dpa_rx_error
dpa_rx_error
wangss
系统启动后,以太网网口收包错误,日志信息如下:
 107.313509] fsl_dpa soc:fsl,dpaa:ethernet@0 eth0: Err FD status = 0x00040000
[ 107.316456] fsl_dpa: dpaa_eth.c:271:_dpa_rx_error() fsl-dpa: non-zero error counters in fman statistics (sysfs)
[ 107.320588] fsl_dpa: dpaa_eth.c:277:_dpa_rx_error() ## _dpa_rx_error,277 fd->status = 0x00040000
[ 107.330676] fsl_dpa: dpaa_eth.c:277:_dpa_rx_error() ## _dpa_rx_error,277 fd->status = 0x00080000
[ 107.617825] fsl_dpa: dpaa_eth.c:277:_dpa_rx_error() ## _dpa_rx_error,277 fd->status = 0x00040000
[ 108.517028] net_ratelimit: 1 callbacks suppressed
[ 108.521757] fsl_dpa soc:fsl,dpaa:ethernet@0 eth0: Err FD status = 0x00040000
[ 108.528821] fsl_dpa: dpaa_eth.c:277:_dpa_rx_error() ## _dpa_rx_error,277 fd->status = 0x00040000
[ 108.802778] fsl_dpa soc:fsl,dpaa:ethernet@0 eth0: Err FD status = 0x00040000
[ 108.809854] fsl_dpa: dpaa_eth.c:277:_dpa_rx_error() ## _dpa_rx_error,277 fd->status = 0x00040000
[ 109.517864] fsl_dpa soc:fsl,dpaa:ethernet@0 eth0: Err FD status = 0x00040000
[ 109.524932] fsl_dpa: dpaa_eth.c:277:_dpa_rx_error() ## _dpa_rx_error,277 fd->status = 0x00040000
[ 109.809071] fsl_dpa soc:fsl,dpaa:ethernet@0 eth0: Err FD status = 0x00040000
[ 109.816146] fsl_dpa: dpaa_eth.c:277:_dpa_rx_error() ## _dpa_rx_error,277 fd->status = 0x00040000
[ 111.314119] fsl_dpa soc:fsl,dpaa:ethernet@0 eth0: Err FD status = 0x00040000
/ # ifconfig eth0
eth0 Link encap:Ethernet HWaddr 00:01:02:03:07:09
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:0 errors:87 dropped:0 overruns:0 frame:0
TX packets:9 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:686 (686.0 B)
Memory:1ae4000-1ae4fff
这是什么情况?
June_Lu
Please kindly share the MPU part number and SW version.
June_Lu
wangss
/ # ethtool eth0
Settings for eth0:
Supported ports: [ MII ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Full
Supported pause frame use: Symmetric Receive-only
Supports auto-negotiation: Yes
Supported FEC modes: Not reported
Advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
Advertised pause frame use: Symmetric Receive-only
Advertised auto-negotiation: Yes
Advertised FEC modes: Not reported
Link partner advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
Link partner advertised pause frame use: No
Link partner advertised auto-negotiation: Yes
Link partner advertised FEC modes: Not reported
Speed: 1000Mb/s
Duplex: Full
Port: Twisted Pair
PHYAD: 1
Transceiver: internal
Auto-negotiation: on
MDI-X: Unknown
Supports Wake-on: d
Wake-on: d
Current message level: 0xffffffff (-1)
drv probe link timer ifdown ifup rx_err tx_err tx_queued intr tx_done rx_status pktdata hw wol 0xffff8000
Link detected: yes
wangss
Kernel log:
[ 47.741385] fsl_dpa: dpaa_eth.c:271:_dpa_rx_error() fsl-dpa: non-zero error counters in fman statistics (sysfs)
[ 244.808044] net_ratelimit: 1 callbacks suppressed
[ 250.555742] net_ratelimit: 1 callbacks suppressed
/ # ethtool -S eth0
NIC statistics:
interrupts [CPU 0]: 24
interrupts [CPU 1]: 25
interrupts [TOTAL]: 49
rx packets [CPU 0]: 0
rx packets [CPU 1]: 0
rx packets [TOTAL]: 0
tx packets [CPU 0]: 9
tx packets [CPU 1]: 0
tx packets [TOTAL]: 9
tx recycled [CPU 0]: 0
tx recycled [CPU 1]: 0
tx recycled [TOTAL]: 0
tx confirm [CPU 0]: 5
tx confirm [CPU 1]: 4
tx confirm [TOTAL]: 9
tx S/G [CPU 0]: 0
tx S/G [CPU 1]: 0
tx S/G [TOTAL]: 0
rx S/G [CPU 0]: 0
rx S/G [CPU 1]: 0
rx S/G [TOTAL]: 0
tx error [CPU 0]: 0
tx error [CPU 1]: 0
tx error [TOTAL]: 0
rx error [CPU 0]: 19
rx error [CPU 1]: 21
rx error [TOTAL]: 40
bp count [CPU 0]: 128
bp count [CPU 1]: 128
bp count [TOTAL]: 256
rx dma error: 0
rx frame physical error: 1
rx frame size error: 39
rx header error: 0
rx csum error: 0
qman cg_tdrop: 0
qman wred: 0
qman error cond: 0
qman early window: 0
qman late window: 0
qman fq tdrop: 0
qman fq retired: 0
qman orp disabled: 0
congestion time (ms): 0
entered congestion: 0
congested (0/1): 0
The Ethernet port eth0 , display information using ethtool . Why do all the packages fail to be received?
wangss
SOC : LS1023a
Uboot: U-Boot 2017.11
firmware: fsl_fman_ucode_ls1043a_r1.1_106_4_18.bin
Linux Kernel: 6.6.52
%3CLINGO-SUB%20id%3D%22lingo-sub-2158894%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3Edpa_rx_error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2158894%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3EAfter%20the%20system%20boots%20up%2C%20the%20Ethernet%20network%20port%20receives%20packet%20errors%20with%20the%20following%20log%20messages%3A%3C%2FP%3E%3CP%3E%20107.313509%5D%20fsl_dpa%20soc%3Afsl%2Cdpaa%3Aethernet%400%20eth0%3A%20Err%20FD%20status%20%3D%200x00040000%20%3CBR%20%2F%3E%5B%20107.316456%5D%20fsl_dpa%3A%20dpaa_eth.c%3A271%3A_dpa_rx_error()%20fsl-dpa%3A%20non-zero%20error%20counters%20in%20fman%20statistics%20(sysfs)%20%3CBR%20%2F%3E%5B%20107.320588%5D%20fsl_dpa%3A%20dpaa_eth.c%3A277%3A_dpa_rx_error()%20%23%23%20_dpa_rx_error%2C277%20fd-%26gt%3Bstatus%20%3D%200x00040000%3CBR%20%2F%3E%5B%20107.330676%5D%20fsl_dpa%3A%20dpaa_eth.c%3A277%3A_dpa_rx_error()%20%23%23%20_dpa_rx_error%2C277%20fd-%20%26gt%3Bstatus%20%3D%200x00080000%20%3CBR%20%2F%3E%5B%20107.617825%5D%20fsl_dpa%3A%20dpaa_eth.c%3A277%3A_dpa_rx_error()%20%23%23%20_dpa_rx_error%2C277%20fd-%26gt%3Bstatus%20%3D%200x00040000%3CBR%20%2F%3E%5B%20108.517028%5D%20net_ratelimit%3A%201%20callbacks%20suppressed%3CBR%20%2F%3E%5B%20108.521757%5D%20fsl_dpa%20soc%3Afsl%2Cdpaa%3Aethernet%400%20eth0%3A%20Err%20FD%20status%20%3D%200x00040000%3CBR%20%2F%3E%5B%20108.528821%5D%20fsl_dpa%3A%20dpaa_eth.c%3A277%3A_dpa_rx_error()%20%23%23%20_dpa_rx_error%2C277%20fd-%20%26gt%3Bstatus%20%3D%200x00040000%20%3CBR%20%2F%3E%5B%20108.802778%5D%20fsl_dpa%20soc%3Afsl%2Cdpaa%3Aethernet%400%20eth0%3A%20Err%20FD%20status%20%3D%200x00040000%20%3CBR%20%2F%3E%5B%20108.809854%5D%20fsl_dpa%3A%20dpaa%20_eth.c%3A277%3A_dpa_rx_error()%20%23%23%20_dpa_rx_error%2C277%20fd-%26gt%3Bstatus%20%3D%200x00040000%3CBR%20%2F%3E%5B%20109.517864%5D%20fsl_dpa%20soc%3Afsl%2Cdpaa%3Aethernet%400%20eth0%3A%20Err%20FD%20status%20%3D%200x00040000%3CBR%20%2F%3E%5B%20109.524932%5D%20fsl_dpa%3A%20dpaa_eth.c%3A277%3A_dpa_rx_error()%20%23%23%20_dpa_rx_error%2C277%20fd-%20%26gt%3Bstatus%20%3D%200x00040000%20%3CBR%20%2F%3E%5B%20109.809071%5D%20fsl_dpa%20soc%3Afsl%2Cdpaa%3Aethernet%400%20eth0%3A%20Err%20FD%20status%20%3D%200x00040000%20%3CBR%20%2F%3E%5B%20109.816146%5D%20fsl_dpa%3A%20dpaa%20_eth.c%3A277%3A_dpa_rx_error()%20%23%23%20_dpa_rx_error%2C277%20fd-%20%26gt%3Bstatus%20%3D%200x00040000%20%3CBR%20%2F%3E%5B%20111.314119%5D%20fsl_dpa%20soc%3Afsl%2Cdpaa%3Aethernet%400%20eth0%3A%20Err%20FD%20status%20%3D%200x00040000%3C%2FP%3E%3CP%3E%2F%20%23%20ifconfig%20eth0%20%3CBR%20%2F%3Eeth0%20Link%20encap%3AEthernet%20HWaddr%2000%3A01%3A02%3A03%3A07%3A09%20%3CBR%20%2F%3EUP%20BROADCAST%20RUNNING%20MULTICAST%20MTU%3A1500%20Metric%3A1%20%3CBR%20%2F%3ERX%20packets%3A0%20errors%3A87%20dropped.%200%20overruns%3A0%20frame%3A0%20%3CBR%20%2F%3ETX%20packets%3A9%20errors%3A0%20dropped%3A0%20overruns%3A0%20carrier%3A0%20%3CBR%20%2F%3Ecollisions%3A0%20txqueuelen%3A1000%20%3CBR%20%2F%3ERX%20bytes%3A0%20(0.0%20B)%20TX%20bytes%3A686%20(686.0%20B)%20%3CBR%20%2F%3EMemory%3A1ae4000-1ae4fff%3C%2FP%3E%3CP%3EWhat's%20going%20on%20here%3F%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2159830%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20dpa_rx_error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2159830%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%2F%20%23%20ethtool%20eth0%3CBR%20%2F%3ESettings%20for%20eth0%3A%3CBR%20%2F%3ESupported%20ports%3A%20%5B%20MII%20%5D%3CBR%20%2F%3ESupported%20link%20modes%3A%2010baseT%2FHalf%2010baseT%2FFull%3CBR%20%2F%3E100baseT%2FHalf%20100baseT%2FFull%3CBR%20%2F%3E1000baseT%2FFull%3CBR%20%2F%3ESupported%20pause%20frame%20use%3A%20Symmetric%20Receive-only%3CBR%20%2F%3ESupports%20auto-negotiation%3A%20Yes%3CBR%20%2F%3ESupported%20FEC%20modes%3A%20Not%20reported%3CBR%20%2F%3EAdvertised%20link%20modes%3A%2010baseT%2FHalf%2010baseT%2FFull%3CBR%20%2F%3E100baseT%2FHalf%20100baseT%2FFull%3CBR%20%2F%3E1000baseT%2FFull%3CBR%20%2F%3EAdvertised%20pause%20frame%20use%3A%20Symmetric%20Receive-only%3CBR%20%2F%3EAdvertised%20auto-negotiation%3A%20Yes%3CBR%20%2F%3EAdvertised%20FEC%20modes%3A%20Not%20reported%3CBR%20%2F%3ELink%20partner%20advertised%20link%20modes%3A%2010baseT%2FHalf%2010baseT%2FFull%3CBR%20%2F%3E100baseT%2FHalf%20100baseT%2FFull%3CBR%20%2F%3E1000baseT%2FFull%3CBR%20%2F%3ELink%20partner%20advertised%20pause%20frame%20use%3A%20No%3CBR%20%2F%3ELink%20partner%20advertised%20auto-negotiation%3A%20Yes%3CBR%20%2F%3ELink%20partner%20advertised%20FEC%20modes%3A%20Not%20reported%3CBR%20%2F%3ESpeed%3A%201000Mb%2Fs%3CBR%20%2F%3EDuplex%3A%20Full%3CBR%20%2F%3EPort%3A%20Twisted%20Pair%3CBR%20%2F%3EPHYAD%3A%201%3CBR%20%2F%3ETransceiver%3A%20internal%3CBR%20%2F%3EAuto-negotiation%3A%20on%3CBR%20%2F%3EMDI-X%3A%20Unknown%3CBR%20%2F%3ESupports%20Wake-on%3A%20d%3CBR%20%2F%3EWake-on%3A%20d%3CBR%20%2F%3ECurrent%20message%20level%3A%200xffffffff%20(-1)%3CBR%20%2F%3Edrv%20probe%20link%20timer%20ifdown%20ifup%20rx_err%20tx_err%20tx_queued%20intr%20tx_done%20rx_status%20pktdata%20hw%20wol%200xffff8000%3CBR%20%2F%3ELink%20detected%3A%20yes%3CBR%20%2F%3E%2F%20%23%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2159811%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20dpa_rx_error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2159811%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ESOC%20%3A%20LS1023a%3CBR%20%2F%3EUboot%3A%20U-Boot%202017.11%3CBR%20%2F%3Efirmware%3A%20fsl_fman_ucode_ls1043a_r1.1_106_4_18.bin%3CBR%20%2F%3ELinux%20Kernel%3A%206.6.52%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2159809%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20dpa_rx_error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2159809%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3EPlease%20kindly%20share%20the%20MPU%20part%20number%20and%20SW%20version.%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%20lang%3D%22en-US%22%3EThanks%3C%2FP%3E%3C%2FLINGO-BODY%3E
