c29x ssl offload
c29x ssl offload
wujm
i have a c29x card for ssl offload ( openssl nginx ), my machine is dell r620
my question is
1、when ". ./fsl-setup-env -m ", which should i choose , p4080ds or c293pcie
2、after "bitbake fsl-image-core",what should i do,
make u-boot (follow c29x skmm user manual )
or direct follow openssl offload user's guide (qoriq-sdk-2.0-ic-rev0.pdf)
can you give me some advice, more details
Pavel
  1. Use the following command:
. ./fsl-setup-env -m c293pcie
  1. Use command sequence from the Sections 9.6.2 or 9.6.3 of the SDK 2.0-1701 documentation:
http://www.nxp.com/assets/documents/data/en/supporting-information/QORIQ-SDK-2.0-IC-REV0.pdf
Pavel Chubakov
