error: initializer element is not constant ..with powerpc64-fsl_networking-linux-gcc
ramakrishnakatt
error: initializer element is not constant ..with powerpc64-fsl_networking-linux-gcc , it is not getting with 32 bit gcc
yipingwang
Hello Rama Krishna Katta,
Would you please provide the whole build log and the source file related to this build error?
Yiping
ramakrishnakatt
bash-3.2$ make
sh ../../utils/info.sh
chmod 777 ../../core/diag_info.c
powerpc64-fsl_networking-linux-gcc  -mhard-float -m64 -mcpu=e5500 --sysroot=/ws/blr-diags-bgl/QorIQ-SDK-64b-V1.5/sysroots/ppc64e5500-fsl_networking-linux -c  -O  -nostdinc -Wall  -I../rudy  -I/ws/blr-diags-bgl/QorIQ-SDK-64b-V1.5/sysroots/ppc64e5500-fsl_networking-linux/usr/include -I../src-rsp2 -I../../common/include -I../../core/include -I../../common/proc/ppc/include -I/ws/blr-diags-bgl/QorIQ-SDK-64b-V1.5/sysroots/x86_64-fsl_networking_sdk-linux/usr/lib/ppc64e5500-fsl_networking-linux/gcc/powerpc64-fsl_networking-linux/4.7.3/include -I. -I../src-rsp2/include -I../rudy/include -I../../common/chips -I../../common/chips/include -I../../common/chips/dev_1337_maxim/ -I../../common/chips/dev_pca9548a_philips/ -I../../common/chips/dev_88e111x_marvell/ -I../../common/chips/dev_psoc3_cypress/ -I../../common/src -I../../common/chips/dev_psu_bel/ -I../../common/chips/dev_mk1493_idt/ -I../../common/chips/dev_adm106x_analog/ -I../../common/chips/dev_adm1166_arad/ -I../../common/chips/dev_pca9535_philips/ -I../../common/chips/dev_ad8158_analog/ -I../../common/chips/dev_fan_tray_m24m01/ -I../../common/chips/dev_common_i2c_driver/ -I../../common/chips/dev_pca9541_philips/ -I../../common/chips/dev_zl30152_zarlink/ -I../../common/chips/dev_adm1066_analog/ -I../../common/chips/dev_ltc4260_linear/ -I../../common/chips/dev_ltc7510_linear/ -I../../common/chips/dev_max7500_maxim/ -I../../common/chips/dev_wp3_wintegra/ -I/nobackup/ramakatt/trunk/plat/obj-rsp2/../../common/src/wddi/include -I/nobackup/ramakatt/trunk/plat/obj-rsp2/../../common/src/wddi/sources -I/nobackup/ramakatt/trunk/plat/obj-rsp2/../../common/src/wddi/sources/api -I/nobackup/ramakatt/trunk/plat/obj-rsp2/../../common/src/wddi/sources/winutil/include -I/nobackup/ramakatt/trunk/plat/obj-rsp2/../../common/src/wddi/sources/winutil/include/winpath3 -I/nobackup/ramakatt/trunk/plat/obj-rsp2/../../common/src/wddi/sources/winutil/api/include -I/nobackup/ramakatt/trunk/plat/obj-rsp2/../../common/src/wddi/sources/winutil/tests/include -I/nobackup/ramakatt/trunk/plat/obj-rsp2/../../common/src/wddi/sources/winutil/api/include/winpath3 -I/nobackup/ramakatt/trunk/plat/obj-rsp2/../../common/src/wddi/sources/hardware/winpath3  -I/nobackup/ramakatt/trunk/plat/obj-rsp2/../../common/src/wddi/phy/wpx_ufe/api -I/nobackup/ramakatt/trunk/plat/obj-rsp2/../../common/src/wddi/phy/wpx_ufe/fpga -I/nobackup/ramakatt/trunk/plat/obj-rsp2/../../common/src/wddi/phy/wpx_ufe/fpga/ufe4 -I/nobackup/ramakatt/trunk/plat/obj-rsp2/../../common/src/wddi/phy/wpx_ufe/sources/include -I/nobackup/ramakatt/trunk/plat/obj-rsp2/../../common/src/wddi/phy/wpx_ufe/sources/include/firmware -I/nobackup/ramakatt/trunk/plat/obj-rsp2/../../common/src/wddi/phy/wpx_ufe/wpx_frmr/flexmux  -I../../common/chips/dev_pmc_4358/ -I../rudy/nile -I../rudy/arad -I../../common/src/cylon -I../../common/chips/dev_psu_at24c02_atmel/ -I../rudy/im/include -I../rudy/im/t1e1/include -I../rudy/im/ocx/include -I../rudy/im/wintegra/include -I../rudy/im/wintegra/platform/include -I../rudy/im/wintegra/board/wds_winpath3 -I../rudy/im/wintegra/platform/include -I../rudy/im/wintegra/platform/ppc_winpath3/include -I../rudy/im/cpak/ -I../rudy/im/gb2 -I../rudy/im/altera_phy/TPO225/sw/modules/tpdrv -I../rudy/im/altera_phy/TPO325/sw/modules/tpdrv -I../rudy/im/altera_phy/TPO325/sw/modules/regdbg -I../rudy/im/altera_phy/TPO425/sw/modules/tpdrv -I../rudy/im/altera_phy/TPO225/sw/modules/tpdrv/tpox25 -I../rudy/im/altera_phy/TPO325/sw/modules/tpdrv/tpox25 -I../rudy/im/altera_phy/TPO425/sw/modules/tpdrv/tpox25  -I../../common/chips/dev_vitesse/base -I../../common/chips/dev_vitesse/include -I../../common/chips/dev_vitesse/base/daytona -I../../common/chips/dev_max2_altera/ -I../../common/chips/dev_psoc3_fw_upgrade/ -I../../common/chips/dev_max442x_maxim/ -I../../common/chips/dev_tps40422/ -I../../common/src/jtag -I../../common/chips/dev_act2lite_cisco/ -I/nobackup/ramakatt/trunk/plat/obj-rsp2/../../common/chips/dev_act2lite_cisco/lib -I/nobackup/ramakatt/trunk/plat/obj-rsp2/../../common/chips/dev_act2lite_cisco/lib/TAM -I../../common/chips/dev_adm1275_analog/ -I../../common/chips/dev_adm9523_analog/ -I../../common/src/brcm_sdk/latest/sdk-all-6.4.3/include -I../../common/src/brcm_sdk/latest/sdk-all-6.4.3/systems/bde/linux/include -I../rudy/arad/kbp_util -I../../common/chips/dev_hyphy20g_cisco/ -I../../common/src/hyphy20g_sdk/hyphyflex_09.06/hyphy20g_drv/inc/  -D__PPC__ -DDIAGMON -DCONFIG_ETSEC -DCPU_P2020 -DRUDY -DWPI_OS_ENET_WINPATH=0 -DWPI_DEBUG_LEVEL=WPI_DEBUG_LEVEL_1 -DINTERRUPT_MODEL_FLAT -DWPI_OS_INT_SERVICE -DNO_APP -DSUPER_LIGHT -DWUFE_UFE4 -DWPL_PRIVATE_HEAP_ALLOCATION   -DPCIE_64BIT_ADDR -DRSP3_BOARD -DASR903 -DWARRIOR -DVTSS_OS_CUSTOM -DVTSS_CHIP_DAYTONA -DALT_ROMMON_UPGRADE -DIN_LINUX -D_LARGEFILE_SOURCE -DCHIP_TPO225 -DCHIP_TPO225_C1 -D_LARGEFILE64_SOURCE -D_REENTRANT -DLINUX -DSOURCE_CHECK_LIBBCM -DBCM_EASY_RELOAD_WB_COMPAT_SUPPORT -DBCM_CONTROL_API_TRACKING -DBCM_DETACH_POLL_INTERVAL_USECS_DEFAULT=100000 -DBCM_DETACH_NUM_RETRIES_DEFAULT=3000 -D__DUNE_LINUX_BCM_CPU_PCIE__ -D_SIMPLE_MEMORY_ALLOCATION_=0 -DUSE_LINUX_BDE_MMAP=1 -DNO_BCM_5690_A0 -DNO_BCM_5670_A0 -DNO_BCM_5673_A0 -DNO_BCM_5674_A0 -DNO_BCM_5665_A0 -DNO_BCM_5665_B0 -DNO_BCM_5650_C0 -DNO_BCM_5695_A0 -DNO_BCM_56601_A0 -DNO_BCM_56601_B0 -DNO_BCM_56601_C0 -DNO_BCM_56602_A0 -DNO_BCM_56602_B0 -DNO_BCM_56602_C0 -DSYS_BE_PIO=1 -DSYS_BE_PACKET=0 -DSYS_BE_OTHER=1 -DSAL_SPL_LOCK_ON_IRQ -DBE_HOST=1  -DBCM_PLATFORM_STRING=\"powerpc\"  -DNO_BCM_88754_A0 -DNO_BCM_88950_A0 -DINCLUDE_CINT  -DINCLUDE_BSAFE  -DINCLUDE_ATPTRANS_SOCKET  -DINCLUDE_L3  -DINCLUDE_I2C  -DINCLUDE_MEM_SCAN -DINCLUDE_EDITLINE  -DINCLUDE_TELNET  -DINCLUDE_DRIVERS  -DINCLUDE_CHASSIS  -DINCLUDE_TEST  -DINCLUDE_BCM_SAL_PROFILE -DINCLUDE_DUNE_UI  -DINCLUDE_INTR  -DINCLUDE_KBP  -DINCLUDE_BFD  -DBCM_RPC_SUPPORT  -DBCM_PETRA_SUPPORT -DBCM_RPC_SUPPORT  -DBCM_DFE_SUPPORT -DINCLUDE_LIB_CPUDB -DINCLUDE_LIB_CPUTRANS -DINCLUDE_LIB_DISCOVER -DINCLUDE_LIB_STKTASK -DDISCOVER_APP_DATA_BOARDID -DINCLUDE_I2C -DINCLUDE_LIB_CINT -DCINT_CONFIG_INCLUDE_SDK_SAL=1 -DCINT_CONFIG_INCLUDE_PARSER=1 -DCINT_CONFIG_INCLUDE_CINT_LOAD=0   -DINCLUDE_PHY_522X  -DINCLUDE_PHY_54XX -DINCLUDE_PHY_5464  -DINCLUDE_PHY_5421S  -DINCLUDE_PHY_5482  -DINCLUDE_PHY_54616  -DINCLUDE_PHY_54680 -DINCLUDE_PHY_54680E  -DINCLUDE_PHY_52681E  -DINCLUDE_PHY_54880E  -DINCLUDE_PHY_54682  -DINCLUDE_PHY_54684 -DINCLUDE_PHY_54640  -DINCLUDE_PHY_54640E  -DINCLUDE_PHY_54880  -DINCLUDE_PHY_SERDES  -DINCLUDE_PHY_SIMUL -DINCLUDE_PHY_8703  -DINCLUDE_PHY_8705  -DINCLUDE_PHY_8706  -DINCLUDE_PHY_8072  -DINCLUDE_PHY_8040 -DINCLUDE_PHY_8481  -DINCLUDE_PHY_8750  -DINCLUDE_PHY_8729  -DINCLUDE_PHY_84740  -DINCLUDE_PHY_84756 -DINCLUDE_PHY_54380  -DINCLUDE_PHY_542XX  -DINCLUDE_PHY_84334  -DINCLUDE_PHY_84728  -DINCLUDE_PHY_84749 -DINCLUDE_PHY_84328  -DINCLUDE_PHY_84793  -DINCLUDE_PHY_82328 -DINCLUDE_LONGREACH -DNO_BCM_88732_A0 -DBE_HOST=1 -D__BSD_SOURCE -DUNIX   -Wall -fno-strict-aliasing    -DLINK_PCP_LIBRARIES -DDUNE_BCM -DLINK_PB_LIBRARIES -DLINK_PETRA_LIBRARIES -DLINK_PB_PP_LIBRARIES -DLINK_PPD_LIBRARIES  -DLINK_ARAD_LIBRARIES -DLINK_PPD_LIBRARIES -DLINK_JERICHO_LIBRARIES -DLINK_PPD_LIBRARIES -DBCM_JERICHO_SUPPORT -DLINK_PPD_LIBRARIES -DDUNE_BCM -DNLMPLATFORM_UNIX -DNLMPLATFORM_LINUX -DPHYMOD_SUPPORT -DPHYMOD_TIER1_SUPPORT -DPHYMOD_INCLUDE_CUSTOM_CONFIG -DPHYMOD_DIAG -DPORTMOD_DIAG -DPORTMOD_SUPPORT   -g -G 0 -fsigned-char -fno-builtin -mhard-float -mno-string -mmultiple -Wa,-me5500 ../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:82:19: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:82:6: error: initializer element is not constant
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:82:6: error: (near initialization for 'ge_1112_cmn_reg_tbl[0].size.size')
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:84:19: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:84:6: error: initializer element is not constant
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:84:6: error: (near initialization for 'ge_1112_cmn_reg_tbl[1].size.size')
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:92:19: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:92:6: error: initializer element is not constant
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:92:6: error: (near initialization for 'ge_1112_cmn_reg_tbl[2].size.size')
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:113:47: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:113:6: error: initializer element is not constant
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:113:6: error: (near initialization for 'ge_1112_p0_reg_tbl[0].size.size')
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:116:46: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:116:6: error: initializer element is not constant
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:116:6: error: (near initialization for 'ge_1112_p0_reg_tbl[1].size.size')
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:119:47: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:119:6: error: initializer element is not constant
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:119:6: error: (near initialization for 'ge_1112_p0_reg_tbl[2].size.size')
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:122:46: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:122:6: error: initializer element is not constant
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:122:6: error: (near initialization for 'ge_1112_p0_reg_tbl[3].size.size')
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:125:46: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:125:6: error: initializer element is not constant
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:125:6: error: (near initialization for 'ge_1112_p0_reg_tbl[4].size.size')
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:128:47: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:128:6: error: initializer element is not constant
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:128:6: error: (near initialization for 'ge_1112_p0_reg_tbl[5].size.size')
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:131:46: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:131:6: error: initializer element is not constant
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:131:6: error: (near initialization for 'ge_1112_p0_reg_tbl[6].size.size')
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:134:47: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:134:6: error: initializer element is not constant
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:134:6: error: (near initialization for 'ge_1112_p0_reg_tbl[7].size.size')
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:137:46: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:137:6: error: initializer element is not constant
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:137:6: error: (near initialization for 'ge_1112_p0_reg_tbl[8].size.size')
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:140:46: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:140:6: error: initializer element is not constant
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:140:6: error: (near initialization for 'ge_1112_p0_reg_tbl[9].size.size')
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:143:47: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:143:6: error: initializer element is not constant
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:143:6: error: (near initialization for 'ge_1112_p0_reg_tbl[10].size.size')
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:146:46: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:146:6: error: initializer element is not constant
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:146:6: error: (near initialization for 'ge_1112_p0_reg_tbl[11].size.size')
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:149:47: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:149:6: error: initializer element is not constant
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:149:6: error: (near initialization for 'ge_1112_p0_reg_tbl[12].size.size')
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:152:46: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:152:6: error: initializer element is not constant
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:152:6: error: (near initialization for 'ge_1112_p0_reg_tbl[13].size.size')
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:155:46: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:155:6: error: initializer element is not constant
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:155:6: error: (near initialization for 'ge_1112_p0_reg_tbl[14].size.size')
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:158:47: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:158:6: error: initializer element is not constant
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:158:6: error: (near initialization for 'ge_1112_p0_reg_tbl[15].size.size')
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:179:46: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:179:6: error: initializer element is not constant
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:179:6: error: (near initialization for 'ge_1112_p1_reg_tbl[0].size.size')
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:182:46: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:182:6: error: initializer element is not constant
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:182:6: error: (near initialization for 'ge_1112_p1_reg_tbl[1].size.size')
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:185:46: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:185:6: error: initializer element is not constant
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:185:6: error: (near initialization for 'ge_1112_p1_reg_tbl[2].size.size')
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:188:46: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:188:6: error: initializer element is not constant
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:188:6: error: (near initialization for 'ge_1112_p1_reg_tbl[3].size.size')
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:191:46: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:191:6: error: initializer element is not constant
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:191:6: error: (near initialization for 'ge_1112_p1_reg_tbl[4].size.size')
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:194:47: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:194:6: error: initializer element is not constant
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:194:6: error: (near initialization for 'ge_1112_p1_reg_tbl[5].size.size')
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:197:46: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:197:6: error: initializer element is not constant
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:197:6: error: (near initialization for 'ge_1112_p1_reg_tbl[6].size.size')
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:200:46: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:200:6: error: initializer element is not constant
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:200:6: error: (near initialization for 'ge_1112_p1_reg_tbl[7].size.size')
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:203:47: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:203:6: error: initializer element is not constant
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:203:6: error: (near initialization for 'ge_1112_p1_reg_tbl[8].size.size')
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:206:46: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:206:6: error: initializer element is not constant
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:206:6: error: (near initialization for 'ge_1112_p1_reg_tbl[9].size.size')
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:209:47: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:209:6: error: initializer element is not constant
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:209:6: error: (near initialization for 'ge_1112_p1_reg_tbl[10].size.size')
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:212:46: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:212:6: error: initializer element is not constant
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:212:6: error: (near initialization for 'ge_1112_p1_reg_tbl[11].size.size')
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:215:46: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
../../common/chips/dev_88e111x_marvell/dev_mrvl_ge.c:215:6: error: initializer element is not constant
yipingwang
Please try whether it would be helpful with the option "-long32", this should be 32bit code porting to 64 bit problem.
Would you please also provide the c sample source code to let me do some verification?
Yiping
ramakrishnakatt
Still it is not working, is it necessary to use SDK 1.7 to work for 64bit version.
Currently we are using SDK1.5?
yipingwang
You could send part of your sample code to me, I will do verification for you.
Yiping
ramakrishnakatt
Above shown error messages from the below files,
#include "diag.h"
#include "defs.h"
#include "free.h"
#include "types.h"
#include "proto.h"
#include "error.h"
#include "strings.h"
#include "endians.h"
#include "dev_1112.h"
#include "dev_1114.h"
#include "dev_print.h"
#define PHY_STAT_MONITOR /* */
#define FPGA_MUX 0x00A4
*                    Function Prototypes                            *
static int poll_sw_reset(dev_object_t *dev);
static void mvl_ge_destroy(dev_object_t **);
static int mvl_ge_alt_reg(dev_object_t *dev);
static int mvl_ge_set_synce(dev_object_t *dev);
static int mvl_ge_reg_test(dev_object_t *dev);
static uint32_t mvl_ge_dev_isr(dev_object_t *);
static uint32_t mvl_ge_dev_init(dev_object_t *);
static uint32_t clear_pkt_cnt(dev_object_t *dev);
static uint32_t mvl_ge_dev_intr_en(dev_object_t *);
static uint32_t mvl_ge_dev_restart(dev_object_t *);
static uint32_t mvl_ge_dev_oper_en(dev_object_t *);
static uint32_t mvl_ge_dev_oper_dis(dev_object_t *);
static uint32_t mvl_ge_dev_intr_dis(dev_object_t *);
static uint32_t mvl_ge_dev_attach(dev_object_t *dev);
static uint32_t mvl_ge_dev_detach(dev_object_t *dev);
static int mvl_ge_set_loopback(dev_object_t *dev, uint lpbk_mode,
        uint speed, uint op, uint auto_neg);
static int mvl_ge_set_test_mode(dev_object_t *dev);
static int mvl_ge_rd_wr_reg(dev_object_t *dev, uint op, smi_t page,
        uchar offset, smi_t *data);
static uint32_t mvl_ge_crsh(dev_object_t *, print_fn_t, dev_show_cmd);
static dev_mrvl_reg_info_t *mvl_ge_get_master_table(dev_object_t *dev);
static uint32_t mvl_ge_dev_reconfig(dev_object_t *, void *, boolean *);
static int mvl_ge_smi_rd(ulong addr, int size, ulong *buf, void *param);
static int mvl_ge_smi_wr(ulong addr, int size, ulong data, void *param);
static uint32_t mvl_ge_dev_show(dev_object_t *, print_fn_t, dev_show_cmd);
*  Extern Functions Declaration
extern int register_tests(ulong base_addr, reg_info_t *reg_ptr);
extern void mdelay(uint32_t msecs);
*                    Global variables                               *
/* reg_info_t extension for SMI access */
static reg_info_t_ext reg_ext = {
    sizeof(smi_t), mvl_ge_smi_rd, mvl_ge_smi_wr, 0};
/* Common registers for all pages */
static reg_info_t ge_1112_cmn_reg_tbl[] = {
    {"PHY Identifier 1", MRV88E111N_PHYID_1_REG, READ_ONLY | SAVE_RESTORE |
     REG_ACCESS, {(uint)&reg_ext}, 0xFFFF, MRV88E1112_PHY_ID_1_VALUE},
    {"PHY Identifier 2", MRV88E111N_PHYID_2_REG, READ_ONLY | SAVE_RESTORE |
     REG_ACCESS, {(uint)&reg_ext}, 0xFFFF, MRV88E1112_PHY_ID_2_VALUE},
    /* Page Address bit 15 - Enable automatic medium register selection */
    /* The note in 88E1112C and 88E1114 (Section 3 Registers Description)
     * - "Note that in order for the paging mechanism to work correctly
     * register 22.15 must be set to 0 to disable the automatic medium
     * register seection"
    {"Page Address", MRV88E111N_PAGE_ADDRESS_REG, READ_WRITE | SAVE_RESTORE |
     REG_ACCESS, {(uint)&reg_ext}, 0x00FF, 0x0000},
    {"End of Common registers page", 0, 0, {0}, 0, 0},
/* Page 0 - Copper */
static reg_info_t ge_1112_p0_reg_tbl[] = {
    /* Control Register - Bit 15 (Reset) and  Bit 9 (Restart Auto-Negotiation)
     * are SC (self clear)
     * Bit 14 (Loopback) - Loopback speed is determined by the mode the device
     * is in Registers 0_2:13 and 0_2:6. After writing 0x7140, it reads back
     * 0x3140.
     * Bit 8 (Duplex Mode), Bit 12 (Auto-Negotiation Enable), and Bits 13, 6
     * (Speed Selection) - "A write to this register bit does not take effect
     * until any one of the following also occurs: Software reset is asserted,
     * Restart Auto-Negotiation is asserted, Power down transition from power
     * down to normal operation.
    /* Bit 11 (Power Down) will work with the registers test. But the side
     * effect will cause the loopback tests later on to fail.
    {"Control Register", MRV88E111N_CONTROL_REG,
     READ_WRITE | SAVE_RESTORE | REG_ACCESS, {(uint)&reg_ext},
     0x0000, 0x1140},
    {"Status Register", MRV88E111N_STATUS_REG,
     READ_ONLY | SAVE_RESTORE | REG_ACCESS, {(uint)&reg_ext},
     0xFF7F, 0x0149},
    {"Auto-Negotiation Advertisement Register", MRV88E111N_AUTONEG_ADVR_REG,
     0xAFFF, 0x0001},
    {"Link Partner Ability Register - Base Page", MRV88E111N_LINK_PART_AV_REG,
     0xFFFF, 0x0000},
    {"Auto-Negotiation Expansion Register", MRV88E111N_AUTONEG_EXPANSION_REG,
     0x001F, 0x0004},
    {"Next Page Transmit Register", MRV88E111N_NEXT_PAGE_REG,
     0xB7FF, 0x2001},
    {"Link Partner Next Page Register", MRV88E111N_LP_NEXT_PAGE_REG,
     0xFFFF, 0x0000},
    {"1000BASE-T Control Register", MRV88E111N_1000B_CNTL_REG,
     0x1F00, 0x0F00},
    {"1000BASE-T Status Register", MRV88E111N_1000B_STATUS_REG,
     0xFCFF, 0x0000},
    {"Extended Status Register", MRV88E111N_EXTENDED_STATUS_REG,
     0xF000, 0x0000},
    {"Specific Control Register 1", MRV88E111N_SPECIFIC_CONTROL1_REG,
     0xFFE3, 0x6060},
    {"Specific Status Register 1", MRV88E111N_SPECIFIC_STATUS1_REG,
     0xFFFF, 0x0010},
    {"Interrupt Enable Register", MRV88E111N_INT_ENABLE_REG,
     0xFF77, 0x0000},
    {"Specific Status Register 2", MRV88E111N_SPECIFIC_STATUS2_REG,
     0xFF77, 0x0000},
    {"Receive Error Counter Register", MRV88E111N_REC_ERROR_COUNTER_REG,
     0xFFFF, 0x0000},
    {"Specific Control Register 2", MRV88E111N_SPECIFIC_CONTROL2_REG,
     0x81F2, 0x0040},
    {"End of Page 0 registers", 0, 0, {0}, 0, 0},
/* Page 1 - Fiber */
static reg_info_t ge_1112_p1_reg_tbl[] = {
     * Bit 13 (speed Select) - "To configure the SGMII media side interface
     * speed when 0_1.12 disables Auto-Negotiation, use 0_2:6, 0_2.13"
     * Bit 12 (Auto-Negotiation Enable), Bit 8 (Duplex Mode) and Bit 6
     * (Speed Selection (MSB)) - "A write to this register bit does not take
     * effect until any one of the following also occurs: Software reset is
     * asserted, Restart Auto-Negotiation is asserted, Power down transition
     * from power down to normal operation.
    {"Control Register", MRV88E111F_CONTROL_REG,
     0x4000, 0x0100},
    {"Status Register", MRV88E111F_STATUS_REG,
     0xFF7D, 0x0141},
    {"Auto-Negotiation Advertisement Register", MRV88E111F_AUTONEG_ADVR_REG,
     0xB1E0, 0x0060},
    {"Link Partner Ability Register - Base Page", MRV88E111F_LINK_PART_AV_REG,
     0xFDE0, 0x0000},
    {"Auto-Negotiation Expansion Register", MRV88E111F_AUTONEG_EXPANSION_REG,
     0x000F, 0x0004},
    {"Next Page Transmit Register", MRV88E111F_NEXT_PAGE_REG,
     0xB7FF, 0x2001},
    {"Link Partner Next Page Register", MRV88E111F_LP_NEXT_PAGE_REG,
     0xFFFF, 0x0000},
    {"Extended Status Register", MRV88E111F_EXTENDED_STATUS_REG,
     0xF000, 0x0000},
    {"Specific Control Register 1", MRV88E111F_SPECIFIC_CONTROL1_REG,
     0x0E00, 0x0000},
    {"Specific Status Register 1", MRV88E111F_SPECIFIC_STATUS1_REG,
     0xFFF8, 0x0010},
    {"Interrupt Enable Register", MRV88E111F_INT_ENABLE_REG,
     0x3F10, 0x0000},
    {"Specific Status Register 2", MRV88E111F_SPECIFIC_STATUS2_REG,
     0x3F10, 0x0000},
    {"Receive Error Counter Register", MRV88E111F_REC_ERROR_COUNTER_REG,
     0xFFFF, 0x0000},
    {"Specific Control Register 2", MRV88E111F_SPECIFIC_CONTROL2_REG,
     0xE080, 0x8103},
    {"End of Page 1 registers", 0, 0, {0}, 0, 0},
/* Page 2 - MAC */
static reg_info_t ge_1112_p2_reg_tbl[] = {
    /* Control Register - Bit 15 (Reset) is SC (self clear)
     * Bit 14 (Loopback) is not working. After writing 0x7040, it returns
     * 0x3040.
     * Bits 13 and 6 (Default MAC Interface and SGMII Media Interface Speed),
     * Bit 12 (SGMII MAC Interface or GBIC Auto-Negotiation Enable) - "Change
     * to these bits are disruptive to the normal operation; therefore, any
     * changes to these registers must be followed by software reset to take
     * effect."
    {"Control Register", MRV88E111M_CONTROL_REG,
     0x0000, 0x1000},
    {"Specific Control Register 1", MRV88E111M_SPECIFIC_CONTROL1_REG,
     0xFF84, 0x0008},
    {"Specific Status Register 1", MRV88E111M_SPECIFIC_STATUS1_REG,
     0x0460, 0x0000},
    {"Interrupt Enable Register", MRV88E111M_INT_ENABLE_REG,
     0x0080, 0x0000},
    {"Specific Status Register 2", MRV88E111M_SPECIFIC_STATUS2_REG,
     0x0080, 0x0000},
    {"Specific Control Register 2", MRV88E111M_SPECIFIC_CONTROL2_REG,
     0xE090, 0x0000},
    {"End of Page 2 registers", 0, 0, {0}, 0, 0},
/* Page 3 - LOS, INIT, STATUS[1:0] */
static reg_info_t ge_1112_p3_reg_tbl[] = {
    {"Function Control Register", MRV88E111L_FUNC_CONTROL_REG,
     0xFFFF, 0x021E},
    {"Polarity Control Register 1", MRV88E111L_POL_CONTROL_REG,
     0xFFFF, 0x44A0},
    {"Timer Control Register 2", MRV88E111L_TMR_CONTROL_REG,
     0x770F, 0x4105},
    {"End of Page 3 registers", 0, 0, {0}, 0, 0},
/* Page 4 - Non-Volatile Memory */
static reg_info_t ge_1112_p4_reg_tbl[] = {
    {"I2C Address Register", MRV88E111NV_ADDRESS,
     0xFFFF, 0x0100},
    {"Read Data and Status Register", MRV88E111NV_READ_DATA_STATUS,
     0xE7FF, 0x0000},
    {"Write Data and Control Register", MRV88E111NV_WRITE_DATA_CONTROL,
     0xF2FF, 0xA000},
    {"RAM Write Data and Control Register", MRV88E111NV_RAM_WRITE_DATA_CONTROL,
     0x00FF, 0x0000},
    {"RAM Address Register", MRV88E111NV_RAM_ADDRESS,
     0x00FF, 0x0000},
    {"End of Page 4 registers", 0, 0, {0}, 0, 0},
/* Page 5 - Virtual Cable Tester */
static reg_info_t ge_1112_p5_reg_tbl[] = {
    /* MDI[0] Virtual Cable Rester Status Register - Bit 15 (Run VCT Test)
     * is SC (self clear).
    {"MDI[0] VCT Status Register", MRV88E111N_VCT_STATUS_MDI0_REG,
     0x0000, 0x0000},
    {"MDI[1] VCT Status Register", MRV88E111N_VCT_STATUS_MDI1_REG,
     0x8000, 0x0000},
    {"MDI[2] VCT Status Register", MRV88E111N_VCT_STATUS_MDI2_REG,
     0x7FFF, 0x0000},
    {"MDI[3] VCT Status Register", MRV88E111N_VCT_STATUS_MDI3_REG,
     0x7FFF, 0x0000},
    {"1000 BASE-T Pair Skew Register", MRV88E111N_VCT_PAIR_SKEW_REG,
     0xFFFF, 0x0000},
    {"1000 BASE-T Pair Swap and Polarity", MRV88E111N_VCT_PAIR_SWP_POL_REG,
     0x007F, 0x0000},
    {"VCT DSP Distance", MRV88E111N_VCT_DSP_DISTANCE,
     0x0007, 0x0000},
    {"End of Page 5 registers", 0, 0, {0}, 0, 0},
/* Page 6 - Miscellaneous */
static reg_info_t ge_1112_p6_reg_tbl[] = {
    {"Packet Generation", MRV88E111N_PACKET_GEN_REG,
     0x001F, 0x0000},
    {"CRC Counters", MRV88E111N_CRC_CHKR_REG,
     0xFFFF, 0x0000},
    {"End of Page 6 registers", 0, 0, {0}, 0, 0},
static reg_info_t ge_1114_cmn_reg_tbl[] = {
     REG_ACCESS, {(uint)&reg_ext}, 0xFFFF, MRV88E1114_PHY_ID_1_VALUE},
    REG_ACCESS, {(uint)&reg_ext}, 0xFFFF, MRV88E1114_PHY_ID_2_VALUE},
static reg_info_t ge_1114_p0_reg_tbl[] = {
     * 0x3140.
     * Bits 13, 6 (Speed Selection), Bit 12 (Auto-Negotation Enable), and Bit
     *  8 (Duplex Mode) - "A write to this register bit does not take effect
     * down to normal operation."
     0x0000, 0x1140},
     0xFF7F, 0x0149},
     0xAFFF, 0x0001},
     0xFFFF, 0x0000},
     0x001F, 0x0004},
     0xB7FF, 0x2001},
     0xFFFF, 0x0000},
     0x1F00, 0x0F00},
     0xFCFF, 0x0000},
     0x3000, 0x0000},
     0xFFE3, 0x6060},
     0xFF7F, 0x0010},
     0xFF77, 0x0000},
     0xFF77, 0x0000},
     0xFFFF, 0x0000},
     0x81F2, 0x0040},
/* Page 1 - Not Used */
static reg_info_t ge_1114_p1_reg_tbl[] = {
     0xFFFF, 0x0000},
/* Page 2 - MAC */
static reg_info_t ge_1114_p2_reg_tbl[] = {
     * 0x3040.
     * Bits 13 and 6 (Default MAC Interface and Speed), Bit 12 (MAC
     * Interface Auto-Negotiation Enable) - "Changes to these bits are
     * disruptive to the normal operation; therefore, any changes to these
     * registers must be followed by software reset to take effect."
     0x0000, 0x1000},
     0xF380, 0x0288},
     0x0460, 0x0000},
     0x0080, 0x0000},
     0x0080, 0x0000},
     0xE010, 0x0000},
static reg_info_t ge_1114_p3_reg_tbl[] = {
     0xFFFF, 0x021E},
     0xFFFF, 0x44A0},
     0x770F, 0x4105},
static reg_info_t ge_1114_p4_reg_tbl[] = {
     0xFFFF, 0x0100},
     0xE7FF, 0x0000},
     0xF2FF, 0xA000},
     0x00FF, 0x0000},
     0x00FF, 0x0000},
static reg_info_t ge_1114_p5_reg_tbl[] = {
    /* MDI[0] Virtual Cable Tester Status Register - Bit 15 (Run VCT Test) is
     * SC (self-clear)
     0x0000, 0x0000},
     0x8000, 0x0000},
     0x7FFF, 0x0000},
     0x7FFF, 0x0000},
     0xFFFF, 0x0000},
     0x007F, 0x0000},
     0x0007, 0x0000},
static reg_info_t ge_1114_p6_reg_tbl[] = {
     0x001F, 0x0000},
     0xFFFF, 0x0000},
/* Master page tables */
/*  88E1112 */
static dev_mrvl_reg_info_t ge_1112_reg_tbl[] = {
    {MRV88E111N_REG_PAGE_0, &ge_1112_cmn_reg_tbl[0]},   /* Common registers */
    {MRV88E111N_REG_PAGE_0, &ge_1112_p0_reg_tbl[0]},    /* Page 0 */
    {MRV88E111N_REG_PAGE_1, &ge_1112_p1_reg_tbl[0]},    /* Page 1 */
    {MRV88E111N_REG_PAGE_2, &ge_1112_p2_reg_tbl[0]},    /* Page 2 */
    {MRV88E111N_REG_PAGE_3, &ge_1112_p3_reg_tbl[0]},    /* Page 3 */
    {MRV88E111N_REG_PAGE_4, &ge_1112_p4_reg_tbl[0]},    /* Page 4 */
    {MRV88E111N_REG_PAGE_5, &ge_1112_p5_reg_tbl[0]},    /* Page 5 */
    {MRV88E111N_REG_PAGE_6, &ge_1112_p6_reg_tbl[0]},    /* Page 6 */
    {0, 0},                     /* End */
/*  88E1114 */
static dev_mrvl_reg_info_t ge_1114_reg_tbl[] = {
    {MRV88E111N_REG_PAGE_0, &ge_1114_cmn_reg_tbl[0]},   /* Common registers */
    {MRV88E111N_REG_PAGE_0, &ge_1114_p0_reg_tbl[0]},    /* Page 0 */
    {MRV88E111N_REG_PAGE_1, &ge_1114_p1_reg_tbl[0]},    /* Page 1 */
    {MRV88E111N_REG_PAGE_2, &ge_1114_p2_reg_tbl[0]},    /* Page 2 */
    {MRV88E111N_REG_PAGE_3, &ge_1114_p3_reg_tbl[0]},    /* Page 3 */
    {MRV88E111N_REG_PAGE_4, &ge_1114_p4_reg_tbl[0]},    /* Page 4 */
    {MRV88E111N_REG_PAGE_5, &ge_1114_p5_reg_tbl[0]},    /* Page 5 */
    {MRV88E111N_REG_PAGE_6, &ge_1114_p6_reg_tbl[0]},    /* Page 6 */
    {0, 0},                     /* End */
* Name: mrvl_ge_dev_create()
* Description: Create object with various device function
* point to "do nothing"
* Input: dev_object_t pointer to the Marvell device.
*    error reporting function pointer.
* Returns: PASSED/FAILED
* Assumption:  Since this device driver is shared amongst different Marvell
*      chips, dev_object_fvt->dev_name needs to be filled after this
*      call.
int
mrvl_ge_dev_create (dev_object_t *dev, dev_error_report_t error_report_fn)
    dev_object_fvt_t    *dev_fvt;
    dev_mrvl_ge_object_t *mrvl_p = (dev_mrvl_ge_object_t *)dev;
    /* Allocate memory for the device object */
    if ((dev_fvt = (dev_object_fvt_t *)malloc(sizeof(dev_object_fvt_t))) ==
        NULL) {
    /* Unable to allocate memory */
    error_report_fn(dev, "obj malloc failure in mrvl_ge_dev_create()",
            0);
    return (FAILED);
    } else {
#ifdef MEM_DEBUG
    printf("\ndev obj @ %#x\n", dev_fvt);
#endif /* MEM_DEBUG */
    /* Init the device object structure to default "do nothing" */
    init_default_dev_object(dev, dev_fvt);
    mrvl_p->base.dev_object_fvt->dev_attach = mvl_ge_dev_attach;
    mrvl_p->base.dev_object_fvt->dev_detach = mvl_ge_dev_detach;
    mrvl_p->base.dev_object_fvt->dev_reconfig_needed = mvl_ge_dev_reconfig;
    mrvl_p->base.dev_object_fvt->dev_restart    = mvl_ge_dev_restart;
    mrvl_p->base.dev_object_fvt->dev_init   = mvl_ge_dev_init;
    mrvl_p->base.dev_object_fvt->dev_oper_enable  = mvl_ge_dev_oper_en;
    mrvl_p->base.dev_object_fvt->dev_oper_disable = mvl_ge_dev_oper_dis;
    mrvl_p->base.dev_object_fvt->dev_intr_enable  = mvl_ge_dev_intr_en;
    mrvl_p->base.dev_object_fvt->dev_intr_disable = mvl_ge_dev_intr_dis;
    mrvl_p->base.dev_object_fvt->dev_isr    = mvl_ge_dev_isr;
    mrvl_p->base.dev_object_fvt->dev_show   = mvl_ge_dev_show;
    mrvl_p->base.dev_object_fvt->dev_error_report = error_report_fn;
    mrvl_p->base.dev_object_fvt->dev_collect_crashinfo = mvl_ge_crsh;
    mrvl_p->base.dev_object_fvt->dev_destroy    = mvl_ge_destroy;
    mrvl_p->base.dev_object_fvt->dev_name = "Marvell GE PHY";
    if ((mrvl_p->callin_fvt = (mrvl_ge_callin_fvt_t *)
                   malloc(sizeof(mrvl_ge_callin_fvt_t))) == NULL) {
#ifdef MEM_DEBUG
    printf("freeing dev_fvt @ %#x after malloc callin\n", dev_fvt);
    free(dev_fvt);
    error_report_fn(dev, "callin malloc failure in mrvl_ge_dev_create()",
            0);
    return (FAILED);
    } else {
#ifdef MEM_DEBUG
    printf("callin_fvt @ %#x\n", mrvl_p->callin_fvt);
    if ((mrvl_p->callout_fvt = (mrvl_ge_callout_fvt_t *)
                   malloc(sizeof(mrvl_ge_callout_fvt_t))) == NULL) {
#ifdef MEM_DEBUG
    printf("freeing callout @ %#x after malloc callout \n", mrvl_p->callout_fvt);
    free(mrvl_p->callin_fvt);
#ifdef MEM_DEBUG
    printf("freeing dev_fvt @ %#x\n", dev_fvt);
    free(dev_fvt);
    error_report_fn(dev, "callout malloc failure in mrvl_ge_dev_create()",
            0);
    return (FAILED);
    } else {
#ifdef MEM_DEBUG
     printf("callout_fvt @ %#x\n", mrvl_p->callout_fvt);
    mrvl_p->base.dev_state = DEV_STATE_CREATE;
    return (PASSED);
* Name: mvl_ge_dev_attach()
* Description: Attach the Marvell GE device for use. This
*   function will initialize and setup all necessary pointers
*   and bring the chip to operation.
* Input: Pointer to the Marvell GE device object
static uint32_t
mvl_ge_dev_attach (dev_object_t *dev)
    uint32_t rc;
    char err_buf[ERR_BUF_SIZE];
    if (mrvl_p->base.dev_state != DEV_STATE_CREATE) {
    sprintf(err_buf, "Invalid device state %#x for attach",
              mrvl_p->base.dev_state);
    DEV_ERROR_REPORT(dev, err_buf, (uint32_t)MRVL_GE_ATTACH);
    return (FAILED);
    /* init the call in function */
    mrvl_p->callin_fvt->register_test = mvl_ge_reg_test;
    mrvl_p->callin_fvt->set_loopback = mvl_ge_set_loopback;
    mrvl_p->callin_fvt->alter_reg = mvl_ge_alt_reg;
    mrvl_p->callin_fvt->set_synce= mvl_ge_set_synce;
    mrvl_p->callin_fvt->set_test_mode = mvl_ge_set_test_mode;
    /* Lock the SMI device */
    if ((rc = mrvl_p->callout_fvt->open(mrvl_p->smi_p)) != PASSED) {
    sprintf(err_buf, "mvl_ge_dev_attach() SMI open failed with rc = %#x",
                            rc);
        return (FAILED);
    mrvl_p->base.dev_state = DEV_STATE_ATTACH;
    return (PASSED);
* Name: mrvl_ge_dev_detach()
* Description: detach the device specific functions from the caller.
*      All of the device specific function are connected to the
*      dev_do_nothing() function, except for the dev_attach()
*      function. Also, the dev_state must be assigned the value
*      of DEV_STATE_DETACH.
*      Since, some platforms may want to detach the device, but not
*      release the memory resources (via a free () in the
*      dev_destroy()), this function can be executed to accomplish
*      this task. However, before a detached device can be used again,
*      it must be re-attached (via the dev_attach()).
static uint32_t
mvl_ge_dev_detach (dev_object_t *dev)
    uint32_t rc;
    dev_mrvl_ge_object_t *mrvl_p = (dev_mrvl_ge_object_t *) dev;
    /* Unlock the SMI device */
    if ((rc = mrvl_p->callout_fvt->close(mrvl_p->smi_p)) != PASSED) {
    sprintf(err_buf, "mvl_ge_dev_detach() SMI close rc = %#x", rc);
    DEV_ERROR_REPORT(dev, err_buf, MRVL_GE_DETACH);
    return (FAILED);
    init_default_dev_object(dev, mrvl_p->base.dev_object_fvt);
    mrvl_p->base.dev_state = DEV_STATE_DETACH;
    return (PASSED);
* Name: mvl_ge_dev_reconfig_needed
* Description: To check whether device re-configuration is needed during
*      (re)initialization. Based on the provided context information,
*      the boolean return value, and possibly other factors external
*      to the device object, the caller shall decide whether to invoke
*      either dev_restart or dev_init, but not both. In general, the
*      boolean return value alone is not sufficient to decide whether
*      the device can safely be restarted or whether it must be fully
*      initialized from scratch.
* Input: dev_object_t pointer to the Marvell GE device
*    void * - a device/platform specific context handle
*    boolean * - a pointer to a boolean
* Returns: PASSED/FAILED, context information and a boolean value.
*      The boolean value shall be set to TRUE if the device must be
*      reconfigured from scratch and it shall be set to FALSE otherwise.
* Assumptions: The dev_attach() function has been called and successfully
static uint32_t
mvl_ge_dev_reconfig(dev_object_t *dev, void *context_handle,
                     boolean *reconfig)
    *reconfig = FALSE;      /* No need to reconfig from scratch */
    return (PASSED);
* Name: mvl_ge_dev_restart
* Description: To restart a previously initialized device without resetting
*      the device or changing its configuration.
*      For example, during a failover event.
*      Change the state of the device from its current state
*      to an initial state. Also, dev_state must be assigned the
*      value of DEV_STATE_INIT.
* Input: dev_object_t pointer to the Marvell GE DEVICE
* Assumptions: The dev_attach() and dev_reconfig_needed() functions has been
*              called and successfully executed.
static uint32_t
mvl_ge_dev_restart(dev_object_t *dev)
    mrvl_p->base.dev_state = DEV_STATE_INIT;
    return (PASSED);
* Name: mvl_ge_dev_init()
* Description: Initializes the Marvell GE chip
* Input: dev_object_t pointer to the Marvell GE device.
*    Caller has to setup the smi_p parameters with init values.
* Note: Make sure base.dev_addr has been initialized to chip_base_addr
*       before calling this function.
static uint32_t
mvl_ge_dev_init (dev_object_t *dev)
    uint32_t rc;
    smi_if_t smi_if;
    reg_info_t *init_p;
    dev_mrvl_reg_info_t *master_reg_p;
    mrvl_ge_callout_fvt_t *callout_p = mrvl_p->callout_fvt;
    smi_t smi_reg;
    /* Setup the SMI API interface struct */
    smi_if.smi_dev = mrvl_p->smi_p->smi_dev;
    smi_if.buf = &smi_reg;
    /* Get the register info table */
    master_reg_p = mvl_ge_get_master_table(dev);
    if (master_reg_p == 0) {
    DEV_ERROR_REPORT(dev, "mvl_ge_dev_init() unable to get the table",
                    MRVL_GE_INIT);
    return (FAILED);
    /* Traverse through all pages */
    while (master_reg_p->reg_p) {
    /* Setup the page */
    smi_if.offset = MRV88E111N_PAGE_ADDRESS_REG;
    smi_reg = master_reg_p->page;
    rc = (*callout_p->wr)(&smi_if);
    if (rc != PASSED) {
        sprintf(err_buf, "mvl_ge_dev_init() Page %#x write failed rc = %#x",
            smi_reg, rc);
        DEV_ERROR_REPORT(dev, err_buf, MRVL_GE_INIT);
        return (FAILED);
    init_p = master_reg_p->reg_p;
    /* Call registers table init. */
    while(init_p->size.size != 0) {
        smi_if.offset = init_p->offset;
        smi_reg = init_p->reset_val; /* Use reset_val as init valure */
        /* Write to the Marvell GE with platform default value */
        if (rc != PASSED) {
        sprintf(err_buf, "mvl_ge_dev_init() write %#x @ %#x pg %#x"
                 " rc = %#x", smi_reg, smi_if.offset,
                 master_reg_p->page, rc);
        return (FAILED);
        init_p++;
    } /* endof while init_p */
    master_reg_p++;
    } /* endof master_reg_p */
    /* Reset to page 0 */
    smi_reg = MRV88E111N_REG_PAGE_0;
    if (rc != PASSED) {
    DEV_ERROR_REPORT(dev, "mvl_ge_dev_init() Unable to set to page 0",
                MRVL_GE_INIT);
    return (FAILED);
    return (PASSED);
* Name: mvl_ge_dev_oper_en
* Description: Enable device operation.
*      Change the state of the device from its current state to an
*      enabled state (which implies that the device is in an
*      operational state at the end of this function execution). Also,
*      the dev_state must be assigned the value of DEV_STATE_ENABLE_OP
*      For devices such as port asic's and framers, this function
*      be used to enable all or only part of the total device port's
*      or channel's.
* Assumptions: The dev_init() function has been called and successfully
static uint32_t
mvl_ge_dev_oper_en(dev_object_t *dev)
    uint32_t rc;
    /* Take the GE device out of reset. The port (enum) to be enabled is in the
     * SMI interface struct */
    /* Enable the device */
    rc = (*callout_p->dev_reset)(ENABLE);
    if (rc != PASSED) {
    sprintf(err_buf, "mvl_ge_dev_oper_en() reset return code = %#x", rc);
    DEV_ERROR_REPORT(dev, err_buf, MRVL_GE_RESET);
    return (FAILED);
    mrvl_p->base.dev_state = DEV_STATE_ENABLE_OP;
    return (PASSED);
* Name: mvl_ge_dev_oper_dis
* Description: Disable device operation.
*      disabled state (which implies that the device is in a
*      non-operational state at the end of this function execution).
*      Also, the dev_state must be assigned the value of
*      DEV_STATE_DISABLE_OP
*      be used to disable all the ports or channels of a specific
*      device
static uint32_t
mvl_ge_dev_oper_dis(dev_object_t *dev)
    uint32_t rc;
    /* Put the GE device into reset. The port (num) to be disabled is in the
    /* Disable the device */
    rc = (*callout_p->dev_reset)(DISABLE);
    if (rc != PASSED) {
    sprintf(err_buf, "mvl_ge_dev_oper_dis() reset return code = %#x", rc);
    return (FAILED);
    mrvl_p->base.dev_state = DEV_STATE_DISABLE_OP;
    return (PASSED);
* Name: mvl_ge__dev_intr_en
* Description: Enable the device interrupt(s).
*      This function is expected to enable the interrupt(s) for a
*      device with the expectation that all portions of the device
*      are active, it is possible that some portions of a device are
*      disabled.
static uint32_t
mvl_ge_dev_intr_en (dev_object_t *dev)
    smi_t smi_d;        /* Data bytes for SMI */
    smi_if_t smi_if;
    /* Setup SMI API interface struct */
    smi_if.buf = &smi_d;
    /* Enable Interrupt Control interupts */
/* TBD */
    return (PASSED);
* Name: mvl_ge_dev_intr_dis
* Description: Disable the device interrupt(s).
*      This function is expected to disable ALL of the device
*      interrupt(s).
static uint32_t
mvl_ge_dev_intr_dis (dev_object_t *dev)
    smi_if_t smi_if;
    smi_d = 0;      /* Disable all interrupts */
    /* Disable Interrupt Control interrupts */
/* TBD */
    return (PASSED);
* Name: mvl_ge_dev_isr
* Description: Process and handle the interrupt(s) on this device.
static uint32_t
mvl_ge_dev_isr (dev_object_t *dev)
    smi_if_t smi_if;
#if 0 /* TBD */
     * Read the interrupt status registers.
     * *** Need mechanism to pass status back to caller. print them out for now
    for (i = 0, new_i2c_if.offset = IDT32021_INTERRUPT1_STS;
     i < IDT32021_NUM_INTRS; i++, new_i2c_if.offset++) {
     new_i2c_if.buf = &intr[i];
    /* Read the interrupt status from the IDT82V32021 */
    rc = callout_p->rd(&smi_if);
    if (rc != PASSED) {
        sprintf(err_buf, "mvl_ge_dev_isr() read from %#x rc %#x\n",
                smi_if.offset, rc);
        DEV_ERROR_REPORT(dev, err_buf, MRVL_GE_ISR);
        return (FAILED);
    printf("\nMarvell GE Interrupt Status %d = %#x\n", intr[i]);
    /* Write the same value back to clear */
    rc = callout_p->wr(&smi_if);
    if (rc != PASSED) {
        sprintf(err_buf, "mvl_ge_dev_isr() write to %#x rc %#x\n",
                smi_if.offset, rc);
        return (FAILED);
#endif /* 0 TBD */
    /* Mask off the interrupts to prevent solid interrupts */
    return (mvl_ge_dev_intr_dis(dev));
* Name: mvl_ge_dev_show
* Description: Provide platforms with a mechanism to display some common
*      device information via the device print function argument.
*    A device print function vector
*    A dev_show_cmd_e command
* Assumptions: The device printf function vector has been provided by the host
*              platform which implements the print logging functionality. The
*              dev_attach() function has been called and successfully executed
static uint32_t
mvl_ge_dev_show(dev_object_t *dev, print_fn_t dev_print, dev_show_cmd cmd)
    uint32_t i, rc;
    smi_if_t smi_if;
    smi_t reg_d, original_page_reg;
    reg_info_t *reg_p;
    smi_if.smi_dev = mrvl_p->smi_p->smi_dev;    /* Setup SMI interface */
    /* Get the original Page register */
    smi_if.buf = &original_page_reg;
    rc = (*callout_p->rd)(&smi_if);
    if (rc != PASSED) {
    sprintf(err_buf, "mvl_ge_dev_show() Page reg read failed. rc = %#x",
                    rc);
    DEV_ERROR_REPORT(dev, err_buf, MRVL_GE_SHOW);
    return (FAILED);
    smi_if.buf = &reg_d;    /* Buffer address */
    DEV_ERROR_REPORT(dev, "mvl_ge_dev_show() unable to get the table",
                    MRVL_GE_SHOW);
    return (FAILED);
    reg_d = master_reg_p->page;
    if (rc != PASSED) {
        /* If we cannot write to the page register, then we cannot recover
         * the page register.
        sprintf(err_buf, "mvl_ge_dev_show() Page %#x write failed rc %#x",
                    reg_d, rc);
        return (FAILED);
    /* Page set. Ready to show all registers in the page */
    reg_p = master_reg_p->reg_p;
    dev_print("\n Page %d :\n", master_reg_p->page);
    switch (cmd) {
    case DEV_SHOW_ALL:
    case DEV_SHOW_CONFIG:
    case DEV_SHOW_REGISTERS:
        while (reg_p->size.size != 0) {
        /* Read the data bytes of Marvell GE */
        smi_if.offset = reg_p->offset;
        if (rc != PASSED) {
            sprintf(err_buf, "mvl_ge_dev_show() %s register read failed"
                     " rc = %#x", reg_p->name, rc);
            return (FAILED);
        dev_print("%s @ %#.2x = %#.4x\n",
               reg_p->name, reg_p->offset, reg_d);
        reg_p++;
        } /* endof while */
        break;
    case DEV_SHOW_BRIEF:
        for (i = 0; i < MAX_SMI_REGS; i++) {
        smi_if.offset = i;
        if (rc != PASSED) {
            sprintf(err_buf, "mvl_ge_dev_show() brief read @ %x failed"
                     " rc = %#x", i, rc);
            return (FAILED);
        dev_print("%#.4x ", reg_d);
        if ((i & SMI_SHOW_MASK) == SMI_SHOW_MASK) {
            dev_print("\n");
        } /* endof for */
        break;
    default:
        assert(!"mvl_ge_dev_show");
        return (FAILED);
        break;
    } /* endof switch */
    master_reg_p++;     /* Point to the next page */
    } /* endof while */
    /* Restore the page register */
    if (rc != PASSED) {
    sprintf(err_buf, "mvl_ge_dev_show() Page reg restore failed rc %#x",
                    rc);
    return (FAILED);
    return (PASSED);
* Name: mvl_ge_crsh
* Description: Allow platforms to collect data from a device during a crash.
*      Print data to the crash log (via the provide print error) using
*      the appropriate verbisity level requested by the host
*        A crash print function vector.
*        A verbosity level.
* Assumptions: A device print function vector has been provided by the host
*      platform which implements the crash logging functionality. It
*      could be the mechanism to log info to the Compact Flash before
*      the device crash and now retrieve them. The dev_attch()
*      function has been called and successfully executed.
static uint32_t
mvl_ge_crsh(dev_object_t *dev, print_fn_t dev_print, dev_show_cmd verbosity)
    /* more development in this section */
    dev_print("mvl_ge_crsh(): No Crash info available for Marvell GE\n");
    return (PASSED);
* Name: mvl_ge_destroy
* Description: Destroy the dev_object structure and free all the resources.
* Returns: none
* Assumptions: The dev_attch() function has been called and successfully
static void
mvl_ge_destroy(dev_object_t **dev)
    dev_mrvl_ge_object_t *mrvl_p;
    uint32_t rc;
    if (dev == NULL) {
    return;
    if (*dev == NULL) {
    return;
    mrvl_p = (dev_mrvl_ge_object_t *)*dev;
    sprintf(err_buf, "mvl_ge_destroy() SMI close return code = %#x", rc);
    DEV_ERROR_REPORT(*dev, err_buf, MRVL_GE_DESTROY);
    if (mrvl_p->callout_fvt) {
#ifdef MEM_DEBUG
    printf("freeing callout @ %#x\n", mrvl_p->callout_fvt);
    free(mrvl_p->callout_fvt);  /* Free callout struct */
    if (mrvl_p->callin_fvt) {
#ifdef MEM_DEBUG
    printf("freeing callin @ %#x\n", mrvl_p->callin_fvt);
    free(mrvl_p->callin_fvt);   /* Free callin struct */
#ifdef MEM_DEBUG
    printf("freeing object @ %#x\n", mrvl_p->base.dev_object_fvt);
    free(mrvl_p->base.dev_object_fvt);  /* Free dev_object_t */
* Function: mvl_ge_reg_test
* This function: tests Marvell GE registers.
*        Also check the ID of the chip.
* Input : dev - Pointer to the Marvell GE device object
* Output: PASSED/FAILED
static int
    uint32_t rc;
    smi_if_t smi_if, *original_smi_if;
    smi_t data, original_page_reg;
    reg_info_t *reg_ptr;
    smi_if.buf = &data;             /* setup test buffer */
    smi_if.offset = MRV88E111N_PHYID_1_REG; /* ID offset */
    original_smi_if = mrvl_p->smi_p;    /* Save the SMI if */
    mrvl_p->smi_p = &smi_if;        /* use local SMI if */
    /* Read the ID data byte of Marvell GE */
    if (rc != PASSED) {
    mrvl_p->smi_p = original_smi_if;    /* restore SMI if */
    sprintf(err_buf, "mvl_ge_reg_test() ID read failed with %#x.", rc);
    DEV_ERROR_REPORT(dev, err_buf, MRVL_GE_REG_TEST);
    return (FAILED);
    if (data != MRV88E111N_PHY_ID_1_VALUE) {
    /* ID does not match to the chip type */
    sprintf(err_buf, "mvl_ge_reg_test() ID read 0x%0.2x. Expect 0x%0.2x.",
                    data, MRV88E111N_PHY_ID_1_VALUE);
    return (FAILED);
    DEV_ERROR_REPORT(dev, "mvl_ge_reg_test() unable to get the table",
                    MRVL_GE_REG_TEST);
    return (FAILED);
    /* Save the page register */
    if (rc != PASSED) {
    sprintf(err_buf, "mvl_ge_reg_test() Page reg read failed. rc = %#x",
                    rc);
    return (FAILED);
    smi_if.buf = &data;     /* setup test buffer again */
    /* Setup the parameter for the registers test */
    reg_ext.param = (void *)dev;
    /* Setup page */
    data = master_reg_p->page;
    if (rc != PASSED) {
        sprintf(err_buf, "mvl_ge_reg_test() Page %#x write failed rc %#x",
                    data, rc);
        return (FAILED);
    /* registers_test() will call mvl_ge_smi_rd/wr() through reg_info_t_ext
     * struct's rd_ptr and wr_ptr.
    reg_ptr = master_reg_p->reg_p;
    if ((rc = register_tests(0, reg_ptr)) == FAILED) {
        sprintf(err_buf, "mvl_ge_reg_test() Page %#x register_tests failed",
        return (FAILED);
    master_reg_p++;
    /* Restore page register */
    if (rc != PASSED) {
    sprintf(err_buf, "mvl_ge_reg_test() Page reg restore failed rc %#x",
                    rc);
    return (FAILED);
    return (rc);
* Function:    mvl_ge_alt_reg
* This function: provides altering Marvell GE registers.
* Input:   dev - Pointer to the Marvell GE device object
static int
    uint32_t rc, page_rc;
    smi_if_t smi_if;
    if (rc != PASSED) {
    sprintf(err_buf, "mvl_ge_alt_reg() Page reg read failed. rc = %#x",
                    rc);
    DEV_ERROR_REPORT(dev, err_buf, MRVL_GE_ALTER);
    return (FAILED);
    /* Ready to setup the page */
    reg_d = gethex_answer("Enter the page: ", MRV88E111N_REG_PAGE_0,
            MRV88E111N_REG_PAGE_0, MRV88E111N_REG_PAGE_6);
    if (rc != PASSED) {
    sprintf(err_buf, "mvl_ge_alt_reg() Page %#x write failed rc %#x",
                    reg_d, rc);
    return (FAILED);
    /* Got the page setup. Get the register */
    smi_if.offset = gethex_answer("Enter the register offset: ", 0,
            0, MAX_SMI_REGS - 1);
    if (rc != PASSED) {
    /* Unable to read, recover the page */
    sprintf(err_buf, "mvl_ge_alt_reg() Unable to read register. rc = %#x",
                    rc);
    return (FAILED);
    /* Got the current data. Get the new data */
    reg_d = gethex_answer("Enter the new data: ", reg_d, 0, 0xFFFF);
    /* Write the new data */
    /* Recover the page */
    page_rc = (*callout_p->wr)(&smi_if);
    if (rc != PASSED) {
    sprintf(err_buf, "mvl_ge_alt_reg() Write failed with rc %#x", rc);
    return (FAILED);
    if (page_rc != PASSED) {
    sprintf(err_buf, "mvl_ge_alt_reg() Unable to recover page %#x rc %#x",
                    original_page_reg, page_rc);
    return (FAILED);
    return (PASSED);
* Function:   mvl_ge_set_synce
* This function: Set synce bit for 88e1512
static int
    smi_if_t smi_if;
    if (rc != PASSED) {
                    rc);
    return (FAILED);
    reg_d = 0x2;
    if (rc != PASSED) {
                    reg_d, rc);
    return (FAILED);
    smi_if.offset = 0x10;
    if (rc != PASSED) {
                    rc);
    return (FAILED);
    reg_d = reg_d | 0x1;
    if (rc != PASSED) {
    return (FAILED);
    return (FAILED);
    return (PASSED);
* Function:    mvl_ge_set_test_mode
* This function: provides PHY test mode for Marvell GE PHYs.
static int
    smi_if_t smi_if;
    smi_t reg_d, original_page_reg, test_mode;
    if (rc != PASSED) {
    sprintf(err_buf, "mvl_ge_set_test_mode() Page reg read failed. "
             "rc = %#x", rc);
    DEV_ERROR_REPORT(dev, err_buf, MRVL_GE_TEST_MODE);
    return (FAILED);
    /* Got the current mode. */
    rc = mvl_ge_rd_wr_reg(dev, PHY_READ, MRV88E111N_REG_PAGE_0,
              MRV88E111N_1000B_CNTL_REG, &reg_d);
    if (rc != PASSED) {
    sprintf(err_buf, "mvl_ge_set_test_mode() Unable to read test mode. "
             "rc = %#x", rc);
    return (FAILED);
    test_mode = (reg_d & PHY_GT_CTL_TEST_MASK) >> (PHY_GT_CTL_TEST_SHIFT);
    printf("\nTest modes -\n");
    printf("    0 - Normal Mode\n");
    printf("    1 - Test Mode 1 - Transmit Waveform Test\n");
    printf("    2 - Test Mode 2 - Transmit Jitter Test (Master mode)\n");
    printf("    3 - Test Mode 3 - Transmit Jitter Test (Slave mode)\n");
    printf("    4 - Test Mode 4 - Transmit Distortion Test\n");
    test_mode = gethex_answer("Enter the test mode: ", test_mode, 0,
                               PHY_GT_CTL_TEST_MAX);
    reg_d &= (~PHY_GT_CTL_TEST_MASK); /* clear the test mode */
    reg_d |= (test_mode << PHY_GT_CTL_TEST_SHIFT);
    rc = mvl_ge_rd_wr_reg(dev, PHY_WRITE, MRV88E111N_REG_PAGE_0,
    if (rc != PASSED) {
    sprintf(err_buf, "mvl_ge_set_test_mode() Unable to write test mode. "
             "rc = %#x", rc);
    return (FAILED);
    if (rc != PASSED) {
    sprintf(err_buf, "mvl_ge_set_test_mode() Write failed with rc %#x", rc);
    return (FAILED);
    sprintf(err_buf, "mvl_ge_set_test_mode() Unable to recover page %#x. "
             "rc = %#x", original_page_reg, page_rc);
    return (FAILED);
    return (PASSED);
* Function: mvl_ge_smi_rd
* This function: reads Marvell GE registers
* Input : addr - offset of register to be read.
*     size - ignored. For SMI, it is always 2.
*     buf  - points to the data buffer to be read. Note that this is a
*        pointer to ulong. SMI data is always 2 bytes long. Either
*        set SMI interface buf field to position at the lower 2 bytes
*        of the ulong, or use a working smi_t (2 bytes), then transfer
*        the resulting data to the ulong.
*     param - Pointer to the Marvell GE device object
static int
    uint32_t rc;
    smi_if_t smi_if;
    dev_mrvl_ge_object_t *mrvl_p = (dev_mrvl_ge_object_t *)param;
    smi_t smi_buf;
    /* Setup the interface struct for SMI API read */
    smi_if.offset = (uint8_t)addr;
    smi_if.buf = &smi_buf;
    /* Call the SMI Read API */
    if (rc != PASSED) {
    /* Read failed */
    sprintf(err_buf, "mvl_ge_smi_rd() read return code = %#x", rc);
    DEV_ERROR_REPORT((dev_object_t *)param, err_buf, MRVL_GE_READ);
    return (FAILED);
    } else {
    /* Got the data */
    *buf = smi_buf;     /* Converting from smi_t to unlong */
    return (PASSED);
* Function: mvl_ge_smi_wr
* This function: writes Marvell GE registers
* Input : addr - offset of register to be written.
*     size - Ignored. For SMI, it is always 2.
*         data  - write data. Note that SMI interface uses 2 bytes (smi_t).
*         similar to the read, we can either set the smi_if_t.buf
*         to point at the position of the lower 2 bytes of ulong, or
*         use a working smi_t area, and transfer the ulong data to the
*         smi_t work area.
static int
    uint32_t rc;
    smi_t smi_buf;
    smi_if_t smi_if;
    /* Setup the interface struct for SMI API write */
    smi_buf = (smi_t)data;  /* Get 2 bytes */
    /* Call the SMI Write API */
    if (rc != PASSED) {
    /* Write failed */
    sprintf(err_buf, "mvl_ge_smi_wr() write return code = %#x", rc);
    DEV_ERROR_REPORT((dev_object_t *)param, err_buf, MRVL_GE_WRITE);
    return (FAILED);
    } else {
    /* Data written */
    return (PASSED);
* Function:    mvl_ge_get_master_table
* This function: returns the pointer to the beginning of register table
*        array.
* Output:  Pointer to the beginning of the register table array.
    /* Check if the user provided the table */
    if (mrvl_p->reg_info_p) {
    /* User provided the table */
    return (mrvl_p->reg_info_p);
    } else {
    /* Use default table provided in this file */
    switch(mrvl_p->type) {
    case MRVL_GE_PHY_1112:
        /* 88E1112 Copper and Fiber */
        return (&ge_1112_reg_tbl[0]);
        break;
    case MRVL_GE_PHY_1114:
        /* 88E1114 Copper */
        return (&ge_1114_reg_tbl[0]);
        break;
    default:
        /* Unknown type */
        assert(!"mvl_ge_get_master_table");
        return (0);
        break;
* Function:    mvl_ge_set_loopback
* This function: sets the loopback mode to the Marvell GE device.
*      loopback mode - dev_mrvl_ge_loopback_t.
*      speed - dev_mrvl_ge_mode_t.
*      op - dev_mrvl_ge_loopback_op_t.
*      auto_neg - TRUE to auto negotiate on the MAC side.
* Output:  None
static int
    uint32_t rc;
    uint i;
    smi_if_t smi_if;
    smi_t reg_d, mac_mode, phy_page, link_mask;
    if (diag_global_flag & DIAG_FLAG_VERBOSE_MODE) {
        printf("mode %#x, speed %#x, op %#x\n", lpbk_mode, speed, op);
    switch (op) {
    case LPBKOP_SAVE:
    smi_if.buf = &mrvl_p->regs.page;
    if (rc != PASSED) {
        sprintf(err_buf, "mvl_ge_set_loopback() Page reg read rc = %#x",
                    rc);
        DEV_ERROR_REPORT(dev, err_buf, MRVL_GE_LPBK);
        return (FAILED);
    /* Get the MAC control register */
    rc = mvl_ge_rd_wr_reg(dev, PHY_READ, MRV88E111N_REG_PAGE_2,
                  MRV88E111M_CONTROL_REG, &mrvl_p->regs.mac_ctrl);
    if (rc != PASSED) {
        sprintf(err_buf, "mvl_ge_set_loopback() MAC control read failed. "
                 "rc = %#x", rc);
        return (FAILED);
    /* Get the MAC Specific Control 1 register */
           MRV88E111M_SPECIFIC_CONTROL1_REG, &mrvl_p->regs.mac_sp_ctl1);
    if (rc != PASSED) {
        sprintf(err_buf, "mvl_ge_set_loopback() MAC specific control 1 "
                 "read failed. rc = %#x", rc);
        return (FAILED);
    /* Get the Packet Generation register */
    rc = mvl_ge_rd_wr_reg(dev, PHY_READ, MRV88E111N_REG_PAGE_6,
                  MRV88E111N_PACKET_GEN_REG, &mrvl_p->regs.pkt_gen);
    if (rc != PASSED) {
        sprintf(err_buf, "mvl_ge_set_loopback() Pkt Gen reg read failed. "
                 "rc = %#x", rc);
        return (FAILED);
    /* Always enable packet CRC checking */
    mrvl_p->regs.pkt_gen |= PHY_PKT_CRC_EN;
    /* Make sure the Stub bit is cleared from last SFP or external
     * loopback. Without the clearing, link won't come up sometimes.
    reg_d = mrvl_p->regs.pkt_gen & (~PHY_PKT_STUB_EN);
    rc = mvl_ge_rd_wr_reg(dev, PHY_WRITE, MRV88E111N_REG_PAGE_6,
                  MRV88E111N_PACKET_GEN_REG, &reg_d);
    if (rc != PASSED) {
        sprintf(err_buf, "%s() Stub clearing write failed. rc = %#x",
                 __FUNCTION__, rc);
        return (FAILED);
    break;
    case LPBKOP_SET:
    /* Setup MAC of the PHY side first */
    mac_mode = 0;
    /* Section 2.4 of 1114 data sheet (2/27/2007) -
     * Before performing any other operations the 88E114 device requires
     * the following register initialization with sequences after power up,
     * or the following at hardware reset:
     * 1. Register 22 = 0x0002
    `* 2. Register 16_2.9:7 = 0x5.
     * 3. Register 22 = 0x8000.
     * 4. Register 0.15 = 0x1.
     * Step 1 is already done. Make sure step 2 is handled here. Step 4
     * will be done later.
     /* Marvell "recommends to force the mode to copper only mode for any
      * loopback test (internal or external stub loopback)." Refer to
      * email dated 9/29/2008 4:30 PM
     if (lpbk_mode == LOOPBACK_SFP) {
        /* SFP Encoding type of 8B10B and SONET scrambled will use
         * Mode of 11 which is converted to MAC Specific Control
         * register 1's Mode Select bits of 011 (Auto Copper/1000Base-X)
         * 4B5B will use mode of 00 - 000 (100Base-FX). Instead of
         * calling the SFP I2C to get the mode, we are using
         * the speed passed to the common device driver. 100M for
         * 4B5B. 1G for others.
        switch (speed) {
        case ETH_MODE_FE100:
        if (callout_p->sfp_setup) {
            /* GLC-GE-100FX uses SGMII */
            mac_mode = MAC_SP_CTL1_SGM_MODE;
        } else {
            mac_mode = MAC_SP_CTL1_FX_MODE;
        break;
        case ETH_MODE_GE:
        mac_mode = MAC_SP_CTL1_A_X_MODE;
        break;
        default:
        sprintf(err_buf, "mvl_ge_set_loopback() invalid speed %#x "
                 "for SFP loopback setup", speed);
        return (FAILED);
        break;
    } else {
        mac_mode = MAC_SP_CTL1_CU_MODE;
    } /* endof if lpbk_mode type */
    reg_d = mrvl_p->regs.mac_sp_ctl1 & (~MAC_SP_CTL1_MODE_MASK);
    reg_d |= mac_mode; /* */
    rc = mvl_ge_rd_wr_reg(dev, PHY_WRITE, MRV88E111N_REG_PAGE_2,
                  MRV88E111M_SPECIFIC_CONTROL1_REG, &reg_d);;
    if (rc != PASSED) {
        sprintf(err_buf, "mvl_ge_set_loopback() MAC specific control 1"
                 " register write failed. rc = %#x", rc);
        return (FAILED);
    } /* endof if rc */
    /* MAC does not have duplex bit. Set the speed in MAC */
    /* Turn off Auto-Neg per 88E1114 Rev C2 Release notes, page 5 */
    reg_d = mrvl_p->regs.mac_ctrl & ~(PHY_CTRL_MASK | PHY_CTRL_AUTO_NEG |
                      PHY_CTRL_PWR_DWN);
    if (auto_neg == TRUE) {
        reg_d |= (PHY_CTRL_RESET | PHY_CTRL_AUTO_NEG);
    } else {
        reg_d |= PHY_CTRL_RESET;    /* Reset to keep new config */
                  MRV88E111M_CONTROL_REG, &reg_d);
    if (rc != PASSED) {
        sprintf(err_buf, "mvl_ge_set_loopback() write %#x to MAC control "
                 "failed. rc = %#x", reg_d, rc);
        return (FAILED);
    if (poll_sw_reset(dev) == FAILED) {
        sprintf(err_buf, "mvl_ge_set_loopback() Unable to reset after "
                 "disabling MAC auto neg");
        return (FAILED);
    switch(speed) {
    case ETH_MODE_FE10:
        reg_d |= PHY_CTRL_10;
        break;
        reg_d |= PHY_CTRL_100;
        break;
    case ETH_MODE_GE:
        reg_d |= PHY_CTRL_1000;
        break;
        printf("writing %#x to offset %#x\n", reg_d, MRV88E111M_CONTROL_REG);
    if (rc != PASSED) {
        return (FAILED);
                 "setting the MAC speed");
        return (FAILED);
    break;
    case LPBKOP_RESTORE:
#ifdef PHY_STAT_MONITOR
    /* Print the CRC counter */
                  MRV88E111N_CRC_CHKR_REG, &reg_d);
    if (rc != PASSED) {
        sprintf(err_buf, "mvl_ge_set_loopback() restore. CRC counter read "
                 "failed. rc = %#x", rc);
        return (FAILED);
    prpass("CRC counter = %#x before restores", reg_d);
#endif /* PHY_STAT_MONITOR */
    break;
    } /* endof switch op */
    /* CSCsv40919 requires to use Class A in the Copper */
              MRV88E111N_SPECIFIC_CONTROL2_REG, &reg_d);
    if (rc != PASSED) {
    sprintf(err_buf, "mvl_ge_set_loopback() Copper Specific Control 2 "
             "register read failed. rc = %#x", rc);
    return (FAILED);
    reg_d &= (~PG0_SP_CTL2_TX_MASK);    /* clear the mask */
    reg_d |= PG0_SP_CTL2_TX_A;      /* set Class A */
    if (rc != PASSED) {
             "register write failed. rc = %#x", rc);
    return (FAILED);
    /******* From this point on, the page is the PHY page, and don't modify
     ******* other page registers.
     * If needed, use phy_page setup here.
    /* Setup the page table */
        /* SFP loopback mode */
        phy_page = MRV88E111N_REG_PAGE_1;
    } else {
        /* RJ45 loopback mode */
        phy_page = MRV88E111N_REG_PAGE_0;
    break;
    break;
    default:
    /* Unknown type */
    assert(!"mvl_ge_set_loopback");
    break;
    reg_d = phy_page;
    if (rc != PASSED) {
    sprintf(err_buf, "mvl_ge_set_loopback() Set Page failed rc = %#x", rc);
    return (FAILED);
    switch(op) {
    case LPBKOP_SAVE:
    /* Save PHY Specific Control register 1 */
    smi_if.buf = &mrvl_p->regs.sp_ctl1;
    smi_if.offset = MRV88E111N_SPECIFIC_CONTROL1_REG;
    if (rc != PASSED) {
        sprintf(err_buf, "mvl_ge_set_loopback() read special ctrl rc = %#x",
                    rc);
        return (FAILED);
    /* Save Control register */
    smi_if.buf = &mrvl_p->regs.control;
    smi_if.offset = MRV88E111N_CONTROL_REG;
    if (rc != PASSED) {
        sprintf(err_buf, "mvl_ge_set_loopback() read Control reg rc = %#x",
                    rc);
        return (FAILED);
    return (rc);
    break;
    /* Restore PHY Specific Control register 1 */
    if (rc != PASSED) {
        sprintf(err_buf, "mvl_ge_set_loopback() write special ctl rc = %#x",
                    rc);
        return (FAILED);
    /* Restore Control register */
    reg_d = mrvl_p->regs.control | PHY_CTRL_RESET;
    if (rc != PASSED) {
        sprintf(err_buf, "mvl_ge_set_loopback() write control reg rc = %#x",
                    rc);
        return (FAILED);
                 "restoring PHY control register");
        return (FAILED);
    }   /* endof if poll */
    /* Restore the MAC control register */
    reg_d = mrvl_p->regs.mac_ctrl | PHY_CTRL_RESET;
    if (rc != PASSED) {
        sprintf(err_buf, "mvl_ge_set_loopback() MAC control write failed. "
                 "rc = %#x", rc);
        return (FAILED);
    if (rc != PASSED) {
                 " write failed. rc = %#x", rc);
        return (FAILED);
    /* Restore the Packet Generation register */
    if (rc != PASSED) {
        sprintf(err_buf, "mvl_ge_set_loopback() Pkt Gen reg write failed. "
                 "rc = %#x", rc);
        return (FAILED);
    if (rc != PASSED) {
        sprintf(err_buf, "mvl_ge_set_loopback() Page reg write rc = %#x",
                    rc);
    return (rc);
    break;
    case LPBKOP_SET:
    /* Configure the PHY side */
    /******* Note that the page is set to the media at this point ****/
    smi_if.buf = &reg_d;    /* Setup the write buffer */
    if (lpbk_mode == LOOPBACK_PHY) {
        /* Turn off auto negotiate and set the soft reset */
        reg_d = mrvl_p->regs.control & (~(PHY_CTRL_AUTO_NEG |
                         PHY_CTRL_MASK | PHY_CTRL_PWR_DWN));
        reg_d |= (PHY_CTRL_RESET | PHY_CTRL_DUPLEX);
        /* Set the speed */
        switch(speed) {
        case ETH_MODE_FE10:
        break;
        break;
        case ETH_MODE_GE:
        break;
        if (rc != PASSED) {
        sprintf(err_buf, "mvl_ge_set_loopback() Reset (%#x) "
        return (FAILED);
        } /* endof if rc */
                 "disabling auto negtiate");
        return (FAILED);
        reg_d &= (~PHY_CTRL_RESET);
        reg_d |= PHY_CTRL_LOOPBACK;
        if (rc == PASSED) {
        /* Reset the Packet CRC counter */
        rc = clear_pkt_cnt(dev);
        if (rc != PASSED) {
            return (FAILED);
        /* Read status 2 and check if any bits set */
        rc = mvl_ge_rd_wr_reg(dev, PHY_READ, phy_page,
                      MRV88E111N_SPECIFIC_STATUS2_REG, &reg_d);
        if (rc != PASSED) {
            sprintf(err_buf, "%s() Stat 2 read rc = %#x",
                     __FUNCTION__, rc);
            return (FAILED);
        prpass("Status 2 after link up = %#x", reg_d);
                      MRV88E111N_REC_ERROR_COUNTER_REG, &reg_d);
        if (rc != PASSED) {
            sprintf(err_buf, "%s() Rx Count read rc = %#x",
                     __FUNCTION__, rc);
            return (FAILED);
        prpass("Receive Error Counter = %#x", reg_d);
        if (rc != PASSED) {
            sprintf(err_buf, "%s() CRC Counter read rc = %#x",
                     __FUNCTION__, rc);
            return (FAILED);
        prpass("CRC counter = %#x after link up", reg_d);
        return (PASSED);
        } else {
        sprintf(err_buf, "mvl_ge_set_loopback() write loopback to "
                 " control register failed. rc = %#x", rc);
        return (FAILED);
    } else {    /* External loopback */
        /* Copper needs to disable Auto MDI and energy detect */
        reg_d = mrvl_p->regs.sp_ctl1 & ~(PHY_SP_CTL1_ENERGY_DET +
                         PHY_SP_CTL1_MDIX_MASK);
        /* For 88E1112. Check for SFP loopback */
        /* Set the SIGDET Polarity. From Marvell - */
        /* "On the SFP/Fiber transceiver, there is a pin called LOS
         * or SD. Typically SFP use LOS (loss of signal) while Fiber
         * transceiver uses SD (signal detect). They have opposite
         * polarity when active. ..."
         reg_d |= PHY_SP_CTL1_SIGLOS;
        } /* endof if lpbk_mode */
        if (rc != PASSED) {
        sprintf(err_buf, "mvl_ge_set_loopback() write %#x to special "
                 "control 1 reg. failed. rc = %#x",
                  reg_d, rc);
        return (FAILED);
        } /* endof if rc */
        /* Setup PHY speed, and loopback mode */
        reg_d = mrvl_p->regs.control & ~(PHY_CTRL_LOOPBACK | PHY_CTRL_MASK |
                      PHY_CTRL_AUTO_NEG | PHY_CTRL_PWR_DWN);
        /* Set Full duplex, and also reset to keep new config. */
        switch(speed) {
        case ETH_MODE_FE10:
        break;
        break;
        case ETH_MODE_GE:
        break;
        if ((lpbk_mode == LOOPBACK_SFP) && callout_p->sfp_setup){
        /* GE-100FX has to use AutoNegotiation */
        /* Needs to setup the SFP - GLC-FE-100FX */
        if ((*callout_p->sfp_setup)(smi_if.smi_dev) != PASSED) {
            sprintf(err_buf, "%s() Unable to setup SFP for operation",
                      __FUNCTION__);
            return (FAILED);
        mdelay(LINK_DELAY);
        reg_d |= PHY_CTRL_AUTO_NEG;
            printf("writing %#x ( %#x ) to offset %#x\n", *smi_if.buf,
                    reg_d, smi_if.offset);
        if (rc != PASSED) {
        sprintf(err_buf, "mvl_ge_set_loopback() write %#x to control "
                 "register failed. rc = %#x", reg_d, rc);
        return (FAILED);
        } /* endof if rc */
                 "setting PHY control");
        return (FAILED);
            if ((*callout_p->rd)(&smi_if) != PASSED) {
                printf("cannot read it back\n");
                return (FAILED);
            printf(" control = %#x ( %#x )\n", *smi_if.buf, reg_d);
    /* Section 2.3.4.1 of 1112 data sheet (2/21/2007) -
     * For 10BASE-T and 100BASE-TX modes, the loopback test requires no
     * register writes. For 1000BASE-T mode, register 16_6.5 must be set
     * to 1 to enable the external loopback. ...
    if (((lpbk_mode == LOOPBACK_EXT) || (lpbk_mode == LOOPBACK_SFP)) &&
         (speed == ETH_MODE_GE)) {
        /* External loopback with 1000BASE-T */
        /* Instead of reading the register then write, use the one in the
         * saved during the LPBKOP_SAVE step.
        reg_d = mrvl_p->regs.pkt_gen | PHY_PKT_STUB_EN;
    } else {
    /* Set the stub first */
    if (rc != PASSED) {
        sprintf(err_buf, "%s() stub setup failed. rc = %#x",
                 __FUNCTION__, rc);
        return (FAILED);
    if (rc != PASSED) {
        return (FAILED);
        /* Enable the SFP */
        (*callout_p->sfp_op)(smi_if.smi_dev, ENABLE);
    /* Needs to reset the page */
    /* check linkup */
    smi_if.offset = MRV88E111N_SPECIFIC_STATUS1_REG;
    for (i = 0; i < (LINK_MAX_TIME * 2); i++) {
            /* GLC-GE-100FX SFP uses SGMII mode. With SGMII mode, different
             * status register nad bit are checked for the link up
                                  MRV88E111N_LINK_PART_AV_REG, &reg_d);
            link_mask = LPA_SGMII_LINK;
        } else {
                                  MRV88E111N_SPECIFIC_STATUS1_REG, &reg_d);
            link_mask = PHY_SP_STA1_LINKUP;
        if (rc != PASSED) {
            sprintf(err_buf, "mvl_ge_set_loopback() linkup read rc = %#x", rc);
            return (FAILED);
        if (reg_d & link_mask) {
            /* Link up */
            if (rc != PASSED) {
                sprintf(err_buf, "mvl_ge_set_loopback() Stat 2 read rc = "
                                 "%#x", rc);
                return (FAILED);
            if (reg_d & PG0_SP_ST2_ERR_MSK) {
                printf("\nStatus 2 after link up = %#x\n", reg_d);
            if (rc != PASSED) {
                sprintf(err_buf, "mvl_ge_set_loopback() Rx Count read rc = "
                                 "%#x", rc);
                return (FAILED);
            if (reg_d) {
                printf("\nReceive Error Counter = %#x\n", reg_d);
            if (rc != PASSED) {
                        __FUNCTION__, rc);
                return (FAILED);
                printf("\n Link up after %d ms\n", i);
            return (PASSED);
        mdelay(LINK_DELAY);
        printf("special status 1 = %#x ( %#x )\n", *smi_if.buf, reg_d);
    sprintf(err_buf, "mvl_ge_set_loopback() %s loopback linkup timedout",
             (lpbk_mode == LOOPBACK_SFP) ? "SFP" : "External");
    return (FAILED);
    } /* endof if op */
    /* should not reach this point. If it does, return failed */
    return (FAILED);
* Function:    mvl_ge_rd_wr_reg
* This function: reads or writes a register of specified page.
*      op - read or write.
*      page - Page number.
*      offset - register offset.
*      data - Points to data of read/write
static int
mvl_ge_rd_wr_reg(dev_object_t *dev, uint op, smi_t page, uchar offset,
        smi_t *data)
    uint32_t rc;
    smi_if_t smi_if;
    smi_t reg_d;
    reg_d = page;
    if (rc != PASSED) {
    sprintf(err_buf, "mvl_ge_rd_wr_reg() set page %#x failed. rc = %#x",
                page, rc);
    DEV_ERROR_REPORT(dev, err_buf, MRVL_GE_PAGE);
    return (FAILED);
    smi_if.buf = data;
    smi_if.offset = offset;
    if (op == PHY_READ) {
    } else {
    if (rc != PASSED) {
    sprintf(err_buf, "mvl_ge_rd_wr_reg() op = %#x reg @ %#x failed. "
             " rc = %#x", op, offset, rc);
    return (rc);
* Function:    poll_sw_reset
* This function: polls the Soft Reset bit in the control register.
* Assumption:  The caller sets up the page of the Control register to be
*      polled.
static int
    uint32_t rc;
    int i;
    smi_if_t smi_if;
    smi_t reg_d;
    for (i = 0; i < PHY_RESET_DELAY; i++) {
    if (rc != PASSED) {
        sprintf(err_buf, "poll_sw_reset() failed. rc = %#x", rc);
        return (FAILED);
    if ((reg_d & PHY_CTRL_RESET) == 0 ) {
        /* Out of reset */
        /* Refer to 88E1114 Release Notes, section 4.8 */
        mdelay(PHY_AUTO_NEG_DELAY);
        return (PASSED);
    mdelay(LINK_DELAY); /* Poll every millisecond */
    return (FAILED); /* Timedout */
* Function:    clear_pkt_cnt
* This function: clears the Packet CRC counter register.
* Assumption:  The caller is required to have the device created.
static uint32_t
    uint32_t rc;
    smi_t reg_d;
    /* Read the register */
    if (rc != PASSED) {
    sprintf(err_buf, "%s Unable to read Packet CRC register. rc = %#x",
             __FUNCTION__, rc);
    return (FAILED);
    /* Setup the packet generation register, with CRC counter cleared */
    reg_d &= (~PHY_PKT_CRC_EN);
    if (rc != PASSED) {
    sprintf(err_buf, "%s clear CRC checker failed. rc = %#x",
             __FUNCTION__, rc);
    return (FAILED);
    /* Re-enable the counter */
    reg_d |= PHY_PKT_CRC_EN;
    if (rc != PASSED) {
    sprintf(err_buf, "%s CRC checker enable failed. rc = %#x",
             __FUNCTION__, rc);
    return (rc);
/******** History ********
* $Log: not supported by cvs2svn $
* Revision 1.1.1.1  2012/04/25 05:28:25  krreddy
* -----krreddy 04/25/2012------
* Initial code import for RSP2 diags based on rudy_diag_V0.4.8.tar.gz code base
* received from Foxconn
* Revision 1.1.2.3  2011/01/22 01:13:46  jackie
* testpass is no longer needed in our prpass function
* Revision 1.1.2.2  2011-01-21 02:17:17  jackie
* use VERBOSE flag to replace PHY_DEBUG
* Revision 1.1.2.1  2010-09-23 12:26:33  kody
* Clean up the code
* Revision 1.1  2010/09/02 07:38:33  kody
* Add for GE PHY test.
* $Endlog$
#ifndef __DEV_MRVL_GE_H__
#define __DEV_MRVL_GE_H__
#include "dev_object.h"
#include "smi_api.h"
#include "common_utils.h"
typedef struct mrvl_ge_callout_fvt_ {
    unsigned int (*open)(smi_if_t *smi_if_p);
    unsigned int (*close)(smi_if_t *smi_if_p);
    unsigned int (*rd)(smi_if_t *smi_if_p);
    unsigned int (*wr)(smi_if_t *smi_if_p);
    int (*dev_reset)(int);
    void (*sfp_op)(int, int);
    int (*sfp_setup)(int);
} mrvl_ge_callout_fvt_t;
typedef struct mrvl_ge_callin_fvt_ {
    int  (*register_test)(dev_object_t *);
    int  (*set_loopback)(dev_object_t *, unsigned int, unsigned int, unsigned int, unsigned int);
    int  (*alter_reg)(dev_object_t *);
    int  (*set_synce)(dev_object_t *);
    int  (*set_test_mode)(dev_object_t *);
} mrvl_ge_callin_fvt_t;
* dev_error_report message codes
typedef enum {
    MRVL_GE_DEV_STATE = 0,
    MRVL_GE_ATTACH,
    MRVL_GE_DETACH,
    MRVL_GE_INIT,
    MRVL_GE_SHOW,
    MRVL_GE_DESTROY,
    MRVL_GE_REG_TEST,
    MRVL_GE_RESET,
    MRVL_GE_READ,
    MRVL_GE_WRITE,
    MRVL_GE_ALTER,
    MRVL_GE_LPBK,
    MRVL_GE_PAGE,
    MRVL_GE_TEST_MODE,
}idt6v4900n_report_code_t;
* Marvell GE PHYs have multiple pages. This struct defines the registers
* and the page associate with them.
typedef struct dev_mrvl_reg_info_t_ {
    smi_t   page;       /* page number */
    reg_info_t  *reg_p;     /* Registers table */
} dev_mrvl_reg_info_t;
* PHY registers changed for loopback.
typedef struct dev_mrvl_lpbk_regs_t_ {
    smi_t page;         /* Page number */
    smi_t sp_ctl1;      /* Specific Control Register 1 */
    smi_t control;      /* Control Register */
    smi_t mac_ctrl;     /* MAC Control Register */
    smi_t mac_sp_ctl1;      /* MAC Specific Control Register 1 */
    smi_t pkt_gen;      /* Packet Generation */
} dev_mrvl_lpbk_regs_t;
* Define the Marvell GE device object structure.
typedef struct dev_mrvl_ge_object_t_ {
    dev_object_t    base;
    mrvl_ge_callout_fvt_t *callout_fvt;
    mrvl_ge_callin_fvt_t  *callin_fvt;
    smi_if_t        *smi_p;     /* SMI API interface struct */
    dev_mrvl_reg_info_t *reg_info_p;    /* Registers table */
    dev_mrvl_lpbk_regs_t regs;      /* Saved registers for loopback */
    unsigned char       type;       /* PHY device type */
}dev_mrvl_ge_object_t;
/* GE type */
typedef enum {
    MRVL_GE_PHY_1112 = 0,   /* GE PHY with Copper and Optic */
    MRVL_GE_PHY_1114,       /* GE PHY with Copper only */
    MRVL_GE_PHY_INVALID,    /* Invalid GE PHY */
} dev_mrvl_ge_type_t;
typedef enum {
    ETH_MODE_FE10 = 0,
    ETH_MODE_FE100,
    ETH_MODE_GE,
    ETH_MODE_INVALID,
} dev_mrvl_ge_mode_t;
typedef enum {
    LOOPBACK_NONE = 0,
    LOOPBACK_MAC,       /* internal loopback at CPU */
    LOOPBACK_PHY,       /* internal loopback at marvell ge phy */
    LOOPBACK_EXT,       /* RJ45 external loopback */
    LOOPBACK_SFP,       /* SFP external loopback */
    LOOPBACK_INVALID,       /* Invalid loopback */
} dev_mrvl_ge_loopback_t;
typedef enum {
    LPBKOP_SAVE = 0,
    LPBKOP_RESTORE,
    LPBKOP_SET,
} dev_mrvl_ge_loopback_op_t;
typedef enum {
    PHY_READ = 0,
    PHY_WRITE,
} dev_mrvl_ge_smi_op_t;
* General Defines
#define SW_LOG_BUF_SIZE                         384
#define INCREMENT_COUNT                         1
#define DECREMENT_COUNT                         -1
#define CONSTANT_COUNT                          0
#define ERR_BUF_SIZE                            80
#define MAX_SMI_REGS                            0x20
#define SMI_SHOW_MASK                           0xF
/* 100 milliseconds delay */
#define PHY_RESET_DELAY                         100
/* Refer to 88E1114 Rev C2 Release Notes. Section 4.8 -
* If Auto=-Neg is turned off and the forced speed of 10 Mbps or 100 Mbps is
* programmed by writing to Register 0, then there will be a 637 ms delay
* before the PHY switches to the programmed speed. There is no delay if
* switching to gigabit speed.
* ... (Wait at least 700ms to give a little margin on top of the 637ms).
* Diag will have the PHY_AUTO_NEG_DELAY regardless of the speed.
/* 700 milliseconds delay. But we extend it to 1 second */
#define PHY_AUTO_NEG_DELAY                      1000
/* SFP MSA recommends 300ms */
#define SFP_ENABLE_WAIT                         500
/* Time to setup GE 100 FX */
#define GE_100FX_SETUP_TIME                     10
/* Refer to "Time to link up and link down for 10/100/1000 PHYs" White Paper
* from Marvell (December 20, 2004). -
* The quick answer to the question is that there is no theoretical upper
* bound, but typically link should come up within 3 seconds.
/* Link up in 3 seconds. */
#define LINK_MAX_TIME                           3000
/* 1 millisecond delay */
#define LINK_DELAY                              1
/* Shared PHY (88E series) Registers Offsets */
#define MRV88E111N_PHYID_1_REG                  2
#define MRV88E111N_PHYID_2_REG                  3
#define MRV88E111N_PAGE_ADDRESS_REG             22
#define MRV88E111N_FACTORY_TEST_MODES0          29
#define MRV88E111N_FACTORY_TEST_MODES1          30
#define MRV88E111N_FACTORY_TEST_MODES2          31
/* Page 0 Register Offsets - Copper */
#define MRV88E111N_CONTROL_REG                  0
#define MRV88E111N_STATUS_REG                   1
#define MRV88E111N_AUTONEG_ADVR_REG             4
#define MRV88E111N_LINK_PART_AV_REG             5
#define MRV88E111N_AUTONEG_EXPANSION_REG        6
#define MRV88E111N_NEXT_PAGE_REG                7
#define MRV88E111N_LP_NEXT_PAGE_REG             8
#define MRV88E111N_1000B_CNTL_REG               9
#define MRV88E111N_1000B_STATUS_REG             10
#define MRV88E111N_EXTENDED_STATUS_REG          15
#define MRV88E111N_SPECIFIC_CONTROL1_REG        16
#define MRV88E111N_SPECIFIC_STATUS1_REG         17
#define MRV88E111N_INT_ENABLE_REG               18
#define MRV88E111N_SPECIFIC_STATUS2_REG         19
#define MRV88E111N_REC_ERROR_COUNTER_REG        21
#define MRV88E111N_SPECIFIC_CONTROL2_REG        26
/* Page 1 Register Offsets - Fiber */
#define MRV88E111F_CONTROL_REG                  0
#define MRV88E111F_STATUS_REG                   1
#define MRV88E111F_AUTONEG_ADVR_REG             4
#define MRV88E111F_LINK_PART_AV_REG             5
#define MRV88E111F_AUTONEG_EXPANSION_REG        6
#define MRV88E111F_NEXT_PAGE_REG                7
#define MRV88E111F_LP_NEXT_PAGE_REG             8
#define MRV88E111F_EXTENDED_STATUS_REG          15
#define MRV88E111F_SPECIFIC_CONTROL1_REG        16
#define MRV88E111F_SPECIFIC_STATUS1_REG         17
#define MRV88E111F_INT_ENABLE_REG               18
#define MRV88E111F_SPECIFIC_STATUS2_REG         19
#define MRV88E111F_REC_ERROR_COUNTER_REG        21
#define MRV88E111F_SPECIFIC_CONTROL2_REG        26
/* Page 2 Register Offsets - MAC */
#define MRV88E111M_CONTROL_REG                  0
#define MRV88E111M_SPECIFIC_CONTROL1_REG        16
#define MRV88E111M_SPECIFIC_STATUS1_REG         17
#define MRV88E111M_INT_ENABLE_REG               18
#define MRV88E111M_SPECIFIC_STATUS2_REG         19
#define MRV88E111M_SPECIFIC_CONTROL2_REG        26
/* Page 3 Register Offsets - LOS, INIT, STATUS[1:0] */
#define MRV88E111L_FUNC_CONTROL_REG             16
#define MRV88E111L_POL_CONTROL_REG              17
#define MRV88E111L_TMR_CONTROL_REG              18
/* Page 4 Register Offsets - Non-Volatile Memory */
#define MRV88E111NV_ADDRESS                     16
#define MRV88E111NV_READ_DATA_STATUS            17
#define MRV88E111NV_WRITE_DATA_CONTROL          18
#define MRV88E111NV_RAM_WRITE_DATA_CONTROL      19
#define MRV88E111NV_RAM_ADDRESS                 20
/* Page 5 Register Offsets - VCT */
#define MRV88E111N_VCT_STATUS_MDI0_REG          16
#define MRV88E111N_VCT_STATUS_MDI1_REG          17
#define MRV88E111N_VCT_STATUS_MDI2_REG          18
#define MRV88E111N_VCT_STATUS_MDI3_REG          19
#define MRV88E111N_VCT_PAIR_SKEW_REG            20
#define MRV88E111N_VCT_PAIR_SWP_POL_REG         21
#define MRV88E111N_VCT_DSP_DISTANCE             26
/* Page 6 Register Offsets */
#define MRV88E111N_PACKET_GEN_REG               16
#define MRV88E111N_CRC_CHKR_REG                 17
#define MRV88E111N_CONTROL_PHY_RESET_VALUE      0x8000
#define MRV88E111N_CONTROL_PHY_RESET            0x8000
#define MRV88E111N_CONTROL_LOOPBACK             0x4000
#define MRV88E111N_CONTROL_FORCE_10_L           0x0000
#define MRV88E111N_CONTROL_FORCE_100_L          0x2000
#define MRV88E111N_CONTROL_FORCE_1000_L         0x0040
#define MRV88E111N_CONTROL_AUTONEG_ENABLE       0x1000
#define MRV88E111N_CONTROL_POWER_DOWN           0x0800
#define MRV88E111N_CONTROL_ISOLATE              0x0400
#define MRV88E111N_CONTROL_RESTART_AUTONEG      0x0200
#define MRV88E111N_CONTROL_FULL_DUPLEX          0x0100
#define MRV88E111N_CONTROL_COLLISION_TEST       0x0080
#define MRV88E111N_CONTROL_FORCE_1000_M         0x0040
#define MRV88E111N_CONTROL_FORCE_10_M           0x0000
#define MRV88E111N_CONTROL_SPEED_MASK           0x2040
#define MRV88E111N_PHY_ID_1_VALUE               0x0141
#define MRV88E111N_STATUS_AUTONEG_CHK           0x0008
#define MRV88E111N_STATUS_LINK_UP               0x0004
#define MRV88E111N_STATUS1_SPEED                0xC000
#define MRV88E111N_STATUS1_SPEED_1000           0x8000
#define MRV88E111N_STATUS1_SPEED_100            0x4000
#define MRV88E111N_STATUS1_SPEED_10             0x0000
#define MRV88E111N_STATUS1_LINK                 0x0400
#define MRV88E111N_RESET_TIMEOUT                15  /* TRESET 10 ms min */
#define MRV88E111N_SPEED_1000BT                 1000
#define MRV88E111N_SPEED_100BT                  100
#define MRV88E111N_SPEED_10BT                   10
#define MRV88E111N_REG_PAGE_0                   0
#define MRV88E111N_REG_PAGE_1                   1
#define MRV88E111N_REG_PAGE_2                   2
#define MRV88E111N_REG_PAGE_3                   3
#define MRV88E111N_REG_PAGE_4                   4
#define MRV88E111N_REG_PAGE_5                   5
#define MRV88E111N_REG_PAGE_6                   6
/* Switch (98DX series) Registers Offsets */
/* SMI Read-Write Status Register */
#define MRV98DX_STATUS                          0x1F
/* SMI Write Address MSBs Register */
#define MRV98DX_WR_ADDR_MSB                     0x00
/* SMI Write Address LSBs Register */
#define MRV98DX_WR_ADDR_LSB                     0x01
/* SMI Write Data MSBs Register */
#define MRV98DX_WR_DATA_MSB                     0x02
/* SMI Write Data LSBs Register */
#define MRV98DX_WR_DATA_LSB                     0x03
/* SMI Read Address MSBs Register */
#define MRV98DX_RD_ADDR_MSB                     0x04
/* SMI Read Address LSBs Register */
#define MRV98DX_RD_ADDR_LSB                     0x05
/* SMI Read Data MSBs Register */
#define MRV98DX_RD_DATA_MSB                     0x06
/* SMI Read Data LSBs Register */
#define MRV98DX_RD_DATA_LSB                     0x07
/* Bits defines for SMI Read-Write Status Register */
/* SMI Write Done */
#define MRV98DX_SMI_WR_DONE                     0x0002
/* SMI Read Ready */
#define MRV98DX_SMI_RD_RDY                      0x0001
/* Control Register (offset 0) Bits defines */
#define PHY_CTRL_RESET                          MRV88E111N_CONTROL_PHY_RESET
#define PHY_CTRL_LOOPBACK                       MRV88E111N_CONTROL_LOOPBACK
#define PHY_CTRL_MASK                           MRV88E111N_CONTROL_SPEED_MASK
#define PHY_CTRL_1000                           MRV88E111N_CONTROL_FORCE_1000_L
#define PHY_CTRL_100                            MRV88E111N_CONTROL_FORCE_100_L
#define PHY_CTRL_10                             MRV88E111N_CONTROL_FORCE_10_L
#define PHY_CTRL_DUPLEX                         MRV88E111N_CONTROL_FULL_DUPLEX
#define PHY_CTRL_AUTO_NEG                       MRV88E111N_CONTROL_AUTONEG_ENABLE
#define PHY_CTRL_PWR_DWN                        MRV88E111N_CONTROL_POWER_DOWN
/* Link Partner Ability Register (offset 5 - Page 1) Bits defines */
/* SGMII Link up */
#define LPA_SGMII_LINK                          0x8000
/* 1000BASE-T Control Register (offset 9) Bits defines */
/* Test Modes */
#define PHY_GT_CTL_TEST_MASK                    0xE000
/* Normal mode */
#define PHY_GT_CTL_NORMAL                       0x0000
/* Test mode 1 - Waveform test */
#define PHY_GT_CTL_WV_TEST                      0x2000
/* Test mode 2 - Jitter (Master) */
#define PHY_GT_CTL_JT_MS                        0x4000
/* Test mode 3 - Jitter (Slave) */
#define PHY_GT_CTL_JT_SL                        0x6000
/* Test mode 4 - Distortion test */
#define PHY_GT_CTL_DS_TEST                      0x8000
#define PHY_GT_CTL_TEST_MAX                     PHY_GT_CTL_DS_TEST
/* Test mode bits shift counts */
#define PHY_GT_CTL_TEST_SHIFT                   13
/* Specific Control 1 Register (offset 16) Bits defines */
/* SIGDET polarity for SFP */
#define PHY_SP_CTL1_SIGLOS                      0x0200
/* Energy detect mask */
#define PHY_SP_CTL1_ENERGY_DET                  0x0180
/* MDI Crossover mask */
#define PHY_SP_CTL1_MDIX_MASK                   0x0060
/* Mode select mask */
#define MAC_SP_CTL1_MODE_MASK                   0x0380
/* 100Base-FX */
#define MAC_SP_CTL1_FX_MODE                     0x0000
/* Copper GBIC */
#define MAC_SP_CTL1_GBIC_MODE                   0x0080
/* Auto Copper/SGMII media interface */
#define MAC_SP_CTL1_A_SGM_MODE                  0x0100
/* Auto Copper/1000Base-X */
#define MAC_SP_CTL1_A_X_MODE                    0x0180
/* Copper only */
#define MAC_SP_CTL1_CU_MODE                     0x0280
/* SGMII media interface only */
#define MAC_SP_CTL1_SGM_MODE                    0x0300
/* 1000Base-X only */
#define MAC_SP_CTL1_X_MODE                      0x0380
/* Specific Status 1 Register (offset 17) Bits defines */
#define PHY_SP_STA1_LINKUP                      MRV88E111N_STATUS1_LINK
/* Packet Generation Register (offset 16 - Page 6) Bits defines */
/* Enable stub test */
#define PHY_PKT_STUB_EN                         0x0020
/* Enable CRC checker */
#define PHY_PKT_CRC_EN                          0x0010
/* Copper Specific Status Register 2 (offset 19 - Page 0) Bits defines */
/* Copper Auto-Negotiation Error */
#define PG0_SP_ST2_AN_ERR                       0x8000
/* Copper Speed Changed */
#define PG0_SP_ST2_SP_CHG                       0x4000
/* Copper Duplex Changed */
#define PG0_SP_ST2_DPX_CHG                      0x2000
/* Copper Page Received */
#define PG0_SP_ST2_PG_RX                        0x1000
/* Copper Auto-Negotiation Completed */
#define PG0_SP_ST2_AN_CMP                       0x0800
/* Copper Link Status Changed */
#define PG0_SP_ST2_LNK_CHG                      0x0400
/* Copper Symbol Error */
#define PG0_SP_ST2_SYM_ERR                      0x0200
/* Copper False Carrier */
#define PG0_SP_ST2_FLS_CRR                      0x0100
/* MDI Crossover Changed */
#define PG0_SP_ST2_MDI_CHG                      0x0040
/* Downshift Interrupt */
#define PG0_SP_ST2_DNS_INT                      0x0020
/* Energy Detect Chagned */
#define PG0_SP_ST2_ED_CHG                       0x0010
/* DTE power detection status changed */
#define PG0_SP_ST2_DTE_CHG                      0x0004
/* Polarity Changed */
#define PG0_SP_ST2_POL_CHG                      0x0002
/* Jabber */
#define PG0_SP_ST2_JAB                          0x0001
#define PG0_SP_ST2_ERR_MSK                      (PG0_SP_ST2_AN_ERR | \
                                                 PG0_SP_ST2_SYM_ERR | \
                                                 PG0_SP_ST2_FLS_CRR | \
                                                 PG0_SP_ST2_JAB)
/* Copper Specific Control Register 2 (offset 26 - Page 0) Bits defines */
/* Transmitter type mask */
#define PG0_SP_CTL2_TX_MASK                     0x8000
/* Class A */
#define PG0_SP_CTL2_TX_A                        0x8000
/* Class B */
#define PG0_SP_CTL2_TX_B                        0x0000
/* MAC Specific Control Register 2 (offset 26 - Page 2) Bits defines */
/* SGMII MAC Interface Output Amplitude defines */
#define MAC_SP_CTL2_AMP_P5                      0x0000  /* 0.50V */
#define MAC_SP_CTL2_AMP_P6                      0x0001  /* 0.60V */
#define MAC_SP_CTL2_AMP_P7                      0x0002  /* 0.70V */
#define MAC_SP_CTL2_AMP_P8                      0x0003  /* 0.80V */
#define MAC_SP_CTL2_AMP_P9                      0x0004  /* 0.90V */
#define MAC_SP_CTL2_AMP_1                       0x0005  /* 1.00V */
#define MAC_SP_CTL2_AMP_1P1                     0x0006  /* 1.10V */
#define MAC_SP_CTL2_AMP_1P2                     0x0007  /* 1.20V */
/* Prototypes */
extern int mrvl_ge_dev_create (dev_object_t *dev,
                dev_error_report_t error_report_fn);
#endif /* __DEV_MRVL_GE_H__ */
yipingwang
Hello Rama Krishna Katta,
I am not sure how you define the type "reg_info_t", it seems that compiler doesn't treat the first string element as a constant. In addition the fourth element is a pointer and it is 64 bit on 64bit system, please also check whether it is corresponding with "reg_info_t" definition.
So I suggest you refine "reg_info_t" definition in your program.
Yiping
ramakrishnakatt
typedef struct reg_info_t_ext_ {
    unsigned int   size;
    int   (*rd_ptr) (unsigned long addr, int size, unsigned long *buf, void *param);
    int   (*wr_ptr) (unsigned long addr, int size, unsigned long data, void *param);
    void   *param;      /* Parameter passed to rd_ptr and wr_ptr */
} reg_info_t_ext;
typedef struct reg_info {
    char                        *name;
    unsigned int        offset;
    unsigned char       type;
    union {
    unsigned long       size;    /* if type is not REG_ACCESS */
    reg_info_t_ext              *ext;    /* if type is REG_ACCESS */
    } size;
    unsigned int        mask;
    unsigned int        reset_val;
} reg_info_t;
yipingwang
Hello Krishna Katta,
I verified part of your program with both 32 and 64bit Toolchain, this compilation error could be encountered  with both of them.
Actually the value of &reg_ext is a pointer, which  should be got during running, it is not a constant value, cannot be used to initialize the global variable reg_ext. So it is not reasonable to initialize global reg_info type variable as the above.
Yiping
ramakrishnakatt
I got the solution, you have to typecase to (ulong) instead of (uint) current one
