20connect%20to%20the%20target.%3C%2FP%3E%3CP%3EWhat%20could%20I%20do%3F%20How%20could%20I%20check%20the%20Reset%20line%20is%20properly%20connected%20and%20the%20signal%20is%20ok.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThank%20you%20very%20much%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1623027%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1623027%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F212364%22%20target%3D%22_blank%22%3E%40DaveNXP%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%3CP%3ECould%20you%20check%20de%20reset%20line%20of%20the%20debugger%3F%20If%20it%20is%20correctly%20connected%20to%20the%20MCU%3F%3C%2FP%3E%3CP%3EOr%20if%20J2%20is%20placed%2C%20maybe%20use%20this%202x5%20connector%20to%20program%20the%20board%20via%20that%20programming%20header%3F%3CBR%20%2F%3EIf%20J2%20is%20not%20placed%2C%20maybe%20you%20could%20solder%20a%202x5%20pin%20header%20in%20to%20program%20the%20board%20via%20that%20route.%3C%2FP%3E%3CP%3EKind%20regards%2C%3C%2FP%3E%3CP%3ECis%20van%20Mierlo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1622556%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1622556%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDoes%20anybody%20know%20how%20to%20factory%20reset%20the%20RDDRONE%20BMS%20board(or%20awaken%20it)%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThe%20board%20may%20be%20in%20deep%20sleep%20or%20in%20a%20state%20I%20cannot%20get%20it%20out.%3C%2FP%3E%3CP%3EAt%20first%20I%20could%20connect%20to%20the%20core%20(Cortex-M4%20identified)%20but%20after%20this%2C%20when%20I%20tried%20to%20flash%20the%20firmware%2C%20I%20cannot%20connect%20to%20the%20target%20anymore(log%20copied%20in%20previous%20post).%20So%20I%20cannot%20send%20any%20command%20with%20J-Link%20Commander.%20The%20voltage%20of%20the%20J-Link%20debugger%20is%203.3V.%20I%20pressed%20the%20physical%20button%20while%20board%20powered%20but%20nothing%20changed%20and%20it%20does%20not%20wake%20up.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThis%20happened%20to%20the%20two%20RDDRONE%20boards%20I%20bought.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EPlease%2C%20any%20help%20would%20be%20really%20appreciated.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThank%20you!%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%3C%2FA%3E%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F15914%22%20target%3D%22_blank%22%3E%40iaingalloway%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1620687%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1620687%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%20thank%20you%20for%20your%20answer.%3C%2FP%3E%3CP%3EI%20tried%20pushing%20the%20SW1%20button.%20I%20tried%20with%20the%20reset%20jumper%20and%20without%20it.%3C%2FP%3E%3CP%3EI%20tried%20generating%20a%20reset%20pulse%20with%20a%20signal%20generator%20following%20the%20electrical%20specifications%20in%20the%20s32k1xx%20datasheet.%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fdata-sheet%2FS32K-DS.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fdata-sheet%2FS32K-DS.pdf%3C%2FA%3E%3C%2FP%3E%3CP%3EI%20checked%20all%20the%20voltages.%3C%2FP%3E%3CP%3EIf%20I%20connect%20the%20FTDI%20cable%20some%20garbage%20slash%20noise%20appears%20in%20the%20Tera%20Term%20console%20when%20I%20turn%20on%20and%20off%20the%20switch%20power%20supply.%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1620180%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1620180%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EWhen%20you%20use%20JLINK%20software%20and%20a%20debugger%20to%20connect%20to%20the%20BMS%2C%20one%20of%20the%20first%20things%20JLINK.exe%20prints%20out%20is%20the%20voltage%20on%20the%20MCU%2Fdebug%20port.%3C%2FP%3E%3CP%3EIt's%20possible%20that%20even%20with%20external%20power%2022v%20or%20whatever%2C%20coming%20in%20to%20the%20BMS%20board%2C%20that%20the%20actual%20power%20supply%20feeding%20the%20MCU%20is%20not%20turned%20on.%3C%2FP%3E%3CP%3EThere%20is%20a%20tiny%20physical%20button%20on%20the%20BMS%20which%20may%20wake%20up%20the%20MCU%20power%20supply.%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fnxp.gitbook.io%2Frddrone-bms772%2Fuser-guide%2Fgetting-to-know-the-hardware%2Fboard-organization%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fnxp.gitbook.io%2Frddrone-bms772%2Fuser-guide%2Fgetting-to-know-the-hardware%2Fboard-organization%3C%2FA%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1619705%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1619705%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Cis%20van%20Mierlo%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThe%20debugger%20provides%203%2C3V.%20And%20the%20output%20of%20the%20power%20supply%20connected%20to%20the%20RDDRONE%20board%20input%20is%2022%2C2V.%20I%20do%20not%20understand%20very%20well%20what%20the%20problem%20may%20be%20and%20what%20changes%20and%20tests%20I%20should%20do.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EI%20don't%20know%20any%20button%20to%20press%20or%20way%20to%20start%20it%20up%20again.%20I%20would%20really%20appreciate%20any%20help%20for%20this.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThank%20you.%20Kind%20regards.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1619239%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1619239%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F212364%22%20target%3D%22_blank%22%3E%40DaveNXP%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3ECould%20you%20check%20if%20the%20voltage%20is%20OK%20according%20to%20the%20debugger%3F%3CBR%20%2F%3EMaybe%20the%20SW%20put%20the%20system%20in%20deep%20sleep%20and%20a%20button%20press%20is%20needed%20to%20start%20it%20up%20again.%3C%2FP%3E%0A%3CP%3EKind%20regards%2C%3C%2FP%3E%0A%3CP%3ECis%20van%20Mierlo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1619209%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1619209%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThanks%20for%20the%20answer%20cisvmierlo%2C%3C%2FP%3E%3CP%3EThe%20thing%20is%20that%20at%20first%20I%20could%20correctly%20connect%20to%20the%20the%20core%20on%20the%20RDDRONE-BMS772%20board%2C%20but%20after%20this%20first%20flash%20I%20cannot%20connect%20to%20core%20on%20the%20board%20anymore.%20So%2C%20I%20cannot%20send%20this%20'h'%20command%20you%20recommend.%3C%2FP%3E%3CP%3EDo%20you%20have%20any%20other%20ideas%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1619170%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1619170%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F212364%22%20target%3D%22_blank%22%3E%40DaveNXP%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%3CP%3EIt%20seems%20that%20you%20can%20connect%20to%20the%20core%2C%20but%20not%20erase%20nor%20flash%20it.%3C%2FP%3E%3CP%3ECould%20you%20try%20to%20restart%20the%20J-Link%20commander%20and%20halt%20the%20core%20with%20the%20'h'%20command%3F%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3EKind%20regards%2C%3C%2FP%3E%3CP%3ECis%20van%20Mierlo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1619116%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1619116%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EI%20have%20a%20problem%20with%20the%20RDDRONE-BMS772%20board.%3C%2FP%3E%3CP%3EI%20soldered%20the%20hardware%20%22configuration%20pads%22%20as%20recommended%20in%20the%20RDDRONE-BMS772%20manual%20for%20a%206s%20battery.%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fnxp.gitbook.io%2Frddrone-bms772%2Fuser-guide%2Fgetting-started-with-the-rddrone-bms772%2Fconfiguring-the-hardware%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fnxp.gitbook.io%2Frddrone-bms772%2Fuser-guide%2Fgetting-started-with-the-rddrone-bms772%2Fconfiguring-the-hardware%3C%2FA%3E%3C%2FP%3E%3CP%3EThen%2C%20I%20connected%20the%20RDDRONE-BMS772%20board%20to%20a%2022.2V%20power%20supply%20for%20the%20first%20time%2C%20the%20onboard%20LED%20turned%20on.%3C%2FP%3E%3CP%3EI%20followed%20the%20steps%20in%20this%20guide%20from%20the%20%22NXP%20Gitbook%22%3A%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fnxp.gitbook.io%2Fnxpmobilerobotics%2Fflashing-guide%2Fflashing-hovergames-boards%2Fwindows%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fnxp.gitbook.io%2Fnxpmobilerobotics%2Fflashing-guide%2Fflashing-hovergames-boards%2Fwindows%3C%2FA%3E%3C%2FP%3E%3CP%3Ebut%20after%20trying%20to%20flash%20the%20firmware%20bin%20file%20downloaded%20from%20the%20official%20github%3A%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%3C%2FA%3E%3C%2FP%3E%3CP%3Ewith%20the%20recommended%20%3CSPAN%3EJ-LINK%26nbsp%3B%3C%2FSPAN%3E%26nbsp%3Bdebugger%20and%20I%20connected%20the%20cables%20as%20seen%20here%3A%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fnxp.gitbook.io%2Fhovergames%2Frddrone-fmuk66%2Fconnectors%2Fdebug-interface-dcd-lz%2Fdcd-lz-breakout-board%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fnxp.gitbook.io%2Fhovergames%2Frddrone-fmuk66%2Fconnectors%2Fdebug-interface-dcd-lz%2Fdcd-lz-breakout-board%3C%2FA%3E%3C%2FP%3E%3CP%3EThe%20flash%20failed%20(log%20below)%2C%20and%20I%20cannot%20connect%20to%20the%20RDDRONE-BMS772%20board%20anymore.%20Furthermore%2C%20the%20LED%20does%20not%20turn%20on%20either.%20I%20am%20trying%20to%20re-flash%20it%2C%20but%20I%20cannot%20get%20J-Link%20commander%20to%20connect%20to%20the%20RDDRONE-BMS772%20anymore.%3C%2FP%3E%3CP%3EIf%20I%20try%20to%20access%20the%20board%20using%20an%20FTDI%20cable%2C%20I%20do%20not%20get%20any%20serial%20connection%20using%20Putty%20either.%3C%2FP%3E%3CP%3EI%20am%20a%20bit%20confused%20as%20I%20do%20not%20understand%20if%20the%20problem%20is%20that%20the%20CPU%20is%20halted%2C%20or%20the%20CPU%20is%20in%20a%20RESET%20loop%2C%20the%20CPU%20waiting%20for%20a%20RESET%20signal%2C%20the%20CPU%20is%20%22locked%22%20and%20I%20have%20to%20unlock%20it%2C%20or%20if%20it%20is%20something%20else.%3C%2FP%3E%3CP%3EAny%20help%20would%20be%20highly%20appreciated.%3C%2FP%3E%3CP%3EThis%20is%20the%20log%20I%20got%20from%20the%20J-Link%20Commander%20console%2C%20in%20case%20it%20is%20helpful%3A%3C%2FP%3E%3CP%3EType%20%22connect%22%20to%20establish%20a%20target%20connection%2C%20'%3F'%20for%20help%3CBR%20%2F%3EJ-Link%26gt%3Bconnect%3CBR%20%2F%3EPlease%20specify%20device%20%2F%20core.%20%3CDEFAULT%3E%3A%20S32K144%3CBR%20%2F%3EType%20'%3F'%20for%20selection%20dialog%3CBR%20%2F%3EDevice%26gt%3B%3CBR%20%2F%3EPlease%20specify%20target%20interface%3A%3CBR%20%2F%3EJ)%20JTAG%20(Default)%3CBR%20%2F%3ES)%20SWD%3CBR%20%2F%3ET)%20cJTAG%3CBR%20%2F%3ETIF%26gt%3Bs%3CBR%20%2F%3ESpecify%20target%20interface%20speed%20%5BkHz%5D.%20%3CDEFAULT%3E%3A%204000%20kHz%3CBR%20%2F%3ESpeed%26gt%3B1000%3CBR%20%2F%3EDevice%20%22S32K144%22%20selected.%3C%2FDEFAULT%3E%3C%2FDEFAULT%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3EConnecting%20to%20target%20via%20SWD%3CBR%20%2F%3EInitTarget()%20start%3CBR%20%2F%3ESWD%20selected.%20Executing%20JTAG%20-%26gt%3B%20SWD%20switching%20sequence.%3CBR%20%2F%3EInitTarget()%20end%20-%20Took%2055ms%3CBR%20%2F%3EFound%20SW-DP%20with%20ID%200x2BA01477%3CBR%20%2F%3EDPIDR%3A%200x2BA01477%3CBR%20%2F%3ECoreSight%20SoC-400%20or%20earlier%3CBR%20%2F%3EScanning%20AP%20map%20to%20find%20all%20available%20APs%3CBR%20%2F%3EAP%5B2%5D%3A%20Stopped%20AP%20scan%20as%20end%20of%20AP%20map%20has%20been%20reached%3CBR%20%2F%3EAP%5B0%5D%3A%20AHB-AP%20(IDR%3A%200x24770011)%3CBR%20%2F%3EAP%5B1%5D%3A%20JTAG-AP%20(IDR%3A%200x001C0000)%3CBR%20%2F%3EIterating%20through%20AP%20map%20to%20find%20AHB-AP%20to%20use%3CBR%20%2F%3EAP%5B0%5D%3A%20Core%20found%3CBR%20%2F%3EAP%5B0%5D%3A%20AHB-AP%20ROM%20base%3A%200xE00FF000%3CBR%20%2F%3ECPUID%20register%3A%200x410FC241.%20Implementer%20code%3A%200x41%20(ARM)%3CBR%20%2F%3EFound%20Cortex-M4%20r0p1%2C%20Little%20endian.%3CBR%20%2F%3EFPUnit%3A%206%20code%20(BP)%20slots%20and%202%20literal%20slots%3CBR%20%2F%3ECoreSight%20components%3A%3CBR%20%2F%3EROMTbl%5B0%5D%20%40%20E00FF000%3CBR%20%2F%3E%5B0%5D%5B0%5D%3A%20E000E000%20CID%20B105E00D%20PID%20000BB00C%20SCS-M7%3CBR%20%2F%3E%5B0%5D%5B1%5D%3A%20E0001000%20CID%20B105E00D%20PID%20003BB002%20DWT%3CBR%20%2F%3E%5B0%5D%5B2%5D%3A%20E0002000%20CID%20B105E00D%20PID%20002BB003%20FPB%3CBR%20%2F%3E%5B0%5D%5B3%5D%3A%20E0000000%20CID%20B105E00D%20PID%20003BB001%20ITM%3CBR%20%2F%3E%5B0%5D%5B4%5D%3A%20E0040000%20CID%20B105900D%20PID%20000BB9A1%20TPIU%3CBR%20%2F%3EInitializing%2061440%20bytes%20work%20RAM%20%40%200x1FFF8000%3CBR%20%2F%3EReset%3A%20Halt%20core%20after%20reset%20via%20DEMCR.VC_CORERESET.%3CBR%20%2F%3EReset%3A%20Reset%20device%20via%20AIRCR.SYSRESETREQ.%3CBR%20%2F%3EMemory%20zones%3A%3CBR%20%2F%3EZone%3A%20%22Default%22%20Description%3A%20Default%20access%20mode%3CBR%20%2F%3ECortex-M4%20identified.%3CBR%20%2F%3EJ-Link%26gt%3Berase%3CBR%20%2F%3ENo%20address%20range%20specified%2C%20'Erase%20Chip'%20will%20be%20executed%3CBR%20%2F%3E'erase'%3A%20Performing%20implicit%20reset%20%26amp%3B%20halt%20of%20MCU.%3CBR%20%2F%3EReset%3A%20Halt%20core%20after%20reset%20via%20DEMCR.VC_CORERESET.%3CBR%20%2F%3EReset%3A%20Reset%20device%20via%20AIRCR.SYSRESETREQ.%3CBR%20%2F%3EErasing%20device...%3C%2FP%3E%3CP%3E******%20Error%3A%20Failed%20to%20erase%20sectors.%3C%2FP%3E%3CP%3EJ-Link%3A%20Flash%20download%3A%20Total%20time%20needed%3A%201.490s%20(Prepare%3A%200.603s%2C%20Compare%3A%200.000s%2C%20Erase%3A%200.885s%2C%20Program%3A%200.000s%2C%20Verify%3A%200.000s%2C%20Restore%3A%200.002s)%3C%2FP%3E%3CP%3E******%20Error%3A%20Failed%20to%20restore%20target.%20RAMCode%20never%20stops%3CBR%20%2F%3EERROR%3A%20Erase%20returned%20with%20error%20code%20-5.%3CBR%20%2F%3EJ-Link%26gt%3Bloadbin%20%22C%3A%5CDocuments%5CRDDRONE-BMS772-main%5CBinary%5Cnuttx.bin%22%200x0%3CBR%20%2F%3E'loadbin'%3A%20Performing%20implicit%20reset%20%26amp%3B%20halt%20of%20MCU.%3CBR%20%2F%3EReset%3A%20Halt%20core%20after%20reset%20via%20DEMCR.VC_CORERESET.%3CBR%20%2F%3EReset%3A%20Reset%20device%20via%20AIRCR.SYSRESETREQ.%3CBR%20%2F%3EReset%3A%20SYSRESETREQ%20has%20confused%20core.%3CBR%20%2F%3EFound%20SW-DP%20with%20ID%200x2BA01477%3CBR%20%2F%3EDPIDR%3A%200x2BA01477%3CBR%20%2F%3ECoreSight%20SoC-400%20or%20earlier%3CBR%20%2F%3EAP%20map%20detection%20skipped.%20Manually%20configured%20AP%20map%20found.%3CBR%20%2F%3EAP%5B0%5D%3A%20AHB-AP%20(IDR%3A%20Not%20set)%3CBR%20%2F%3EAP%5B0%5D%3A%20Skipped.%20Could%20not%20read%20CPUID%20register%3CBR%20%2F%3EAttach%20to%20CPU%20failed.%20Executing%20connect%20under%20reset.%3CBR%20%2F%3EDPIDR%3A%200x2BA01477%3CBR%20%2F%3ECoreSight%20SoC-400%20or%20earlier%3CBR%20%2F%3EAP%20map%20detection%20skipped.%20Manually%20configured%20AP%20map%20found.%3CBR%20%2F%3EAP%5B0%5D%3A%20AHB-AP%20(IDR%3A%20Not%20set)%3CBR%20%2F%3EAP%5B0%5D%3A%20Skipped.%20Could%20not%20read%20CPUID%20register%3CBR%20%2F%3ECould%20not%20find%20core%20in%20Coresight%20setup%3CBR%20%2F%3EReset%3A%20Using%20fallback%3A%20VECTRESET.%3CBR%20%2F%3EReset%3A%20Halt%20core%20after%20reset%20via%20DEMCR.VC_CORERESET.%3CBR%20%2F%3EReset%3A%20Reset%20device%20via%20AIRCR.VECTRESET.%3CBR%20%2F%3EReset%3A%20VECTRESET%20has%20confused%20core.%3CBR%20%2F%3EReset%3A%20Using%20fallback%3A%20Reset%20pin.%3CBR%20%2F%3EReset%3A%20Halt%20core%20after%20reset%20via%20DEMCR.VC_CORERESET.%3CBR%20%2F%3EReset%3A%20Reset%20device%20via%20reset%20pin%3CBR%20%2F%3EReset%3A%20VC_CORERESET%20did%20not%20halt%20CPU.%20(Debug%20logic%20also%20reset%20by%20reset%20pin%3F).%3CBR%20%2F%3EReset%3A%20Reconnecting%20and%20manually%20halting%20CPU.%3CBR%20%2F%3EFound%20SW-DP%20with%20ID%200x2BA01477%3CBR%20%2F%3EDPIDR%3A%200x2BA01477%3CBR%20%2F%3ECoreSight%20SoC-400%20or%20earlier%3CBR%20%2F%3EAP%20map%20detection%20skipped.%20Manually%20configured%20AP%20map%20found.%3CBR%20%2F%3EAP%5B0%5D%3A%20AHB-AP%20(IDR%3A%20Not%20set)%3CBR%20%2F%3EAP%5B0%5D%3A%20Skipped.%20Could%20not%20read%20CPUID%20register%3CBR%20%2F%3EAttach%20to%20CPU%20failed.%20Executing%20connect%20under%20reset.%3CBR%20%2F%3EDPIDR%3A%200x2BA01477%3CBR%20%2F%3ECoreSight%20SoC-400%20or%20earlier%3CBR%20%2F%3EAP%20map%20detection%20skipped.%20Manually%20configured%20AP%20map%20found.%3CBR%20%2F%3EAP%5B0%5D%3A%20AHB-AP%20(IDR%3A%20Not%20set)%3CBR%20%2F%3EAP%5B0%5D%3A%20Skipped.%20Could%20not%20read%20CPUID%20register%3CBR%20%2F%3ECould%20not%20find%20core%20in%20Coresight%20setup%3CBR%20%2F%3ECPU%20could%20not%20be%20halted%3CBR%20%2F%3EReset%3A%20Core%20did%20not%20halt%20after%20reset%2C%20trying%20to%20disable%20WDT.%3CBR%20%2F%3EReset%3A%20Halt%20core%20after%20reset%20via%20DEMCR.VC_CORERESET.%3CBR%20%2F%3EReset%3A%20Reset%20device%20via%20reset%20pin%3CBR%20%2F%3EReset%3A%20VC_CORERESET%20did%20not%20halt%20CPU.%20(Debug%20logic%20also%20reset%20by%20reset%20pin%3F).%3CBR%20%2F%3EReset%3A%20Reconnecting%20and%20manually%20halting%20CPU.%3CBR%20%2F%3EFound%20SW-DP%20with%20ID%200x2BA01477%3CBR%20%2F%3EDPIDR%3A%200x2BA01477%3CBR%20%2F%3ECoreSight%20SoC-400%20or%20earlier%3CBR%20%2F%3EAP%20map%20detection%20skipped.%20Manually%20configured%20AP%20map%20found.%3CBR%20%2F%3EAP%5B0%5D%3A%20AHB-AP%20(IDR%3A%20Not%20set)%3CBR%20%2F%3EAP%5B0%5D%3A%20Skipped.%20Could%20not%20read%20CPUID%20register%3CBR%20%2F%3EAttach%20to%20CPU%20failed.%20Executing%20connect%20under%20reset.%3CBR%20%2F%3EDPIDR%3A%200x2BA01477%3CBR%20%2F%3ECoreSight%20SoC-400%20or%20earlier%3CBR%20%2F%3EAP%20map%20detection%20skipped.%20Manually%20configured%20AP%20map%20found.%3CBR%20%2F%3EAP%5B0%5D%3A%20AHB-AP%20(IDR%3A%20Not%20set)%3CBR%20%2F%3EAP%5B0%5D%3A%20Skipped.%20Could%20not%20read%20CPUID%20register%3CBR%20%2F%3ECould%20not%20find%20core%20in%20Coresight%20setup%3CBR%20%2F%3ECPU%20could%20not%20be%20halted%3CBR%20%2F%3EReset%3A%20Failed.%20Toggling%20reset%20pin%20and%20trying%20reset%20strategy%20again.%3CBR%20%2F%3EFound%20SW-DP%20with%20ID%200x2BA01477%3CBR%20%2F%3EDPIDR%3A%200x2BA01477%3CBR%20%2F%3ECoreSight%20SoC-400%20or%20earlier%3CBR%20%2F%3EAP%20map%20detection%20skipped.%20Manually%20configured%20AP%20map%20found.%3CBR%20%2F%3EAP%5B0%5D%3A%20AHB-AP%20(IDR%3A%20Not%20set)%3CBR%20%2F%3EAP%5B0%5D%3A%20Skipped.%20Could%20not%20read%20CPUID%20register%3CBR%20%2F%3EAttach%20to%20CPU%20failed.%20Executing%20connect%20under%20reset.%3CBR%20%2F%3EDPIDR%3A%200x2BA01477%3CBR%20%2F%3ECoreSight%20SoC-400%20or%20earlier%3CBR%20%2F%3EAP%20map%20detection%20skipped.%20Manually%20configured%20AP%20map%20found.%3CBR%20%2F%3EAP%5B0%5D%3A%20AHB-AP%20(IDR%3A%20Not%20set)%3CBR%20%2F%3EAP%5B0%5D%3A%20Skipped.%20Could%20not%20read%20CPUID%20register%3CBR%20%2F%3ECould%20not%20find%20core%20in%20Coresight%20setup%3CBR%20%2F%3EReset%3A%20Halt%20core%20after%20reset%20via%20DEMCR.VC_CORERESET.%3CBR%20%2F%3EReset%3A%20Reset%20device%20via%20AIRCR.SYSRESETREQ.%3CBR%20%2F%3EReset%3A%20SYSRESETREQ%20has%20confused%20core.%3CBR%20%2F%3EFound%20SW-DP%20with%20ID%200x2BA01477%3CBR%20%2F%3EDPIDR%3A%200x2BA01477%3CBR%20%2F%3ECoreSight%20SoC-400%20or%20earlier%3CBR%20%2F%3EAP%20map%20detection%20skipped.%20Manually%20configured%20AP%20map%20found.%3CBR%20%2F%3EAP%5B0%5D%3A%20AHB-AP%20(IDR%3A%20Not%20set)%3CBR%20%2F%3EAP%5B0%5D%3A%20Skipped.%20Could%20not%20read%20CPUID%20register%3CBR%20%2F%3EAttach%20to%20CPU%20failed.%20Executing%20connect%20under%20reset.%3CBR%20%2F%3EDPIDR%3A%200x2BA01477%3CBR%20%2F%3ECoreSight%20SoC-400%20or%20earlier%3CBR%20%2F%3EAP%20map%20detection%20skipped.%20Manually%20configured%20AP%20map%20found.%3CBR%20%2F%3EAP%5B0%5D%3A%20AHB-AP%20(IDR%3A%20Not%20set)%3CBR%20%2F%3EAP%5B0%5D%3A%20Skipped.%20Could%20not%20read%20CPUID%20register%3CBR%20%2F%3ECould%20not%20find%20core%20in%20Coresight%20setup%3CBR%20%2F%3EReset%3A%20Using%20fallback%3A%20VECTRESET.%3CBR%20%2F%3EReset%3A%20Halt%20core%20after%20reset%20via%20DEMCR.VC_CORERESET.%3CBR%20%2F%3EReset%3A%20Reset%20device%20via%20AIRCR.VECTRESET.%3CBR%20%2F%3EReset%3A%20VECTRESET%20has%20confused%20core.%3CBR%20%2F%3EReset%3A%20Using%20fallback%3A%20Reset%20pin.%3CBR%20%2F%3EReset%3A%20Halt%20core%20after%20reset%20via%20DEMCR.VC_CORERESET.%3CBR%20%2F%3EReset%3A%20Reset%20device%20via%20reset%20pin%3CBR%20%2F%3EReset%3A%20VC_CORERESET%20did%20not%20halt%20CPU.%20(Debug%20logic%20also%20reset%20by%20reset%20pin%3F).%3CBR%20%2F%3EReset%3A%20Reconnecting%20and%20manually%20halting%20CPU.%3CBR%20%2F%3EFound%20SW-DP%20with%20ID%200x2BA01477%3CBR%20%2F%3EDPIDR%3A%200x2BA01477%3CBR%20%2F%3ECoreSight%20SoC-400%20or%20earlier%3CBR%20%2F%3EAP%20map%20detection%20skipped.%20Manually%20configured%20AP%20map%20found.%3CBR%20%2F%3EAP%5B0%5D%3A%20AHB-AP%20(IDR%3A%20Not%20set)%3CBR%20%2F%3EAP%5B0%5D%3A%20Skipped.%20Could%20not%20read%20CPUID%20register%3CBR%20%2F%3EAttach%20to%20CPU%20failed.%20Executing%20connect%20under%20reset.%3CBR%20%2F%3EDPIDR%3A%200x2BA01477%3CBR%20%2F%3ECoreSight%20SoC-400%20or%20earlier%3CBR%20%2F%3EAP%20map%20detection%20skipped.%20Manually%20configured%20AP%20map%20found.%3CBR%20%2F%3EAP%5B0%5D%3A%20AHB-AP%20(IDR%3A%20Not%20set)%3CBR%20%2F%3EAP%5B0%5D%3A%20Skipped.%20Could%20not%20read%20CPUID%20register%3CBR%20%2F%3ECould%20not%20find%20core%20in%20Coresight%20setup%3CBR%20%2F%3ECPU%20could%20not%20be%20halted%3CBR%20%2F%3EReset%3A%20Core%20did%20not%20halt%20after%20reset%2C%20trying%20to%20disable%20WDT.%3CBR%20%2F%3EReset%3A%20Halt%20core%20after%20reset%20via%20DEMCR.VC_CORERESET.%3CBR%20%2F%3EReset%3A%20Reset%20device%20via%20reset%20pin%3CBR%20%2F%3EReset%3A%20VC_CORERESET%20did%20not%20halt%20CPU.%20(Debug%20logic%20also%20reset%20by%20reset%20pin%3F).%3CBR%20%2F%3EReset%3A%20Reconnecting%20and%20manually%20halting%20CPU.%3CBR%20%2F%3EFound%20SW-DP%20with%20ID%200x2BA01477%3CBR%20%2F%3EDPIDR%3A%200x2BA01477%3CBR%20%2F%3ECoreSight%20SoC-400%20or%20earlier%3CBR%20%2F%3EAP%20map%20detection%20skipped.%20Manually%20configured%20AP%20map%20found.%3CBR%20%2F%3EAP%5B0%5D%3A%20AHB-AP%20(IDR%3A%20Not%20set)%3CBR%20%2F%3EAP%5B0%5D%3A%20Skipped.%20Could%20not%20read%20CPUID%20register%3CBR%20%2F%3EAttach%20to%20CPU%20failed.%20Executing%20connect%20under%20reset.%3CBR%20%2F%3EDPIDR%3A%200x2BA01477%3CBR%20%2F%3ECoreSight%20SoC-400%20or%20earlier%3CBR%20%2F%3EAP%20map%20detection%20skipped.%20Manually%20configured%20AP%20map%20found.%3CBR%20%2F%3EAP%5B0%5D%3A%20AHB-AP%20(IDR%3A%20Not%20set)%3CBR%20%2F%3EAP%5B0%5D%3A%20Skipped.%20Could%20not%20read%20CPUID%20register%3CBR%20%2F%3ECould%20not%20find%20core%20in%20Coresight%20setup%3CBR%20%2F%3ECPU%20could%20not%20be%20halted%3CBR%20%2F%3ECPU%20could%20not%20be%20halted%3C%2FP%3E%3CP%3E******%20Error%3A%20Failed%20to%20halt%20CPU.%3CBR%20%2F%3ECPU%20could%20not%20be%20halted%3CBR%20%2F%3EDownloading%20file%20%5BC%3A%5CDocuments%5CRDDRONE-BMS772-main%5CBinary%5Cnuttx.bin%5D...%3CBR%20%2F%3ECPU%20could%20not%20be%20halted%3C%2FP%3E%3CP%3E******%20Error%3A%20Failed%20to%20restore%20target.%20RAMCode%20never%20stops%3CBR%20%2F%3EFailed%20to%20erase%20sectors.%3C%2FP%3E%3CP%3EUnspecified%20error%20-1%3CBR%20%2F%3EJ-Link%26gt%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1617779%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1617779%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F213615%22%20target%3D%22_blank%22%3E%40dmorvay%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CP%3EThe%20I2C%20voltage%20level%20is%203.3V.%3CBR%20%2F%3EThis%20is%20the%20MCU%20voltage%20domain%20as%20well.%3CBR%20%2F%3E%3CBR%20%2F%3EBut%20there%20is%205V%20on%20the%20board%20which%20can%20be%20used%20to%20supply%20a%20display%20with%205V.%3CBR%20%2F%3E%3CBR%20%2F%3EThe%20schematic%20of%20the%20RDDRONE-BMS772%20can%20be%20downloaded%20from%20the%20NXP%20webpage%20(click%20on%20design%20files%20or%20scroll%20down%20to%20the%20design%20resources)%3A%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesigns%2Fsmart-battery-management-for-mobile-robotics%3ARDDRONE-BMS772%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesigns%2Fsmart-battery-management-for-mobile-robotics%3ARDDRONE-BMS772%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EKind%20regards%2C%3C%2FP%3E%0A%3CP%3ECis%20van%20Mierlo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1617771%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1617771%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%3C%2FA%3E%2C%20I%20appreciate%20the%20information!%20I%20will%20try%20again%20on%20the%20display.%20For%20reference%2C%20what%20is%20the%20I2C%20transmission%20voltage%20on%20the%20BMS772%3F%20Is%20it%205V%20or%203.3V%20I2C%3F%20I%20don't%20want%20to%20hook%20up%20a%205V%20I2C%20(say%20Arduino)%20and%20then%20damage%20the%20board%20if%20it%20is%203.3V.%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1617458%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1617458%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F213615%22%20target%3D%22_blank%22%3E%40dmorvay%3C%2FA%3E%2C%3C%2FP%3E%3CP%3EGreat%20that%20soldering%20the%20correct%20jumpers%20solves%20the%20cell%20voltage%20issue!%26nbsp%3B%3C%2FP%3E%3CP%3EFor%20the%20OLED%20display%2C%20as%20I%20said%20I'm%20not%20familiar%20with%20the%20Model%20Based%20Design%20Toolbox%20examples.%26nbsp%3B%3CBR%20%2F%3EMaybe%20they%20mean%20the%20RGB-LED%20which%20is%20on%20the%20board%20with%20the%20LED%20example%3F%3C%2FP%3E%3CP%3EThe%20display%20delivered%20with%20the%20kit%20should%20support%203.3V.%3C%2FP%3E%3CP%3EBut%20if%20you%20are%20interested%20in%20an%20BMS%20example%20project%20written%20in%20C%20with%20the%20NuttX%20RTOS%20(this%20includes%20the%20display%20to%20showcase%20battery%20values)%2C%20see%20the%20example%20here%3A%26nbsp%3B%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3EPS%3A%20This%20is%20a%20graphical%20display%2C%20not%20a%20textual%20display.%20So%20each%20character%20needs%20to%20be%20drawn%20according%20to%20a%20specific%20font%20that%20is%20used.%3C%2FP%3E%3CP%3EKind%20regards%2C%3C%2FP%3E%3CP%3ECis%20van%20Mierlo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1617200%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1617200%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%3C%2FA%3E%26nbsp%3BThat%20seemed%20to%20do%20the%20trick!%20It%20appears%20that%20I%20failed%20to%20read%20that%20portion%20of%20the%20documentation%20about%20soldering%20those%20jumpers.%26nbsp%3B%3C%2FP%3E%3CP%3EAnother%20question%20regarding%20the%20OLED%20screen%2C%20I%20tried%20building%20and%20flashing%20the%20LED%20example%20onto%20the%20board%2C%20but%20the%20screen%20would%20not%20turn%20on.%20Is%20there%20anything%20special%20I%20need%20to%20do%20there%3F%20I%20was%20reading%203.3V%20on%20J23%20between%20VCC%20and%20GND%2C%20but%20when%20I%20plugged%20the%20screen%20in%2C%20it%20would%20not%20turn%20on.%20Any%20suggestions%3F%20I%20didn't%20get%20a%20chance%20to%20check%20the%20D34%20and%20D35%20diodes%20today%2C%20but%20do%20those%20need%20to%20be%20moved%20if%20I%20am%20reading%203.3V%3F%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1616502%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1616502%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F213615%22%20target%3D%22_blank%22%3E%40dmorvay%3C%2FA%3E%2C%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3EI%20do%20not%20have%20experience%20with%20the%20%3CSPAN%3EModel-Based%20Development%20toolbox%20yet%2C%20so%20in%20this%20regard%20I%20can%20not%20check%20it.%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSPAN%3EFor%20the%20HW%3A%3CBR%20%2F%3ECould%20you%20confirm%20that%20the%20soldered%20jumpers%20are%20SJ6%2C%20SJ10%2C%20SJ11%20and%20SJ12%20for%203S%3F%3CBR%20%2F%3EAnd%20the%20cell%20voltage%20filters%20are%20correctly%20in%20place%3A%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22cisvmierlo_0-1678950769358.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cisvmierlo_0-1678950769358.png%22%20style%3D%22width%3A%20261px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cisvmierlo_0-1678950769358.png%22%20style%3D%22width%3A%20261px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cisvmierlo_0-1678950769358.png%22%20style%3D%22width%3A%20261px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cisvmierlo_0-1678950769358.png%22%20style%3D%22width%3A%20261px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cisvmierlo_0-1678950769358.png%22%20style%3D%22width%3A%20261px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cisvmierlo_0-1678950769358.png%22%20style%3D%22width%3A%20261px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cisvmierlo_0-1678950769358.png%22%20style%3D%22width%3A%20261px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cisvmierlo_0-1678950769358.png%22%20style%3D%22width%3A%20261px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cisvmierlo_0-1678950769358.png%22%20style%3D%22width%3A%20261px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F214878i62C02D5A4FCD83F1%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22cisvmierlo_0-1678950769358.png%22%20alt%3D%22cisvmierlo_0-1678950769358.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Ecisvmierlo_0-1678950769358.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3EKind%20regards%2C%3CBR%20%2F%3E%3CBR%20%2F%3ECis%20van%20Mierlo%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1616239%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1616239%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%20I%20was%20experimenting%20with%20the%20BMS772%20this%20evening%20and%20was%20trying%20to%20display%20cell%20voltages.%20I%20have%20a%203s%20setup%20and%20for%20some%20reason%20one%20cell%20is%20consistently%20reading%20higher%20than%20the%20others.%20I%20confirmed%20via%20a%20multimeter%20that%20the%20cells%20are%20all%20roughly%20the%20same%20value.%20I%20tried%20this%20with%20two%20different%20battery%20packs%20as%20well.%20See%20my%20attached%20screenshot%20for%20more%20information.%20Notice%2C%20the%20BMS%20is%20consistently%20reading%20~0.7%20greater%20than%20the%20others.%20I%20am%20using%20Model-Based%20Development%20with%20a%20J-Link%20Debugger%20in%20FreeMaster.%20Any%20advice%20would%20be%20appreciated!%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22dmorvay_0-1678921034731.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22dmorvay_0-1678921034731.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22dmorvay_0-1678921034731.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22dmorvay_0-1678921034731.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22dmorvay_0-1678921034731.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22dmorvay_0-1678921034731.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22dmorvay_0-1678921034731.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22dmorvay_0-1678921034731.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22dmorvay_0-1678921034731.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22dmorvay_0-1678921034731.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F214816i1AD583C84C4CDDF9%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22dmorvay_0-1678921034731.png%22%20alt%3D%22dmorvay_0-1678921034731.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Edmorvay_0-1678921034731.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1606759%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1606759%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EDoes%20BMS772%20board%20support%20Pixhawk%20Cube%20Orange%20Autopilot%3F%3C%2FP%3E%3CP%3EI%20have%20successfully%20communicated%20with%20other%20UAVCAN%20devices%20such%20as%3CSTRONG%3E%20Zubax%20ESC%2C%20Packet%20digital%20MPPT.%20%3C%2FSTRONG%3Elinks%20given%20below.%20But%20it%20didn't%20work%20with%20BMS772.%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fpacketdigital.com%2Fpower-products%2Fmaximum-power-point-tracker%2F%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fpacketdigital.com%2Fpower-products%2Fmaximum-power-point-tracker%2F%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Ffiles.zubax.com%2Fproducts%2Fcom.zubax.telega%2FZubax_Myxa_Datasheet.pdf%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Ffiles.zubax.com%2Fproducts%2Fcom.zubax.telega%2FZubax_Myxa_Datasheet.pdf%3C%2FA%3E%3C%2FP%3E%3CP%3EAlso%2C%20Does%20BMS772%20board%20support%20classical%20CAN%20(CAN%202.0)%20protocol%3F%20If%20yes%2C%20I%20would%20like%20to%20test%20it%20with%20Microchip's%20CAN%20bus%20analyzer.%3C%2FP%3E%3CP%3EPlease%20clarify.%3C%2FP%3E%3CP%3EThanks%20in%20advance..%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1604889%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1604889%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThis%20isn't%20helpful%20according%20to%20your%20question%2C%20but%20the%20code%20was%20developed%20using%20a%20segger%20jlink%20family%20device.%20If%20you%20are%20a%20student%20and%20this%20is%20non-commercial%20use%2C%20you%20can%20use%20one%20of%20the%20lower%20cost%20jlink-edu%20from%20suppliers%20like%20Adafruit.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1604885%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Request%20for%20Register%20Map%20for%20NXP%20RDDrone-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1604885%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThe%20best%20reference%20for%20what%20is%20implemented%20is%20by%20referring%20to%20the%20actual%20code.%20Which%20is%20published%20and%20open%20source.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1604876%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Request%20for%20Register%20Map%20for%20NXP%20RDDrone-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1604876%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThe%20Smart%20Battery%20System%20Specification%20ended%20up%20being%20helpful.%3C%2FP%3E%3CP%3EThe%20spec%20sheet%20can%20be%20found%20here%3A%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fsbs-forum.org%2Fspecs%2Fsbdat110.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fsbs-forum.org%2Fspecs%2Fsbdat110.pdf%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1604268%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERequest%20for%20Register%20Map%20for%20NXP%20RDDrone-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1604268%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ERequest%20for%20Register%20Map%20for%20NXP%20RDDrone-BMS772%3C%2FP%3E%3CP%3EHi%20all%2C%3C%2FP%3E%3CP%3EI%20recently%20purchased%20the%20NXP%20RDDrone-BMS772%20battery%20management%20system%20for%20my%20project%2C%20and%20I%20am%20having%20trouble%20communicating%20with%20the%20device%20via%20I2C.%20I%20have%20been%20trying%20to%20read%20the%20registers%20of%20the%20device%2C%20but%20without%20a%20register%20map%2C%20it's%20difficult%20to%20know%20which%20registers%20to%20access.%3C%2FP%3E%3CP%3EI%20was%20wondering%20if%20someone%20could%20please%20provide%20me%20with%20a%20register%20map%20for%20the%20RDDrone-BMS772%2C%20or%20point%20me%20in%20the%20direction%20of%20where%20I%20could%20find%20one.%20I%20believe%20that%20having%20a%20register%20map%20would%20greatly%20help%20me%20to%20communicate%20with%20the%20device%20and%20extract%20the%20information%20that%20I%20need.%3C%2FP%3E%3CP%3EThank%20you%20for%20your%20help%20in%20advance.%3C%2FP%3E%3CP%3EBest%20regards%2C%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1601937%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1601937%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%3C%2FA%3E%2C%3C%2FP%3E%3CP%3EThanks%20for%20your%20help.%20I%20could%20solve%20Under%20voltage%20fault%20problem.%20Now%20I%20want%20to%20see%20DroneCAN%20%2F%20UAVCAN%20messages%20%2F%20parameters%20sent%20by%20BMS%20in%20some%20software%20tool.%3C%2FP%3E%3CP%3EDo%20you%20have%20some%20software%20GUI%20tool%20to%20see%20CAN%20messages%20from%20BMS%3F%3C%2FP%3E%3CP%3EI%20tried%20to%20see%20messages%20with%20DroneCAN%20GUI%20tool%20with%20BMS772%20connected%20to%20Orange%20Cube%20Autopilot.%20But%20I%20am%20not%20successful.%20Mission%20planner%20software%20didn't%20recognize%20BMS%20in%20SLCAN%20mode.%3C%2FP%3E%3CP%3E%3CSTRONG%3EWhere%20as%20Cube%20orange%20detects%20other%20UAVCAN%20devices%20such%20as%20Zubax%20ESC%2C%20Packet%20digital%20MPPT.%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EAlso%2C%20Should%20I%20change%20DroneCAN%20static%20node%20ID%20to%20other%20than%20255%20for%20it%20to%20work%3F%3C%2FP%3E%3CP%3ENXP's%20UCAN%20based%20nodes%20are%20not%20available%20for%20purchase%20in%20India.%3C%2FP%3E%3CP%3EAlso%2C%20please%20clarify%20whether%20Over%20current%2C%20output%20short%20circuit%20protection%20is%20available%20on%20BMS%3F%3C%2FP%3E%3CP%3EPlease%20clarify%20the%20above.%20Thanks%20again%20for%20your%20great%20support.%3C%2FP%3E%3CP%3E...%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1601120%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1601120%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F195015%22%20target%3D%22_blank%22%3E%40Prince1%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EGreat%20that%20the%20communication%20issue%20has%20been%20resolved!%3C%2FP%3E%0A%3CP%3EFor%20the%20other%20questions%3A%3C%2FP%3E%0A%3CP%3E%22Yes%2C%20CLI%20shows%20%22Cell%20under%20voltage%20detected!%22%20and%20display%20shows%2011.26V%20although%20fluke%20instrument%20measures%2011.7V.%22%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThe%20display%20shows%20v-out.%20Which%20is%20measured%20via%20a%20resistor%20divider%20on%20the%20output%20with%201%25%20tolerance.%20Meaning%20that%20you%20could%20have%20a%200.946V%20difference%20on%2026V%2C%20just%20because%20of%20the%20resistor%20tolerances.%3C%2FP%3E%0A%3CP%3ESo%20it%20could%20be%20that%20this%20is%20a%20little%20off%20with%20the%20actual%20value.%20In%20the%20current%20SW%20example%20there%20is%20no%20option%20to%20fine%20tune%20this%20measurement.%3CBR%20%2F%3E%3CBR%20%2F%3EWhat%20you%20could%20do%20is%3A%20look%20at%20v-batt%20or%20add%20all%20the%20cell%20voltages%20together%20(which%20is%20the%20most%20precise).%20Vtot%20%3D%20v-cell1%20%2B%20v-cell2%20%2B%20..%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%221.%20It%20looks%20if%20cell%20voltages%20%26lt%3B%203.8V%2C%20it%20goes%20to%20Deep_Sleep.%20Will%20it%20happen%20even%20if%20load%20is%20connected%20on%20J5%3F%20I%20mean%2C%20if%20load%20is%20connected%20disconnecting%20the%20battery%20at%203.8V%20is%20too%20early%20when%20cell%20cutoff%20voltage%20is%203V.%22%3CBR%20%2F%3E%3CBR%20%2F%3ESo%20the%20default%20cell%20under%20voltage%20(for%20a%20LiPo%20battery)%20is%20set%20at%203V.%20You%20could%20check%20this%20setting%20via%20the%20UART%20interface%20via%3A%26nbsp%3B%3CBR%20%2F%3Ebms%20get%20v-cell-uv%3CBR%20%2F%3EYou%20could%20set%20the%20cell%20under%20voltage%20you%20think%20is%20suitable%20with%3A%20%22bms%20set%20v-cell-uv%20x.xV%22%3CBR%20%2F%3EAfter%20setting%20parameters%2C%20do%20not%20forget%20to%20save%20it%20to%20flash%20with%20%22bms%20save%22.%3CBR%20%2F%3E%3CBR%20%2F%3EFor%20more%20information%20on%20which%20parameters%20there%20are%2C%20please%20have%20a%20look%20at%20chapter%208.2%20of%26nbsp%3B%3CA%20class%3D%22js-navigation-open%20Link--primary%22%20title%3D%22BMS772_releaseNotes_5.0.pdf%22%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2Fblob%2Fmain%2FBMS772_releaseNotes_5.0.pdf%22%20data-turbo-frame%3D%22repo-content-turbo-frame%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EBMS772_releaseNotes_5.0.pdf.%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EBut%20I%20would%20check%20the%20cell%20voltages%20via%20the%20UART%20connection%2C%20so%20you%20can%20see%20which%20cell%20has%20a%20problem.%26nbsp%3B%3CBR%20%2F%3EYou%20can%20use%3A%20%22bms%20get%20all%22%20(gets%20all%20parameters)%2C%26nbsp%3B%20%22bms%20show%20all%201%22%20(updates%20the%20battery%20values)%2C%20%22bms%20show%20top%201%22%20(updates%20the%20battery%20values%20without%20scrolling).%3C%2FP%3E%0A%3CP%3E%222.%20Is%20it%20possible%20to%20reduce%20the%20voltage%20measurement%20error%20in%20BMS%3F%22%3CBR%20%2F%3EAs%20stated%20in%20the%20beginning%2C%20there%20is%20no%20parameter%20for%20correcting%20the%20v-out%20voltage.%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3EBut%20feel%20free%20to%20adjust%20the%20SW%20yourself%20so%20for%20example%20v-batt%20is%20displayed%20on%20the%20display%20instead%20of%20v-out.%3CBR%20%2F%3E%3CBR%20%2F%3EKind%20regards%2C%26nbsp%3B%3C%2FP%3E%0A%3CP%3ECis%20van%20Mierlo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1601097%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1601097%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%3C%2FA%3E%20%2C%3C%2FP%3E%3CP%3EThanks%20a%20lot.%3C%2FP%3E%3CP%3EYou%20solved%20my%20problem.%3C%2FP%3E%3CP%3EAfter%20rectifying%20J19%20connections%2C%20CLI%20and%20Display%20worked.%3C%2FP%3E%3CP%3EYes%2C%20CLI%20shows%20%22Cell%20undervoltage%20detected!%22%20and%20display%20shows%2011.26V%20although%20fluke%20instrument%20measures%2011.7V.%3C%2FP%3E%3CP%3E1.%20It%20looks%20if%20cell%20voltages%20%26lt%3B%203.8V%2C%20it%20goes%20to%20Deep_Sleep.%20Will%20it%20happen%20even%20if%20load%20is%20connected%20on%20J5%3F%20I%20mean%2C%20if%20load%20is%20connected%20disconnecting%20the%20battery%20at%203.8V%20is%20too%20early%20when%20cell%20cutoff%20voltage%20is%203V.%3C%2FP%3E%3CP%3E2.%20Is%20it%20possible%20to%20reduce%20the%20voltage%20measurement%20error%20in%20BMS%3F%3C%2FP%3E%3CP%3EKindly%20answer%20the%20above%20questions.%3C%2FP%3E%3CP%3EThanks..%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1601076%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1601076%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F195015%22%20target%3D%22_blank%22%3E%40Prince1%3C%2FA%3E%2C%3C%2FP%3E%3CP%3EI%20think%20I%20found%20the%20issue%20with%20the%20communication%20on%20BMS1.%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3EThe%20black%20wire%20is%20connected%20to%20J19%20pin%201%2C%20which%20is%203.3V%20and%20not%20connected%20to%20ground.%3CBR%20%2F%3EFor%20ground%2C%20you%20need%20to%20connect%20the%20black%20wire%20to%20J19%20pin%207%20(other%20side%20of%20the%20connector).%26nbsp%3B%3C%2FP%3E%3CP%3ELight%20blue%20is%20now%20connected%20to%20J19%20pin%205%20(SWD_CLK)%20and%20yellow%20is%20now%20connected%20to%20J19%20pin%206%20(RST_N).%3CBR%20%2F%3EI%20think%20you%20need%20to%20swap%20the%20connections%20on%20the%20connector%20J19.%3CBR%20%2F%3E%3CBR%20%2F%3EI%20will%20come%20back%20on%20the%20other%20PCB%20later.%3C%2FP%3E%3CP%3EKind%20regards%2C%3C%2FP%3E%3CP%3ECis%20van%20Mierlo%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1601062%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1601062%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%40CisvanMierlo%2C%3C%2FP%3E%3CP%3EI%20have%20attached%20images%20of%20two%20BMSes%2C%3C%2FP%3E%3CP%3E1st%20one%3A%20LED%20blinks%20in%20red%20for%201%20min%20before%20going%20to%20Deep_Sleep.%3C%2FP%3E%3CP%3E2nd%20one%3A%20has%20over%20heat%20issue%20and%20LED%20doesn't%20turn%20ON.%3C%2FP%3E%3CP%3EThough%20I%20have%20used%205%20pin%20cell%20terminal%20connector%2C%20I%20have%20not%20connected%204S%20pin%20(5th%20pin%20open)%20%2F%20wire.%20So%2C%205%20pin%20connector%20is%20used%20for%203S%20battery.%20Voltages%20are%20correct%20at%20JP1%20connector.%3C%2FP%3E%3CP%3EToday%20I%20charged%20battery%20to%2011.7V%20and%20tested%20still%20same%20result.%3C%2FP%3E%3CP%3EThanks..%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1600460%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1600460%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F195015%22%20target%3D%22_blank%22%3E%40Prince1%3C%2FA%3E%2C%3C%2FP%3E%3CP%3EOnly%20with%20a%20cell%20under%20voltage%20detection%20it%20will%20go%20to%20deep-sleep%20after%201%20min.%3CBR%20%2F%3E%3CBR%20%2F%3EMaybe%20there%20is%20something%20with%20the%20cell%20connections.%3CBR%20%2F%3Ecould%20you%20perhaps%20share%20images%20of%20this%20board%20as%20well%20(top%20and%20bottom)%3F%3C%2FP%3E%3CP%3EKind%20regards%2C%3C%2FP%3E%3CP%3ECis%20van%20Mierlo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1600427%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1600427%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Cis%20van%20Mierlo%2C%3C%2FP%3E%3CP%3EBMS%20default%20%3CSTRONG%3EV-cell-UV%3C%2FSTRONG%3E%20may%20be%203V%2C%20but%20my%20all%20battery%20cell%20voltages%20are%20beyond%203.8V%20and%203S%20pack%20voltage%20is%2011.5V.%20I%20think%20under%20voltage%20is%20not%20the%20reason%20for%20BMS%20going%20into%20Deep_Sleep.%3C%2FP%3E%3CP%3EPlease%20mention%20what%20could%20be%20other%20reasons%20for%20BMS%20LED%20blinking%20in%20red%20for%201min%20and%20then%20going%20into%20Deep_Sleep.%3C%2FP%3E%3CP%3ED34%20is%20placed%2C%20D35%20not%20placed.%20Still%20Display%20doesn't%20turn%20on.%20Display%20pin%20numbers%20are%20connected%20as%20suggested.%3C%2FP%3E%3CP%3EI%20will%20share%20the%20images%20of%20other%20BMS%20board%20with%20over%20heating%20issue.%3C%2FP%3E%3CP%3EThanks..%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1600323%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1600323%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F195015%22%20target%3D%22_blank%22%3E%40Prince1%3C%2FA%3E%2C%3C%2FP%3E%3CP%3E%22BMS%20LED%20is%20blinking%20in%20red%20colour%20and%20then%20goes%20OFF%20after%20around%201min.%20I%20think%20it%20goes%20to%20SLEEP.%22%3CBR%20%2F%3E%3CBR%20%2F%3EThis%20indicates%20that%20there%20is%20a%20cell%20under-voltage%20detected%20(based%20on%20default%20battery%20technology%3A%20LiPo).%3CBR%20%2F%3EWhen%20this%20happens%2C%20the%20BMS%20goes%20to%20DEEP_SLEEP%20after%20t-fault-timeout%20(60s%20default)%20in%20order%20to%20preserve%20the%20battery%20with%20its%20lowest%20power%20mode.%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3EIn%20that%20DEEP_SLEEP%20state%20the%20MCU%20(and%20SBC)%20is%20turned%20off%2C%20so%20no%20communication%20is%20possible%20after%20that%201%20min.%20The%20button%20is%20press%20(or%20a%20re-power)%20is%20the%20only%20thing%20to%20wake%20the%20BMS%20from%20the%20DEEP_SLEEP%20state.%3CBR%20%2F%3E%3CBR%20%2F%3ESo%20it%20could%20be%20that%20there%20is%20no%20communication%20because%20the%20BMS%20entered%20the%20DEEP_SLEEP.%3CBR%20%2F%3EOr%20there%20would%20be%20something%20with%20the%20connection.%26nbsp%3B%3C%2FP%3E%3CP%3EFor%20the%20display%20to%20turn%20on%20during%20initialization%2C%20could%20you%20maybe%20check%20that%20D34%20is%20placed%20instead%20of%20D35%3F%3CBR%20%2F%3E%3CBR%20%2F%3EFor%20the%20other%20BMS%20setup%2C%20the%20SBC%20overheating%20and%20LED%20not%20turning%20on%2C%20indicates%20that%20there%20might%20be%20a%20short%20on%20the%203.3V%20domain%20(shorted%20to%20gnd).%3C%2FP%3E%3CP%3ECould%20you%20maybe%20show%20both%20of%20your%20boards%20(top%20and%20bottom%20side)%3F%3CBR%20%2F%3E%3CBR%20%2F%3EKind%20regards%2C%3C%2FP%3E%3CP%3ECis%20van%20Mierlo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1600171%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1600171%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3CSPAN%20class%3D%22%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F90400%22%20target%3D%22_self%22%3E%3CSPAN%20class%3D%22%22%3EGeraldP%3C%2FSPAN%3E%3C%2FA%3E%3C%2FSPAN%3E%2C%3C%2FP%3E%3CP%3EI%20have%20done%20the%20following%20on%20a%20new%20BMS%2C%3C%2FP%3E%3CP%3ESJ6%2C%2010%2C%2011%2C%2012%20are%20shorted%20for%203S%20configuration.%3C%2FP%3E%3CP%3E3S%20LiPo%20battery%20is%20connected%20to%20J4%20and%20their%20cell%20balancing%20wires%20connected%20to%20JP1%3C%2FP%3E%3CP%3Epins%205%2C%204%2C%201%20of%20FTDI%20USB%20UART%20are%20connected%20to%20pins%202%2C%203%2C%207%20of%20J19%20respectively%20and%20then%20connected%20to%20PC%3C%2FP%3E%3CP%3E115k2%208n1%2C%20Parity%3A%20None%2C%20Flow%3A%20None%20configured%20in%20COM%20port%20properties%20and%20Tera%20Term%3C%2FP%3E%3CP%3EThe%20result%20is%20as%20follows%2C%3C%2FP%3E%3CP%3EBMS%20LED%20is%20blinking%20in%20red%20colour%20and%20then%20goes%20OFF%20after%20around%201min.%20I%20think%20it%20goes%20to%20SLEEP.%3C%2FP%3E%3CP%3EBMS%20output%20voltage%20at%20J5%20is%20zero%20(load%20is%20not%20connected)%3C%2FP%3E%3CP%3ETera%20Term%20window%20displays%20blank%20screen%20and%20doesn't%20take%20keyboard%20input%3C%2FP%3E%3CP%3EDisplay%20connected%20to%20J23%20doesn't%20turn%20ON%3C%2FP%3E%3CP%3EKindly%20help%20me%20in%20sorting%20out%20above%20issues.%3C%2FP%3E%3CP%3EI%20tried%20the%20same%20things%20on%20another%20BMS%2C%20in%20which%20LED%20doesn't%20turn%20ON%20and%20SBC%20chip%20is%20getting%20over%20heated.%3C%2FP%3E%3CP%3EThanks..%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1596441%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1596441%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDoes%20anyone%20know%20where%20can%20I%20purchase%20other%20suitable%20debugger%20for%20NXP%20RDDRONE-BMS%20apart%20from%20J-Link%20or%20PEMicro%20%3F%3F%20Thank%20you.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1594395%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1594395%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3CSPAN%20class%3D%22%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F90400%22%20target%3D%22_self%22%3E%3CSPAN%20class%3D%22%22%3EGeraldP%3C%2FSPAN%3E%3C%2FA%3E%3C%2FSPAN%3E%2C%3C%2FP%3E%3CP%3EThanks%20for%20your%20help.%20I%20will%20try%20the%20way%20you%20suggested.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1594197%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1594197%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F195015%22%20target%3D%22_blank%22%3E%40Prince1%3C%2FA%3E%2C%20the%20SW%20will%20just%20report%20an%20error%20and%20power%20out%20will%20be%20not%20enabled%20if%20you%20have%20a%20battery%20connected%20that%20has%20different%20cell%20numbering%20than%20configured.%3CBR%20%2F%3EBattery%20needs%20to%20be%20connected%20to%20be%20able%20to%20configure%20the%20BMS.%3CBR%20%2F%3ESo%20the%20way%20to%20setup%20the%20BMS%20is%3A%3CBR%20%2F%3E-%20connect%20your%20UART%20adapter%20and%20open%20terminal%20SW%20with%20115k2%208n1%20serial%20port%20setting.%3CBR%20%2F%3E-%20Connect%20balancer%20and%20main%20power%20connector%20of%20battery%20to%20the%20BMS%3CBR%20%2F%3E-%20see%20bootup%20sequence%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fnxp.gitbook.io%2Frddrone-bms772%2Fsoftware-guide-nuttx%2Ffirst-start-up%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EFirst%20start-up%20-%20RDDRONE-BMS772%20(gitbook.io)%3C%2FA%3E%3CBR%20%2F%3E-%20configure%20the%20bms%20via%20command%20line%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fnxp.gitbook.io%2Frddrone-bms772%2Fsoftware-guide-nuttx%2Fcommand-line-interface-cli%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ECommand%20Line%20Interface%20(CLI)%20-%20RDDRONE-BMS772%20(gitbook.io)%3C%2FA%3E%26nbsp%3B%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3Bbms%20set%20%3CPARAMETER%20name%3D%22%22%3E%20%3CVALUE%3E%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fnxp.gitbook.io%2Frddrone-bms772%2Fsoftware-guide-nuttx%2Funtitled-1%23bms-configuration-parameters-list%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EParameters%20of%20the%20BMS%20-%20RDDRONE-BMS772%20(gitbook.io)%3C%2FA%3E%3CBR%20%2F%3E-%20finish%20with%20bms%20save%3CBR%20%2F%3Eif%20you%20type%20reboot%20the%20BMS%20will%20reboot%20with%20correct%20settings%20and%20will%20activate%20output%20in%20case%20no%20errors.%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FVALUE%3E%3C%2FPARAMETER%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1593928%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1593928%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EI%20have%20%3CSTRONG%3E%3CFONT%20size%3D%223%22%3EPL2303HX%20USB%20To%20TTL(Serial)%20Converter%20%3C%2FFONT%3E%3C%2FSTRONG%3E%3CFONT%20size%3D%223%22%3Ewhich%20provides%203.3V%20on%3C%2FFONT%3E%20Tx%2C%20Rx%20and%20GND.%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Frobu.in%2Fproduct%2Fpl2303-pl2303hx-usb-ttl-module-5-pin%2F%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Frobu.in%2Fproduct%2Fpl2303-pl2303hx-usb-ttl-module-5-pin%2F%3C%2FA%3E%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CP%3EWith%20this%20Can%20I%20attempt%20software%20reconfiguration%3F%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CFONT%20size%3D%223%22%3EPL2303HX%3C%2FFONT%3E%3C%2FSTRONG%3E%20will%20be%20inserted%20in%20USB%20port%20and%20its%20TX%2C%20RX%2C%20GND%20pins%20are%20connected%20to%20respective%20pins%20in%20J19%20port.%20Do%20I%20need%20to%20connect%20battery%20also%20to%20BMS%20(to%20J4)%20to%20power%20it's%20circuit%3F%20If%20so%2C%204S%20or%203S%20battery%3F%3C%2FP%3E%3CP%3EAs%20in%20my%20BMS%2C%204S%20cell%20terminal%20connector%20is%20soldered%20in%20JP1%20and%20SJ3%2C%20SJ7%2C%20SJ11%20and%20SJ12%20are%20connected%2C%20but%20its%20factory%20default%20configuration%20in%20software%20is%203S.%20So%2C%20I%20am%20confused.%3C%2FP%3E%3CP%3EThanks..%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1586545%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1586545%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F195015%22%20target%3D%22_blank%22%3E%40Prince1%3C%2FA%3E%2C%26nbsp%3B%3C%2FP%3E%0A%3CP%3EYes%20you%20only%20need%20to%20connect%20GND%2C%20TX%20and%20RX%20as%20seen%20in%20this%20screenshot%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22cisvmierlo_0-1674467103221.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cisvmierlo_0-1674467103221.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cisvmierlo_0-1674467103221.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cisvmierlo_0-1674467103221.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cisvmierlo_0-1674467103221.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cisvmierlo_0-1674467103221.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cisvmierlo_0-1674467103221.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cisvmierlo_0-1674467103221.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cisvmierlo_0-1674467103221.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22cisvmierlo_0-1674467103221.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F208136i231AF9CF29015C16%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22cisvmierlo_0-1674467103221.png%22%20alt%3D%22cisvmierlo_0-1674467103221.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Ecisvmierlo_0-1674467103221.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3EKeep%20in%20mind%20that%20a%26nbsp%3B%3CSPAN%20data-slate-fragment%3D%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%22%3EUSB-TTL-%3CSTRONG%3E3V3%26nbsp%3B%3C%2FSTRONG%3Eis%20used%2C%20this%20ensures%203.3V%20logic%20level%20on%20the%20RX%20and%20TX%20pins.%3CBR%20%2F%3E%3CBR%20%2F%3EKind%20regards%2C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20data-slate-fragment%3D%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%22%3ECis%20van%20Mierlo%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1586527%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1586527%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3Eiaingalloway%3C%2FSPAN%3E%3C%2FSPAN%3E%2C%3C%2FP%3E%3CP%3EThanks%20for%20your%20reply.%3C%2FP%3E%3CP%3EI%20want%20to%20change%20the%20BMS%20configuration%20from%20default%203S%20to%204S%20and%20also%20change%20battery%20chemistry%20through%20serial%20console.%20Is%20FTDI%20type%20USB-UART%20cable%20connected%20to%20JST%20GH%207%20pin%20connector%20(only%20Tx%2C%20Rx%2C%20GND%20pins)%20is%20sufficient%20for%20this%3F%3C%2FP%3E%3CP%3EI%20am%20also%20trying%20to%20get%20J%20link%20EDU%20mini%20debugger%20to%20update%20firmware%2C%20but%20it's%20lead%20time%20is%2040%20weeks.%20So%2C%20Just%20trying%20to%20update%20configuration%20parameters%20as%20of%20now.%3C%2FP%3E%3CP%3EThanks..%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1586201%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1586201%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20know%20this%20is%20now%20an%20old%20post%2C%20but%20I've%20cross%20posted%20and%26nbsp%3B%20asked%20the%20model%20based%20design%20team%20to%20have%20a%20look%20here.%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FModel-Based-Design-Toolbox-MBDT%2FRDDRONE-BMS771-MBDT-question%2Fm-p%2F1586198%23M7996%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FModel-Based-Design-Toolbox-MBDT%2FRDDRONE-BMS771-MBDT-question%2Fm-p%2F1586198%23M7996%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1586193%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1586193%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ENote%20also%20there%20has%20been%20some%20work%20done%20in%20NuttX%2FPX4%20on%20CAN%20bootloaders.%20But%20these%20are%20incomplete%20at%20this%20time.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1586179%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1586179%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20wanted%20to%20note%20that%20there%20are%20also%20additional%20GPIO%20on%20the%20board%20that%20were%20allocated%20for%20this%20type%20of%20function%20to%20be%20added%20in%20the%20future%20as%20per%20a%20proposed%20DroneCode%20standard.%20There%20were%20some%20other%20potential%20for%20added%20features%20here%2C%20including%20identifying%20the%20battery%20to%20the%20vehicle%20etc.%3CBR%20%2F%3E%3CBR%20%2F%3EIn%20addition%20to%20code%20needing%20to%20be%20written%2C%3CBR%20%2F%3EThese%20are%20located%20on%20a%20separate%20header%20and%20would%20need%20to%20be%20asserted%20on%20plugging%20in%20the%20battery%20to%20a%20drone%20or%20vehicle.%26nbsp%3B%3CBR%20%2F%3EYou%20will%20need%20to%20refer%20to%20the%20schematics%20on%20NXP.com%20for%20the%20details.%3C%2FP%3E%0A%3CP%3EI%20am%20referring%20to%20the%20header%20J21%20here%3A%3C%2FP%3E%0A%3CDIV%20id%3D%22tinyMceEditoriaingalloway_0%22%20class%3D%22mceNonEditable%20lia-copypaste-placeholder%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22iaingalloway_2-1674236410319.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_2-1674236410319.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_2-1674236410319.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_2-1674236410319.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_2-1674236410319.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_2-1674236410319.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_2-1674236410319.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_2-1674236410319.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_2-1674236410319.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_2-1674236410319.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F208066i4CA12BCA40A012A6%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22iaingalloway_2-1674236410319.png%22%20alt%3D%22iaingalloway_2-1674236410319.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Eiaingalloway_2-1674236410319.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22iaingalloway_3-1674236426257.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_3-1674236426257.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_3-1674236426257.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_3-1674236426257.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_3-1674236426257.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_3-1674236426257.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_3-1674236426257.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_3-1674236426257.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_3-1674236426257.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_3-1674236426257.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F208067i7CB2E73936BFA44F%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22iaingalloway_3-1674236426257.png%22%20alt%3D%22iaingalloway_3-1674236426257.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Eiaingalloway_3-1674236426257.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CDIV%20id%3D%22tinyMceEditoriaingalloway_1%22%20class%3D%22mceNonEditable%20lia-copypaste-placeholder%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1586168%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1586168%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ENote%20that%20if%20you%20want%20to%20just%20use%20the%20serial%20console%20to%20see%20what%20is%20going%20on%20internally%20(and%20not%20reprogram%20and%20debug%20the%20board)%20Then%20you%20can%20buy%20any%20FTDI%20type%20USB-UART%20cable%20(or%20use%20a%20PC%20with%20a%20UART)%20to%20connect%20a%20serial%20console%20to%20the%20BMS772.%20Normally%20this%20is%20broken%20out%20on%20the%20DCD-LZ%20board%20so%20it%20can%20be%20plugged%20in%20easily.%3CBR%20%2F%3E%3CBR%20%2F%3EHere%20is%20the%20type%20of%20cable%20you%20would%20buy%20at%20Amazon%20or%20Digikey%20or%20whereever%3A%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fwww.digikey.com%2Fen%2Fproducts%2Fdetail%2Fftdi-future-technology-devices-international-ltd%2FTTL-234X-3V3%2F6823715%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.digikey.com%2Fen%2Fproducts%2Fdetail%2Fftdi-future-technology-devices-international-ltd%2FTTL-234X-3V3%2F6823715%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22iaingalloway_0-1674235896394.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_0-1674235896394.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_0-1674235896394.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_0-1674235896394.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_0-1674235896394.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_0-1674235896394.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_0-1674235896394.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_0-1674235896394.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_0-1674235896394.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_0-1674235896394.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F208063i084ED54D9FB16F5E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22iaingalloway_0-1674235896394.png%22%20alt%3D%22iaingalloway_0-1674235896394.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Eiaingalloway_0-1674235896394.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3EYou%20would%20then%20use%20a%20JST-GH%20connector%20to%20attach%20to%20the%20RX%20TX%20and%20GND%20pins%20of%20the%20DCD-LZ%20interface%20on%20the%20BMS%20-%20%3CSTRONG%3Edo%20NOT%20connect%20the%20power%20from%20the%20FTDI%20cable%20to%20the%20DCD-LZ%3C%2FSTRONG%3E%3A%3CBR%20%2F%3EThe%20pinout%20is%20shown%20here%3A%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fnxp.gitbook.io%2Fhovergames%2Frddrone-fmuk66%2Fconnectors%2Fdebug-interface-dcd-lz%2Fdcd-lz-breakout-board%23pinout%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fnxp.gitbook.io%2Fhovergames%2Frddrone-fmuk66%2Fconnectors%2Fdebug-interface-dcd-lz%2Fdcd-lz-breakout-board%23pinout%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1582513%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1582513%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThank%20you%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%3C%2FA%3E.%3C%2FP%3E%3CP%3EVery%20useful%20information.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1581963%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1581963%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ENote%20you%20will%20need%20a%200.50%22%20header%20to%20solder%20into%20J2%20if%20you%20want%20to%20use%20it.%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1581962%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1581962%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22iaingalloway_0-1673558852262.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_0-1673558852262.png%22%20style%3D%22width%3A%20388px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_0-1673558852262.png%22%20style%3D%22width%3A%20388px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_0-1673558852262.png%22%20style%3D%22width%3A%20388px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_0-1673558852262.png%22%20style%3D%22width%3A%20388px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_0-1673558852262.png%22%20style%3D%22width%3A%20388px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_0-1673558852262.png%22%20style%3D%22width%3A%20388px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_0-1673558852262.png%22%20style%3D%22width%3A%20388px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_0-1673558852262.png%22%20style%3D%22width%3A%20388px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22iaingalloway_0-1673558852262.png%22%20style%3D%22width%3A%20388px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F207150i2EFE104225F00316%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22iaingalloway_0-1673558852262.png%22%20alt%3D%22iaingalloway_0-1673558852262.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Eiaingalloway_0-1673558852262.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EJ2%20is%20a%20socket%20for%20a%20standard%2010%2F9%20pin%20debug%20header%20that%20will%20work%20with%20any%20Segger%20JLINK%20device.%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3EYou%20can%20also%20make%20a%20cable%20to%20plug%20into%20the%20DCDLZ%20port%20and%20connect%20to%20a%20FTDI%203v3%20USB2UART%20cable.%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fwww.amazon.com%2FPre-Crimped-Connectors-Pixhawk2-Pixracer-Silicone%2Fdp%2FB07PBHN7TM%2Fref%3Dsr_1_3%3Fcrid%3DGL7B8ZZMTG79%26amp%3Bkeywords%3Djst-gh%26amp%3Bqid%3D1673558988%26amp%3Bsprefix%3Djst-gh%252Caps%252C147%26amp%3Bsr%3D8-3%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.amazon.com%2FPre-Crimped-Connectors-Pixhawk2-Pixracer-Silicone%2Fdp%2FB07PBHN7TM%2Fref%3Dsr_1_3%3Fcrid%3DGL7B8ZZMTG79%26amp%3Bkeywords%3Djst-gh%26amp%3Bqid%3D1673558988%26amp%3Bsprefix%3Djst-gh%252Caps%252C147%26amp%3Bsr%3D8-3%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3EAs%20noted%2C%20these%20items%20are%20included%20with%20some%20of%20the%20other%20development%20kits%20and%20can%20be%20re-used%20here.%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1581811%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1581811%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F195015%22%20target%3D%22_blank%22%3E%40Prince1%3C%2FA%3E%2C%26nbsp%3B%3C%2FP%3E%0A%3CP%3ELet%20me%20check%20internally%20about%20the%20availability%20of%20this%20adapter%20board.%3CBR%20%2F%3EHere%20is%20some%20more%20information%20about%20the%20DCD-LZ%20adapter%20board%2C%20including%20the%20schematic%3A%26nbsp%3B%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fnxp.gitbook.io%2Fhovergames%2Frddrone-fmuk66%2Fconnectors%2Fdebug-interface-dcd-lz%2Fdcd-lz-breakout-board%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fnxp.gitbook.io%2Fhovergames%2Frddrone-fmuk66%2Fconnectors%2Fdebug-interface-dcd-lz%2Fdcd-lz-breakout-board%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EI%20do%20know%20that%20they%20are%20usually%20part%20of%20a%20kit%2C%20I%20did%20find%20this%20UCAN%20board%20where%20you%20have%20the%20option%20to%20buy%20the%20KIT-UCANS32K1SIC.%3CBR%20%2F%3EThis%20kit%20includes%202x%20DCD-LZ%20adapters%2C%202x%20FTDI-USB%20cable%20and%201x%26nbsp%3BSegger%20Jlink%20mini%20EDU%20debugger%20(program%20and%20debug)%20as%20well.%3CBR%20%2F%3E%3CBR%20%2F%3ELink%20to%20the%26nbsp%3BKIT-UCANS32K1SIC%3A%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Finterfaces%2Fcan-transceivers%2Fcan-signal-improvement%2Fcan-sic-evaluation-board%3AUCANS32K1SIC%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fproducts%2Finterfaces%2Fcan-transceivers%2Fcan-signal-improvement%2Fcan-sic-evaluation-board%3AUCANS32K1SIC%3C%2FA%3E%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3EKind%20regards%2C%3CBR%20%2F%3E%3CBR%20%2F%3ECis%20van%20Mierlo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1581747%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1581747%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F211084%22%20target%3D%22_blank%22%3E%40Airobot-Dynamics%3C%2FA%3E%2C%26nbsp%3B%3C%2FP%3E%0A%3CP%3EIn%20the%20following%20NXP%20community%20page%20it%20is%20stated%20that%20t%3CSPAN%3Ehe%20documentation%20and%20software%20is%20available%20on%20DocStore.%26nbsp%3BIt%20also%20explains%20how%20to%20get%20access%20to%20DocStore.%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%3ESo%20I%20believe%20the%20A1007%20is%20available%20under%20NDA%20only.%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSPAN%3ELink%20to%20the%20NXP%20community%20page%3A%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FOther-NXP-Products%2FOM67201UL-driver-A1007%2Fm-p%2F1447573%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FOther-NXP-Products%2FOM67201UL-driver-A1007%2Fm-p%2F1447573%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EIf%20you%20are%20looking%20to%20build%20something%20yourself%2C%20I%20would%20recommend%20to%20look%20at%20the%20common%20available%20NXP%20IoT%20Security%20and%20Authentication%20Portfolio%3A%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fiotsecurity%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fiotsecurity%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EFor%20example%2C%20the%20SE050%20or%20SE051%20is%20a%20greatly%20supported%20device%2C%20with%20lots%20of%20use%20cases%20already%20implemented.%3CBR%20%2F%3E%3CBR%20%2F%3EIf%20you%20would%20like%20to%20develop%20on%20a%20board%20with%20an%20SE050%20and%20a%20similar%20MCU%20(S32K146%20instead%20of%20S32K144).%20The%26nbsp%3B%3CSPAN%3EUCANS32K146%20might%20be%20an%20interesting%20product.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3ELink%20to%20the%20SE050%3A%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fsecurity-and-authentication%2Fauthentication%2Fedgelock-se050-plug-trust-secure-element-family-enhanced-iot-security-with-high-flexibility%3ASE050%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fproducts%2Fsecurity-and-authentication%2Fauthentication%2Fedgelock-se050-plug-trust-secure-element-family-enhanced-iot-security-with-high-flexibility%3ASE050%3C%2FA%3E%26nbsp%3B%3CBR%20%2F%3ELink%20to%20the%20%3CSPAN%3EUCANS32K146%3C%2FSPAN%3E%3A%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdevelopment-boards%2Fautomotive-development-platforms%2Fs32k-mcu-platforms%2Fs32k146-uavcan-v1-and-mavcan-development-system%3AUCANS32K146%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdevelopment-boards%2Fautomotive-development-platforms%2Fs32k-mcu-platforms%2Fs32k146-uavcan-v1-and-mavcan-development-system%3AUCANS32K146%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EI%20hope%20this%20answers%20your%20questions%2C%20kind%20regards%2C%3C%2FP%3E%0A%3CP%3ECis%20van%20Mierlo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1580845%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1580845%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EA1007%20Secure%20Authenticator%3C%2FP%3E%3CP%3EHi%20community%2C%20I%20have%20just%20started%20developing%20with%20the%20BMS772.%20However%2C%20I%20can%20not%20find%20any%20information%20on%20the%20A1007%20IC.%3C%2FP%3E%3CP%3EI%20can%20not%20even%20find%20this%20IC%20on%20the%20NXP%20site%20of%20any%20of%20our%20usual%20suppliers%2C%20Digi-Key%20etc.%26nbsp%3B%3CBR%20%2F%3EIs%20this%20IC%20obsolete%3F%26nbsp%3B%3C%2FP%3E%3CP%3EIf%20so%2C%20are%20there%20any%20suggested%20alternative.%3C%2FP%3E%3CP%3EThanks%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1580776%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1580776%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EThanks%20for%20your%20quick%20reply.%20Unfortunately%2C%20I%20couldn't%20find%20distributor%20to%20purchase%20DCD-LZ%20adapter%20in%20India.%20I%20don't%20have%20a%20hover%20games%20kit%20as%20well.%3C%2FP%3E%3CP%3ECan%20you%20suggest%20any%20alternative%20adapter%20which%20is%20widely%20available%3F%3C%2FP%3E%3CP%3EThanks.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1579322%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1579322%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F195015%22%20target%3D%22_blank%22%3E%40Prince1%3C%2FA%3E%2C%3C%2FP%3E%3CP%3EIndeed%20you%20would%20need%20to%20configure%20the%20software%20accordingly.%3CBR%20%2F%3E%3CBR%20%2F%3EThis%20can%20be%20done%20as%20followed%3A%3C%2FP%3E%3CP%3E1.%20Hook%20up%20the%20DCD-LZ%20adapter%20to%20the%20BMS772%20board%20using%20the%207-pins%20JST-GH%20cable.%26nbsp%3B%3CBR%20%2F%3E2.%20Hook%20up%20the%20DCD-LZ%20adapter%20to%20a%20laptop%20or%20PC%20with%20a%20FTDI%20USBUART-3V3%20cable.%26nbsp%3B%3CBR%20%2F%3E3.%20Connect%20to%20the%20BMS772%20over%20a%20serial%20interface%2C%20like%20PuTTY%20or%20TeraTerm%20(%3CSPAN%3E115200%20Baud)%3C%2FSPAN%3E.%3CBR%20%2F%3E4.%20Type%20%22bms%20help%22%20to%20get%20the%20help%20for%20the%20Command%20Line%20Interface%20(CLI).%3CBR%20%2F%3E5.%20Type%20%22bms%20get%20all%22%20to%20get%20all%20the%20parameters%20and%20the%20values%20associated%20with%20those%20parameters.%3CBR%20%2F%3E6.%20Change%20the%20variable%20you%20would%20like%20to%20change%2C%20in%20this%20case%20n-cells%20to%204%2C%20type%3A%20%22bms%20set%20n-cells%204%22%26nbsp%3B%3CBR%20%2F%3E7.%20To%20make%20sure%20the%20parameters%20are%20saved%20to%20flash%2C%20type%3A%20%22bms%20save%22%26nbsp%3B%3CBR%20%2F%3E8.%20After%20the%20new%20parameter%20settings%2C%20you%20could%20either%20press%20the%20button%20or%20type%3A%20%22bms%20reset%22%20to%20reset%20the%20fault.%3CBR%20%2F%3E%3CBR%20%2F%3EThe%20CLI%20is%20very%20useful%20as%20it%20will%20indicate%20what%20caused%20the%20error.%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3EHere%20are%20some%20useful%20links%20to%20get%20started%3A%3CBR%20%2F%3EA%20link%20about%20setting%20up%20the%20CLI%3A%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fnxp.gitbook.io%2Frddrone-bms772%2Fuser-guide%2Fgetting-started-with-the-rddrone-bms772%2Fusing-the-command-line-interface-cli%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fnxp.gitbook.io%2Frddrone-bms772%2Fuser-guide%2Fgetting-started-with-the-rddrone-bms772%2Fusing-the-command-line-interface-cli%3C%2FA%3E%26nbsp%3B%3CBR%20%2F%3EA%20link%20about%20using%20the%20CLI%3A%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fnxp.gitbook.io%2Frddrone-bms772%2Fsoftware-guide-nuttx%2Fcommand-line-interface-cli%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fnxp.gitbook.io%2Frddrone-bms772%2Fsoftware-guide-nuttx%2Fcommand-line-interface-cli%3C%2FA%3E%26nbsp%3B%3CBR%20%2F%3EA%20link%20with%20a%20list%20of%20parameters%3A%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fnxp.gitbook.io%2Frddrone-bms772%2Fsoftware-guide-nuttx%2Funtitled-1%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fnxp.gitbook.io%2Frddrone-bms772%2Fsoftware-guide-nuttx%2Funtitled-1%3C%2FA%3E%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3EChapter%207%20of%20the%20release%20notes%20(rev.%205)%20is%20useful%20as%20well%20as%20this%20contains%20a%20picture%20of%20the%20DCD-LZ%20adapter%20with%20the%207-pins%20JST%20GH%20cable%20and%20the%20USB-TTL-3V3%20cable%20connected%20to%20it.%3CBR%20%2F%3EChapter%208%20includes%20the%20parameters%20of%20the%20BMS772.%3CBR%20%2F%3E%3CBR%20%2F%3EI%20would%20recommend%20the%20update%20the%20software%20to%20the%20latest%20binary.%26nbsp%3B%3CBR%20%2F%3EThe%20latest%20binary%20can%20be%20found%20at%3A%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2Ftree%2Fmain%2FBinary%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2Ftree%2Fmain%2FBinary%3C%2FA%3E%26nbsp%3B%3CBR%20%2F%3EInstructions%20can%20be%20found%20in%20chapter%207%20of%20the%20release%20notes%2C%20on%20the%20code%20repository%20or%20on%20the%20gitbook%3A%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fnxp.gitbook.io%2Frddrone-bms772%2Fuser-guide%2Fgetting-started-with-the-rddrone-bms772%2Fflashing-firmware-to-the-rddrone-bms772%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fnxp.gitbook.io%2Frddrone-bms772%2Fuser-guide%2Fgetting-started-with-the-rddrone-bms772%2Fflashing-firmware-to-the-rddrone-bms772%3C%2FA%3E%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3EKeep%20in%20mind%20that%20after%20programming%2C%20you%20need%20to%20re-configure%20the%20parameters%20again%20as%20these%20get%20overwritten.%3C%2FP%3E%3CP%3EI%20hope%20this%20helps%2C%20kind%20regards%2C%3C%2FP%3E%3CP%3ECis%20van%20Mierlo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1579306%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1579306%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSTRONG%3EHi%2C%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EI%20bought%20a%20new%20RDDRONE-BMS772%20board%20and%20want%20to%20use%20it%20for%204S%20LiPo%20battery%20pack.%20I%20have%20soldered%20Cell%20terminal%20connector%20and%20Solder%20jumper%20pins%20(SJ)%20for%204S.%20After%20connecting%20to%204S%20pack%2C%20When%20I%20measured%20the%20output%20voltage%20it%20is%200V.%20I%20don't%20know%20why.%3C%2FP%3E%3CP%3EShall%20I%20do%20any%20configuration%20change(for%204S)%20in%20the%20software%20also%3F%20If%20so%2C%20how%3F%20Please%20reply.%3C%2FP%3E%3CP%3EThanks%20in%20advance.%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1558683%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1558683%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F209164%22%20target%3D%22_blank%22%3E%40Ch_Han%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EWhen%20the%20BMS%20is%20in%20the%20DEEP_SLEEP%20state%20it%20needs%20to%20limit%20the%20power%20the%20BMS%20is%20using%20itself%2C%20in%20order%20to%20preserve%20the%20battery%20the%20most.%3C%2FP%3E%0A%3CP%3EThis%20is%20done%20by%20setting%20the%20components%20powered%20by%20the%20battery%20in%20a%20deepsleep%20%2F%20sleep%20state%20as%20well%20and%20by%20disabling%20the%20voltage%20domains%20(3.3V%20and%205V%20are%20turned%20off)%2C%20amongst%20others%2C%20powering%20off%20the%20microcontroller%2C%20which%20is%20supplied%20by%20this%203.3V.%3C%2FP%3E%0A%3CP%3ETo%20initiate%20a%20wake%20for%20the%20SBC%20(to%20turn%20on%20the%203.3V%20again%20which%20will%20power%20the%20microcontroller)%2C%20I%20believe%20the%20SW%20has%20only%20configured%20that%20the%20wake%20pin%20of%20the%20SBC%2C%20issues%20an%20SBC%20wake.%20To%20do%20that%2C%20the%20button%20needs%20to%20be%20pressed%20or%20J22%20needs%20to%20be%20shorted.%3C%2FP%3E%0A%3CP%3EBut%20I%20do%20believe%20a%20wake-up%20via%20CAN%20could%20be%20enabled%20in%20the%20SW%2C%20as%20the%20SBC%20is%20in%20a%20sleep%20state%20and%20still%20powered%20by%20the%20battery.%20This%20is%20however%20not%20enabled%20by%20the%20current%20SW%20example%20and%20I%20do%20not%20know%20the%20HW%20requirements%20for%20this.%3C%2FP%3E%0A%3CP%3EIf%20you%20would%20like%20to%20add%20this%20functionality%2C%20you%20could%20check%20the%20datasheet%20of%20the%20SBC%20and%20the%20sbc.c%20and%20sbc.h%20files%20of%20the%20public%20BMS%20SW%20example%20for%20this%20board.%3CBR%20%2F%3EThe%20datasheet%20of%20the%20SBC%20can%20be%20found%20here%3A%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fpower-management%2Fpmics-and-sbcs%2Fmini-sbcs%2Fmini-high-speed-can-system-basis-chip%3AUJA1169ATK%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fproducts%2Fpower-management%2Fpmics-and-sbcs%2Fmini-sbcs%2Fmini-high-speed-can-system-basis-chip%3AUJA1169ATK%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EKind%20regards%2C%3C%2FP%3E%0A%3CP%3Ecisvmierlo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1558599%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1558599%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThank%20you%20for%20your%20answer.%3C%2FP%3E%3CP%3EThen%20if%20the%20battery%20is%20in%20storage%20with%20the%20BMS%20in%20DEEPSLEEP%20state%2C%20can%20the%20BMS%20detect%20when%20the%20output%20is%20connected%20to%20go%20back%20to%20NORMAL%20or%20is%20the%20only%20way%20out%20of%20DEEPSLEEP%20by%20pushing%20the%20button%3F%3C%2FP%3E%3CP%3ERegards%2C%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1558555%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1558555%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F196312%22%20target%3D%22_blank%22%3E%40OGUZ1%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EI%20wanted%20to%20let%20you%20know%20that%20the%20RDDRONE-BMS772%20board%20is%20now%20supported%20in%20the%20NXP%20Model-Based%20Design%20Toolbox%20(MBDT)%20for%20S32K1xx%20-%20version%204.3.0.%3C%2FP%3E%0A%3CP%3EHere%20is%20the%26nbsp%3B%3CSPAN%3EProduct%20Release%20Announcement%3A%26nbsp%3B%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Model-Based-Design-Tools%2FNXP-Model-Based-Design-Toolbox-for-S32K1xx-MCUs-version-4-3-0%2Fta-p%2F1549163%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Model-Based-Design-Tools%2FNXP-Model-Based-Design-Toolbox-for-S32K1xx-MCUs-version-4-3-0%2Fta-p%2F1549163%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThe%20NXP%20MBDT%20includes%20an%20integrated%20Simulink%3CSUP%3E%C2%AE%3C%2FSUP%3E-embedded%20target%20supporting%20NXP%20MCUs%20for%20direct%20rapid%20prototyping%20and%20built-in%20support%20for%20software-%20and%20processor-in-the-loop%20(SIL%20and%20PIL)%20development.%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fautomotive-software-and-tools%2Fmodel-based-design-toolbox-mbdt%3AMBDT%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdesign%2Fautomotive-software-and-tools%2Fmodel-based-design-toolbox-mbdt%3AMBDT%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EKind%20regards!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1558534%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1558534%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F209164%22%20target%3D%22_blank%22%3E%40Ch_Han%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EPlease%20see%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CA%20title%3D%22https%3A%2F%2Fgithub.com%2Fnxphovergames%2Frddrone-bms772%2F%22%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2F%22%20target%3D%22_blank%22%20rel%3D%22noopener%20noreferrer%20nofollow%22%3Ehttps%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2F%3C%2FA%3E%3CSPAN%3E%26nbsp%3Bfor%20the%20release%20notes.%20This%20describes%20the%20state%20machine%20of%20the%20BMS%20example%20software.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EThe%20SLEEP%20state%20is%20not%20for%20storage%2C%20as%20in%20this%20example%20the%20output%20power%20is%20still%20enabled%20in%20this%20SLEEP%20state.%20For%20storage%2C%20the%20BMS%20should%20indeed%20go%20to%20the%20DEEPSLEEP%20state%2C%20where%20the%20output%20power%20is%20disabled%20(power%20switch%20is%20open)%20and%20the%20current%20is%20as%20little%20as%20possible.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EIn%20chapter%208%20of%20the%20release%20notes%2C%20the%20parameters%20are%20described%20to%20control%20the%20BMS.%20If%20you%20set%20parameter%20self-discharge-enable%20to%200.%20You%20could%20go%20to%20the%20DEEPSLEEP%20state%20without%20discharging%20the%20battery%20cells%20to%20storage%20voltage.%20Keep%20in%20mind%20that%20this%20might%20not%20be%20good%20for%20the%20battery%20cells%20if%20they%20are%20at%20a%20high%20voltage%20for%20a%20long%20time.%3C%2FP%3E%0A%3CP%3EIn%20the%20self-discharge%20state%2C%20the%20BMS%20will%20use%20the%20balancing%20current%20to%20discharge%20all%20the%20cells%20to%20be%20less%20than%20the%20set%20storage%20voltage%20(with%20margin).%3C%2FP%3E%0A%3CP%3EIn%20SLEEP%20state%2C%20the%20switch%20is%20always%20closed%20in%20this%20example%2C%20enabling%20the%20output%20power.%20Thus%2C%20it%20could%20detect%20a%20load%20by%20measuring%20current.%3CBR%20%2F%3E%3CBR%20%2F%3EI%20usually%20work%20with%20a%20lab%20power%20supply%20to%20charge%20the%20batteries.%3C%2FP%3E%0A%3CP%3EPS%3A%20You%20could%20develop%20your%20own%20software%20or%20adapt%20the%20SW%20for%20your%20needs%20based%20on%20the%20open%20source%20example%20on%26nbsp%3B%3CA%20title%3D%22https%3A%2F%2Fgithub.com%2Fnxphovergames%2Frddrone-bms772%2F%22%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2F%22%20target%3D%22_blank%22%20rel%3D%22noopener%20noreferrer%20nofollow%22%3Ehttps%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2F%3C%2FA%3E.%3C%2FP%3E%0A%3CP%3EHopefully%20this%20answers%20your%20questions%2C%20kind%20regards%2C%3C%2FP%3E%0A%3CP%3Ecisvmierlo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1558484%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1558484%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F15914%22%20target%3D%22_blank%22%3E%40iaingalloway%3C%2FA%3E%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%3CP%3EI%20plan%20to%20use%20the%20BMS772%20with%206s%20LiPo%20batteries%2C%20and%20have%20questions%20concerning%20the%20charge%20and%20discharge.%3C%2FP%3E%3CP%3E1-%20Is%20there%20a%20way%20to%20store%20the%20batteries%20without%20discharging%3F%20I%20see%20that%20before%20going%20into%20DEEPSLEEP%20state%20where%20the%20gates%20are%20open%2C%20the%20BMS%20must%20go%20through%20a%20SELF-DISCHARGE%20state%3B%20or%20if%20the%20BMS%20is%20in%20SLEEP%20state%20the%20gates%20are%20closed%20which%20also%20leads%20to%20discharging.%3C%2FP%3E%3CP%3E2-%20What%20is%20the%20physical%20process%20of%20the%20self-discharge%3F%3C%2FP%3E%3CP%3E3-%20Has%20measuring%20the%20impedance%20through%20CAN%20been%20thought%20of%20to%20detect%20if%20an%20output%20is%20connected%3F%20For%20example%20to%20know%20if%20gates%20should%20be%20open%20or%20closed%20in%20SLEEP%20state.%3C%2FP%3E%3CP%3E4-%20Is%20there%20a%20recommended%20charger%20to%20charge%20the%20batteries%20with%20a%20limited%20current%3F%20Or%20at%20least%20which%20one%20do%20you%20use%20usually%3F%3C%2FP%3E%3CP%3EThank%20you.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1434088%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1434088%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F198622%22%20target%3D%22_blank%22%3E%40vikrantj%3C%2FA%3E%2C%3C%2FP%3E%3CP%3ESince%20you%20are%20doing%20this%20for%20a%20school%20project%2C%20I%20think%20you%20are%20able%20to%20buy%20a%20J-Link%20EDU%20(mini).%3CBR%20%2F%3EThis%20is%20a%20cheaper%20version%20of%20the%20normal%20J-Link%20meant%20for%20educational%20purposes.%3CBR%20%2F%3E%3CBR%20%2F%3EHere%20is%20a%20guide%20on%20how%20to%20use%20the%20J-Link%20EDU%20(mini)%20to%20flash%20the%20RDDRONE-BMS772%3A%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fnxp.gitbook.io%2Fnxpmobilerobotics%2Fflashing-guide%2Fflashing-hovergames-boards%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fnxp.gitbook.io%2Fnxpmobilerobotics%2Fflashing-guide%2Fflashing-hovergames-boards.%26nbsp%3B%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3EWould%20this%20help%20you%3F%3CBR%20%2F%3E%3CBR%20%2F%3EKind%20regards%2C%3C%2FP%3E%3CP%3ECis%20van%20Mierlo%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1433972%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1433972%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F198622%22%20target%3D%22_blank%22%3E%40vikrantj%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EI%20did%20not%20have%20the%20chance%20to%20use%20this%20board%20yet.%20But%20having%20a%20look%20at%20the%20schematic%2C%20the%20easiest%20way%20to%20flash%20this%20board%20directly%20from%20Simulink%20without%20using%20a%20JTAG%20all%20the%20time%20is%20to%20use%20the%20RAppID%20bootloader%2C%20over%20the%20UART.%20Of%20course%2C%20you%20have%20to%20flash%20the%20bootloader%20once%20using%20a%20JTAG%20but%20once%20you%20have%20the%20bootloader%20written%20in%20the%20flash%20memory%2C%20you%20can%20use%20the%20Serial%2C%20directly%20from%20Simulink.%3C%2FP%3E%0A%3CP%3EYou%20can%20find%20a%20suitable%20bootloader%20in%20the%20toolbox%2C%20under%26nbsp%3Btools%5CBootLoader%5CRBF_Files%20the%26nbsp%3B%20S32K144_S32DS_UART1_CAN0.rbf%20which%20uses%20the%20pins%20PTC6%20and%20PTC7%20over%20the%20DCD-LZ.%20And%20here%2C%20you%20can%20use%20an%20external%20USB2Serial%20converter.%3C%2FP%3E%0A%3CP%3EAlso%2C%20the%20CAN0%20can%20be%20used%20to%20deploy%20the%20code%20on%20the%20board%2C%20but%20you%20need%20to%20use%20the%20RAppID%20bootloader%20app%2C%20and%20a%20compatible%20CAN%20tool.%3C%2FP%3E%0A%3CP%3ELet%20me%20know%20if%20Serial%20is%20a%20good%20option%20for%20you.%3C%2FP%3E%0A%3CP%3ERegards%2C%3C%2FP%3E%0A%3CP%3EMarius%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1433750%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1433750%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%26nbsp%3B%3C%2FP%3E%3CP%3EI%20am%20using%20the%26nbsp%3BRDDRONE-BMS772%20to%20build%20a%203s%20li-ion%20cell%20cycler.%20I%20wanted%20to%20be%20able%20to%20flash%20the%20program%20to%20the%20S32K%20on%20the%20board%20using%20a%20CAN%20bus.%20I%20was%20wondering%20if%20there%20is%20any%20way%20to%20do%20this.%20Or%20is%20using%20a%20debugger%20the%20only%20way%20to%20flash%20the%20program%3F%20If%20there%20are%20any%20other%20alternatives%20you%20could%20suggest%20I%20would%20appreciate%20it.%20This%20is%20for%20a%20school%20project%20and%20hence%20I%20need%20to%20keep%20the%20costs%20(and%20the%20complexity)%20low.%26nbsp%3B%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F196312%22%20target%3D%22_blank%22%3E%40OGUZ1%3C%2FA%3E%26nbsp%3B%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F15914%22%20target%3D%22_blank%22%3E%40iaingalloway%3C%2FA%3E%2C%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F72088%22%20target%3D%22_blank%22%3E%40mariuslucianand%3C%2FA%3E%26nbsp%3B%20I%20would%20love%20to%20know%20your%20thoughts%20about%20this.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1420015%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1420015%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3EThank%20you%20very%20much%20for%20your%20reply.%3C%2FP%3E%3CP%3EYes%2C%20I'm%20using%20SPI0%20but%20I%20can't%20see%20any%20effect.%20I%20always%20read%20something%20like%202.7Volt%20from%20pin%20V2.%20I%20always%20read%203.3%20volts%20from%20V1%20pin.%20I%20still%20read%20the%20same%20values%20when%20I%20press%20the%20reset%20button.%20I%20couldn't%20figure%20out%20what%20it%20means.%20I%20tried%20all%20the%20configurations.%20Vbat%20and%20Wake%20pins%20are%20the%20same%20value%20in%20SBC.%3CBR%20%2F%3EWhen%20I%20press%20reset%2C%20the%20Wake%20pin%20drops%20to%200.%203.3%20volts%20is%20always%20going%20to%20the%20SBCWake%20pin%20of%20the%20processor.%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F72088%22%20target%3D%22_blank%22%3E%3CFONT%3E%40mariuslucianand%3C%2FFONT%3E%3C%2FA%3E%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F176411%22%20target%3D%22_blank%22%3E%3CFONT%3E%40constantinrazva%3C%2FFONT%3E%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1419888%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1419888%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F196312%22%20target%3D%22_blank%22%3E%40OGUZ1%3C%2FA%3E%2C%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSPAN%3ESorry%20I%20do%20not%20have%20experience%20using%20MBDT%20in%20Matlab%20%2F%20Simulink.%3CBR%20%2F%3E%3CBR%20%2F%3EFor%20the%20help%20with%20the%20model%20based%20design%20toolbox%20and%20SBC%205V%20problems.%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F72088%22%20target%3D%22_blank%22%3E%40mariuslucianand%3C%2FA%3E%26nbsp%3Bcould%20you%20help%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F196312%22%20target%3D%22_blank%22%3E%40OGUZ1%3C%2FA%3E%26nbsp%3Bfurther%20with%20this%3F%3CBR%20%2F%3E%3CBR%20%2F%3EIt%20could%20be%20that%20the%20UJA1169%20configuration%20might%20be%20meant%20only%20for%20the%20S32K144%20evb%20board%2C%20which%20could%20be%20different%20than%20what%20should%20be%20used%20on%20the%20RDDRONE-BMS772.%3CBR%20%2F%3EFor%20example%2C%20on%20the%20S32k144%20evb%20LPSPI1%20is%20used%20to%20communicate%20with%20the%20SBC.%20%3CBR%20%2F%3EWhile%20on%20the%20RDDRONE-BMS772%20LPSPI0%20is%20used.%3CBR%20%2F%3ECould%20you%20verify%20that%20the%20correct%20SPI%20bus%200%20is%20used%20to%20communicate%20with%20the%20SBC%3F%3CBR%20%2F%3E%3CBR%20%2F%3EAccording%20to%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F176411%22%20target%3D%22_blank%22%3E%40constantinrazva%3C%2FA%3E%26nbsp%3Bthe%20SBC%20driver%20is%20located%20in%20the%20external%20devices.%3CBR%20%2F%3ECould%20you%20verify%20that%20you%20are%20using%20this%20SBC%20block%3F%3CBR%20%2F%3E%3CBR%20%2F%3EIf%20you%20are%20interested%20to%20see%20how%20to%20set%20the%20SBC%20using%20C%20code%2C%20here%20is%20an%20example%3A%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2Fblob%2Fmain%2Fsrc%2Fsbc.c%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2Fblob%2Fmain%2Fsrc%2Fsbc.c%3C%2FA%3E%3CBR%20%2F%3EThis%20enables%20the%205V%20in%20normal%20operation%20of%20the%20SBC.%26nbsp%3B%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EFor%20the%20display%2C%20we%20have%20example%20code%20how%20to%20use%20the%20display%20with%20the%20NuttX%20RTOS.%3CBR%20%2F%3ESee%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2Fblob%2Fmain%2Fsrc%2Fdisplay.c%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2Fblob%2Fmain%2Fsrc%2Fdisplay.c%3C%2FA%3E.%26nbsp%3B%3CBR%20%2F%3EIt%20uses%20the%20characters%20and%20drivers%20from%20this%20NuttX%20RTOS.%3CBR%20%2F%3E%3CBR%20%2F%3EThe%20display%20itself%20is%20a%20SSD1306%20I2C%20display%20that%20works%20at%20both%205V%20and%203.3V.%3CBR%20%2F%3EI%20believe%20there%20are%20many%20C%20examples%20of%20how%20to%20work%20with%20this%20kind%20of%20display.%26nbsp%3B%3CBR%20%2F%3EFor%20example%3A%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fadafruit%2FAdafruit_SSD1306%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fadafruit%2FAdafruit_SSD1306%3C%2FA%3E%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3EFor%20MATLAB%20maybe%20these%20sources%20would%20be%20able%20to%20help%20as%20well%3A%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fnl.mathworks.com%2Fmatlabcentral%2Ffileexchange%2F50766-ssd1306-hex-bitmap-creator%3Fs_tid%3Dsrchtitle%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fnl.mathworks.com%2Fmatlabcentral%2Ffileexchange%2F50766-ssd1306-hex-bitmap-creator%3Fs_tid%3Dsrchtitle%3C%2FA%3E%26nbsp%3Bor%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fnl.mathworks.com%2Fmatlabcentral%2Fanswers%2F512483-how-to-control-ssd1306-128x32-oled-display-in-matlab%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fnl.mathworks.com%2Fmatlabcentral%2Fanswers%2F512483-how-to-control-ssd1306-128x32-oled-display-in-matlab%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EKind%20regards%20and%20have%20a%20nice%20weekend%2C%3CBR%20%2F%3E%3CBR%20%2F%3ECis%20van%20Mierlo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1419827%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1419827%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F15914%22%20target%3D%22_blank%22%3E%40iaingalloway%3C%2FA%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%3C%2FA%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EI%20want%20to%20run%20the%20screen%20via%20Matlab%2FSimulink.%20Can%20you%20share%20any%20example%20with%20me%3F%20I%20can%20see%20the%20battery%20values%20with%20Matlab%2FSimulink.%20I%20want%20to%20use%20CAN%20communication%20but%20I%20still%20can't%20get%205V%20from%20SBC.%20I%20still%20could%20not%20get%205V%20output%20from%20SBC.%20Are%20you%20interested%20in%20me%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EBest%20Regards!%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1411597%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1411597%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F196312%22%20target%3D%22_blank%22%3E%40OGUZ1%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EPlease%20see%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CA%20title%3D%22https%3A%2F%2Fgithub.com%2Fnxphovergames%2Frddrone-bms772%2F%22%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2F%22%20target%3D%22_blank%22%20rel%3D%22noopener%20noreferrer%20nofollow%22%3Ehttps%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2F%3C%2FA%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3Efor%20the%20NuttX%20RDDRONE-BMS772%20BMS%20example.%26nbsp%3B%3CSPAN%3EDocumentation%2C%20source%20code%2C%20binary%20and%20a%20manual%20can%20all%20be%20found%20at%20that%20website.%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3EIt%20uses%20the%20POSIX%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3Ecompliant%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3BRTOS%20NuttX.%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3EThat%20example%20contains%20the%20things%20like%20SSD1306%20display%20support%20and%20configured%20SBC%20for%205V.%3C%2FSPAN%3E%3CSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EIf%20Matlab%2FSimulink%2C%20FREEMASTER%20or%20something%20else%20is%20used%20to%20re-program%20the%20boards%2C%20there%20might%20be%20different%20software%20running%20on%20the%20microcontroller%20and%20thus%20it%20won't%20have%20the%20correct%20behavior%20and%20functions.%20%3CSPAN%3EYou%20are%20free%20to%20re-program%20this%20board%2Fmicrocontroller%20with%20the%20software%20you%20want%20(or%20make!)%2C%20but%20make%20sure%20that%20what%20you%20program%20is%20what%20you%20are%20looking%20for.%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EIf%20you%20would%20like%20to%20create%20your%20software%2C%20you%20could%20create%20it%20based%20on%20sources%20from%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CA%20title%3D%22https%3A%2F%2Fgithub.com%2Fnxphovergames%2Frddrone-bms772%2F%22%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2F%22%20target%3D%22_blank%22%20rel%3D%22noopener%20noreferrer%20nofollow%22%3Ehttps%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2F%3C%2FA%3E.%20This%20could%20help%20you%20get%20started%20with%20NXP%20components%20like%20the%20SBC%20(UJA1169)%2C%20the%20BCC%20(MC33772B)%20or%20the%20NTAG5%20boost%20NFC%20chip.%20If%20you%20want%20to%20program%20the%20NuttX%20BMS%20example%2C%20there%20is%20already%20a%20binary%20on%20that%20website%2Frepository%20which%20you%20could%20easily%20program%20using%20the%20J-Link%20commander%20application%20(for%20windows%20(or%20JLinkExe%20on%20Linux))%20and%20a%20J-Link%20programmer.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1410958%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1410958%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F15914%22%20target%3D%22_blank%22%3E%40iaingalloway%3C%2FA%3E%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3EI%20programmed%20the%20RDDRONE%20-%20BMS772%20board%20with%20Matlab%2FSimulink.%20I%20see%20all%20values%20in%20FreeMaster.%3CBR%20%2F%3EI%20have%20a%20few%20questions...%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E1)%20I%20want%20to%20run%20the%20SSD1306%20screen%20on%20the%20card.%20I%20changed%20the%20D34%20and%20D35%20diodes.%203.3Volt%20appears%20on%20the%20screen%2C%20but%20it%20does%20not%20work.%20Could%20you%20help%20%3F%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E2)%20We%20give%201%20to%20the%20Gate%20leg%20of%20the%20power%20mosfets%20of%20the%20card%20from%20the%20software%20and%20we%20get%20the%20output%20voltage.%20Why%20do%20we%20still%20get%20output%20voltage%20when%20we%20give%20logic%200%20from%20the%20software%3F%20(We%20tested%20it%20with%20the%20load%20connected.)%3C%2FP%3E%3CP%3E3)Although%20we%20operate%20the%20SBC%20in%20normal%20mode%2C%20we%20cannot%20get%205V%20output.%20We%20only%20get%203V3.%20We%20are%20using%20sbc_uja1169_s32k_config.%20Although%20we%20activate%20the%20V2%2FVEXT%20config%20section%20in%20the%20regulator%20section%2C%20we%20cannot%20get%20output%20from%20V2.%20What%20is%20the%20reason%20of%20this%3F%20Can%20you%20help%20us%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1395481%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1395481%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F195015%22%20target%3D%22_blank%22%3E%40Prince1%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EFirst%20of%20all%2C%20best%20wishes%20for%20this%20new%20year!%3CBR%20%2F%3EMy%20apologies%20for%20the%20late%20response%2C%20we%20had%20some%20time%20off.%3C%2FP%3E%0A%3CP%3ETo%20answer%20your%20questions%3A%3C%2FP%3E%0A%3COL%3E%0A%3CLI%3E%0A%3CP%3EThe%26nbsp%3BBMS772%20comes%20with%20pre-installed%26nbsp%3Bexample%26nbsp%3Bsoftware%2C%20but%20you%20might%20want%20to%20update%20it%20to%20the%20latest%20version.%20But%20keep%20in%20mind%20that%20it%20is%20a%20development%20platform%20with%20open%20source%20example%20software.%26nbsp%3BThis%20software%20is%20opensource%20and%20provided%20for%20development%20purposes%20and%20not%20warranted%20for%20end%20use.%20You%20will%20still%20need%20to%20ensure%20that%20the%20hardware%20and%20software%20meets%20your%20needs.%3C%2FP%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3ECurrently%20we%20have%20not%20tested%20the%20BMS%20with%20multiple%20packs%20in%20parallel.%20It%20could%20be%20that%20the%20hardware%20could%20accommodate%20it%2C%20but%20the%20software%20and%20state%20machine%20would%20need%20to%20be%20reviewed%20for%20correct%20operation%20in%20parallel%20configuration.%3C%2FP%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3EThere%20is%20a%20self-test%20build%20in%20which%20will%20test%20if%20the%20MOSFET%20can%20be%20switched%20off%20during%20startup.%20This%20to%26nbsp%3Bensure%20the%20MOSFET%20and%20its%20control%20circuitry%20is%20fully%20functional%20and%20can%20be%20used%20for%20HW%2FSW%20OC%2FOV%2Ftemp%20protections%20(see%20SW%20release%20documentation).%20What%20happens%20to%20the%20batteries%20depend%20on%20the%20scenario%2C%20is%20it%20charging%20or%20discharging%2C%20does%20it%20need%20to%20connect%20or%20disconnect%20the%20batteries%20using%20the%20MOSFET.%20Plus%26nbsp%3Bthe%20BMS%20is%20not%20the%20same%20as%20a%20battery%20charger.%20An%20externally%20controlled%20constant%20current%20(CC)%20constant%20voltage%20(CV)%20source%20is%20still%20required%20to%20charge%20the%20batteries.%3C%2FP%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3ECurrently%20the%20BMS%20has%20on-board%20balance%20resistors%20plus%20FETs%20inside%20the%20installed%20BCC%20chip%20to%20balance%20the%20cells%2C%20a%20command%20from%20the%20MCU%20to%20the%20BCC%20enables%20or%20disables%20balancing%20for%20each%20individual%20cell.%3C%2FP%3E%0A%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3E%3CSPAN%3EI%20hope%20this%20answers%20your%20questions!%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1390544%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1390544%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EWe%20want%20to%20use%20RDDRONE-BMS772%20for%20solar%20drone%20with%2020%20Nos.%20of%204S%20battery%20packs%20in%20parallel.%20Please%20clarify%20the%20following%20queries%2C%3C%2FP%3E%3CP%3E1.%20Can%20RDDRONE-BMS772%20board%20be%20used%20readily%20or%20any%20software%20to%20be%20uploaded%20before%20using%3F%3C%2FP%3E%3CP%3E2.%20Can%20we%20connect%2020%20nos.%20of%20BMS772%20in%20parallel%20to%20charge%2020%20no.%20battery%20packs%20(each%20pack%20has%204S%20cells)%3F%20If%20yes%2C%20any%20additional%20protection%20to%20be%20provided%20externally%3F%3C%2FP%3E%3CP%3E3.%20Is%20there%20any%20inbuilt%20protection%20to%20prevent%20MOSFET%20failure%20in%20BMS772%3F%20If%20not%2C%20what%20happens%20to%20batteries%20when%20MOSFET%20fails%3F%3C%2FP%3E%3CP%3E4.%20Are%20external%20MOSFETs%20required%20for%20Active%20cell%20balancing%3F%20How%20active%20cell%20balance%20works%20in%20BMS772%3F%3C%2FP%3E%3CP%3EThanks%20in%20advance.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1371403%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1371403%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F189198%22%20target%3D%22_blank%22%3E%40coryjfowler%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EWe're%20actively%20investigating%20the%20issue.%20We%20needed%20to%20get%20some%20of%20the%20current%20build%20of%20boards%20from%20the%20warehouse%20in%20order%20to%20determine%20what%20is%20going%20on%20with%20this%20latest%20board%20build.%20A%20workaround%20will%20be%20provided%20shortly%20while%20we%20determine%20the%20root%20cause.%20Thank%20you%20for%20your%20patience.%3CBR%20%2F%3E%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1371347%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1371347%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ECan%20I%20get%20some%20help%20with%20my%20V%204.0%20REV%20D%20board%20and%20the%20issue%20with%20the%20NFC%20chip%20that%20causes%20a%20full%20stop%20of%20the%20BMS%20application%3F%26nbsp%3B%20Last%20reply%20to%20the%20Github%20issue%20was%203%20days%20ago.%26nbsp%3B%20I%20was%20anticipating%20a%20reply%20this%20morning%2C%20but%20no%20such%20luck.%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2Fissues%2F6%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%2Fissues%2F6%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1277972%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1277972%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20KarenRdz!%3C%2FP%3E%0A%3CP%3EYes%20that%20is%20possible.%3C%2FP%3E%0A%3CP%3EJ19%20combines%20the%20JTAG%20debugger%20pins%20together%20with%20the%20UART%20pins%2C%20the%20UART%20pins%20are%20needed%20for%20the%20CLI.%3CBR%20%2F%3EThere%20is%20a%20DCD-LZ%20breakout%20board%20which%20lets%20you%20connect%20your%20JTAG%20debugger%20to%20the%20JTAG%20debugger%20pins%20(like%20J2)%20of%20that%20breakout%20board%20and%20separates%20the%20UART%20to%20FTDI%20pinout.%3C%2FP%3E%0A%3CP%3EThis%20could%20be%20connected%20to%20J19%20of%20the%20BMS.%20%3CBR%20%2F%3ESee%20%3CA%20href%3D%22https%3A%2F%2Fnxp.gitbook.io%2Fhovergames%2Frddrone-fmuk66%2Fconnectors%2Fdebug-interface-dcd-lz%2Fdcd-lz-breakout-board%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fnxp.gitbook.io%2Fhovergames%2Frddrone-fmuk66%2Fconnectors%2Fdebug-interface-dcd-lz%2Fdcd-lz-breakout-board%3C%2FA%3E%20for%20more%20detail%20on%20the%20breakout%20board.%3C%2FP%3E%0A%3CP%3EConnector%20J2%20is%20only%20a%2010%20pins%20JTAG%20connector%2C%20without%20UART%20pins.%20%3CBR%20%2F%3EYou%20could%20use%20J2%20to%20program%2Fdebug%20the%20board%20and%20use%20J19%20for%20the%20CLI.%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3EAs%20an%20alternative%20to%20that%2C%20connector%20J21%20has%20another%20UART%20bus%20on%20it.%3C%2FP%3E%0A%3CP%3ESince%20the%20code%20is%20publicly%20available%20and%20it%20uses%20the%20NuttX%20RTOS%2C%20it%20could%20easily%20be%20changed%20in%20using%20the%20other%20UART%20bus%20for%20the%20CLI.%20%3CBR%20%2F%3EYou%20could%20select%20LPUART0%20as%20serial%20console%20in%20the%20menuconfig%20of%20NuttX%20(in%20Device%20Drivers%20-%26gt%3B%20Serial%20Driver%20Support%20-%26gt%3B%20Serial%20console).%3C%2FP%3E%0A%3CP%3ESo%20then%20you%20could%20use%20J2%20for%20programming%2Fdebugging%20and%20J21%20for%20the%20CLI%20if%20you%20configure%20it.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1276596%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1276596%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi!%3C%2FP%3E%3CP%3EI%20have%20a%20question%2C%20is%20it%20posible%20to%20use%20the%20CLI%20if%20the%20J-link%20debugger%20is%20on%20the%20J2%20port%3F%20Or%20is%20there%20another%20way%20to%20obtain%20the%20information%20on%20the%20J2%20whitout%20using%20the%20CLI%3F%3C%2FP%3E%3CP%3EThank%20you!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1269793%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1269793%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EYes%20-%20sorry%20to%20hear%20that.%20I%20also%20looked%2C%20and%20you%20are%20correct%2C%20there%20doesn't%20seem%20to%20be%20global%20availability.%20This%20is%20an%20active%20and%20good%20part%2C%20it%20is%20just%20caught%20up%20in%20the%20global%20chip%20shortage.%3C%2FP%3E%0A%3CP%3EHere%20are%20some%20(not%20so%20great)%20options%3A%3CBR%20%2F%3E-%20Contact%20Nexperia%20directly.%20You%20only%20need%20a%20few%20correct%3F%20Sometimes%20there%20are%20samples%20they%20have%20on%20hand.%3C%2FP%3E%0A%3CP%3E-%20Look%20through%20Nexperia.com%20for%20close%20alternatives%3F%3C%2FP%3E%0A%3CP%3E-%20Buy%20an%20additional%20BMS-772%20and%20take%20the%20parts%20off%20one%20to%20add%20to%20the%20other%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1269709%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1269709%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDue%20to%20the%20chip%20shortage%20the%26nbsp%3BPSMNR70-30YLH%20mosfet%20is%20no%20more%20available%20in%20the%20market.%20What%20to%20do%20with%20that%2C%20is%20there%20any%20other%20mosfet%20we%20can%20use%20with%20that%20model.%20Please%20reply%20me%20soon%20as%20we%20need%20this%20product%20as%20soon%20as%20possible.%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1267858%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1267858%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Anuj%2C%3C%2FP%3E%0A%3CP%3EThe%20FRDM33772BSPIEVB%20is%20an%20evaluation%20board%20for%20the%20battery%20cell%20controller.%20This%20is%20without%20microcontroller%2C%20switches%2C%20safety%20measures%20and%20etc.%3C%2FP%3E%0A%3CP%3EThe%20RDDRONE-BMS772%20is%20a%20mobile%20robotics%20reference%20design%20including%20microcontroller%2C%20power%20switch%2C%20(working%20and%20available)%20example%20software%2C%20hardware%20overcurrent%20circuit%20and%20more.%20%3CBR%20%2F%3E%3CBR%20%2F%3EFor%20more%20information%20about%20the%20RDDRONE-BMS772%20see%3A%20%3CA%20href%3D%22https%3A%2F%2Fnxp.gitbook.io%2Frddrone-bms772%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fnxp.gitbook.io%2Frddrone-bms772%2F%3C%2FA%3E%3CBR%20%2F%3EFor%20the%20example%20software%20see%3A%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2FNXPHoverGames%2FRDDRONE-BMS772%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EThe%20RDDRONE-BMS772%20as%20populated%20is%20rated%20for%2060A%20continues%20DC%20current.%3CBR%20%2F%3EWith%204%20pairs%20of%20MOSFETs%20and%204%20heatsinks%20it%20is%20rated%20at%2090A%20maximum%20DC%20current%20(continues)%20and%20this%20includes%20the%20layout%20and%20copper%20used.%3C%2FP%3E%0A%3CP%3EOn%20the%20RDDRONE-BMS772%20there%20is%20a%20hardware%20overcurrent%20circuit%20at%20545A%20which%20will%20act%20within%2020us.%3CBR%20%2F%3EWhich%20means%20a%20peak%20current%20of%20545A%20is%20allowed%20for%2020us%20without%20damaging%20the%20board.%3C%2FP%3E%0A%3CP%3EHigher%20currents%20or%20currents%20for%20a%20longer%20amount%20of%20time%20might%20be%20possible%2C%20but%20has%20not%20been%20tested.%3C%2FP%3E%0A%3CP%3EGoing%20over%20the%20maximum%20rated%20currents%20or%20the%20specified%20time%20will%20be%20of%20own%20risk.%20%3CBR%20%2F%3EKeep%20in%20mind%20batteries%20should%20always%20be%20handled%20with%20care.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1265442%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1265442%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EWe%20are%20working%20with%20solar%20drone%20which%20requires%20a%20lot%20of%20power.%26nbsp%3B%3C%2FP%3E%3CP%3EThis%20product%20seems%20very%20nice%20but%20i%20am%20confused%20on%20the%20maximum%20rating.%20We%20have%206s%20configuration%20Lipo%20battery%20which%20is%2022%20volt%2C%20and%20the%20motor%20can%20require%20a%20huge%20burst%20current%20and%20continuous%20current(90A%20for%20minutes).%26nbsp%3B%20I%20see%20that%20the%20maximum%20rating%20for%20this%20is%2090A%20DC%2C%20Is%20this%20value%20continuous%20maximum%20rating%20or%20burst%20maximum%20rating.%20What%20is%20the%20burst%20current%20and%20time%20limit%20for%20the%20burst%20current.%20Can%20you%20please%20suggest%20me%20which%20can%20be%20better%20for%20me%20this%20one%20or%20the%20other%20BMS%26nbsp%3BFRDM33772BSPIEVB.%26nbsp%3B%3C%2FP%3E%3CP%3EHope%20i%20get%20a%20very%20fast%20reply.%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1216911%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1216911%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThe%20BMS772%20does%20the%20self%20balancing.%20You%20will%20need%20to%20control%20the%20overall%20current%20provided%20to%20charge%20the%20battery.%20You%20should%20also%20provide%20some%20power%20steering%2Fisolation%20otherwise%20with%20the%20two%20batteries%20in%20parallel%2C%20the%20higher%20charged%20one%20will%20attempt%20to%20charge%20the%20lower%20charged%20one.%3CBR%20%2F%3E%3CBR%20%2F%3EAlso%20-%20what%20is%20not%20clear%20above%20-%20are%20you%20making%20one%20pack%20or%20two%20separate%20pluggable%20packs.%20You%20CAN%20parallel%20individual%20cells%20in%20one%20large%20one%20(and%20use%20a%20single%20BMS)%20if%20you%20wish%2C%20but%20that%20does%20not%20seem%20to%20be%20how%20you%20have%20described%20it.%20So%20one%20BMS%20per%20pack%20is%20needed.%3CBR%20%2F%3E%3CBR%20%2F%3EThe%20BMS%20is%20approximately%20the%20size%20of%20a%203S%204000mA%2Fh%20hobby%20LiPo%20-%20Sorry%20i%20do%20not%20have%20exact%20dimensions.%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1203659%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1203659%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThanks%20for%20the%20update%20and%20quick%20reply.%20I'll%20be%20sure%20to%20keep%20an%20eye%20on%20this%20thread.%20Looking%20for%20the%20same%20issue.%20Bumped%20into%20your%20thread.%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Falaskasworld.run%2F%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ealaskasworld.com%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1153065%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1153065%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20there%2C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3Ewe%20have%20a%20drone%20battery%20that%20consists%20of%202%20x%207000mAh%206S%20lithium%20polymer%20batteries.%20These%20two%20packs%20are%20going%20to%20be%20connected%20in%20parallel%20to%20achieve%2014000mAh%206S.%26nbsp%3B%3C%2FP%3E%3CP%3EWhat%20I%20did%20is%20made%20a%20housing%20to%20incubate%20the%20two%20packs%20and%20connected%20them%20to%20a%20single%2010%20pin%20robust%20male%20connector%20and%20in%20the%20UAV%20size%20there%20is%20a%20female%20connector%20.%20The%20plan%20is%20to%20make%20the%20drone%20battery%20like%20cartridge%20so%20we%20can%20slide%20it%20in%20UAV%20to%20click%20in%20and%20go%20on%20and%20when%20battery%20need%20recharging%20we%20take%20out%20the%20cartridge%20and%20connect%20it%20to%20the%20charger%20with%20same%20pin%20type%20used%20on%20UAV.%20The%20question%20is%20are%20we%20able%20to%20use%20you%20BMS%20772%20to%20achieve%20a%20self%20balancing%20cartridge%20when%20recharging%3F%3C%2FP%3E%3CP%3Eif%20so%20how%20would%20we%20do%20that%3F%20Do%20we%20need%20two%20boards%20or%20one%20only%3F%20And%20how%20to%20connect%20it%20to%20the%20batteries%3F%3C%2FP%3E%3CP%3Eand%20what%E2%80%99s%20the%20dimensions%20of%20that%20board%20please%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3Ebest%20regards%26nbsp%3B%3C%2FP%3E%3CP%3EFalcon%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2317850%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2317850%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178538%22%20target%3D%22_blank%22%3E%40SH%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CP%3EThis%20depends%20on%20what%20you%20would%20like%20to%20test.%26nbsp%3B%3CBR%20%2F%3EIf%20you%20would%20like%20to%20have%20voltages%20on%20cell%20measurement%20tabs.%20Without%20charging%20or%20(passively)%20balancing%20the%20cells.%20You%20can%20easily%20add%20some%20resistors%20over%20your%20voltage%20supply%20to%20mimic%20the%20cell%20voltages%20and%20measure%20them%20with%20the%20BMS772.%3C%2FP%3E%0A%3CP%3EFor%20example%20you%20have%20a%20lab%20power%20supply%20and%20you%20would%20like%20to%20test%20a%203S%20battery%20(3%20cells%20in%20series)%20setup.%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3EYou%20can%20set%20the%20lab%20power%20supply%20to%2012V%20attach%20them%20to%20the%20power%20in%20%2B%20and%20power%20in%20-%20of%20the%20BMS.%20Parallel%20to%20that%20you%20add%20a%20voltage%20divider%20with%203%20resistors%20of%20for%20example%201k%CE%A9%20in%20series%20from%20power%20%2B%20to%20power%20-.%26nbsp%3B%3CBR%20%2F%3EYou%20can%20add%20the%204%20balance%20wires%20to%20these%20resistor%20(%2B%2C%20-%20and%20the%202%20in%20between%20resistors)%20to%20connect%20to%20the%20balance%20lead%20connector%20JP1.%26nbsp%3B%3CBR%20%2F%3EMake%20sure%20to%20solder%20the%20BMS%20for%203S%20configuration%20according%20to%20the%20release%20notes%20on%20github%3A%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXP-Robotics%2FRDDRONE-BMS772%2Fblob%2Fmain%2FBMS772_releaseNotes_6.0.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ERDDRONE-BMS772%2FBMS772_releaseNotes_6.0.pdf%20at%20main%20%C2%B7%20NXP-Robotics%2FRDDRONE-BMS772%20%C2%B7%20GitHub%3C%2FA%3E%3CBR%20%2F%3EI%20would%20suggest%20to%20download%20this%20release%20note%20PDF%20as%20the%20viewer%20is%20clipping%20the%20document.%3CBR%20%2F%3E%3CBR%20%2F%3EThere%20should%20be%20~4V%20per%20%22cell%22%20in%20this%20setup.%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3EYou%20should%20be%20able%20to%20start%20up%20the%20BMS772%20in%20normal%20mode%20when%20you%20power%20on%20the%20lab%20power%20supply%20(current%20limit%20could%20be%20set%20to%20100mA%20without%20a%20load).%26nbsp%3B%3C%2FP%3E%0A%3CP%3EAs%20long%20as%20the%20BMS%20and%20power%20supply%20is%20able%20to%20handle%20it%20and%20configured%20for%20it%2C%20you%20can%20add%20a%20load%20to%20the%20output%20of%20the%20BMS772%20as%20well.%26nbsp%3B%3C%2FP%3E%0A%3CP%3EI%20hope%20this%20helps!%3CBR%20%2F%3E%3CBR%20%2F%3EKind%20regards%2C%3C%2FP%3E%0A%3CP%3ECis%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2317845%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2317845%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%3CP%3EI%20am%20using%20the%20BMS-772%20for%20a%20university%20project%20and%20do%20not%20have%20access%20to%20the%20battery%20cell%20emulator.%20I%20was%20wondering%20how%20design%20a%20resistor%20setup%20on%20breadboard%20to%20mimic%20the%20battery%20cells%20for%20purely%20testing%20purposes%20temporarily.%26nbsp%3B%3C%2FP%3E%3CP%3EThank%20you%20for%20any%20help%2C%3C%2FP%3E%3CP%3EShane.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2318145%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2318145%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHI%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThank%20you%20for%20your%20help.%20Lowering%20the%20clock%20speed%20solved%20the%20issue.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2345508%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2345508%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20again%2C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThank%20you%20for%20your%20help.%20I%20have%20a%20second%20BMS-772%20board%20and%20have%20soldered%20the%203%20cell%20connector%20to%20the%20board%20and%20I%20am%20using%20a%20three%20cell%20configuration%20with%20resistors%20mimicking%20cells.%20However%2C%20the%20CLI%20always%20gives%20me%200v%20for%20the%203rd%20cell%20and%20therefore%20an%20undervoltage%20error.%20There%20is%20voltage%20across%20the%203rd%20resistor.%20I%20got%20some%20solder%20across%20the%20cell%20setup%20pads%20on%20the%20bottom%20of%20the%20board%20but%20removed%20most%20of%20it.%20What%20could%20be%20the%20issue%20here%3F%3C%2FP%3E%3CP%3EThank%20you%20again%20for%20any%20help%2C%3C%2FP%3E%3CP%3EShane%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2220260404_171220.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260404_171220.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260404_171220.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260404_171220.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260404_171220.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260404_171220.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F381323i73E864FB58426931%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2220260404_171220.jpg%22%20alt%3D%2220260404_171220.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260404_171220.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2220260404_171231.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260404_171231.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260404_171231.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260404_171231.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260404_171231.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260404_171231.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F381325i7006506CB8F06056%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2220260404_171231.jpg%22%20alt%3D%2220260404_171231.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260404_171231.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2220260404_171422.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260404_171422.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260404_171422.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260404_171422.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260404_171422.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2220260404_171422.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F381324iF8917DE718BCF66E%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2220260404_171422.jpg%22%20alt%3D%2220260404_171422.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E20260404_171422.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2346028%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2346028%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F259906%22%20target%3D%22_blank%22%3E%40Shane93%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CP%3EThank%20you%20for%20reaching%20out%20for%20a%20question%20on%20the%20RDDRONE-BMS772.%3CBR%20%2F%3EAnd%20thank%20for%20sharing%20the%20helpful%20images!%3C%2FP%3E%0A%3CP%3EWould%20it%20be%20possible%20to%20verify%20the%20solder%20connections%20to%20make%20sure%20the%20BMS%20is%20configured%20for%203S%3F%3CBR%20%2F%3EFrom%20the%20image%20it%20looks%20like%20SJ2%20is%20connected%2C%20while%20SJ12%20and%20SJ10%20might%20not%20be%20connected%3F%3CBR%20%2F%3EIf%20you%20have%20a%20multimeter%20with%20resistance%20measurement%2C%20you%20are%20able%20to%20check%20with%20(with%20resistors%20removed%20and%20the%20board%20not%20powered).%26nbsp%3B%3CBR%20%2F%3EHere%20you%20can%20find%20more%20information%20on%20the%20solder%20jumpers%20for%20the%20cell%20configuration%20(3S)%3A%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fnxp.gitbook.io%2Frddrone-bms772%2Fboard-user-guide%2Fgetting-started-with-the-rddrone-bms772%2Fconfiguring-the-hardware%23cell-terminal-connection%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fnxp.gitbook.io%2Frddrone-bms772%2Fboard-user-guide%2Fgetting-started-with-the-rddrone-bms772%2Fconfiguring-the-hardware%23cell-terminal-connection%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EAnother%20thing%20that%20I%20notice%20is%20that%20you%20are%20using%20a%20bread%20board%20and%20Dupont%20jumper%20wires.%20Keep%20in%20mind%20that%20these%20are%20known%20to%20have%20bad%20connections.%20I%20do%20understand%20that%20for%20debugging%20this%20might%20be%20easy%20to%20do.%20But%20a%20bad%20connection%20because%20of%20the%20breadboard%20and%20%2F%20or%20the%20wires%20could%20also%20be%20a%20problem.%20%3CBR%20%2F%3EFrom%20what%20I%20can%20see%20in%20the%20image%2C%20the%20way%20you%20connect%20it%20is%20OK.%26nbsp%3B%3C%2FP%3E%0A%3CP%3EI'm%20also%20curious%20about%20your%20settings.%20%3CBR%20%2F%3EIf%20you%20type%20in%20the%20CLI%20%2F%20UART%20command%20window%20the%20following%20command%3A%3CBR%20%2F%3Ebms%20get%20all%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3EWhat%20do%20you%20see%3F%3C%2FP%3E%0A%3CP%3EI%20would%20like%20to%20see%20the%20n-cells%20you%20have%20configured%20for%20example%20as%20default%20this%20is%206%20cells.%26nbsp%3B%3CBR%20%2F%3EYou%20can%20find%20which%20commands%20to%20look%20at%20in%20the%20Chapter%206%20Getting%20started%20%2F%20quick%20start%20guide%20of%20the%20release%20notes%20(page%209%20of%2059)%3A%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXP-Robotics%2FRDDRONE-BMS772%2Fblob%2Fmain%2FBMS772_releaseNotes_6.0.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ERDDRONE-BMS772%2FBMS772_releaseNotes_6.0.pdf%20at%20main%20%C2%B7%20NXP-Robotics%2FRDDRONE-BMS772%20%C2%B7%20GitHub%3C%2FA%3E%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3EChapter%206.4.1%3A%20The%20most%20important%20BMS%20variables%20lets%20you%20know%20what%20to%20configure%20when%20you%20start%20with%20a%20BMS.%20Like%20n-cells.%3C%2FP%3E%0A%3CP%3EYou%20can%20change%20n-cells%20to%203%20(in%20your%20case)%20with%20the%20command%3A%3CBR%20%2F%3Ebms%20set%20n-cells%203%3CBR%20%2F%3E%3CBR%20%2F%3EThat%20should%20make%20sure%20the%20BMS%20doesn't%20check%20the%20other%203%20cells%20that%20are%20not%20present%20in%20your%20setup.%3C%2FP%3E%0A%3CP%3EI%20hope%20this%20helps!%3C%2FP%3E%0A%3CP%3EKind%20regards%2C%26nbsp%3B%3C%2FP%3E%0A%3CP%3ECis%20van%20Mierlo%3C%2FP%3E%0A%3CDIV%20id%3D%22tinyMceEditorcisvmierlo_1%22%20class%3D%22mceNonEditable%20lia-copypaste-placeholder%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2347106%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2347106%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3EThank%20you%20for%20all%20your%20help.%20The%20solder%20pads%20seem%20to%20be%20connected%2C%20when%20I%20run%20a%20%22bms%20get%20all%22%20I%20get%20this%20return.%20However%2C%20measuring%20across%20the%203%20resistors%20gives%20me%20the%20natural%20step%20down%20of%2012v%2C%208v%2C%204v%2C%200v.%26nbsp%3B%3C%2FP%3E%3CP%3EThank%20you%2C%3C%2FP%3E%3CP%3EShane%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22image_2026-04-08_115330382.png%22%20style%3D%22width%3A%20422px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image_2026-04-08_115330382.png%22%20style%3D%22width%3A%20422px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image_2026-04-08_115330382.png%22%20style%3D%22width%3A%20422px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image_2026-04-08_115330382.png%22%20style%3D%22width%3A%20422px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F381564i400DFD6906B5EBDB%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22image_2026-04-08_115330382.png%22%20alt%3D%22image_2026-04-08_115330382.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Eimage_2026-04-08_115330382.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2357827%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2357827%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F178264%22%20target%3D%22_blank%22%3E%40cisvmierlo%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThank%20you%20very%20much%20for%20you%20help.%20Two%20of%20the%20surface%20mount%20resistors%20had%20lifted%20on%20the%20back%20of%20the%20board%20causing%20an%20error%20in%20the%20cell%20reading%20circuit.%20The%20issue%20is%20resolved%20now%20thank%20you%20again.%20I%20have%20one%20final%20question%20you%20might%20be%20able%20to%20assist%20with.%20I%20am%20building%20my%20own%20custom%20CAN%20interface%20using%20NI-XNET%20with%20Cyphal%20CAN.%20Can%20you%20tell%20me%20how%20the%20CAN%20frames%20are%20structured%20and%20the%20addresses%3F%20Also%20is%20it%20possible%20to%20turn%20off%20the%20output%20voltage%20by%20controlling%20the%20MOSFET's%20over%20CAN%3F%3C%2FP%3E%3CP%3EThank%20you%2C%3C%2FP%3E%3CP%3EShane%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2358374%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2358374%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F259906%22%20target%3D%22_blank%22%3E%40Shane93%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EGood%20that%20you%20have%20found%20this%20issue%20with%202%20SMD%20resistors%20and%20thank%20you%20for%20sharing%20this%20information.%3C%2FP%3E%0A%3CP%3EI%20believe%20both%20CyphalCAN%20and%20DroneCAN%20information%20can%20be%20found%20in%20the%20release%20notes.%26nbsp%3B%3CBR%20%2F%3EIt%20will%20mention%20which%20messages%20are%20implemented.%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThere%20is%20no%20direct%20message%20in%20either%20protocol%20that%20can%20turn%20off%20the%20power%20switch.%26nbsp%3B%3CBR%20%2F%3EWith%20DroneCAN%2C%20you%20can%20easily%20change%20settings%20and%20might%20be%20able%20to%20create%20an%20error%20in%20which%20the%20BMS%20will%20turn%20off%20the%20power.%20For%20example%2C%20changing%20the%20overtemperature%20setting.%26nbsp%3B%3CBR%20%2F%3EYou%20should%20be%20able%20to%20change%20the%20setting%20back%20to%20a%20%22good%22%20value%20and%20reset%20the%20fault.%26nbsp%3B%3CBR%20%2F%3EThis%20has%20been%20tested%20with%20DroneCAN.%26nbsp%3B%3C%2FP%3E%0A%3CP%3EBut%20if%20you%20are%20creating%20your%20own%20custom%20CAN%20interface%2C%20you%20can%20add%20this%20feature%20yourself.%26nbsp%3B%3C%2FP%3E%0A%3CP%3EI%20hope%20this%20helps.%3C%2FP%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3ECis%3C%2FP%3E%3C%2FLINGO-BODY%3E
