Re: T2080RDB FRA DORRBELL
zhuzhuxia11
你好,
我想要运行fra测试程序,通过testspeed发送srio doorbell到对端设备。
运行fra程序我使用的命令如下:
fra -r -f /usr/etc/fra_config_dstr_testspeed_txpoint.xml
testspeed的测试命令如下:
testspeed send 1024 1 0
但是在我运行testspeed时,出现了如下错误
Qman ErrInt: Invalid Enqueue State
Testspeed: succeQman ErrInt: DCP id 4
ssful loop timesQman ErrInt: ecir.fqid 0x0
is 0
上面是我的RCW和设备树中关于srio及rman节点的配置
Tags (3)
zhuzhuxia11
请问,有其他关于rman dooebell的例程可以提供测试吗
petervlna
Moving this thread to QorIQ community.
zhuzhuxia11
万分感谢
%3CLINGO-SUB%20id%3D%22lingo-sub-2170237%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20t2080rdb%20fra%20dorrbell%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2170237%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3EHi%2C%20%3CBR%20%2F%3EI%20want%20to%20run%20the%20fra%20test%20program%20to%20send%20srio%20doorbell%20to%20the%20opposite%20device%20via%20testspeed.%20%3CBR%20%2F%3ETo%20run%20the%20fra%20program%20I%20use%20the%20following%20command%3A%20%3CBR%20%2F%3Efra%20-r%20-f%20%2Fusr%2Fetc%2Ffra_config_dstr_testspeed_txpoint.xml%20%3CBR%20%2F%3EThe%20test%20command%20for%20testspeed%20is%20as%20follows%3A%20%3CBR%20%2F%3Etestspeed%20send%201024%201%200%20%3CBR%20%2F%3EBut%20when%20I%20run%20testspeed%2C%20I%20get%20the%20following%20error%20%3CBR%20%2F%3EQman%20ErrInt%3A%20Invalid%20Enqueue%20State%20%3CBR%20%2F%3ETestspeed%3A%20succeQman%20ErrInt%3A%20DCP%20id%204%20%3CBR%20%2F%3Essful%20loop%20timesQman%20ErrInt%3A%20ecir.fqid%200x0%20%3CBR%20%2F%3Eis%200%20%3CBR%20%2F%3E%3CBR%20%2F%3EAbove%20is%20my%20RCW%20and%20device%20tree%20configuration%20for%20srio%20and%20rman%20nodes%20%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2170985%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20T2080RDB%20FRA%20DORRBELL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2170985%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3EPlease%2C%20are%20there%20any%20other%20routines%20for%20rman%20dooebell%20that%20you%20can%20provide%20for%20testing%3F%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2170983%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20T2080RDB%20FRA%20DORRBELL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2170983%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3Eextremely%20grateful%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2170897%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20T2080RDB%20FRA%20DORRBELL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2170897%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EMoving%20this%20thread%20to%20QorIQ%20community.%3C%2FP%3E%3C%2FLINGO-BODY%3E
