VxWorks endpoint detection
nikhitha
Hi, I am working on MIL 1553 communication between BU-67302B0C0L-202 and T2080 based SBC board in Linux environment. Linux BIOS will do enumeration process and it identifies my Endpoint device automatically. In VxWorks. endpoint is not detecting.
PCIE is detecting. 1553 is connected through PCIE transceiver only. But still PCIE is detected. But end point is not detected
Tags (3)
Oswalag
We only provide direct support for NXP SDK.
Please address your issue to Wind River technical support if you are using VxWorks.
