mpc8572 toolchain
mpc8572 toolchain
1,277 次查看
andrewmotorin
I have reference board mpc8572ds with e500v2 cores as a target and x86_64 machine with ubuntu 16.04 as a host, and i want to compile some applications written in Ada language. To get started i've used powerpc-linux-gnu toolchain, but due to floating point issue this toolchain is not proper for that, so i've thought to change toolchain to powerpc-linux-gnuspe. The problem is that spe-toolchain from ubuntu repo is not support Ada. So, how could i get gcc spe-toolchain for my purpose?
1,195 次查看
Pavel
Look at the following pages about LTIB toolchain:
http://ltib.org/documentation-LtibFaq
and
http://ltib.org/pages/LTIB_generic_v1.4_-_version_6.4.1.pdf
https://lists.nongnu.org/archive/html/ltib/2010-07/msg00172.html
Pavel Chubakov
