Power on reset sequence
1,774件の閲覧回数
rachanatm
We are using P1022NXN2LFB processor in our design. After power on, HRESET_B will be deasserted as it is pulled up. Once all the power supplies and system clock are stable, HRESET_B gets asserted by an active device for a minimum of 25us. Please let me know whether this scheme work?  or is it required to deassert all the supplies and SYS_CLK once HRESET_B gets asserted by an active device after power on and to assert power supplies, system clock and HRESET_B in sequence.
1,538件の閲覧回数
LPP
During power ramp, you must keep HRESET asserted until all the power rails are valid.
Futher, once the power is good, HRESET can be asserted by reset logic at any time. Power supplies need not to be turned off during reset.
Pavel
