Questions about fw_printenv
1,990件の閲覧回数
songhee_yun
Hello~
I use lx2160ardb board and sd card by changing the DIP switch(SW1:1111->1000).
I added the env tool(fw_printenv/fw_setenv) build configuration in u-boot and ran this command after kernel boot.
This tool get flexSPI environment value, not sd card env.
I want to get sd card env.
How can i do?
and default mtd part(flexSpi) has 0 and 1. what's different?
1,850件の閲覧回数
songhee_yun
I solve this problem. i can edit config at u-boot environment!
i changed value in lx2160a_common.h
CONFIG_SYS_MMC_ENV_DEV 0 -> 1
and edit fw_env.config like this
/dev/mmcblk0   0x500000 0x2000
